[U-Boot] [PATCH 07/19] ColdFire: Modules header files cleanup - 6
Consolidate FlexBus structures and definitions in immap_5xxx.h and m5xxx.h to more unify modules header files. Apply changes to mcf52x2's cpu_init.c
Signed-off-by: TsiChung Liew Tsi-Chung.Liew@freescale.com --- cpu/mcf52x2/cpu_init.c | 271 ++++++++++------------------------ include/asm-m68k/coldfire/flexbus.h | 96 ++++++++----- include/asm-m68k/immap_5235.h | 52 +------- include/asm-m68k/immap_5249.h | 2 + include/asm-m68k/immap_5253.h | 2 + include/asm-m68k/immap_5271.h | 1 + include/asm-m68k/immap_5275.h | 46 +------ include/asm-m68k/immap_5282.h | 52 +------- include/asm-m68k/m5235.h | 40 ----- include/asm-m68k/m5249.h | 13 -- include/asm-m68k/m5282.h | 23 --- include/asm-m68k/m5329.h | 59 -------- include/configs/EB+MCF-EV123.h | 16 +-- include/configs/M5235EVB.h | 10 +- include/configs/M5249EVB.h | 14 +- include/configs/M5253DEMO.h | 24 +-- include/configs/M5253EVBE.h | 20 +-- include/configs/M5275EVB.h | 14 +- include/configs/M5282EVB.h | 18 +-- include/configs/TASREG.h | 14 +- 20 files changed, 196 insertions(+), 591 deletions(-)
diff --git a/cpu/mcf52x2/cpu_init.c b/cpu/mcf52x2/cpu_init.c index 7bb358e..32ad6cd 100644 --- a/cpu/mcf52x2/cpu_init.c +++ b/cpu/mcf52x2/cpu_init.c @@ -36,6 +36,65 @@ #include <watchdog.h> #include <asm/immap.h>
+#ifndef CONFIG_M5272 +/* Only 5272 Flexbus chipselect is different from the rest */ +void init_fbcs(void) +{ + volatile fbcs_t *fbcs = (fbcs_t *) (MMAP_FBCS); + +#if (defined(CONFIG_SYS_CS0_BASE) && defined(CONFIG_SYS_CS0_MASK) \ + && defined(CONFIG_SYS_CS0_CTRL)) + fbcs->csar0 = CONFIG_SYS_CS0_BASE; + fbcs->cscr0 = CONFIG_SYS_CS0_CTRL; + fbcs->csmr0 = CONFIG_SYS_CS0_MASK; +#else +#warning "Chip Select 0 are not initialized/used" +#endif +#if (defined(CONFIG_SYS_CS1_BASE) && defined(CONFIG_SYS_CS1_MASK) \ + && defined(CONFIG_SYS_CS1_CTRL)) + fbcs->csar1 = CONFIG_SYS_CS1_BASE; + fbcs->cscr1 = CONFIG_SYS_CS1_CTRL; + fbcs->csmr1 = CONFIG_SYS_CS1_MASK; +#endif +#if (defined(CONFIG_SYS_CS2_BASE) && defined(CONFIG_SYS_CS2_MASK) \ + && defined(CONFIG_SYS_CS2_CTRL)) + fbcs->csar2 = CONFIG_SYS_CS2_BASE; + fbcs->cscr2 = CONFIG_SYS_CS2_CTRL; + fbcs->csmr2 = CONFIG_SYS_CS2_MASK; +#endif +#if (defined(CONFIG_SYS_CS3_BASE) && defined(CONFIG_SYS_CS3_MASK) \ + && defined(CONFIG_SYS_CS3_CTRL)) + fbcs->csar3 = CONFIG_SYS_CS3_BASE; + fbcs->cscr3 = CONFIG_SYS_CS3_CTRL; + fbcs->csmr3 = CONFIG_SYS_CS3_MASK; +#endif +#if (defined(CONFIG_SYS_CS4_BASE) && defined(CONFIG_SYS_CS4_MASK) \ + && defined(CONFIG_SYS_CS4_CTRL)) + fbcs->csar4 = CONFIG_SYS_CS4_BASE; + fbcs->cscr4 = CONFIG_SYS_CS4_CTRL; + fbcs->csmr4 = CONFIG_SYS_CS4_MASK; +#endif +#if (defined(CONFIG_SYS_CS5_BASE) && defined(CONFIG_SYS_CS5_MASK) \ + && defined(CONFIG_SYS_CS5_CTRL)) + fbcs->csar5 = CONFIG_SYS_CS5_BASE; + fbcs->cscr5 = CONFIG_SYS_CS5_CTRL; + fbcs->csmr5 = CONFIG_SYS_CS5_MASK; +#endif +#if (defined(CONFIG_SYS_CS6_BASE) && defined(CONFIG_SYS_CS6_MASK) \ + && defined(CONFIG_SYS_CS6_CTRL)) + fbcs->csar6 = CONFIG_SYS_CS6_BASE; + fbcs->cscr6 = CONFIG_SYS_CS6_CTRL; + fbcs->csmr6 = CONFIG_SYS_CS6_MASK; +#endif +#if (defined(CONFIG_SYS_CS7_BASE) && defined(CONFIG_SYS_CS7_MASK) \ + && defined(CONFIG_SYS_CS7_CTRL)) + fbcs->csar7 = CONFIG_SYS_CS7_BASE; + fbcs->cscr7 = CONFIG_SYS_CS7_CTRL; + fbcs->csmr7 = CONFIG_SYS_CS7_MASK; +#endif +} +#endif + #if defined(CONFIG_M5253) /* * Breath some life into the CPU... @@ -66,22 +125,14 @@ void cpu_init_f(void) mbar2_writeByte(MCFSIM_INTBASE, 0x40); /* Base interrupts at 64 */ mbar2_writeByte(MCFSIM_SPURVEC, 0x00);
- /*mbar2_writeLong(MCFSIM_IDECONFIG1, 0x00000020); */ /* Enable a 1 cycle pre-drive cycle on CS1 */ - - /* - * Setup chip selects... - */ - - mbar_writeShort(MCFSIM_CSAR1, CONFIG_SYS_CSAR1); - mbar_writeShort(MCFSIM_CSCR1, CONFIG_SYS_CSCR1); - mbar_writeLong(MCFSIM_CSMR1, CONFIG_SYS_CSMR1); + /*mbar2_writeLong(MCFSIM_IDECONFIG1, 0x00000020); *//* Enable a 1 cycle pre-drive cycle on CS1 */
- mbar_writeShort(MCFSIM_CSAR0, CONFIG_SYS_CSAR0); - mbar_writeShort(MCFSIM_CSCR0, CONFIG_SYS_CSCR0); - mbar_writeLong(MCFSIM_CSMR0, CONFIG_SYS_CSMR0); + /* FlexBus Chipselect */ + init_fbcs();
#ifdef CONFIG_FSL_I2C - CONFIG_SYS_I2C_PINMUX_REG = CONFIG_SYS_I2C_PINMUX_REG & CONFIG_SYS_I2C_PINMUX_CLR; + CONFIG_SYS_I2C_PINMUX_REG = + CONFIG_SYS_I2C_PINMUX_REG & CONFIG_SYS_I2C_PINMUX_CLR; CONFIG_SYS_I2C_PINMUX_REG |= CONFIG_SYS_I2C_PINMUX_SET; #ifdef CONFIG_SYS_I2C2_OFFSET CONFIG_SYS_I2C2_PINMUX_REG &= CONFIG_SYS_I2C2_PINMUX_CLR; @@ -121,6 +172,9 @@ void cpu_init_f(void) mbar_writeShort(MCF_WTM_WCR, 0); #endif
+ /* FlexBus Chipselect */ + init_fbcs(); + /* Set clockspeed to 100MHz */ mbar_writeShort(MCF_FMPLL_SYNCR, MCF_FMPLL_SYNCR_MFD(0) | MCF_FMPLL_SYNCR_RFD(0)); @@ -268,66 +322,20 @@ void uart_port_conf(void) */ void cpu_init_f(void) { - /* if we come from RAM we assume the CPU is + /* + * if we come from RAM we assume the CPU is * already initialized. */
#ifndef CONFIG_MONITOR_IS_IN_RAM - volatile wdog_t *wdog_reg = (wdog_t *)(MMAP_WDOG); - volatile gpio_t *gpio_reg = (gpio_t *)(MMAP_GPIO); - volatile csctrl_t *csctrl_reg = (csctrl_t *)(MMAP_FBCS); + volatile wdog_t *wdog_reg = (wdog_t *) (MMAP_WDOG); + volatile gpio_t *gpio_reg = (gpio_t *) (MMAP_GPIO);
