[U-Boot] [PATCH v2 00/18] SPL: extend FIT loading support
A fixed version of the SPL FIT loading series. The error handling has been improved, also quite some comments and documentation has been added. The README.pine64 file has been totally reworked to reflect the new way of building the firmware for the Pine64 (and other 64-bit Allwinner SoCs, really). Some minor bugs have been fixed and Reviewed-by: tags have been added.
The first five patches introduce the core of the extened SPL FIT loading support, see below for a description. Patches 6-9 make some room in the sunxi 64-bit SPL to allow compiling in the FIT loading bits. Patch 10 and 11 let the SPL choose the proper DT from the FIT image. The next two patches add the infrastructure and an actual generator script, so the FIT image is automatically created at build time. Patches 14 and 15 enable the SPL FIT support in the Pine64 and the OrangePi PC 2 defconfigs. The following two patches store a DT file name in the SPL header, so U-Boot can easily pick the proper DT when scanning the FIT image. The idea is that this DT name should stay with the board, ideally on eMMC or SPI flash. So both U-Boot and a firmware update tool could identify a board, updating with compatible firmware while keeping the DT name in place. Ideally a board vendor would once seed this name onto on-board storage like SPI flash. I kept those two patches in, as the work on replacing mksunxiboot with an mkimage extension is not ready yet. Feel free to drop those from the series if this is a problem. The final patch updates the Pine64 README file to document the current way of building U-Boot, which now includes the ARM Trusted Firmware build in its image.
I would be delighted if that series can make it into the next release, as this finally enables the fully open source firmware for the 64-bit Allwinner SoCs (including the ATF binary).
This series is based on sunxi/master, rebased upon origin/master.
Cheers, Andre.
------- Currently the FIT format is not used to its full potential in the SPL: It only loads the first image from the /images node and appends the proper FDT. Some boards and platforms would benefit from loading more images before starting U-Boot proper, notably Allwinner A64 and ARMv8 Rockchip boards, which use an ARM Trusted Firmware (ATF) image to be executed before U-Boot.
This series tries to solve this in a board agnostic and generic way: We extend the SPL FIT loading scheme to allow loading multiple images. So apart from loading the image which is referenced by the "firmware" property in the respective configuration node and placing the DTB right behind it, we iterate over all strings in the "loadable" property. Each image referenced there will be loaded to its specified load address. The entry point U-Boot eventually branches to will be taken from the first image to explicitly provide the "entry" property, or, if none of them does so, from the load address of the "firmware" image. This keeps the scheme compatible with the FIT images our Makefile creates automatically at the moment. Apart from the already mentioned ATF scenario this opens up more usage scenarios, of which the commit message of patch 04/11 lists some. The remaining patches prepare ane finally enable this scheme for the 64-bit Allwinner boards.
Andre Przywara (17): SPL: FIT: refactor FDT loading SPL: FIT: rework U-Boot image loading SPL: FIT: improve error handling SPL: FIT: factor out spl_load_fit_image() SPL: FIT: allow loading multiple images tools: mksunxiboot: allow larger SPL binaries armv8: SPL: only compile GIC code if needed armv8: fsl: move ccn504 code into FSL Makefile sunxi: A64: move SPL stack to end of SRAM A2 sunxi: SPL: store RAM size in gd sunxi: SPL: add FIT config selector for Pine64 boards Makefile: add rules to generate SPL FIT images sunxi: A64: Pine64: introduce FIT generator script sunxi: Pine64: defconfig: enable SPL FIT support sunxi: OrangePi-PC2: defconfig: enable SPL FIT support sunxi: use SPL header DT name for FIT board matching sunxi: update Pine64 README
Siarhei Siamashka (1): sunxi: Store the device tree name in the SPL header
Kconfig | 17 ++ Makefile | 20 +++ arch/arm/include/asm/arch-sunxi/spl.h | 19 ++- arch/arm/lib/Makefile | 4 +- board/sunxi/README.pine64 | 177 +++++++++++++------- board/sunxi/board.c | 36 +++- board/sunxi/mksunxi_fit_atf.sh | 73 +++++++++ common/spl/spl_fit.c | 298 ++++++++++++++++++++++------------ configs/orangepi_pc2_defconfig | 6 + configs/pine64_plus_defconfig | 6 + doc/uImage.FIT/howto.txt | 21 +++ include/configs/sunxi-common.h | 17 +- scripts/Makefile.spl | 3 +- tools/mksunxiboot.c | 51 +++++- 14 files changed, 563 insertions(+), 185 deletions(-) create mode 100755 board/sunxi/mksunxi_fit_atf.sh
Currently the SPL FIT loader uses the spl_fit_select_fdt() function to find the offset to the right DTB within the FIT image. For this it iterates over all subnodes of the /configuration node in the FIT tree and compares all "description" strings therein using a board specific matching function. If that finds a match, it uses the string in the "fdt" property of that subnode to locate the matching subnode in the /images node, which points to the DTB data. Now this works very well, but is quite specific to cover this particular use case. To open up the door for a more generic usage, let's split this function into: 1) a function that just returns the node offset for the matching configuration node (spl_fit_find_config_node()) 2) a function that returns the image data any given property in a given configuration node points to, additionally using a given index into a possbile list of strings (spl_fit_select_index()) This allows us to replace the specific function above by asking for the image the _first string of the "fdt" property_ in the matching configuration subnode points to.
This patch introduces no functional changes, it just refactors the code to allow reusing it later.
(diff is overly clever here and produces a hard-to-read patch, so I recommend to throw a look at the result instead).
