[U-Boot] [ARM] RFC: Add board support for Colorado Engineering TK1-SOM
This patch adds support for the TK1-SOM board, which is almost the same as the Jetson TK1. Board info at https://tk1som.com/products/tk1-som
Query: Is this the best way to support this board? Or is there an easy way to merge the necessary changes into the Jetson-TK1 board? The main differences are in the pinmux and device tree. And the device tree is maybe 10 lines different.
Signed-off-by: Peter Chubb peter.chubb@data61.csiro.au --- arch/arm/dts/Makefile | 1 + arch/arm/dts/tegra124-tk1-som.dts | 477 +++++++++++++++++++++++++++ arch/arm/mach-tegra/tegra124/Kconfig | 11 + board/nvidia/tk1-som/Kconfig | 12 + board/nvidia/tk1-som/MAINTAINERS | 6 + board/nvidia/tk1-som/Makefile | 9 + board/nvidia/tk1-som/pinmux-config-tk1-som.h | 289 ++++++++++++++++ board/nvidia/tk1-som/tk1-som.c | 76 +++++ board/nvidia/venice2/as3722_init.h | 4 +- configs/tk1-som_defconfig | 55 +++ include/configs/tk1-som.h | 69 ++++ 11 files changed, 1007 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/tegra124-tk1-som.dts create mode 100644 board/nvidia/tk1-som/Kconfig create mode 100644 board/nvidia/tk1-som/MAINTAINERS create mode 100644 board/nvidia/tk1-som/Makefile create mode 100644 board/nvidia/tk1-som/pinmux-config-tk1-som.h create mode 100644 board/nvidia/tk1-som/tk1-som.c create mode 100644 configs/tk1-som_defconfig create mode 100644 include/configs/tk1-som.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 223124e..999d847 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -57,6 +57,7 @@ dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra114-dalmore.dtb \ tegra124-jetson-tk1.dtb \ tegra124-nyan-big.dtb \ + tegra124-tk1-som.dtb \ tegra124-venice2.dtb \ tegra186-p2771-0000-a02.dtb \ tegra186-p2771-0000-b00.dtb \ diff --git a/arch/arm/dts/tegra124-tk1-som.dts b/arch/arm/dts/tegra124-tk1-som.dts new file mode 100644 index 0000000..ee77353 --- /dev/null +++ b/arch/arm/dts/tegra124-tk1-som.dts @@ -0,0 +1,477 @@ +/dts-v1/; + +#include "tegra124.dtsi" + +/ { + model = "NVIDIA Jetson TK1"; + compatible = "nvidia,jetson-tk1", "nvidia,tegra124"; + + chosen { + stdout-path = &uartd; + }; + + aliases { + i2c0 = "/i2c@7000d000"; + i2c1 = "/i2c@7000c000"; + i2c2 = "/i2c@7000c400"; + i2c3 = "/i2c@7000c500"; + i2c4 = "/i2c@7000c700"; + sdhci0 = "/sdhci@700b0600"; + sdhci1 = "/sdhci@700b0400"; + spi0 = "/spi@7000d400"; + spi1 = "/spi@7000da00"; + usb0 = "/usb@7d000000"; + usb1 = "/usb@7d008000"; + }; + + memory { + device_type = "memory"; + reg = <0x80000000 0x80000000>; + }; + + pcie-controller@01003000 { + status = "okay"; + + avddio-pex-supply = <&vdd_1v05_run>; + dvddio-pex-supply = <&vdd_1v05_run>; + avdd-pex-pll-supply = <&vdd_1v05_run>; + hvdd-pex-supply = <&vdd_3v3_lp0>; + hvdd-pex-pll-e-supply = <&vdd_3v3_lp0>; + vddio-pex-ctl-supply = <&vdd_3v3_lp0>; + avdd-pll-erefe-supply = <&avdd_1v05_run>; + + pci@1,0 { + status = "okay"; + nvidia,num-lanes = <4>; + }; + + pci@2,0 { + status = "okay"; + }; + }; + + i2c@7000c000 { + status = "okay"; + clock-frequency = <100000>; + }; + + i2c@7000c400 { + status = "okay"; + clock-frequency = <100000>; + }; + + i2c@7000c500 { + status = "okay"; + clock-frequency = <100000>; + }; + + i2c@7000c700 { + status = "okay"; + clock-frequency = <100000>; + }; + + /* Expansion PWR_I2C_*, on-board components */ + i2c@7000d000 { + status = "okay"; + clock-frequency = <400000>; + + pmic: pmic@40 { + compatible = "ams,as3722"; + reg = <0x40>; + interrupts = <0 86 IRQ_TYPE_LEVEL_HIGH>; + + ams,system-power-controller; + + #interrupt-cells = <2>; + interrupt-controller; + + gpio-controller; + #gpio-cells = <2>; + + pinctrl-names = "default"; + pinctrl-0 = <&as3722_default>; + + as3722_default: pinmux { + gpio0 { + pins = "gpio0"; + function = "gpio"; + bias-pull-down; + }; + + gpio1_2_4_7 { + pins = "gpio1", "gpio2", "gpio4", "gpio7"; + function = "gpio"; + bias-pull-up; + }; + + gpio3_5_6 { + pins = "gpio3", "gpio5", "gpio6"; + bias-high-impedance; + }; + }; + + regulators { + vsup-sd2-supply = <&vdd_5v0_sys>; + vsup-sd3-supply = <&vdd_5v0_sys>; + vsup-sd4-supply = <&vdd_5v0_sys>; + vsup-sd5-supply = <&vdd_5v0_sys>; + vin-ldo0-supply = <&vdd_1v35_lp0>; + vin-ldo1-6-supply = <&vdd_3v3_run>; + vin-ldo2-5-7-supply = <&vddio_1v8>; + vin-ldo3-4-supply = <&vdd_3v3_sys>; + vin-ldo9-10-supply = <&vdd_5v0_sys>; + vin-ldo11-supply = <&vdd_3v3_run>; + + sd0 { + regulator-name = "+VDD_CPU_AP"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1400000>; + regulator-min-microamp = <3500000>; + regulator-max-microamp = <3500000>; + regulator-always-on; + regulator-boot-on; + ams,ext-control = <2>; + }; + + sd1 { + regulator-name = "+VDD_CORE"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + regulator-min-microamp = <2500000>; + regulator-max-microamp = <2500000>; + regulator-always-on; + regulator-boot-on; + ams,ext-control = <1>; + }; + + vdd_1v35_lp0: sd2 { + regulator-name = "+1.35V_LP0(sd2)"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + }; + + sd3 { + regulator-name = "+1.35V_LP0(sd3)"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_1v05_run: sd4 { + regulator-name = "+1.05V_RUN"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + }; + + vddio_1v8: sd5 { + regulator-name = "+1.8V_VDDIO"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + vdd_gpu: sd6 { + regulator-name = "+VDD_GPU_AP"; + regulator-min-microvolt = <650000>; + regulator-max-microvolt = <1200000>; + regulator-min-microamp = <3500000>; + regulator-max-microamp = <3500000>; + regulator-boot-on; + regulator-always-on; + }; + + avdd_1v05_run: ldo0 { + regulator-name = "+1.05V_RUN_AVDD"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + regulator-boot-on; + regulator-always-on; + ams,ext-control = <1>; + }; + + ldo1 { + regulator-name = "+1.8V_RUN_CAM"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + ldo2 { + regulator-name = "+1.2V_GEN_AVDD"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3 { + regulator-name = "+1.05V_LP0_VDD_RTC"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-boot-on; + regulator-always-on; + ams,enable-tracking; + }; + + ldo4 { + regulator-name = "+2.8V_RUN_CAM"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + }; + + ldo5 { + regulator-name = "+1.2V_RUN_CAM_FRONT"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + }; + + vddio_sdmmc3: ldo6 { + regulator-name = "+VDDIO_SDMMC3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + + ldo7 { + regulator-name = "+1.05V_RUN_CAM_REAR"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + }; + + ldo9 { + regulator-name = "+3.3V_RUN_TOUCH"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + }; + + ldo10 { + regulator-name = "+2.8V_RUN_CAM_AF"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + }; + + ldo11 { + regulator-name = "+1.8V_RUN_VPP_FUSE"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + }; + }; + }; + + i2c@7000d100 { + status = "okay"; + clock-frequency = <400000>; + }; + + spi@7000d400 { + status = "okay"; + spi-max-frequency = <25000000>; + }; + + spi@7000da00 { + status = "okay"; + spi-max-frequency = <25000000>; + }; + + padctl@7009f000 { + pinctrl-0 = <&padctl_default>; + pinctrl-names = "default"; + + padctl_default: pinmux { + usb3 { + nvidia,lanes = "sata-0"; + nvidia,function = "usb3"; + nvidia,iddq = <0>; + }; + + pcie { + nvidia,lanes = "pcie-0", "pcie-1", "pcie-2", "pcie-3", + "pcie-4"; + nvidia,function = "pcie"; + nvidia,iddq = <0>; + }; + + }; + }; + + sdhci@700b0400 { + status = "okay"; + cd-gpios = <&gpio TEGRA_GPIO(V, 2) GPIO_ACTIVE_LOW>; + power-gpios = <&gpio TEGRA_GPIO(R, 0) GPIO_ACTIVE_HIGH>; + wp-gpios = <&gpio TEGRA_GPIO(Q, 4) GPIO_ACTIVE_HIGH>; + bus-width = <4>; + }; + + sdhci@700b0600 { + status = "okay"; + bus-width = <8>; + }; + + usb@7d000000 { + status = "okay"; + dr_mode = "otg"; + nvidia,vbus-gpio = <&gpio TEGRA_GPIO(N, 4) GPIO_ACTIVE_HIGH>; + }; + + usb@7d008000 { + status = "okay"; + nvidia,vbus-gpio = <&gpio TEGRA_GPIO(N, 5) GPIO_ACTIVE_HIGH>; + }; + + clocks { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + clk32k_in: clock@0 { + compatible = "fixed-clock"; + reg = <0>; + #clock-cells = <0>; + clock-frequency = <32768>; + }; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + vdd_mux: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "+VDD_MUX"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_5v0_sys: regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "+5V_SYS"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vdd_mux>; + }; + + vdd_3v3_sys: regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "+3.3V_SYS"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vdd_mux>; + }; + + vdd_3v3_run: regulator@3 { + compatible = "regulator-fixed"; + reg = <3>; + regulator-name = "+3.3V_RUN"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + gpio = <&pmic 1 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_3v3_sys>; + }; + + vdd_3v3_hdmi: regulator@4 { + compatible = "regulator-fixed"; + reg = <4>; + regulator-name = "+3.3V_AVDD_HDMI_AP_GATED"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vdd_3v3_run>; + }; + + vdd_usb1_vbus: regulator@7 { + compatible = "regulator-fixed"; + reg = <7>; + regulator-name = "+USB0_VBUS_SW"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio TEGRA_GPIO(N, 4) GPIO_ACTIVE_HIGH>; + enable-active-high; + gpio-open-drain; + vin-supply = <&vdd_5v0_sys>; + }; + + vdd_usb3_vbus: regulator@8 { + compatible = "regulator-fixed"; + reg = <8>; + regulator-name = "+5V_USB_HS"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio TEGRA_GPIO(N, 5) GPIO_ACTIVE_HIGH>; + enable-active-high; + gpio-open-drain; + vin-supply = <&vdd_5v0_sys>; + }; + + vdd_3v3_lp0: regulator@10 { + compatible = "regulator-fixed"; + reg = <10>; + regulator-name = "+3.3V_LP0"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + gpio = <&pmic 2 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_3v3_sys>; + }; + + vdd_hdmi_pll: regulator@11 { + compatible = "regulator-fixed"; + reg = <11>; + regulator-name = "+1.05V_RUN_AVDD_HDMI_PLL"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + gpio = <&gpio TEGRA_GPIO(H, 7) GPIO_ACTIVE_LOW>; + vin-supply = <&vdd_1v05_run>; + }; + + vdd_5v0_hdmi: regulator@12 { + compatible = "regulator-fixed"; + reg = <12>; + regulator-name = "+5V_HDMI_CON"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio TEGRA_GPIO(K, 6) GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_5v0_sys>; + }; + + /* Molex power connector */ + vdd_5v0_sata: regulator@13 { + compatible = "regulator-fixed"; + reg = <13>; + regulator-name = "+5V_SATA"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio TEGRA_GPIO(EE, 2) GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_5v0_sys>; + }; + + vdd_12v0_sata: regulator@14 { + compatible = "regulator-fixed"; + reg = <14>; + regulator-name = "+12V_SATA"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + gpio = <&gpio TEGRA_GPIO(EE, 2) GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_mux>; + }; + }; +}; diff --git a/arch/arm/mach-tegra/tegra124/Kconfig b/arch/arm/mach-tegra/tegra124/Kconfig index f3324ff..9075820 100644 --- a/arch/arm/mach-tegra/tegra124/Kconfig +++ b/arch/arm/mach-tegra/tegra124/Kconfig @@ -9,6 +9,16 @@ config TARGET_JETSON_TK1 select CPU_V7_HAS_NONSEC if !SPL_BUILD select CPU_V7_HAS_VIRT if !SPL_BUILD
+config TARGET_TK1_SOM + bool "Colorado/NVIDIA Tegra124 TK1-som board" + select CPU_V7_HAS_NONSEC if !SPL_BUILD + select CPU_V7_HAS_VIRT if !SPL_BUILD + help + The Tegra TK1-SOM is a very compact (51mmx58mm) board that + is functionally almost the same as the Jetson TK1. The main + differences are in which balls on the SoC are assigned to + which functions. + config TARGET_NYAN_BIG bool "Google/NVIDIA Nyan-big Chromebook" help @@ -27,6 +37,7 @@ config SYS_SOC default "tegra124"
source "board/nvidia/jetson-tk1/Kconfig" +source "board/nvidia/tk1-som/Kconfig" source "board/nvidia/nyan-big/Kconfig" source "board/nvidia/venice2/Kconfig"
diff --git a/board/nvidia/tk1-som/Kconfig b/board/nvidia/tk1-som/Kconfig new file mode 100644 index 0000000..2094b67 --- /dev/null +++ b/board/nvidia/tk1-som/Kconfig @@ -0,0 +1,12 @@ +if TARGET_TK1_SOM + +config SYS_BOARD + default "tk1-som" + +config SYS_VENDOR + default "nvidia" + +config SYS_CONFIG_NAME + default "tk1-som" + +endif diff --git a/board/nvidia/tk1-som/MAINTAINERS b/board/nvidia/tk1-som/MAINTAINERS new file mode 100644 index 0000000..ed94b07 --- /dev/null +++ b/board/nvidia/tk1-som/MAINTAINERS @@ -0,0 +1,6 @@ +TK1-SOM BOARD +M: Peter.Chubb@data61.csiro.au +S: Maintained +F: board/nvidia/tk1-som/ +F: include/configs/tk1=som.h +F: configs/tk1-som_defconfig diff --git a/board/nvidia/tk1-som/Makefile b/board/nvidia/tk1-som/Makefile new file mode 100644 index 0000000..fb32338 --- /dev/null +++ b/board/nvidia/tk1-som/Makefile @@ -0,0 +1,9 @@ +# +# (C) Copyright 2014 +# NVIDIA Corporation <www.nvidia.com> +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += ../venice2/as3722_init.o +obj-y += tk1-som.o diff --git a/board/nvidia/tk1-som/pinmux-config-tk1-som.h b/board/nvidia/tk1-som/pinmux-config-tk1-som.h new file mode 100644 index 0000000..170a7ee --- /dev/null +++ b/board/nvidia/tk1-som/pinmux-config-tk1-som.h @@ -0,0 +1,289 @@ +/* + * Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* + * THIS FILE IS AUTO-GENERATED - DO NOT EDIT! + * + * To generate this file, use the tegra-pinmux-scripts tool available from + * https://github.com/NVIDIA/tegra-pinmux-scripts + * Run "board-to-uboot.py tk1-som". + */ + +#ifndef _PINMUX_CONFIG_TK1_SOM_H_ +#define _PINMUX_CONFIG_TK1_SOM_H_ + +#define GPIO_INIT(_port, _gpio, _init) \ + { \ + .gpio = TEGRA_GPIO(_port, _gpio), \ + .init = TEGRA_GPIO_INIT_##_init, \ + } + +static const struct tegra_gpio_config tk1_som_gpio_inits[] = { + /* port, pin, init_val */ + GPIO_INIT(G, 0, IN), + GPIO_INIT(G, 1, IN), + GPIO_INIT(G, 2, IN), + GPIO_INIT(G, 3, IN), + GPIO_INIT(G, 4, IN), + GPIO_INIT(H, 4, IN), + GPIO_INIT(H, 7, IN), + GPIO_INIT(I, 0, OUT0), + GPIO_INIT(I, 1, IN), + GPIO_INIT(I, 4, IN), + GPIO_INIT(I, 6, IN), + GPIO_INIT(J, 0, IN), + GPIO_INIT(J, 2, IN), + GPIO_INIT(K, 6, OUT0), + GPIO_INIT(N, 7, IN), + GPIO_INIT(O, 1, IN), + GPIO_INIT(O, 4, IN), + GPIO_INIT(Q, 0, IN), + GPIO_INIT(Q, 3, IN), + GPIO_INIT(R, 0, IN), + GPIO_INIT(R, 2, OUT0), + GPIO_INIT(R, 4, IN), + GPIO_INIT(R, 6, IN), + GPIO_INIT(S, 2, IN), + GPIO_INIT(S, 3, IN), + GPIO_INIT(S, 4, IN), + GPIO_INIT(S, 5, IN), + GPIO_INIT(S, 6, IN), + GPIO_INIT(S, 7, IN), + GPIO_INIT(T, 0, IN), + GPIO_INIT(T, 1, IN), + GPIO_INIT(V, 0, IN), + GPIO_INIT(V, 1, IN), + GPIO_INIT(X, 1, IN), + GPIO_INIT(X, 