/* Kill watchdog so we can initialize the PLL */ wdog_reg->wcr = 0;
- /* Memory Controller: */ - /* Flash */ - csctrl_reg->ar0 = CONFIG_SYS_AR0_PRELIM; - csctrl_reg->cr0 = CONFIG_SYS_CR0_PRELIM; - csctrl_reg->mr0 = CONFIG_SYS_MR0_PRELIM; - -#if (defined(CONFIG_SYS_AR1_PRELIM) && defined(CONFIG_SYS_CR1_PRELIM) && defined(CONFIG_SYS_MR1_PRELIM)) - csctrl_reg->ar1 = CONFIG_SYS_AR1_PRELIM; - csctrl_reg->cr1 = CONFIG_SYS_CR1_PRELIM; - csctrl_reg->mr1 = CONFIG_SYS_MR1_PRELIM; -#endif - -#if (defined(CONFIG_SYS_AR2_PRELIM) && defined(CONFIG_SYS_CR2_PRELIM) && defined(CONFIG_SYS_MR2_PRELIM)) - csctrl_reg->ar2 = CONFIG_SYS_AR2_PRELIM; - csctrl_reg->cr2 = CONFIG_SYS_CR2_PRELIM; - csctrl_reg->mr2 = CONFIG_SYS_MR2_PRELIM; -#endif - -#if (defined(CONFIG_SYS_AR3_PRELIM) && defined(CONFIG_SYS_CR3_PRELIM) && defined(CONFIG_SYS_MR3_PRELIM)) - csctrl_reg->ar3 = CONFIG_SYS_AR3_PRELIM; - csctrl_reg->cr3 = CONFIG_SYS_CR3_PRELIM; - csctrl_reg->mr3 = CONFIG_SYS_MR3_PRELIM; -#endif - -#if (defined(CONFIG_SYS_AR4_PRELIM) && defined(CONFIG_SYS_CR4_PRELIM) && defined(CONFIG_SYS_MR4_PRELIM)) - csctrl_reg->ar4 = CONFIG_SYS_AR4_PRELIM; - csctrl_reg->cr4 = CONFIG_SYS_CR4_PRELIM; - csctrl_reg->mr4 = CONFIG_SYS_MR4_PRELIM; -#endif - -#if (defined(CONFIG_SYS_AR5_PRELIM) && defined(CONFIG_SYS_CR5_PRELIM) && defined(CONFIG_SYS_MR5_PRELIM)) - csctrl_reg->ar5 = CONFIG_SYS_AR5_PRELIM; - csctrl_reg->cr5 = CONFIG_SYS_CR5_PRELIM; - csctrl_reg->mr5 = CONFIG_SYS_MR5_PRELIM; -#endif - -#if (defined(CONFIG_SYS_AR6_PRELIM) && defined(CONFIG_SYS_CR6_PRELIM) && defined(CONFIG_SYS_MR6_PRELIM)) - csctrl_reg->ar6 = CONFIG_SYS_AR6_PRELIM; - csctrl_reg->cr6 = CONFIG_SYS_CR6_PRELIM; - csctrl_reg->mr6 = CONFIG_SYS_MR6_PRELIM; -#endif - -#if (defined(CONFIG_SYS_AR7_PRELIM) && defined(CONFIG_SYS_CR7_PRELIM) && defined(CONFIG_SYS_MR7_PRELIM)) - csctrl_reg->ar7 = CONFIG_SYS_AR7_PRELIM; - csctrl_reg->cr7 = CONFIG_SYS_CR7_PRELIM; - csctrl_reg->mr7 = CONFIG_SYS_MR7_PRELIM; -#endif - + /* FlexBus Chipselect */ + init_fbcs(); #endif /* #ifndef CONFIG_MONITOR_IS_IN_RAM */
#ifdef CONFIG_FSL_I2C @@ -349,7 +357,7 @@ int cpu_init_r(void)
void uart_port_conf(void) { - volatile gpio_t *gpio = (gpio_t *)MMAP_GPIO; + volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO;
/* Setup Ports: */ switch (CONFIG_SYS_UART_PORT) { @@ -384,7 +392,8 @@ void cpu_init_f(void) #ifndef CONFIG_MONITOR_IS_IN_RAM /* Set speed /PLL */ MCFCLOCK_SYNCR = - MCFCLOCK_SYNCR_MFD(CONFIG_SYS_MFD) | MCFCLOCK_SYNCR_RFD(CONFIG_SYS_RFD); + MCFCLOCK_SYNCR_MFD(CONFIG_SYS_MFD) | + MCFCLOCK_SYNCR_RFD(CONFIG_SYS_RFD); while (!(MCFCLOCK_SYNSR & MCFCLOCK_SYNSR_LOCK)) ;
MCFGPIO_PBCDPAR = 0xc0; @@ -425,119 +434,8 @@ void cpu_init_f(void) MCFGPIO_DDRUA = CONFIG_SYS_DDRUA; #endif
- /* This is probably a bad place to setup chip selects, but everyone - else is doing it! */ - -#if defined(CONFIG_SYS_CS0_BASE) & defined(CONFIG_SYS_CS0_SIZE) & \ - defined(CONFIG_SYS_CS0_WIDTH) & defined(CONFIG_SYS_CS0_WS) - - MCFCSM_CSAR0 = (CONFIG_SYS_CS0_BASE >> 16) & 0xFFFF; - -#if (CONFIG_SYS_CS0_WIDTH == 8) -#define CONFIG_SYS_CS0_PS MCFCSM_CSCR_PS_8 -#elif (CONFIG_SYS_CS0_WIDTH == 16) -#define CONFIG_SYS_CS0_PS MCFCSM_CSCR_PS_16 -#elif (CONFIG_SYS_CS0_WIDTH == 32) -#define CONFIG_SYS_CS0_PS MCFCSM_CSCR_PS_32 -#else -#error "CONFIG_SYS_CS0_WIDTH: Fault - wrong bus with for CS0" -#endif - MCFCSM_CSCR0 = MCFCSM_CSCR_WS(CONFIG_SYS_CS0_WS) - | CONFIG_SYS_CS0_PS | MCFCSM_CSCR_AA; - -#if (CONFIG_SYS_CS0_RO != 0) - MCFCSM_CSMR0 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS0_SIZE - 1) - | MCFCSM_CSMR_WP | MCFCSM_CSMR_V; -#else - MCFCSM_CSMR0 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS0_SIZE - 1) | MCFCSM_CSMR_V; -#endif -#else -#warning "Chip Select 0 are not initialized/used" -#endif - -#if defined(CONFIG_SYS_CS1_BASE) & defined(CONFIG_SYS_CS1_SIZE) & \ - defined(CONFIG_SYS_CS1_WIDTH) & defined(CONFIG_SYS_CS1_WS) - - MCFCSM_CSAR1 = (CONFIG_SYS_CS1_BASE >> 16) & 0xFFFF; - -#if (CONFIG_SYS_CS1_WIDTH == 8) -#define CONFIG_SYS_CS1_PS MCFCSM_CSCR_PS_8 -#elif (CONFIG_SYS_CS1_WIDTH == 16) -#define CONFIG_SYS_CS1_PS MCFCSM_CSCR_PS_16 -#elif (CONFIG_SYS_CS1_WIDTH == 32) -#define CONFIG_SYS_CS1_PS MCFCSM_CSCR_PS_32 -#else -#error "CONFIG_SYS_CS1_WIDTH: Fault - wrong bus with for CS1" -#endif - MCFCSM_CSCR1 = MCFCSM_CSCR_WS(CONFIG_SYS_CS1_WS) - | CONFIG_SYS_CS1_PS | MCFCSM_CSCR_AA; - -#if (CONFIG_SYS_CS1_RO != 0) - MCFCSM_CSMR1 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS1_SIZE - 1) - | MCFCSM_CSMR_WP | MCFCSM_CSMR_V; -#else - MCFCSM_CSMR1 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS1_SIZE - 1) - | MCFCSM_CSMR_V; -#endif -#else -#warning "Chip Select 1 are not initialized/used" -#endif - -#if defined(CONFIG_SYS_CS2_BASE) & defined(CONFIG_SYS_CS2_SIZE) & \ - defined(CONFIG_SYS_CS2_WIDTH) & defined(CONFIG_SYS_CS2_WS) - - MCFCSM_CSAR2 = (CONFIG_SYS_CS2_BASE >> 16) & 0xFFFF; - -#if (CONFIG_SYS_CS2_WIDTH == 8) -#define CONFIG_SYS_CS2_PS MCFCSM_CSCR_PS_8 -#elif (CONFIG_SYS_CS2_WIDTH == 16) -#define CONFIG_SYS_CS2_PS MCFCSM_CSCR_PS_16 -#elif (CONFIG_SYS_CS2_WIDTH == 