Signed-off-by: Andre Przywara andre.przywara@arm.com Reviewed-by: Lokesh Vutla lokeshvuta@ti.com --- common/spl/spl_fit.c | 88 ++++++++++++++++++++++++++++++++++------------------ 1 file changed, 57 insertions(+), 31 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index aae556f..bf9fbb6 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -22,13 +22,16 @@ static ulong fdt_getprop_u32(const void *fdt, int node, const char *prop) return fdt32_to_cpu(*cell); }
-static int spl_fit_select_fdt(const void *fdt, int images, int *fdt_offsetp) +/* + * Iterate over all /configurations subnodes and call a platform specific + * function to find the matching configuration. + * Returns the node offset. + */ +static int spl_fit_find_config_node(const void *fdt) { - const char *name, *fdt_name; - int conf, node, fdt_node; - int len; + const char *name; + int conf, node, len;
- *fdt_offsetp = 0; conf = fdt_path_offset(fdt, FIT_CONFS_PATH); if (conf < 0) { debug("%s: Cannot find /configurations node: %d\n", __func__, @@ -50,39 +53,61 @@ static int spl_fit_select_fdt(const void *fdt, int images, int *fdt_offsetp) continue;
debug("Selecting config '%s'", name); - fdt_name = fdt_getprop(fdt, node, FIT_FDT_PROP, &len); - if (!fdt_name) { - debug("%s: Cannot find fdt name property: %d\n", - __func__, len); - return -EINVAL; - }
- debug(", fdt '%s'\n", fdt_name); - fdt_node = fdt_subnode_offset(fdt, images, fdt_name); - if (fdt_node < 0) { - debug("%s: Cannot find fdt node '%s': %d\n", - __func__, fdt_name, fdt_node); - return -EINVAL; + return node; + } + + return -1; +} + +static int spl_fit_select_index(const void *fit, int images, int *offsetp, + const char *type, int index) +{ + const char *name, *str; + int node, conf_node; + int len, i; + + *offsetp = 0; + conf_node = spl_fit_find_config_node(fit); + if (conf_node < 0) { +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT + printf("No matching DT out of these options:\n"); + for (node = fdt_first_subnode(fit, conf_node); + node >= 0; + node = fdt_next_subnode(fit, node)) { + name = fdt_getprop(fit, node, "description", &len); + printf(" %s\n", name); } +#endif + return -ENOENT; + }
- *fdt_offsetp = fdt_getprop_u32(fdt, fdt_node, "data-offset"); - len = fdt_getprop_u32(fdt, fdt_node, "data-size"); - debug("FIT: Selected '%s'\n", name); + name = fdt_getprop(fit, conf_node, type, &len); + if (!name) { + debug("cannot find property '%s': %d\n", type, len); + return -EINVAL; + }
- return len; + str = name; + for (i = 0; i < index; i++) { + str = strchr(str, '\0') + 1; + if (!str || (str - name >= len)) { + debug("no string for index %d\n", index); + return -E2BIG; + } }
-#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - printf("No matching DT out of these options:\n"); - for (node = fdt_first_subnode(fdt, conf); - node >= 0; - node = fdt_next_subnode(fdt, node)) { - name = fdt_getprop(fdt, node, "description", &len); - printf(" %s\n", name); + debug("%s: '%s'\n", type, str); + node = fdt_subnode_offset(fit, images, str); + if (node < 0) { + debug("cannot find image node '%s': %d\n", str, node); + return -EINVAL; } -#endif
- return -ENOENT; + *offsetp = fdt_getprop_u32(fit, node, "data-offset"); + len = fdt_getprop_u32(fit, node, "data-size"); + + return len; }
static int get_aligned_image_offset(struct spl_load_info *info, int offset) @@ -218,7 +243,8 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, memcpy(dst, src, data_size);
/* Figure out which device tree the board wants to use */ - fdt_len = spl_fit_select_fdt(fit, images, &fdt_offset); + fdt_len = spl_fit_select_index(fit, images, &fdt_offset, + FIT_FDT_PROP, 0); if (fdt_len < 0) return fdt_len;
Currently the SPL FIT loader always looks only for the first image in the /images node a FIT tree, which it loads and later executes.
Generalize this by looking for a "firmware" property in the matched configuration subnode, or, if that does not exist, for the first string in the "loadables" property. Then using the string in that property, load the image of that name from the /images node. This still loads only one image at the moment, but refactors the code to allow extending this in a following patch. To simplify later re-usage, we also generalize the spl_fit_select_index() function to not return the image location, but just the node offset.
Signed-off-by: Andre Przywara andre.przywara@arm.com Reviewed-by: Lokesh Vutla lokeshvuta@ti.com --- common/spl/spl_fit.c | 45 +++++++++++++++++++++++++++++++-------------- 1 file changed, 31 insertions(+), 14 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index bf9fbb6..a4ac27b 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -60,14 +60,24 @@ static int spl_fit_find_config_node(const void *fdt) return -1; }
-static int spl_fit_select_index(const void *fit, int images, int *offsetp, - const char *type, int index) +/* + * By using the matching configuration subnode, retrieve the name of an image, + * specified by a property name and an index into that. + * @fit: Pointer to the FDT blob. + * @images: Offset of the /images subnode. + * @type: Name of the property within the configuration subnode. + * @index: Index into the list of strings in this property. + * + * Returns the node offset of the respective image node or a negative error + * number. + */ +static int spl_fit_get_image_node(const void *fit, int images, + const char *type, int index) { const char *name, *str; int node, conf_node; int len, i;
- *offsetp = 0; conf_node = spl_fit_find_config_node(fit); if (conf_node < 0) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT @@ -104,10 +114,7 @@ static int spl_fit_select_index(const void *fit, int images, int *offsetp, return -EINVAL; }
- *offsetp = fdt_getprop_u32(fit, node, "data-offset"); - len = fdt_getprop_u32(fit, node, "data-size"); - - return len; + return node; }
static int get_aligned_image_offset(struct spl_load_info *info, int offset) @@ -193,15 +200,22 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, if (count == 0) return -EIO;
- /* find the firmware image to load */ + /* find the node holding the images information */ images = fdt_path_offset(fit, FIT_IMAGES_PATH); if (images < 0) { debug("%s: Cannot find /images node: %d\n", __func__, images); return -1; } - node = fdt_first_subnode(fit, images); + + /* find the U-Boot image */ + node = spl_fit_get_image_node(fit, images, "firmware", 0); + if (node < 0) { + debug("could not find firmware image, trying loadables...\n"); + node = spl_fit_get_image_node(fit, images, "loadables", 0); + } if (node < 0) { - debug("%s: Cannot find first image node: %d\n", __func__, node); + debug("%s: Cannot find u-boot image node: %d\n", + __func__, node); return -1; }
@@ -243,10 +257,13 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, memcpy(dst, src, data_size);
/* Figure out which device tree the board wants to use */ - fdt_len = spl_fit_select_index(fit, images, &fdt_offset, - FIT_FDT_PROP, 0); - if (fdt_len < 0) - return fdt_len; + node = spl_fit_get_image_node(fit, images, FIT_FDT_PROP, 0); + if (node < 0) { + debug("%s: cannot find FDT node\n", __func__); + return node; + } + fdt_offset = fdt_getprop_u32(fit, node, "data-offset"); + fdt_len = fdt_getprop_u32(fit, node, "data-size");
/* * Read the device tree and place it after the image. There may be
At the moment we ignore any errors due to missing FIT properties, instead go ahead and calculate our addresses with the -1 return value. Fix this and bail out if any of the mandatory properties are missing.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- common/spl/spl_fit.c | 15 +++++++++++++-- 1 file changed, 13 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index a4ac27b..55da37a 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -11,14 +11,17 @@ #include <libfdt.h> #include <spl.h>
+#define FDT_ERROR ((ulong)(-1)) + static ulong fdt_getprop_u32(const void *fdt, int node, const char *prop) { const u32 *cell; int len;
cell = fdt_getprop(fdt, node, prop, &len); - if (len != sizeof(*cell)) - return -1U; + if (!cell || len != sizeof(*cell)) + return FDT_ERROR; + return fdt32_to_cpu(*cell); }
@@ -221,7 +224,11 @@ int spl_load_simple_fit(struct spl_image_info *spl_image,
