[U-Boot] [PATCH v3 00/19] Add Intel Arria 10 SoC support
This is the 3rd version of patchset to adds support for Intel Arria 10 SoC. This version mainly resolved comments from Marek in [v2].
This is initial patchset enables the basic support for Arria 10 and other features will come after this.
This series is working on top of “arm: socfpga: Move to using distro boot” series [1] from Dalon Westergreen.
[1]: https://www.mail-archive.com/u-boot@lists.denx.de/msg239560.html
v2 -> v3 changes: ----------------- - Drop "[PATCH v2 02/20] arm: socfpga: Update clock for Gen5" in [v2] from this A10 patch series, since it is non Arria 10 related. - Add socfpga_ prefix for exported functions in reset driver. - Check return value from wait_for_bit(). - Remove extra parenthesis around statement - Refactor cm_calc_safe_pll_numer() clock driver. - Use BIT(n) for bit shifting. - Resolved warnings and errors from checkpatch.pl.
Patchset history ---------------- [v1]: https://www.mail-archive.com/u-boot@lists.denx.de/msg240052.html [v2]: https://www.mail-archive.com/u-boot@lists.denx.de/msg241249.html
Ley Foon Tan (19): arm: socfpga: Restructure clock manager driver arm: socfpga: Restructure reset manager driver arm: socfpga: Restructure system manager arm: socfpga: Restructure misc driver arm: socfpga: Add A10 macros arm: socfpga: Add reset driver support for Arria 10 arm: socfpga: Add clock driver for Arria 10 arm: socfpga: Add system manager for Arria 10 arm: socfpga: Add sdram header file for Arria 10 arm: socfpga: Add misc support for Arria 10 arm: socfpga: Add pinmux for Arria 10 fdt: Add compatible strings for Arria 10 arm: dts: Add dts and dtsi for Arria 10 arm: socfpga: Add SPL support for Arria 10 drivers: fpga: Add compile switch for Gen5 only registers arm: socfpga: Convert Altera DDR SDRAM driver to use Kconfig arm: socfpga: Add config and defconfig for Arria 10 arm: socfpga: Add board files for the Arria10 arm: socfpga: Enable build for Arria 10
arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_arria10.dtsi | 859 +++++++++++++++ arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts | 30 + .../dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi | 481 +++++++++ arch/arm/mach-socfpga/Kconfig | 10 + arch/arm/mach-socfpga/Makefile | 41 +- arch/arm/mach-socfpga/clock_manager.c | 525 +--------- arch/arm/mach-socfpga/clock_manager_arria10.c | 1096 ++++++++++++++++++++ .../{clock_manager.c => clock_manager_gen5.c} | 104 +- arch/arm/mach-socfpga/include/mach/base_addr_a10.h | 8 +- arch/arm/mach-socfpga/include/mach/clock_manager.h | 317 +----- .../include/mach/clock_manager_arria10.h | 224 ++++ .../mach/{clock_manager.h => clock_manager_gen5.h} | 151 +-- arch/arm/mach-socfpga/include/mach/misc.h | 31 + arch/arm/mach-socfpga/include/mach/pinmux.h | 15 + arch/arm/mach-socfpga/include/mach/reset_manager.h | 50 +- .../include/mach/reset_manager_arria10.h | 144 +++ .../mach-socfpga/include/mach/reset_manager_gen5.h | 47 + arch/arm/mach-socfpga/include/mach/sdram_arria10.h | 380 +++++++ .../arm/mach-socfpga/include/mach/system_manager.h | 202 ++-- .../include/mach/system_manager_arria10.h | 81 ++ .../{system_manager.h => system_manager_gen5.h} | 39 +- arch/arm/mach-socfpga/misc.c | 361 +------ arch/arm/mach-socfpga/misc_arria10.c | 258 +++++ arch/arm/mach-socfpga/{misc.c => misc_gen5.c} | 149 +-- arch/arm/mach-socfpga/pinmux_arria10.c | 96 ++ arch/arm/mach-socfpga/reset_manager.c | 93 +- arch/arm/mach-socfpga/reset_manager_arria10.c | 389 +++++++ .../{reset_manager.c => reset_manager_gen5.c} | 51 +- arch/arm/mach-socfpga/spl.c | 74 +- .../{system_manager.c => system_manager_gen5.c} | 6 +- board/altera/arria10-socdk/Kconfig | 18 + board/altera/arria10-socdk/Makefile | 7 + board/altera/arria10-socdk/socfpga.c | 7 + configs/socfpga_arria10_defconfig | 28 + drivers/Kconfig | 2 + drivers/ddr/Kconfig | 1 + drivers/ddr/altera/Kconfig | 6 + drivers/ddr/altera/Makefile | 4 +- drivers/fpga/socfpga.c | 6 + include/configs/socfpga_arria10_socdk.h | 66 ++ include/configs/socfpga_common.h | 33 +- include/dt-bindings/reset/altr,rst-mgr-a10.h | 103 ++ include/fdtdec.h | 8 + lib/fdtdec.c | 8 + 45 files changed, 4824 insertions(+), 1786 deletions(-) create mode 100644 arch/arm/dts/socfpga_arria10.dtsi create mode 100644 arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts create mode 100644 arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi create mode 100644 arch/arm/mach-socfpga/clock_manager_arria10.c copy arch/arm/mach-socfpga/{clock_manager.c => clock_manager_gen5.c} (88%) create mode 100644 arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h copy arch/arm/mach-socfpga/include/mach/{clock_manager.h => clock_manager_gen5.h} (80%) create mode 100644 arch/arm/mach-socfpga/include/mach/misc.h create mode 100644 arch/arm/mach-socfpga/include/mach/pinmux.h create mode 100644 arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h create mode 100644 arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h create mode 100644 arch/arm/mach-socfpga/include/mach/sdram_arria10.h create mode 100644 arch/arm/mach-socfpga/include/mach/system_manager_arria10.h copy arch/arm/mach-socfpga/include/mach/{system_manager.h => system_manager_gen5.h} (73%) create mode 100644 arch/arm/mach-socfpga/misc_arria10.c copy arch/arm/mach-socfpga/{misc.c => misc_gen5.c} (73%) create mode 100644 arch/arm/mach-socfpga/pinmux_arria10.c create mode 100644 arch/arm/mach-socfpga/reset_manager_arria10.c copy arch/arm/mach-socfpga/{reset_manager.c => reset_manager_gen5.c} (75%) rename arch/arm/mach-socfpga/{system_manager.c => system_manager_gen5.c} (94%) create mode 100644 board/altera/arria10-socdk/Kconfig create mode 100644 board/altera/arria10-socdk/Makefile create mode 100644 board/altera/arria10-socdk/socfpga.c create mode 100644 configs/socfpga_arria10_defconfig create mode 100644 drivers/ddr/Kconfig create mode 100644 drivers/ddr/altera/Kconfig create mode 100644 include/configs/socfpga_arria10_socdk.h create mode 100644 include/dt-bindings/reset/altr,rst-mgr-a10.h
Restructure clock manager driver in the preparation to support A10. Move the Gen5 specific code to _gen5 files. No functional change.
Change all uint32_t to u32 and change to use macro BIT(n) for bit shift.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 3 +- arch/arm/mach-socfpga/clock_manager.c | 515 +-------------------- .../{clock_manager.c => clock_manager_gen5.c} | 104 ++--- arch/arm/mach-socfpga/include/mach/clock_manager.h | 316 +------------ .../mach/{clock_manager.h => clock_manager_gen5.h} | 151 +++--- 5 files changed, 125 insertions(+), 964 deletions(-) copy arch/arm/mach-socfpga/{clock_manager.c => clock_manager_gen5.c} (88%) copy arch/arm/mach-socfpga/include/mach/{clock_manager.h => clock_manager_gen5.h} (80%)
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 809cd47..b76de4c 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -13,7 +13,8 @@ obj-y += misc.o timer.o reset_manager.o system_manager.o clock_manager.o \ obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o
# QTS-generated config file wrappers -obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o +obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o \ + clock_manager_gen5.o obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ wrap_sdram_config.o CFLAGS_wrap_iocsr_config.o += -I$(srctree)/board/$(BOARDDIR) diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager.c index 29e18f8..8051995 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -1,10 +1,11 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> +#include <wait_bit.h> #include <asm/io.h> #include <asm/arch/clock_manager.h>
@@ -13,10 +14,10 @@ DECLARE_GLOBAL_DATA_PTR; static const struct socfpga_clock_manager *clock_manager_base = (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS;
-static void cm_wait_for_lock(uint32_t mask) +void cm_wait_for_lock(u32 mask) { - register uint32_t inter_val; - uint32_t retry = 0; + u32 inter_val; + u32 retry = 0; do { inter_val = readl(&clock_manager_base->inter) & mask; if (inter_val == mask) @@ -29,510 +30,10 @@ static void cm_wait_for_lock(uint32_t mask) }
/* function to poll in the fsm busy bit */ -static void cm_wait_for_fsm(void) +int cm_wait_for_fsm(void) { - while (readl(&clock_manager_base->stat) & CLKMGR_STAT_BUSY) - ; -} - -/* - * function to write the bypass register which requires a poll of the - * busy bit - */ -static void cm_write_bypass(uint32_t val) -{ - writel(val, &clock_manager_base->bypass); - cm_wait_for_fsm(); -} - -/* function to write the ctrl register which requires a poll of the busy bit */ -static void cm_write_ctrl(uint32_t val) -{ - writel(val, &clock_manager_base->ctrl); - cm_wait_for_fsm(); -} - -/* function to write a clock register that has phase information */ -static void cm_write_with_phase(uint32_t value, - uint32_t reg_address, uint32_t mask) -{ - /* poll until phase is zero */ - while (readl(reg_address) & mask) - ; - - writel(value, reg_address); - - while (readl(reg_address) & mask) - ; -} - -/* - * Setup clocks while making no assumptions about previous state of the clocks. - * - * Start by being paranoid and gate all sw managed clocks - * Put all plls in bypass - * Put all plls VCO registers back to reset value (bandgap power down). - * Put peripheral and main pll src to reset value to avoid glitch. - * Delay 5 us. - * Deassert bandgap power down and set numerator and denominator - * Start 7 us timer. - * set internal dividers - * Wait for 7 us timer. - * Enable plls - * Set external dividers while plls are locking - * Wait for pll lock - * Assert/deassert outreset all. - * Take all pll's out of bypass - * Clear safe mode - * set source main and peripheral clocks - * Ungate clocks - */ - -void cm_basic_init(const struct cm_config * const cfg) -{ - unsigned long end; - - /* Start by being paranoid and gate all sw managed clocks */ - - /* - * We need to disable nandclk - * and then do another apb access before disabling - * gatting off the rest of the periperal clocks. - */ - writel(~CLKMGR_PERPLLGRP_EN_NANDCLK_MASK & - readl(&clock_manager_base->per_pll.en), - &clock_manager_base->per_pll.en); - - /* DO NOT GATE OFF DEBUG CLOCKS & BRIDGE CLOCKS */ - writel(CLKMGR_MAINPLLGRP_EN_DBGTIMERCLK_MASK | - CLKMGR_MAINPLLGRP_EN_DBGTRACECLK_MASK | - CLKMGR_MAINPLLGRP_EN_DBGCLK_MASK | - CLKMGR_MAINPLLGRP_EN_DBGATCLK_MASK | - CLKMGR_MAINPLLGRP_EN_S2FUSER0CLK_MASK | - CLKMGR_MAINPLLGRP_EN_L4MPCLK_MASK, - &clock_manager_base->main_pll.en); - - writel(0, &clock_manager_base->sdr_pll.en); - - /* now we can gate off the rest of the peripheral clocks */ - writel(0, &clock_manager_base->per_pll.en); - - /* Put all plls in bypass */ - cm_write_bypass(CLKMGR_BYPASS_PERPLL | CLKMGR_BYPASS_SDRPLL | - CLKMGR_BYPASS_MAINPLL); - - /* Put all plls VCO registers back to reset value. */ - writel(CLKMGR_MAINPLLGRP_VCO_RESET_VALUE & - ~CLKMGR_MAINPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->main_pll.vco); - writel(CLKMGR_PERPLLGRP_VCO_RESET_VALUE & - ~CLKMGR_PERPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->per_pll.vco); - writel(CLKMGR_SDRPLLGRP_VCO_RESET_VALUE & - ~CLKMGR_SDRPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->sdr_pll.vco); - - /* - * The clocks to the flash devices and the L4_MAIN clocks can - * glitch when coming out of safe mode if their source values - * are different from their reset value. So the trick it to - * put them back to their reset state, and change input - * after exiting safe mode but before ungating the clocks. - */ - writel(CLKMGR_PERPLLGRP_SRC_RESET_VALUE, - &clock_manager_base->per_pll.src); - writel(CLKMGR_MAINPLLGRP_L4SRC_RESET_VALUE, - &clock_manager_base->main_pll.l4src); - - /* read back for the required 5 us delay. */ - readl(&clock_manager_base->main_pll.vco); - readl(&clock_manager_base->per_pll.vco); - readl(&clock_manager_base->sdr_pll.vco); - - - /* - * We made sure bgpwr down was assert for 5 us. Now deassert BG PWR DN - * with numerator and denominator. - */ - writel(cfg->main_vco_base, &clock_manager_base->main_pll.vco); - writel(cfg->peri_vco_base, &clock_manager_base->per_pll.vco); - writel(cfg->sdram_vco_base, &clock_manager_base->sdr_pll.vco); - - /* - * Time starts here. Must wait 7 us from - * BGPWRDN_SET(0) to VCO_ENABLE_SET(1). - */ - end = timer_get_us() + 7; - - /* main mpu */ - writel(cfg->mpuclk, &clock_manager_base->main_pll.mpuclk); - - /* altera group mpuclk */ - writel(cfg->altera_grp_mpuclk, &clock_manager_base->altera.mpuclk); - - /* main main clock */ - writel(cfg->mainclk, &clock_manager_base->main_pll.mainclk); - - /* main for dbg */ - writel(cfg->dbgatclk, &clock_manager_base->main_pll.dbgatclk); - - /* main for cfgs2fuser0clk */ - writel(cfg->cfg2fuser0clk, - &clock_manager_base->main_pll.cfgs2fuser0clk); - - /* Peri emac0 50 MHz default to RMII */ - writel(cfg->emac0clk, &clock_manager_base->per_pll.emac0clk); - - /* Peri emac1 50 MHz default to RMII */ - writel(cfg->emac1clk, &clock_manager_base->per_pll.emac1clk); - - /* Peri QSPI */ - writel(cfg->mainqspiclk, &clock_manager_base->main_pll.mainqspiclk); - - writel(cfg->perqspiclk, &clock_manager_base->per_pll.perqspiclk); - - /* Peri pernandsdmmcclk */ - writel(cfg->mainnandsdmmcclk, - &clock_manager_base->main_pll.mainnandsdmmcclk); - - writel(cfg->pernandsdmmcclk, - &clock_manager_base->per_pll.pernandsdmmcclk); - - /* Peri perbaseclk */ - writel(cfg->perbaseclk, &clock_manager_base->per_pll.perbaseclk); - - /* Peri s2fuser1clk */ - writel(cfg->s2fuser1clk, &clock_manager_base->per_pll.s2fuser1clk); - - /* 7 us must have elapsed before we can enable the VCO */ - while (timer_get_us() < end) - ; - - /* Enable vco */ - /* main pll vco */ - writel(cfg->main_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->main_pll.vco); - - /* periferal pll */ - writel(cfg->peri_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->per_pll.vco); - - /* sdram pll vco */ - writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->sdr_pll.vco); - - /* L3 MP and L3 SP */ - writel(cfg->maindiv, &clock_manager_base->main_pll.maindiv); - - writel(cfg->dbgdiv, &clock_manager_base->main_pll.dbgdiv); - - writel(cfg->tracediv, &clock_manager_base->main_pll.tracediv); - - /* L4 MP, L4 SP, can0, and can1 */ - writel(cfg->perdiv, &clock_manager_base->per_pll.div); - - writel(cfg->gpiodiv, &clock_manager_base->per_pll.gpiodiv); - -#define LOCKED_MASK \ - (CLKMGR_INTER_SDRPLLLOCKED_MASK | \ - CLKMGR_INTER_PERPLLLOCKED_MASK | \ - CLKMGR_INTER_MAINPLLLOCKED_MASK) - - cm_wait_for_lock(LOCKED_MASK); - - /* write the sdram clock counters before toggling outreset all */ - writel(cfg->ddrdqsclk & CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK, - &clock_manager_base->sdr_pll.ddrdqsclk); - - writel(cfg->ddr2xdqsclk & CLKMGR_SDRPLLGRP_DDR2XDQSCLK_CNT_MASK, - &clock_manager_base->sdr_pll.ddr2xdqsclk); - - writel(cfg->ddrdqclk & CLKMGR_SDRPLLGRP_DDRDQCLK_CNT_MASK, - &clock_manager_base->sdr_pll.ddrdqclk); - - writel(cfg->s2fuser2clk & CLKMGR_SDRPLLGRP_S2FUSER2CLK_CNT_MASK, - &clock_manager_base->sdr_pll.s2fuser2clk); - - /* - * after locking, but before taking out of bypass - * assert/deassert outresetall - */ - uint32_t mainvco = readl(&clock_manager_base->main_pll.vco); - - /* assert main outresetall */ - writel(mainvco | CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->main_pll.vco); - - uint32_t periphvco = readl(&clock_manager_base->per_pll.vco); - - /* assert pheriph outresetall */ - writel(periphvco | CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->per_pll.vco); - - /* assert sdram outresetall */ - writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN| - CLKMGR_SDRPLLGRP_VCO_OUTRESETALL, - &clock_manager_base->sdr_pll.vco); - - /* deassert main outresetall */ - writel(mainvco & ~CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->main_pll.vco); - - /* deassert pheriph outresetall */ - writel(periphvco & ~CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->per_pll.vco); - - /* deassert sdram outresetall */ - writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->sdr_pll.vco); - - /* - * now that we've toggled outreset all, all the clocks - * are aligned nicely; so we can change any phase. - */ - cm_write_with_phase(cfg->ddrdqsclk, - (uint32_t)&clock_manager_base->sdr_pll.ddrdqsclk, - CLKMGR_SDRPLLGRP_DDRDQSCLK_PHASE_MASK); - - /* SDRAM DDR2XDQSCLK */ - cm_write_with_phase(cfg->ddr2xdqsclk, - (uint32_t)&clock_manager_base->sdr_pll.ddr2xdqsclk, - CLKMGR_SDRPLLGRP_DDR2XDQSCLK_PHASE_MASK); - - cm_write_with_phase(cfg->ddrdqclk, - (uint32_t)&clock_manager_base->sdr_pll.ddrdqclk, - CLKMGR_SDRPLLGRP_DDRDQCLK_PHASE_MASK); - - cm_write_with_phase(cfg->s2fuser2clk, - (uint32_t)&clock_manager_base->sdr_pll.s2fuser2clk, - CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_MASK); - - /* Take all three PLLs out of bypass when safe mode is cleared. */ - cm_write_bypass(0); - - /* clear safe mode */ - cm_write_ctrl(readl(&clock_manager_base->ctrl) | CLKMGR_CTRL_SAFEMODE); - - /* - * now that safe mode is clear with clocks gated - * it safe to change the source mux for the flashes the the L4_MAIN - */ - writel(cfg->persrc, &clock_manager_base->per_pll.src); - writel(cfg->l4src, &clock_manager_base->main_pll.l4src); - - /* Now ungate non-hw-managed clocks */ - writel(~0, &clock_manager_base->main_pll.en); - writel(~0, &clock_manager_base->per_pll.en); - writel(~0, &clock_manager_base->sdr_pll.en); - - /* Clear the loss of lock bits (write 1 to clear) */ - writel(CLKMGR_INTER_SDRPLLLOST_MASK | CLKMGR_INTER_PERPLLLOST_MASK | - CLKMGR_INTER_MAINPLLLOST_MASK, - &clock_manager_base->inter); -} - -static unsigned int cm_get_main_vco_clk_hz(void) -{ - uint32_t reg, clock; - - /* get the main VCO clock */ - reg = readl(&clock_manager_base->main_pll.vco); - clock = cm_get_osc_clk_hz(1); - clock /= ((reg & CLKMGR_MAINPLLGRP_VCO_DENOM_MASK) >> - CLKMGR_MAINPLLGRP_VCO_DENOM_OFFSET) + 1; - clock *= ((reg & CLKMGR_MAINPLLGRP_VCO_NUMER_MASK) >> - CLKMGR_MAINPLLGRP_VCO_NUMER_OFFSET) + 1; - - return clock; -} - -static unsigned int cm_get_per_vco_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify PER PLL clock source */ - reg = readl(&clock_manager_base->per_pll.vco); - reg = (reg & CLKMGR_PERPLLGRP_VCO_SSRC_MASK) >> - CLKMGR_PERPLLGRP_VCO_SSRC_OFFSET; - if (reg == CLKMGR_VCO_SSRC_EOSC1) - clock = cm_get_osc_clk_hz(1); - else if (reg == CLKMGR_VCO_SSRC_EOSC2) - clock = cm_get_osc_clk_hz(2); - else if (reg == CLKMGR_VCO_SSRC_F2S) - clock = cm_get_f2s_per_ref_clk_hz(); - - /* get the PER VCO clock */ - reg = readl(&clock_manager_base->per_pll.vco); - clock /= ((reg & CLKMGR_PERPLLGRP_VCO_DENOM_MASK) >> - CLKMGR_PERPLLGRP_VCO_DENOM_OFFSET) + 1; - clock *= ((reg & CLKMGR_PERPLLGRP_VCO_NUMER_MASK) >> - CLKMGR_PERPLLGRP_VCO_NUMER_OFFSET) + 1; - - return clock; -} - -unsigned long cm_get_mpu_clk_hz(void) -{ - uint32_t reg, clock; - - clock = cm_get_main_vco_clk_hz(); - - /* get the MPU clock */ - reg = readl(&clock_manager_base->altera.mpuclk); - clock /= (reg + 1); - reg = readl(&clock_manager_base->main_pll.mpuclk); - clock /= (reg + 1); - return clock; -} - -unsigned long cm_get_sdram_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify SDRAM PLL clock source */ - reg = readl(&clock_manager_base->sdr_pll.vco); - reg = (reg & CLKMGR_SDRPLLGRP_VCO_SSRC_MASK) >> - CLKMGR_SDRPLLGRP_VCO_SSRC_OFFSET; - if (reg == CLKMGR_VCO_SSRC_EOSC1) - clock = cm_get_osc_clk_hz(1); - else if (reg == CLKMGR_VCO_SSRC_EOSC2) - clock = cm_get_osc_clk_hz(2); - else if (reg == CLKMGR_VCO_SSRC_F2S) - clock = cm_get_f2s_sdr_ref_clk_hz(); - - /* get the SDRAM VCO clock */ - reg = readl(&clock_manager_base->sdr_pll.vco); - clock /= ((reg & CLKMGR_SDRPLLGRP_VCO_DENOM_MASK) >> - CLKMGR_SDRPLLGRP_VCO_DENOM_OFFSET) + 1; - clock *= ((reg & CLKMGR_SDRPLLGRP_VCO_NUMER_MASK) >> - CLKMGR_SDRPLLGRP_VCO_NUMER_OFFSET) + 1; - - /* get the SDRAM (DDR_DQS) clock */ - reg = readl(&clock_manager_base->sdr_pll.ddrdqsclk); - reg = (reg & CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK) >> - CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_OFFSET; - clock /= (reg + 1); - - return clock; -} - -unsigned int cm_get_l4_sp_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify the source of L4 SP clock */ - reg = readl(&clock_manager_base->main_pll.l4src); - reg = (reg & CLKMGR_MAINPLLGRP_L4SRC_L4SP) >> - CLKMGR_MAINPLLGRP_L4SRC_L4SP_OFFSET; - - if (reg == CLKMGR_L4_SP_CLK_SRC_MAINPLL) { - clock = cm_get_main_vco_clk_hz(); - - /* get the clock prior L4 SP divider (main clk) */ - reg = readl(&clock_manager_base->altera.mainclk); - clock /= (reg + 1); - reg = readl(&clock_manager_base->main_pll.mainclk); - clock /= (reg + 1); - } else if (reg == CLKMGR_L4_SP_CLK_SRC_PERPLL) { - clock = cm_get_per_vco_clk_hz(); - - /* get the clock prior L4 SP divider (periph_base_clk) */ - reg = readl(&clock_manager_base->per_pll.perbaseclk); - clock /= (reg + 1); - } - - /* get the L4 SP clock which supplied to UART */ - reg = readl(&clock_manager_base->main_pll.maindiv); - reg = (reg & CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_MASK) >> - CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_OFFSET; - clock = clock / (1 << reg); - - return clock; -} - -unsigned int cm_get_mmc_controller_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify the source of MMC clock */ - reg = readl(&clock_manager_base->per_pll.src); - reg = (reg & CLKMGR_PERPLLGRP_SRC_SDMMC_MASK) >> - CLKMGR_PERPLLGRP_SRC_SDMMC_OFFSET; - - if (reg == CLKMGR_SDMMC_CLK_SRC_F2S) { - clock = cm_get_f2s_per_ref_clk_hz(); - } else if (reg == CLKMGR_SDMMC_CLK_SRC_MAIN) { - clock = cm_get_main_vco_clk_hz(); - - /* get the SDMMC clock */ - reg = readl(&clock_manager_base->main_pll.mainnandsdmmcclk); - clock /= (reg + 1); - } else if (reg == CLKMGR_SDMMC_CLK_SRC_PER) { - clock = cm_get_per_vco_clk_hz(); - - /* get the SDMMC clock */ - reg = readl(&clock_manager_base->per_pll.pernandsdmmcclk); - clock /= (reg + 1); - } - - /* further divide by 4 as we have fixed divider at wrapper */ - clock /= 4; - return clock; -} - -unsigned int cm_get_qspi_controller_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify the source of QSPI clock */ - reg = readl(&clock_manager_base->per_pll.src); - reg = (reg & CLKMGR_PERPLLGRP_SRC_QSPI_MASK) >> - CLKMGR_PERPLLGRP_SRC_QSPI_OFFSET; - - if (reg == CLKMGR_QSPI_CLK_SRC_F2S) { - clock = cm_get_f2s_per_ref_clk_hz(); - } else if (reg == CLKMGR_QSPI_CLK_SRC_MAIN) { - clock = cm_get_main_vco_clk_hz(); - - /* get the qspi clock */ - reg = readl(&clock_manager_base->main_pll.mainqspiclk); - clock /= (reg + 1); - } else if (reg == CLKMGR_QSPI_CLK_SRC_PER) { - clock = cm_get_per_vco_clk_hz(); - - /* get the qspi clock */ - reg = readl(&clock_manager_base->per_pll.perqspiclk); - clock /= (reg + 1); - } - - return clock; -} - -unsigned int cm_get_spi_controller_clk_hz(void) -{ - uint32_t reg, clock = 0; - - clock = cm_get_per_vco_clk_hz(); - - /* get the clock prior L4 SP divider (periph_base_clk) */ - reg = readl(&clock_manager_base->per_pll.perbaseclk); - clock /= (reg + 1); - - return clock; -} - -static void cm_print_clock_quick_summary(void) -{ - printf("MPU %10ld kHz\n", cm_get_mpu_clk_hz() / 1000); - printf("DDR %10ld kHz\n", cm_get_sdram_clk_hz() / 1000); - printf("EOSC1 %8d kHz\n", cm_get_osc_clk_hz(1) / 1000); - printf("EOSC2 %8d kHz\n", cm_get_osc_clk_hz(2) / 1000); - printf("F2S_SDR_REF %8d kHz\n", cm_get_f2s_sdr_ref_clk_hz() / 1000); - printf("F2S_PER_REF %8d kHz\n", cm_get_f2s_per_ref_clk_hz() / 1000); - printf("MMC %8d kHz\n", cm_get_mmc_controller_clk_hz() / 1000); - printf("QSPI %8d kHz\n", cm_get_qspi_controller_clk_hz() / 1000); - printf("UART %8d kHz\n", cm_get_l4_sp_clk_hz() / 1000); - printf("SPI %8d kHz\n", cm_get_spi_controller_clk_hz() / 1000); + return wait_for_bit(__func__, (const u32 *)&clock_manager_base->stat, + CLKMGR_STAT_BUSY, false, 20000, false); }
int set_cpu_clk_info(void) diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager_gen5.c similarity index 88% copy from arch/arm/mach-socfpga/clock_manager.c copy to arch/arm/mach-socfpga/clock_manager_gen5.c index 29e18f8..ed8a6f0 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager_gen5.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -7,63 +7,45 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/clock_manager.h> +#include <wait_bit.h>
-static void cm_wait_for_lock(uint32_t mask) -{ - register uint32_t inter_val; - uint32_t retry = 0; - do { - inter_val = readl(&clock_manager_base->inter) & mask; - if (inter_val == mask) - retry++; - else - retry = 0; - if (retry >= 10) - break; - } while (1); -} - -/* function to poll in the fsm busy bit */ -static void cm_wait_for_fsm(void) -{ - while (readl(&clock_manager_base->stat) & CLKMGR_STAT_BUSY) - ; -} - /* * function to write the bypass register which requires a poll of the * busy bit */ -static void cm_write_bypass(uint32_t val) +static void cm_write_bypass(u32 val) { writel(val, &clock_manager_base->bypass); cm_wait_for_fsm(); }
/* function to write the ctrl register which requires a poll of the busy bit */ -static void cm_write_ctrl(uint32_t val) +static void cm_write_ctrl(u32 val) { writel(val, &clock_manager_base->ctrl); cm_wait_for_fsm(); }