32) -#define CONFIG_SYS_CS2_PS MCFCSM_CSCR_PS_32 -#else -#error "CONFIG_SYS_CS2_WIDTH: Fault - wrong bus with for CS2" -#endif - MCFCSM_CSCR2 = MCFCSM_CSCR_WS(CONFIG_SYS_CS2_WS) - | CONFIG_SYS_CS2_PS | MCFCSM_CSCR_AA; - -#if (CONFIG_SYS_CS2_RO != 0) - MCFCSM_CSMR2 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS2_SIZE - 1) - | MCFCSM_CSMR_WP | MCFCSM_CSMR_V; -#else - MCFCSM_CSMR2 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS2_SIZE - 1) - | MCFCSM_CSMR_V; -#endif -#else -#warning "Chip Select 2 are not initialized/used" -#endif - -#if defined(CONFIG_SYS_CS3_BASE) & defined(CONFIG_SYS_CS3_SIZE) & \ - defined(CONFIG_SYS_CS3_WIDTH) & defined(CONFIG_SYS_CS3_WS) - - MCFCSM_CSAR3 = (CONFIG_SYS_CS3_BASE >> 16) & 0xFFFF; - -#if (CONFIG_SYS_CS3_WIDTH == 8) -#define CONFIG_SYS_CS3_PS MCFCSM_CSCR_PS_8 -#elif (CONFIG_SYS_CS3_WIDTH == 16) -#define CONFIG_SYS_CS3_PS MCFCSM_CSCR_PS_16 -#elif (CONFIG_SYS_CS3_WIDTH == 32) -#define CONFIG_SYS_CS3_PS MCFCSM_CSCR_PS_32 -#else -#error "CONFIG_SYS_CS3_WIDTH: Fault - wrong bus with for CS1" -#endif - MCFCSM_CSCR3 = MCFCSM_CSCR_WS(CONFIG_SYS_CS3_WS) - | CONFIG_SYS_CS3_PS | MCFCSM_CSCR_AA; - -#if (CONFIG_SYS_CS3_RO != 0) - MCFCSM_CSMR3 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS3_SIZE - 1) - | MCFCSM_CSMR_WP | MCFCSM_CSMR_V; -#else - MCFCSM_CSMR3 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS3_SIZE - 1) - | MCFCSM_CSMR_V; -#endif -#else -#warning "Chip Select 3 are not initialized/used" -#endif + /* FlexBus Chipselect */ + init_fbcs();
#endif /* CONFIG_MONITOR_IS_IN_RAM */
@@ -632,17 +530,8 @@ void cpu_init_f(void) mbar2_writeLong(MCFSIM_IDECONFIG1, 0x00000020); mbar2_writeLong(MCFSIM_IDECONFIG2, 0x00000000);
- /* - * Setup chip selects... - */ - - mbar_writeShort(MCFSIM_CSAR1, CONFIG_SYS_CSAR1); - mbar_writeShort(MCFSIM_CSCR1, CONFIG_SYS_CSCR1); - mbar_writeLong(MCFSIM_CSMR1, CONFIG_SYS_CSMR1); - - mbar_writeShort(MCFSIM_CSAR0, CONFIG_SYS_CSAR0); - mbar_writeShort(MCFSIM_CSCR0, CONFIG_SYS_CSCR0); - mbar_writeLong(MCFSIM_CSMR0, CONFIG_SYS_CSMR0); + /* FlexBus Chipselect */ + init_fbcs();
/* enable instruction cache now */ icache_enable(); diff --git a/include/asm-m68k/coldfire/flexbus.h b/include/asm-m68k/coldfire/flexbus.h index 1d902c0..51cbbd8 100644 --- a/include/asm-m68k/coldfire/flexbus.h +++ b/include/asm-m68k/coldfire/flexbus.h @@ -31,33 +31,36 @@ *********************************************************************/
typedef struct fbcs { - u32 csar0; /* Chip-select Address Register */ - u32 csmr0; /* Chip-select Mask Register */ - u32 cscr0; /* Chip-select Control Register */ - u32 csar1; /* Chip-select Address Register */ - u32 csmr1; /* Chip-select Mask Register */ - u32 cscr1; /* Chip-select Control Register */ - u32 csar2; /* Chip-select Address Register */ - u32 csmr2; /* Chip-select Mask Register */ - u32 cscr2; /* Chip-select Control Register */ - u32 csar3; /* Chip-select Address Register */ - u32 csmr3; /* Chip-select Mask Register */ - u32 cscr3; /* Chip-select Control Register */ - u32 csar4; /* Chip-select Address Register */ - u32 csmr4; /* Chip-select Mask Register */ - u32 cscr4; /* Chip-select Control Register */ - u32 csar5; /* Chip-select Address Register */ - u32 csmr5; /* Chip-select Mask Register */ - u32 cscr5; /* Chip-select Control Register */ + u32 csar0; /* Chip-select Address */ + u32 csmr0; /* Chip-select Mask */ + u32 cscr0; /* Chip-select Control */ + u32 csar1; + u32 csmr1; + u32 cscr1; + u32 csar2; + u32 csmr2; + u32 cscr2; + u32 csar3; + u32 csmr3; + u32 cscr3; + u32 csar4; + u32 csmr4; + u32 cscr4; + u32 csar5; + u32 csmr5; + u32 cscr5; + u32 csar6; + u32 csmr6; + u32 cscr6; + u32 csar7; + u32 csmr7; + u32 cscr7; } fbcs_t;
-/* Bit definitions and macros for CSAR group */ -#define FBCS_CSAR_BA(x) ((x)&0xFFFF0000) +#define FBCS_CSAR_BA(x) ((x) & 0xFFFF0000)
-/* Bit definitions and macros for CSMR group */ -#define FBCS_CSMR_V (0x00000001) /* Valid bit */ -#define FBCS_CSMR_WP (0x00000100) /* Write protect */ -#define FBCS_CSMR_BAM(x) (((x)&0x0000FFFF)<<16) /* Base address mask */ +#define FBCS_CSMR_BAM(x) (((x) & 0xFFFF) << 16) +#define FBCS_CSMR_BAM_MASK (0x0000FFFF) #define FBCS_CSMR_BAM_4G (0xFFFF0000) #define FBCS_CSMR_BAM_2G (0x7FFF0000) #define FBCS_CSMR_BAM_1G (0x3FFF0000) @@ -78,21 +81,40 @@ typedef struct fbcs { #define FBCS_CSMR_BAM_128K (0x00010000) #define FBCS_CSMR_BAM_64K (0x00000000)