4, IN), + GPIO_INIT(BB, 3, OUT0), + GPIO_INIT(BB, 6, OUT0), + GPIO_INIT(CC, 1, IN), + GPIO_INIT(CC, 2, IN), +}; + +#define PINCFG(_pingrp, _mux, _pull, _tri, _io, _od, _rcv_sel) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .od = PMUX_PIN_OD_##_od, \ + .rcv_sel = PMUX_PIN_RCV_SEL_##_rcv_sel, \ + .lock = PMUX_PIN_LOCK_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +static const struct pmux_pingrp_config tk1_som_pingrps[] = { + /* pingrp, mux, pull, tri, e_input, od, rcv_sel */ + PINCFG(CLK_32K_OUT_PA0, SOC, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_CTS_N_PA1, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_FS_PA2, I2S1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_SCLK_PA3, I2S1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_DIN_PA4, I2S1, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_DOUT_PA5, I2S1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CLK_PA6, SDMMC3, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CMD_PA7, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PB0, UARTD, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PB1, UARTD, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT3_PB4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT2_PB5, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT1_PB6, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT0_PB7, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_RTS_N_PC0, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_TXD_PC2, IRDA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_RXD_PC3, IRDA, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PC7, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG0, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PG1, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PG2, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PG3, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PG4, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PG5, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG6, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG7, SPI4, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PH0, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH1, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH2, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH3, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH4, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PH5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH6, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH7, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PI0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI1, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PI2, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI3, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI4, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PI5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI6, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PI7, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PJ0, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PJ2, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(UART2_CTS_N_PJ5, UARTB, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(UART2_RTS_N_PJ6, UARTB, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PJ7, UARTD, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK0, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK1, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK2, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK3, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK4, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_OUT_PK5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_IN_PK6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK7, UARTD, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_FS_PN0, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_DIN_PN1, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_DOUT_PN2, I2S0, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_SCLK_PN3, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(USB_VBUS_EN0_PN4, USB, NORMAL, NORMAL, INPUT, DISABLE, DEFAULT), + PINCFG(USB_VBUS_EN1_PN5, USB, NORMAL, NORMAL, INPUT, DISABLE, DEFAULT), + PINCFG(HDMI_INT_PN7, DEFAULT, DOWN, TRISTATE, INPUT, DEFAULT, NORMAL), + PINCFG(ULPI_DATA7_PO0, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA0_PO1, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA1_PO2, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA2_PO3, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA3_PO4, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA4_PO5, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA5_PO6, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA6_PO7, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_FS_PP0, I2S2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DIN_PP1, I2S2