[PATCH] apalis-imx8: Fix sc_misc_otp_fuse_read() error check
Commit bfb3409d676f ("imx: toradex/apalis-imx8: correct SCU API usage") made an incorrect logic change in the error code check of sc_misc_otp_fuse_read():
- if (scierr == SC_ERR_NONE) { + if (scierr) { /* QP has one A72 core disabled */ is_quadplus = ((val >> 4) & 0x3) != 0x0; }
The other changes in this commit are correct.
sc_misc_otp_fuse_read() returns 0 on a successful fuse read.
This inversion causes board_mem_get_layout() to report incorrect RAM size.
Go back the original error check logic to fix the problem.
Fixes: bfb3409d676f ("imx: toradex/apalis-imx8: correct SCU API usage") Signed-off-by: Fabio Estevam festevam@gmail.com --- board/toradex/apalis-imx8/apalis-imx8.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/toradex/apalis-imx8/apalis-imx8.c b/board/toradex/apalis-imx8/apalis-imx8.c index 2483a63c6733..49719f2f5533 100644 --- a/board/toradex/apalis-imx8/apalis-imx8.c +++ b/board/toradex/apalis-imx8/apalis-imx8.c @@ -133,7 +133,7 @@ void board_mem_get_layout(u64 *phys_sdram_1_start, struct tdx_user_fuses tdxramfuses; int scierr = sc_misc_otp_fuse_read(-1, 6, &val);
- if (scierr) { + if (!scierr) { /* QP has one A72 core disabled */ is_quadplus = ((val >> 4) & 0x3) != 0x0; }
-----Original Message----- From: Fabio Estevam festevam@gmail.com Sent: Wednesday, March 13, 2024 9:00 AM To: festevam@gmail.com Cc: Marcel Ziswiler marcel.ziswiler@toradex.com; hiago.franco@toradex.com; Francesco Dolcini francesco.dolcini@toradex.com; u-boot@lists.denx.de; Peng Fan peng.fan@nxp.com; joao.goncalves@toradex.com Subject: [PATCH] apalis-imx8: Fix sc_misc_otp_fuse_read() error check
Reviewed-by: Peng Fan peng.fan@nxp.com
diff --git a/board/toradex/apalis-imx8/apalis-imx8.c b/board/toradex/apalis- imx8/apalis-imx8.c index 2483a63c6733..49719f2f5533 100644 --- a/board/toradex/apalis-imx8/apalis-imx8.c +++ b/board/toradex/apalis-imx8/apalis-imx8.c @@ -133,7 +133,7 @@ void board_mem_get_layout(u64 *phys_sdram_1_start, struct tdx_user_fuses tdxramfuses; int scierr = sc_misc_otp_fuse_read(-1, 6, &val);
- if (scierr) {
- if (!scierr) { /* QP has one A72 core disabled */ is_quadplus = ((val >> 4) & 0x3) != 0x0; }
-- 2.34.1
Hi Fabio
Thanks!
Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
- if (scierr) {
- if (!scierr) {
Cheers
Marcel
Applied for u-boot-imx/master, thanks.
Fabio Estevam
Marcel Ziswiler
Peng Fan