-/* Bit definitions and macros for CSCR group */ -#define FBCS_CSCR_BSTW (0x00000008) /* Burst-write enable */ -#define FBCS_CSCR_BSTR (0x00000010) /* Burst-read enable */ -#define FBCS_CSCR_BEM (0x00000020) /* Byte-enable mode */ -#define FBCS_CSCR_PS(x) (((x)&0x00000003)<<6) /* Port size */ -#define FBCS_CSCR_AA (0x00000100) /* Auto-acknowledge */ -#define FBCS_CSCR_WS(x) (((x)&0x0000003F)<<10) /* Wait states */ -#define FBCS_CSCR_WRAH(x) (((x)&0x00000003)<<16) /* Write address hold or deselect */ -#define FBCS_CSCR_RDAH(x) (((x)&0x00000003)<<18) /* Read address hold or deselect */ -#define FBCS_CSCR_ASET(x) (((x)&0x00000003)<<20) /* Address setup */ -#define FBCS_CSCR_SWSEN (0x00800000) /* Secondary wait state enable */ -#define FBCS_CSCR_SWS(x) (((x)&0x0000003F)<<26) /* Secondary wait states */ +#ifdef CONFIG_M5249 +#define FBCS_CSMR_WP (0x00000080) +#define FBCS_CSMR_AM (0x00000040) +#define FBCS_CSMR_CI (0x00000020) +#define FBCS_CSMR_SC (0x00000010) +#define FBCS_CSMR_SD (0x00000008) +#define FBCS_CSMR_UC (0x00000004) +#define FBCS_CSMR_UD (0x00000002) +#else +#define FBCS_CSMR_WP (0x00000100) +#endif +#define FBCS_CSMR_V (0x00000001) /* Valid bit */ + +#define FBCS_CSCR_SWS(x) (((x) & 0x3F) << 26) +#define FBCS_CSCR_SWS_MASK (0x03FFFFFF) +#define FBCS_CSCR_SWSEN (0x00800000) +#define FBCS_CSCR_ASET(x) (((x) & 0x03) << 20) +#define FBCS_CSCR_ASET_MASK (0xFFCFFFFF) +#define FBCS_CSCR_RDAH(x) (((x) & 0x03) << 18) +#define FBCS_CSCR_RDAH_MASK (0xFFF3FFFF) +#define FBCS_CSCR_WRAH(x) (((x) & 0x03) << 16) +#define FBCS_CSCR_WRAH_MASK (0xFFFCFFFF) +#define FBCS_CSCR_WS(x) (((x) & 0x3F) << 10) +#define FBCS_CSCR_WS_MASK (0xFFFF03FF) +#define FBCS_CSCR_SBM (0x00000200) +#define FBCS_CSCR_AA (0x00000100) +#define FBCS_CSCR_PS(x) (((x) & 0x03) << 6) +#define FBCS_CSCR_PS_MASK (0xFFFFFF3F) +#define FBCS_CSCR_BEM (0x00000020) +#define FBCS_CSCR_BSTR (0x00000010) +#define FBCS_CSCR_BSTW (0x00000008)
-#define FBCS_CSCR_PS_8 (0x00000040) #define FBCS_CSCR_PS_16 (0x00000080) +#define FBCS_CSCR_PS_8 (0x00000040) #define FBCS_CSCR_PS_32 (0x00000000)
#endif /* __FLEXBUS_H */ diff --git a/include/asm-m68k/immap_5235.h b/include/asm-m68k/immap_5235.h index a987121..f7f35fc 100644 --- a/include/asm-m68k/immap_5235.h +++ b/include/asm-m68k/immap_5235.h @@ -64,6 +64,7 @@ #define MMAP_CAN2 (CONFIG_SYS_MBAR + 0x001F0000)
#include <asm/coldfire/eport.h> +#include <asm/coldfire/flexbus.h> #include <asm/coldfire/flexcan.h> #include <asm/coldfire/intctrl.h> #include <asm/coldfire/mdha.h> @@ -112,57 +113,6 @@ typedef struct sdram_ctrl { u32 dmr1; /* 0x14 mask register block 1 */ } sdram_t;
-/* Flexbus module Chip select registers */ -typedef struct fbcs_ctrl { - u16 csar0; /* 0x00 Chip-Select Address Register 0 */ - u16 res0; - u32 csmr0; /* 0x04 Chip-Select Mask Register 0 */ - u16 res1; /* 0x08 */ - u16 cscr0; /* 0x0A Chip-Select Control Register 0 */ - - u16 csar1; /* 0x0C Chip-Select Address Register 1 */ - u16 res2; - u32 csmr1; /* 0x10 Chip-Select Mask Register 1 */ - u16 res3; /* 0x14 */ - u16 cscr1; /* 0x16 Chip-Select Control Register 1 */ - - u16 csar2; /* 0x18 Chip-Select Address Register 2 */ - u16 res4; - u32 csmr2; /* 0x1C Chip-Select Mask Register 2 */ - u16 res5; /* 0x20 */ - u16 cscr2; /* 0x22 Chip-Select Control Register 2 */ - - u16 csar3; /* 0x24 Chip-Select Address Register 3 */ - u16 res6; - u32 csmr3; /* 0x28 Chip-Select Mask Register 3 */ - u16 res7; /* 0x2C */ - u16 cscr3; /* 0x2E Chip-Select Control Register 3 */ - - u16 csar4; /* 0x30 Chip-Select Address Register 4 */ - u16 res8; - u32 csmr4; /* 0x34 Chip-Select Mask Register 4 */ - u16 res9; /* 0x38 */ - u16 cscr4; /* 0x3A Chip-Select Control Register 4 */ - - u16 csar5; /* 0x3C Chip-Select Address Register 5 */ - u16 res10; - u32 csmr5; /* 0x40 Chip-Select Mask Register 5 */ - u16 res11; /* 0x44 */ - u16 cscr5; /* 0x46 Chip-Select Control Register 5 */ - - u16 csar6; /* 0x48 Chip-Select Address Register 5 */ - u16 res12; - u32 csmr6; /* 0x4C Chip-Select Mask Register 5 */ - u16 res13; /* 0x50 */ - u16 cscr6; /* 0x52 Chip-Select Control Register 5 */ - - u16 csar7; /* 0x54 Chip-Select Address Register 5 */ - u16 res14; - u32 csmr7; /* 0x58 Chip-Select Mask Register 5 */ - u16 res15; /* 0x5C */ - u16 cscr7; /* 0x5E Chip-Select Control Register 5 */ -} fbcs_t; - typedef struct canex_ctrl { can_msg_t msg[16]; /* 0x00 Message Buffer 0-15 */ } canex_t; diff --git a/include/asm-m68k/immap_5249.h b/include/asm-m68k/immap_5249.h index f4fedfd..0242086 100644 --- a/include/asm-m68k/immap_5249.h +++ b/include/asm-m68k/immap_5249.h @@ -26,12 +26,14 @@ #define __IMMAP_5249__
#define MMAP_INTC (CONFIG_SYS_MBAR + 0x00000040) +#define MMAP_FBCS (CONFIG_SYS_MBAR + 0x00000080) #define MMAP_DTMR0 (CONFIG_SYS_MBAR + 0x00000140) #define MMAP_DTMR1 (CONFIG_SYS_MBAR + 0x00000180) #define MMAP_UART0 (CONFIG_SYS_MBAR + 0x000001C0) #define MMAP_UART1 (CONFIG_SYS_MBAR + 0x00000200) #define MMAP_QSPI (CONFIG_SYS_MBAR + 0x00000400)
+#include <asm/coldfire/flexbus.h> #include <asm/coldfire/qspi.h>
#endif /* __IMMAP_5249__ */ diff --git a/include/asm-m68k/immap_5253.h b/include/asm-m68k/immap_5253.h index bf30189..b5a4cb5 100644 --- a/include/asm-m68k/immap_5253.h +++ b/include/asm-m68k/immap_5253.h @@ -27,6 +27,7 @@ #define __IMMAP_5253__
#define MMAP_INTC (CONFIG_SYS_MBAR + 0x00000040) +#define MMAP_FBCS (CONFIG_SYS_MBAR + 0x00000080) #define MMAP_DTMR0 (CONFIG_SYS_MBAR + 0x00000140) #define MMAP_DTMR1 (CONFIG_SYS_MBAR + 0x00000180) #define MMAP_UART0 (CONFIG_SYS_MBAR + 0x000001C0) @@ -40,6 +41,7 @@ #define MMAP_UART2 (CONFIG_SYS_MBAR2 + 0x00000C00)
#include <asm/coldfire/ata.h> +#include <asm/coldfire/flexbus.h> #include <asm/coldfire/flexcan.h> #include <asm/coldfire/qspi.h>
diff --git a/include/asm-m68k/immap_5271.h b/include/asm-m68k/immap_5271.h index 3576656..8ddec5c 100644 --- a/include/asm-m68k/immap_5271.h +++ b/include/asm-m68k/immap_5271.h @@ -64,6 +64,7 @@ #define MMAP_CAN2 (CONFIG_SYS_MBAR + 0x001F0000)