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DOUT_PP2, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_SCLK_PP3, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_FS_PP4, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_DIN_PP5, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_DOUT_PP6, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_SCLK_PP7, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL0_PQ0, DEFAULT, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL1_PQ1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL2_PQ2, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL3_PQ3, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL4_PQ4, KBC, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL5_PQ5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL6_PQ6, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL7_PQ7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW0_PR0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW1_PR1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW2_PR2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW3_PR3, KBC, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW4_PR4, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW5_PR5, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW6_PR6, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW7_PR7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW8_PS0, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW9_PS1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW10_PS2, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW11_PS3, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW12_PS4, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW13_PS5, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW14_PS6, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW15_PS7, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW16_PT0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW17_PT1, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(GEN2_I2C_SCL_PT5, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(GEN2_I2C_SDA_PT6, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC4_CMD_PT7, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU0, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU1, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU2, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU3, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU4, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU5, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU6, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PV0, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PV1, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CD_N_PV2, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_WP_N_PV3, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DDC_SCL_PV4, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(DDC_SDA_PV5, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(GPIO_W2_AUD_PW2, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_W3_AUD_PW3, SPI6, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP_MCLK1_PW4, EXTPERIPH1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_OUT_PW5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART3_TXD_PW6, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART3_RXD_PW7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DVFS_PWM_PX0, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X1_AUD_PX1, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(DVFS_CLK_PX2, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X3_AUD_PX3, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X4_AUD_PX4, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X5_AUD_PX5, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X6_AUD_PX6, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X7_AUD_PX7, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_CLK_PY0, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DIR_PY1, SPI1, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_NXT_PY2, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_STP_PY3, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT3_PY4, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT2_PY5, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT1_PY6, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT0_PY7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_CLK_PZ0, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_CMD_PZ1, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PWR_I2C_SCL_PZ6, I2CPWR, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PWR_I2C_SDA_PZ7, I2CPWR, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC4_DAT0_PAA0, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT1_PAA1, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT2_PAA2, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT3_PAA3, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT4_PAA4, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT5_PAA5, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PBB0, VIMCLK2_ALT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CAM_I2C_SCL_PBB1, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(CAM_I2C_SDA_PBB2, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PBB3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB4, VGP4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB5, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CAM_MCLK_PCC0, VI_ALT3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PCC1, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PCC2, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_REQ_PCC5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L0_RST_N_PDD1, PE0, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L0_CLKREQ_N_PDD2, PE0, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PEX_WAKE_N_PDD3, PE, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L1_RST_N_PDD5, PE1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L1_CLKREQ_N_PDD6, PE1, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_OUT_PEE0, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_REQ_PEE1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP_MCLK1_REQ_PEE2, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(HDMI_CEC_PEE3, CEC, NORMAL, NORMAL, INPUT, DISABLE, DEFAULT), + PINCFG(SDMMC3_CLK_LB_OUT_PEE4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CLK_LB_IN_PEE5, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DP_HPD_PFF0, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(USB_VBUS_EN2_PFF1, RSVD2, DOWN, TRISTATE, OUTPUT, DISABLE, DEFAULT), + PINCFG(PFF2, RSVD2, DOWN, TRISTATE, OUTPUT, DISABLE, DEFAULT), + PINCFG(CORE_PWR_REQ, PWRON, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CPU_PWR_REQ, CPU, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PWR_INT_N, PMI, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(RESET_OUT_N, RESET_OUT_N, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(OWR, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, NORMAL), + PINCFG(CLK_32K_IN, CLK, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(JTAG_RTCK, RTCK, UP, NORMAL, OUTPUT, DEFAULT, DEFAULT), +}; + +#define DRVCFG(_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) \ + { \ + .drvgrp = PMUX_DRVGRP_##_drvgrp, \ + .slwf = _slwf, \ + .slwr = _slwr, \ + .drvup = _drvup, \ + .drvdn = _drvdn, \ + .lpmd = PMUX_LPMD_##_lpmd, \ + .schmt = PMUX_SCHMT_##_schmt, \ + .hsm = PMUX_HSM_##_hsm, \ + } + +static const struct pmux_drvgrp_config tk1_som_drvgrps[] = { +}; + +#endif /* PINMUX_CONFIG_TK1_SOM_H */ diff --git a/board/nvidia/tk1-som/tk1-som.c b/board/nvidia/tk1-som/tk1-som.c new file mode 100644 index 0000000..5d8d8fc --- /dev/null +++ b/board/nvidia/tk1-som/tk1-som.c @@ -0,0 +1,76 @@ +/* + * (C) Copyright 2014 + * NVIDIA Corporation <www.nvidia.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <power/as3722.h> + +#include <asm/arch/gpio.h> +#include <asm/arch/pinmux.h> + +#include "pinmux-config-tk1-som.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Routine: pinmux_init + * Description: Do individual peripheral pinmux configs + */ +void pinmux_init(void) +{ + pinmux_clear_tristate_input_clamping(); + + gpio_config_table(tk1_som_gpio_inits, + ARRAY_SIZE(tk1_som_gpio_inits)); + + pinmux_config_pingrp_table(tk1_som_pingrps, + ARRAY_SIZE(tk1_som_pingrps)); + + pinmux_config_drvgrp_table(tk1_som_drvgrps, + ARRAY_SIZE(tk1_som_drvgrps)); +} + +#ifdef CONFIG_PCI_TEGRA +int tegra_pcie_board_init(void) +{ + struct udevice *pmic; + int err; + + err = as3722_init(&pmic); + if (err) { + error("failed to initialize AS3722 PMIC: %d\n", err); + return err; + } + + err = as3722_sd_enable(pmic, 4); + if (err < 0) { + error("failed to enable SD4: %d\n", err); + return err; + } + + err = as3722_sd_set_voltage(pmic, 4, 0x24); + if (err < 0) { + error("failed to set SD4 voltage: %d\n", err); + return err; + } + + err = as3722_gpio_configure(pmic, 1, AS3722_GPIO_OUTPUT_VDDH | + AS3722_GPIO_INVERT); + if (err < 0) { + error("failed to configure GPIO#1 as output: %d\n", err); + return err; + } + + err = as3722_gpio_direction_output(pmic, 2, 1); + if (err < 0) { + error("failed to set GPIO#2 high: %d\n", err); + return err; + } + + + return 0; +} +#endif /* PCI */ diff --git a/board/nvidia/venice2/as3722_init.h b/board/nvidia/venice2/as3722_init.h index c6b1247..bf1d1ce 100644 --- a/board/nvidia/venice2/as3722_init.h +++ b/board/nvidia/venice2/as3722_init.h @@ -18,14 +18,14 @@ #define AS3722_LDO6VOLTAGE_REG 0x16 /* VDD_SDMMC */ #define AS3722_LDCONTROL_REG 0x4E
-#if defined(CONFIG_TARGET_JETSON_TK1) || defined(CONFIG_TARGET_NYAN_BIG) +#if defined(CONFIG_TARGET_JETSON_TK1) || defined(CONFIG_TARGET_NYAN_BIG) || defined(CONFIG_TARGET_TK1_SOM) #define AS3722_SD0VOLTAGE_DATA (0x3C00 | AS3722_SD0VOLTAGE_REG) #else #define AS3722_SD0VOLTAGE_DATA (0x2800 | AS3722_SD0VOLTAGE_REG) #endif #define AS3722_SD0CONTROL_DATA (0x0100 | AS3722_SDCONTROL_REG)