/* Get its information and set up the spl_image structure */ data_offset = fdt_getprop_u32(fit, node, "data-offset"); + if (data_offset == FDT_ERROR) + return -1; data_size = fdt_getprop_u32(fit, node, "data-size"); + if (data_size == FDT_ERROR) + return -1; load = fdt_getprop_u32(fit, node, "load"); debug("data_offset=%x, data_size=%x\n", data_offset, data_size); spl_image->load_addr = load; @@ -264,6 +271,10 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, } fdt_offset = fdt_getprop_u32(fit, node, "data-offset"); fdt_len = fdt_getprop_u32(fit, node, "data-size"); + if (fdt_offset == FDT_ERROR || fdt_len == FDT_ERROR) { + debug("%s: cannot load FDT data\n" __func__); + return -1; + }
At the moment we load two images from a FIT image: the actual U-Boot image and the .dtb file. Both times we have very similar code, that deals with alignment requirements the media we load from imposes upon us. Factor out this code into a new function, which we just call twice.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- common/spl/spl_fit.c | 160 +++++++++++++++++++++++++-------------------------- 1 file changed, 78 insertions(+), 82 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 55da37a..cfcb1fe 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -158,19 +158,79 @@ static int get_aligned_image_size(struct spl_load_info *info, int data_size, return (data_size + info->bl_len - 1) / info->bl_len; }
+/* + * spl_load_fit_image loads the image described in a certain FIT node. + * @info: points to information about the device to load data from + * @sector: the start sector of the FIT image on the device + * @fit: points to the flattened device tree blob describing the FIT image + * @base_offset: the beginning of the data area containing the actual + * image data, relative to the beginning of the FIT + * @node: offset of the DT node describing the image to load (relative to @fit) + * @image_info: will be filled with information about the loaded image + * If the FIT node does not contain a "load" (address) property, + * the image gets loaded to the address pointed to by the + * load_addr member in this struct. + * + * Returns an error value or 0 on success. + */ +static int spl_load_fit_image(struct spl_load_info *info, ulong sector, + void *fit, ulong base_offset, int node, + struct spl_image_info *image_info) +{ + ulong offset; + size_t length; + ulong load_addr, load_ptr; + void *src; + ulong overhead; + int nr_sectors; + int align_len = ARCH_DMA_MINALIGN - 1; + + offset = fdt_getprop_u32(fit, node, "data-offset"); + if (offset == FDT_ERROR) + return -ENOENT; + offset += base_offset; + length = fdt_getprop_u32(fit, node, "data-size"); + if (length == FDT_ERROR) + return -ENOENT; + load_addr = fdt_getprop_u32(fit, node, "load"); + if (load_addr == FDT_ERROR && image_info) + load_addr = image_info->load_addr; + load_ptr = (load_addr + align_len) & ~align_len; + + overhead = get_aligned_image_overhead(info, offset); + nr_sectors = get_aligned_image_size(info, length, offset); + + if (info->read(info, sector + get_aligned_image_offset(info, offset), + nr_sectors, (void*)load_ptr) != nr_sectors) + return -EIO; + debug("image: dst=%lx, offset=%lx, size=%lx\n", load_ptr, offset, + (unsigned long)length); + + src = (void *)load_ptr + overhead; +#ifdef CONFIG_SPL_FIT_IMAGE_POST_PROCESS + board_fit_image_post_process(&src, &length); +#endif + + memcpy((void*)load_addr, src, length); + + if (image_info) { + image_info->load_addr = load_addr; + image_info->size = length; + image_info->entry_point = fdt_getprop_u32(fit, node, "entry"); + } + + return 0; +} + int spl_load_simple_fit(struct spl_image_info *spl_image, struct spl_load_info *info, ulong sector, void *fit) { int sectors; - ulong size, load; + ulong size; unsigned long count; - int node, images; - void *load_ptr; - int fdt_offset, fdt_len; - int data_offset, data_size; + struct spl_image_info image_info; + int node, images, ret; int base_offset, align_len = ARCH_DMA_MINALIGN - 1; - int src_sector; - void *dst, *src;
/* * Figure out where the external images start. This is the base for the @@ -222,46 +282,13 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, return -1; }
- /* Get its information and set up the spl_image structure */ - data_offset = fdt_getprop_u32(fit, node, "data-offset"); - if (data_offset == FDT_ERROR) - return -1; - data_size = fdt_getprop_u32(fit, node, "data-size"); - if (data_size == FDT_ERROR) - return -1; - load = fdt_getprop_u32(fit, node, "load"); - debug("data_offset=%x, data_size=%x\n", data_offset, data_size); - spl_image->load_addr = load; - spl_image->entry_point = load; - spl_image->os = IH_OS_U_BOOT; - - /* - * Work out where to place the image. We read it so that the first - * byte will be at 'load'. This may mean we need to load it starting - * before then, since we can only read whole blocks. - */ - data_offset += base_offset; - sectors = get_aligned_image_size(info, data_size, data_offset); - load_ptr = (void *)load; - debug("U-Boot size %x, data %p\n", data_size, load_ptr); - dst = load_ptr; - - /* Read the image */ - src_sector = sector + get_aligned_image_offset(info, data_offset); - debug("Aligned image read: dst=%p, src_sector=%x, sectors=%x\n", - dst, src_sector, sectors); - count = info->read(info, src_sector, sectors, dst); - if (count != sectors) - return -EIO; - debug("image: dst=%p, data_offset=%x, size=%x\n", dst, data_offset, - data_size); - src = dst + get_aligned_image_overhead(info, data_offset); + /* Load the image and set up the spl_image structure */ + ret = spl_load_fit_image(info, sector, fit, base_offset, node, + spl_image); + if (ret) + return ret;
-#ifdef CONFIG_SPL_FIT_IMAGE_POST_PROCESS - board_fit_image_post_process((void **)&src, (size_t *)&data_size); -#endif - - memcpy(dst, src, data_size); + spl_image->os = IH_OS_U_BOOT;
/* Figure out which device tree the board wants to use */ node = spl_fit_get_image_node(fit, images, FIT_FDT_PROP, 0); @@ -269,43 +296,12 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, debug("%s: cannot find FDT node\n", __func__); return node; } - fdt_offset = fdt_getprop_u32(fit, node, "data-offset"); - fdt_len = fdt_getprop_u32(fit, node, "data-size"); - if (fdt_offset == FDT_ERROR || fdt_len == FDT_ERROR) { - debug("%s: cannot load FDT data\n" __func__); - return -1; - }
/* - * Read the device tree and place it after the image. There may be - * some extra data before it since we can only read entire blocks. - * And also align the destination address to ARCH_DMA_MINALIGN. + * Read the device tree and place it after the image. + * Align the destination address to ARCH_DMA_MINALIGN. */ - dst = (void *)((load + data_size + align_len) & ~align_len); - fdt_offset += base_offset; - sectors = get_aligned_image_size(info, fdt_len, fdt_offset); - src_sector = sector + get_aligned_image_offset(info, fdt_offset); - count = info->read(info, src_sector, sectors, dst); - debug("Aligned fdt read: dst %p, src_sector = %x, sectors %x\n", - dst, src_sector, sectors); - if (count != sectors) - return -EIO; - - /* - * Copy the device tree so that it starts immediately after the image. - * After this we will have the U-Boot image and its device tree ready - * for us to start. - */ - debug("fdt: dst=%p, data_offset=%x, size=%x\n", dst, fdt_offset, - fdt_len); - src = dst + get_aligned_image_overhead(info, fdt_offset); - dst = load_ptr + data_size; - -#ifdef CONFIG_SPL_FIT_IMAGE_POST_PROCESS - board_fit_image_post_process((void **)&src, (size_t *)&fdt_len); -#endif - - memcpy(dst, src, fdt_len); - - return 0; + image_info.load_addr = spl_image->load_addr + spl_image->size; + return spl_load_fit_image(info, sector, fit, base_offset, node, + &image_info); }
So far we were not using the FIT image format to its full potential: The SPL FIT loader was just loading the first image from the /images node plus one of the listed DTBs. Now with the refactored loader code it's easy to load an arbitrary number of images in addition to the two mentioned above. As described in the FIT image source file format description, iterate over all images listed at the "loadables" property in the configuration node and load every image at its desired location. This allows to load any kind of images: - firmware images to execute before U-Boot proper (for instance ARM Trusted Firmware (ATF)) - firmware images for management processors (SCP, arisc, ...) - firmware images for devices like WiFi controllers - bit files for FPGAs - additional configuration data - kernels and/or ramdisks The actual usage of this feature would be platform and/or board specific.