#include <asm/coldfire/eport.h> +#include <asm/coldfire/flexbus.h> #include <asm/coldfire/intctrl.h> #include <asm/coldfire/mdha.h> #include <asm/coldfire/qspi.h> diff --git a/include/asm-m68k/immap_5275.h b/include/asm-m68k/immap_5275.h index e04dd4e..46426a3 100644 --- a/include/asm-m68k/immap_5275.h +++ b/include/asm-m68k/immap_5275.h @@ -67,6 +67,7 @@ #define MMAP_PWM0 (CONFIG_SYS_MBAR + 0x001D0000)
#include <asm/coldfire/eport.h> +#include <asm/coldfire/flexbus.h> #include <asm/coldfire/intctrl.h> #include <asm/coldfire/mdha.h> #include <asm/coldfire/pwm.h> @@ -117,51 +118,6 @@ typedef struct sdram_ctrl { u32 sdbmr1; } sdramctrl_t;
-/* Chip select module registers, offset: 0x080 -*/ -typedef struct cs_ctlr { - u16 ar0; - u16 res1; - u32 mr0; - u16 res2; - u16 cr0; - u16 ar1; - u16 res3; - u32 mr1; - u16 res4; - u16 cr1; - u16 ar2; - u16 res5; - u32 mr2; - u16 res6; - u16 cr2; - u16 ar3; - u16 res7; - u32 mr3; - u16 res8; - u16 cr3; - u16 ar4; - u16 res9; - u32 mr4; - u16 res10; - u16 cr4; - u16 ar5; - u16 res11; - u32 mr5; - u16 res12; - u16 cr5; - u16 ar6; - u16 res13; - u32 mr6; - u16 res14; - u16 cr6; - u16 ar7; - u16 res15; - u32 mr7; - u16 res16; - u16 cr7; -} csctrl_t; - /* DMA module registers, offset 0x100 */ typedef struct dma_ctrl { diff --git a/include/asm-m68k/immap_5282.h b/include/asm-m68k/immap_5282.h index f0ae599..dd526a1 100644 --- a/include/asm-m68k/immap_5282.h +++ b/include/asm-m68k/immap_5282.h @@ -63,6 +63,7 @@ #define MMAP_CFMMEM (CONFIG_SYS_MBAR + 0x04000000)
#include <asm/coldfire/eport.h> +#include <asm/coldfire/flexbus.h> #include <asm/coldfire/flexcan.h> #include <asm/coldfire/intctrl.h> #include <asm/coldfire/qspi.h> @@ -101,57 +102,6 @@ typedef struct canex_ctrl { can_msg_t msg[16]; /* 0x00 Message Buffer 0-15 */ } canex_t;
-/* Flexbus module Chip select registers */ -typedef struct fbcs_ctrl { - u16 csar0; /* 0x00 Chip-Select Address Register 0 */ - u16 res0; - u32 csmr0; /* 0x04 Chip-Select Mask Register 0 */ - u16 res1; /* 0x08 */ - u16 cscr0; /* 0x0A Chip-Select Control Register 0 */ - - u16 csar1; /* 0x0C Chip-Select Address Register 1 */ - u16 res2; - u32 csmr1; /* 0x10 Chip-Select Mask Register 1 */ - u16 res3; /* 0x14 */ - u16 cscr1; /* 0x16 Chip-Select Control Register 1 */ - - u16 csar2; /* 0x18 Chip-Select Address Register 2 */ - u16 res4; - u32 csmr2; /* 0x1C Chip-Select Mask Register 2 */ - u16 res5; /* 0x20 */ - u16 cscr2; /* 0x22 Chip-Select Control Register 2 */ - - u16 csar3; /* 0x24 Chip-Select Address Register 3 */ - u16 res6; - u32 csmr3; /* 0x28 Chip-Select Mask Register 3 */ - u16 res7; /* 0x2C */ - u16 cscr3; /* 0x2E Chip-Select Control Register 3 */ - - u16 csar4; /* 0x30 Chip-Select Address Register 4 */ - u16 res8; - u32 csmr4; /* 0x34 Chip-Select Mask Register 4 */ - u16 res9; /* 0x38 */ - u16 cscr4; /* 0x3A Chip-Select Control Register 4 */ - - u16 csar5; /* 0x3C Chip-Select Address Register 5 */ - u16 res10; - u32 csmr5; /* 0x40 Chip-Select Mask Register 5 */ - u16 res11; /* 0x44 */ - u16 cscr5; /* 0x46 Chip-Select Control Register 5 */ - - u16 csar6; /* 0x48 Chip-Select Address Register 5 */ - u16 res12; - u32 csmr6; /* 0x4C Chip-Select Mask Register 5 */ - u16 res13; /* 0x50 */ - u16 cscr6; /* 0x52 Chip-Select Control Register 5 */ - - u16 csar7; /* 0x54 Chip-Select Address Register 5 */ - u16 res14; - u32 csmr7; /* 0x58 Chip-Select Mask Register 5 */ - u16 res15; /* 0x5C */ - u16 cscr7; /* 0x5E Chip-Select Control Register 5 */ -} fbcs_t; - /* Clock Module registers */ typedef struct pll_ctrl { u16 syncr; /* 0x00 synthesizer control register */ diff --git a/include/asm-m68k/m5235.h b/include/asm-m68k/m5235.h index 1733be6..22987ac 100644 --- a/include/asm-m68k/m5235.h +++ b/include/asm-m68k/m5235.h @@ -163,46 +163,6 @@ #define SDRAMC_DMRn_V (0x00000001)
/********************************************************************* -* FlexBus Chip Selects (FBCS) -*********************************************************************/ -/* Bit definitions and macros for FBCS_CSMR */ -#define FBCS_CSMR_BAM(x) (((x)&0xFFFF)<<16) -#define FBCS_CSMR_BAM_4G (0xFFFF0000) -#define FBCS_CSMR_BAM_2G (0x7FFF0000) -#define FBCS_CSMR_BAM_1G (0x3FFF0000) -#define FBCS_CSMR_BAM_1024M (0x3FFF0000) -#define FBCS_CSMR_BAM_512M (0x1FFF0000) -#define FBCS_CSMR_BAM_256M (0x0FFF0000) -#define FBCS_CSMR_BAM_128M (0x07FF0000) -#define FBCS_CSMR_BAM_64M (0x03FF0000) -#define FBCS_CSMR_BAM_32M (0x01FF0000) -#define FBCS_CSMR_BAM_16M (0x00FF0000) -#define FBCS_CSMR_BAM_8M (0x007F0000) -#define FBCS_CSMR_BAM_4M (0x003F0000) -#define FBCS_CSMR_BAM_2M (0x001F0000) -#define FBCS_CSMR_BAM_1M (0x000F0000) -#define FBCS_CSMR_BAM_1024K (0x000F0000) -#define FBCS_CSMR_BAM_512K (0x00070000) -#define FBCS_CSMR_BAM_256K (0x00030000) -#define FBCS_CSMR_BAM_128K (0x00010000) -#define FBCS_CSMR_BAM_64K (0x00000000) -#define FBCS_CSMR_WP (0x00000100) -#define FBCS_CSMR_V (0x00000001) - -/* Bit definitions and macros for FBCS_CSCR */ -#define FBCS_CSCR_SRWS(x) (((x)&0x03)<<14) -#define FBCS_CSCR_IWS(x) (((x)&0x0F)<<10) -#define FBCS_CSCR_AA (0x0100) -#define FBCS_CSCR_PS_MASK (0x00C0) -#define FBCS_CSCR_PS_32 (0x0000) -#define FBCS_CSCR_PS_16 (0x0080) -#define FBCS_CSCR_PS_8 (0x0040) -#define FBCS_CSCR_BEM (0x0020) -#define FBCS_CSCR_BSTR (0x0010) -#define FBCS_CSCR_BSTW (0x0008) -#define FBCS_CSCR_SWWS(x) ((x)&0x07) - -/********************************************************************* * Interrupt Controller (INTC) *********************************************************************/ #define INT0_LO_RSVD0 (0) diff --git a/include/asm-m68k/m5249.h b/include/asm-m68k/m5249.h index feb675c..fa0cb14 100644 --- a/include/asm-m68k/m5249.h +++ b/include/asm-m68k/m5249.h @@ -77,19 +77,6 @@ #define MCFSIM_IPR 0x40 /* Interrupt Pend reg (r/w) */ #define MCFSIM_IMR 0x44 /* Interrupt Mask reg (r/w) */