-#ifdef CONFIG_TARGET_JETSON_TK1 +#if defined(CONFIG_TARGET_JETSON_TK1) || defined(CONFIG_TARGET_TK1_SOM) #define AS3722_SD1VOLTAGE_DATA (0x2800 | AS3722_SD1VOLTAGE_REG) #define AS3722_SD1CONTROL_DATA (0x0200 | AS3722_SDCONTROL_REG) #endif diff --git a/configs/tk1-som_defconfig b/configs/tk1-som_defconfig new file mode 100644 index 0000000..a804efe --- /dev/null +++ b/configs/tk1-som_defconfig @@ -0,0 +1,55 @@ +CONFIG_ARM=y +CONFIG_TEGRA=y +CONFIG_SPL_DM=y +CONFIG_TEGRA124=y +CONFIG_TARGET_TK1_SOM=y +CONFIG_DEFAULT_DEVICE_TREE="tegra124-tk1-som" +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="tk1-som # " +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_RTL8169=y +CONFIG_PCI_TEGRA=y +CONFIG_SYS_NS16550=y +CONFIG_TEGRA114_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_GADGET=y +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="NVIDIA" +CONFIG_G_DNL_VENDOR_NUM=0x0955 +CONFIG_G_DNL_PRODUCT_NUM=0x701a +CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_CPU_V7_HAS_NONSEC=y +CONFIG_CPU_V7_HAS_VIRT=y +CONFIG_ARMV7_NONSEC=y +CONFIG_ARMV7_VIRT=y +CONFIG_SUPPORT_SPL=y +CONFIG_SPL=y +CONFIG_SPL_BUILD=y +CONFIG_ARMV7_PSCI=y diff --git a/include/configs/tk1-som.h b/include/configs/tk1-som.h new file mode 100644 index 0000000..c950a6c --- /dev/null +++ b/include/configs/tk1-som.h @@ -0,0 +1,69 @@ +/* + * (C) Copyright 2013-2014 + * NVIDIA Corporation <www.nvidia.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <linux/sizes.h> + +/* enable PMIC */ +#define CONFIG_AS3722_POWER + +#include "tegra124-common.h" + +/* High-level configuration options */ +#define CONFIG_TEGRA_BOARD_STRING "NVIDIA tk1-som" + +/* Board-specific serial config */ +#define CONFIG_TEGRA_ENABLE_UARTD +#define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTD_BASE + +/* I2C */ +#define CONFIG_SYS_I2C_TEGRA + +/* SD/MMC */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_TEGRA_MMC + +/* Environment in eMMC, at the end of 2nd "boot sector" */ +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_PART 2 + +/* SPI */ +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#define CONFIG_SF_DEFAULT_SPEED 24000000 +#define CONFIG_SPI_FLASH_SIZE (4 << 20) + +/* USB Host support */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_TEGRA +#define CONFIG_USB_STORAGE + +/* USB networking support */ +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX + +/* PCI host support */ +#define CONFIG_PCI +#define CONFIG_PCI_PNP +#define CONFIG_CMD_PCI + +/* General networking support */ + +#include "tegra-common-usb-gadget.h" +#include "tegra-common-post.h" + +#define CONFIG_ARMV7_PSCI 1 +#define CONFIG_ARMV7_PSCI_NR_CPUS 4 +/* Reserve top 1M for secure RAM */ +#define CONFIG_ARMV7_SECURE_BASE 0xfff00000 +#define CONFIG_ARMV7_SECURE_RESERVE_SIZE 0x00100000 + +#endif /* __CONFIG_H */
Nit: That blank line at start of the commit description should be removed.
tk1-som sounds like a rather generic name. I'm sure there are many boards that could be called that. Can we add the company name to the U-Boot board name? They seem to abbreviate themselves to CEI on their website, so cei-tk1-som seems like a reasonable name.
Having a separate top-level board identity seems reasonable if the HW is different. Judging by a diff between the files in this patch and the existing Jetson TK1 support, there are some differences, so I think this is all fine.
This isn't an NVIDIA board. I think that should be board/cei/tk1-som/Kconfig. Similar comment for most of the other files.
- bool "Colorado/NVIDIA Tegra124 TK1-som board"
I'd say "Colorado Engineering Inc. TK1-SOM"
- Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved.
- THIS FILE IS AUTO-GENERATED - DO NOT EDIT!
- To generate this file, use the tegra-pinmux-scripts tool available from
- Run "board-to-uboot.py tk1-som".
Did you generate this yourself, or extract it from some CEI U-Boot source tree? I ask because the file is obviously based on an old version of the pinmux spreadsheet and pinmux scripts (e.g. the unsupported OWR pin is configured, there's no tk1_som_mipipadctrlgrps variable, etc. If you generated this yourself, if you could update it based on the latest spreadsheet that'd be great. If you're just taking this from some CEI U-Boot source tree, then the commit description should mention this, and you likely need to preserve the original CEI authorship and Signed-off-by lines.
- err = as3722_gpio_configure(pmic, 1, AS3722_GPIO_OUTPUT_VDDH |
- if (err < 0) {
return err;
- err = as3722_gpio_direction_output(pmic, 2, 1);
- if (err < 0) {
return err;
Perhaps you could add a comment describing what that PMIC GPIO is used for, and hence why it's necessary to do this.