Also update the FIT documentation to mention the new SPL feature.
Signed-off-by: Andre Przywara andre.przywara@arm.com Reviewed-by: Lokesh Vutla lokeshvuta@ti.com --- common/spl/spl_fit.c | 42 ++++++++++++++++++++++++++++++++++++++++-- doc/uImage.FIT/howto.txt | 21 +++++++++++++++++++++ 2 files changed, 61 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index cfcb1fe..edf4a43 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -231,6 +231,7 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, struct spl_image_info image_info; int node, images, ret; int base_offset, align_len = ARCH_DMA_MINALIGN - 1; + int index = 0;
/* * Figure out where the external images start. This is the base for the @@ -275,6 +276,11 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, if (node < 0) { debug("could not find firmware image, trying loadables...\n"); node = spl_fit_get_image_node(fit, images, "loadables", 0); + /* + * If we pick the U-Boot image from "loadables", start at + * the second image when later loading additional images. + */ + index = 1; } if (node < 0) { debug("%s: Cannot find u-boot image node: %d\n", @@ -302,6 +308,38 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, * Align the destination address to ARCH_DMA_MINALIGN. */ image_info.load_addr = spl_image->load_addr + spl_image->size; - return spl_load_fit_image(info, sector, fit, base_offset, node, - &image_info); + ret = spl_load_fit_image(info, sector, fit, base_offset, node, + &image_info); + if (ret < 0) + return ret; + + /* Now check if there are more images for us to load */ + for (; ; index++) { + node = spl_fit_get_image_node(fit, images, "loadables", index); + if (node < 0) + break; + + ret = spl_load_fit_image(info, sector, fit, base_offset, node, + &image_info); + if (ret < 0) + continue; + + /* + * If the "firmware" image did not provide an entry point, + * use the first valid entry point from the loadables. + */ + if (spl_image->entry_point == FDT_ERROR && + image_info.entry_point != FDT_ERROR) + spl_image->entry_point = image_info.entry_point; + } + + /* + * If a platform does not provide CONFIG_SYS_UBOOT_START, U-Boot's + * Makefile will set it to 0 and it will end up as the entry point + * here. What it actually means is: use the load address. + */ + if (spl_image->entry_point == FDT_ERROR || spl_image->entry_point == 0) + spl_image->entry_point = spl_image->load_addr; + + return 0; } diff --git a/doc/uImage.FIT/howto.txt b/doc/uImage.FIT/howto.txt index 14e316f..2988a52 100644 --- a/doc/uImage.FIT/howto.txt +++ b/doc/uImage.FIT/howto.txt @@ -44,6 +44,27 @@ image source file mkimage + dtc transfer to target + ---------------> image file --------------------> bootm image data file(s)
+SPL usage +--------- + +The SPL can make use of the new image format as well, this traditionally +is used to ship multiple device tree files within one image. Code in the SPL +will choose the one matching the current board and append this to the +U-Boot proper binary to be automatically used up by it. +Aside from U-Boot proper and one device tree blob the SPL can load multiple, +arbitrary image files as well. These binaries should be specified in their +own subnode under the /images node, which should then be referenced from one or +multiple /configurations subnodes. The required images must be enumerated in +the "loadables" property as a list of strings. + +If a platform specific image source file (.its) is shipped with the U-Boot +source, it can be specified using the CONFIG_SPL_FIT_SOURCE Kconfig symbol. +In this case it will be automatically used by U-Boot's Makefile to generate +the image. +If a static source file is not flexible enough, CONFIG_SPL_FIT_GENERATOR +can point to a script which generates this image source file during +the build process. It gets passed a list of device tree files (taken from the +CONFIG_OF_LIST symbol).
Example 1 -- old-style (non-FDT) kernel booting -----------------------------------------------
mksunxiboot limits the size of the resulting SPL binaries to pretty conservative values to cover all SoCs and all boot media (NAND). It turns out that we have limit checks in place in the build process, so mksunxiboot can be relaxed and allow packaging binaries up to the actual 32KB the mask boot ROM actually imposes. This allows to have a bigger SPL, which is crucial for AArch64 builds.
Signed-off-by: Andre Przywara andre.przywara@arm.com Reviewed-by: Simon Glass sjg@chromium.org --- tools/mksunxiboot.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/mksunxiboot.c b/tools/mksunxiboot.c index 0f0b003..6bb649c 100644 --- a/tools/mksunxiboot.c +++ b/tools/mksunxiboot.c @@ -48,7 +48,7 @@ int gen_check_sum(struct boot_file_head *head_p) #define ALIGN(x, a) __ALIGN_MASK((x), (typeof(x))(a)-1) #define __ALIGN_MASK(x, mask) (((x)+(mask))&~(mask))
-#define SUN4I_SRAM_SIZE 0x7600 /* 0x7748+ is used by BROM */ +#define SUN4I_SRAM_SIZE 0x8000 /* SoC with smaller size are limited before */ #define SRAM_LOAD_MAX_SIZE (SUN4I_SRAM_SIZE - sizeof(struct boot_file_head))
Not every SoC needs to set up the GIC interrupt controller, so link think code only when the respective config option is set. This shaves off some bytes from the SPL code size.
Signed-off-by: Andre Przywara andre.przywara@arm.com Reviewed-by: Simon Glass sjg@chromium.org --- arch/arm/lib/Makefile | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index b95e105..5733430 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -44,7 +44,9 @@ ifdef CONFIG_CPU_V7M obj-y += interrupts_m.o else ifdef CONFIG_ARM64 obj-y += ccn504.o +ifneq ($(CONFIG_GICV2)$(CONFIG_GICV3),) obj-y += gic_64.o +endif obj-y += interrupts_64.o else obj-y += interrupts.o
The generic ARMv8 assembly code contains routines for setting up a CCN interconnect, though the Freescale SoCs are the only user. Link this code only for Freescale targets, this saves some precious bytes in the chronically tight SPL.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/lib/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 5733430..82154f6 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -43,7 +43,7 @@ obj-y += stack.o ifdef CONFIG_CPU_V7M obj-y += interrupts_m.o else ifdef CONFIG_ARM64 -obj-y += ccn504.o +obj-$(CONFIG_FSL_LAYERSCAPE) += ccn504.o ifneq ($(CONFIG_GICV2)$(CONFIG_GICV3),) obj-y += gic_64.o endif
The SPL stack is usually located at the end of SRAM A1, where it grows towards the end of the SPL. For the really big AArch64 binaries the stack overwrites code pretty soon, so move the SPL stack to the end of SRAM A2, which is unused at this time.