-#define MCFSIM_CSAR0 0x80 /* CS 0 Address 0 reg (r/w) */ -#define MCFSIM_CSMR0 0x84 /* CS 0 Mask 0 reg (r/w) */ -#define MCFSIM_CSCR0 0x8a /* CS 0 Control reg (r/w) */ -#define MCFSIM_CSAR1 0x8c /* CS 1 Address reg (r/w) */ -#define MCFSIM_CSMR1 0x90 /* CS 1 Mask reg (r/w) */ -#define MCFSIM_CSCR1 0x96 /* CS 1 Control reg (r/w) */ -#define MCFSIM_CSAR2 0x98 /* CS 2 Address reg (r/w) */ -#define MCFSIM_CSMR2 0x9c /* CS 2 Mask reg (r/w) */ -#define MCFSIM_CSCR2 0xa2 /* CS 2 Control reg (r/w) */ -#define MCFSIM_CSAR3 0xa4 /* CS 3 Address reg (r/w) */ -#define MCFSIM_CSMR3 0xa8 /* CS 3 Mask reg (r/w) */ -#define MCFSIM_CSCR3 0xae /* CS 3 Control reg (r/w) */ - #define MCFSIM_DCR 0x100 /* DRAM Control reg (r/w) */ #define MCFSIM_DACR0 0x108 /* DRAM 0 Addr and Ctrl (r/w) */ #define MCFSIM_DMR0 0x10c /* DRAM 0 Mask reg (r/w) */ diff --git a/include/asm-m68k/m5282.h b/include/asm-m68k/m5282.h index 772c7e0..d59a8b2 100644 --- a/include/asm-m68k/m5282.h +++ b/include/asm-m68k/m5282.h @@ -440,29 +440,6 @@ #define MCFWTM_WCNTR (*(vu_short *)(CONFIG_SYS_MBAR+0x00140004)) #define MCFWTM_WSR (*(vu_short *)(CONFIG_SYS_MBAR+0x00140006))
-/* Chip SELECT Module CSM */ -#define MCFCSM_CSAR0 (*(vu_short *)(CONFIG_SYS_MBAR+0x00000080)) -#define MCFCSM_CSMR0 (*(vu_long *) (CONFIG_SYS_MBAR+0x00000084)) -#define MCFCSM_CSCR0 (*(vu_short *)(CONFIG_SYS_MBAR+0x0000008a)) -#define MCFCSM_CSAR1 (*(vu_short *)(CONFIG_SYS_MBAR+0x0000008C)) -#define MCFCSM_CSMR1 (*(vu_long *) (CONFIG_SYS_MBAR+0x00000090)) -#define MCFCSM_CSCR1 (*(vu_short *)(CONFIG_SYS_MBAR+0x00000096)) -#define MCFCSM_CSAR2 (*(vu_short *)(CONFIG_SYS_MBAR+0x00000098)) -#define MCFCSM_CSMR2 (*(vu_long *) (CONFIG_SYS_MBAR+0x0000009C)) -#define MCFCSM_CSCR2 (*(vu_short *)(CONFIG_SYS_MBAR+0x000000A2)) -#define MCFCSM_CSAR3 (*(vu_short *)(CONFIG_SYS_MBAR+0x000000A4)) -#define MCFCSM_CSMR3 (*(vu_long *) (CONFIG_SYS_MBAR+0x000000A8)) -#define MCFCSM_CSCR3 (*(vu_short *)(CONFIG_SYS_MBAR+0x000000AE)) - -#define MCFCSM_CSMR_BAM(x) ((x) & 0xFFFF0000) -#define MCFCSM_CSMR_WP (1<<8) -#define MCFCSM_CSMR_V (0x01) -#define MCFCSM_CSCR_WS(x) ((x & 0x0F)<<10) -#define MCFCSM_CSCR_AA (0x0100) -#define MCFCSM_CSCR_PS_32 (0x0000) -#define MCFCSM_CSCR_PS_8 (0x0040) -#define MCFCSM_CSCR_PS_16 (0x0080) - /********************************************************************* * General Purpose Timer (GPT) Module *********************************************************************/ diff --git a/include/asm-m68k/m5329.h b/include/asm-m68k/m5329.h index 0aa50f1..c7ebed1 100644 --- a/include/asm-m68k/m5329.h +++ b/include/asm-m68k/m5329.h @@ -187,65 +187,6 @@ #define CFATR_TYPE (0x01)
/********************************************************************* -* FlexBus Chip Selects (FBCS) -*********************************************************************/ -/* Bit definitions and macros for FBCS_CSAR */ -#define CSAR_BA(x) (((x)&0xFFFF)<<16) - -/* Bit definitions and macros for FBCS_CSMR */ -#define CSMR_BAM(x) (((x)&0xFFFF)<<16) -#define CSMR_BAM_4G (0xFFFF0000) -#define CSMR_BAM_2G (0x7FFF0000) -#define CSMR_BAM_1G (0x3FFF0000) -#define CSMR_BAM_1024M (0x3FFF0000) -#define CSMR_BAM_512M (0x1FFF0000) -#define CSMR_BAM_256M (0x0FFF0000) -#define CSMR_BAM_128M (0x07FF0000) -#define CSMR_BAM_64M (0x03FF0000) -#define CSMR_BAM_32M (0x01FF0000) -#define CSMR_BAM_16M (0x00FF0000) -#define CSMR_BAM_8M (0x007F0000) -#define CSMR_BAM_4M (0x003F0000) -#define CSMR_BAM_2M (0x001F0000) -#define CSMR_BAM_1M (0x000F0000) -#define CSMR_BAM_1024K (0x000F0000) -#define CSMR_BAM_512K (0x00070000) -#define CSMR_BAM_256K (0x00030000) -#define CSMR_BAM_128K (0x00010000) -#define CSMR_BAM_64K (0x00000000) -#define CSMR_WP (0x00000100) -#define CSMR_V (0x00000001) - -/* Bit definitions and macros for FBCS_CSCR */ -#define CSCR_SWS(x) (((x)&0x3F)<<26) -#define CSCR_ASET(x) (((x)&0x03)<<20) -#define CSCR_SWSEN (0x00800000) -#define CSCR_ASET_4CLK (0x00300000) -#define CSCR_ASET_3CLK (0x00200000) -#define CSCR_ASET_2CLK (0x00100000) -#define CSCR_ASET_1CLK (0x00000000) -#define CSCR_RDAH(x) (((x)&0x03)<<18) -#define CSCR_RDAH_4CYC (0x000C0000) -#define CSCR_RDAH_3CYC (0x00080000) -#define CSCR_RDAH_2CYC (0x00040000) -#define CSCR_RDAH_1CYC (0x00000000) -#define CSCR_WRAH(x) (((x)&0x03)<<16) -#define CSCR_WDAH_4CYC (0x00003000) -#define CSCR_WDAH_3CYC (0x00002000) -#define CSCR_WDAH_2CYC (0x00001000) -#define CSCR_WDAH_1CYC (0x00000000) -#define CSCR_WS(x) (((x)&0x3F)<<10) -#define CSCR_SBM (0x00000200) -#define CSCR_AA (0x00000100) -#define CSCR_PS_MASK (0x000000C0) -#define CSCR_PS_32 (0x00000000) -#define CSCR_PS_16 (0x00000080) -#define CSCR_PS_8 (0x00000040) -#define CSCR_BEM (0x00000020) -#define CSCR_BSTR (0x00000010) -#define CSCR_BSTW (0x00000008) - -/********************************************************************* * Reset Controller Module (RCM) *********************************************************************/