/* function to write a clock register that has phase information */ -static void cm_write_with_phase(uint32_t value, - uint32_t reg_address, uint32_t mask) +static int cm_write_with_phase(u32 value, u32 reg_address, u32 mask) { + int ret; + /* poll until phase is zero */ - while (readl(reg_address) & mask) - ; + ret = wait_for_bit(__func__, (const u32 *)reg_address, mask, + false, 20000, false); + if (ret) + return ret;
- while (readl(reg_address) & mask) - ; + return wait_for_bit(__func__, (const u32 *)reg_address, mask, + false, 20000, false); }
/* @@ -233,11 +215,6 @@ void cm_basic_init(const struct cm_config * const cfg)
-#define LOCKED_MASK \ - (CLKMGR_INTER_SDRPLLLOCKED_MASK | \ - CLKMGR_INTER_PERPLLLOCKED_MASK | \ - CLKMGR_INTER_MAINPLLLOCKED_MASK) - cm_wait_for_lock(LOCKED_MASK);
/* write the sdram clock counters before toggling outreset all */ @@ -257,13 +234,13 @@ void cm_basic_init(const struct cm_config * const cfg) * after locking, but before taking out of bypass * assert/deassert outresetall */ - uint32_t mainvco = readl(&clock_manager_base->main_pll.vco); + u32 mainvco = readl(&clock_manager_base->main_pll.vco);
/* assert main outresetall */ writel(mainvco | CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK, &clock_manager_base->main_pll.vco);
- uint32_t periphvco = readl(&clock_manager_base->per_pll.vco); + u32 periphvco = readl(&clock_manager_base->per_pll.vco);
/* assert pheriph outresetall */ writel(periphvco | CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK, @@ -291,20 +268,20 @@ void cm_basic_init(const struct cm_config * const cfg) * are aligned nicely; so we can change any phase. */ cm_write_with_phase(cfg->ddrdqsclk, - (uint32_t)&clock_manager_base->sdr_pll.ddrdqsclk, + (u32)&clock_manager_base->sdr_pll.ddrdqsclk, CLKMGR_SDRPLLGRP_DDRDQSCLK_PHASE_MASK);
/* SDRAM DDR2XDQSCLK */ cm_write_with_phase(cfg->ddr2xdqsclk, - (uint32_t)&clock_manager_base->sdr_pll.ddr2xdqsclk, + (u32)&clock_manager_base->sdr_pll.ddr2xdqsclk, CLKMGR_SDRPLLGRP_DDR2XDQSCLK_PHASE_MASK);
cm_write_with_phase(cfg->ddrdqclk, - (uint32_t)&clock_manager_base->sdr_pll.ddrdqclk, + (u32)&clock_manager_base->sdr_pll.ddrdqclk, CLKMGR_SDRPLLGRP_DDRDQCLK_PHASE_MASK);
cm_write_with_phase(cfg->s2fuser2clk, - (uint32_t)&clock_manager_base->sdr_pll.s2fuser2clk, + (u32)&clock_manager_base->sdr_pll.s2fuser2clk, CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_MASK);
/* Take all three PLLs out of bypass when safe mode is cleared. */ @@ -333,7 +310,7 @@ void cm_basic_init(const struct cm_config * const cfg)
static unsigned int cm_get_main_vco_clk_hz(void) { - uint32_t reg, clock; + u32 reg, clock;
/* get the main VCO clock */ reg = readl(&clock_manager_base->main_pll.vco); @@ -348,7 +325,7 @@ static unsigned int cm_get_main_vco_clk_hz(void)
static unsigned int cm_get_per_vco_clk_hz(void) { - uint32_t reg, clock = 0; + u32 reg, clock = 0;
/* identify PER PLL clock source */ reg = readl(&clock_manager_base->per_pll.vco); @@ -373,7 +350,7 @@ static unsigned int cm_get_per_vco_clk_hz(void)
unsigned long cm_get_mpu_clk_hz(void) { - uint32_t reg, clock; + u32 reg, clock;
@@ -387,7 +364,7 @@ unsigned long cm_get_mpu_clk_hz(void)
unsigned long cm_get_sdram_clk_hz(void) { - uint32_t reg, clock = 0; + u32 reg, clock = 0;
/* identify SDRAM PLL clock source */ reg = readl(&clock_manager_base->sdr_pll.vco); @@ -418,7 +395,7 @@ unsigned long cm_get_sdram_clk_hz(void)
unsigned int cm_get_l4_sp_clk_hz(void) { - uint32_t reg, clock = 0; + u32 reg, clock = 0;
/* identify the source of L4 SP clock */ reg = readl(&clock_manager_base->main_pll.l4src); @@ -452,7 +429,7 @@ unsigned int cm_get_l4_sp_clk_hz(void)
unsigned int cm_get_mmc_controller_clk_hz(void) { - uint32_t reg, clock = 0; + u32 reg, clock = 0;
/* identify the source of MMC clock */ reg = readl(&clock_manager_base->per_pll.src); @@ -482,7 +459,7 @@ unsigned int cm_get_mmc_controller_clk_hz(void)
unsigned int cm_get_qspi_controller_clk_hz(void) { - uint32_t reg, clock = 0; + u32 reg, clock = 0;
/* identify the source of QSPI clock */ reg = readl(&clock_manager_base->per_pll.src); @@ -510,7 +487,7 @@ unsigned int cm_get_qspi_controller_clk_hz(void)
unsigned int cm_get_spi_controller_clk_hz(void) { - uint32_t reg, clock = 0; + u32 reg, clock = 0;
@@ -521,7 +498,7 @@ unsigned int cm_get_spi_controller_clk_hz(void) return clock; }
-static void cm_print_clock_quick_summary(void) +void cm_print_clock_quick_summary(void) { printf("MPU %10ld kHz\n", cm_get_mpu_clk_hz() / 1000); printf("DDR %10ld kHz\n", cm_get_sdram_clk_hz() / 1000); @@ -534,28 +511,3 @@ static void cm_print_clock_quick_summary(void) printf("UART %8d kHz\n", cm_get_l4_sp_clk_hz() / 1000); printf("SPI %8d kHz\n", cm_get_spi_controller_clk_hz() / 1000); } - -int set_cpu_clk_info(void) -{ - /* Calculate the clock frequencies required for drivers */ - cm_get_l4_sp_clk_hz(); - cm_get_mmc_controller_clk_hz(); - - gd->bd->bi_arm_freq = cm_get_mpu_clk_hz() / 1000000; - gd->bd->bi_dsp_freq = 0; - gd->bd->bi_ddr_freq = cm_get_sdram_clk_hz() / 1000000; - - return 0; -} - -int do_showclocks(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - cm_print_clock_quick_summary(); - return 0; -} - -U_BOOT_CMD( - clocks, CONFIG_SYS_MAXARGS, 1, do_showclocks, - "display clocks", - "" -); diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager.h index 803c926..b076497 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager.h @@ -1,317 +1,19 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef _CLOCK_MANAGER_H_ -#define _CLOCK_MANAGER_H_ +#ifndef _CLOCK_MANAGER_H_ +#define _CLOCK_MANAGER_H_
#ifndef __ASSEMBLER__ -/* Clock speed accessors */ -unsigned long cm_get_mpu_clk_hz(void); -unsigned long cm_get_sdram_clk_hz(void); -unsigned int cm_get_l4_sp_clk_hz(void); -unsigned int cm_get_mmc_controller_clk_hz(void); -unsigned int cm_get_qspi_controller_clk_hz(void); -unsigned int cm_get_spi_controller_clk_hz(void); -const unsigned int cm_get_osc_clk_hz(const int osc); -const unsigned int cm_get_f2s_per_ref_clk_hz(void); -const unsigned int cm_get_f2s_sdr_ref_clk_hz(void); - -/* Clock configuration accessors */ -const struct cm_config * const cm_get_default_config(void); +void cm_wait_for_lock(u32 mask); +int cm_wait_for_fsm(void); +void cm_print_clock_quick_summary(void); #endif
-struct cm_config { - /* main group */ - uint32_t main_vco_base; - uint32_t mpuclk; - uint32_t mainclk; - uint32_t dbgatclk; - uint32_t mainqspiclk; - uint32_t mainnandsdmmcclk; - uint32_t cfg2fuser0clk; - uint32_t maindiv; - uint32_t dbgdiv; - uint32_t tracediv; - uint32_t l4src; - - /* peripheral group */ - uint32_t peri_vco_base; - uint32_t emac0clk; - uint32_t emac1clk; - uint32_t perqspiclk; - uint32_t pernandsdmmcclk; - uint32_t perbaseclk; - uint32_t s2fuser1clk; - uint32_t perdiv; - uint32_t gpiodiv; - uint32_t persrc; - - /* sdram pll group */ - uint32_t sdram_vco_base; - uint32_t ddrdqsclk; - uint32_t ddr2xdqsclk; - uint32_t ddrdqclk; - uint32_t s2fuser2clk; - - /* altera group */ - uint32_t altera_grp_mpuclk; -}; - -void cm_basic_init(const struct cm_config * const cfg); - -struct socfpga_clock_manager_main_pll { - u32 vco; - u32 misc; - u32 mpuclk; - u32 mainclk; - u32 dbgatclk; - u32 mainqspiclk; - u32 mainnandsdmmcclk; - u32 cfgs2fuser0clk; - u32 en; - u32 maindiv; - u32 dbgdiv; - u32 tracediv; - u32 l4src; - u32 stat; - u32 _pad_0x38_0x40[2]; -}; - -struct socfpga_clock_manager_per_pll { - u32 vco; - u32 misc; - u32 emac0clk; - u32 emac1clk; - u32 perqspiclk; - u32 pernandsdmmcclk; - u32 perbaseclk; - u32 s2fuser1clk; - u32 en; - u32 div; - u32 gpiodiv; - u32 src; - u32 stat; - u32 _pad_0x34_0x40[3]; -}; - -struct socfpga_clock_manager_sdr_pll { - u32 vco; - u32 ctrl; - u32 ddrdqsclk; - u32 ddr2xdqsclk; - u32 ddrdqclk; - u32 s2fuser2clk; - u32 en; - u32 stat; -}; - -struct socfpga_clock_manager_altera { - u32 mpuclk; - u32 mainclk; -}; - -struct socfpga_clock_manager { - u32 ctrl; - u32 bypass; - u32 inter; - u32 intren; - u32 dbctrl; - u32 stat; - u32 _pad_0x18_0x3f[10]; - struct socfpga_clock_manager_main_pll main_pll; - struct socfpga_clock_manager_per_pll per_pll; - struct socfpga_clock_manager_sdr_pll sdr_pll; - struct socfpga_clock_manager_altera altera; - u32 _pad_0xe8_0x200[70]; -}; - -#define CLKMGR_CTRL_SAFEMODE (1 << 0) -#define CLKMGR_CTRL_SAFEMODE_OFFSET 0 - -#define CLKMGR_BYPASS_PERPLLSRC (1 << 4) -#define CLKMGR_BYPASS_PERPLLSRC_OFFSET 4 -#define CLKMGR_BYPASS_PERPLL (1 << 3) -#define CLKMGR_BYPASS_PERPLL_OFFSET 3 -#define CLKMGR_BYPASS_SDRPLLSRC (1 << 2) -#define CLKMGR_BYPASS_SDRPLLSRC_OFFSET 2 -#define CLKMGR_BYPASS_SDRPLL (1 << 1) -#define CLKMGR_BYPASS_SDRPLL_OFFSET 1 -#define CLKMGR_BYPASS_MAINPLL (1 << 0) -#define CLKMGR_BYPASS_MAINPLL_OFFSET 0 - -#define CLKMGR_INTER_SDRPLLLOCKED_MASK 0x00000100 -#define CLKMGR_INTER_PERPLLLOCKED_MASK 0x00000080 -#define CLKMGR_INTER_MAINPLLLOCKED_MASK 0x00000040 -#define CLKMGR_INTER_PERPLLLOST_MASK 0x00000010 -#define CLKMGR_INTER_SDRPLLLOST_MASK 0x00000020 -#define CLKMGR_INTER_MAINPLLLOST_MASK 0x00000008 - -#define CLKMGR_STAT_BUSY (1 << 0) - -/* Main PLL */ -#define CLKMGR_MAINPLLGRP_VCO_BGPWRDN (1 << 0) -#define CLKMGR_MAINPLLGRP_VCO_BGPWRDN_OFFSET 0 -#define CLKMGR_MAINPLLGRP_VCO_DENOM_OFFSET 16 -#define CLKMGR_MAINPLLGRP_VCO_DENOM_MASK 0x003f0000 -#define CLKMGR_MAINPLLGRP_VCO_EN (1 << 1) -#define CLKMGR_MAINPLLGRP_VCO_EN_OFFSET 1 -#define CLKMGR_MAINPLLGRP_VCO_NUMER_OFFSET 3 -#define CLKMGR_MAINPLLGRP_VCO_NUMER_MASK 0x0000fff8 -#define CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK 0x01000000 -#define CLKMGR_MAINPLLGRP_VCO_PWRDN (1 << 2) -#define CLKMGR_MAINPLLGRP_VCO_PWRDN_OFFSET 2 -#define CLKMGR_MAINPLLGRP_VCO_REGEXTSEL_MASK 0x80000000 -#define CLKMGR_MAINPLLGRP_VCO_RESET_VALUE 0x8001000d - -#define CLKMGR_MAINPLLGRP_MPUCLK_CNT_OFFSET 0 -#define CLKMGR_MAINPLLGRP_MPUCLK_CNT_MASK 0x000001ff - -#define CLKMGR_MAINPLLGRP_MAINCLK_CNT_OFFSET 0 -#define CLKMGR_MAINPLLGRP_MAINCLK_CNT_MASK 0x000001ff - -#define CLKMGR_MAINPLLGRP_DBGATCLK_CNT_OFFSET 0 -#define CLKMGR_MAINPLLGRP_DBGATCLK_CNT_MASK 0x000001ff - -#define CLKMGR_MAINPLLGRP_MAINQSPICLK_CNT_OFFSET 0 -#define CLKMGR_MAINPLLGRP_MAINQSPICLK_CNT_MASK 0x000001ff - -#define CLKMGR_MAINPLLGRP_MAINNANDSDMMCCLK_CNT_OFFSET 0 -#define CLKMGR_MAINPLLGRP_MAINNANDSDMMCCLK_CNT_MASK 0x000001ff - -#define CLKMGR_MAINPLLGRP_CFGS2FUSER0CLK_CNT_OFFSET 0 -#define CLKMGR_MAINPLLGRP_CFGS2FUSER0CLK_CNT_MASK 0x000001ff - -#define CLKMGR_MAINPLLGRP_EN_DBGATCLK_MASK 0x00000010 -#define CLKMGR_MAINPLLGRP_EN_DBGCLK_MASK 0x00000020 -#define CLKMGR_MAINPLLGRP_EN_DBGTIMERCLK_MASK 0x00000080 -#define CLKMGR_MAINPLLGRP_EN_DBGTRACECLK_MASK 0x00000040 -#define CLKMGR_MAINPLLGRP_EN_L4MPCLK_MASK 0x00000004 -#define CLKMGR_MAINPLLGRP_EN_S2FUSER0CLK_MASK 0x00000200 - -#define CLKMGR_MAINPLLGRP_MAINDIV_L3MPCLK_OFFSET 0 -#define CLKMGR_MAINPLLGRP_MAINDIV_L3MPCLK_MASK 0x00000003 -#define CLKMGR_MAINPLLGRP_MAINDIV_L3SPCLK_OFFSET 2 -#define CLKMGR_MAINPLLGRP_MAINDIV_L3SPCLK_MASK 0x0000000c -#define CLKMGR_MAINPLLGRP_MAINDIV_L4MPCLK_OFFSET 4 -#define CLKMGR_MAINPLLGRP_MAINDIV_L4MPCLK_MASK 0x00000070 -#define CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_OFFSET 7 -#define CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_MASK 0x00000380 - -#define CLKMGR_MAINPLLGRP_DBGDIV_DBGATCLK_OFFSET 0 -#define CLKMGR_MAINPLLGRP_DBGDIV_DBGATCLK_MASK 0x00000003 -#define CLKMGR_MAINPLLGRP_DBGDIV_DBGCLK_OFFSET 2 -#define CLKMGR_MAINPLLGRP_DBGDIV_DBGCLK_MASK 0x0000000c - -#define CLKMGR_MAINPLLGRP_TRACEDIV_TRACECLK_OFFSET 0 -#define CLKMGR_MAINPLLGRP_TRACEDIV_TRACECLK_MASK 0x00000007 - -#define CLKMGR_MAINPLLGRP_L4SRC_L4MP (1 << 0) -#define CLKMGR_MAINPLLGRP_L4SRC_L4MP_OFFSET 0 -#define CLKMGR_MAINPLLGRP_L4SRC_L4SP (1 << 1) -#define CLKMGR_MAINPLLGRP_L4SRC_L4SP_OFFSET 1 -#define CLKMGR_MAINPLLGRP_L4SRC_RESET_VALUE 0x00000000 -#define CLKMGR_L4_SP_CLK_SRC_MAINPLL 0x0 -#define CLKMGR_L4_SP_CLK_SRC_PERPLL 0x1 - -/* Per PLL */ -#define CLKMGR_PERPLLGRP_VCO_DENOM_OFFSET 16 -#define CLKMGR_PERPLLGRP_VCO_DENOM_MASK 0x003f0000 -#define CLKMGR_PERPLLGRP_VCO_NUMER_OFFSET 3 -#define CLKMGR_PERPLLGRP_VCO_NUMER_MASK 0x0000fff8 -#define CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK 0x01000000 -#define CLKMGR_PERPLLGRP_VCO_PSRC_OFFSET 22 -#define CLKMGR_PERPLLGRP_VCO_PSRC_MASK 0x00c00000 -#define CLKMGR_PERPLLGRP_VCO_REGEXTSEL_MASK 0x80000000 -#define CLKMGR_PERPLLGRP_VCO_RESET_VALUE 0x8001000d -#define CLKMGR_PERPLLGRP_VCO_SSRC_OFFSET 22 -#define CLKMGR_PERPLLGRP_VCO_SSRC_MASK 0x00c00000 - -#define CLKMGR_VCO_SSRC_EOSC1 0x0 -#define CLKMGR_VCO_SSRC_EOSC2 0x1 -#define CLKMGR_VCO_SSRC_F2S 0x2 - -#define CLKMGR_PERPLLGRP_EMAC0CLK_CNT_OFFSET 0 -#define CLKMGR_PERPLLGRP_EMAC0CLK_CNT_MASK 0x000001ff - -#define CLKMGR_PERPLLGRP_EMAC1CLK_CNT_OFFSET 0 -#define CLKMGR_PERPLLGRP_EMAC1CLK_CNT_MASK 0x000001ff - -#define CLKMGR_PERPLLGRP_PERQSPICLK_CNT_OFFSET 0 -#define CLKMGR_PERPLLGRP_PERQSPICLK_CNT_MASK 0x000001ff - -#define CLKMGR_PERPLLGRP_PERNANDSDMMCCLK_CNT_OFFSET 0 -#define CLKMGR_PERPLLGRP_PERNANDSDMMCCLK_CNT_MASK 0x000001ff - -#define CLKMGR_PERPLLGRP_PERBASECLK_CNT_OFFSET 0 -#define CLKMGR_PERPLLGRP_PERBASECLK_CNT_MASK 0x000001ff - -#define CLKMGR_PERPLLGRP_S2FUSER1CLK_CNT_OFFSET 0 -#define CLKMGR_PERPLLGRP_S2FUSER1CLK_CNT_MASK 0x000001ff - -#define CLKMGR_PERPLLGRP_EN_NANDCLK_MASK 0x00000400 -#define CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK 0x00000100 - -#define CLKMGR_PERPLLGRP_DIV_CAN0CLK_OFFSET 6 -#define CLKMGR_PERPLLGRP_DIV_CAN0CLK_MASK 0x000001c0 -#define CLKMGR_PERPLLGRP_DIV_CAN1CLK_OFFSET 9 -#define CLKMGR_PERPLLGRP_DIV_CAN1CLK_MASK 0x00000e00 -#define CLKMGR_PERPLLGRP_DIV_SPIMCLK_OFFSET 3 -#define CLKMGR_PERPLLGRP_DIV_SPIMCLK_OFFSET 3 -#define CLKMGR_PERPLLGRP_DIV_USBCLK_OFFSET 0 -#define CLKMGR_PERPLLGRP_DIV_USBCLK_MASK 0x00000007 - -#define CLKMGR_PERPLLGRP_GPIODIV_GPIODBCLK_OFFSET 0 -#define CLKMGR_PERPLLGRP_GPIODIV_GPIODBCLK_MASK 0x00ffffff - -#define CLKMGR_PERPLLGRP_SRC_NAND_OFFSET 2 -#define CLKMGR_PERPLLGRP_SRC_NAND_MASK 0x0000000c -#define CLKMGR_PERPLLGRP_SRC_QSPI_OFFSET 4 -#define CLKMGR_PERPLLGRP_SRC_QSPI_MASK 0x00000030 -#define CLKMGR_PERPLLGRP_SRC_RESET_VALUE 0x00000015 -#define CLKMGR_PERPLLGRP_SRC_SDMMC_OFFSET 0 -#define CLKMGR_PERPLLGRP_SRC_SDMMC_MASK 0x00000003 -#define CLKMGR_SDMMC_CLK_SRC_F2S 0x0 -#define CLKMGR_SDMMC_CLK_SRC_MAIN 0x1 -#define CLKMGR_SDMMC_CLK_SRC_PER 0x2 -#define CLKMGR_QSPI_CLK_SRC_F2S 0x0 -#define CLKMGR_QSPI_CLK_SRC_MAIN 0x1 -#define CLKMGR_QSPI_CLK_SRC_PER 0x2 - -/* SDR PLL */ -#define CLKMGR_SDRPLLGRP_VCO_DENOM_OFFSET 16 -#define CLKMGR_SDRPLLGRP_VCO_DENOM_MASK 0x003f0000 -#define CLKMGR_SDRPLLGRP_VCO_NUMER_OFFSET 3 -#define CLKMGR_SDRPLLGRP_VCO_NUMER_MASK 0x0000fff8 -#define CLKMGR_SDRPLLGRP_VCO_OUTRESETALL (1 << 24) -#define CLKMGR_SDRPLLGRP_VCO_OUTRESETALL_OFFSET 24 -#define CLKMGR_SDRPLLGRP_VCO_OUTRESET_OFFSET 25 -#define CLKMGR_SDRPLLGRP_VCO_OUTRESET_MASK 0x7e000000 -#define CLKMGR_SDRPLLGRP_VCO_REGEXTSEL_MASK 0x80000000 -#define CLKMGR_SDRPLLGRP_VCO_RESET_VALUE 0x8001000d -#define CLKMGR_SDRPLLGRP_VCO_SSRC_OFFSET 22 -#define CLKMGR_SDRPLLGRP_VCO_SSRC_MASK 0x00c00000 - -#define CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_OFFSET 0 -#define CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK 0x000001ff -#define CLKMGR_SDRPLLGRP_DDRDQSCLK_PHASE_OFFSET 9 -#define CLKMGR_SDRPLLGRP_DDRDQSCLK_PHASE_MASK 0x00000e00 - -#define CLKMGR_SDRPLLGRP_DDR2XDQSCLK_CNT_OFFSET 0 -#define CLKMGR_SDRPLLGRP_DDR2XDQSCLK_CNT_MASK 0x000001ff -#define CLKMGR_SDRPLLGRP_DDR2XDQSCLK_PHASE_OFFSET 9 -#define CLKMGR_SDRPLLGRP_DDR2XDQSCLK_PHASE_MASK 0x00000e00 - -#define CLKMGR_SDRPLLGRP_DDRDQCLK_CNT_OFFSET 0 -#define CLKMGR_SDRPLLGRP_DDRDQCLK_CNT_MASK 0x000001ff -#define CLKMGR_SDRPLLGRP_DDRDQCLK_PHASE_OFFSET 9 -#define CLKMGR_SDRPLLGRP_DDRDQCLK_PHASE_MASK 0x00000e00 - -#define CLKMGR_SDRPLLGRP_S2FUSER2CLK_CNT_OFFSET 0 -#define CLKMGR_SDRPLLGRP_S2FUSER2CLK_CNT_MASK 0x000001ff -#define CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_OFFSET 9 -#define CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_MASK 0x00000e00 - +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#include <asm/arch/clock_manager_gen5.h> +#endif #endif /* _CLOCK_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h similarity index 80% copy from arch/arm/mach-socfpga/include/mach/clock_manager.h copy to arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h index 803c926..dec08e0 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h @@ -1,67 +1,51 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef _CLOCK_MANAGER_H_ -#define _CLOCK_MANAGER_H_ +#ifndef _CLOCK_MANAGER_GEN5_H_ +#define _CLOCK_MANAGER_GEN5_H_
#ifndef __ASSEMBLER__ -/* Clock speed accessors */ -unsigned long cm_get_mpu_clk_hz(void); -unsigned long cm_get_sdram_clk_hz(void); -unsigned int cm_get_l4_sp_clk_hz(void); -unsigned int cm_get_mmc_controller_clk_hz(void); -unsigned int cm_get_qspi_controller_clk_hz(void); -unsigned int cm_get_spi_controller_clk_hz(void); -const unsigned int cm_get_osc_clk_hz(const int osc); -const unsigned int cm_get_f2s_per_ref_clk_hz(void); -const unsigned int cm_get_f2s_sdr_ref_clk_hz(void); - -/* Clock configuration accessors */ -const struct cm_config * const cm_get_default_config(void); -#endif
struct cm_config { /* main group */ - uint32_t main_vco_base; - uint32_t mpuclk; - uint32_t mainclk; - uint32_t dbgatclk; - uint32_t mainqspiclk; - uint32_t mainnandsdmmcclk; - uint32_t cfg2fuser0clk; - uint32_t maindiv; - uint32_t dbgdiv; - uint32_t tracediv; - uint32_t l4src; + u32 main_vco_base; + u32 mpuclk; + u32 mainclk; + u32 dbgatclk; + u32 mainqspiclk; + u32 mainnandsdmmcclk; + u32 cfg2fuser0clk; + u32 maindiv; + u32 dbgdiv; + u32 tracediv; + u32 l4src;
/* peripheral group */ - uint32_t peri_vco_base; - uint32_t emac0clk; - uint32_t emac1clk; - uint32_t perqspiclk; - uint32_t pernandsdmmcclk; - uint32_t perbaseclk; - uint32_t s2fuser1clk; - uint32_t perdiv; - uint32_t gpiodiv; - uint32_t persrc; + u32 peri_vco_base; + u32 emac0clk; + u32 emac1clk; + u32 perqspiclk; + u32 pernandsdmmcclk; + u32 perbaseclk; + u32 s2fuser1clk; + u32 perdiv; + u32 gpiodiv; + u32 persrc;
/* sdram pll group */ - uint32_t sdram_vco_base; - uint32_t ddrdqsclk; - uint32_t ddr2xdqsclk; - uint32_t ddrdqclk; - uint32_t s2fuser2clk; + u32 sdram_vco_base; + u32 ddrdqsclk; + u32 ddr2xdqsclk; + u32 ddrdqclk; + u32 s2fuser2clk;
/* altera group */ - uint32_t altera_grp_mpuclk; + u32 altera_grp_mpuclk; };
-void cm_basic_init(const struct cm_config * const cfg); - struct socfpga_clock_manager_main_pll { u32 vco; u32 misc; @@ -128,40 +112,61 @@ struct socfpga_clock_manager { u32 _pad_0xe8_0x200[70]; };
-#define CLKMGR_CTRL_SAFEMODE (1 << 0) +/* Clock speed accessors */ +unsigned long cm_get_mpu_clk_hz(void); +unsigned long cm_get_sdram_clk_hz(void); +unsigned int cm_get_l4_sp_clk_hz(void); +unsigned int cm_get_mmc_controller_clk_hz(void); +unsigned int cm_get_qspi_controller_clk_hz(void); +unsigned int cm_get_spi_controller_clk_hz(void); +const unsigned int cm_get_osc_clk_hz(const int osc); +const unsigned int cm_get_f2s_per_ref_clk_hz(void); +const unsigned int cm_get_f2s_sdr_ref_clk_hz(void); + +/* Clock configuration accessors */ +void cm_basic_init(const struct cm_config * const cfg); +const struct cm_config * const cm_get_default_config(void); +#endif /* __ASSEMBLER__ */ + +#define LOCKED_MASK \ + (CLKMGR_INTER_SDRPLLLOCKED_MASK | \ + CLKMGR_INTER_PERPLLLOCKED_MASK | \ + CLKMGR_INTER_MAINPLLLOCKED_MASK) + +#define CLKMGR_CTRL_SAFEMODE BIT(0) #define CLKMGR_CTRL_SAFEMODE_OFFSET 0
-#define CLKMGR_BYPASS_PERPLLSRC (1 << 4) +#define CLKMGR_BYPASS_PERPLLSRC BIT(4) #define CLKMGR_BYPASS_PERPLLSRC_OFFSET 4 -#define CLKMGR_BYPASS_PERPLL (1 << 3) +#define CLKMGR_BYPASS_PERPLL BIT(3) #define CLKMGR_BYPASS_PERPLL_OFFSET 3 -#define CLKMGR_BYPASS_SDRPLLSRC (1 << 2) +#define CLKMGR_BYPASS_SDRPLLSRC BIT(2) #define CLKMGR_BYPASS_SDRPLLSRC_OFFSET 2 -#define CLKMGR_BYPASS_SDRPLL (1 << 1) +#define CLKMGR_BYPASS_SDRPLL BIT(1) #define CLKMGR_BYPASS_SDRPLL_OFFSET 1 -#define CLKMGR_BYPASS_MAINPLL (1 << 0) +#define CLKMGR_BYPASS_MAINPLL BIT(0) #define CLKMGR_BYPASS_MAINPLL_OFFSET 0
-#define CLKMGR_INTER_SDRPLLLOCKED_MASK 0x00000100 -#define CLKMGR_INTER_PERPLLLOCKED_MASK 0x00000080 -#define CLKMGR_INTER_MAINPLLLOCKED_MASK 0x00000040 -#define CLKMGR_INTER_PERPLLLOST_MASK 0x00000010 -#define CLKMGR_INTER_SDRPLLLOST_MASK 0x00000020 -#define CLKMGR_INTER_MAINPLLLOST_MASK 0x00000008 +#define CLKMGR_INTER_MAINPLLLOST_MASK BIT(3) +#define CLKMGR_INTER_PERPLLLOST_MASK BIT(4) +#define CLKMGR_INTER_SDRPLLLOST_MASK BIT(5) +#define CLKMGR_INTER_MAINPLLLOCKED_MASK BIT(6) +#define CLKMGR_INTER_PERPLLLOCKED_MASK BIT(7) +#define CLKMGR_INTER_SDRPLLLOCKED_MASK BIT(8)
-#define CLKMGR_STAT_BUSY (1 << 0) +#define CLKMGR_STAT_BUSY BIT(0)
/* Main PLL */ -#define CLKMGR_MAINPLLGRP_VCO_BGPWRDN (1 << 0) +#define CLKMGR_MAINPLLGRP_VCO_BGPWRDN BIT(0) #define CLKMGR_MAINPLLGRP_VCO_BGPWRDN_OFFSET 0 #define CLKMGR_MAINPLLGRP_VCO_DENOM_OFFSET 16 #define CLKMGR_MAINPLLGRP_VCO_DENOM_MASK 0x003f0000 -#define CLKMGR_MAINPLLGRP_VCO_EN (1 << 1) +#define CLKMGR_MAINPLLGRP_VCO_EN BIT(1) #define CLKMGR_MAINPLLGRP_VCO_EN_OFFSET 1 #define CLKMGR_MAINPLLGRP_VCO_NUMER_OFFSET 3 #define CLKMGR_MAINPLLGRP_VCO_NUMER_MASK 0x0000fff8 #define CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK 0x01000000 -#define CLKMGR_MAINPLLGRP_VCO_PWRDN (1 << 2) +#define CLKMGR_MAINPLLGRP_VCO_PWRDN BIT(2) #define CLKMGR_MAINPLLGRP_VCO_PWRDN_OFFSET 2 #define CLKMGR_MAINPLLGRP_VCO_REGEXTSEL_MASK 0x80000000 #define CLKMGR_MAINPLLGRP_VCO_RESET_VALUE 0x8001000d @@ -184,12 +189,12 @@ struct socfpga_clock_manager { #define CLKMGR_MAINPLLGRP_CFGS2FUSER0CLK_CNT_OFFSET 0 #define CLKMGR_MAINPLLGRP_CFGS2FUSER0CLK_CNT_MASK 0x000001ff
-#define CLKMGR_MAINPLLGRP_EN_DBGATCLK_MASK 0x00000010 -#define CLKMGR_MAINPLLGRP_EN_DBGCLK_MASK 0x00000020 -#define CLKMGR_MAINPLLGRP_EN_DBGTIMERCLK_MASK 0x00000080 -#define CLKMGR_MAINPLLGRP_EN_DBGTRACECLK_MASK 0x00000040 -#define CLKMGR_MAINPLLGRP_EN_L4MPCLK_MASK 0x00000004 -#define CLKMGR_MAINPLLGRP_EN_S2FUSER0CLK_MASK 0x00000200 +#define CLKMGR_MAINPLLGRP_EN_L4MPCLK_MASK BIT(2) +#define CLKMGR_MAINPLLGRP_EN_DBGATCLK_MASK BIT(4) +#define CLKMGR_MAINPLLGRP_EN_DBGCLK_MASK BIT(5) +#define CLKMGR_MAINPLLGRP_EN_DBGTRACECLK_MASK BIT(6) +#define CLKMGR_MAINPLLGRP_EN_DBGTIMERCLK_MASK BIT(7) +#define CLKMGR_MAINPLLGRP_EN_S2FUSER0CLK_MASK BIT(9)
#define CLKMGR_MAINPLLGRP_MAINDIV_L3MPCLK_OFFSET 0 #define CLKMGR_MAINPLLGRP_MAINDIV_L3MPCLK_MASK 0x00000003 @@ -208,9 +213,9 @@ struct socfpga_clock_manager { #define CLKMGR_MAINPLLGRP_TRACEDIV_TRACECLK_OFFSET 0 #define CLKMGR_MAINPLLGRP_TRACEDIV_TRACECLK_MASK 0x00000007
-#define CLKMGR_MAINPLLGRP_L4SRC_L4MP (1 << 0) +#define CLKMGR_MAINPLLGRP_L4SRC_L4MP BIT(0) #define CLKMGR_MAINPLLGRP_L4SRC_L4MP_OFFSET 0 -#define CLKMGR_MAINPLLGRP_L4SRC_L4SP (1 << 1) +#define CLKMGR_MAINPLLGRP_L4SRC_L4SP BIT(1) #define CLKMGR_MAINPLLGRP_L4SRC_L4SP_OFFSET 1 #define CLKMGR_MAINPLLGRP_L4SRC_RESET_VALUE 0x00000000 #define CLKMGR_L4_SP_CLK_SRC_MAINPLL 0x0 @@ -285,11 +290,11 @@ struct socfpga_clock_manager { #define CLKMGR_SDRPLLGRP_VCO_DENOM_MASK 0x003f0000 #define CLKMGR_SDRPLLGRP_VCO_NUMER_OFFSET 3 #define CLKMGR_SDRPLLGRP_VCO_NUMER_MASK 0x0000fff8 -#define CLKMGR_SDRPLLGRP_VCO_OUTRESETALL (1 << 24) +#define CLKMGR_SDRPLLGRP_VCO_OUTRESETALL BIT(24) #define CLKMGR_SDRPLLGRP_VCO_OUTRESETALL_OFFSET 24 #define CLKMGR_SDRPLLGRP_VCO_OUTRESET_OFFSET 25 #define CLKMGR_SDRPLLGRP_VCO_OUTRESET_MASK 0x7e000000 -#define CLKMGR_SDRPLLGRP_VCO_REGEXTSEL_MASK 0x80000000 +#define CLKMGR_SDRPLLGRP_VCO_REGEXTSEL_MASK BIT(31) #define CLKMGR_SDRPLLGRP_VCO_RESET_VALUE 0x8001000d #define CLKMGR_SDRPLLGRP_VCO_SSRC_OFFSET 22 #define CLKMGR_SDRPLLGRP_VCO_SSRC_MASK 0x00c00000 @@ -314,4 +319,4 @@ struct socfpga_clock_manager { #define CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_OFFSET 9 #define CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_MASK 0x00000e00
-#endif /* _CLOCK_MANAGER_H_ */ +#endif /* _CLOCK_MANAGER_GEN5_H_ */
[snip]
You changed the return type of this function here...
int ret;
if (ret)
return ret; writel(value, reg_address);
because now, you got a 20 seconds timeout and a return value if there is a timeout,
cm_wait_for_lock(LOCKED_MASK); /* write the sdram clock counters before toggling outreset all */
u32 mainvco = readl(&clock_manager_base->main_pll.vco); /* assert main outresetall */ writel(mainvco | CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK, &clock_manager_base->main_pll.vco);
u32 periphvco = readl(&clock_manager_base->per_pll.vco); /* assert pheriph outresetall */ writel(periphvco | CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK,
(u32)&clock_manager_base->sdr_pll.ddrdqsclk, CLKMGR_SDRPLLGRP_DDRDQSCLK_PHASE_MASK); /* SDRAM DDR2XDQSCLK */ cm_write_with_phase(cfg->ddr2xdqsclk,
(u32)&clock_manager_base->sdr_pll.ddr2xdqsclk, CLKMGR_SDRPLLGRP_DDR2XDQSCLK_PHASE_MASK); cm_write_with_phase(cfg->ddrdqclk,
(u32)&clock_manager_base->sdr_pll.ddrdqclk, CLKMGR_SDRPLLGRP_DDRDQCLK_PHASE_MASK); cm_write_with_phase(cfg->s2fuser2clk,
but you're not checking the return value at all?
Dinh
[snip]
Will update commit message for more detail.
int ret;
if (ret)
Will check the return value from cm_write_with_phase() and cm_basic_init(). Thanks.