Signed-off-by: Andre Przywara andre.przywara@arm.com Reviewed-by: Simon Glass sjg@chromium.org --- include/configs/sunxi-common.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 171cea2..b7eb95e 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -182,7 +182,12 @@ #ifdef CONFIG_SUNXI_HIGH_SRAM #define CONFIG_SPL_TEXT_BASE 0x10040 /* sram start+header */ #define CONFIG_SPL_MAX_SIZE 0x7fc0 /* 32 KiB */ +#ifdef CONFIG_ARM64 +/* end of SRAM A2 for now, as SRAM A1 is pretty tight for an ARM64 build */ +#define LOW_LEVEL_SRAM_STACK 0x00054000 +#else #define LOW_LEVEL_SRAM_STACK 0x00018000 +#endif /* !CONFIG_ARM64 */ #else #define CONFIG_SPL_TEXT_BASE 0x40 /* sram start+header */ #define CONFIG_SPL_MAX_SIZE 0x5fc0 /* 24KB on sun4i/sun7i */
The sunxi SPL was holding the detected RAM size in some local variable only, so it wasn't accessible for other functions. Store the value in gd->ram_size instead, so it can be used later on.
Signed-off-by: Andre Przywara andre.przywara@arm.com Reviewed-by: Simon Glass sjg@chromium.org --- board/sunxi/board.c | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index b966012..a510422 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -480,7 +480,6 @@ void i2c_init_board(void) void sunxi_board_init(void) { int power_failed = 0; - unsigned long ramsize;
#ifdef CONFIG_SY8106A_POWER power_failed = sy8106a_set_vout1(CONFIG_SY8106A_VOUT1_VOLT); @@ -541,9 +540,9 @@ void sunxi_board_init(void) #endif #endif printf("DRAM:"); - ramsize = sunxi_dram_init(); - printf(" %d MiB\n", (int)(ramsize >> 20)); - if (!ramsize) + gd->ram_size = sunxi_dram_init(); + printf(" %d MiB\n", (int)(gd->ram_size >> 20)); + if (!gd->ram_size) hang();
For a board or platform to support FIT loading in the SPL, it has to provide a board_fit_config_name_match() routine, which helps to select one of possibly multiple DTBs contained in a FIT image. Provide a simple function which chooses the DT name U-Boot was configured with. If the DT name is one of the two Pine64 versions, determine the exact model by checking the DRAM size.
Signed-off-by: Andre Przywara andre.przywara@arm.com Reviewed-by: Simon Glass sjg@chromium.org --- board/sunxi/board.c | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index a510422..2ddff28 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -725,3 +725,26 @@ int ft_board_setup(void *blob, bd_t *bd) #endif return 0; } + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + const char *cmp_str; + +#ifdef CONFIG_DEFAULT_DEVICE_TREE + cmp_str = CONFIG_DEFAULT_DEVICE_TREE; +#else + return 0; +#endif + +/* Differentiate the two Pine64 board DTs by their DRAM size. */ + if (strstr(name, "-pine64") && strstr(cmp_str, "-pine64")) { + if ((gd->ram_size > 512 * 1024 * 1024)) + return !strstr(name, "plus"); + else + return !!strstr(name, "plus"); + } else { + return strcmp(name, cmp_str); + } +} +#endif
Some platforms require more complex U-Boot images than we can easily generate via the mkimage command line, for instance to load additional image files. Introduce a CONFIG_SPL_FIT_SOURCE and CONFIG_SPL_FIT_GENERATOR symbol, which can either hold an .its source file describing the image layout, or, in the second case, a generator tool (script) to create such a source file. This script gets passed the list of device tree files from the CONFIG_OF_LIST variable. A platform or board can define either of those in their defconfig file to allow an easy building of such an image.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- Kconfig | 17 +++++++++++++++++ Makefile | 20 ++++++++++++++++++++ 2 files changed, 37 insertions(+)
diff --git a/Kconfig b/Kconfig index e0744d1..69382ea 100644 --- a/Kconfig +++ b/Kconfig @@ -239,6 +239,23 @@ config SPL_FIT_IMAGE_POST_PROCESS injected into the FIT creation (i.e. the blobs would have been pre- processed before being added to the FIT image).
+config SPL_FIT_SOURCE + string ".its source file for U-Boot FIT image" + depends on SPL_FIT + help + Specifies a (platform specific) FIT source file to generate the + U-Boot FIT image. This could specify further image to load and/or + execute. + +config SPL_FIT_GENERATOR + string ".its file generator script for U-Boot FIT image" + depends on SPL_FIT + help + Specifies a (platform specific) script file to generate the FIT + source file used to build the U-Boot FIT image file. This gets + passed a list of supported device tree file stub names to + include in the generated image. + endif # FIT
config OF_BOARD_SETUP diff --git a/Makefile b/Makefile index 539fb20..5ecf40f 100644 --- a/Makefile +++ b/Makefile @@ -827,6 +827,10 @@ quiet_cmd_mkimage = MKIMAGE $@ cmd_mkimage = $(objtree)/tools/mkimage $(MKIMAGEFLAGS_$(@F)) -d $< $@ \ $(if $(KBUILD_VERBOSE:1=), >$(MKIMAGEOUTPUT))
+quiet_cmd_mkfitimage = MKIMAGE $@ +cmd_mkfitimage = $(objtree)/tools/mkimage $(MKIMAGEFLAGS_$(@F)) -f $(U_BOOT_ITS) -E $@ \ + $(if $(KBUILD_VERBOSE:1=), >$(MKIMAGEOUTPUT)) + quiet_cmd_cat = CAT $@ cmd_cat = cat $(filter-out $(PHONY), $^) > $@
@@ -946,6 +950,19 @@ quiet_cmd_cpp_cfg = CFG $@ cmd_cpp_cfg = $(CPP) -Wp,-MD,$(depfile) $(cpp_flags) $(LDPPFLAGS) -ansi \ -DDO_DEPS_ONLY -D__ASSEMBLY__ -x assembler-with-cpp -P -dM -E -o $@ $<
+# Boards with more complex image requirments can provide an .its source file +# or a generator script +ifneq ($(CONFIG_SPL_FIT_SOURCE),"") +U_BOOT_ITS = $(subst ",,$(CONFIG_SPL_FIT_SOURCE)) +else +ifneq ($(CONFIG_SPL_FIT_GENERATOR),"") +U_BOOT_ITS := u-boot.its +$(U_BOOT_ITS): FORCE + $(srctree)/$(CONFIG_SPL_FIT_GENERATOR) \ + $(patsubst %,arch/$(ARCH)/dts/%.dtb,$(subst ",,$(CONFIG_OF_LIST))) > $@ +endif +endif + ifdef CONFIG_SPL_LOAD_FIT MKIMAGEFLAGS_u-boot.img = -f auto -A $(ARCH) -T firmware -C none -O u-boot \ -a $(CONFIG_SYS_TEXT_BASE) -e $(CONFIG_SYS_UBOOT_START) \ @@ -978,6 +995,9 @@ u-boot-dtb.img u-boot.img u-boot.kwb u-boot.pbl u-boot-ivt.img: \ $(if $(CONFIG_SPL_LOAD_FIT),u-boot-nodtb.bin dts/dt.dtb,u-boot.bin) FORCE $(call if_changed,mkimage)
+u-boot.itb: u-boot-nodtb.bin dts/dt.dtb $(U_BOOT_ITS) FORCE + $(call if_changed,mkfitimage) + u-boot-spl.kwb: u-boot.img spl/u-boot-spl.bin FORCE $(call if_changed,mkimage)
Now that the Makefile can call a generator script to build a more advanced FIT image, let's use this feature to address the needs of Allwinner A64 boards. The (DTB stripped) U-Boot binary and the ATF are static, but we allow an arbitrary number of supported device trees to be passed. The script enters both a DT entry in the /images node and the respective subnode in /configurations to support all listed DTBs.