diff --git a/include/configs/EB+MCF-EV123.h b/include/configs/EB+MCF-EV123.h index 876ec20..a13db7c 100644 --- a/include/configs/EB+MCF-EV123.h +++ b/include/configs/EB+MCF-EV123.h @@ -178,7 +178,7 @@ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_SDRAM_BASE1 #define CONFIG_SYS_SDRAM_SIZE CONFIG_SYS_SDRAM_SIZE1
-#define CONFIG_SYS_FLASH_BASE 0xFFE00000 +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE #define CONFIG_SYS_INT_FLASH_BASE 0xF0000000 #define CONFIG_SYS_INT_FLASH_ENABLE 0x21
@@ -218,17 +218,13 @@ * Memory bank definitions */
-#define CONFIG_SYS_CS0_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_CS0_SIZE 2*1024*1024 -#define CONFIG_SYS_CS0_WIDTH 16 -#define CONFIG_SYS_CS0_RO 0 -#define CONFIG_SYS_CS0_WS 6 +#define CONFIG_SYS_CS0_BASE 0xFFE00000 +#define CONFIG_SYS_CS0_CTRL 0x00001980 +#define CONFIG_SYS_CS0_MASK 0x001F0001
#define CONFIG_SYS_CS3_BASE 0xE0000000 -#define CONFIG_SYS_CS3_SIZE 1*1024*1024 -#define CONFIG_SYS_CS3_WIDTH 16 -#define CONFIG_SYS_CS3_RO 0 -#define CONFIG_SYS_CS3_WS 6 +#define CONFIG_SYS_CS0_CTRL 0x00001980 +#define CONFIG_SYS_CS3_MASK 0x000F0001
/*----------------------------------------------------------------------- * Port configuration diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index e6c87ef..8c66f87 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -215,7 +215,7 @@ # define CONFIG_SYS_FLASH_PROTECTION /* "Real" (hardware) sectors protection */ #endif
-#define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CS0_BASE << 16) +#define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CS0_BASE)
/* Configuration for environment * Environment is embedded in u-boot in the second sector of the flash @@ -251,13 +251,13 @@ * CS7 - Available */ #ifdef NORFLASH_PS32BIT -# define CONFIG_SYS_CS0_BASE 0xFFC0 +# define CONFIG_SYS_CS0_BASE 0xFFC00000 # define CONFIG_SYS_CS0_MASK 0x003f0001 -# define CONFIG_SYS_CS0_CTRL 0x1D00 +# define CONFIG_SYS_CS0_CTRL 0x00001D00 #else -# define CONFIG_SYS_CS0_BASE 0xFFE0 +# define CONFIG_SYS_CS0_BASE 0xFFE00000 # define CONFIG_SYS_CS0_MASK 0x001f0001 -# define CONFIG_SYS_CS0_CTRL 0x1D80 +# define CONFIG_SYS_CS0_CTRL 0x00001D80 #endif
#endif /* _M5329EVB_H */ diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index 8699ef9..e3830e5 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -125,7 +125,7 @@ */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_SDRAM_SIZE 16 /* SDRAM size in MB */ -#define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CSAR0 << 16) +#define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CS0_BASE)
#if 0 /* test-only */ #define CONFIG_PRAM 512 /* test-only for SDRAM problem!!!!!!!!!!!!!!!!!!!! */ @@ -170,15 +170,15 @@ */
/* CS0 - AMD Flash, address 0xffc00000 */ -#define CONFIG_SYS_CSAR0 0xffe0 -#define CONFIG_SYS_CSCR0 0x1980 /* WS=0110, AA=1, PS=10 */ +#define CONFIG_SYS_CS0_BASE 0xffe00000 +#define CONFIG_SYS_CS0_CTRL 0x00001980 /* WS=0110, AA=1, PS=10 */ /** Note: There is a CSMR0/DRAM vector problem, need to disable C/I ***/ -#define CONFIG_SYS_CSMR0 0x003f0021 /* 4MB, AA=0, WP=0, C/I=1, V=1 */ +#define CONFIG_SYS_CS0_MASK 0x003f0021 /* 4MB, AA=0, WP=0, C/I=1, V=1 */
/* CS1 - FPGA, address 0xe0000000 */ -#define CONFIG_SYS_CSAR1 0xe000 -#define CONFIG_SYS_CSCR1 0x0d80 /* WS=0011, AA=1, PS=10 */ -#define CONFIG_SYS_CSMR1 0x00010001 /* 128kB, AA=0, WP=0, C/I=0, V=1*/ +#define CONFIG_SYS_CS1_BASE 0xe0000000 +#define CONFIG_SYS_CS1_CTRL 0x00000d80 /* WS=0011, AA=1, PS=10 */ +#define CONFIG_SYS_CS1_MASK 0x00010001 /* 128kB, AA=0, WP=0, C/I=0, V=1*/
/*----------------------------------------------------------------------- * Port configuration diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index 3a5c12f..378e45a 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -90,7 +90,7 @@
#define CONFIG_DRIVER_DM9000 #ifdef CONFIG_DRIVER_DM9000 -# define CONFIG_DM9000_BASE ((CONFIG_SYS_CSAR1 << 16) | 0x300) +# define CONFIG_DM9000_BASE (CONFIG_SYS_CS1_BASE | 0x300) # define DM9000_IO CONFIG_DM9000_BASE # define DM9000_DATA (CONFIG_DM9000_BASE + 4) # undef CONFIG_DM9000_DEBUG @@ -202,7 +202,7 @@ #define CONFIG_SYS_BOOTMAPSZ (CONFIG_SYS_SDRAM_BASE + (CONFIG_SYS_SDRAM_SIZE << 20))
/* FLASH organization */ -#define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CSAR0 << 16) +#define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CS0_BASE) #define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ #define CONFIG_SYS_MAX_FLASH_SECT 2048 /* max number of sectors on one chip */ #define CONFIG_SYS_FLASH_ERASE_TOUT 1000 @@ -233,21 +233,13 @@ /* Port configuration */ #define CONFIG_SYS_FECI2C 0xF0