Regards Ley Foon
Restructure reset manager driver in the preparation to support A10. Move the Gen5 specific code to gen5 files. Minor update in socfpga_per_reset(). No functional change.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 2 +- arch/arm/mach-socfpga/include/mach/reset_manager.h | 48 ++--------- .../mach-socfpga/include/mach/reset_manager_gen5.h | 47 +++++++++++ arch/arm/mach-socfpga/reset_manager.c | 93 +--------------------- .../{reset_manager.c => reset_manager_gen5.c} | 51 ++++++------ 5 files changed, 81 insertions(+), 160 deletions(-) create mode 100644 arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h copy arch/arm/mach-socfpga/{reset_manager.c => reset_manager_gen5.c} (75%)
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index b76de4c..97819ac 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -14,7 +14,7 @@ obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o
# QTS-generated config file wrappers obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o \ - clock_manager_gen5.o + clock_manager_gen5.o reset_manager_gen5.o obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ wrap_sdram_config.o CFLAGS_wrap_iocsr_config.o += -I$(srctree)/board/$(BOARDDIR) diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h index 2f070f2..c99efa7 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager.h @@ -1,34 +1,19 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef _RESET_MANAGER_H_ -#define _RESET_MANAGER_H_ +#ifndef _RESET_MANAGER_H_ +#define _RESET_MANAGER_H_
void reset_cpu(ulong addr); -void reset_deassert_peripherals_handoff(void);
-void socfpga_bridges_reset(int enable); +int socfpga_bridges_reset(int enable);
void socfpga_per_reset(u32 reset, int set); void socfpga_per_reset_all(void);
-struct socfpga_reset_manager { - u32 status; - u32 ctrl; - u32 counts; - u32 padding1; - u32 mpu_mod_reset; - u32 per_mod_reset; - u32 per2_mod_reset; - u32 brg_mod_reset; - u32 misc_mod_reset; - u32 padding2[12]; - u32 tstscratch; -}; - #if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) #define RSTMGR_CTRL_SWWARMRSTREQ_LSB 2 #else @@ -55,28 +40,11 @@ struct socfpga_reset_manager { #define RSTMGR_BANK(_reset) \ (((_reset) >> RSTMGR_BANK_OFFSET) & RSTMGR_BANK_MASK)
-/* - * SocFPGA Cyclone V/Arria V reset IDs, bank mapping is as follows: - * 0 ... mpumodrst - * 1 ... permodrst - * 2 ... per2modrst - * 3 ... brgmodrst - * 4 ... miscmodrst - */ -#define RSTMGR_EMAC0 RSTMGR_DEFINE(1, 0) -#define RSTMGR_EMAC1 RSTMGR_DEFINE(1, 1) -#define RSTMGR_NAND RSTMGR_DEFINE(1, 4) -#define RSTMGR_QSPI RSTMGR_DEFINE(1, 5) -#define RSTMGR_L4WD0 RSTMGR_DEFINE(1, 6) -#define RSTMGR_OSC1TIMER0 RSTMGR_DEFINE(1, 8) -#define RSTMGR_UART0 RSTMGR_DEFINE(1, 16) -#define RSTMGR_SPIM0 RSTMGR_DEFINE(1, 18) -#define RSTMGR_SPIM1 RSTMGR_DEFINE(1, 19) -#define RSTMGR_SDMMC RSTMGR_DEFINE(1, 22) -#define RSTMGR_DMA RSTMGR_DEFINE(1, 28) -#define RSTMGR_SDR RSTMGR_DEFINE(1, 29) - /* Create a human-readable reference to SoCFPGA reset. */ #define SOCFPGA_RESET(_name) RSTMGR_##_name
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#include <asm/arch/reset_manager_gen5.h> +#endif + #endif /* _RESET_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h b/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h new file mode 100644 index 0000000..672c519 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h @@ -0,0 +1,47 @@ +/* + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _RESET_MANAGER_GEN5_H_ +#define _RESET_MANAGER_GEN5_H_ + +void reset_deassert_peripherals_handoff(void); + +struct socfpga_reset_manager { + u32 status; + u32 ctrl; + u32 counts; + u32 padding1; + u32 mpu_mod_reset; + u32 per_mod_reset; + u32 per2_mod_reset; + u32 brg_mod_reset; + u32 misc_mod_reset; + u32 padding2[12]; + u32 tstscratch; +}; + +/* + * SocFPGA Cyclone V/Arria V reset IDs, bank mapping is as follows: + * 0 ... mpumodrst + * 1 ... permodrst + * 2 ... per2modrst + * 3 ... brgmodrst + * 4 ... miscmodrst + */ +#define RSTMGR_EMAC0 RSTMGR_DEFINE(1, 0) +#define RSTMGR_EMAC1 RSTMGR_DEFINE(1, 1) +#define RSTMGR_NAND RSTMGR_DEFINE(1, 4) +#define RSTMGR_QSPI RSTMGR_DEFINE(1, 5) +#define RSTMGR_L4WD0 RSTMGR_DEFINE(1, 6) +#define RSTMGR_OSC1TIMER0 RSTMGR_DEFINE(1, 8) +#define RSTMGR_UART0 RSTMGR_DEFINE(1, 16) +#define RSTMGR_SPIM0 RSTMGR_DEFINE(1, 18) +#define RSTMGR_SPIM1 RSTMGR_DEFINE(1, 19) +#define RSTMGR_SDMMC RSTMGR_DEFINE(1, 22) +#define RSTMGR_DMA RSTMGR_DEFINE(1, 28) +#define RSTMGR_SDR RSTMGR_DEFINE(1, 29) + +#endif /* _RESET_MANAGER_GEN5_H_ */ diff --git a/arch/arm/mach-socfpga/reset_manager.c b/arch/arm/mach-socfpga/reset_manager.c index b6beaa2..29438ed 100644 --- a/arch/arm/mach-socfpga/reset_manager.c +++ b/arch/arm/mach-socfpga/reset_manager.c @@ -7,53 +7,12 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/fpga_manager.h> #include <asm/arch/reset_manager.h> -#include <asm/arch/system_manager.h>
static const struct socfpga_reset_manager *reset_manager_base = (void *)SOCFPGA_RSTMGR_ADDRESS; -static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - -/* Assert or de-assert SoCFPGA reset manager reset. */ -void socfpga_per_reset(u32 reset, int set) -{ - const void *reg; - - if (RSTMGR_BANK(reset) == 0) - reg = &reset_manager_base->mpu_mod_reset; - else if (RSTMGR_BANK(reset) == 1) - reg = &reset_manager_base->per_mod_reset; - else if (RSTMGR_BANK(reset) == 2) - reg = &reset_manager_base->per2_mod_reset; - else if (RSTMGR_BANK(reset) == 3) - reg = &reset_manager_base->brg_mod_reset; - else if (RSTMGR_BANK(reset) == 4) - reg = &reset_manager_base->misc_mod_reset; - else /* Invalid reset register, do nothing */ - return; - - if (set) - setbits_le32(reg, 1 << RSTMGR_RESET(reset)); - else - clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); -} - -/* - * Assert reset on every peripheral but L4WD0. - * Watchdog must be kept intact to prevent glitches - * and/or hangs. - */ -void socfpga_per_reset_all(void) -{ - const u32 l4wd0 = 1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)); - - writel(~l4wd0, &reset_manager_base->per_mod_reset); - writel(0xffffffff, &reset_manager_base->per2_mod_reset); -}
/* * Write the reset manager register to cause reset @@ -61,8 +20,8 @@ void socfpga_per_reset_all(void) void reset_cpu(ulong addr) { /* request a warm reset */ - writel((1 << RSTMGR_CTRL_SWWARMRSTREQ_LSB), - &reset_manager_base->ctrl); + writel(1 << RSTMGR_CTRL_SWWARMRSTREQ_LSB, + &reset_manager_base->ctrl); /* * infinite loop here as watchdog will trigger and reset * the processor @@ -70,51 +29,3 @@ void reset_cpu(ulong addr) while (1) ; } - -/* - * Release peripherals from reset based on handoff - */ -void reset_deassert_peripherals_handoff(void) -{ - writel(0, &reset_manager_base->per_mod_reset); -} - -#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) -void socfpga_bridges_reset(int enable) -{ - /* For SoCFPGA-VT, this is NOP. */ -} -#else - -#define L3REGS_REMAP_LWHPS2FPGA_MASK 0x10 -#define L3REGS_REMAP_HPS2FPGA_MASK 0x08 -#define L3REGS_REMAP_OCRAM_MASK 0x01 - -void socfpga_bridges_reset(int enable) -{ - const uint32_t l3mask = L3REGS_REMAP_LWHPS2FPGA_MASK | - L3REGS_REMAP_HPS2FPGA_MASK | - L3REGS_REMAP_OCRAM_MASK; - - if (enable) { - /* brdmodrst */ - writel(0xffffffff, &reset_manager_base->brg_mod_reset); - } else { - writel(0, &sysmgr_regs->iswgrp_handoff[0]); - writel(l3mask, &sysmgr_regs->iswgrp_handoff[1]); - - /* Check signal from FPGA. */ - if (!fpgamgr_test_fpga_ready()) { - /* FPGA not ready, do nothing. */ - printf("%s: FPGA not ready, aborting.\n", __func__); - return; - } - - /* brdmodrst */ - writel(0, &reset_manager_base->brg_mod_reset); - - /* Remap the bridges into memory map */ - writel(l3mask, SOCFPGA_L3REGS_ADDRESS); - } -} -#endif diff --git a/arch/arm/mach-socfpga/reset_manager.c b/arch/arm/mach-socfpga/reset_manager_gen5.c similarity index 75% copy from arch/arm/mach-socfpga/reset_manager.c copy to arch/arm/mach-socfpga/reset_manager_gen5.c index b6beaa2..42be69a 100644 --- a/arch/arm/mach-socfpga/reset_manager.c +++ b/arch/arm/mach-socfpga/reset_manager_gen5.c @@ -15,26 +15,35 @@ DECLARE_GLOBAL_DATA_PTR;
static const struct socfpga_reset_manager *reset_manager_base = (void *)SOCFPGA_RSTMGR_ADDRESS; -static struct socfpga_system_manager *sysmgr_regs = +static const struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
/* Assert or de-assert SoCFPGA reset manager reset. */ void socfpga_per_reset(u32 reset, int set) { - const void *reg; + const u32 *reg; + u32 rstmgr_bank = RSTMGR_BANK(reset);
- if (RSTMGR_BANK(reset) == 0) + switch (rstmgr_bank) { + case 0: reg = &reset_manager_base->mpu_mod_reset; - else if (RSTMGR_BANK(reset) == 1) + break; + case 1: reg = &reset_manager_base->per_mod_reset; - else if (RSTMGR_BANK(reset) == 2) + break; + case 2: reg = &reset_manager_base->per2_mod_reset; - else if (RSTMGR_BANK(reset) == 3) + break; + case 3: reg = &reset_manager_base->brg_mod_reset; - else if (RSTMGR_BANK(reset) == 4) + break; + case 4: reg = &reset_manager_base->misc_mod_reset; - else /* Invalid reset register, do nothing */ + break; + + default: return; + }
if (set) setbits_le32(reg, 1 << RSTMGR_RESET(reset)); @@ -56,22 +65,6 @@ void socfpga_per_reset_all(void) }
/* - * Write the reset manager register to cause reset - */ -void reset_cpu(ulong addr) -{ - /* request a warm reset */ - writel((1 << RSTMGR_CTRL_SWWARMRSTREQ_LSB), - &reset_manager_base->ctrl); - /* - * infinite loop here as watchdog will trigger and reset - * the processor - */ - while (1) - ; -} - -/* * Release peripherals from reset based on handoff */ void reset_deassert_peripherals_handoff(void) @@ -80,9 +73,10 @@ void reset_deassert_peripherals_handoff(void) }
#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) -void socfpga_bridges_reset(int enable) +int socfpga_bridges_reset(int enable) { /* For SoCFPGA-VT, this is NOP. */ + return 0; } #else
@@ -90,9 +84,9 @@ void socfpga_bridges_reset(int enable) #define L3REGS_REMAP_HPS2FPGA_MASK 0x08 #define L3REGS_REMAP_OCRAM_MASK 0x01
-void socfpga_bridges_reset(int enable) +int socfpga_bridges_reset(int enable) { - const uint32_t l3mask = L3REGS_REMAP_LWHPS2FPGA_MASK | + const u32 l3mask = L3REGS_REMAP_LWHPS2FPGA_MASK | L3REGS_REMAP_HPS2FPGA_MASK | L3REGS_REMAP_OCRAM_MASK;
@@ -107,7 +101,7 @@ void socfpga_bridges_reset(int enable) if (!fpgamgr_test_fpga_ready()) { /* FPGA not ready, do nothing. */ printf("%s: FPGA not ready, aborting.\n", __func__); - return; + return -EINVAL; }
/* brdmodrst */ @@ -116,5 +110,6 @@ void socfpga_bridges_reset(int enable) /* Remap the bridges into memory map */ writel(l3mask, SOCFPGA_L3REGS_ADDRESS); } + return 0; } #endif
[snip]
You're changing the return type, to me, that's a functional change.
[snip]
- Write the reset manager register to cause reset
What's the reason for the above change?
[snip]
return;
return -EINVAL; } /* brdmodrst */
How are you intending to use these return values?
Dinh
[snip]
Will update the commit message.
[snip]
Requested by Marek to remove extra parenthesis.
[snip]
return;
Will display error when error and hang().
Regards Ley Foon
Restructure system manager in the preparation to support A10. No functional change.
Change uint32_t to u32.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 5 +- .../arm/mach-socfpga/include/mach/system_manager.h | 128 ++------------------- .../{system_manager.h => system_manager_gen5.h} | 39 +------ .../{system_manager.c => system_manager_gen5.c} | 6 +- 4 files changed, 22 insertions(+), 156 deletions(-) copy arch/arm/mach-socfpga/include/mach/{system_manager.h => system_manager_gen5.h} (73%) rename arch/arm/mach-socfpga/{system_manager.c => system_manager_gen5.c} (94%)
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 97819ac..4980e51 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -7,14 +7,15 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += misc.o timer.o reset_manager.o system_manager.o clock_manager.o \ +obj-y += misc.o timer.o reset_manager.o clock_manager.o \ fpga_manager.o board.o
# QTS-generated config file wrappers obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o \ - clock_manager_gen5.o reset_manager_gen5.o + clock_manager_gen5.o reset_manager_gen5.o \ + system_manager_gen5.o obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ wrap_sdram_config.o CFLAGS_wrap_iocsr_config.o += -I$(srctree)/board/$(BOARDDIR) diff --git a/arch/arm/mach-socfpga/include/mach/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager.h index c45edea..30f0bbe 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager.h @@ -1,120 +1,11 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef _SYSTEM_MANAGER_H_ -#define _SYSTEM_MANAGER_H_ - -#ifndef __ASSEMBLY__ - -void sysmgr_pinmux_init(void); -void sysmgr_config_warmrstcfgio(int enable); - -void sysmgr_get_pinmux_table(const u8 **table, unsigned int *table_len); -#endif - -struct socfpga_system_manager { - /* System Manager Module */ - u32 siliconid1; /* 0x00 */ - u32 siliconid2; - u32 _pad_0x8_0xf[2]; - u32 wddbg; /* 0x10 */ - u32 bootinfo; - u32 hpsinfo; - u32 parityinj; - /* FPGA Interface Group */ - u32 fpgaintfgrp_gbl; /* 0x20 */ - u32 fpgaintfgrp_indiv; - u32 fpgaintfgrp_module; - u32 _pad_0x2c_0x2f; - /* Scan Manager Group */ - u32 scanmgrgrp_ctrl; /* 0x30 */ - u32 _pad_0x34_0x3f[3]; - /* Freeze Control Group */ - u32 frzctrl_vioctrl; /* 0x40 */ - u32 _pad_0x44_0x4f[3]; - u32 frzctrl_hioctrl; /* 0x50 */ - u32 frzctrl_src; - u32 frzctrl_hwctrl; - u32 _pad_0x5c_0x5f; - /* EMAC Group */ - u32 emacgrp_ctrl; /* 0x60 */ - u32 emacgrp_l3master; - u32 _pad_0x68_0x6f[2]; - /* DMA Controller Group */ - u32 dmagrp_ctrl; /* 0x70 */ - u32 dmagrp_persecurity; - u32 _pad_0x78_0x7f[2]; - /* Preloader (initial software) Group */ - u32 iswgrp_handoff[8]; /* 0x80 */ - u32 _pad_0xa0_0xbf[8]; /* 0xa0 */ - /* Boot ROM Code Register Group */ - u32 romcodegrp_ctrl; /* 0xc0 */ - u32 romcodegrp_cpu1startaddr; - u32 romcodegrp_initswstate; - u32 romcodegrp_initswlastld; - u32 romcodegrp_bootromswstate; /* 0xd0 */ - u32 __pad_0xd4_0xdf[3]; - /* Warm Boot from On-Chip RAM Group */ - u32 romcodegrp_warmramgrp_enable; /* 0xe0 */ - u32 romcodegrp_warmramgrp_datastart; - u32 romcodegrp_warmramgrp_length; - u32 romcodegrp_warmramgrp_execution; - u32 romcodegrp_warmramgrp_crc; /* 0xf0 */ - u32 __pad_0xf4_0xff[3]; - /* Boot ROM Hardware Register Group */ - u32 romhwgrp_ctrl; /* 0x100 */ - u32 _pad_0x104_0x107; - /* SDMMC Controller Group */ - u32 sdmmcgrp_ctrl; - u32 sdmmcgrp_l3master; - /* NAND Flash Controller Register Group */ - u32 nandgrp_bootstrap; /* 0x110 */ - u32 nandgrp_l3master; - /* USB Controller Group */ - u32 usbgrp_l3master; - u32 _pad_0x11c_0x13f[9]; - /* ECC Management Register Group */ - u32 eccgrp_l2; /* 0x140 */ - u32 eccgrp_ocram; - u32 eccgrp_usb0; - u32 eccgrp_usb1; - u32 eccgrp_emac0; /* 0x150 */ - u32 eccgrp_emac1; - u32 eccgrp_dma; - u32 eccgrp_can0; - u32 eccgrp_can1; /* 0x160 */ - u32 eccgrp_nand; - u32 eccgrp_qspi; - u32 eccgrp_sdmmc; - u32 _pad_0x170_0x3ff[164]; - /* Pin Mux Control Group */ - u32 emacio[20]; /* 0x400 */ - u32 flashio[12]; /* 0x450 */ - u32 generalio[28]; /* 0x480 */ - u32 _pad_0x4f0_0x4ff[4]; - u32 mixed1io[22]; /* 0x500 */ - u32 mixed2io[8]; /* 0x558 */ - u32 gplinmux[23]; /* 0x578 */ - u32 gplmux[71]; /* 0x5d4 */ - u32 nandusefpga; /* 0x6f0 */ - u32 _pad_0x6f4; - u32 rgmii1usefpga; /* 0x6f8 */ - u32 _pad_0x6fc_0x700[2]; - u32 i2c0usefpga; /* 0x704 */ - u32 sdmmcusefpga; /* 0x708 */ - u32 _pad_0x70c_0x710[2]; - u32 rgmii0usefpga; /* 0x714 */ - u32 _pad_0x718_0x720[3]; - u32 i2c3usefpga; /* 0x724 */ - u32 i2c2usefpga; /* 0x728 */ - u32 i2c1usefpga; /* 0x72c */ - u32 spim1usefpga; /* 0x730 */ - u32 _pad_0x734; - u32 spim0usefpga; /* 0x738 */ -}; +#ifndef _SYSTEM_MANAGER_H_ +#define _SYSTEM_MANAGER_H_
#define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGPINMUX (1 << 0) #define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO (1 << 1) @@ -129,12 +20,6 @@ struct socfpga_system_manager { #define SYSMGR_FPGAINTF_NAND (1 << 4) #define SYSMGR_FPGAINTF_SDMMC (1 << 5)
-#if defined(CONFIG_TARGET_SOCFPGA_GEN5) -#define SYSMGR_SDMMC_SMPLSEL_SHIFT 3 -#else -#define SYSMGR_SDMMC_SMPLSEL_SHIFT 4 -#endif - #define SYSMGR_SDMMC_DRVSEL_SHIFT 0
/* EMAC Group Bit definitions */ @@ -146,4 +31,11 @@ struct socfpga_system_manager { #define SYSMGR_EMACGRP_CTRL_PHYSEL1_LSB 2 #define SYSMGR_EMACGRP_CTRL_PHYSEL_MASK 0x3
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#include <asm/arch/system_manager_gen5.h> +#endif + +#define SYSMGR_GET_BOOTINFO_BSEL(bsel) \ + (((bsel) >> SYSMGR_BOOTINFO_BSEL_SHIFT) & 7) + #endif /* _SYSTEM_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager_gen5.h similarity index 73% copy from arch/arm/mach-socfpga/include/mach/system_manager.h copy to arch/arm/mach-socfpga/include/mach/system_manager_gen5.h index c45edea..285c1a2 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager_gen5.h @@ -1,11 +1,11 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef _SYSTEM_MANAGER_H_ -#define _SYSTEM_MANAGER_H_ +#ifndef _SYSTEM_MANAGER_GEN5_H_ +#define _SYSTEM_MANAGER_GEN5_H_
@@ -13,7 +13,6 @@ void sysmgr_pinmux_init(void); void sysmgr_config_warmrstcfgio(int enable);
struct socfpga_system_manager { /* System Manager Module */ @@ -115,35 +114,9 @@ struct socfpga_system_manager { u32 _pad_0x734; u32 spim0usefpga; /* 0x738 */ }; - -#define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGPINMUX (1 << 0) -#define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO (1 << 1) -#define SYSMGR_ECC_OCRAM_EN (1 << 0) -#define SYSMGR_ECC_OCRAM_SERR (1 << 3) -#define SYSMGR_ECC_OCRAM_DERR (1 << 4) -#define SYSMGR_FPGAINTF_USEFPGA 0x1 -#define SYSMGR_FPGAINTF_SPIM0 (1 << 0) -#define SYSMGR_FPGAINTF_SPIM1 (1 << 1) -#define SYSMGR_FPGAINTF_EMAC0 (1 << 2) -#define SYSMGR_FPGAINTF_EMAC1 (1 << 3) -#define SYSMGR_FPGAINTF_NAND (1 << 4) -#define SYSMGR_FPGAINTF_SDMMC (1 << 5) - -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) -#define SYSMGR_SDMMC_SMPLSEL_SHIFT 3 -#else -#define SYSMGR_SDMMC_SMPLSEL_SHIFT 4 #endif
-#define SYSMGR_SDMMC_DRVSEL_SHIFT 0 - -/* EMAC Group Bit definitions */ -#define SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_GMII_MII 0x0 -#define SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RGMII 0x1 -#define SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RMII 0x2 - -#define SYSMGR_EMACGRP_CTRL_PHYSEL0_LSB 0 -#define SYSMGR_EMACGRP_CTRL_PHYSEL1_LSB 2 -#define SYSMGR_EMACGRP_CTRL_PHYSEL_MASK 0x3 +#define SYSMGR_SDMMC_SMPLSEL_SHIFT 3 +#define SYSMGR_BOOTINFO_BSEL_SHIFT 0
-#endif /* _SYSTEM_MANAGER_H_ */ +#endif /* _SYSTEM_MANAGER_GEN5_H_ */ diff --git a/arch/arm/mach-socfpga/system_manager.c b/arch/arm/mach-socfpga/system_manager_gen5.c similarity index 94% rename from arch/arm/mach-socfpga/system_manager.c rename to arch/arm/mach-socfpga/system_manager_gen5.c index 75a65f3..3588a57 100644 --- a/arch/arm/mach-socfpga/system_manager.c +++ b/arch/arm/mach-socfpga/system_manager_gen5.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -21,7 +21,7 @@ static struct socfpga_system_manager *sysmgr_regs = */ static void populate_sysmgr_fpgaintf_module(void) { - uint32_t handoff_val = 0; + u32 handoff_val = 0;
/* ISWGRP_HANDOFF_FPGAINTF */ writel(0, &sysmgr_regs->iswgrp_handoff[2]); @@ -56,7 +56,7 @@ static void populate_sysmgr_fpgaintf_module(void) */ void sysmgr_pinmux_init(void) { - uint32_t regs = (uint32_t)&sysmgr_regs->emacio[0]; + u32 regs = (u32)&sysmgr_regs->emacio[0]; const u8 *sys_mgr_init_table; unsigned int len; int i;
Restructure misc driver in the preparation to support A10. Move the Gen5 specific code to gen5 file. No functional change.
Change all uint32_t_to u32.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 2 +- arch/arm/mach-socfpga/include/mach/misc.h | 25 ++ arch/arm/mach-socfpga/misc.c | 361 ++------------------------ arch/arm/mach-socfpga/{misc.c => misc_gen5.c} | 149 ++--------- 4 files changed, 60 insertions(+), 477 deletions(-) create mode 100644 arch/arm/mach-socfpga/include/mach/misc.h copy arch/arm/mach-socfpga/{misc.c => misc_gen5.c} (73%)
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 4980e51..e83da2e 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -15,7 +15,7 @@ obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o # QTS-generated config file wrappers obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o \ clock_manager_gen5.o reset_manager_gen5.o \ - system_manager_gen5.o + misc_gen5.o system_manager_gen5.o obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ wrap_sdram_config.o CFLAGS_wrap_iocsr_config.o += -I$(srctree)/board/$(BOARDDIR) diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h new file mode 100644 index 0000000..f344749 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -0,0 +1,25 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _MISC_H_ +#define _MISC_H_ + +void dwmac_deassert_reset(const unsigned int of_reset_id, const u32 phymode); + +struct bsel { + const char *mode; + const char *name; +}; + +extern struct bsel bsel_str[]; + +#ifdef CONFIG_FPGA +void socfpga_fpga_add(void); +#else +static inline void socfpga_fpga_add(void) {} +#endif + +#endif /* _MISC_H_ */ diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index dd6b53b..cd250af 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -13,6 +13,7 @@ #include <miiphy.h> #include <netdev.h> #include <watchdog.h> +#include <asm/arch/misc.h> #include <asm/arch/reset_manager.h> #include <asm/arch/scan_manager.h> #include <asm/arch/system_manager.h> @@ -24,16 +25,19 @@
-static struct pl310_regs *const pl310 = +static const struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE; -static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; -static struct socfpga_reset_manager *reset_manager_base = - (struct socfpga_reset_manager *)SOCFPGA_RSTMGR_ADDRESS; -static struct nic301_registers *nic301_regs = - (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; -static struct scu_registers *scu_regs = - (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS; + +struct bsel bsel_str[] = { + { "rsvd", "Reserved", }, + { "fpga", "FPGA (HPS2FPGA Bridge)", }, + { "nand", "NAND Flash (1.8V)", }, + { "nand", "NAND Flash (3.0V)", }, + { "sd", "SD/MMC External Transceiver (1.8V)", }, + { "sd", "SD/MMC Internal Transceiver (3.0V)", }, + { "qspi", "QSPI Flash (1.8V)", }, + { "qspi", "QSPI Flash (3.0V)", }, +};
int dram_init(void) { @@ -72,207 +76,6 @@ void v7_outer_cache_disable(void) clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); }
-/* - * DesignWare Ethernet initialization - */ -#ifdef CONFIG_ETH_DESIGNWARE -static void dwmac_deassert_reset(const unsigned int of_reset_id, - const u32 phymode) -{ - u32 physhift, reset; - - if (of_reset_id == EMAC0_RESET) { - physhift = SYSMGR_EMACGRP_CTRL_PHYSEL0_LSB; - reset = SOCFPGA_RESET(EMAC0); - } else if (of_reset_id == EMAC1_RESET) { - physhift = SYSMGR_EMACGRP_CTRL_PHYSEL1_LSB; - reset = SOCFPGA_RESET(EMAC1); - } else { - printf("GMAC: Invalid reset ID (%i)!\n", of_reset_id); - return; - } - - /* Clearing emac0 PHY interface select to 0 */ - clrbits_le32(&sysmgr_regs->emacgrp_ctrl, - SYSMGR_EMACGRP_CTRL_PHYSEL_MASK << physhift); - - /* configure to PHY interface select choosed */ - setbits_le32(&sysmgr_regs->emacgrp_ctrl, - phymode << physhift); - - /* Release the EMAC controller from reset */ - socfpga_per_reset(reset, 0); -} - -static u32 dwmac_phymode_to_modereg(const char *phymode, u32 *modereg) -{ - if (!phymode) - return -EINVAL; - - if (!strcmp(phymode, "mii") || !strcmp(phymode, "gmii")) { - *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_GMII_MII; - return 0; - } - - if (!strcmp(phymode, "rgmii")) { - *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RGMII; - return 0; - } - - if (!strcmp(phymode, "rmii")) { - *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RMII; - return 0; - } - - return -EINVAL; -} - -static int socfpga_eth_reset(void) -{ - const void *fdt = gd->fdt_blob; - struct fdtdec_phandle_args args; - const char *phy_mode; - u32 phy_modereg; - int nodes[2]; /* Max. two GMACs */ - int ret, count; - int i, node; - - /* Put both GMACs into RESET state. */ - socfpga_per_reset(SOCFPGA_RESET(EMAC0), 1); - socfpga_per_reset(SOCFPGA_RESET(EMAC1), 1); - - count = fdtdec_find_aliases_for_id(fdt, "ethernet", - COMPAT_ALTERA_SOCFPGA_DWMAC, - nodes, ARRAY_SIZE(nodes)); - for (i = 0; i < count; i++) { - node = nodes[i]; - if (node <= 0) - continue; - - ret = fdtdec_parse_phandle_with_args(fdt, node, "resets", - "#reset-cells", 1, 0, - &args); - if (ret || (args.args_count != 1)) { - debug("GMAC%i: Failed to parse DT 'resets'!\n", i); - continue; - } - - phy_mode = fdt_getprop(fdt, node, "phy-mode", NULL); - ret = dwmac_phymode_to_modereg(phy_mode, &phy_modereg); - if (ret) { - debug("GMAC%i: Failed to parse DT 'phy-mode'!\n", i); - continue; - } - - dwmac_deassert_reset(args.args[0], phy_modereg); - } - - return 0; -} -#else -static int socfpga_eth_reset(void) -{ - return 0; -}; -#endif - -struct { - const char *mode; - const char *name; -} bsel_str[] = { - { "rsvd", "Reserved", }, - { "fpga", "FPGA (HPS2FPGA Bridge)", }, - { "nand", "NAND Flash (1.8V)", }, - { "nand", "NAND Flash (3.0V)", }, - { "sd", "SD/MMC External Transceiver (1.8V)", }, - { "sd", "SD/MMC Internal Transceiver (3.0V)", }, - { "qspi", "QSPI Flash (1.8V)", }, - { "qspi", "QSPI Flash (3.0V)", }, -}; - -static const struct { - const u16 pn; - const char *name; - const char *var; -} const socfpga_fpga_model[] = { - /* Cyclone V E */ - { 0x2b15, "Cyclone V, E/A2", "cv_e_a2" }, - { 0x2b05, "Cyclone V, E/A4", "cv_e_a4" }, - { 0x2b22, "Cyclone V, E/A5", "cv_e_a5" }, - { 0x2b13, "Cyclone V, E/A7", "cv_e_a7" }, - { 0x2b14, "Cyclone V, E/A9", "cv_e_a9" }, - /* Cyclone V GX/GT */ - { 0x2b01, "Cyclone V, GX/C3", "cv_gx_c3" }, - { 0x2b12, "Cyclone V, GX/C4", "cv_gx_c4" }, - { 0x2b02, "Cyclone V, GX/C5 or GT/D5", "cv_gx_c5" }, - { 0x2b03, "Cyclone V, GX/C7 or GT/D7", "cv_gx_c7" }, - { 0x2b04, "Cyclone V, GX/C9 or GT/D9", "cv_gx_c9" }, - /* Cyclone V SE/SX/ST */ - { 0x2d11, "Cyclone V, SE/A2 or SX/C2", "cv_se_a2" }, - { 0x2d01, "Cyclone V, SE/A4 or SX/C4", "cv_se_a4" }, - { 0x2d12, "Cyclone V, SE/A5 or SX/C5 or ST/D5", "cv_se_a5" }, - { 0x2d02, "Cyclone V, SE/A6 or SX/C6 or ST/D6", "cv_se_a6" }, - /* Arria V */ - { 0x2d03, "Arria V, D5", "av_d5" }, -}; - -static int socfpga_fpga_id(const bool print_id) -{ - const u32 altera_mi = 0x6e; - const u32 id = scan_mgr_get_fpga_id(); - - const u32 lsb = id & 0x00000001; - const u32 mi = (id >> 1) & 0x000007ff; - const u32 pn = (id >> 12) & 0x0000ffff; - const u32 version = (id >> 28) & 0x0000000f; - int i; - - if ((mi != altera_mi) || (lsb != 1)) { - printf("FPGA: Not Altera chip ID\n"); - return -EINVAL; - } - - for (i = 0; i < ARRAY_SIZE(socfpga_fpga_model); i++) - if (pn == socfpga_fpga_model[i].pn) - break; - - if (i == ARRAY_SIZE(socfpga_fpga_model)) { - printf("FPGA: Unknown Altera chip, ID 0x%08x\n", id); - return -EINVAL; - } - - if (print_id) - printf("FPGA: Altera %s, version 0x%01x\n", - socfpga_fpga_model[i].name, version); - return i; -} - -/* - * Print CPU information - */ -#if defined(CONFIG_DISPLAY_CPUINFO) -int print_cpuinfo(void) -{ - const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; - puts("CPU: Altera SoCFPGA Platform\n"); - socfpga_fpga_id(1); - printf("BOOT: %s\n", bsel_str[bsel].name); - return 0; -} -#endif - -#ifdef CONFIG_ARCH_MISC_INIT -int arch_misc_init(void) -{ - const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; - const int fpga_id = socfpga_fpga_id(0); - setenv("bootmode", bsel_str[bsel].mode); - if (fpga_id >= 0) - setenv("fpgatype", socfpga_fpga_model[fpga_id].var); - return socfpga_eth_reset(); -} -#endif - #if defined(CONFIG_SYS_CONSOLE_IS_IN_ENV) && \ defined(CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE) int overwrite_console(void) @@ -303,15 +106,13 @@ static Altera_desc altera_fpga[] = { };
/* add device descriptor to FPGA device table */ -static void socfpga_fpga_add(void) +void socfpga_fpga_add(void) { int i; fpga_init(); for (i = 0; i < ARRAY_SIZE(altera_fpga); i++) fpga_add(fpga_altera, &altera_fpga[i]); } -#else -static inline void socfpga_fpga_add(void) {} #endif
int arch_cpu_init(void) @@ -337,135 +138,3 @@ int arch_cpu_init(void)
return 0; } - -/* - * Convert all NIC-301 AMBA slaves from secure to non-secure - */ -static void socfpga_nic301_slave_ns(void) -{ - writel(0x1, &nic301_regs->lwhps2fpgaregs); - writel(0x1, &nic301_regs->hps2fpgaregs); - writel(0x1, &nic301_regs->acp); - writel(0x1, &nic301_regs->rom); - writel(0x1, &nic301_regs->ocram); - writel(0x1, &nic301_regs->sdrdata); -} - -static uint32_t iswgrp_handoff[8]; - -int arch_early_init_r(void) -{ - int i; - - /* - * Write magic value into magic register to unlock support for - * issuing warm reset. The ancient kernel code expects this - * value to be written into the register by the bootloader, so - * to support that old code, we write it here instead of in the - * reset_cpu() function just before resetting the CPU. - */ - writel(0xae9efebc, &sysmgr_regs->romcodegrp_warmramgrp_enable); - - for (i = 0; i < 8; i++) /* Cache initial SW setting regs */ - iswgrp_handoff[i] = readl(&sysmgr_regs->iswgrp_handoff[i]); - - socfpga_bridges_reset(1); - socfpga_nic301_slave_ns(); - - /* - * Private components security: - * U-Boot : configure private timer, global timer and cpu component - * access as non secure for kernel stage (as required by Linux) - */ - setbits_le32(&scu_regs->sacr, 0xfff); - - /* Configure the L2 controller to make SDRAM start at 0 */ -#ifdef CONFIG_SOCFPGA_VIRTUAL_TARGET - writel(0x2, &nic301_regs->remap); -#else - writel(0x1, &nic301_regs->remap); /* remap.mpuzero */ - writel(0x1, &pl310->pl310_addr_filter_start); -#endif - - /* Add device descriptor to FPGA device table */ - socfpga_fpga_add(); - -#ifdef CONFIG_DESIGNWARE_SPI - /* Get Designware SPI controller out of reset */ - socfpga_per_reset(SOCFPGA_RESET(SPIM0), 0); - socfpga_per_reset(SOCFPGA_RESET(SPIM1), 0); -#endif - -#ifdef CONFIG_NAND_DENALI - socfpga_per_reset(SOCFPGA_RESET(NAND), 0); -#endif - - return 0; -} - -static void socfpga_sdram_apply_static_cfg(void) -{ - const uint32_t staticcfg = SOCFPGA_SDR_ADDRESS + 0x505c; - const uint32_t applymask = 0x8; - uint32_t val = readl(staticcfg) | applymask; - - /* - * SDRAM staticcfg register specific: - * When applying the register setting, the CPU must not access - * SDRAM. Luckily for us, we can abuse i-cache here to help us - * circumvent the SDRAM access issue. The idea is to make sure - * that the code is in one full i-cache line by branching past - * it and back. Once it is in the i-cache, we execute the core - * of the code and apply the register settings. - * - * The code below uses 7 instructions, while the Cortex-A9 has - * 32-byte cachelines, thus the limit is 8 instructions total. - */ - asm volatile( - ".align 5 \n" - " b 2f \n" - "1: str %0, [%1] \n" - " dsb \n" - " isb \n" - " b 3f \n" - "2: b 1b \n" - "3: nop \n" - : : "r"(val), "r"(staticcfg) : "memory", "cc"); -} - -int do_bridge(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - if (argc != 2) - return CMD_RET_USAGE; - - argv++; - - switch (*argv[0]) { - case 'e': /* Enable */ - writel(iswgrp_handoff[2], &sysmgr_regs->fpgaintfgrp_module); - socfpga_sdram_apply_static_cfg(); - writel(iswgrp_handoff[3], SOCFPGA_SDR_ADDRESS + 0x5080); - writel(iswgrp_handoff[0], &reset_manager_base->brg_mod_reset); - writel(iswgrp_handoff[1], &nic301_regs->remap); - break; - case 'd': /* Disable */ - writel(0, &sysmgr_regs->fpgaintfgrp_module); - writel(0, SOCFPGA_SDR_ADDRESS + 0x5080); - socfpga_sdram_apply_static_cfg(); - writel(0, &reset_manager_base->brg_mod_reset); - writel(1, &nic301_regs->remap); - break; - default: - return CMD_RET_USAGE; - } - - return 0; -} - -U_BOOT_CMD( - bridge, 2, 1, do_bridge, - "SoCFPGA HPS FPGA bridge control", - "enable - Enable HPS-to-FPGA, FPGA-to-HPS, LWHPS-to-FPGA bridges\n" - "bridge disable - Enable HPS-to-FPGA, FPGA-to-HPS, LWHPS-to-FPGA bridges\n" - "" -); diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc_gen5.c similarity index 73% copy from arch/arm/mach-socfpga/misc.c copy to arch/arm/mach-socfpga/misc_gen5.c index dd6b53b..420b1fd 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -13,6 +13,7 @@ #include <miiphy.h> #include <netdev.h> #include <watchdog.h> +#include <asm/arch/misc.h> #include <asm/arch/reset_manager.h> #include <asm/arch/scan_manager.h> #include <asm/arch/system_manager.h> @@ -35,48 +36,11 @@ static struct nic301_registers *nic301_regs = static struct scu_registers *scu_regs = (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS;
-int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); - return 0; -} - -void enable_caches(void) -{ -#ifndef CONFIG_SYS_ICACHE_OFF - icache_enable(); -#endif -#ifndef CONFIG_SYS_DCACHE_OFF - dcache_enable(); -#endif -} - -void v7_outer_cache_enable(void) -{ - /* Disable the L2 cache */ - clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); - - /* enable BRESP, instruction and data prefetch, full line of zeroes */ - setbits_le32(&pl310->pl310_aux_ctrl, - L310_AUX_CTRL_DATA_PREFETCH_MASK | - L310_AUX_CTRL_INST_PREFETCH_MASK | - L310_SHARED_ATT_OVERRIDE_ENABLE); - - /* Enable the L2 cache */ - setbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); -} - -void v7_outer_cache_disable(void) -{ - /* Disable the L2 cache */ - clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); -} - /* * DesignWare Ethernet initialization */ #ifdef CONFIG_ETH_DESIGNWARE -static void dwmac_deassert_reset(const unsigned int of_reset_id, +void dwmac_deassert_reset(const unsigned int of_reset_id, const u32 phymode) { u32 physhift, reset; @@ -92,13 +56,10 @@ static void dwmac_deassert_reset(const unsigned int of_reset_id, return; }
- /* Clearing emac0 PHY interface select to 0 */ - clrbits_le32(&sysmgr_regs->emacgrp_ctrl, - SYSMGR_EMACGRP_CTRL_PHYSEL_MASK << physhift); - /* configure to PHY interface select choosed */ - setbits_le32(&sysmgr_regs->emacgrp_ctrl, - phymode << physhift); + clrsetbits_le32(&sysmgr_regs->emacgrp_ctrl, + SYSMGR_EMACGRP_CTRL_PHYSEL_MASK << physhift, + phymode << physhift);
/* Release the EMAC controller from reset */ socfpga_per_reset(reset, 0); @@ -176,20 +137,6 @@ static int socfpga_eth_reset(void) }; #endif
-struct { - const char *mode; - const char *name; -} bsel_str[] = { - { "rsvd", "Reserved", }, - { "fpga", "FPGA (HPS2FPGA Bridge)", }, - { "nand", "NAND Flash (1.8V)", }, - { "nand", "NAND Flash (3.0V)", }, - { "sd", "SD/MMC External Transceiver (1.8V)", }, - { "sd", "SD/MMC Internal Transceiver (3.0V)", }, - { "qspi", "QSPI Flash (1.8V)", }, - { "qspi", "QSPI Flash (3.0V)", }, -}; - static const struct { const u16 pn; const char *name; @@ -253,9 +200,12 @@ static int socfpga_fpga_id(const bool print_id) #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo(void) { - const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; + const u32 bsel = + SYSMGR_GET_BOOTINFO_BSEL(readl(&sysmgr_regs->bootinfo)); + puts("CPU: Altera SoCFPGA Platform\n"); socfpga_fpga_id(1); + printf("BOOT: %s\n", bsel_str[bsel].name); return 0; } @@ -273,71 +223,6 @@ int arch_misc_init(void) } #endif
-#if defined(CONFIG_SYS_CONSOLE_IS_IN_ENV) && \ -defined(CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE) -int overwrite_console(void) -{ - return 0; -} -#endif - -#ifdef CONFIG_FPGA -/* - * FPGA programming support for SoC FPGA Cyclone V - */ -static Altera_desc altera_fpga[] = { - { - /* Family */ - Altera_SoCFPGA, - /* Interface type */ - fast_passive_parallel, - /* No limitation as additional data will be ignored */ - -1, - /* No device function table */ - NULL, - /* Base interface address specified in driver */ - NULL, - /* No cookie implementation */ - 0 - }, -}; - -/* add device descriptor to FPGA device table */ -static void socfpga_fpga_add(void) -{ - int i; - fpga_init(); - for (i = 0; i < ARRAY_SIZE(altera_fpga); i++) - fpga_add(fpga_altera, &altera_fpga[i]); -} -#else -static inline void socfpga_fpga_add(void) {} -#endif - -int arch_cpu_init(void) -{ -#ifdef CONFIG_HW_WATCHDOG - /* - * In case the watchdog is enabled, make sure to (re-)configure it - * so that the defined timeout is valid. Otherwise the SPL (Perloader) - * timeout value is still active which might too short for Linux - * booting. - */ - hw_watchdog_init(); -#else - /* - * If the HW watchdog is NOT enabled, make sure it is not running, - * for example because it was enabled in the preloader. This might - * trigger a watchdog-triggered reboot of Linux kernel later. - * Toggle watchdog reset, so watchdog in not running state. - */ - socfpga_per_reset(SOCFPGA_RESET(L4WD0), 1); - socfpga_per_reset(SOCFPGA_RESET(L4WD0), 0); -#endif - - return 0; -} - /* * Convert all NIC-301 AMBA slaves from secure to non-secure */ @@ -351,11 +236,12 @@ static void socfpga_nic301_slave_ns(void) writel(0x1, &nic301_regs->sdrdata); }
-static uint32_t iswgrp_handoff[8]; +static u32 iswgrp_handoff[8];
int arch_early_init_r(void) { int i; + int ret;
/* * Write magic value into magic register to unlock support for @@ -369,7 +255,10 @@ int arch_early_init_r(void) for (i = 0; i < 8; i++) /* Cache initial SW setting regs */ iswgrp_handoff[i] = readl(&sysmgr_regs->iswgrp_handoff[i]);
- socfpga_bridges_reset(1); + ret = socfpga_bridges_reset(1); + if (ret) + return ret; + socfpga_nic301_slave_ns();
/* @@ -405,9 +294,9 @@ int arch_early_init_r(void)
static void socfpga_sdram_apply_static_cfg(void) { - const uint32_t staticcfg = SOCFPGA_SDR_ADDRESS + 0x505c; - const uint32_t applymask = 0x8; - uint32_t val = readl(staticcfg) | applymask; + const u32 staticcfg = SOCFPGA_SDR_ADDRESS + 0x505c; + const u32 applymask = 0x8; + u32 val = readl(staticcfg) | applymask;
/* * SDRAM staticcfg register specific:
- Copyright (C) 2016-2017 Intel Corporation
- SPDX-License-Identifier: GPL-2.0
In the reset_manager_gen5.h file, patch #02, you are still using Altera in the header and it was GPL-2.0+ license. Now you're using Intel and GPL-2.0, I'm not sure which is right, but I think it should be Intel for all new files? Let's be consistent?