This requires to copy the ARM Trusted Firmware build (bl31.bin) into the U-Boot source directory (or to create a symlink to it).
Signed-off-by: Andre Przywara andre.przywara@arm.com Reviewed-by: Simon Glass sjg@chromium.org --- board/sunxi/mksunxi_fit_atf.sh | 73 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 73 insertions(+) create mode 100755 board/sunxi/mksunxi_fit_atf.sh
diff --git a/board/sunxi/mksunxi_fit_atf.sh b/board/sunxi/mksunxi_fit_atf.sh new file mode 100755 index 0000000..afa22e8 --- /dev/null +++ b/board/sunxi/mksunxi_fit_atf.sh @@ -0,0 +1,73 @@ +#!/bin/sh +# +# script to generate FIT image source for 64-bit sunxi boards with +# ARM Trusted Firmware and multiple device trees (given on the command line) +# +# usage: $0 <dt_name> [<dt_name> [<dt_name] ...] + +cat << __HEADER_EOF +/dts-v1/; + +/ { + description = "Configuration to load ATF before U-Boot"; + #address-cells = <1>; + + images { + uboot@1 { + description = "U-Boot (64-bit)"; + data = /incbin/("u-boot-nodtb.bin"); + type = "standalone"; + arch = "arm64"; + compression = "none"; + load = <0x4a000000>; + }; + atf@1 { + description = "ARM Trusted Firmware"; + data = /incbin/("bl31.bin"); + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <0x44000>; + entry = <0x44000>; + }; +__HEADER_EOF + +cnt=1 +for dtname in $* +do + cat << __FDT_IMAGE_EOF + fdt@$cnt { + description = "$(basename $dtname .dtb)"; + data = /incbin/("$dtname"); + type = "flat_dt"; + compression = "none"; + }; +__FDT_IMAGE_EOF + cnt=$((cnt+1)) +done + +cat << __CONF_HEADER_EOF + }; + configurations { + default = "config@1"; + +__CONF_HEADER_EOF + +cnt=1 +for dtname in $* +do + cat << __CONF_SECTION_EOF + config@$cnt { + description = "$(basename $dtname .dtb)"; + firmware = "uboot@1"; + loadables = "atf@1"; + fdt = "fdt@$cnt"; + }; +__CONF_SECTION_EOF + cnt=$((cnt+1)) +done + +cat << __ITS_EOF + }; +}; +__ITS_EOF
The Pine64 (and all other 64-bit Allwinner boards) need to load an ARM Trusted Firmware image beside the actual U-Boot proper. This can now be easily achieved by using the just extended SPL FIT loading support, so enable it in the Pine64 defconfig. Also add the FIT image as a build target to 64-bit sunxi board to trigger the respective Makefile rules.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- configs/pine64_plus_defconfig | 6 ++++++ include/configs/sunxi-common.h | 4 ++++ 2 files changed, 10 insertions(+)
diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index 92bda60..8a90579 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -3,9 +3,14 @@ CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN50I=y CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pine64-plus" +CONFIG_OF_LIST="sun50i-a64-pine64 sun50i-a64-pine64-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_SPL_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_OF_LIBFDT=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set @@ -14,3 +19,4 @@ CONFIG_SPL=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y +CONFIG_SPL_FIT_GENERATOR="board/sunxi/mksunxi_fit_atf.sh" diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index b7eb95e..1982063 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -32,6 +32,10 @@ # define CONFIG_MACH_TYPE_COMPAT_REV 1 #endif
+#ifdef CONFIG_ARM64 +#define CONFIG_BUILD_TARGET "u-boot.itb" +#endif + /* Serial & console */ #define CONFIG_SYS_NS16550_SERIAL /* ns16550 reg in the low bits of cpu reg */
Again, this doesn't make any sense to enable it in *all* our defconfigs. If this is something that should be enabled by default for the A64 support, then do so in Kconfig directly.
Maxime
Oh sorry, I think I completely misunderstood you last time. Indeed this makes sense, especially with more defconfigs for A64/H5 boards coming up.
I will think about a solution that makes Icenowy happy as well, something like BOARD_NEEDS_SPL_FIT or so - though a simple "select" sounds tempting ;-)
Cheers, Andre.
Throwing a bunch of select to reduce the number of options to enable would definitely be welcome indeed, at least between all the SPL_FIT* options.
Maxime
This sounds like a job for the new "imply" keyword in Kconfig :)
In fact we combine this with
# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_LEGACY_IMAGE_SUPPORT is not set
for our boards, so we can iterate through a list of potential boot sources than could contain a FIT image.
Cheers, Phil.
Enable the SPL FIT support and the FIT generator script for the OrangePi PC2 board, as it also need to load an ATF binary.
Signed-off-by: Andre Przywara andre.przywara@arm.com Reviewed-by: Simon Glass sjg@chromium.org --- configs/orangepi_pc2_defconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/configs/orangepi_pc2_defconfig b/configs/orangepi_pc2_defconfig index 19a5c2b..8a2d289 100644 --- a/configs/orangepi_pc2_defconfig +++ b/configs/orangepi_pc2_defconfig @@ -5,6 +5,12 @@ CONFIG_SPL=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881977 CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-pc2" +CONFIG_OF_LIST="sun50i-h5-orangepi-pc2" +CONFIG_FIT=y +CONFIG_SPL_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_OF_LIBFDT=y +CONFIG_SPL_FIT_GENERATOR="board/sunxi/mksunxi_fit_atf.sh" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y # CONFIG_CMD_IMLS is not set
From: Siarhei Siamashka siarhei.siamashka@gmail.com
This patch updates the mksunxiboot tool to optionally add the default device tree name string to the SPL header. This information can be used by the firmware upgrade tools to protect users from harming themselves by trying to upgrade to an incompatible bootloader.
The primary use case here is a non-removable bootable media (such as NAND, eMMC or SPI flash), which already may have a properly working, but a little bit outdated bootloader installed. For example, the user may download or build a new U-Boot image for "Cubieboard", and then attemept to install it on a "Cubieboard2" hardware by mistake as a replacement for the already existing bootloader. If this happens, the flash programming tool can identify this problem and warn the user.