Actually, if you look at the history of jetson-tk1.c, you'll find commit 7fb82986be62 "ARM: tegra: rm Jetson TK1 PMIC GPIO programming" which implies that such PMIC GPIO programming should not be performed.
Nit: Two blank lines?
Hmm. Considering we have 3 boards taking the "if" path and I think just one taking the "else" path, I think it would be better to do the following instead:
#if defined(CONFIG_TARGET_VENICE2) // existing else value #else // existing if value #endif
... since Venice2 is an odd-ball board that likely few people have, and almost any new board we support will be derived from Jetson TK1 and hence also take the "if" path in the existing code.
None of those are in jetson-tk1_defconfig. Was this addition deliberate?
"Stephen" == Stephen Warren swarren@wwwdotorg.org writes:
Stephen> Nit: That blank line at start of the commit description Stephen> should be removed.
OK.
Stephen> tk1-som sounds like a rather generic name. I'm sure there are Stephen> many boards that could be called that. Can we add the company Stephen> name to the U-Boot board name? They seem to abbreviate Stephen> themselves to CEI on their website, so cei-tk1-som seems like Stephen> a reasonable name.
OK, will do.
Stephen> Having a separate top-level board identity seems reasonable Stephen> if the HW is different. Judging by a diff between the files Stephen> in this patch and the existing Jetson TK1 support, there are Stephen> some differences, so I think this is all fine.
Stephen> This isn't an NVIDIA board. I think that should be Stephen> board/cei/tk1-som/Kconfig. Similar comment for most of the Stephen> other files.
OK.
Stephen> I'd say "Colorado Engineering Inc. TK1-SOM"
OK.
Stephen> Did you generate this yourself, or extract it from some CEI Stephen> U-Boot source tree? I ask because the file is obviously based Stephen> on an old version of the pinmux spreadsheet and pinmux Stephen> scripts (e.g. the unsupported OWR pin is configured, there's Stephen> no tk1_som_mipipadctrlgrps variable, etc. If you generated Stephen> this yourself, if you could update it based on the latest Stephen> spreadsheet that'd be great. If you're just taking this from Stephen> some CEI U-Boot source tree, then the commit description Stephen> should mention this, and you likely need to preserve the Stephen> original CEI authorship and Signed-off-by lines.
I generated this myself from a spreadsheet provided by Colorado Engineering and the current tegra-pinmux-scripts. Is there any easy way to see the differences in versions between the one this was based on (v09 of the upstream NVIDIA sheet) and the current v11 one to be able to transform the spreadsheet?
Stephen> Perhaps you could add a comment describing what that PMIC Stephen> GPIO is used for, and hence why it's necessary to do this.
Stephen> Actually, if you look at the history of jetson-tk1.c, you'll Stephen> find commit 7fb82986be62 "ARM: tegra: rm Jetson TK1 PMIC GPIO Stephen> programming" which implies that such PMIC GPIO programming Stephen> should not be performed.
It was in the upstream Colorado-supplied U-Boot; I'll test without it.
Stephen> Nit: Two blank lines? OK.
Stephen> Hmm. Considering we have 3 boards taking the "if" path and I Stephen> think just one taking the "else" path, I think it would be Stephen> better to do the following instead:
Stephen> #if defined(CONFIG_TARGET_VENICE2) // existing else value Stephen> #else // existing if value #endif
OK. The alternative is to have a third symbol to test on, a feature-test macro rather than a board macro.
Stephen> None of those are in jetson-tk1_defconfig. Was this addition Stephen> deliberate?
Yes, except the USE_PRIVATE_LIBGCC which I think is an error. The main use-case I have for the board is for virtualisation; enabling booting in nonsec mode is essential for this. And it's harmless, as the feature has to be enabled via an environment variable.
Peter C
Probably the easiest way is to save the v9 and v11 versions of the Jetson TK1 spreadsheet as CSV, and then diff that. There are tons of columns in the spreadsheet that aren't terribly relevant though, so the lines will be long and hard to interpret. It might be better to go through the whole process of importing v9 and v11 into tegra-pinmux-scripts, which will extract just the useful information, and then diff the data files there. That should give a list of changes you can use to bring the v9-based TK1 SOM spreadsheet up to match the v11 spreadsheet.
BTW, I meant to mention: can you also send a patch to tegra-pinmux-scripts to add support for this board there too?
Yes, looks like that's in the original Jetson TK1 spreadsheet too. I assume the mistake you're referring to is that I mentioned that config option in my mail as being added by you? Having that option enabled is necessary for the U-Boot SPL to work, unless your toolchain's libc is built for a very old instruction set, and we don't want to require people to use only such toolchains.
Peter Chubb
Stephen Warren