Dinh
reset_manager_gen5.h is moved from reset_manager.h. So, I keep its original license header for it. But, arch/arm/mach-socfpga/include/mach/misc.h is a new file. So, we use Intel license header for all new files.
Regards Ley Foon
Add i2c, timer and other A10 macros.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/include/mach/base_addr_a10.h | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_a10.h b/arch/arm/mach-socfpga/include/mach/base_addr_a10.h index a7056d4..448fbdc 100644 --- a/arch/arm/mach-socfpga/include/mach/base_addr_a10.h +++ b/arch/arm/mach-socfpga/include/mach/base_addr_a10.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2014 Altera Corporation <www.altera.com> + * Copyright (C) 2014-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -29,14 +29,20 @@ #define SOCFPGA_MPUL2_ADDRESS 0xfffff000 #define SOCFPGA_I2C0_ADDRESS 0xffc02200 #define SOCFPGA_I2C1_ADDRESS 0xffc02300 +#define SOCFPGA_I2C2_ADDRESS 0xffc02400 +#define SOCFPGA_I2C3_ADDRESS 0xffc02500 +#define SOCFPGA_I2C4_ADDRESS 0xffc02600
#define SOCFPGA_ECC_OCRAM_ADDRESS 0xff8c3000 #define SOCFPGA_UART0_ADDRESS 0xffc02000 #define SOCFPGA_OSC1TIMER0_ADDRESS 0xffd00000 +#define SOCFPGA_OSC1TIMER1_ADDRESS 0xffd00100 #define SOCFPGA_CLKMGR_ADDRESS 0xffd04000 #define SOCFPGA_RSTMGR_ADDRESS 0xffd05000
#define SOCFPGA_SDR_ADDRESS 0xffcfb000 +#define SOCFPGA_NOC_L4_PRIV_FLT_OFST 0xffd11000 +#define SOCFPGA_NOC_FW_H2F_SCR_OFST 0xffd13500 #define SOCFPGA_SDR_SCHEDULER_ADDRESS 0xffd12400 #define SOCFPGA_SDR_FIREWALL_OCRAM_ADDRESS 0xffd13200 #define SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS 0xffd13300
- Copyright (C) 2014 Altera Corporation <www.altera.com>
- Copyright (C) 2014-2017 Altera Corporation <www.altera.com>
Do we need to add these if we have DTS support?
Dinh
Add reset driver support for Arria 10.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 2 + arch/arm/mach-socfpga/include/mach/reset_manager.h | 2 + .../include/mach/reset_manager_arria10.h | 144 ++++++++ arch/arm/mach-socfpga/reset_manager_arria10.c | 389 +++++++++++++++++++++ include/dt-bindings/reset/altr,rst-mgr-a10.h | 103 ++++++ 5 files changed, 640 insertions(+) create mode 100644 arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h create mode 100644 arch/arm/mach-socfpga/reset_manager_arria10.c create mode 100644 include/dt-bindings/reset/altr,rst-mgr-a10.h
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index e83da2e..d81f003 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -10,6 +10,8 @@ obj-y += misc.o timer.o reset_manager.o clock_manager.o \ fpga_manager.o board.o
+obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += reset_manager_arria10.o + obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o
# QTS-generated config file wrappers diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h index c99efa7..a0d611b 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager.h @@ -45,6 +45,8 @@ void socfpga_per_reset_all(void);
#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #include <asm/arch/reset_manager_gen5.h> +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#include <asm/arch/reset_manager_arria10.h> #endif
#endif /* _RESET_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h new file mode 100644 index 0000000..878c1b6 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h @@ -0,0 +1,144 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _RESET_MANAGER_ARRIA10_H_ +#define _RESET_MANAGER_ARRIA10_H_ + +void socfpga_watchdog_disable(void); +void socfpga_reset_deassert_noc_ddr_scheduler(void); +int socfpga_is_wdt_in_reset(void); +void socfpga_emac_manage_reset(ulong emacbase, u32 state); +int socfpga_reset_deassert_bridges_handoff(void); +void socfpga_reset_assert_fpga_connected_peripherals(void); +void socfpga_reset_deassert_osc1wd0(void); +void socfpga_reset_uart(int assert); + +struct socfpga_reset_manager { + u32 stat; + u32 ramstat; + u32 miscstat; + u32 ctrl; + u32 hdsken; + u32 hdskreq; + u32 hdskack; + u32 counts; + u32 mpumodrst; + u32 per0modrst; + u32 per1modrst; + u32 brgmodrst; + u32 sysmodrst; + u32 coldmodrst; + u32 nrstmodrst; + u32 dbgmodrst; + u32 mpuwarmmask; + u32 per0warmmask; + u32 per1warmmask; + u32 brgwarmmask; + u32 syswarmmask; + u32 nrstwarmmask; + u32 l3warmmask; + u32 tststa; + u32 tstscratch; + u32 hdsktimeout; + u32 hmcintr; + u32 hmcintren; + u32 hmcintrens; + u32 hmcintrenr; + u32 hmcgpout; + u32 hmcgpin; +}; + +/* + * SocFPGA Arria10 reset IDs, bank mapping is as follows: + * 0 ... mpumodrst + * 1 ... per0modrst + * 2 ... per1modrst + * 3 ... brgmodrst + * 4 ... sysmodrst + */ +#define RSTMGR_EMAC0 RSTMGR_DEFINE(1, 0) +#define RSTMGR_EMAC1 RSTMGR_DEFINE(1, 1) +#define RSTMGR_EMAC2 RSTMGR_DEFINE(1, 2) +#define RSTMGR_NAND RSTMGR_DEFINE(1, 5) +#define RSTMGR_QSPI RSTMGR_DEFINE(1, 6) +#define RSTMGR_SDMMC RSTMGR_DEFINE(1, 7) +#define RSTMGR_DMA RSTMGR_DEFINE(1, 16) +#define RSTMGR_SPIM0 RSTMGR_DEFINE(1, 17) +#define RSTMGR_SPIM1 RSTMGR_DEFINE(1, 18) +#define RSTMGR_L4WD0 RSTMGR_DEFINE(2, 0) +#define RSTMGR_L4WD1 RSTMGR_DEFINE(2, 1) +#define RSTMGR_L4SYSTIMER0 RSTMGR_DEFINE(2, 2) +#define RSTMGR_L4SYSTIMER1 RSTMGR_DEFINE(2, 3) +#define RSTMGR_SPTIMER0 RSTMGR_DEFINE(2, 4) +#define RSTMGR_SPTIMER1 RSTMGR_DEFINE(2, 5) +#define RSTMGR_UART0 RSTMGR_DEFINE(2, 16) +#define RSTMGR_UART1 RSTMGR_DEFINE(2, 17) +#define RSTMGR_DDRSCH RSTMGR_DEFINE(3, 6) + +#define ALT_RSTMGR_CTL_SWWARMRSTREQ_SET_MSK BIT(1) +#define ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK BIT(0) +#define ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK BIT(1) +#define ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK BIT(2) +#define ALT_RSTMGR_PER0MODRST_USB0_SET_MSK BIT(3) +#define ALT_RSTMGR_PER0MODRST_USB1_SET_MSK BIT(4) +#define ALT_RSTMGR_PER0MODRST_NAND_SET_MSK BIT(5) +#define ALT_RSTMGR_PER0MODRST_QSPI_SET_MSK BIT(6) +#define ALT_RSTMGR_PER0MODRST_SDMMC_SET_MSK BIT(7) +#define ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK BIT(8) +#define ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK BIT(9) +#define ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK BIT(10) +#define ALT_RSTMGR_PER0MODRST_USBECC0_SET_MSK BIT(11) +#define ALT_RSTMGR_PER0MODRST_USBECC1_SET_MSK BIT(12) +#define ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK BIT(13) +#define ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK BIT(14) +#define ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK BIT(15) +#define ALT_RSTMGR_PER0MODRST_DMA_SET_MSK BIT(16) +#define ALT_RSTMGR_PER0MODRST_SPIM0_SET_MSK BIT(17) +#define ALT_RSTMGR_PER0MODRST_SPIM1_SET_MSK BIT(18) +#define ALT_RSTMGR_PER0MODRST_SPIS0_SET_MSK BIT(19) +#define ALT_RSTMGR_PER0MODRST_SPIS1_SET_MSK BIT(20) +#define ALT_RSTMGR_PER0MODRST_DMAECC_SET_MSK BIT(21) +#define ALT_RSTMGR_PER0MODRST_EMACPTP_SET_MSK BIT(22) +#define ALT_RSTMGR_PER0MODRST_DMAIF0_SET_MSK BIT(24) +#define ALT_RSTMGR_PER0MODRST_DMAIF1_SET_MSK BIT(25) +#define ALT_RSTMGR_PER0MODRST_DMAIF2_SET_MSK BIT(26) +#define ALT_RSTMGR_PER0MODRST_DMAIF3_SET_MSK BIT(27) +#define ALT_RSTMGR_PER0MODRST_DMAIF4_SET_MSK BIT(28) +#define ALT_RSTMGR_PER0MODRST_DMAIF5_SET_MSK BIT(29) +#define ALT_RSTMGR_PER0MODRST_DMAIF6_SET_MSK BIT(30) +#define ALT_RSTMGR_PER0MODRST_DMAIF7_SET_MSK BIT(31) + +#define ALT_RSTMGR_PER1MODRST_WD0_SET_MSK BIT(0) +#define ALT_RSTMGR_PER1MODRST_WD1_SET_MSK BIT(1) +#define ALT_RSTMGR_PER1MODRST_L4SYSTMR0_SET_MSK BIT(2) +#define ALT_RSTMGR_PER1MODRST_L4SYSTMR1_SET_MSK BIT(3) +#define ALT_RSTMGR_PER1MODRST_SPTMR0_SET_MSK BIT(4) +#define ALT_RSTMGR_PER1MODRST_SPTMR1_SET_MSK BIT(5) +#define ALT_RSTMGR_PER1MODRST_I2C0_SET_MSK BIT(8) +#define ALT_RSTMGR_PER1MODRST_I2C1_SET_MSK BIT(9) +#define ALT_RSTMGR_PER1MODRST_I2C2_SET_MSK BIT(10) +#define ALT_RSTMGR_PER1MODRST_I2C3_SET_MSK BIT(11) +#define ALT_RSTMGR_PER1MODRST_I2C4_SET_MSK BIT(12) +#define ALT_RSTMGR_PER1MODRST_UART0_SET_MSK BIT(16) +#define ALT_RSTMGR_PER1MODRST_UART1_SET_MSK BIT(17) +#define ALT_RSTMGR_PER1MODRST_GPIO0_SET_MSK BIT(24) +#define ALT_RSTMGR_PER1MODRST_GPIO1_SET_MSK BIT(25) +#define ALT_RSTMGR_PER1MODRST_GPIO2_SET_MSK BIT(26) + +#define ALT_RSTMGR_BRGMODRST_H2F_SET_MSK BIT(0) +#define ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK BIT(1) +#define ALT_RSTMGR_BRGMODRST_F2H_SET_MSK BIT(2) +#define ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK BIT(3) +#define ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK BIT(4) +#define ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK BIT(5) +#define ALT_RSTMGR_BRGMODRST_DDRSCH_SET_MSK BIT(6) + +#define ALT_RSTMGR_HDSKEN_SDRSELFREFEN_SET_MSK BIT(0) +#define ALT_RSTMGR_HDSKEN_FPGAMGRHSEN_SET_MSK BIT(1) +#define ALT_RSTMGR_HDSKEN_FPGAHSEN_SET_MSK BIT(2) +#define ALT_RSTMGR_HDSKEN_ETRSTALLEN_SET_MSK BIT(3) + +#endif /* _RESET_MANAGER_ARRIA10_H_ */ diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c new file mode 100644 index 0000000..e24f2f2 --- /dev/null +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -0,0 +1,389 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <asm/io.h> +#include <asm/arch/fpga_manager.h> +#include <asm/arch/misc.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> +#include <common.h> +#include <errno.h> +#include <fdtdec.h> +#include <wait_bit.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_reset_manager *reset_manager_base = + (void *)SOCFPGA_RSTMGR_ADDRESS; +static const struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; + +#define ECC_MASK (ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | \ + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK | \ + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK | \ + ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK | \ + ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK | \ + ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK) + +void socfpga_reset_uart(int assert) +{ + u32 mask = 0; + unsigned int com_port; + + com_port = uart_com_port(gd->fdt_blob); + + if (com_port == SOCFPGA_UART1_ADDRESS) + mask |= ALT_RSTMGR_PER1MODRST_UART1_SET_MSK; + else if (com_port == SOCFPGA_UART0_ADDRESS) + mask |= ALT_RSTMGR_PER1MODRST_UART0_SET_MSK; + + if (assert) + setbits_le32(&reset_manager_base->per1modrst, mask); + else + clrbits_le32(&reset_manager_base->per1modrst, mask); +} + +static const u32 per0fpgamasks[] = { + ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK, + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK, + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK, + 0, /* i2c0 per1mod */ + 0, /* i2c1 per1mod */ + 0, /* i2c0_emac */ + 0, /* i2c1_emac */ + 0, /* i2c2_emac */ + ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_NAND_SET_MSK, + ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_QSPI_SET_MSK, + ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_SDMMC_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIM0_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIM1_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIS0_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIS1_SET_MSK, + 0, /* uart0 per1mod */ + 0, /* uart1 per1mod */ +}; + +static const u32 per1fpgamasks[] = { + 0, /* emac0 per0mod */ + 0, /* emac1 per0mod */ + 0, /* emac2 per0mod */ + ALT_RSTMGR_PER1MODRST_I2C0_SET_MSK, + ALT_RSTMGR_PER1MODRST_I2C1_SET_MSK, + ALT_RSTMGR_PER1MODRST_I2C2_SET_MSK, /* i2c0_emac */ + ALT_RSTMGR_PER1MODRST_I2C3_SET_MSK, /* i2c1_emac */ + ALT_RSTMGR_PER1MODRST_I2C4_SET_MSK, /* i2c2_emac */ + 0, /* nand per0mod */ + 0, /* qspi per0mod */ + 0, /* sdmmc per0mod */ + 0, /* spim0 per0mod */ + 0, /* spim1 per0mod */ + 0, /* spis0 per0mod */ + 0, /* spis1 per0mod */ + ALT_RSTMGR_PER1MODRST_UART0_SET_MSK, + ALT_RSTMGR_PER1MODRST_UART1_SET_MSK, +}; + +struct bridge_cfg { + int compat_id; + u32 mask_noc; + u32 mask_rstmgr; +}; + +static const struct bridge_cfg bridge_cfg_tbl[] = { + { + COMPAT_ALTERA_SOCFPGA_H2F_BRG, + ALT_SYSMGR_NOC_H2F_SET_MSK, + ALT_RSTMGR_BRGMODRST_H2F_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_LWH2F_BRG, + ALT_SYSMGR_NOC_LWH2F_SET_MSK, + ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2H_BRG, + ALT_SYSMGR_NOC_F2H_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2H_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2SDR0, + ALT_SYSMGR_NOC_F2SDR0_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2SDR1, + ALT_SYSMGR_NOC_F2SDR1_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2SDR2, + ALT_SYSMGR_NOC_F2SDR2_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK, + }, +}; + +/* Disable the watchdog (toggle reset to watchdog) */ +void socfpga_watchdog_disable(void) +{ + /* assert reset for watchdog */ + setbits_le32(&reset_manager_base->per1modrst, + ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); +} + +/* Release NOC ddr scheduler from reset */ +void socfpga_reset_deassert_noc_ddr_scheduler(void) +{ + clrbits_le32(&reset_manager_base->brgmodrst, + ALT_RSTMGR_BRGMODRST_DDRSCH_SET_MSK); +} + +/* Check whether Watchdog in reset state? */ +int socfpga_is_wdt_in_reset(void) +{ + u32 val; + + val = readl(&reset_manager_base->per1modrst); + val &= ALT_RSTMGR_PER1MODRST_WD0_SET_MSK; + + /* return 0x1 if watchdog in reset */ + return val; +} + +/* emacbase: base address of emac to enable/disable reset + * state: 0 - disable reset, !0 - enable reset + */ +void socfpga_emac_manage_reset(ulong emacbase, u32 state) +{ + ulong eccmask; + ulong emacmask; + + switch (emacbase) { + case SOCFPGA_EMAC0_ADDRESS: + eccmask = ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK; + emacmask = ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK; + break; + case SOCFPGA_EMAC1_ADDRESS: + eccmask = ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK; + emacmask = ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK; + break; + case SOCFPGA_EMAC2_ADDRESS: + eccmask = ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK; + emacmask = ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK; + break; + default: + error("emac base address unexpected! %lx", emacbase); + hang(); + break; + } + + if (state) { + /* Enable ECC OCP first */ + setbits_le32(&reset_manager_base->per0modrst, eccmask); + setbits_le32(&reset_manager_base->per0modrst, emacmask); + } else { + /* Disable ECC OCP first */ + clrbits_le32(&reset_manager_base->per0modrst, emacmask); + clrbits_le32(&reset_manager_base->per0modrst, eccmask); + } +} + +static int get_bridge_init_val(const void *blob, int compat_id) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, compat_id); + if (node < 0) + return 0; + + return fdtdec_get_uint(blob, node, "init-val", 0); +} + +/* Enable bridges (hps2fpga, lwhps2fpga, fpga2hps, fpga2sdram) per handoff */ +int socfpga_reset_deassert_bridges_handoff(void) +{ + u32 mask_noc = 0, mask_rstmgr = 0; + int i; + + for (i = 0; i < ARRAY_SIZE(bridge_cfg_tbl); i++) { + if (get_bridge_init_val(gd->fdt_blob, + bridge_cfg_tbl[i].compat_id)) { + mask_noc |= bridge_cfg_tbl[i].mask_noc; + mask_rstmgr |= bridge_cfg_tbl[i].mask_rstmgr; + } + } + + /* clear idle request to all bridges */ + setbits_le32(&sysmgr_regs->noc_idlereq_clr, mask_noc); + + /* Release bridges from reset state per handoff value */ + clrbits_le32(&reset_manager_base->brgmodrst, mask_rstmgr); + + /* Poll until all idleack to 0, timeout at 1000ms */ + return wait_for_bit(__func__, &sysmgr_regs->noc_idleack, mask_noc, + false, 1000, false); +} + +void socfpga_reset_assert_fpga_connected_peripherals(void) +{ + u32 mask0 = 0; + u32 mask1 = 0; + u32 fpga_pinux_addr = SOCFPGA_PINMUX_FPGA_INTERFACE_ADDRESS; + int i; + + for (i = 0; i < ARRAY_SIZE(per1fpgamasks); i++) { + if (readl(fpga_pinux_addr)) { + mask0 |= per0fpgamasks[i]; + mask1 |= per1fpgamasks[i]; + } + fpga_pinux_addr += sizeof(u32); + } + + setbits_le32(&reset_manager_base->per0modrst, mask0 & ECC_MASK); + setbits_le32(&reset_manager_base->per1modrst, mask1); + setbits_le32(&reset_manager_base->per0modrst, mask0); +} + +/* Release L4 OSC1 Watchdog Timer 0 from reset through reset manager */ +void socfpga_reset_deassert_osc1wd0(void) +{ + clrbits_le32(&reset_manager_base->per1modrst, + ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); +} + +/* + * Assert or de-assert SoCFPGA reset manager reset. + */ +void socfpga_per_reset(u32 reset, int set) +{ + const u32 *reg; + u32 rstmgr_bank = RSTMGR_BANK(reset); + + switch (rstmgr_bank) { + case 0: + reg = &reset_manager_base->mpumodrst; + break; + case 1: + reg = &reset_manager_base->per0modrst; + break; + case 2: + reg = &reset_manager_base->per1modrst; + break; + case 3: + reg = &reset_manager_base->brgmodrst; + break; + case 4: + reg = &reset_manager_base->sysmodrst; + break; + + default: + return; + } + + if (set) + setbits_le32(reg, 1 << RSTMGR_RESET(reset)); + else + clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); +} + +/* + * Assert reset on every peripheral but L4WD0. + * Watchdog must be kept intact to prevent glitches + * and/or hangs. + * For the Arria10, we disable all the peripherals except L4 watchdog0, + * L4 Timer 0, and ECC. + */ +void socfpga_per_reset_all(void) +{ + const u32 l4wd0 = (1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)) | + (1 << RSTMGR_RESET(SOCFPGA_RESET(L4SYSTIMER0)))); + unsigned mask_ecc_ocp = + ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK | + ALT_RSTMGR_PER0MODRST_USBECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_USBECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK; + + /* disable all components except ECC_OCP, L4 Timer0 and L4 WD0 */ + writel(~l4wd0, &reset_manager_base->per1modrst); + setbits_le32(&reset_manager_base->per0modrst, ~mask_ecc_ocp); + + /* Finally disable the ECC_OCP */ + setbits_le32(&reset_manager_base->per0modrst, mask_ecc_ocp); +} + +#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) +int socfpga_bridges_reset(int enable) +{ + /* For SoCFPGA-VT, this is NOP. */ + return 0; +} +#else +int socfpga_bridges_reset(int enable) +{ + int ret; + + /* Disable all the bridges (hps2fpga, lwhps2fpga, fpga2hps, + fpga2sdram) */ + /* set idle request to all bridges */ + writel(ALT_SYSMGR_NOC_H2F_SET_MSK | + ALT_SYSMGR_NOC_LWH2F_SET_MSK | + ALT_SYSMGR_NOC_F2H_SET_MSK | + ALT_SYSMGR_NOC_F2SDR0_SET_MSK | + ALT_SYSMGR_NOC_F2SDR1_SET_MSK | + ALT_SYSMGR_NOC_F2SDR2_SET_MSK, + &sysmgr_regs->noc_idlereq_set); + + /* Enable the NOC timeout */ + writel(ALT_SYSMGR_NOC_TMO_EN_SET_MSK, &sysmgr_regs->noc_timeout); + + /* Poll until all idleack to 1 */ + ret = wait_for_bit(__func__, &sysmgr_regs->noc_idleack, + ALT_SYSMGR_NOC_H2F_SET_MSK | + ALT_SYSMGR_NOC_LWH2F_SET_MSK | + ALT_SYSMGR_NOC_F2H_SET_MSK | + ALT_SYSMGR_NOC_F2SDR0_SET_MSK | + ALT_SYSMGR_NOC_F2SDR1_SET_MSK | + ALT_SYSMGR_NOC_F2SDR2_SET_MSK, + true, 10000, false); + if (ret) + return ret; + + /* Poll until all idlestatus to 1 */ + ret = wait_for_bit(__func__, &sysmgr_regs->noc_idlestatus, + ALT_SYSMGR_NOC_H2F_SET_MSK | + ALT_SYSMGR_NOC_LWH2F_SET_MSK | + ALT_SYSMGR_NOC_F2H_SET_MSK | + ALT_SYSMGR_NOC_F2SDR0_SET_MSK | + ALT_SYSMGR_NOC_F2SDR1_SET_MSK | + ALT_SYSMGR_NOC_F2SDR2_SET_MSK, + true, 10000, false); + if (ret) + return ret; + + /* Put all bridges (except NOR DDR scheduler) into reset state */ + setbits_le32(&reset_manager_base->brgmodrst, + (ALT_RSTMGR_BRGMODRST_H2F_SET_MSK | + ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2H_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK)); + + /* Disable NOC timeout */ + writel(0, &sysmgr_regs->noc_timeout); + + return 0; +} +#endif diff --git a/include/dt-bindings/reset/altr,rst-mgr-a10.h b/include/dt-bindings/reset/altr,rst-mgr-a10.h new file mode 100644 index 0000000..99875de --- /dev/null +++ b/include/dt-bindings/reset/altr,rst-mgr-a10.h @@ -0,0 +1,103 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _DT_BINDINGS_RESET_ALTR_RST_MGR_A10_H +#define _DT_BINDINGS_RESET_ALTR_RST_MGR_A10_H + +/* MPUMODRST */ +#define CPU0_RESET 0 +#define CPU1_RESET 1 +#define WDS_RESET 2 +#define SCUPER_RESET 3 + +/* PER0MODRST */ +#define EMAC0_RESET 32 +#define EMAC1_RESET 33 +#define EMAC2_RESET 34 +#define USB0_RESET 35 +#define USB1_RESET 36 +#define NAND_RESET 37 +#define QSPI_RESET 38 +#define SDMMC_RESET 39 +#define EMAC0_OCP_RESET 40 +#define EMAC1_OCP_RESET 41 +#define EMAC2_OCP_RESET 42 +#define USB0_OCP_RESET 43 +#define USB1_OCP_RESET 44 +#define NAND_OCP_RESET 45 +#define QSPI_OCP_RESET 46 +#define SDMMC_OCP_RESET 47 +#define DMA_RESET 48 +#define SPIM0_RESET 49 +#define SPIM1_RESET 50 +#define SPIS0_RESET 51 +#define SPIS1_RESET 52 +#define DMA_OCP_RESET 53 +#define EMAC_PTP_RESET 54 +/* 55 is empty*/ +#define DMAIF0_RESET 56 +#define DMAIF1_RESET 57 +#define DMAIF2_RESET 58 +#define DMAIF3_RESET 59 +#define DMAIF4_RESET 60 +#define DMAIF5_RESET 61 +#define DMAIF6_RESET 62 +#define DMAIF7_RESET 63 + +/* PER1MODRST */ +#define L4WD0_RESET 64 +#define L4WD1_RESET 65 +#define L4SYSTIMER0_RESET 66 +#define L4SYSTIMER1_RESET 67 +#define SPTIMER0_RESET 68 +#define SPTIMER1_RESET 69 +/* 70-71 is reserved */ +#define I2C0_RESET 72 +#define I2C1_RESET 73 +#define I2C2_RESET 74 +#define I2C3_RESET 75 +#define I2C4_RESET 76 +/* 77-79 is reserved */ +#define UART0_RESET 80 +#define UART1_RESET 81 +/* 82-87 is reserved */ +#define GPIO0_RESET 88 +#define GPIO1_RESET 89 +#define GPIO2_RESET 90 + +/* BRGMODRST */ +#define HPS2FPGA_RESET 96 +#define LWHPS2FPGA_RESET 97 +#define FPGA2HPS_RESET 98 +#define F2SSDRAM0_RESET 99 +#define F2SSDRAM1_RESET 100 +#define F2SSDRAM2_RESET 101 +#define DDRSCH_RESET 102 + +/* SYSMODRST*/ +#define ROM_RESET 128 +#define OCRAM_RESET 129 +/* 130 is reserved */ +#define FPGAMGR_RESET 131 +#define S2F_RESET 132 +#define SYSDBG_RESET 133 +#define OCRAM_OCP_RESET 134 + +/* COLDMODRST */ +#define CLKMGRCOLD_RESET 160 +/* 161-162 is reserved */ +#define S2FCOLD_RESET 163 +#define TIMESTAMPCOLD_RESET 164 +#define TAPCOLD_RESET 165 +#define HMCCOLD_RESET 166 +#define IOMGRCOLD_RESET 167 + +/* NRSTMODRST */ +#define NRSTPINOE_RESET 192 + +/* DBGMODRST */ +#define DBG_RESET 224 +#endif
Add clock driver support for Arria 10.