The size of the SPL header is also increased from 64 bytes to 96 bytes to provide enough space for the device tree name string. [Andre: split patch to remove OF_LIST hash feature]
Signed-off-by: Siarhei Siamashka siarhei.siamashka@gmail.com Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/include/asm/arch-sunxi/spl.h | 19 +++++++++++--- include/configs/sunxi-common.h | 8 +++--- scripts/Makefile.spl | 3 ++- tools/mksunxiboot.c | 49 ++++++++++++++++++++++++++++++++--- 4 files changed, 67 insertions(+), 12 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/spl.h b/arch/arm/include/asm/arch-sunxi/spl.h index 831d0c0..9358397 100644 --- a/arch/arm/include/asm/arch-sunxi/spl.h +++ b/arch/arm/include/asm/arch-sunxi/spl.h @@ -10,7 +10,7 @@
#define BOOT0_MAGIC "eGON.BT0" #define SPL_SIGNATURE "SPL" /* marks "sunxi" SPL header */ -#define SPL_HEADER_VERSION 1 +#define SPL_HEADER_VERSION 2
#ifdef CONFIG_SUNXI_HIGH_SRAM #define SPL_ADDR 0x10000 @@ -58,11 +58,24 @@ struct boot_file_head { * compatible format, ready to be imported via "env import -t". */ uint32_t fel_uEnv_length; - uint32_t reserved1[2]; + /* + * Offset of an ASCIIZ string (relative to the SPL header), which + * contains the default device tree name (CONFIG_DEFAULT_DEVICE_TREE). + * This is optional and may be set to NULL. Is intended to be used + * by flash programming tools for providing nice informative messages + * to the users. + */ + uint32_t dt_name_offset; + uint32_t reserved1; uint32_t boot_media; /* written here by the boot ROM */ - uint32_t reserved2[5]; /* padding, align to 64 bytes */ + /* A padding area (may be used for storing text strings) */ + uint32_t string_pool[13]; + /* The header must be a multiple of 32 bytes (for VBAR alignment) */ };
+/* Compile time check to assure proper alignment of structure */ +typedef char boot_file_head_not_multiple_of_32[1 - 2*(sizeof(struct boot_file_head) % 32)]; + #define is_boot0_magic(addr) (memcmp((void *)addr, BOOT0_MAGIC, 8) == 0)
#endif diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 1982063..65f0f69 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -184,8 +184,8 @@ #endif
#ifdef CONFIG_SUNXI_HIGH_SRAM -#define CONFIG_SPL_TEXT_BASE 0x10040 /* sram start+header */ -#define CONFIG_SPL_MAX_SIZE 0x7fc0 /* 32 KiB */ +#define CONFIG_SPL_TEXT_BASE 0x10060 /* sram start+header */ +#define CONFIG_SPL_MAX_SIZE 0x7fa0 /* 32 KiB */ #ifdef CONFIG_ARM64 /* end of SRAM A2 for now, as SRAM A1 is pretty tight for an ARM64 build */ #define LOW_LEVEL_SRAM_STACK 0x00054000 @@ -193,8 +193,8 @@ #define LOW_LEVEL_SRAM_STACK 0x00018000 #endif /* !CONFIG_ARM64 */ #else -#define CONFIG_SPL_TEXT_BASE 0x40 /* sram start+header */ -#define CONFIG_SPL_MAX_SIZE 0x5fc0 /* 24KB on sun4i/sun7i */ +#define CONFIG_SPL_TEXT_BASE 0x60 /* sram start+header */ +#define CONFIG_SPL_MAX_SIZE 0x5fa0 /* 24KB on sun4i/sun7i */ #define LOW_LEVEL_SRAM_STACK 0x00008000 /* End of sram */ #endif
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index d01af3b..d134b74 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -294,7 +294,8 @@ $(obj)/$(SPL_BIN).sfp: $(obj)/$(SPL_BIN).bin FORCE $(call if_changed,mkimage)
quiet_cmd_mksunxiboot = MKSUNXI $@ -cmd_mksunxiboot = $(objtree)/tools/mksunxiboot $< $@ +cmd_mksunxiboot = $(objtree)/tools/mksunxiboot \ + --default-dt $(CONFIG_DEFAULT_DEVICE_TREE) $< $@ $(obj)/sunxi-spl.bin: $(obj)/$(SPL_BIN).bin FORCE $(call if_changed,mksunxiboot)
diff --git a/tools/mksunxiboot.c b/tools/mksunxiboot.c index 6bb649c..4ac2791 100644 --- a/tools/mksunxiboot.c +++ b/tools/mksunxiboot.c @@ -70,11 +70,40 @@ int main(int argc, char *argv[]) struct boot_img img; unsigned file_size; int count; + char *tool_name = argv[0]; + char *default_dt = NULL;
- if (argc < 2) { - printf("\tThis program makes an input bin file to sun4i " \ - "bootable image.\n" \ - "\tUsage: %s input_file out_putfile\n", argv[0]); + /* a sanity check */ + if ((sizeof(img.header) % 32) != 0) { + fprintf(stderr, "ERROR: the SPL header must be a multiple "); + fprintf(stderr, "of 32 bytes.\n"); + return EXIT_FAILURE; + } + + /* process optional command line switches */ + while (argc >= 2 && argv[1][0] == '-') { + if (strcmp(argv[1], "--default-dt") == 0) { + if (argc >= 3) { + default_dt = argv[2]; + argv += 2; + argc -= 2; + continue; + } + fprintf(stderr, "ERROR: no --default-dt arg\n"); + return EXIT_FAILURE; + } else { + fprintf(stderr, "ERROR: bad option '%s'\n", argv[1]); + return EXIT_FAILURE; + } + } + + if (argc < 3) { + printf("This program converts an input binary file to a sunxi bootable image.\n"); + printf("\nUsage: %s [options] input_file output_file\n", + tool_name); + printf("Where [options] may be:\n"); + printf(" --default-dt arg - 'arg' is the default device tree name\n"); + printf(" (CONFIG_DEFAULT_DEVICE_TREE).\n"); return EXIT_FAILURE; }
@@ -122,6 +151,18 @@ int main(int argc, char *argv[]) memcpy(img.header.spl_signature, SPL_SIGNATURE, 3); /* "sunxi" marker */ img.header.spl_signature[3] = SPL_HEADER_VERSION;
+ if (default_dt) { + if (strlen(default_dt) + 1 <= sizeof(img.header.string_pool)) { + strcpy((char *)img.header.string_pool, default_dt); + img.header.dt_name_offset = + cpu_to_le32(offsetof(struct boot_file_head, + string_pool)); + } else { + printf("WARNING: The SPL header is too small\n"); + printf(" and has no space to store the dt name.\n"); + } + } + gen_check_sum(&img.header);
count = write(fd_out, &img, le32_to_cpu(img.header.length));
Now that we can store a DT name in the SPL header, use this string (if available) when finding the right DT blob to load for U-Boot proper. This allows a generic U-Boot (proper) image to be combined with a bunch of supported DTs, with just the SPL (possibly only that string) to be different. Eventually this string can be written after the build process by some firmware update tool.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- board/sunxi/board.c | 12 +++++++++--- 1 file changed, 9 insertions(+), 3 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 2ddff28..714f8fd 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -729,13 +729,19 @@ int ft_board_setup(void *blob, bd_t *bd) #ifdef CONFIG_SPL_LOAD_FIT int board_fit_config_name_match(const char *name) { - const char *cmp_str; + struct boot_file_head *spl = (void *)(ulong)SPL_ADDR; + const char *cmp_str = (void *)(ulong)SPL_ADDR;
+ /* Check if there is a DT name stored in the SPL header and use that. */ + if (spl->dt_name_offset) { + cmp_str += spl->dt_name_offset; + } else { #ifdef CONFIG_DEFAULT_DEVICE_TREE - cmp_str = CONFIG_DEFAULT_DEVICE_TREE; + cmp_str = CONFIG_DEFAULT_DEVICE_TREE; #else - return 0; + return 0; #endif + };
/* Differentiate the two Pine64 board DTs by their DRAM size. */ if (strstr(name, "-pine64") && strstr(cmp_str, "-pine64")) {
With the DRAM init code and the SPL's ability to load the ATF binary as well, we can now officially get rid of the boot0 boot method, which involed a closed-source proprietary blob to be used. Rework the Pine64 README file to document how to build the firmware.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- board/sunxi/README.pine64 | 177 ++++++++++++++++++++++++++++++---------------- 1 file changed, 115 insertions(+), 62 deletions(-)
diff --git a/board/sunxi/README.pine64 b/board/sunxi/README.pine64 index 5553415..41fb58e 100644 --- a/board/sunxi/README.pine64 +++ b/board/sunxi/README.pine64 @@ -8,75 +8,130 @@ This chip has ARM Cortex A-53 cores and thus can run both in AArch32 in AArch32 mode and executes 32-bit code from the Boot ROM (BROM). This has some implications on U-Boot.