-#define CONFIG_SYS_CSAR0 0xFF80 -#define CONFIG_SYS_CSMR0 0x007F0021 -#define CONFIG_SYS_CSCR0 0x1D80 +#define CONFIG_SYS_CS0_BASE 0xFF800000 +#define CONFIG_SYS_CS0_MASK 0x007F0021 +#define CONFIG_SYS_CS0_CTRL 0x00001D80
-#define CONFIG_SYS_CSAR1 0xE000 -#define CONFIG_SYS_CSMR1 0x00000001 -#define CONFIG_SYS_CSCR1 0x3DD8 - -#define CONFIG_SYS_CSAR2 0 -#define CONFIG_SYS_CSMR2 0 -#define CONFIG_SYS_CSCR2 0 - -#define CONFIG_SYS_CSAR3 0 -#define CONFIG_SYS_CSMR3 0 -#define CONFIG_SYS_CSCR3 0 +#define CONFIG_SYS_CS1_BASE 0xE0000000 +#define CONFIG_SYS_CS1_MASK 0x00000001 +#define CONFIG_SYS_CS1_CTRL 0x00003DD8
/*----------------------------------------------------------------------- * Port configuration diff --git a/include/configs/M5253EVBE.h b/include/configs/M5253EVBE.h index c2cd62b..86de97d 100644 --- a/include/configs/M5253EVBE.h +++ b/include/configs/M5253EVBE.h @@ -166,7 +166,7 @@ #define CONFIG_SYS_BOOTMAPSZ (CONFIG_SYS_SDRAM_BASE + (CONFIG_SYS_SDRAM_SIZE << 20))
/* FLASH organization */ -#define CONFIG_SYS_FLASH_BASE 0xffe00000 +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE #define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ #define CONFIG_SYS_MAX_FLASH_SECT 35 /* max number of sectors on one chip */ #define CONFIG_SYS_FLASH_ERASE_TOUT 1000 @@ -182,21 +182,9 @@ /* Port configuration */ #define CONFIG_SYS_FECI2C 0xF0
-#define CONFIG_SYS_CSAR0 0xFFE0 -#define CONFIG_SYS_CSMR0 0x001F0021 -#define CONFIG_SYS_CSCR0 0x1D80 - -#define CONFIG_SYS_CSAR1 0 -#define CONFIG_SYS_CSMR1 0 -#define CONFIG_SYS_CSCR1 0 - -#define CONFIG_SYS_CSAR2 0 -#define CONFIG_SYS_CSMR2 0 -#define CONFIG_SYS_CSCR2 0 - -#define CONFIG_SYS_CSAR3 0 -#define CONFIG_SYS_CSMR3 0 -#define CONFIG_SYS_CSCR3 0 +#define CONFIG_SYS_CS0_BASE 0xFFE00000 +#define CONFIG_SYS_CS0_MASK 0x001F0021 +#define CONFIG_SYS_CS0_CTRL 0x00001D80
/*----------------------------------------------------------------------- * Port configuration diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index 1f3539e..db48d76 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -173,7 +173,7 @@ */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_SDRAM_SIZE 16 /* SDRAM size in MB */ -#define CONFIG_SYS_FLASH_BASE 0xffe00000 +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE
#ifdef CONFIG_MONITOR_IS_IN_RAM #define CONFIG_SYS_MONITOR_BASE 0x20000 @@ -211,13 +211,13 @@ /*----------------------------------------------------------------------- * Memory bank definitions */ -#define CONFIG_SYS_AR0_PRELIM (CONFIG_SYS_FLASH_BASE >> 16) -#define CONFIG_SYS_CR0_PRELIM 0x1980 -#define CONFIG_SYS_MR0_PRELIM 0x001F0001 +#define CONFIG_SYS_CS0_BASE 0xffe00000 +#define CONFIG_SYS_CS0_CTRL 0x00001980 +#define CONFIG_SYS_CS0_MASK 0x001F0001
-#define CONFIG_SYS_AR1_PRELIM 0x3000 -#define CONFIG_SYS_CR1_PRELIM 0x1900 -#define CONFIG_SYS_MR1_PRELIM 0x00070001 +#define CONFIG_SYS_CS1_BASE 0x30000000 +#define CONFIG_SYS_CS1_CTRL 0x00001900 +#define CONFIG_SYS_CS1_MASK 0x00070001
/*----------------------------------------------------------------------- * Port configuration diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index a8a2655..15590cf 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -165,7 +165,7 @@ */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_SDRAM_SIZE 16 /* SDRAM size in MB */ -#define CONFIG_SYS_FLASH_BASE 0xffe00000 +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE #define CONFIG_SYS_INT_FLASH_BASE 0xf0000000 #define CONFIG_SYS_INT_FLASH_ENABLE 0x21
@@ -212,18 +212,10 @@ /*----------------------------------------------------------------------- * Memory bank definitions */ -#define CONFIG_SYS_CS0_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_CS0_SIZE 2*1024*1024 -#define CONFIG_SYS_CS0_WIDTH 16 -#define CONFIG_SYS_CS0_RO 0 -#define CONFIG_SYS_CS0_WS 6 -/* -#define CONFIG_SYS_CS3_BASE 0xE0000000 -#define CONFIG_SYS_CS3_SIZE 1*1024*1024 -#define CONFIG_SYS_CS3_WIDTH 16 -#define CONFIG_SYS_CS3_RO 0 -#define CONFIG_SYS_CS3_WS 6 -*/ +#define CONFIG_SYS_CS0_BASE 0xFFE00000 +#define CONFIG_SYS_CS0_CTRL 0x00001980 +#define CONFIG_SYS_CS0_MASK 0x001F0001 + /*----------------------------------------------------------------------- * Port configuration */ diff --git a/include/configs/TASREG.h b/include/configs/TASREG.h index 18ffbfd..25f3a26 100644 --- a/include/configs/TASREG.h +++ b/include/configs/TASREG.h @@ -206,7 +206,7 @@ */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_SDRAM_SIZE 16 /* SDRAM size in MB */ -#define CONFIG_SYS_FLASH_BASE 0xffc00000 +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE
#if 0 /* test-only */ #define CONFIG_PRAM 512 /* test-only for SDRAM problem!!!!!!!!!!!!!!!!!!!! */ @@ -257,15 +257,15 @@ */
/* CS0 - AMD Flash, address 0xffc00000 */ -#define CONFIG_SYS_CSAR0 0xffc0 -#define CONFIG_SYS_CSCR0 0x1980 /* WS=0110, AA=1, PS=10 */ +#define CONFIG_SYS_CS0_BASE 0xffc00000 +#define CONFIG_SYS_CS0_CTRL 0x00001980 /* WS=0110, AA=1, PS=10 */ /** Note: There is a CSMR0/DRAM vector problem, need to disable C/I ***/ -#define CONFIG_SYS_CSMR0 0x003f0021 /* 4MB, AA=0, WP=0, C/I=1, V=1 */ +#define CONFIG_SYS_CS0_MASK 0x003f0021 /* 4MB, AA=0, WP=0, C/I=1, V=1 */
Tsi-Chung Liew