Conflicts: arch/arm/mach-socfpga/clock_manager.c --- arch/arm/mach-socfpga/Makefile | 3 +- arch/arm/mach-socfpga/clock_manager.c | 10 + arch/arm/mach-socfpga/clock_manager_arria10.c | 1096 ++++++++++++++++++++ arch/arm/mach-socfpga/include/mach/clock_manager.h | 3 + .../include/mach/clock_manager_arria10.h | 224 ++++ 5 files changed, 1335 insertions(+), 1 deletion(-) create mode 100644 arch/arm/mach-socfpga/clock_manager_arria10.c create mode 100644 arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index d81f003..c494930 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -10,7 +10,8 @@ obj-y += misc.o timer.o reset_manager.o clock_manager.o \ fpga_manager.o board.o
-obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += reset_manager_arria10.o +obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clock_manager_arria10.o \ + reset_manager_arria10.o
diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager.c index 8051995..cb6ae03 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -19,7 +19,12 @@ void cm_wait_for_lock(u32 mask) u32 inter_val; u32 retry = 0; do { +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) inter_val = readl(&clock_manager_base->inter) & mask; +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + inter_val = readl(&clock_manager_base->stat) & mask; +#endif + /* Wait for stable lock */ if (inter_val == mask) retry++; else @@ -44,7 +49,12 @@ int set_cpu_clk_info(void)
gd->bd->bi_arm_freq = cm_get_mpu_clk_hz() / 1000000; gd->bd->bi_dsp_freq = 0; + +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) gd->bd->bi_ddr_freq = cm_get_sdram_clk_hz() / 1000000; +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + gd->bd->bi_ddr_freq = 0; +#endif
return 0; } diff --git a/arch/arm/mach-socfpga/clock_manager_arria10.c b/arch/arm/mach-socfpga/clock_manager_arria10.c new file mode 100644 index 0000000..482b854 --- /dev/null +++ b/arch/arm/mach-socfpga/clock_manager_arria10.c @@ -0,0 +1,1096 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <fdtdec.h> +#include <asm/io.h> +#include <asm/arch/clock_manager.h> + +DECLARE_GLOBAL_DATA_PTR; + +static u32 eosc1_hz; +static u32 cb_intosc_hz; +static u32 f2s_free_hz; +static u32 cm_l4_main_clk_hz; +static u32 cm_l4_sp_clk_hz; +static u32 cm_l4_mp_clk_hz; +static u32 cm_l4_sys_free_clk_hz; + +struct mainpll_cfg { + u32 vco0_psrc; + u32 vco1_denom; + u32 vco1_numer; + u32 mpuclk; + u32 mpuclk_cnt; + u32 mpuclk_src; + u32 nocclk; + u32 nocclk_cnt; + u32 nocclk_src; + u32 cntr2clk_cnt; + u32 cntr3clk_cnt; + u32 cntr4clk_cnt; + u32 cntr5clk_cnt; + u32 cntr6clk_cnt; + u32 cntr7clk_cnt; + u32 cntr7clk_src; + u32 cntr8clk_cnt; + u32 cntr9clk_cnt; + u32 cntr9clk_src; + u32 cntr15clk_cnt; + u32 nocdiv_l4mainclk; + u32 nocdiv_l4mpclk; + u32 nocdiv_l4spclk; + u32 nocdiv_csatclk; + u32 nocdiv_cstraceclk; + u32 nocdiv_cspdbclk; +}; + +struct perpll_cfg { + u32 vco0_psrc; + u32 vco1_denom; + u32 vco1_numer; + u32 cntr2clk_cnt; + u32 cntr2clk_src; + u32 cntr3clk_cnt; + u32 cntr3clk_src; + u32 cntr4clk_cnt; + u32 cntr4clk_src; + u32 cntr5clk_cnt; + u32 cntr5clk_src; + u32 cntr6clk_cnt; + u32 cntr6clk_src; + u32 cntr7clk_cnt; + u32 cntr8clk_cnt; + u32 cntr8clk_src; + u32 cntr9clk_cnt; + u32 emacctl_emac0sel; + u32 emacctl_emac1sel; + u32 emacctl_emac2sel; + u32 gpiodiv_gpiodbclk; +}; + +struct alteragrp_cfg { + u32 nocclk; + u32 mpuclk; +}; + +static const struct socfpga_clock_manager *clock_manager_base = + (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS; + +static int of_to_struct(const void *blob, int node, int cfg_len, void *cfg) +{ + if (fdtdec_get_int_array(blob, node, "altr,of_reg_value", + (u32 *)cfg, cfg_len)) { + /* could not find required property */ + return -EINVAL; + } + + return 0; +} + +static int of_get_input_clks(const void *blob, int node, u32 *val) +{ + *val = fdtdec_get_uint(blob, node, "clock-frequency", 0); + if (!*val) + return -EINVAL; + + return 0; +} + +static int of_get_clk_cfg(const void *blob, struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, + struct alteragrp_cfg *altrgrp_cfg) +{ + int node, child, len; + const char *node_name; + + node = fdtdec_next_compatible(blob, 0, COMPAT_ALTERA_SOCFPGA_CLK); + if (node < 0) + return -EINVAL; + + child = fdt_first_subnode(blob, node); + if (child < 0) + return -EINVAL; + + child = fdt_first_subnode(blob, child); + if (child < 0) + return -EINVAL; + + node_name = fdt_get_name(blob, child, &len); + + while (node_name) { + if (!strcmp(node_name, "osc1")) { + if (of_get_input_clks(blob, child, &eosc1_hz)) + return -EINVAL; + } else if (!strcmp(node_name, "cb_intosc_ls_clk")) { + if (of_get_input_clks(blob, child, &cb_intosc_hz)) + return -EINVAL; + } else if (!strcmp(node_name, "f2s_free_clk")) { + if (of_get_input_clks(blob, child, &f2s_free_hz)) + return -EINVAL; + } else if (!strcmp(node_name, "main_pll")) { + if (of_to_struct(blob, child, + sizeof(*main_cfg)/sizeof(u32), + main_cfg)) + return -EINVAL; + } else if (!strcmp(node_name, "periph_pll")) { + if (of_to_struct(blob, child, + sizeof(*per_cfg)/sizeof(u32), + per_cfg)) + return -EINVAL; + } else if (!strcmp(node_name, "altera")) { + if (of_to_struct(blob, child, + sizeof(*altrgrp_cfg)/sizeof(u32), + altrgrp_cfg)) + return -EINVAL; + + main_cfg->mpuclk = altrgrp_cfg->mpuclk; + main_cfg->nocclk = altrgrp_cfg->nocclk; + } + child = fdt_next_subnode(blob, child); + + if (child < 0) + break; + + node_name = fdt_get_name(blob, child, &len); + } + + return 0; +} + +/* calculate the intended main VCO frequency based on handoff */ +static unsigned int cm_calc_handoff_main_vco_clk_hz + (struct mainpll_cfg *main_cfg) +{ + unsigned int clk_hz; + + /* Check main VCO clock source: eosc, intosc or f2s? */ + switch (main_cfg->vco0_psrc) { + case CLKMGR_MAINPLL_VCO0_PSRC_EOSC: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_VCO0_PSRC_E_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_VCO0_PSRC_F2S: + clk_hz = f2s_free_hz; + break; + default: + return 0; + } + + /* calculate the VCO frequency */ + clk_hz /= 1 + main_cfg->vco1_denom; + clk_hz *= 1 + main_cfg->vco1_numer; + + return clk_hz; +} + +/* calculate the intended periph VCO frequency based on handoff */ +static unsigned int cm_calc_handoff_periph_vco_clk_hz( + struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) +{ + unsigned int clk_hz; + + /* Check periph VCO clock source: eosc, intosc, f2s or mainpll? */ + switch (per_cfg->vco0_psrc) { + case CLKMGR_PERPLL_VCO0_PSRC_EOSC: + clk_hz = eosc1_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_E_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_F2S: + clk_hz = f2s_free_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_MAIN: + clk_hz = cm_calc_handoff_main_vco_clk_hz(main_cfg); + clk_hz /= main_cfg->cntr15clk_cnt; + break; + default: + return 0; + } + + /* calculate the VCO frequency */ + clk_hz /= 1 + per_cfg->vco1_denom; + clk_hz *= 1 + per_cfg->vco1_numer; + + return clk_hz; +} + +/* calculate the intended MPU clock frequency based on handoff */ +static unsigned int cm_calc_handoff_mpu_clk_hz(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg) +{ + unsigned int clk_hz; + + /* Check MPU clock source: main, periph, osc1, intosc or f2s? */ + switch (main_cfg->mpuclk_src) { + case CLKMGR_MAINPLL_MPUCLK_SRC_MAIN: + clk_hz = cm_calc_handoff_main_vco_clk_hz(main_cfg); + clk_hz /= (main_cfg->mpuclk & CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + + 1; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_PERI: + clk_hz = cm_calc_handoff_periph_vco_clk_hz(main_cfg, per_cfg); + clk_hz /= ((main_cfg->mpuclk >> + CLKMGR_MAINPLL_MPUCLK_PERICNT_LSB) & + CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + 1; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_OSC1: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_FPGA: + clk_hz = f2s_free_hz; + break; + default: + return 0; + } + + clk_hz /= main_cfg->mpuclk_cnt + 1; + return clk_hz; +} + +/* calculate the intended NOC clock frequency based on handoff */ +static unsigned int cm_calc_handoff_noc_clk_hz(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg) +{ + unsigned int clk_hz; + + /* Check MPU clock source: main, periph, osc1, intosc or f2s? */ + switch (main_cfg->nocclk_src) { + case CLKMGR_MAINPLL_NOCCLK_SRC_MAIN: + clk_hz = cm_calc_handoff_main_vco_clk_hz(main_cfg); + clk_hz /= (main_cfg->nocclk & CLKMGR_MAINPLL_NOCCLK_CNT_MSK) + + 1; + break; + case CLKMGR_MAINPLL_NOCCLK_SRC_PERI: + clk_hz = cm_calc_handoff_periph_vco_clk_hz(main_cfg, per_cfg); + clk_hz /= ((main_cfg->nocclk >> + CLKMGR_MAINPLL_NOCCLK_PERICNT_LSB) & + CLKMGR_MAINPLL_NOCCLK_CNT_MSK) + 1; + break; + case CLKMGR_MAINPLL_NOCCLK_SRC_OSC1: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_NOCCLK_SRC_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_NOCCLK_SRC_FPGA: + clk_hz = f2s_free_hz; + break; + default: + return 0; + } + + clk_hz /= main_cfg->nocclk_cnt + 1; + return clk_hz; +} + +/* return 1 if PLL ramp is required */ +static int cm_is_pll_ramp_required(int main0periph1, + struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg) +{ + /* Check for main PLL */ + if (main0periph1 == 0) { + /* + * PLL ramp is not required if both MPU clock and NOC clock are + * not sourced from main PLL + */ + if (main_cfg->mpuclk_src != CLKMGR_MAINPLL_MPUCLK_SRC_MAIN && + main_cfg->nocclk_src != CLKMGR_MAINPLL_NOCCLK_SRC_MAIN) + return 0; + + /* + * PLL ramp is required if MPU clock is sourced from main PLL + * and MPU clock is over 900MHz (as advised by HW team) + */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_MAIN && + (cm_calc_handoff_mpu_clk_hz(main_cfg, per_cfg) > + CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ)) + return 1; + + /* + * PLL ramp is required if NOC clock is sourced from main PLL + * and NOC clock is over 300MHz (as advised by HW team) + */ + if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_MAIN && + (cm_calc_handoff_noc_clk_hz(main_cfg, per_cfg) > + CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ)) + return 2; + + } else if (main0periph1 == 1) { + /* + * PLL ramp is not required if both MPU clock and NOC clock are + * not sourced from periph PLL + */ + if (main_cfg->mpuclk_src != CLKMGR_MAINPLL_MPUCLK_SRC_PERI && + main_cfg->nocclk_src != CLKMGR_MAINPLL_NOCCLK_SRC_PERI) + return 0; + + /* + * PLL ramp is required if MPU clock are source from periph PLL + * and MPU clock is over 900MHz (as advised by HW team) + */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_PERI && + (cm_calc_handoff_mpu_clk_hz(main_cfg, per_cfg) > + CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ)) + return 1; + + /* + * PLL ramp is required if NOC clock are source from periph PLL + * and NOC clock is over 300MHz (as advised by HW team) + */ + if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_PERI && + (cm_calc_handoff_noc_clk_hz(main_cfg, per_cfg) > + CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ)) + return 2; + } + + return 0; +} + +static u32 cm_calculate_numer(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, + u32 safe_hz, u32 clk_hz) +{ + u32 cnt; + u32 clk; + u32 shift; + u32 mask; + u32 denom; + + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_MAIN) { + cnt = main_cfg->mpuclk_cnt; + clk = main_cfg->mpuclk; + shift = 0; + mask = CLKMGR_MAINPLL_MPUCLK_CNT_MSK; + denom = main_cfg->vco1_denom; + } else if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_MAIN) { + cnt = main_cfg->nocclk_cnt; + clk = main_cfg->nocclk; + shift = 0; + mask = CLKMGR_MAINPLL_NOCCLK_CNT_MSK; + denom = main_cfg->vco1_denom; + } else if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_PERI) { + cnt = main_cfg->mpuclk_cnt; + clk = main_cfg->mpuclk; + shift = CLKMGR_MAINPLL_MPUCLK_PERICNT_LSB; + mask = CLKMGR_MAINPLL_MPUCLK_CNT_MSK; + denom = per_cfg->vco1_denom; + } else if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_PERI) { + cnt = main_cfg->nocclk_cnt; + clk = main_cfg->nocclk; + shift = CLKMGR_MAINPLL_NOCCLK_PERICNT_LSB; + mask = CLKMGR_MAINPLL_NOCCLK_CNT_MSK; + denom = per_cfg->vco1_denom; + } else { + return 0; + } + + return (safe_hz / clk_hz) * (cnt + 1) * (((clk >> shift) & mask) + 1) * + (1 + denom) - 1; +} + +/* + * Calculate the new PLL numerator which is based on existing DTS hand off and + * intended safe frequency (safe_hz). Note that PLL ramp is only modifying the + * numerator while maintaining denominator as denominator will influence the + * jitter condition. Please refer A10 HPS TRM for the jitter guide. Note final + * value for numerator is minus with 1 to cater our register value + * representation. + */ +static unsigned int cm_calc_safe_pll_numer(int main0periph1, + struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, + unsigned int safe_hz) +{ + unsigned int clk_hz = 0; + + /* Check for main PLL */ + if (main0periph1 == 0) { + /* Check main VCO clock source: eosc, intosc or f2s? */ + switch (main_cfg->vco0_psrc) { + case CLKMGR_MAINPLL_VCO0_PSRC_EOSC: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_VCO0_PSRC_E_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_VCO0_PSRC_F2S: + clk_hz = f2s_free_hz; + break; + default: + return 0; + } + } else if (main0periph1 == 1) { + /* Check periph VCO clock source: eosc, intosc, f2s, mainpll */ + switch (per_cfg->vco0_psrc) { + case CLKMGR_PERPLL_VCO0_PSRC_EOSC: + clk_hz = eosc1_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_E_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_F2S: + clk_hz = f2s_free_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_MAIN: + clk_hz = cm_calc_handoff_main_vco_clk_hz(main_cfg); + clk_hz /= main_cfg->cntr15clk_cnt; + break; + default: + return 0; + } + } else { + return 0; + } + + return cm_calculate_numer(main_cfg, per_cfg, safe_hz, clk_hz); +} + +/* ramping the main PLL to final value */ +static void cm_pll_ramp_main(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, + unsigned int pll_ramp_main_hz) +{ + unsigned int clk_hz = 0, clk_incr_hz = 0, clk_final_hz = 0; + + /* find out the increment value */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_MAIN) { + clk_incr_hz = CLKMGR_PLL_RAMP_MPUCLK_INCREMENT_HZ; + clk_final_hz = cm_calc_handoff_mpu_clk_hz(main_cfg, per_cfg); + } else if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_MAIN) { + clk_incr_hz = CLKMGR_PLL_RAMP_NOCCLK_INCREMENT_HZ; + clk_final_hz = cm_calc_handoff_noc_clk_hz(main_cfg, per_cfg); + } + + /* execute the ramping here */ + for (clk_hz = pll_ramp_main_hz + clk_incr_hz; + clk_hz < clk_final_hz; clk_hz += clk_incr_hz) { + writel((main_cfg->vco1_denom << + CLKMGR_MAINPLL_VCO1_DENOM_LSB) | + cm_calc_safe_pll_numer(0, main_cfg, per_cfg, clk_hz), + &clock_manager_base->main_pll.vco1); + mdelay(1); + cm_wait_for_lock(LOCKED_MASK); + } + writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) | + main_cfg->vco1_numer, &clock_manager_base->main_pll.vco1); + mdelay(1); + cm_wait_for_lock(LOCKED_MASK); +} + +/* ramping the periph PLL to final value */ +static void cm_pll_ramp_periph(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, + unsigned int pll_ramp_periph_hz) +{ + unsigned int clk_hz = 0, clk_incr_hz = 0, clk_final_hz = 0; + + /* find out the increment value */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_PERI) { + clk_incr_hz = CLKMGR_PLL_RAMP_MPUCLK_INCREMENT_HZ; + clk_final_hz = cm_calc_handoff_mpu_clk_hz(main_cfg, per_cfg); + } else if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_PERI) { + clk_incr_hz = CLKMGR_PLL_RAMP_NOCCLK_INCREMENT_HZ; + clk_final_hz = cm_calc_handoff_noc_clk_hz(main_cfg, per_cfg); + } + /* execute the ramping here */ + for (clk_hz = pll_ramp_periph_hz + clk_incr_hz; + clk_hz < clk_final_hz; clk_hz += clk_incr_hz) { + writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | + cm_calc_safe_pll_numer(1, main_cfg, per_cfg, clk_hz), + &clock_manager_base->per_pll.vco1); + mdelay(1); + cm_wait_for_lock(LOCKED_MASK); + } + writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | + per_cfg->vco1_numer, &clock_manager_base->per_pll.vco1); + mdelay(1); + cm_wait_for_lock(LOCKED_MASK); +} + +/* + * Setup clocks while making no assumptions of the + * previous state of the clocks. + * + * Start by being paranoid and gate all sw managed clocks + * + * Put all plls in bypass + * + * Put all plls VCO registers back to reset value (bgpwr dwn). + * + * Put peripheral and main pll src to reset value to avoid glitch. + * + * Delay 5 us. + * + * Deassert bg pwr dn and set numerator and denominator + * + * Start 7 us timer. + * + * set internal dividers + * + * Wait for 7 us timer. + * + * Enable plls + * + * Set external dividers while plls are locking + * + * Wait for pll lock + * + * Assert/deassert outreset all. + * + * Take all pll's out of bypass + * + * Clear safe mode + * + * set source main and peripheral clocks + * + * Ungate clocks + */ + +static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) +{ + unsigned int pll_ramp_main_hz = 0, pll_ramp_periph_hz = 0, + ramp_required; + + /* gate off all mainpll clock excpet HW managed clock */ + writel(CLKMGR_MAINPLL_EN_S2FUSER0CLKEN_SET_MSK | + CLKMGR_MAINPLL_EN_HMCPLLREFCLKEN_SET_MSK, + &clock_manager_base->main_pll.enr); + + /* now we can gate off the rest of the peripheral clocks */ + writel(0, &clock_manager_base->per_pll.en); + + /* Put all plls in external bypass */ + writel(CLKMGR_MAINPLL_BYPASS_RESET, + &clock_manager_base->main_pll.bypasss); + writel(CLKMGR_PERPLL_BYPASS_RESET, + &clock_manager_base->per_pll.bypasss); + + /* + * Put all plls VCO registers back to reset value. + * Some code might have messed with them. At same time set the + * desired clock source + */ + writel(CLKMGR_MAINPLL_VCO0_RESET | + CLKMGR_MAINPLL_VCO0_REGEXTSEL_SET_MSK | + (main_cfg->vco0_psrc << CLKMGR_MAINPLL_VCO0_PSRC_LSB), + &clock_manager_base->main_pll.vco0); + + writel(CLKMGR_PERPLL_VCO0_RESET | + CLKMGR_PERPLL_VCO0_REGEXTSEL_SET_MSK | + (per_cfg->vco0_psrc << CLKMGR_PERPLL_VCO0_PSRC_LSB), + &clock_manager_base->per_pll.vco0); + + writel(CLKMGR_MAINPLL_VCO1_RESET, &clock_manager_base->main_pll.vco1); + writel(CLKMGR_PERPLL_VCO1_RESET, &clock_manager_base->per_pll.vco1); + + /* clear the interrupt register status register */ + writel(CLKMGR_CLKMGR_INTR_MAINPLLLOST_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLLOST_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLRFSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLRFSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLFBSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLFBSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLACHIEVED_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLACHIEVED_SET_MSK, + &clock_manager_base->intr); + + /* Program VCO Numerator and Denominator for main PLL */ + ramp_required = cm_is_pll_ramp_required(0, main_cfg, per_cfg); + if (ramp_required) { + /* set main PLL to safe starting threshold frequency */ + if (ramp_required == 1) + pll_ramp_main_hz = CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ; + else if (ramp_required == 2) + pll_ramp_main_hz = CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ; + + writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) | + cm_calc_safe_pll_numer(0, main_cfg, per_cfg, + pll_ramp_main_hz), + &clock_manager_base->main_pll.vco1); + } else + writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) | + main_cfg->vco1_numer, + &clock_manager_base->main_pll.vco1); + + /* Program VCO Numerator and Denominator for periph PLL */ + ramp_required = cm_is_pll_ramp_required(1, main_cfg, per_cfg); + if (ramp_required) { + /* set periph PLL to safe starting threshold frequency */ + if (ramp_required == 1) + pll_ramp_periph_hz = + CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ; + else if (ramp_required == 2) + pll_ramp_periph_hz = + CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ; + + writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | + cm_calc_safe_pll_numer(1, main_cfg, per_cfg, + pll_ramp_periph_hz), + &clock_manager_base->per_pll.vco1); + } else + writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | + per_cfg->vco1_numer, + &clock_manager_base->per_pll.vco1); + + /* Wait for at least 5 us */ + udelay(5); + + /* Now deassert BGPWRDN and PWRDN */ + clrbits_le32(&clock_manager_base->main_pll.vco0, + CLKMGR_MAINPLL_VCO0_BGPWRDN_SET_MSK | + CLKMGR_MAINPLL_VCO0_PWRDN_SET_MSK); + clrbits_le32(&clock_manager_base->per_pll.vco0, + CLKMGR_PERPLL_VCO0_BGPWRDN_SET_MSK | + CLKMGR_PERPLL_VCO0_PWRDN_SET_MSK); + + /* Wait for at least 7 us */ + udelay(7); + + /* enable the VCO and disable the external regulator to PLL */ + writel((readl(&clock_manager_base->main_pll.vco0) & + ~CLKMGR_MAINPLL_VCO0_REGEXTSEL_SET_MSK) | + CLKMGR_MAINPLL_VCO0_EN_SET_MSK, + &clock_manager_base->main_pll.vco0); + writel((readl(&clock_manager_base->per_pll.vco0) & + ~CLKMGR_PERPLL_VCO0_REGEXTSEL_SET_MSK) | + CLKMGR_PERPLL_VCO0_EN_SET_MSK, + &clock_manager_base->per_pll.vco0); + + /* setup all the main PLL counter and clock source */ + writel(main_cfg->nocclk, + SOCFPGA_CLKMGR_ADDRESS + CLKMGR_MAINPLL_NOC_CLK_OFFSET); + writel(main_cfg->mpuclk, + SOCFPGA_CLKMGR_ADDRESS + CLKMGR_ALTERAGRP_MPU_CLK_OFFSET); + + /* main_emaca_clk divider */ + writel(main_cfg->cntr2clk_cnt, &clock_manager_base->main_pll.cntr2clk); + /* main_emacb_clk divider */ + writel(main_cfg->cntr3clk_cnt, &clock_manager_base->main_pll.cntr3clk); + /* main_emac_ptp_clk divider */ + writel(main_cfg->cntr4clk_cnt, &clock_manager_base->main_pll.cntr4clk); + /* main_gpio_db_clk divider */ + writel(main_cfg->cntr5clk_cnt, &clock_manager_base->main_pll.cntr5clk); + /* main_sdmmc_clk divider */ + writel(main_cfg->cntr6clk_cnt, &clock_manager_base->main_pll.cntr6clk); + /* main_s2f_user0_clk divider */ + writel(main_cfg->cntr7clk_cnt | + (main_cfg->cntr7clk_src << CLKMGR_MAINPLL_CNTR7CLK_SRC_LSB), + &clock_manager_base->main_pll.cntr7clk); + /* main_s2f_user1_clk divider */ + writel(main_cfg->cntr8clk_cnt, &clock_manager_base->main_pll.cntr8clk); + /* main_hmc_pll_clk divider */ + writel(main_cfg->cntr9clk_cnt | + (main_cfg->cntr9clk_src << CLKMGR_MAINPLL_CNTR9CLK_SRC_LSB), + &clock_manager_base->main_pll.cntr9clk); + /* main_periph_ref_clk divider */ + writel(main_cfg->cntr15clk_cnt, + &clock_manager_base->main_pll.cntr15clk); + + /* setup all the peripheral PLL counter and clock source */ + /* peri_emaca_clk divider */ + writel(per_cfg->cntr2clk_cnt | + (per_cfg->cntr2clk_src << CLKMGR_PERPLL_CNTR2CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr2clk); + /* peri_emacb_clk divider */ + writel(per_cfg->cntr3clk_cnt | + (per_cfg->cntr3clk_src << CLKMGR_PERPLL_CNTR3CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr3clk); + /* peri_emac_ptp_clk divider */ + writel(per_cfg->cntr4clk_cnt | + (per_cfg->cntr4clk_src << CLKMGR_PERPLL_CNTR4CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr4clk); + /* peri_gpio_db_clk divider */ + writel(per_cfg->cntr5clk_cnt | + (per_cfg->cntr5clk_src << CLKMGR_PERPLL_CNTR5CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr5clk); + /* peri_sdmmc_clk divider */ + writel(per_cfg->cntr6clk_cnt | + (per_cfg->cntr6clk_src << CLKMGR_PERPLL_CNTR6CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr6clk); + /* peri_s2f_user0_clk divider */ + writel(per_cfg->cntr7clk_cnt, &clock_manager_base->per_pll.cntr7clk); + /* peri_s2f_user1_clk divider */ + writel(per_cfg->cntr8clk_cnt | + (per_cfg->cntr8clk_src << CLKMGR_PERPLL_CNTR8CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr8clk); + /* peri_hmc_pll_clk divider */ + writel(per_cfg->cntr9clk_cnt, &clock_manager_base->per_pll.cntr9clk); + + /* setup all the external PLL counter */ + /* mpu wrapper / external divider */ + writel(main_cfg->mpuclk_cnt | + (main_cfg->mpuclk_src << CLKMGR_MAINPLL_MPUCLK_SRC_LSB), + &clock_manager_base->main_pll.mpuclk); + /* NOC wrapper / external divider */ + writel(main_cfg->nocclk_cnt | + (main_cfg->nocclk_src << CLKMGR_MAINPLL_NOCCLK_SRC_LSB), + &clock_manager_base->main_pll.nocclk); + /* NOC subclock divider such as l4 */ + writel(main_cfg->nocdiv_l4mainclk | + (main_cfg->nocdiv_l4mpclk << + CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB) | + (main_cfg->nocdiv_l4spclk << + CLKMGR_MAINPLL_NOCDIV_L4SPCLK_LSB) | + (main_cfg->nocdiv_csatclk << + CLKMGR_MAINPLL_NOCDIV_CSATCLK_LSB) | + (main_cfg->nocdiv_cstraceclk << + CLKMGR_MAINPLL_NOCDIV_CSTRACECLK_LSB) | + (main_cfg->nocdiv_cspdbclk << + CLKMGR_MAINPLL_NOCDIV_CSPDBGCLK_LSB), + &clock_manager_base->main_pll.nocdiv); + /* gpio_db external divider */ + writel(per_cfg->gpiodiv_gpiodbclk, + &clock_manager_base->per_pll.gpiodiv); + + /* setup the EMAC clock mux select */ + writel((per_cfg->emacctl_emac0sel << + CLKMGR_PERPLL_EMACCTL_EMAC0SEL_LSB) | + (per_cfg->emacctl_emac1sel << + CLKMGR_PERPLL_EMACCTL_EMAC1SEL_LSB) | + (per_cfg->emacctl_emac2sel << + CLKMGR_PERPLL_EMACCTL_EMAC2SEL_LSB), + &clock_manager_base->per_pll.emacctl); + + /* at this stage, check for PLL lock status */ + cm_wait_for_lock(LOCKED_MASK); + + /* + * after locking, but before taking out of bypass, + * assert/deassert outresetall + */ + /* assert mainpll outresetall */ + setbits_le32(&clock_manager_base->main_pll.vco0, + CLKMGR_MAINPLL_VCO0_OUTRSTALL_SET_MSK); + /* assert perpll outresetall */ + setbits_le32(&clock_manager_base->per_pll.vco0, + CLKMGR_PERPLL_VCO0_OUTRSTALL_SET_MSK); + /* de-assert mainpll outresetall */ + clrbits_le32(&clock_manager_base->main_pll.vco0, + CLKMGR_MAINPLL_VCO0_OUTRSTALL_SET_MSK); + /* de-assert perpll outresetall */ + clrbits_le32(&clock_manager_base->per_pll.vco0, + CLKMGR_PERPLL_VCO0_OUTRSTALL_SET_MSK); + + /* Take all PLLs out of bypass when boot mode is cleared. */ + /* release mainpll from bypass */ + writel(CLKMGR_MAINPLL_BYPASS_RESET, + &clock_manager_base->main_pll.bypassr); + /* wait till Clock Manager is not busy */ + cm_wait_for_fsm(); + + /* release perpll from bypass */ + writel(CLKMGR_PERPLL_BYPASS_RESET, + &clock_manager_base->per_pll.bypassr); + /* wait till Clock Manager is not busy */ + cm_wait_for_fsm(); + + /* clear boot mode */ + clrbits_le32(&clock_manager_base->ctrl, + CLKMGR_CLKMGR_CTL_BOOTMOD_SET_MSK); + /* wait till Clock Manager is not busy */ + cm_wait_for_fsm(); + + /* At here, we need to ramp to final value if needed */ + if (pll_ramp_main_hz != 0) + cm_pll_ramp_main(main_cfg, per_cfg, pll_ramp_main_hz); + if (pll_ramp_periph_hz != 0) + cm_pll_ramp_periph(main_cfg, per_cfg, pll_ramp_periph_hz); + + /* Now ungate non-hw-managed clocks */ + writel(CLKMGR_MAINPLL_EN_S2FUSER0CLKEN_SET_MSK | + CLKMGR_MAINPLL_EN_HMCPLLREFCLKEN_SET_MSK, + &clock_manager_base->main_pll.ens); + writel(CLKMGR_PERPLL_EN_RESET, &clock_manager_base->per_pll.ens); + + /* Clear the loss lock and slip bits as they might set during + clock reconfiguration */ + writel(CLKMGR_CLKMGR_INTR_MAINPLLLOST_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLLOST_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLRFSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLRFSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLFBSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLFBSLIP_SET_MSK, + &clock_manager_base->intr); + + return 0; +} + +void cm_use_intosc(void) +{ + setbits_le32(&clock_manager_base->ctrl, + CLKMGR_CLKMGR_CTL_BOOTCLK_INTOSC_SET_MSK); +} + +unsigned int cm_get_noc_clk_hz(void) +{ + unsigned int clk_src, divisor, nocclk, src_hz; + + nocclk = readl(&clock_manager_base->main_pll.nocclk); + clk_src = (nocclk >> CLKMGR_MAINPLL_NOCCLK_SRC_LSB) & + CLKMGR_MAINPLL_NOCCLK_SRC_MSK; + + divisor = 1 + (nocclk & CLKMGR_MAINPLL_NOCDIV_MSK); + + if (clk_src == CLKMGR_PERPLLGRP_SRC_MAIN) { + src_hz = cm_get_main_vco_clk_hz(); + src_hz /= 1 + + (readl(SOCFPGA_CLKMGR_ADDRESS + CLKMGR_MAINPLL_NOC_CLK_OFFSET) & + CLKMGR_MAINPLL_NOCCLK_CNT_MSK); + } else if (clk_src == CLKMGR_PERPLLGRP_SRC_PERI) { + src_hz = cm_get_per_vco_clk_hz(); + src_hz /= 1 + + ((readl(SOCFPGA_CLKMGR_ADDRESS + + CLKMGR_MAINPLL_NOC_CLK_OFFSET) >> + CLKMGR_MAINPLL_NOCCLK_PERICNT_LSB) & + CLKMGR_MAINPLL_NOCCLK_CNT_MSK); + } else if (clk_src == CLKMGR_PERPLLGRP_SRC_OSC1) { + src_hz = eosc1_hz; + } else if (clk_src == CLKMGR_PERPLLGRP_SRC_INTOSC) { + src_hz = cb_intosc_hz; + } else if (clk_src == CLKMGR_PERPLLGRP_SRC_FPGA) { + src_hz = f2s_free_hz; + } else { + src_hz = 0; + } + + return src_hz / divisor; +} + +unsigned int cm_get_l4_noc_hz(unsigned int nocdivshift) +{ + unsigned int divisor2 = 1 << + ((readl(&clock_manager_base->main_pll.nocdiv) >> + nocdivshift) & CLKMGR_MAINPLL_NOCDIV_MSK); + + return cm_get_noc_clk_hz() / divisor2; +} + +int cm_basic_init(const void *blob) +{ + struct mainpll_cfg main_cfg; + struct perpll_cfg per_cfg; + struct alteragrp_cfg altrgrp_cfg; + int rval; + + /* initialize to zero for use case of optional node */ + memset(&main_cfg, 0, sizeof(main_cfg)); + memset(&per_cfg, 0, sizeof(per_cfg)); + memset(&altrgrp_cfg, 0, sizeof(altrgrp_cfg)); + + rval = of_get_clk_cfg(blob, &main_cfg, &per_cfg, &altrgrp_cfg); + if (rval) + return rval; + + rval = cm_full_cfg(&main_cfg, &per_cfg); + + cm_l4_main_clk_hz = + cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LSB); + + cm_l4_mp_clk_hz = cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB); + + cm_l4_sp_clk_hz = cm_get_l4_sp_clk_hz(); + + cm_l4_sys_free_clk_hz = cm_get_noc_clk_hz() / 4; + + return rval; +} + +unsigned long cm_get_mpu_clk_hz(void) +{ + u32 reg, clk_hz; + u32 clk_src, mainmpuclk_reg; + + mainmpuclk_reg = readl(&clock_manager_base->main_pll.mpuclk); + + clk_src = (mainmpuclk_reg >> CLKMGR_MAINPLL_MPUCLK_SRC_LSB) & + CLKMGR_MAINPLL_MPUCLK_SRC_MSK; + + reg = readl(&clock_manager_base->altera.mpuclk); + /* Check MPU clock source: main, periph, osc1, intosc or f2s? */ + switch (clk_src) { + case CLKMGR_MAINPLL_MPUCLK_SRC_MAIN: + clk_hz = cm_get_main_vco_clk_hz(); + clk_hz /= (reg & CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + 1; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_PERI: + clk_hz = cm_get_per_vco_clk_hz(); + clk_hz /= (((reg >> CLKMGR_MAINPLL_MPUCLK_PERICNT_LSB) & + CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + 1); + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_OSC1: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_FPGA: + clk_hz = f2s_free_hz; + break; + default: + printf("cm_get_mpu_clk_hz invalid clk_src %d\n", clk_src); + return 0; + } + + clk_hz /= (mainmpuclk_reg & CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + 1; + + return clk_hz; +} + +unsigned int cm_get_per_vco_clk_hz(void) +{ + u32 src_hz = 0; + u32 clk_src = 0; + u32 numer = 0; + u32 denom = 0; + u32 vco = 0; + + clk_src = readl(&clock_manager_base->per_pll.vco0); + + clk_src = (clk_src >> CLKMGR_PERPLL_VCO0_PSRC_LSB) & + CLKMGR_PERPLL_VCO0_PSRC_MSK; + + if (clk_src == CLKMGR_PERPLL_VCO0_PSRC_EOSC) { + src_hz = eosc1_hz; + } else if (clk_src == CLKMGR_PERPLL_VCO0_PSRC_E_INTOSC) { + src_hz = cb_intosc_hz; + } else if (clk_src == CLKMGR_PERPLL_VCO0_PSRC_F2S) { + src_hz = f2s_free_hz; + } else if (clk_src == CLKMGR_PERPLL_VCO0_PSRC_MAIN) { + src_hz = cm_get_main_vco_clk_hz(); + src_hz /= (readl(&clock_manager_base->main_pll.cntr15clk) & + CLKMGR_MAINPLL_CNTRCLK_MSK) + 1; + } else { + printf("cm_get_per_vco_clk_hz invalid clk_src %d\n", clk_src); + return 0; + } + + vco = readl(&clock_manager_base->per_pll.vco1); + + numer = vco & CLKMGR_PERPLL_VCO1_NUMER_MSK; + + denom = (vco >> CLKMGR_PERPLL_VCO1_DENOM_LSB) & + CLKMGR_PERPLL_VCO1_DENOM_MSK; + + vco = src_hz; + vco /= 1 + denom; + vco *= 1 + numer; + + return vco; +} + +unsigned int cm_get_main_vco_clk_hz(void) +{ + u32 src_hz, numer, denom, vco; + + u32 clk_src = readl(&clock_manager_base->main_pll.vco0); + + clk_src = (clk_src >> CLKMGR_MAINPLL_VCO0_PSRC_LSB) & + CLKMGR_MAINPLL_VCO0_PSRC_MSK; + + if (clk_src == CLKMGR_MAINPLL_VCO0_PSRC_EOSC) { + src_hz = eosc1_hz; + } else if (clk_src == CLKMGR_MAINPLL_VCO0_PSRC_E_INTOSC) { + src_hz = cb_intosc_hz; + } else if (clk_src == CLKMGR_MAINPLL_VCO0_PSRC_F2S) { + src_hz = f2s_free_hz; + } else { + printf("cm_get_main_vco_clk_hz invalid clk_src %d\n", clk_src); + return 0; + } + + vco = readl(&clock_manager_base->main_pll.vco1); + + numer = vco & CLKMGR_MAINPLL_VCO1_NUMER_MSK; + + denom = (vco >> CLKMGR_MAINPLL_VCO1_DENOM_LSB) & + CLKMGR_MAINPLL_VCO1_DENOM_MSK; + + vco = src_hz; + vco /= 1 + denom; + vco *= 1 + numer; + + return vco; +} + +unsigned int cm_get_l4_sp_clk_hz(void) +{ + return cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4SPCLK_LSB); +} + +unsigned int cm_get_mmc_controller_clk_hz(void) +{ + u32 clk_hz = 0; + u32 clk_input = 0; + + clk_input = readl(&clock_manager_base->per_pll.cntr6clk); + clk_input = (clk_input >> CLKMGR_PERPLL_CNTR6CLK_SRC_LSB) & + CLKMGR_PERPLLGRP_SRC_MSK; + + switch (clk_input) { + case CLKMGR_PERPLLGRP_SRC_MAIN: + clk_hz = cm_get_main_vco_clk_hz(); + clk_hz /= 1 + (readl(&clock_manager_base->main_pll.cntr6clk) & + CLKMGR_MAINPLL_CNTRCLK_MSK); + break; + + case CLKMGR_PERPLLGRP_SRC_PERI: + clk_hz = cm_get_per_vco_clk_hz(); + clk_hz /= 1 + (readl(&clock_manager_base->per_pll.cntr6clk) & + CLKMGR_PERPLL_CNTRCLK_MSK); + break; + + case CLKMGR_PERPLLGRP_SRC_OSC1: + clk_hz = eosc1_hz; + break; + + case CLKMGR_PERPLLGRP_SRC_INTOSC: + clk_hz = cb_intosc_hz; + break; + + case CLKMGR_PERPLLGRP_SRC_FPGA: + clk_hz = f2s_free_hz; + break; + } + + return clk_hz / 4; +} + +unsigned int cm_get_spi_controller_clk_hz(void) +{ + return cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB); +} + +unsigned int cm_get_qspi_controller_clk_hz(void) +{ + return cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LSB); +} + +void cm_print_clock_quick_summary(void) +{ + printf("MPU %10ld kHz\n", cm_get_mpu_clk_hz() / 1000); + printf("MMC %8d kHz\n", cm_get_mmc_controller_clk_hz() / 1000); + printf("QSPI %8d kHz\n", cm_get_qspi_controller_clk_hz() / 1000); + printf("SPI %8d kHz\n", cm_get_spi_controller_clk_hz() / 1000); + printf("EOSC1 %8d kHz\n", eosc1_hz / 1000); + printf("cb_intosc %8d kHz\n", cb_intosc_hz / 1000); + printf("f2s_free %8d kHz\n", f2s_free_hz / 1000); + printf("Main VCO %8d kHz\n", cm_get_main_vco_clk_hz() / 1000); + printf("NOC %8d kHz\n", cm_get_noc_clk_hz() / 1000); + printf("L4 Main %8d kHz\n", + cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LSB) / 1000); + printf("L4 MP %8d kHz\n", + cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB) / 1000); + printf("L4 SP %8d kHz\n", cm_get_l4_sp_clk_hz() / 1000); + printf("L4 sys free %8d kHz\n", cm_l4_sys_free_clk_hz / 1000); +} diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager.h index b076497..4c6b1f8 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager.h @@ -15,5 +15,8 @@ void cm_print_clock_quick_summary(void);
#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #include <asm/arch/clock_manager_gen5.h> +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#include <asm/arch/clock_manager_arria10.h> #endif + #endif /* _CLOCK_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h new file mode 100644 index 0000000..1b55bb8 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h @@ -0,0 +1,224 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef CLOCK_MANAGER_ARRIA10 +#define CLOCK_MANAGER_ARRIA10 + +#ifndef __ASSEMBLER__ + +struct socfpga_clock_manager_main_pll { + u32 vco0; + u32 vco1; + u32 en; + u32 ens; + u32 enr; + u32 bypass; + u32 bypasss; + u32 bypassr; + u32 mpuclk; + u32 nocclk; + u32 cntr2clk; + u32 cntr3clk; + u32 cntr4clk; + u32 cntr5clk; + u32 cntr6clk; + u32 cntr7clk; + u32 cntr8clk; + u32 cntr9clk; + u32 pad_0x48_0x5b[5]; + u32 cntr15clk; + u32 outrst; + u32 outrststat; + u32 nocdiv; + u32 pad_0x6c_0x80[5]; +}; + +struct socfpga_clock_manager_per_pll { + u32 vco0; + u32 vco1; + u32 en; + u32 ens; + u32 enr; + u32 bypass; + u32 bypasss; + u32 bypassr; + u32 pad_0x20_0x27[2]; + u32 cntr2clk; + u32 cntr3clk; + u32 cntr4clk; + u32 cntr5clk; + u32 cntr6clk; + u32 cntr7clk; + u32 cntr8clk; + u32 cntr9clk; + u32 pad_0x48_0x5f[6]; + u32 outrst; + u32 outrststat; + u32 emacctl; + u32 gpiodiv; + u32 pad_0x70_0x80[4]; +}; + +struct socfpga_clock_manager_altera { + u32 mpuclk; + u32 nocclk; + u32 mainmisc0; + u32 mainmisc1; + u32 perimisc0; + u32 perimisc1; +}; + +struct socfpga_clock_manager { + /* clkmgr */ + u32 ctrl; + u32 intr; + u32 intrs; + u32 intrr; + u32 intren; + u32 intrens; + u32 intrenr; + u32 stat; + u32 testioctrl; + u32 _pad_0x24_0x40[7]; + /* mainpllgrp */ + struct socfpga_clock_manager_main_pll main_pll; + /* perpllgrp */ + struct socfpga_clock_manager_per_pll per_pll; + struct socfpga_clock_manager_altera altera; +}; + +void cm_use_intosc(void); +unsigned int cm_get_noc_clk_hz(void); +unsigned int cm_get_l4_noc_hz(unsigned int nocdivshift); +int cm_basic_init(const void *blob); + +unsigned int cm_get_l4_sp_clk_hz(void); +unsigned int cm_get_main_vco_clk_hz(void); +unsigned int cm_get_per_vco_clk_hz(void); +unsigned long cm_get_mpu_clk_hz(void); + +unsigned int cm_get_qspi_controller_clk_hz(void); +unsigned int cm_get_mmc_controller_clk_hz(void); +unsigned int cm_get_spi_controller_clk_hz(void); + +#endif /* __ASSEMBLER__ */ + +#define CLKMGR_ALTERAGRP_MPU_CLK_OFFSET 0x140 +#define CLKMGR_MAINPLL_NOC_CLK_OFFSET 0x144 +#define LOCKED_MASK (CLKMGR_CLKMGR_STAT_MAINPLLLOCKED_SET_MSK | \ + CLKMGR_CLKMGR_STAT_PERPLLLOCKED_SET_MSK) + +/* value */ +#define CLKMGR_MAINPLL_BYPASS_RESET 0x0000003f +#define CLKMGR_PERPLL_BYPASS_RESET 0x000000ff +#define CLKMGR_MAINPLL_VCO0_RESET 0x00010053 +#define CLKMGR_MAINPLL_VCO1_RESET 0x00010001 +#define CLKMGR_PERPLL_VCO0_RESET 0x00010053 +#define CLKMGR_PERPLL_VCO1_RESET 0x00010001 +#define CLKMGR_MAINPLL_VCO0_PSRC_EOSC 0x0 +#define CLKMGR_MAINPLL_VCO0_PSRC_E_INTOSC 0x1 +#define CLKMGR_MAINPLL_VCO0_PSRC_F2S 0x2 +#define CLKMGR_PERPLL_VCO0_PSRC_EOSC 0x0 +#define CLKMGR_PERPLL_VCO0_PSRC_E_INTOSC 0x1 +#define CLKMGR_PERPLL_VCO0_PSRC_F2S 0x2 +#define CLKMGR_PERPLL_VCO0_PSRC_MAIN 0x3 + +/* mask */ +#define CLKMGR_MAINPLL_EN_S2FUSER0CLKEN_SET_MSK BIT(6) +#define CLKMGR_MAINPLL_EN_HMCPLLREFCLKEN_SET_MSK BIT(7) +#define CLKMGR_CLKMGR_STAT_MAINPLLLOCKED_SET_MSK BIT(8) +#define CLKMGR_CLKMGR_STAT_PERPLLLOCKED_SET_MSK BIT(9) +#define CLKMGR_CLKMGR_STAT_BOOTCLKSRC_SET_MSK BIT(17) +#define CLKMGR_MAINPLL_VCO0_BGPWRDN_SET_MSK BIT(0) +#define CLKMGR_MAINPLL_VCO0_PWRDN_SET_MSK BIT(1) +#define CLKMGR_MAINPLL_VCO0_EN_SET_MSK BIT(2) +#define CLKMGR_MAINPLL_VCO0_OUTRSTALL_SET_MSK BIT(3) +#define CLKMGR_MAINPLL_VCO0_REGEXTSEL_SET_MSK BIT(4) +#define CLKMGR_PERPLL_VCO0_BGPWRDN_SET_MSK BIT(0) +#define CLKMGR_PERPLL_VCO0_PWRDN_SET_MSK BIT(1) +#define CLKMGR_PERPLL_VCO0_EN_SET_MSK BIT(2) +#define CLKMGR_PERPLL_VCO0_OUTRSTALL_SET_MSK BIT(3) +#define CLKMGR_PERPLL_VCO0_REGEXTSEL_SET_MSK BIT(4) +#define CLKMGR_CLKMGR_INTR_MAINPLLACHIEVED_SET_MSK BIT(0) +#define CLKMGR_CLKMGR_INTR_PERPLLACHIEVED_SET_MSK BIT(1) +#define CLKMGR_CLKMGR_INTR_MAINPLLLOST_SET_MSK BIT(2) +#define CLKMGR_CLKMGR_INTR_PERPLLLOST_SET_MSK BIT(3) +#define CLKMGR_CLKMGR_INTR_MAINPLLRFSLIP_SET_MSK BIT(8) +#define CLKMGR_CLKMGR_INTR_PERPLLRFSLIP_SET_MSK BIT(9) +#define CLKMGR_CLKMGR_INTR_MAINPLLFBSLIP_SET_MSK BIT(10) +#define CLKMGR_CLKMGR_INTR_PERPLLFBSLIP_SET_MSK BIT(11) +#define CLKMGR_CLKMGR_CTL_BOOTMOD_SET_MSK BIT(0) +#define CLKMGR_CLKMGR_CTL_BOOTCLK_INTOSC_SET_MSK 0x00000300 +#define CLKMGR_PERPLL_EN_RESET 0x00000f7f +#define CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK BIT(5) +#define CLKMGR_MAINPLL_VCO0_PSRC_MSK 0x00000003 +#define CLKMGR_MAINPLL_VCO1_NUMER_MSK 0x00001fff +#define CLKMGR_MAINPLL_VCO1_DENOM_MSK 0x0000003f +#define CLKMGR_MAINPLL_CNTRCLK_MSK 0x000003ff +#define CLKMGR_PERPLL_VCO0_PSRC_MSK 0x00000003 +#define CLKMGR_PERPLL_VCO1_NUMER_MSK 0x00001fff +#define CLKMGR_PERPLL_VCO1_DENOM_MSK 0x0000003f +#define CLKMGR_PERPLL_CNTRCLK_MSK 0x000003ff +#define CLKMGR_MAINPLL_MPUCLK_SRC_MSK 0x00000007 +#define CLKMGR_MAINPLL_MPUCLK_CNT_MSK 0x000003ff +#define CLKMGR_MAINPLL_MPUCLK_SRC_MAIN 0 +#define CLKMGR_MAINPLL_MPUCLK_SRC_PERI 1 +#define CLKMGR_MAINPLL_MPUCLK_SRC_OSC1 2 +#define CLKMGR_MAINPLL_MPUCLK_SRC_INTOSC 3 +#define CLKMGR_MAINPLL_MPUCLK_SRC_FPGA 4 +#define CLKMGR_MAINPLL_NOCDIV_MSK 0x00000003 +#define CLKMGR_MAINPLL_NOCCLK_CNT_MSK 0x000003ff +#define CLKMGR_MAINPLL_NOCCLK_SRC_MSK 0x00000007 +#define CLKMGR_MAINPLL_NOCCLK_SRC_MAIN 0 +#define CLKMGR_MAINPLL_NOCCLK_SRC_PERI 1 +#define CLKMGR_MAINPLL_NOCCLK_SRC_OSC1 2 +#define CLKMGR_MAINPLL_NOCCLK_SRC_INTOSC 3 +#define CLKMGR_MAINPLL_NOCCLK_SRC_FPGA 4 + +#define CLKMGR_PERPLLGRP_SRC_MSK 0x00000007 +#define CLKMGR_PERPLLGRP_SRC_MAIN 0 +#define CLKMGR_PERPLLGRP_SRC_PERI 1 +#define CLKMGR_PERPLLGRP_SRC_OSC1 2 +#define CLKMGR_PERPLLGRP_SRC_INTOSC 3 +#define CLKMGR_PERPLLGRP_SRC_FPGA 4 + +/* bit shifting macro */ +#define CLKMGR_MAINPLL_VCO0_PSRC_LSB 8 +#define CLKMGR_PERPLL_VCO0_PSRC_LSB 8 +#define CLKMGR_MAINPLL_VCO1_DENOM_LSB 16 +#define CLKMGR_PERPLL_VCO1_DENOM_LSB 16 +#define CLKMGR_MAINPLL_NOCCLK_PERICNT_LSB 16 +#define CLKMGR_MAINPLL_NOCCLK_SRC_LSB 16 +#define CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LSB 0 +#define CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB 8 +#define CLKMGR_MAINPLL_NOCDIV_L4SPCLK_LSB 16 +#define CLKMGR_MAINPLL_NOCDIV_CSATCLK_LSB 24 +#define CLKMGR_MAINPLL_NOCDIV_CSTRACECLK_LSB 26 +#define CLKMGR_MAINPLL_NOCDIV_CSPDBGCLK_LSB 28 +#define CLKMGR_MAINPLL_MPUCLK_SRC_LSB 16 +#define CLKMGR_MAINPLL_MPUCLK_PERICNT_LSB 16 +#define CLKMGR_MAINPLL_NOCCLK_SRC_LSB 16 +#define CLKMGR_MAINPLL_CNTR7CLK_SRC_LSB 16 +#define CLKMGR_MAINPLL_CNTR9CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR2CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR3CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR4CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR5CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR6CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR8CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_EMACCTL_EMAC0SEL_LSB 26 +#define CLKMGR_PERPLL_EMACCTL_EMAC1SEL_LSB 27 +#define CLKMGR_PERPLL_EMACCTL_EMAC2SEL_LSB 28 + +/* PLL ramping work around */ +#define CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ 900000000 +#define CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ 300000000 +#define CLKMGR_PLL_RAMP_MPUCLK_INCREMENT_HZ 100000000 +#define CLKMGR_PLL_RAMP_NOCCLK_INCREMENT_HZ 33000000 + +#define CLKMGR_STAT_BUSY BIT(0) + +#endif /* CLOCK_MANAGER_ARRIA10 */
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com
^ what's this "conflicts" about ?
