[U-Boot] [PATCH v8 6/9] x86: slimbootloader: Set TSC information for tsc_timer
Slim Bootloader already calibrated TSC and provides it to U-Boot. Therefore, U-Boot does not have to re-calibrate TSC. Configuring tsc_base and clock_rate makes x86 tsc_timer driver bypass TSC calibration and use the provided TSC frequency. - Get TSC frequency from performance info hob - Set tsc_base and clock_rate for tsc_timer driver
Signed-off-by: Aiden Park aiden.park@intel.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Andy Shevchenko andy.shevchenko@gmail.com --- Changes in v6: * Use EFI_GUID * Add more comments while setting tsc_base and clock_rate * Apply code-review comments
Changes in v3: * Use HOB function from the common HOB library
arch/x86/cpu/slimbootloader/slimbootloader.c | 37 +++++++++++++++++++ .../asm/arch-slimbootloader/slimbootloader.h | 28 ++++++++++++++ 2 files changed, 65 insertions(+)
diff --git a/arch/x86/cpu/slimbootloader/slimbootloader.c b/arch/x86/cpu/slimbootloader/slimbootloader.c index 9f3a61ec61..e6b174ca88 100644 --- a/arch/x86/cpu/slimbootloader/slimbootloader.c +++ b/arch/x86/cpu/slimbootloader/slimbootloader.c @@ -4,9 +4,46 @@ */
#include <common.h> +#include <asm/arch/slimbootloader.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * This sets tsc_base and clock_rate for early_timer and tsc_timer. + * The performance info guid hob has all performance timestamp data, but + * the only tsc frequency info is used for the timer driver for now. + * + * Slim Bootloader already calibrated TSC and provides it to U-Boot. + * Therefore, U-Boot does not have to re-calibrate TSC. + * Configuring tsc_base and clock_rate here makes x86 tsc_timer driver + * bypass TSC calibration and use the provided TSC frequency. + */ +static void tsc_init(void) +{ + struct sbl_performance_info *data; + const efi_guid_t guid = SBL_PERFORMANCE_INFO_GUID; + + if (!gd->arch.hob_list) + panic("hob list not found!"); + + gd->arch.tsc_base = rdtsc(); + debug("tsc_base=0x%llx\n", gd->arch.tsc_base); + + data = hob_get_guid_hob_data(gd->arch.hob_list, NULL, &guid); + if (!data) { + debug("performance info hob not found\n"); + return; + } + + /* frequency is in KHz, so to Hz */ + gd->arch.clock_rate = data->frequency * 1000; + debug("freq=0x%lx\n", gd->arch.clock_rate); +}
int arch_cpu_init(void) { + tsc_init(); + return x86_cpu_init_f(); }
diff --git a/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h b/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h index 174a341d32..05dd1b2b44 100644 --- a/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h +++ b/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h @@ -23,6 +23,13 @@ EFI_GUID(0x6c6872fe, 0x56a9, 0x4403, \ 0xbb, 0x98, 0x95, 0x8d, 0x62, 0xde, 0x87, 0xf1)
+/** + * A GUID to get boot performance info hob which is provided by Slim Bootloader + */ +#define SBL_PERFORMANCE_INFO_GUID \ + EFI_GUID(0x868204be, 0x23d0, 0x4ff9, \ + 0xac, 0x34, 0xb9, 0x95, 0xac, 0x04, 0xb1, 0xb9) + /** * A single entry of memory map information * @@ -84,4 +91,25 @@ struct sbl_serial_port_info { u32 rsvd1; };
+/** + * This includes timestamp data which has been collected in Slim Bootloader + * stages from the reset vector. In addition, this has TSC frequency in KHz to + * calculate each timestamp. + * + * @rev : revision of performance_info structure. currently 1. + * @rsvd : padding for alignment + * @count : the number of collected timestamp data + * @flags : only used in Slim Bootloader + * @frequency: tsc frequency in KHz + * @timestamp: the array of timestamp data which has 64-bit tsc value + */ +struct sbl_performance_info { + u8 rev; + u8 rsvd[3]; + u16 count; + u16 flags; + u32 frequency; + u64 timestamp[0]; +}; + #endif /* __SLIMBOOTLOADER_ARCH_H__ */
Park, Aiden
