[U-Boot] [PATCH] net/phy/cortina: Add No firmware upload option
Current Cortina phy driver assumes that firmware upload is required during initialization and is dependent on presence of corresponding macros like CONFIG_CORTINA_FW_ADDR for compilation.
But Cortina phy has provision to store phy firmware in attached dedicated EEPROM. And boards designed with such EEPROM does not require firmware upload.
Add CORTINA_NO_FW_UPLOAD option in cortina.c to support such boards.
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- drivers/net/phy/cortina.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/net/phy/cortina.c b/drivers/net/phy/cortina.c index 3ac833d..a6b4754 100644 --- a/drivers/net/phy/cortina.c +++ b/drivers/net/phy/cortina.c @@ -4,6 +4,7 @@ * SPDX-License-Identifier: GPL-2.0+ * * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2018 NXP * */
@@ -27,6 +28,7 @@ #error The Cortina PHY needs 10G support #endif
+#ifndef CORTINA_NO_FW_UPLOAD struct cortina_reg_config cortina_reg_cfg[] = { /* CS4315_enable_sr_mode */ {VILLA_GLOBAL_MSEQCLKCTRL, 0x8004}, @@ -215,12 +217,22 @@ void cs4340_upload_firmware(struct phy_device *phydev) phy_write(phydev, 0x00, fw_temp.reg_addr, fw_temp.reg_value); } } +#endif
int cs4340_phy_init(struct phy_device *phydev) { +#ifndef CORTINA_NO_FW_UPLOAD int timeout = 100; /* 100ms */ +#endif int reg_value;
+ /* + * Cortina phy has provision to store + * phy firmware in attached dedicated EEPROM. + * Boards designed with EEPROM attached to Cortina + * does not require FW upload. + */ +#ifndef CORTINA_NO_FW_UPLOAD /* step1: BIST test */ phy_write(phydev, 0x00, VILLA_GLOBAL_MSEQCLKCTRL, 0x0004); phy_write(phydev, 0x00, VILLA_GLOBAL_LINE_SOFT_RESET, 0x0000); @@ -241,6 +253,7 @@ int cs4340_phy_init(struct phy_device *phydev)
/* setp2: upload ucode */ cs4340_upload_firmware(phydev); +#endif reg_value = phy_read(phydev, 0x00, VILLA_GLOBAL_DWNLD_CHECKSUM_STATUS); if (reg_value) { debug("%s checksum status failed.\n", __func__);
Hi Priyanka,
https://patchwork.ozlabs.org/patch/867408/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Joe Hershberger
Priyanka Jain