It was leave over from git rebase, will remove it.
Regards Ley Foon
Add system manager register struct and macros for Arria 10.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- .../arm/mach-socfpga/include/mach/system_manager.h | 74 +++++++++++++++++--- .../include/mach/system_manager_arria10.h | 81 ++++++++++++++++++++++ 2 files changed, 144 insertions(+), 11 deletions(-) create mode 100644 arch/arm/mach-socfpga/include/mach/system_manager_arria10.h
diff --git a/arch/arm/mach-socfpga/include/mach/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager.h index 30f0bbe..e6d4280 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager.h @@ -7,18 +7,18 @@ #ifndef _SYSTEM_MANAGER_H_ #define _SYSTEM_MANAGER_H_
-#define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGPINMUX (1 << 0) -#define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO (1 << 1) -#define SYSMGR_ECC_OCRAM_EN (1 << 0) -#define SYSMGR_ECC_OCRAM_SERR (1 << 3) -#define SYSMGR_ECC_OCRAM_DERR (1 << 4) +#define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGPINMUX BIT(0) +#define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO BIT(1) +#define SYSMGR_ECC_OCRAM_EN BIT(0) +#define SYSMGR_ECC_OCRAM_SERR BIT(3) +#define SYSMGR_ECC_OCRAM_DERR BIT(4) #define SYSMGR_FPGAINTF_USEFPGA 0x1 -#define SYSMGR_FPGAINTF_SPIM0 (1 << 0) -#define SYSMGR_FPGAINTF_SPIM1 (1 << 1) -#define SYSMGR_FPGAINTF_EMAC0 (1 << 2) -#define SYSMGR_FPGAINTF_EMAC1 (1 << 3) -#define SYSMGR_FPGAINTF_NAND (1 << 4) -#define SYSMGR_FPGAINTF_SDMMC (1 << 5) +#define SYSMGR_FPGAINTF_SPIM0 BIT(0) +#define SYSMGR_FPGAINTF_SPIM1 BIT(1) +#define SYSMGR_FPGAINTF_EMAC0 BIT(2) +#define SYSMGR_FPGAINTF_EMAC1 BIT(3) +#define SYSMGR_FPGAINTF_NAND BIT(4) +#define SYSMGR_FPGAINTF_SDMMC BIT(5)
#define SYSMGR_SDMMC_DRVSEL_SHIFT 0
@@ -31,8 +31,60 @@ #define SYSMGR_EMACGRP_CTRL_PHYSEL1_LSB 2 #define SYSMGR_EMACGRP_CTRL_PHYSEL_MASK 0x3
+/* For dedicated IO configuration */ +/* Voltage select enums */ +#define VOLTAGE_SEL_3V 0x0 +#define VOLTAGE_SEL_1P8V 0x1 +#define VOLTAGE_SEL_2P5V 0x2 + +/* Input buffer enable */ +#define INPUT_BUF_DISABLE 0 +#define INPUT_BUF_1P8V 1 +#define INPUT_BUF_2P5V3V 2 + +/* Weak pull up enable */ +#define WK_PU_DISABLE 0 +#define WK_PU_ENABLE 1 + +/* Pull up slew rate control */ +#define PU_SLW_RT_SLOW 0 +#define PU_SLW_RT_FAST 1 +#define PU_SLW_RT_DEFAULT PU_SLW_RT_SLOW + +/* Pull down slew rate control */ +#define PD_SLW_RT_SLOW 0 +#define PD_SLW_RT_FAST 1 +#define PD_SLW_RT_DEFAULT PD_SLW_RT_SLOW + +/* Drive strength control */ +#define PU_DRV_STRG_DEFAULT 0x10 +#define PD_DRV_STRG_DEFAULT 0x10 + +/* bit position */ +#define PD_DRV_STRG_LSB 0 +#define PD_SLW_RT_LSB 5 +#define PU_DRV_STRG_LSB 8 +#define PU_SLW_RT_LSB 13 +#define WK_PU_LSB 16 +#define INPUT_BUF_LSB 17 +#define BIAS_TRIM_LSB 19 +#define VOLTAGE_SEL_LSB 0 + +#define ALT_SYSMGR_NOC_H2F_SET_MSK BIT(0) +#define ALT_SYSMGR_NOC_LWH2F_SET_MSK BIT(4) +#define ALT_SYSMGR_NOC_F2H_SET_MSK BIT(8) +#define ALT_SYSMGR_NOC_F2SDR0_SET_MSK BIT(16) +#define ALT_SYSMGR_NOC_F2SDR1_SET_MSK BIT(20) +#define ALT_SYSMGR_NOC_F2SDR2_SET_MSK BIT(24) +#define ALT_SYSMGR_NOC_TMO_EN_SET_MSK BIT(0) + +#define ALT_SYSMGR_ECC_INTSTAT_SERR_OCRAM_SET_MSK BIT(1) +#define ALT_SYSMGR_ECC_INTSTAT_DERR_OCRAM_SET_MSK BIT(1) + #if defined(CONFIG_TARGET_SOCFPGA_GEN5) #include <asm/arch/system_manager_gen5.h> +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#include <asm/arch/system_manager_arria10.h> #endif
#define SYSMGR_GET_BOOTINFO_BSEL(bsel) \ diff --git a/arch/arm/mach-socfpga/include/mach/system_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/system_manager_arria10.h new file mode 100644 index 0000000..f235aba --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/system_manager_arria10.h @@ -0,0 +1,81 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _SYSTEM_MANAGER_ARRIA10_H_ +#define _SYSTEM_MANAGER_ARRIA10_H_ + +struct socfpga_system_manager { + u32 siliconid1; + u32 siliconid2; + u32 wddbg; + u32 bootinfo; + u32 mpu_ctrl_l2_ecc; + u32 _pad_0x14_0x1f[3]; + u32 dma; + u32 dma_periph; + u32 sdmmcgrp_ctrl; + u32 sdmmc_l3master; + u32 nand_bootstrap; + u32 nand_l3master; + u32 usb0_l3master; + u32 usb1_l3master; + u32 emac_global; + u32 emac[3]; + u32 _pad_0x50_0x5f[4]; + u32 fpgaintf_en_global; + u32 fpgaintf_en_0; + u32 fpgaintf_en_1; + u32 fpgaintf_en_2; + u32 fpgaintf_en_3; + u32 _pad_0x74_0x7f[3]; + u32 noc_addr_remap_value; + u32 noc_addr_remap_set; + u32 noc_addr_remap_clear; + u32 _pad_0x8c_0x8f; + u32 ecc_intmask_value; + u32 ecc_intmask_set; + u32 ecc_intmask_clr; + u32 ecc_intstatus_serr; + u32 ecc_intstatus_derr; + u32 mpu_status_l2_ecc; + u32 mpu_clear_l2_ecc; + u32 mpu_status_l1_parity; + u32 mpu_clear_l1_parity; + u32 mpu_set_l1_parity; + u32 _pad_0xb8_0xbf[2]; + u32 noc_timeout; + u32 noc_idlereq_set; + u32 noc_idlereq_clr; + u32 noc_idlereq_value; + u32 noc_idleack; + u32 noc_idlestatus; + u32 fpga2soc_ctrl; + u32 _pad_0xdc_0xff[9]; + u32 tsmc_tsel_0; + u32 tsmc_tsel_1; + u32 tsmc_tsel_2; + u32 tsmc_tsel_3; + u32 _pad_0x110_0x200[60]; + u32 romhw_ctrl; + u32 romcode_ctrl; + u32 romcode_cpu1startaddr; + u32 romcode_initswstate; + u32 romcode_initswlastld; + u32 _pad_0x214_0x217; + u32 warmram_enable; + u32 warmram_datastart; + u32 warmram_length; + u32 warmram_execution; + u32 warmram_crc; + u32 _pad_0x22c_0x22f; + u32 isw_handoff[8]; + u32 romcode_bootromswstate[8]; +}; + +#define SYSMGR_SDMMC_SMPLSEL_SHIFT 4 +#define SYSMGR_BOOTINFO_BSEL_SHIFT 12 + +#endif /* _SYSTEM_MANAGER_ARRIA10_H_ */
Add sdram header file for Arria 10.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/include/mach/sdram_arria10.h | 380 +++++++++++++++++++++ 1 file changed, 380 insertions(+) create mode 100644 arch/arm/mach-socfpga/include/mach/sdram_arria10.h
diff --git a/arch/arm/mach-socfpga/include/mach/sdram_arria10.h b/arch/arm/mach-socfpga/include/mach/sdram_arria10.h new file mode 100644 index 0000000..1d7b7c1 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/sdram_arria10.h @@ -0,0 +1,380 @@ +/* + * Copyright (C) 2015-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _SOCFPGA_SDRAM_ARRIA10_H_ +#define _SOCFPGA_SDRAM_ARRIA10_H_ + +#ifndef __ASSEMBLY__ + +struct socfpga_ecc_hmc { + u32 ip_rev_id; + u32 _pad_0x4_0x7; + u32 ddrioctrl; + u32 ddrcalstat; + u32 mpr_0beat1; + u32 mpr_1beat1; + u32 mpr_2beat1; + u32 mpr_3beat1; + u32 mpr_4beat1; + u32 mpr_5beat1; + u32 mpr_6beat1; + u32 mpr_7beat1; + u32 mpr_8beat1; + u32 mpr_0beat2; + u32 mpr_1beat2; + u32 mpr_2beat2; + u32 mpr_3beat2; + u32 mpr_4beat2; + u32 mpr_5beat2; + u32 mpr_6beat2; + u32 mpr_7beat2; + u32 mpr_8beat2; + u32 _pad_0x58_0x5f[2]; + u32 auto_precharge; + u32 _pad_0x64_0xff[39]; + u32 eccctrl; + u32 eccctrl2; + u32 _pad_0x108_0x10f[2]; + u32 errinten; + u32 errintens; + u32 errintenr; + u32 intmode; + u32 intstat; + u32 diaginttest; + u32 modstat; + u32 derraddra; + u32 serraddra; + u32 _pad_0x134_0x137; + u32 autowb_corraddr; + u32 serrcntreg; + u32 autowb_drop_cntreg; + u32 _pad_0x144_0x147; + u32 ecc_reg2wreccdatabus; + u32 ecc_rdeccdata2regbus; + u32 ecc_reg2rdeccdatabus; + u32 _pad_0x154_0x15f[3]; + u32 ecc_diagon; + u32 ecc_decstat; + u32 _pad_0x168_0x16f[2]; + u32 ecc_errgenaddr_0; + u32 ecc_errgenaddr_1; + u32 ecc_errgenaddr_2; + u32 ecc_errgenaddr_3; +}; + +struct socfpga_noc_ddr_scheduler { + u32 ddr_t_main_scheduler_id_coreid; + u32 ddr_t_main_scheduler_id_revisionid; + u32 ddr_t_main_scheduler_ddrconf; + u32 ddr_t_main_scheduler_ddrtiming; + u32 ddr_t_main_scheduler_ddrmode; + u32 ddr_t_main_scheduler_readlatency; + u32 _pad_0x20_0x34[8]; + u32 ddr_t_main_scheduler_activate; + u32 ddr_t_main_scheduler_devtodev; +}; + +/* + * OCRAM firewall + */ +struct socfpga_noc_fw_ocram { + u32 enable; + u32 enable_set; + u32 enable_clear; + u32 region0; + u32 region1; + u32 region2; + u32 region3; + u32 region4; + u32 region5; +}; + +/* for master such as MPU and FPGA */ +struct socfpga_noc_fw_ddr_mpu_fpga2sdram { + u32 enable; + u32 enable_set; + u32 enable_clear; + u32 _pad_0xc_0xf; + u32 mpuregion0addr; + u32 mpuregion1addr; + u32 mpuregion2addr; + u32 mpuregion3addr; + u32 fpga2sdram0region0addr; + u32 fpga2sdram0region1addr; + u32 fpga2sdram0region2addr; + u32 fpga2sdram0region3addr; + u32 fpga2sdram1region0addr; + u32 fpga2sdram1region1addr; + u32 fpga2sdram1region2addr; + u32 fpga2sdram1region3addr; + u32 fpga2sdram2region0addr; + u32 fpga2sdram2region1addr; + u32 fpga2sdram2region2addr; + u32 fpga2sdram2region3addr; +}; + +/* for L3 master */ +struct socfpga_noc_fw_ddr_l3 { + u32 enable; + u32 enable_set; + u32 enable_clear; + u32 hpsregion0addr; + u32 hpsregion1addr; + u32 hpsregion2addr; + u32 hpsregion3addr; + u32 hpsregion4addr; + u32 hpsregion5addr; + u32 hpsregion6addr; + u32 hpsregion7addr; +}; + +struct socfpga_io48_mmr { + u32 dbgcfg0; + u32 dbgcfg1; + u32 dbgcfg2; + u32 dbgcfg3; + u32 dbgcfg4; + u32 dbgcfg5; + u32 dbgcfg6; + u32 reserve0; + u32 reserve1; + u32 reserve2; + u32 ctrlcfg0; + u32 ctrlcfg1; + u32 ctrlcfg2; + u32 ctrlcfg3; + u32 ctrlcfg4; + u32 ctrlcfg5; + u32 ctrlcfg6; + u32 ctrlcfg7; + u32 ctrlcfg8; + u32 ctrlcfg9; + u32 dramtiming0; + u32 dramodt0; + u32 dramodt1; + u32 sbcfg0; + u32 sbcfg1; + u32 sbcfg2; + u32 sbcfg3; + u32 sbcfg4; + u32 sbcfg5; + u32 sbcfg6; + u32 sbcfg7; + u32 caltiming0; + u32 caltiming1; + u32 caltiming2; + u32 caltiming3; + u32 caltiming4; + u32 caltiming5; + u32 caltiming6; + u32 caltiming7; + u32 caltiming8; + u32 caltiming9; + u32 caltiming10; + u32 dramaddrw; + u32 sideband0; + u32 sideband1; + u32 sideband2; + u32 sideband3; + u32 sideband4; + u32 sideband5; + u32 sideband6; + u32 sideband7; + u32 sideband8; + u32 sideband9; + u32 sideband10; + u32 sideband11; + u32 sideband12; + u32 sideband13; + u32 sideband14; + u32 sideband15; + u32 dramsts; + u32 dbgdone; + u32 dbgsignals; + u32 dbgreset; + u32 dbgmatch; + u32 counter0mask; + u32 counter1mask; + u32 counter0match; + u32 counter1match; + u32 niosreserve0; + u32 niosreserve1; + u32 niosreserve2; +}; +#endif /*__ASSEMBLY__*/ + +#define IO48_MMR_CTRLCFG0_DB2_BURST_LENGTH_MASK 0x1F000000 +#define IO48_MMR_CTRLCFG0_DB2_BURST_LENGTH_SHIFT 24 +#define IO48_MMR_CTRLCFG0_DB1_BURST_LENGTH_MASK 0x00F80000 +#define IO48_MMR_CTRLCFG0_DB1_BURST_LENGTH_SHIFT 19 +#define IO48_MMR_CTRLCFG0_DB0_BURST_LENGTH_MASK 0x0007C000 +#define IO48_MMR_CTRLCFG0_DB0_BURST_LENGTH_SHIFT 14 +#define IO48_MMR_CTRLCFG0_CTRL_BURST_LENGTH_MASK 0x00003E00 +#define IO48_MMR_CTRLCFG0_CTRL_BURST_LENGTH_SHIFT 9 +#define IO48_MMR_CTRLCFG0_AC_POS_MASK 0x00000180 +#define IO48_MMR_CTRLCFG0_AC_POS_SHIFT 7 +#define IO48_MMR_CTRLCFG0_DIMM_TYPE_MASK 0x00000070 +#define IO48_MMR_CTRLCFG0_DIM_TYPE_SHIFT 4 +#define IO48_MMR_CTRLCFG0_MEM_TYPE_MASK 0x0000000F +#define IO48_MMR_CTRLCFG0_MEM_TYPE_SHIFT 0 + +#define IO48_MMR_CTRLCFG1_DBC3_ENABLE_DM BIT(30) +#define IO48_MMR_CTRLCFG1_DBC2_ENABLE_DM BIT(29) +#define IO48_MMR_CTRLCFG1_DBC1_ENABLE_DM BIT(28) +#define IO48_MMR_CTRLCFG1_DBC0_ENABLE_DM BIT(27) +#define IO48_MMR_CTRLCFG1_CTRL_ENABLE_DM BIT(26) +#define IO48_MMR_CTRLCFG1_DQSTRK_EN BIT(25) +#define IO48_MMR_CTRLCFG1_STARVE_LIMIT_MASK 0x01F80000 +#define IO48_MMR_CTRLCFG1_STARVE_LIMIT_SHIFT 19 +#define IO48_MMR_CTRLCFG1_REORDER_READ BIT(18) +#define IO48_MMR_CTRLCFG1_DBC3_REORDER_RDATA BIT(17) +#define IO48_MMR_CTRLCFG1_DBC2_REORDER_RDATA BIT(16) +#define IO48_MMR_CTRLCFG1_DBC1_REORDER_RDATA BIT(15) +#define IO48_MMR_CTRLCFG1_DBC0_REORDER_RDATA BIT(14) +#define IO48_MMR_CTRLCFG1_CTRL_REORDER_RDATA BIT(13) +#define IO48_MMR_CTRLCFG1_REORDER_DATA BIT(12) +#define IO48_MMR_CTRLCFG1_DBC3_ENABLE_ECC BIT(11) +#define IO48_MMR_CTRLCFG1_DBC2_ENABLE_ECC BIT(10) +#define IO48_MMR_CTRLCFG1_DBC1_ENABLE_ECC BIT(9) +#define IO48_MMR_CTRLCFG1_DBC0_ENABLE_ECC BIT(8) +#define IO48_MMR_CTRLCFG1_CTRL_ENABLE_ECC BIT(7) +#define IO48_MMR_CTRLCFG1_ADDR_ORDER_MASK 0x00000060 +#define IO48_MMR_CTRLCFG1_ADDR_ORDER_SHIFT 5 +#define IO48_MMR_CTRLCFG1_DBC3_BURST_LENGTH_MASK 0x0000001F +#define IO48_MMR_CTRLCFG1_DBC3_BURST_LENGTH_SHIFT 0 + +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_DIFF_BG_MASK 0x3F000000 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_DIFF_BG_SHIFT 24 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_DIFF_BANK_MASK 0x00FC0000 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_DIFF_BANK_SHIFT 18 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_MASK 0x0003F000 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_SHIFT 12 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_PCH_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_PCH_SHIFT 6 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_RDWR_MASK 0x0000003F +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_RDWR_SHIFT 0 + +#define IO48_MMR_CALTIMING1_CFG_RD_TO_WR_DIFF_CHIP_MASK 0x3F000000 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_WR_DIFF_CHIP_SHIFT 24 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_WR_MASK 0x00FC0000 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_WR_SHIFT 18 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_DB_MASK 0x0003F000 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_DB_SHIFT 12 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_DC_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_DC_SHIFT 6 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_MASK 0x0000003F +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_SHIFT 0 + +#define IO48_MMR_CALTIMING2_CFG_WR_TO_WR_DIFF_CHIP_MASK 0x3F000000 +#define IO48_MMR_CALTIMING2_CFG_WR_TO_WR_DIFF_CHIP_SHIFT 24 +#define IO48_MMR_CALTIMING2_CFG_WR_TO_WR_MASK 0x00FC0000 +#define IO48_MMR_CALTIMING2_CFG_WR_TO_WR_SHIFT 18 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_AP_VALID_MASK 0x0003F000 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_AP_VALID_SHIFT 12 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_PCH_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_PCH_SHIFT 6 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_WR_DIFF_BG_MASK 0x0000003F +#define IO48_MMR_CALTIMING2_CFG_RD_TO_WR_DIFF_BG_SHIFT 0 + +#define IO48_MMR_CALTIMING3_CFG_WR_TO_PCH_MASK 0x3F000000 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_PCH_SHIFT 24 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_DIFF_BG_MASK 0x00FC0000 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_DIFF_BG_SHIFT 18 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_DIFF_CHIP_MASK 0x0003F000 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_DIFF_CHIP_SHIFT 12 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_SHIFT 6 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_WR_DIFF_BG_MASK 0x0000003F +#define IO48_MMR_CALTIMING3_CFG_WR_TO_WR_DIFF_BG_SHIFT 0 + +#define IO48_MMR_CALTIMING4_CFG_PDN_TO_VALID_MASK 0xFC000000 +#define IO48_MMR_CALTIMING4_CFG_PDN_TO_VALID_SHIFT 26 +#define IO48_MMR_CALTIMING4_CFG_ARF_TO_VALID_MASK 0x03FC0000 +#define IO48_MMR_CALTIMING4_CFG_ARF_TO_VALID_SHIFT 18 +#define IO48_MMR_CALTIMING4_CFG_PCH_ALL_TO_VALID_MASK 0x0003F000 +#define IO48_MMR_CALTIMING4_CFG_PCH_ALL_TO_VALID_SHIFT 12 +#define IO48_MMR_CALTIMING4_CFG_PCH_TO_VALID_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING4_CFG_PCH_TO_VALID_SHIFT 6 +#define IO48_MMR_CALTIMING4_CFG_WR_AP_TO_VALID_MASK 0x0000003F +#define IO48_MMR_CALTIMING4_CFG_WR_AP_TO_VALID_SHIFT 0 + +#define IO48_MMR_CALTIMING9_CFG_WR_4_ACT_TO_ACT_MASK 0x000000FF +#define IO48_MMR_CALTIMING9_CFG_WR_4_ACT_TO_ACT_SHIFT 0 + +#define IO48_MMR_DRAMADDRW_CFG_CS_ADDR_WIDTH_MASK 0x00070000 +#define IO48_MMR_DRAMADDRW_CFG_CS_ADDR_WIDTH_SHIFT 16 +#define IO48_MMR_DRAMADDRW_CFG_BANK_GROUP_ADDR_WIDTH_MASK 0x0000C000 +#define IO48_MMR_DRAMADDRW_CFG_BANK_GROUP_ADDR_WIDTH_SHIFT 14 +#define IO48_MMR_DRAMADDRW_CFG_BANK_ADDR_WIDTH_MASK 0x00003C00 +#define IO48_MMR_DRAMADDRW_CFG_BANK_ADDR_WIDTH_SHIFT 10 +#define IO48_MMR_DRAMADDRW_CFG_ROW_ADDR_WIDTH_MASK 0x000003E0 +#define IO48_MMR_DRAMADDRW_CFG_ROW_ADDR_WIDTH_SHIFT 5 +#define IO48_MMR_DRAMADDRW_CFG_COL_ADDR_WIDTH_MASK 0x0000001F +#define IO48_MMR_DRAMADDRW_CFG_COL_ADDR_WIDTH_SHIFT 0 + +#define ALT_ECC_HMC_OCP_DDRIOCTRL_IO_SIZE_MSK 0x00000003 + +#define ALT_ECC_HMC_OCP_INTSTAT_SERRPENA_SET_MSK BIT(0) +#define ALT_ECC_HMC_OCP_INTSTAT_DERRPENA_SET_MSK BIT(1) +#define ALT_ECC_HMC_OCP_ERRINTEN_SERRINTEN_SET_MSK BIT(0) +#define ALT_ECC_HMC_OCP_ERRINTEN_DERRINTEN_SET_MSK BIT(1) +#define ALT_ECC_HMC_OCP_INTMOD_INTONCMP_SET_MSK BIT(16) +#define ALT_ECC_HMC_OCP_ECCCTL_AWB_CNT_RST_SET_MSK BIT(16) +#define ALT_ECC_HMC_OCP_ECCCTL_CNT_RST_SET_MSK BIT(8) +#define ALT_ECC_HMC_OCP_ECCCTL_ECC_EN_SET_MSK BIT(0) +#define ALT_ECC_HMC_OCP_ECCCTL2_RMW_EN_SET_MSK BIT(8) +#define ALT_ECC_HMC_OCP_ECCCTL2_AWB_EN_SET_MSK BIT(0) + +#define ALT_ECC_HMC_OCP_SERRCNTREG_VALUE 8 + +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_ACTTOACT_LSB 0 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_RDTOMISS_LSB 6 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_WRTOMISS_LSB 12 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_BURSTLEN_LSB 18 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_RDTOWR_LSB 21 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_WRTORD_LSB 26 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_BWRATIO_LSB 31 + +#define ALT_NOC_MPU_DDR_T_SCHED_DDRMOD_AUTOPRECHARGE_LSB 0 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRMOD_BWRATIOEXTENDED_LSB 1 + +#define ALT_NOC_MPU_DDR_T_SCHED_ACTIVATE_RRD_LSB 0 +#define ALT_NOC_MPU_DDR_T_SCHED_ACTIVATE_FAW_LSB 4 +#define ALT_NOC_MPU_DDR_T_SCHED_ACTIVATE_FAWBANK_LSB 10 + +#define ALT_NOC_MPU_DDR_T_SCHED_DEVTODEV_BUSRDTORD_LSB 0 +#define ALT_NOC_MPU_DDR_T_SCHED_DEVTODEV_BUSRDTOWR_LSB 2 +#define ALT_NOC_MPU_DDR_T_SCHED_DEVTODEV_BUSWRTORD_LSB 4 + +#define ALT_NOC_FW_DDR_END_ADDR_LSB 16 +#define ALT_NOC_FW_DDR_ADDR_MASK 0xFFFF +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG0EN_SET_MSK BIT(0) +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG1EN_SET_MSK BIT(1) +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG2EN_SET_MSK BIT(2) +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG3EN_SET_MSK BIT(3) +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG4EN_SET_MSK BIT(4) +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG5EN_SET_MSK BIT(5) +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG6EN_SET_MSK BIT(6) +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG7EN_SET_MSK BIT(7) +#define ALT_NOC_FW_DDR_SCR_EN_MPUREG0EN_SET_MSK BIT(0) +#define ALT_NOC_FW_DDR_SCR_EN_MPUREG1EN_SET_MSK BIT(1) +#define ALT_NOC_FW_DDR_SCR_EN_MPUREG2EN_SET_MSK BIT(2) +#define ALT_NOC_FW_DDR_SCR_EN_MPUREG3EN_SET_MSK BIT(3) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG0EN_SET_MSK BIT(4) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG1EN_SET_MSK BIT(5) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG2EN_SET_MSK BIT(6) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG3EN_SET_MSK BIT(7) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG0EN_SET_MSK BIT(8) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG1EN_SET_MSK BIT(9) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG2EN_SET_MSK BIT(10) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG3EN_SET_MSK BIT(11) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG0EN_SET_MSK BIT(12) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG1EN_SET_MSK BIT(13) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG2EN_SET_MSK BIT(14) +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG3EN_SET_MSK BIT(15) + +#define ALT_IO48_DRAMTIME_MEM_READ_LATENCY_MASK 0x0000003F +#endif /* _SOCFPGA_SDRAM_ARRIA10_H_ */
Add misc support for Arria 10.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 1 + arch/arm/mach-socfpga/include/mach/misc.h | 6 + arch/arm/mach-socfpga/misc_arria10.c | 258 ++++++++++++++++++++++++++++++ 3 files changed, 265 insertions(+) create mode 100644 arch/arm/mach-socfpga/misc_arria10.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index c494930..9c4617f 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -11,6 +11,7 @@ obj-y += misc.o timer.o reset_manager.o clock_manager.o \ fpga_manager.o board.o
obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clock_manager_arria10.o \ + misc_arria10.o \ reset_manager_arria10.o
obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h index f344749..0b65783 100644 --- a/arch/arm/mach-socfpga/include/mach/misc.h +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -22,4 +22,10 @@ void socfpga_fpga_add(void); static inline void socfpga_fpga_add(void) {} #endif
+#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +unsigned int dedicated_uart_com_port(const void *blob); +unsigned int shared_uart_com_port(const void *blob); +unsigned int uart_com_port(const void *blob); +#endif + #endif /* _MISC_H_ */ diff --git a/arch/arm/mach-socfpga/misc_arria10.c b/arch/arm/mach-socfpga/misc_arria10.c new file mode 100644 index 0000000..a591a67 --- /dev/null +++ b/arch/arm/mach-socfpga/misc_arria10.c @@ -0,0 +1,258 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <altera.h> +#include <common.h> +#include <errno.h> +#include <fdtdec.h> +#include <miiphy.h> +#include <netdev.h> +#include <ns16550.h> +#include <watchdog.h> +#include <asm/arch/misc.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/sdram_arria10.h> +#include <asm/arch/system_manager.h> +#include <asm/arch/nic301.h> +#include <asm/io.h> +#include <asm/pl310.h> + +#define PINMUX_UART0_TX_SHARED_IO_OFFSET_Q1_3 0x08 +#define PINMUX_UART0_TX_SHARED_IO_OFFSET_Q2_11 0x58 +#define PINMUX_UART0_TX_SHARED_IO_OFFSET_Q3_3 0x68 +#define PINMUX_UART1_TX_SHARED_IO_OFFSET_Q1_7 0x18 +#define PINMUX_UART1_TX_SHARED_IO_OFFSET_Q3_7 0x78 +#define PINMUX_UART1_TX_SHARED_IO_OFFSET_Q4_3 0x98 + +DECLARE_GLOBAL_DATA_PTR; + +#if defined(CONFIG_SPL_BUILD) +static struct pl310_regs *const pl310 = + (struct pl310_regs *)CONFIG_SYS_PL310_BASE; +static const struct socfpga_noc_fw_ocram *noc_fw_ocram_base = + (void *)SOCFPGA_SDR_FIREWALL_OCRAM_ADDRESS; +#endif + +static struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; + +/* + * DesignWare Ethernet initialization + */ +#ifdef CONFIG_ETH_DESIGNWARE +void dwmac_deassert_reset(const unsigned int of_reset_id, + const u32 phymode) +{ + u32 reset; + + if (of_reset_id == EMAC0_RESET) { + reset = SOCFPGA_RESET(EMAC0); + } else if (of_reset_id == EMAC1_RESET) { + reset = SOCFPGA_RESET(EMAC1); + } else if (of_reset_id == EMAC2_RESET) { + reset = SOCFPGA_RESET(EMAC2); + } else { + printf("GMAC: Invalid reset ID (%i)!\n", of_reset_id); + return; + } + + clrsetbits_le32(&sysmgr_regs->emac[of_reset_id - EMAC0_RESET], + SYSMGR_EMACGRP_CTRL_PHYSEL_MASK, + phymode); + + /* Release the EMAC controller from reset */ + socfpga_per_reset(reset, 0); +} +#endif + +#if defined(CONFIG_SPL_BUILD) +/* ++ * This function initializes security policies to be consistent across ++ * all logic units in the Arria 10. ++ * ++ * The idea is to set all security policies to be normal, nonsecure ++ * for all units. ++ */ +static void initialize_security_policies(void) +{ + /* Put OCRAM in non-secure */ + writel(0x003f0000, &noc_fw_ocram_base->region0); + writel(0x1, &noc_fw_ocram_base->enable); +} + +int arch_early_init_r(void) +{ + initialize_security_policies(); + + /* Configure the L2 controller to make SDRAM start at 0 */ + writel(0x1, &pl310->pl310_addr_filter_start); + + /* assert reset to all except L4WD0 and L4TIMER0 */ + socfpga_per_reset_all(); + + /* configuring the clock based on handoff */ + /* TODO: Add call to cm_basic_init() */ + + /* Add device descriptor to FPGA device table */ + socfpga_fpga_add(); + return 0; +} +#else +int arch_early_init_r(void) +{ + return 0; +} +#endif + +/* + * This function looking the 1st encounter UART peripheral, + * and then return its offset of the dedicated/shared IO pin + * mux. offset value (zero and above). + */ +static int find_peripheral_uart(const void *blob, + int child, const char *node_name) +{ + int len; + fdt_addr_t base_addr = 0; + fdt_size_t size; + const u32 *cell; + u32 value, offset = 0; + + base_addr = fdtdec_get_addr_size(blob, child, "reg", &size); + if (base_addr != FDT_ADDR_T_NONE) { + cell = fdt_getprop(blob, child, "pinctrl-single,pins", + &len); + if (cell != NULL) { + for (; len > 0; len -= (2 * sizeof(u32))) { + offset = fdt32_to_cpu(*cell++); + value = fdt32_to_cpu(*cell++); + /* Found UART peripheral */ + if (value == 0x0D) + return offset; + } + } + } + return -EINVAL; +} + +/* + * This function looks up the 1st encounter UART peripheral, + * and then return its offset of the dedicated/shared IO pin + * mux. UART peripheral is found if the offset is not in negative + * value. + */ +static int is_peripheral_uart_true(const void *blob, + int node, const char *child_name) +{ + int child, len; + const char *node_name; + + child = fdt_first_subnode(blob, node); + + if (child < 0) + return -EINVAL; + + node_name = fdt_get_name(blob, child, &len); + + while (node_name) { + if (!strcmp(child_name, node_name)) + return find_peripheral_uart(blob, child, node_name); + + child = fdt_next_subnode(blob, child); + if (child < 0) + break; + + node_name = fdt_get_name(blob, child, &len); + } + + return -1; +} + +/* + * This function looking the 1st encounter UART dedicated IO peripheral, + * and then return based address of the 1st encounter UART dedicated + * IO peripheral. + */ +unsigned int dedicated_uart_com_port(const void *blob) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE); + if (node < 0) + return 0; + + if (is_peripheral_uart_true(blob, node, "dedicated") >= 0) + return SOCFPGA_UART1_ADDRESS; + + return 0; +} + +/* + * This function looking the 1st encounter UART shared IO peripheral, and then + * return based address of the 1st encounter UART shared IO peripheral. + */ +unsigned int shared_uart_com_port(const void *blob) +{ + int node, ret; + + node = fdtdec_next_compatible(blob, 0, + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE); + if (node < 0) + return 0; + + ret = is_peripheral_uart_true(blob, node, "shared"); + + if (ret == PINMUX_UART0_TX_SHARED_IO_OFFSET_Q1_3 || + ret == PINMUX_UART0_TX_SHARED_IO_OFFSET_Q2_11 || + ret == PINMUX_UART0_TX_SHARED_IO_OFFSET_Q3_3) + return SOCFPGA_UART0_ADDRESS; + else if (ret == PINMUX_UART1_TX_SHARED_IO_OFFSET_Q1_7 || + ret == PINMUX_UART1_TX_SHARED_IO_OFFSET_Q3_7 || + ret == PINMUX_UART1_TX_SHARED_IO_OFFSET_Q4_3) + return SOCFPGA_UART1_ADDRESS; + + return 0; +} + +/* + * This function looking the 1st encounter UART peripheral, and then return + * base address of the 1st encounter UART peripheral. + */ +unsigned int uart_com_port(const void *blob) +{ + unsigned int ret; + + ret = dedicated_uart_com_port(blob); + + if (ret) + return ret; + + return shared_uart_com_port(blob); +} + +/* + * Print CPU information + */ +#if defined(CONFIG_DISPLAY_CPUINFO) +int print_cpuinfo(void) +{ + const u32 bsel = + SYSMGR_GET_BOOTINFO_BSEL(readl(&sysmgr_regs->bootinfo)); + + puts("CPU: Altera SoCFPGA Arria 10\n"); + + printf("BOOT: %s\n", bsel_str[bsel].name); + return 0; +} +#endif + +#ifdef CONFIG_ARCH_MISC_INIT +int arch_misc_init(void) +{ + return 0; +} +#endif
Add pinmux support for Arria 10.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Makefile | 1 + arch/arm/mach-socfpga/include/mach/pinmux.h | 15 +++++ arch/arm/mach-socfpga/pinmux_arria10.c | 96 +++++++++++++++++++++++++++++ 3 files changed, 112 insertions(+) create mode 100644 arch/arm/mach-socfpga/include/mach/pinmux.h create mode 100644 arch/arm/mach-socfpga/pinmux_arria10.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 9c4617f..68d55e4 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -12,6 +12,7 @@ obj-y += misc.o timer.o reset_manager.o clock_manager.o \
obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clock_manager_arria10.o \ misc_arria10.o \ + pinmux_arria10.o \ reset_manager_arria10.o
obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o diff --git a/arch/arm/mach-socfpga/include/mach/pinmux.h b/arch/arm/mach-socfpga/include/mach/pinmux.h new file mode 100644 index 0000000..ba51d45 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/pinmux.h @@ -0,0 +1,15 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _PINMUX_H_ +#define _PINMUX_H_ + +#ifndef __ASSEMBLY__ +int config_dedicated_pins(const void *blob); +int config_pins(const void *blob, const char *pin_grp); +#endif + +#endif /* _PINMUX_H_ */ diff --git a/arch/arm/mach-socfpga/pinmux_arria10.c b/arch/arm/mach-socfpga/pinmux_arria10.c new file mode 100644 index 0000000..69d6a92 --- /dev/null +++ b/arch/arm/mach-socfpga/pinmux_arria10.c @@ -0,0 +1,96 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <asm/arch/pinmux.h> +#include <asm/io.h> +#include <common.h> +#include <fdtdec.h> + +static int do_pinctr_pin(const void *blob, int child, const char *node_name) +{ + int len; + fdt_addr_t base_addr; + fdt_size_t size; + const u32 *cell; + u32 offset, value; + + base_addr = fdtdec_get_addr_size(blob, child, "reg", &size); + if (base_addr != FDT_ADDR_T_NONE) { + cell = fdt_getprop(blob, child, "pinctrl-single,pins", &len); + if (!cell || len <= 0) + return -EFAULT; + + debug("%p %d\n", cell, len); + for (; len > 0; len -= (2 * sizeof(u32))) { + offset = fdt32_to_cpu(*cell++); + value = fdt32_to_cpu(*cell++); + debug("<0x%x 0x%x>\n", offset, value); + writel(value, base_addr + offset); + } + return 0; + } + return -EFAULT; +} + +static int do_pinctrl_pins(const void *blob, int node, const char *child_name) +{ + int child, len; + const char *node_name; + + child = fdt_first_subnode(blob, node); + + if (child < 0) + return -EINVAL; + + node_name = fdt_get_name(blob, child, &len); + + while (node_name) { + if (!strcmp(child_name, node_name)) + return do_pinctr_pin(blob, child, node_name); + + child = fdt_next_subnode(blob, child); + + if (child < 0) + break; + + node_name = fdt_get_name(blob, child, &len); + } + + return -EFAULT; +} + +int config_dedicated_pins(const void *blob) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE); + if (node < 0) + return -EINVAL; + + if (do_pinctrl_pins(blob, node, "dedicated_cfg")) + return -EFAULT; + + if (do_pinctrl_pins(blob, node, "dedicated")) + return -EFAULT; + + return 0; +} + +int config_pins(const void *blob, const char *pin_grp) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE); + if (node < 0) + return -EINVAL; + + if (do_pinctrl_pins(blob, node, pin_grp)) + return -EFAULT; + + return 0; +}
Add compatible strings for Intel Arria 10 SoCFPGA device.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- include/fdtdec.h | 8 ++++++++ lib/fdtdec.c | 8 ++++++++ 2 files changed, 16 insertions(+)
diff --git a/include/fdtdec.h b/include/fdtdec.h index d074478..2134701 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -155,6 +155,14 @@ enum fdt_compat_id { COMPAT_INTEL_BAYTRAIL_FSP_MDP, /* Intel FSP memory-down params */ COMPAT_INTEL_IVYBRIDGE_FSP, /* Intel Ivy Bridge FSP */ COMPAT_SUNXI_NAND, /* SUNXI NAND controller */ + COMPAT_ALTERA_SOCFPGA_CLK, /* SoCFPGA Clock initialization */ + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE, /* SoCFPGA pinctrl-single */ + COMPAT_ALTERA_SOCFPGA_H2F_BRG, /* SoCFPGA hps2fpga bridge */ + COMPAT_ALTERA_SOCFPGA_LWH2F_BRG, /* SoCFPGA lwhps2fpga bridge */ + COMPAT_ALTERA_SOCFPGA_F2H_BRG, /* SoCFPGA fpga2hps bridge */ + COMPAT_ALTERA_SOCFPGA_F2SDR0, /* SoCFPGA fpga2SDRAM0 bridge */ + COMPAT_ALTERA_SOCFPGA_F2SDR1, /* SoCFPGA fpga2SDRAM1 bridge */ + COMPAT_ALTERA_SOCFPGA_F2SDR2, /* SoCFPGA fpga2SDRAM2 bridge */
COMPAT_COUNT, }; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 81f47ef..ebe4a9a 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -66,6 +66,14 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(INTEL_BAYTRAIL_FSP_MDP, "intel,baytrail-fsp-mdp"), COMPAT(INTEL_IVYBRIDGE_FSP, "intel,ivybridge-fsp"), COMPAT(COMPAT_SUNXI_NAND, "allwinner,sun4i-a10-nand"), + COMPAT(ALTERA_SOCFPGA_CLK, "altr,clk-mgr"), + COMPAT(ALTERA_SOCFPGA_PINCTRL_SINGLE, "pinctrl-single"), + COMPAT(ALTERA_SOCFPGA_H2F_BRG, "altr,socfpga-hps2fpga-bridge"), + COMPAT(ALTERA_SOCFPGA_LWH2F_BRG, "altr,socfpga-lwhps2fpga-bridge"), + COMPAT(ALTERA_SOCFPGA_F2H_BRG, "altr,socfpga-fpga2hps-bridge"), + COMPAT(ALTERA_SOCFPGA_F2SDR0, "altr,socfpga-fpga2sdram0-bridge"), + COMPAT(ALTERA_SOCFPGA_F2SDR1, "altr,socfpga-fpga2sdram1-bridge"), + COMPAT(ALTERA_SOCFPGA_F2SDR2, "altr,socfpga-fpga2sdram2-bridge"), };
const char *fdtdec_get_compatible(enum fdt_compat_id id)
Device tree files for Arria 10
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_arria10.dtsi | 859 +++++++++++++++++++++ arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts | 30 + .../dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi | 481 ++++++++++++ 4 files changed, 1371 insertions(+) create mode 100644 arch/arm/dts/socfpga_arria10.dtsi create mode 100644 arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts create mode 100644 arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index eb68c20..25e08eb 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -139,6 +139,7 @@ dtb-$(CONFIG_AM43XX) += am437x-gp-evm.dtb am437x-sk-evm.dtb \ dtb-$(CONFIG_THUNDERX) += thunderx-88xx.dtb
dtb-$(CONFIG_ARCH_SOCFPGA) += \ + socfpga_arria10_socdk_sdmmc.dtb \ socfpga_arria5_socdk.dtb \ socfpga_cyclone5_is1.dtb \ socfpga_cyclone5_mcvevk.dtb \ diff --git a/arch/arm/dts/socfpga_arria10.dtsi b/arch/arm/dts/socfpga_arria10.dtsi new file mode 100644 index 0000000..52ab7fe --- /dev/null +++ b/arch/arm/dts/socfpga_arria10.dtsi @@ -0,0 +1,859 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 X11 + */ + +#include "skeleton.dtsi" +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/reset/altr,rst-mgr-a10.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + + aliases { + ethernet0 = &gmac0; + ethernet1 = &gmac1; + ethernet2 = &gmac2; + serial0 = &uart0; + serial1 = &uart1; + timer0 = &timer0; + timer1 = &timer1; + timer2 = &timer2; + timer3 = &timer3; + spi0 = &spi0; + spi1 = &spi1; + }; + + memory { + name = "memory"; + device_type = "memory"; + reg = <0x0 0x40000000>; /* 1GB */ + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <0>; + next-level-cache = <&L2>; + }; + cpu@1 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <1>; + next-level-cache = <&L2>; + }; + }; + + intc: intc@ffffd000 { + compatible = "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0xffffd000 0x1000>, + <0xffffc100 0x100>; + }; + + soc { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + device_type = "soc"; + interrupt-parent = <&intc>; + ranges; + + amba { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + pdma: pdma@ffda1000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0xffda1000 0x1000>; + interrupts = <0 83 IRQ_TYPE_LEVEL_HIGH>, + <0 84 IRQ_TYPE_LEVEL_HIGH>, + <0 85 IRQ_TYPE_LEVEL_HIGH>, + <0 86 IRQ_TYPE_LEVEL_HIGH>, + <0 87 IRQ_TYPE_LEVEL_HIGH>, + <0 88 IRQ_TYPE_LEVEL_HIGH>, + <0 89 IRQ_TYPE_LEVEL_HIGH>, + <0 90 IRQ_TYPE_LEVEL_HIGH>, + <0 91 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + #dma-channels = <8>; + #dma-requests = <32>; + clocks = <&l4_main_clk>; + clock-names = "apb_pclk"; + }; + }; + + clkmgr@ffd04000 { + compatible = "altr,clk-mgr"; + reg = <0xffd04000 0x1000>; + reg-names = "soc_clock_manager_OCP_SLV"; + + clocks { + #address-cells = <1>; + #size-cells = <0>; + + cb_intosc_hs_div2_clk: cb_intosc_hs_div2_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + cb_intosc_ls_clk: cb_intosc_ls_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + f2s_free_clk: f2s_free_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + osc1: osc1 { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + main_pll: main_pll { + #address-cells = <1>; + #size-cells = <0>; + #clock-cells = <0>; + compatible = "altr,socfpga-a10-pll-clock"; + clocks = <&osc1>, <&cb_intosc_ls_clk>, + <&f2s_free_clk>; + reg = <0x40>; + + main_mpu_base_clk: main_mpu_base_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + div-reg = <0x140 0 11>; + }; + + main_noc_base_clk: main_noc_base_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + div-reg = <0x144 0 11>; + }; + + main_emaca_clk: main_emaca_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x68>; + }; + + main_emacb_clk: main_emacb_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x6C>; + }; + + main_emac_ptp_clk: main_emac_ptp_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x70>; + }; + + main_gpio_db_clk: main_gpio_db_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x74>; + }; + + main_sdmmc_clk: main_sdmmc_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x78>; + }; + + main_s2f_usr0_clk: main_s2f_usr0_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x7C>; + }; + + main_s2f_usr1_clk: main_s2f_usr1_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x80>; + }; + + main_hmc_pll_ref_clk: main_hmc_pll_ref_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x84>; + }; + + main_periph_ref_clk: main_periph_ref_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x9C>; + }; + }; + + periph_pll: periph_pll { + #address-cells = <1>; + #size-cells = <0>; + #clock-cells = <0>; + compatible = "altr,socfpga-a10-pll-clock"; + clocks = <&osc1>, <&cb_intosc_ls_clk>, + <&f2s_free_clk>, <&main_periph_ref_clk>; + reg = <0xC0>; + + peri_mpu_base_clk: peri_mpu_base_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + div-reg = <0x140 16 11>; + }; + + peri_noc_base_clk: peri_noc_base_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + div-reg = <0x144 16 11>; + }; + + peri_emaca_clk: peri_emaca_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xE8>; + }; + + peri_emacb_clk: peri_emacb_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xEC>; + }; + + peri_emac_ptp_clk: peri_emac_ptp_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xF0>; + }; + + peri_gpio_db_clk: peri_gpio_db_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xF4>; + }; + + peri_sdmmc_clk: peri_sdmmc_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xF8>; + }; + + peri_s2f_usr0_clk: peri_s2f_usr0_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xFC>; + }; + + peri_s2f_usr1_clk: peri_s2f_usr1_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0x100>; + }; + + peri_hmc_pll_ref_clk: peri_hmc_pll_ref_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0x104>; + }; + }; + + mpu_free_clk: mpu_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_mpu_base_clk>, <&peri_mpu_base_clk>, + <&osc1>, <&cb_intosc_hs_div2_clk>, + <&f2s_free_clk>; + reg = <0x60>; + }; + + noc_free_clk: noc_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_noc_base_clk>, <&peri_noc_base_clk>, + <&osc1>, <&cb_intosc_hs_div2_clk>, + <&f2s_free_clk>; + reg = <0x64>; + }; + + s2f_user1_free_clk: s2f_user1_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_s2f_usr1_clk>, <&peri_s2f_usr1_clk>, + <&osc1>, <&cb_intosc_hs_div2_clk>, + <&f2s_free_clk>; + reg = <0x104>; + }; + + sdmmc_free_clk: sdmmc_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_sdmmc_clk>, <&peri_sdmmc_clk>, + <&osc1>, <&cb_intosc_hs_div2_clk>, + <&f2s_free_clk>; + fixed-divider = <4>; + reg = <0xF8>; + }; + + l4_sys_free_clk: l4_sys_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&noc_free_clk>; + fixed-divider = <4>; + }; + + l4_main_clk: l4_main_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&noc_free_clk>; + div-reg = <0xA8 0 2>; + clk-gate = <0x48 1>; + }; + + l4_mp_clk: l4_mp_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&noc_free_clk>; + div-reg = <0xA8 8 2>; + clk-gate = <0x48 2>; + }; + + l4_sp_clk: l4_sp_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&noc_free_clk>; + div-reg = <0xA8 16 2>; + clk-gate = <0x48 3>; + }; + + mpu_periph_clk: mpu_periph_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&mpu_free_clk>; + fixed-divider = <4>; + clk-gate = <0x48 0>; + }; + + sdmmc_clk: sdmmc_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&sdmmc_free_clk>; + clk-gate = <0xC8 5>; + clk-phase = <0 135>; + }; + + qspi_clk: qspi_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&l4_main_clk>; + clk-gate = <0xC8 11>; + }; + + nand_clk: nand_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&l4_mp_clk>; + clk-gate = <0xC8 10>; + }; + + spi_m_clk: spi_m_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&l4_main_clk>; + clk-gate = <0xC8 9>; + }; + + usb_clk: usb_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&l4_mp_clk>; + clk-gate = <0xC8 8>; + }; + + s2f_usr1_clk: s2f_usr1_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&peri_s2f_usr1_clk>; + clk-gate = <0xC8 6>; + }; + }; + }; + + gmac0: ethernet@ff800000 { + compatible = "altr,socfpga-stmmac", "snps,dwmac-3.72a", "snps,dwmac"; + altr,sysmgr-syscon = <&sysmgr 0x44 0>; + reg = <0xff800000 0x2000>; + interrupts = <0 92 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + /* Filled in by bootloader */ + mac-address = [00 00 00 00 00 00]; + snps,multicast-filter-bins = <256>; + snps,perfect-filter-entries = <128>; + tx-fifo-depth = <4096>; + rx-fifo-depth = <16384>; + clocks = <&l4_mp_clk>; + clock-names = "stmmaceth"; + resets = <&rst EMAC0_RESET>; + reset-names = "stmmaceth"; + status = "disabled"; + }; + + gmac1: ethernet@ff802000 { + compatible = "altr,socfpga-stmmac", "snps,dwmac-3.72a", "snps,dwmac"; + altr,sysmgr-syscon = <&sysmgr 0x48 0>; + reg = <0xff802000 0x2000>; + interrupts = <0 93 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + /* Filled in by bootloader */ + mac-address = [00 00 00 00 00 00]; + snps,multicast-filter-bins = <256>; + snps,perfect-filter-entries = <128>; + tx-fifo-depth = <4096>; + rx-fifo-depth = <16384>; + clocks = <&l4_mp_clk>; + clock-names = "stmmaceth"; + resets = <&rst EMAC1_RESET>; + reset-names = "stmmaceth"; + status = "disabled"; + }; + + gmac2: ethernet@ff804000 { + compatible = "altr,socfpga-stmmac", "snps,dwmac-3.72a", "snps,dwmac"; + altr,sysmgr-syscon = <&sysmgr 0x4C 0>; + reg = <0xff804000 0x2000>; + interrupts = <0 94 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + /* Filled in by bootloader */ + mac-address = [00 00 00 00 00 00]; + snps,multicast-filter-bins = <256>; + snps,perfect-filter-entries = <128>; + tx-fifo-depth = <4096>; + rx-fifo-depth = <16384>; + clocks = <&l4_mp_clk>; + clock-names = "stmmaceth"; + status = "disabled"; + }; + + gpio0: gpio@ffc02900 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0xffc02900 0x100>; + status = "disabled"; + + porta: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <29>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 112 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + gpio1: gpio@ffc02a00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0xffc02a00 0x100>; + status = "disabled"; + + portb: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <29>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 113 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + gpio2: gpio@ffc02b00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0xffc02b00 0x100>; + status = "disabled"; + + portc: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <27>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 114 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + fpga_mgr: fpga-mgr@ffd03000 { + compatible = "altr,socfpga-a10-fpga-mgr"; + reg = <0xffd03000 0x100 + 0xffcfe400 0x20>; + clocks = <&l4_mp_clk>; + resets = <&rst FPGAMGR_RESET>; + reset-names = "fpgamgr"; + }; + + i2c0: i2c@ffc02200 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02200 0x100>; + interrupts = <0 105 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + i2c1: i2c@ffc02300 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02300 0x100>; + interrupts = <0 106 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + i2c2: i2c@ffc02400 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02400 0x100>; + interrupts = <0 107 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + i2c3: i2c@ffc02500 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02500 0x100>; + interrupts = <0 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + i2c4: i2c@ffc02600 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02600 0x100>; + interrupts = <0 109 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + sdr: sdr@0xffcfb100 { + compatible = "syscon"; + reg = <0xffcfb100 0x80>; + }; + + spi0: spi@ffda4000 { + compatible = "snps,dw-apb-ssi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xffda4000 0x100>; + interrupts = <0 101 IRQ_TYPE_LEVEL_HIGH>; + num-chipselect = <4>; + bus-num = <0>; + tx-dma-channel = <&pdma 16>; + rx-dma-channel = <&pdma 17>; + clocks = <&spi_m_clk>; + status = "disabled"; + }; + + spi1: spi@ffda5000 { + compatible = "snps,dw-apb-ssi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xffda5000 0x100>; + interrupts = <0 102 IRQ_TYPE_LEVEL_HIGH>; + num-chipselect = <4>; + bus-num = <0>; + tx-dma-channel = <&pdma 20>; + rx-dma-channel = <&pdma 21>; + clocks = <&spi_m_clk>; + status = "disabled"; + }; + + L2: l2-cache@fffff000 { + compatible = "arm,pl310-cache"; + reg = <0xfffff000 0x1000>; + interrupts = <0 18 IRQ_TYPE_LEVEL_HIGH>; + cache-unified; + cache-level = <2>; + }; + + mmc: dwmmc0@ff808000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "altr,socfpga-dw-mshc"; + reg = <0xff808000 0x1000>; + interrupts = <0 98 IRQ_TYPE_LEVEL_HIGH>; + fifo-depth = <0x400>; + bus-width = <4>; + clocks = <&l4_mp_clk>, <&sdmmc_clk>; + clock-names = "biu", "ciu"; + status = "disabled"; + }; + + ocram: sram@ffe00000 { + compatible = "mmio-sram"; + reg = <0xffe00000 0x40000>; + }; + + eccmgr: eccmgr@ffd06000 { + compatible = "altr,socfpga-a10-ecc-manager"; + altr,sysmgr-syscon = <&sysmgr>; + #address-cells = <1>; + #size-cells = <1>; + interrupts = <0 2 IRQ_TYPE_LEVEL_HIGH>, + <0 0 IRQ_TYPE_LEVEL_HIGH>; + interrupt-controller; + #interrupt-cells = <2>; + ranges; + + sdramedac { + compatible = "altr,sdram-edac-a10"; + altr,sdr-syscon = <&sdr>; + interrupts = <17 IRQ_TYPE_LEVEL_HIGH>, + <49 IRQ_TYPE_LEVEL_HIGH>; + }; + + l2-ecc@ffd06010 { + compatible = "altr,socfpga-a10-l2-ecc"; + reg = <0xffd06010 0x4>; + interrupts = <0 IRQ_TYPE_LEVEL_HIGH>, + <32 IRQ_TYPE_LEVEL_HIGH>; + }; + + ocram-ecc@ff8c3000 { + compatible = "altr,socfpga-a10-ocram-ecc"; + reg = <0xff8c3000 0x400>; + interrupts = <1 IRQ_TYPE_LEVEL_HIGH>, + <33 IRQ_TYPE_LEVEL_HIGH>; + }; + + sdmmca-ecc@ff8c2c00 { + compatible = "altr,socfpga-sdmmc-ecc"; + reg = <0xff8c2c00 0x400>; + altr,ecc-parent = <&mmc>; + interrupts = <15 IRQ_TYPE_LEVEL_HIGH>, + <47 IRQ_TYPE_LEVEL_HIGH>, + <16 IRQ_TYPE_LEVEL_HIGH>, + <48 IRQ_TYPE_LEVEL_HIGH>; + }; + + emac0-rx-ecc@ff8c0800 { + compatible = "altr,socfpga-eth-mac-ecc"; + reg = <0xff8c0800 0x400>; + altr,ecc-parent = <&gmac0>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH>, + <36 IRQ_TYPE_LEVEL_HIGH>; + }; + + emac0-tx-ecc@ff8c0c00 { + compatible = "altr,socfpga-eth-mac-ecc"; + reg = <0xff8c0c00 0x400>; + altr,ecc-parent = <&gmac0>; + interrupts = <5 IRQ_TYPE_LEVEL_HIGH>, + <37 IRQ_TYPE_LEVEL_HIGH>; + }; + + dma-ecc@ff8c8000 { + compatible = "altr,socfpga-dma-ecc"; + reg = <0xff8c8000 0x400>; + altr,ecc-parent = <&pdma>; + interrupts = <10 IRQ_TYPE_LEVEL_HIGH>, + <42 IRQ_TYPE_LEVEL_HIGH>; + }; + + usb0-ecc@ff8c8800 { + compatible = "altr,socfpga-usb-ecc"; + reg = <0xff8c8800 0x400>; + altr,ecc-parent = <&usb0>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH>, + <34 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + qspi: qspi@ff809000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "cadence,qspi"; + reg = <0xff809000 0x100>, + <0xffa00000 0x100000>; + interrupts = <0 100 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_main_clk>; + ext-decoder = <0>; /* external decoder */ + num-chipselect = <4>; + fifo-depth = <128>; + sram-size = <512>; + bus-num = <2>; + status = "disabled"; + }; + + rst: rstmgr@ffd05000 { + #reset-cells = <1>; + compatible = "altr,rst-mgr"; + reg = <0xffd05000 0x100>; + altr,modrst-offset = <0x20>; + }; + + scu: snoop-control-unit@ffffc000 { + compatible = "arm,cortex-a9-scu"; + reg = <0xffffc000 0x100>; + }; + + sysmgr: sysmgr@ffd06000 { + compatible = "altr,sys-mgr", "syscon"; + reg = <0xffd06000 0x300>; + cpu1-start-addr = <0xffd06230>; + }; + + /* Local timer */ + timer@ffffc600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0xffffc600 0x100>; + interrupts = <1 13 0xf04>; + clocks = <&mpu_periph_clk>; + }; + + timer0: timer0@ffc02700 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 115 IRQ_TYPE_LEVEL_HIGH>; + reg = <0xffc02700 0x100>; + clocks = <&l4_sp_clk>; + clock-names = "timer"; + }; + + timer1: timer1@ffc02800 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 116 IRQ_TYPE_LEVEL_HIGH>; + reg = <0xffc02800 0x100>; + clocks = <&l4_sp_clk>; + clock-names = "timer"; + }; + + timer2: timer2@ffd00000 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 117 IRQ_TYPE_LEVEL_HIGH>; + reg = <0xffd00000 0x100>; + clocks = <&l4_sys_free_clk>; + clock-names = "timer"; + }; + + timer3: timer3@ffd00100 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 118 IRQ_TYPE_LEVEL_HIGH>; + reg = <0xffd01000 0x100>; + clocks = <&l4_sys_free_clk>; + clock-names = "timer"; + }; + + uart0: serial0@ffc02000 { + compatible = "snps,dw-apb-uart"; + reg = <0xffc02000 0x100>; + interrupts = <0 110 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + uart1: serial1@ffc02100 { + compatible = "snps,dw-apb-uart"; + reg = <0xffc02100 0x100>; + interrupts = <0 111 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + usbphy0: usbphy@0 { + #phy-cells = <0>; + compatible = "usb-nop-xceiv"; + status = "okay"; + }; + + usb0: usb@ffb00000 { + compatible = "snps,dwc2"; + reg = <0xffb00000 0xffff>; + interrupts = <0 95 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&usb_clk>; + clock-names = "otg"; + resets = <&rst USB0_RESET>; + reset-names = "dwc2"; + phys = <&usbphy0>; + phy-names = "usb2-phy"; + status = "disabled"; + }; + + usb1: usb@ffb40000 { + compatible = "snps,dwc2"; + reg = <0xffb40000 0xffff>; + interrupts = <0 96 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&usb_clk>; + clock-names = "otg"; + resets = <&rst USB1_RESET>; + reset-names = "dwc2"; + phys = <&usbphy0>; + phy-names = "usb2-phy"; + status = "disabled"; + }; + + watchdog0: watchdog@ffd00200 { + compatible = "snps,dw-wdt"; + reg = <0xffd00200 0x100>; + interrupts = <0 119 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sys_free_clk>; + status = "disabled"; + }; + + watchdog1: watchdog@ffd00300 { + compatible = "snps,dw-wdt"; + reg = <0xffd00300 0x100>; + interrupts = <0 120 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sys_free_clk>; + status = "disabled"; + }; + }; +}; diff --git a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts new file mode 100644 index 0000000..a4215ee --- /dev/null +++ b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts @@ -0,0 +1,30 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 X11 + */ + +/dts-v1/; +#include "socfpga_arria10_socdk_sdmmc_handoff.dtsi" + +/ { + chosen { + bootargs = "console=ttyS0,115200"; + }; +}; + +&uart1 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&mmc { + u-boot,dm-pre-reloc; + status = "okay"; + num-slots = <1>; + cap-sd-highspeed; + broken-cd; + bus-width = <4>; + altr,dw-mshc-ciu-div = <3>; + altr,dw-mshc-sdr-timing = <0 3>; +}; diff --git a/arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi b/arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi new file mode 100644 index 0000000..d10e089 --- /dev/null +++ b/arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi @@ -0,0 +1,481 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 X11 + * + *<auto-generated> + * This code was generated by a tool based on + * handoffs from both Qsys and Quartus. + * + * Changes to this file may be lost if + * the code is regenerated. + *</auto-generated> + */ + +#include "socfpga_arria10.dtsi" + +/ { + model = "Altera SOCFPGA Arria 10"; + compatible = "altr,socfpga-arria10", "altr,socfpga"; + + chosen { + /* Bootloader setting: uboot.rbf_filename */ + cff-file = "ghrd_10as066n2.periph.rbf"; + early-release-fpga-config; + }; + + soc { + u-boot,dm-pre-reloc; + clkmgr@ffd04000 { + u-boot,dm-pre-reloc; + clocks { + u-boot,dm-pre-reloc; + osc1 { + u-boot,dm-pre-reloc; + clock-frequency = <25000000>; + clock-output-names = "altera_arria10_hps_eosc1-clk"; + }; + + cb_intosc_ls_clk { + u-boot,dm-pre-reloc; + clock-frequency = <60000000>; + clock-output-names = "altera_arria10_hps_cb_intosc_ls-clk"; + }; + + f2s_free_clk { + u-boot,dm-pre-reloc; + clock-frequency = <200000000>; + clock-output-names = "altera_arria10_hps_f2h_free-clk"; + }; + + main_pll { + u-boot,dm-pre-reloc; + /* + * Address Block: soc_clock_manager_OCP_SLV. + * i_clk_mgr_mainpllgrp + */ + altr,of_reg_value = < + 0 /* Field: vco0.psrc */ + 1 /* Field: vco1.denom */ + 191 /* Field: vco1.numer */ + 0 /* Field: mpuclk */ + 0 /* Field: mpuclk.cnt */ + 0 /* Field: mpuclk.src */ + 0 /* Field: nocclk */ + 0 /* Field: nocclk.cnt */ + 0 /* Field: nocclk.src */ + 900 /* Field: cntr2clk.cnt */ + 900 /* Field: cntr3clk.cnt */ + 900 /* Field: cntr4clk.cnt */ + 900 /* Field: cntr5clk.cnt */ + 900 /* Field: cntr6clk.cnt */ + 900 /* Field: cntr7clk.cnt */ + 0 /* Field: cntr7clk.src */ + 900 /* Field: cntr8clk.cnt */ + 900 /* Field: cntr9clk.cnt */ + 0 /* Field: cntr9clk.src */ + 900 /* Field: cntr15clk.cnt */ + 0 /* Field: nocdiv.l4mainclk */ + 0 /* Field: nocdiv.l4mpclk */ + 2 /* Field: nocdiv.l4spclk */ + 0 /* Field: nocdiv.csatclk */ + 1 /* Field: nocdiv.cstraceclk */ + 1 /* Field: nocdiv.cspdbgclk */ + >; + }; + + periph_pll { + u-boot,dm-pre-reloc; + /* + * Address Block: soc_clock_manager_OCP_SLV. + * i_clk_mgr_perpllgrp + */ + altr,of_reg_value = < + 0 /* Field: vco0.psrc */ + 1 /* Field: vco1.denom */ + 159 /* Field: vco1.numer */ + 7 /* Field: cntr2clk.cnt */ + 1 /* Field: cntr2clk.src */ + 900 /* Field: cntr3clk.cnt */ + 1 /* Field: cntr3clk.src */ + 19 /* Field: cntr4clk.cnt */ + 1 /* Field: cntr4clk.src */ + 499 /* Field: cntr5clk.cnt */ + 1 /* Field: cntr5clk.src */ + 9 /* Field: cntr6clk.cnt */ + 1 /* Field: cntr6clk.src */ + 900 /* Field: cntr7clk.cnt */ + 900 /* Field: cntr8clk.cnt */ + 0 /* Field: cntr8clk.src */ + 900 /* Field: cntr9clk.cnt */ + 0 /* Field: emacctl.emac0sel */ + 0 /* Field: emacctl.emac1sel */ + 0 /* Field: emacctl.emac2sel */ + 32000 /* Field: gpiodiv.gpiodbclk */ + >; + }; + + altera { + u-boot,dm-pre-reloc; + /* + * Address Block: soc_clock_manager_OCP_SLV. + * i_clk_mgr_alteragrp + */ + altr,of_reg_value = < + 0x0384000b /* Register: nocclk */ + 0x03840001 /* Register: mpuclk */ + >; + }; + }; + }; + + /* + * Driver: altera_arria10_soc_3v_io48_pin_mux_arria10_uboot_driver + * Binding: pinmux + */ + i_io48_pin_mux: pinmux@0xffd07000 { + u-boot,dm-pre-reloc; + #address-cells = <1>; + #size-cells = <1>; + compatible = "pinctrl-single"; + reg = <0xffd07000 0x00000800>; + reg-names = "soc_3v_io48_pin_mux_OCP_SLV"; + + /* + * Address Block: soc_3v_io48_pin_mux_OCP_SLV. + * i_io48_pin_mux_shared_3v_io_grp + */ + shared { + u-boot,dm-pre-reloc; + reg = <0xffd07000 0x00000200>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000000f>; + pinctrl-single,pins = + /* Reg: pinmux_shared_io_q1_1 */ + <0x00000000 0x00000008>, + /* Reg: pinmux_shared_io_q1_2 */ + <0x00000004 0x00000008>, + /* Reg: pinmux_shared_io_q1_3 */ + <0x00000008 0x00000008>, + /* Reg: pinmux_shared_io_q1_4 */ + <0x0000000c 0x00000008>, + /* Reg: pinmux_shared_io_q1_5 */ + <0x00000010 0x00000008>, + /* Reg: pinmux_shared_io_q1_6 */ + <0x00000014 0x00000008>, + /* Reg: pinmux_shared_io_q1_7 */ + <0x00000018 0x00000008>, + /* Reg: pinmux_shared_io_q1_8 */ + <0x0000001c 0x00000008>, + /* Reg: pinmux_shared_io_q1_9 */ + <0x00000020 0x00000008>, + /* Reg: pinmux_shared_io_q1_10 */ + <0x00000024 0x00000008>, + /* Reg: pinmux_shared_io_q1_11 */ + <0x00000028 0x00000008>, + /* Reg: pinmux_shared_io_q1_12 */ + <0x0000002c 0x00000008>, + /* Reg: pinmux_shared_io_q2_1 */ + <0x00000030 0x00000004>, + /* Reg: pinmux_shared_io_q2_2 */ + <0x00000034 0x00000004>, + /* Reg: pinmux_shared_io_q2_3 */ + <0x00000038 0x00000004>, + /* Reg: pinmux_shared_io_q2_4 */ + <0x0000003c 0x00000004>, + /* Reg: pinmux_shared_io_q2_5 */ + <0x00000040 0x00000004>, + /* Reg: pinmux_shared_io_q2_6 */ + <0x00000044 0x00000004>, + /* Reg: pinmux_shared_io_q2_7 */ + <0x00000048 0x00000004>, + /* Reg: pinmux_shared_io_q2_8 */ + <0x0000004c 0x00000004>, + /* Reg: pinmux_shared_io_q2_9 */ + <0x00000050 0x00000004>, + /* Reg: pinmux_shared_io_q2_10 */ + <0x00000054 0x00000004>, + /* Reg: pinmux_shared_io_q2_11 */ + <0x00000058 0x00000004>, + /* Reg: pinmux_shared_io_q2_12 */ + <0x0000005c 0x00000004>, + /* Reg: pinmux_shared_io_q3_1 */ + <0x00000060 0x00000003>, + /* Reg: pinmux_shared_io_q3_2 */ + <0x00000064 0x00000003>, + /* Reg: pinmux_shared_io_q3_3 */ + <0x00000068 0x00000003>, + /* Reg: pinmux_shared_io_q3_4 */ + <0x0000006c 0x00000003>, + /* Reg: pinmux_shared_io_q3_5 */ + <0x00000070 0x00000003>, + /* Reg: pinmux_shared_io_q3_6 */ + <0x00000074 0x0000000f>, + /* Reg: pinmux_shared_io_q3_7 */ + <0x00000078 0x0000000a>, + /* Reg: pinmux_shared_io_q3_8 */ + <0x0000007c 0x0000000a>, + /* Reg: pinmux_shared_io_q3_9 */ + <0x00000080 0x0000000a>, + /* Reg: pinmux_shared_io_q3_10 */ + <0x00000084 0x0000000a>, + /* Reg: pinmux_shared_io_q3_11 */ + <0x00000088 0x00000001>, + /* Reg: pinmux_shared_io_q3_12 */ + <0x0000008c 0x00000001>, + /* Reg: pinmux_shared_io_q4_1 */ + <0x00000090 0x00000000>, + /* Reg: pinmux_shared_io_q4_2 */ + <0x00000094 0x00000000>, + /* Reg: pinmux_shared_io_q4_3 */ + <0x00000098 0x0000000f>, + /* Reg: pinmux_shared_io_q4_4 */ + <0x0000009c 0x0000000c>, + /* Reg: pinmux_shared_io_q4_5 */ + <0x000000a0 0x0000000f>, + /* Reg: pinmux_shared_io_q4_6 */ + <0x000000a4 0x0000000f>, + /* Reg: pinmux_shared_io_q4_7 */ + <0x000000a8 0x0000000a>, + /* Reg: pinmux_shared_io_q4_8 */ + <0x000000ac 0x0000000a>, + /* Reg: pinmux_shared_io_q4_9 */ + <0x000000b0 0x0000000c>, + /* Reg: pinmux_shared_io_q4_10 */ + <0x000000b4 0x0000000c>, + /* Reg: pinmux_shared_io_q4_11 */ + <0x000000b8 0x0000000c>, + /* Reg: pinmux_shared_io_q4_12 */ + <0x000000bc 0x0000000c>; + }; + + /* + * Address Block: soc_3v_io48_pin_mux_OCP_SLV. + * i_io48_pin_mux_dedicated_io_grp + */ + dedicated { + u-boot,dm-pre-reloc; + reg = <0xffd07200 0x00000200>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000000f>; + pinctrl-single,pins = + /* Reg: pinmux_dedicated_io_4 */ + <0x0000000c 0x00000008>, + /* Reg: pinmux_dedicated_io_5 */ + <0x00000010 0x00000008>, + /* Reg: pinmux_dedicated_io_6 */ + <0x00000014 0x00000008>, + /* Regi: pinmux_dedicated_io_7 */ + <0x00000018 0x00000008>, + /* Reg: pinmux_dedicated_io_8 */ + <0x0000001c 0x00000008>, + /* Reg: pinmux_dedicated_io_9 */ + <0x00000020 0x00000008>, + /* Reg: pinmux_dedicated_io_10 */ + <0x00000024 0x0000000a>, + /* Reg: pinmux_dedicated_io_11 */ + <0x00000028 0x0000000a>, + /* Reg: pinmux_dedicated_io_12 */ + <0x0000002c 0x00000008>, + /* Reg: pinmux_dedicated_io_13 */ + <0x00000030 0x00000008>, + /* Reg: pinmux_dedicated_io_14 */ + <0x00000034 0x00000008>, + /* Reg: pinmux_dedicated_io_15 */ + <0x00000038 0x00000008>, + /* Reg: pinmux_dedicated_io_16 */ + <0x0000003c 0x0000000d>, + /* Reg: pinmux_dedicated_io_17 */ + <0x00000040 0x0000000d>; + }; + + /* + * Address Block: soc_3v_io48_pin_mux_OCP_SLV. + * i_io48_pin_mux_dedicated_io_grp + */ + dedicated_cfg { + u-boot,dm-pre-reloc; + reg = <0xffd07200 0x00000200>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x003f3f3f>; + pinctrl-single,pins = + /* Reg: cfg_dedicated_io_bank */ + <0x00000100 0x00000101>, + /* Reg: cfg_dedicated_io_1 */ + <0x00000104 0x000b080a>, + /* Reg: cfg_dedicated_io_2 */ + <0x00000108 0x000b080a>, + /* Reg: cfg_dedicated_io_3 */ + <0x0000010c 0x000b080a>, + /* Reg: cfg_dedicated_io_4 */ + <0x00000110 0x000a282a>, + /* Reg: cfg_dedicated_io_5 */ + <0x00000114 0x000a282a>, + /* Reg: cfg_dedicated_io_6 */ + <0x00000118 0x0008282a>, + /* Reg: cfg_dedicated_io_7 */ + <0x0000011c 0x000a282a>, + /* Reg: cfg_dedicated_io_8 */ + <0x00000120 0x000a282a>, + /* Reg: cfg_dedicated_io_9 */ + <0x00000124 0x000a282a>, + /* Reg: cfg_dedicated_io_10 */ + <0x00000128 0x00090000>, + /* Reg: cfg_dedicated_io_11 */ + <0x0000012c 0x00090000>, + /* Reg: cfg_dedicated_io_12 */ + <0x00000130 0x000b282a>, + /* Reg: cfg_dedicated_io_13 */ + <0x00000134 0x000b282a>, + /* Reg: cfg_dedicated_io_14 */ + <0x00000138 0x000b282a>, + /* Reg: cfg_dedicated_io_15 */ + <0x0000013c 0x000b282a>, + /* Reg: cfg_dedicated_io_16 */ + <0x00000140 0x0008282a>, + /* Reg: cfg_dedicated_io_17 */ + <0x00000144 0x000a282a>; + }; + + /* + * Address Block: soc_3v_io48_pin_mux_OCP_SLV. + * i_io48_pin_mux_fpga_interface_grp + */ + fpga { + u-boot,dm-pre-reloc; + reg = <0xffd07400 0x00000100>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x00000001>; + pinctrl-single,pins = + /* Reg: pinmux_emac0_usefpga */ + <0x00000000 0x00000000>, + /* Reg: pinmux_emac1_usefpga */ + <0x00000004 0x00000000>, + /* Reg: pinmux_emac2_usefpga */ + <0x00000008 0x00000000>, + /* Reg: pinmux_i2c0_usefpga */ + <0x0000000c 0x00000000>, + /* Reg: pinmux_i2c1_usefpga */ + <0x00000010 0x00000000>, + /* Reg: pinmux_i2c_emac0_usefpga */ + <0x00000014 0x00000000>, + /* Reg: pinmux_i2c_emac1_usefpga */ + <0x00000018 0x00000000>, + /* Reg: pinmux_i2c_emac2_usefpga */ + <0x0000001c 0x00000000>, + /* Reg: pinmux_nand_usefpga */ + <0x00000020 0x00000000>, + /* Reg: pinmux_qspi_usefpga */ + <0x00000024 0x00000000>, + /* Reg: pinmux_sdmmc_usefpga */ + <0x00000028 0x00000000>, + /* Reg: pinmux_spim0_usefpga */ + <0x0000002c 0x00000000>, + /* Reg: pinmux_spim1_usefpga */ + <0x00000030 0x00000000>, + /* Reg: pinmux_spis0_usefpga */ + <0x00000034 0x00000000>, + /* Reg: pinmux_spis1_usefpga */ + <0x00000038 0x00000000>, + /* Reg: pinmux_uart0_usefpga */ + <0x0000003c 0x00000000>, + /* Reg: pinmux_uart1_usefpga */ + <0x00000040 0x00000000>; + }; + }; + + i_noc: noc@0xffd10000 { + u-boot,dm-pre-reloc; + compatible = "altr,socfpga-a10-noc"; + reg = <0xffd10000 0x00008000>; + reg-names = "mpu_m0"; + + firewall { + u-boot,dm-pre-reloc; + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * mpuregion0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * mpuregion0addr.limit + */ + altr,mpu0 = <0x00000000 0x0000ffff>; + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0.noc_fw_ddr_l3_ddr_scr. + * hpsregion0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0.noc_fw_ddr_l3_ddr_scr. + * hpsregion0addr.limit + */ + altr,l3-0 = <0x00000000 0x0000ffff>; + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram0region0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram0region0addr.limit + */ + altr,fpga2sdram0-0 = <0x00000000 0x0000ffff>; + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram1region0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram1region0addr.limit + */ + altr,fpga2sdram1-0 = <0x00000000 0x0000ffff>; + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram2region0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram2region0addr.limit + */ + altr,fpga2sdram2-0 = <0x00000000 0x0000ffff>; + }; + }; + + hps_fpgabridge0: fpgabridge@0 { + compatible = "altr,socfpga-hps2fpga-bridge"; + altr,init-val = <1>; + }; + + hps_fpgabridge1: fpgabridge@1 { + compatible = "altr,socfpga-lwhps2fpga-bridge"; + altr,init-val = <1>; + }; + + hps_fpgabridge2: fpgabridge@2 { + compatible = "altr,socfpga-fpga2hps-bridge"; + altr,init-val = <1>; + }; + + hps_fpgabridge3: fpgabridge@3 { + compatible = "altr,socfpga-fpga2sdram0-bridge"; + altr,init-val = <1>; + }; + + hps_fpgabridge4: fpgabridge@4 { + compatible = "altr,socfpga-fpga2sdram1-bridge"; + altr,init-val = <0>; + }; + + hps_fpgabridge5: fpgabridge@5 { + compatible = "altr,socfpga-fpga2sdram2-bridge"; + altr,init-val = <1>; + }; + }; +};
Add SPL support for Arria 10.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/spl.c | 74 ++++++++++++++++++++++++++++++++++++++++++--- 1 file changed, 69 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-socfpga/spl.c b/arch/arm/mach-socfpga/spl.c index fec4c7a..31f4d41 100644 --- a/arch/arm/mach-socfpga/spl.c +++ b/arch/arm/mach-socfpga/spl.c @@ -19,23 +19,32 @@ #include <asm/arch/sdram.h> #include <asm/arch/scu.h> #include <asm/arch/nic301.h> +#include <asm/sections.h> +#include <fdtdec.h> +#include <watchdog.h> +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#include <asm/arch/pinmux.h> +#endif
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE; static struct scu_registers *scu_regs = (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS; static struct nic301_registers *nic301_regs = (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; -static struct socfpga_system_manager *sysmgr_regs = +#endif + +static const struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
u32 spl_boot_device(void) { const u32 bsel = readl(&sysmgr_regs->bootinfo);
- switch (bsel & 0x7) { + switch (SYSMGR_GET_BOOTINFO_BSEL(bsel)) { case 0x1: /* FPGA (HPS2FPGA Bridge) */ return BOOT_DEVICE_RAM; case 0x2: /* NAND Flash (1.8V) */ @@ -68,6 +77,7 @@ u32 spl_boot_mode(const u32 boot_device) } #endif
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static void socfpga_nic301_slave_ns(void) { writel(0x1, &nic301_regs->lwhps2fpgaregs); @@ -85,6 +95,7 @@ void board_init_f(ulong dummy) #endif unsigned long sdram_size; unsigned long reg; + int ret;
/* * First C code to run. Clear fake OCRAM ECC first as SBE @@ -117,7 +128,11 @@ void board_init_f(ulong dummy) /* Put everything into reset but L4WD0. */ socfpga_per_reset_all(); /* Put FPGA bridges into reset too. */ - socfpga_bridges_reset(1); + ret = socfpga_bridges_reset(1); + if (ret) { + debug("socfpga_bridges_reset() failed: %d\n", ret); + hang(); + }
socfpga_per_reset(SOCFPGA_RESET(SDR), 0); socfpga_per_reset(SOCFPGA_RESET(UART0), 0); @@ -147,7 +162,11 @@ void board_init_f(ulong dummy)
/* De-assert reset for peripherals and bridges based on handoff */ reset_deassert_peripherals_handoff(); - socfpga_bridges_reset(0); + ret = socfpga_bridges_reset(0); + if (ret) { + debug("socfpga_bridges_reset() failed: %d\n", ret); + hang(); + }
debug("Unfreezing/Thaw all I/O banks\n"); /* unfreeze / thaw all IO banks */ @@ -177,8 +196,53 @@ void board_init_f(ulong dummy) hang(); }
/* Configure simple malloc base pointer into RAM. */ gd->malloc_base = CONFIG_SYS_TEXT_BASE + (1024 * 1024); } +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#ifdef CONFIG_SPL_BOARD_INIT +void spl_board_init(void) +{ + /* configuring the clock based on handoff */ + cm_basic_init(gd->fdt_blob); + WATCHDOG_RESET(); + + config_dedicated_pins(gd->fdt_blob); + WATCHDOG_RESET(); + + /* Release UART from reset */ + socfpga_reset_uart(0); + + /* enable console uart printing */ + preloader_console_init(); +} +#endif + +void board_init_f(ulong dummy) +{ + /* + * Configure Clock Manager to use intosc clock instead external osc to + * ensure success watchdog operation. We do it as early as possible. + */ + cm_use_intosc(); + + socfpga_watchdog_disable(); + + arch_early_init_r(); + +#ifdef CONFIG_HW_WATCHDOG + /* release osc1 watchdog timer 0 from reset */ + socfpga_reset_deassert_osc1wd0(); + + /* reconfigure and enable the watchdog */ + hw_watchdog_init(); + WATCHDOG_RESET(); +#endif /* CONFIG_HW_WATCHDOG */ +} +#endif
- switch (SYSMGR_GET_BOOTINFO_BSEL(bsel)) { case 0x1: /* FPGA (HPS2FPGA Bridge) */ return BOOT_DEVICE_RAM; case 0x2: /* NAND Flash (1.8V) */
int ret;
- First C code to run. Clear fake OCRAM ECC first as SBE
- ret = socfpga_bridges_reset(1);
- if (ret) {
Shouldn't this be printf() ?
hang();
- ret = socfpga_bridges_reset(0);
- if (ret) {
DTTO ?
hang();
- if (ret) {
DTTO ?
hang();
- /* configuring the clock based on handoff */
- cm_basic_init(gd->fdt_blob);
- WATCHDOG_RESET();
- config_dedicated_pins(gd->fdt_blob);
- WATCHDOG_RESET();
- /* Release UART from reset */
- socfpga_reset_uart(0);
- /* enable console uart printing */
- preloader_console_init();
+} +#endif
- cm_use_intosc();
- socfpga_watchdog_disable();
- arch_early_init_r();
- /* release osc1 watchdog timer 0 from reset */
- socfpga_reset_deassert_osc1wd0();
- /* reconfigure and enable the watchdog */
- hw_watchdog_init();
- WATCHDOG_RESET();
These registers only available for Gen5 device, exclude them from Arria 10 build.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- drivers/fpga/socfpga.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/fpga/socfpga.c b/drivers/fpga/socfpga.c index f1b2f2c..3751574 100644 --- a/drivers/fpga/socfpga.c +++ b/drivers/fpga/socfpga.c @@ -19,8 +19,10 @@ DECLARE_GLOBAL_DATA_PTR;
static struct socfpga_fpga_manager *fpgamgr_regs = (struct socfpga_fpga_manager *)SOCFPGA_FPGAMGRREGS_ADDRESS; +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; +#endif
/* Set CD ratio */ static void fpgamgr_set_cd_ratio(unsigned long ratio) @@ -268,8 +270,10 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size)
/* Prior programming the FPGA, all bridges need to be shut off */
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* Disable all signals from hps peripheral controller to fpga */ writel(0, &sysmgr_regs->fpgaintfgrp_module); +#endif
/* Disable all signals from FPGA to HPS SDRAM */ #define SDR_CTRLGRP_FPGAPORTRST_ADDRESS 0x5080 @@ -278,8 +282,10 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) /* Disable all axi bridge (hps2fpga, lwhps2fpga & fpga2hps) */ socfpga_bridges_reset(1);
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* Unmap the bridges from NIC-301 */ writel(0x1, SOCFPGA_L3REGS_ADDRESS); +#endif
/* Initialize the FPGA Manager */ status = fpgamgr_program_init();
Convert Altera DDR SDRAM driver to use Kconfig method. Enable ALTERA_SDRAM by default if it is on Gen5 target. Arria 10 will have different driver.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- drivers/Kconfig | 2 ++ drivers/ddr/Kconfig | 1 + drivers/ddr/altera/Kconfig | 6 ++++++ drivers/ddr/altera/Makefile | 4 +++- include/configs/socfpga_common.h | 5 ----- 5 files changed, 12 insertions(+), 6 deletions(-) create mode 100644 drivers/ddr/Kconfig create mode 100644 drivers/ddr/altera/Kconfig
diff --git a/drivers/Kconfig b/drivers/Kconfig index 0e5d97d..3e6bbac 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -14,6 +14,8 @@ source "drivers/cpu/Kconfig"
source "drivers/crypto/Kconfig"
+source "drivers/ddr/Kconfig" + source "drivers/demo/Kconfig"
source "drivers/ddr/fsl/Kconfig" diff --git a/drivers/ddr/Kconfig b/drivers/ddr/Kconfig new file mode 100644 index 0000000..b764add --- /dev/null +++ b/drivers/ddr/Kconfig @@ -0,0 +1 @@ +source "drivers/ddr/altera/Kconfig" diff --git a/drivers/ddr/altera/Kconfig b/drivers/ddr/altera/Kconfig new file mode 100644 index 0000000..eb82038 --- /dev/null +++ b/drivers/ddr/altera/Kconfig @@ -0,0 +1,6 @@ +config ALTERA_SDRAM + bool "SoCFPGA DDR SDRAM driver" + depends on TARGET_SOCFPGA_GEN5 + default y if TARGET_SOCFPGA_GEN5 + help + Enable DDR SDRAM controller for the SoCFPGA devices. diff --git a/drivers/ddr/altera/Makefile b/drivers/ddr/altera/Makefile index 1ca7058..bdd2872 100644 --- a/drivers/ddr/altera/Makefile +++ b/drivers/ddr/altera/Makefile @@ -8,4 +8,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_ALTERA_SDRAM) += sdram.o sequencer.o +ifdef CONFIG_ALTERA_SDRAM +obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += sdram.o sequencer.o +endif diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 55e0bf9..bc92a2c 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -77,11 +77,6 @@ #define CONFIG_SYS_PL310_BASE SOCFPGA_MPUL2_ADDRESS
/* - * SDRAM controller - */ -#define CONFIG_ALTERA_SDRAM - -/* * EPCS/EPCQx1 Serial Flash Controller */ #ifdef CONFIG_ALTERA_SPI
- bool "SoCFPGA DDR SDRAM driver"
- depends on TARGET_SOCFPGA_GEN5
- default y if TARGET_SOCFPGA_GEN5
The arch/arm/mach-socfpga/Kconfig should select this, so drop the default y part
- help
- SDRAM controller
- EPCS/EPCQx1 Serial Flash Controller
Okay.
Thanks. Regards Ley Foon
Add config and defconfig for the Arria10 and update socfpga_common.h.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- configs/socfpga_arria10_defconfig | 28 ++++++++++++++ include/configs/socfpga_arria10_socdk.h | 66 +++++++++++++++++++++++++++++++++ include/configs/socfpga_common.h | 28 +++++++++++--- 3 files changed, 117 insertions(+), 5 deletions(-) create mode 100644 configs/socfpga_arria10_defconfig create mode 100644 include/configs/socfpga_arria10_socdk.h
diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig new file mode 100644 index 0000000..e1f5929 --- /dev/null +++ b/configs/socfpga_arria10_defconfig @@ -0,0 +1,28 @@ +CONFIG_ARM=y +CONFIG_ARCH_SOCFPGA=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_SOCFPGA_ARRIA10_SOCDK=y +CONFIG_IDENT_STRING="socfpga_arria10" +CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria10_socdk_sdmmc" +CONFIG_DEFAULT_FDT_FILE="socfpga_arria10_socdk_sdmmc.dtb" +CONFIG_SPL=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_DOS_PARTITION=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_GPIO=y +CONFIG_DWAPB_GPIO=y +CONFIG_DM_MMC=y +CONFIG_SYS_NS16550=y +CONFIG_USE_TINY_PRINTF=y diff --git a/include/configs/socfpga_arria10_socdk.h b/include/configs/socfpga_arria10_socdk.h new file mode 100644 index 0000000..052244f --- /dev/null +++ b/include/configs/socfpga_arria10_socdk.h @@ -0,0 +1,66 @@ +/* + * Copyright (C) 2015-2017 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __CONFIG_SOCFGPA_ARRIA10_H__ +#define __CONFIG_SOCFGPA_ARRIA10_H__ + +#include <asm/arch/base_addr_a10.h> +/* U-Boot Commands */ +#define CONFIG_FAT_WRITE +#define CONFIG_HW_WATCHDOG + +/* Booting Linux */ +#define CONFIG_LOADADDR 0x01000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* + * U-Boot general configurations + */ +/* Cache options */ +#define CONFIG_SYS_DCACHE_OFF + +/* Memory configurations */ +#define PHYS_SDRAM_1_SIZE 0x80000000 + +/* Ethernet on SoC (EMAC) */ +#if defined(CONFIG_CMD_NET) +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_MICREL_KSZ9031 +#endif + +/* + * U-Boot environment configurations + */ +#define CONFIG_ENV_IS_IN_MMC + +/* + * arguments passed to the bootz command. The value of + * CONFIG_BOOTARGS goes into the environment value "bootargs". + * Do note the value will overide also the chosen node in FDT blob. + */ +#define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) + +/* + * Serial / UART configurations + */ +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, 115200} + +/* + * L4 OSC1 Timer 0 + */ +/* reload value when timer count to zero */ +#define TIMER_LOAD_VAL 0xFFFFFFFF + +/* + * Flash configurations + */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 + +/* The rest of the configuration is shared */ +#include <configs/socfpga_common.h> + +#endif /* __CONFIG_SOCFGPA_ARRIA10_H__ */ diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index bc92a2c..1cedef8 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -34,9 +34,13 @@ #define CONFIG_SYS_MALLOC_LEN (64 * 1024 * 1024) #define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 #define CONFIG_SYS_MEMTEST_END PHYS_SDRAM_1_SIZE - +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #define CONFIG_SYS_INIT_RAM_ADDR 0xFFFF0000 #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define CONFIG_SYS_INIT_RAM_ADDR 0xFFE00000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x40000 /* 256KB */ +#endif #define CONFIG_SYS_INIT_SP_OFFSET \ (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR \ @@ -67,8 +71,10 @@ #define CONFIG_SYS_HOSTNAME CONFIG_SYS_BOARD #endif
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #define CONFIG_CMD_PXE #define CONFIG_MENU +#endif
/* * Cache @@ -103,13 +109,14 @@ /* * FPGA Driver */ +#ifdef CONFIG_TARGET_SOCFPGA_GEN5 #ifdef CONFIG_CMD_FPGA #define CONFIG_FPGA #define CONFIG_FPGA_ALTERA #define CONFIG_FPGA_SOCFPGA #define CONFIG_FPGA_COUNT 1 #endif - +#endif /* * L4 OSC1 Timer 0 */ @@ -209,11 +216,14 @@ unsigned int cm_get_qspi_controller_clk_hz(void); */ #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE -4 -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART0_ADDRESS #ifdef CONFIG_SOCFPGA_VIRTUAL_TARGET #define CONFIG_SYS_NS16550_CLK 1000000 -#else +#elif defined(CONFIG_TARGET_SOCFPGA_GEN5) +#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART0_ADDRESS #define CONFIG_SYS_NS16550_CLK 100000000 +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART1_ADDRESS +#define CONFIG_SYS_NS16550_CLK 50000000 #endif #define CONFIG_CONS_INDEX 1 #define CONFIG_BAUDRATE 115200 @@ -301,7 +311,10 @@ unsigned int cm_get_qspi_controller_clk_hz(void); */ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_TEXT_BASE CONFIG_SYS_INIT_RAM_ADDR -#define CONFIG_SPL_MAX_SIZE (64 * 1024) +#define CONFIG_SPL_MAX_SIZE CONFIG_SYS_INIT_RAM_SIZE +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define CONFIG_SPL_BOARD_INIT +#endif
/* SPL SDMMC boot support */ #ifdef CONFIG_SPL_MMC_SUPPORT @@ -349,10 +362,15 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define BOOT_TARGET_DEVICES_MMC(func) #endif
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #define BOOT_TARGET_DEVICES(func) \ BOOT_TARGET_DEVICES_MMC(func) \ BOOT_TARGET_DEVICES_PXE(func) \ func(DHCP, dhcp, na) +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_DEVICES_MMC(func) +#endif
#include <config_distro_bootcmd.h>
Add support for the Arria10 SoCDK.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- board/altera/arria10-socdk/Kconfig | 18 ++++++++++++++++++ board/altera/arria10-socdk/Makefile | 7 +++++++ board/altera/arria10-socdk/socfpga.c | 7 +++++++ 3 files changed, 32 insertions(+) create mode 100644 board/altera/arria10-socdk/Kconfig create mode 100644 board/altera/arria10-socdk/Makefile create mode 100644 board/altera/arria10-socdk/socfpga.c
diff --git a/board/altera/arria10-socdk/Kconfig b/board/altera/arria10-socdk/Kconfig new file mode 100644 index 0000000..b80cc6d --- /dev/null +++ b/board/altera/arria10-socdk/Kconfig @@ -0,0 +1,18 @@ +if TARGET_SOCFPGA_ARRIA10 + +config SYS_CPU + default "armv7" + +config SYS_BOARD + default "socfpga_arria10" + +config SYS_VENDOR + default "altera" + +config SYS_SOC + default "socfpga_arria10" + +config SYS_CONFIG_NAME + default "socfpga_arria10" + +endif diff --git a/board/altera/arria10-socdk/Makefile b/board/altera/arria10-socdk/Makefile new file mode 100644 index 0000000..1d885ce --- /dev/null +++ b/board/altera/arria10-socdk/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2015 Altera Corporation <www.altera.com> +# +# SPDX-License-Identifier: GPL-2.0 +# + +obj-y := socfpga.o diff --git a/board/altera/arria10-socdk/socfpga.c b/board/altera/arria10-socdk/socfpga.c new file mode 100644 index 0000000..8516633 --- /dev/null +++ b/board/altera/arria10-socdk/socfpga.c @@ -0,0 +1,7 @@ +/* + * Copyright (C) 2015 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h>
Update Kconfig and Makefile to enable Arria 10. Clean up Makefile and sorting *.o alphanumerically.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/Kconfig | 10 +++++++++ arch/arm/mach-socfpga/Makefile | 46 ++++++++++++++++++++++++++++++------------ 2 files changed, 43 insertions(+), 13 deletions(-)
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index e56b3db..ee98a44 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -37,6 +37,9 @@ config TARGET_SOCFPGA_ARRIA5 bool select TARGET_SOCFPGA_GEN5
+config TARGET_SOCFPGA_ARRIA10 + bool + config TARGET_SOCFPGA_CYCLONE5 bool select TARGET_SOCFPGA_GEN5 @@ -48,6 +51,10 @@ choice prompt "Altera SOCFPGA board select" optional
+config TARGET_SOCFPGA_ARRIA10_SOCDK + bool "Altera SOCFPGA SoCDK (Arria 10)" + select TARGET_SOCFPGA_ARRIA10 + config TARGET_SOCFPGA_ARRIA5_SOCDK bool "Altera SOCFPGA SoCDK (Arria V)" select TARGET_SOCFPGA_ARRIA5 @@ -93,6 +100,7 @@ endchoice
config SYS_BOARD default "arria5-socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "arria10-socdk" if TARGET_SOCFPGA_ARRIA10_SOCDK default "cyclone5-socdk" if TARGET_SOCFPGA_CYCLONE5_SOCDK default "de0-nano-soc" if TARGET_SOCFPGA_TERASIC_DE0_NANO default "de1-soc" if TARGET_SOCFPGA_TERASIC_DE1_SOC @@ -105,6 +113,7 @@ config SYS_BOARD
config SYS_VENDOR default "altera" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "altera" if TARGET_SOCFPGA_ARRIA10_SOCDK default "altera" if TARGET_SOCFPGA_CYCLONE5_SOCDK default "denx" if TARGET_SOCFPGA_DENX_MCVEVK default "ebv" if TARGET_SOCFPGA_EBV_SOCRATES @@ -118,6 +127,7 @@ config SYS_SOC
config SYS_CONFIG_NAME default "socfpga_arria5_socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "socfpga_arria10_socdk" if TARGET_SOCFPGA_ARRIA10_SOCDK default "socfpga_cyclone5_socdk" if TARGET_SOCFPGA_CYCLONE5_SOCDK default "socfpga_de0_nano_soc" if TARGET_SOCFPGA_TERASIC_DE0_NANO default "socfpga_de1_soc" if TARGET_SOCFPGA_TERASIC_DE1_SOC diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 68d55e4..41b779c 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -2,28 +2,48 @@ # (C) Copyright 2000-2003 # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # -# Copyright (C) 2012 Altera Corporation <www.altera.com> +# Copyright (C) 2012-2017 Altera Corporation <www.altera.com> # # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += misc.o timer.o reset_manager.o clock_manager.o \ - fpga_manager.o board.o +obj-y += board.o +obj-y += clock_manager.o +obj-y += fpga_manager.o +obj-y += misc.o +obj-y += reset_manager.o +obj-y += timer.o
-obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clock_manager_arria10.o \ - misc_arria10.o \ - pinmux_arria10.o \ - reset_manager_arria10.o +ifdef CONFIG_TARGET_SOCFPGA_GEN5 +obj-y += clock_manager_gen5.o +obj-y += misc_gen5.o +obj-y += reset_manager_gen5.o +obj-y += scan_manager.o +obj-y += system_manager_gen5.o +obj-y += wrap_pll_config.o +endif
-obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o +ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 +obj-y += clock_manager_arria10.o +obj-y += misc_arria10.o +obj-y += pinmux_arria10.o +obj-y += reset_manager_arria10.o +endif
+ifdef CONFIG_SPL_BUILD +obj-y += spl.o +ifdef CONFIG_TARGET_SOCFPGA_GEN5 +obj-y += freeze_controller.o +obj-y += wrap_iocsr_config.o +obj-y += wrap_pinmux_config.o +obj-y += wrap_sdram_config.o +endif +endif + +ifdef CONFIG_TARGET_SOCFPGA_GEN5 # QTS-generated config file wrappers -obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o \ - clock_manager_gen5.o reset_manager_gen5.o \ - misc_gen5.o system_manager_gen5.o -obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ - wrap_sdram_config.o CFLAGS_wrap_iocsr_config.o += -I$(srctree)/board/$(BOARDDIR) CFLAGS_wrap_pinmux_config.o += -I$(srctree)/board/$(BOARDDIR) CFLAGS_wrap_pll_config.o += -I$(srctree)/board/$(BOARDDIR) CFLAGS_wrap_sdram_config.o += -I$(srctree)/board/$(BOARDDIR) +endif
Dinh Nguyen
Ley Foon Tan
Ley Foon Tan