-Quick start -============ -- Get hold of a boot0.img file (see below for more details). -- Get the boot0img tool source from the tools directory in [1] and compile - that on your host. -- Build U-Boot: +Quick Start / Overview +====================== +- Build the ARM Trusted Firmware binary (see "ARM Trusted firmware (ATF)" below) +- Build U-Boot (see "SPL/U-Boot" below) +- Transfer to an uSD card (see "microSD card" below) +- Boot and enjoy! + +Building the firmware +===================== + +The Allwinner A64 firmware consists of three parts: U-Boot's SPL, an +ARM Trusted Firmware (ATF) build and the U-Boot proper. +The SPL will load both ATF and U-Boot proper along with the right device +tree blob (.dtb) and will pass execution to ATF (in EL3), which in turn will +drop into the U-Boot proper (in EL2). +As the ATF binary will become part of the U-Boot image file, you will need +to build it first. + + ARM Trusted firmware (ATF) +---------------------------- +Checkout the "allwinner" branch from the github repository [1] and build it: +$ export CROSS_COMPILE=aarch64-linux-gnu- +$ make PLAT=sun50iw1p1 DEBUG=1 bl31 + The resulting binary is build/sun50iw1p1/debug/bl31.bin. Copy this to the + root of the U-Boot source tree (or create a symbolic link). + + SPL/U-Boot +------------ +Both U-Boot proper and the SPL are using the 64-bit mode. As the boot ROM +enters the SPL still in AArch32 secure SVC mode, there is some shim code to +enter AArch64 very early. The rest of the SPL runs in AArch64 EL3. +U-boot proper runs in EL2 and can load any AArch64 code, EFI applications or +arm64 Linux kernel images (often named "Image") using the booti command. + +$ make clean $ export CROSS_COMPILE=aarch64-linux-gnu- $ make pine64_plus_defconfig $ make -- You also need a compiled ARM Trusted Firmware (ATF) binary. Checkout the - "allwinner" branch from the github repository [2] and build it: -$ export CROSS_COMPILE=aarch64-linux-gnu- -$ make PLAT=sun50iw1p1 DEBUG=1 bl31 - The resulting binary is build/sun50iw1p1/debug/bl31.bin.
-Now put an empty (or disposable) micro SD card in your card reader and learn -its device file name, replacing /dev/sd<x> below with the result (that could -be /dev/mmcblk<x> as well): +This will build the SPL in spl/sunxi-spl.bin and a FIT image called u-boot.itb, +which contains the rest of the firmware. +
-$ ./boot0img --device /dev/sd<x> -e -u u-boot.bin -B boot0.img \ - -d trampoline64:0x44000 -s bl31.bin -a 0x44008 -p 100 -(either copying the respective files to the working directory or specifying -the paths directly) +Boot process +============ +The on-die BROM code will try several methods to load and execute the firmware. +On the Pine64 this will result in the following boot order: +1) Reading 32KB from sector 16 (@8K) of the microSD card to SRAM A1. If the +BROM finds the magic "eGON" header in the first bytes, it will execute that +code. If not, it will: +2) Initialize the SPI0 controller and try to access a NOR flash connected to +it (using the CS0 pin). If a flash chip is found, the BROM will load the +first 32KB (from offset 0) into SRAM A1. Now it checks for the magic eGON +header and will execute the code upon finding it. If not, it will: +3) Initialize the USB OTG controller and will wait for a host to connect to +it, speaking the Allwinner proprietary (but deciphered) "FEL" USB protocol. + +To boot the Pine64 board, you can use U-Boot and any of the described methods.
-This will create a new partition table (with a 100 MB FAT boot partition), -copies boot0.img, ATF and U-Boot to the proper locations on the SD card and -will fill in the magic Allwinner header to be recognized by boot0. -Prefix the above call with "sudo" if you don't have write access to the -uSD card. You can also use "-o output.img" instead of "--device /dev/sd<x>" -to create an image file and "dd" that to the uSD card. -Omitting the "-p" option will skip the partition table. +FEL boot (USB OTG) +------------------ +FEL is the name of the Allwinner defined USB boot protocol built in the +mask ROM of most Allwinner SoCs. It allows to bootstrap a board solely +by using the USB-OTG interface and a host port on another computer. +As the FEL mode is controlled by the boot ROM, it expects to be running in +AArch32. For now the AArch64 SPL cannot properly return into FEL mode, so the +feature is disabled in the configuration at the moment.
-Now put this uSD card in the board and power it on. You should be greeted by -the U-Boot prompt. +microSD card +------------ +Transfer the SPL and the U-Boot FIT image directly to an uSD card: +# dd if=spl/sunxi-spl.bin of=/dev/sdx bs=8k seek=1 +# dd if=u-boot.itb of=/dev/sdx bs=8k seek=5 +# sync +(replace /dev/sdx with you SD card device file name, which could be +/dev/mmcblk[x] as well).
+Alternative you can concatenate the SPL and the U-Boot FIT image into a single +file and transfer that instead: +$ cat spl/sunxi-spl.bin u-boot.itb > u-boot-sunxi-with-spl.bin +# dd if=u-boot-sunxi-with-spl.bin of=/dev/sdx bs=8k seek=1
-Main U-Boot -============ -The main U-Boot proper is a real 64-bit ARMv8 port and runs entirely in the -64-bit AArch64 mode. It can load any AArch64 code, EFI applications or arm64 -Linux kernel images (often named "Image") using the booti command. -Launching 32-bit code and kernels is technically possible, though not without -drawbacks (or hacks to avoid them) and currently not implemented. +You can partition the microSD card, but leave the first MB unallocated (most +partitioning tools will do this anyway).
-SPL support -============ -The main task of the SPL support is to bring up the DRAM controller and make -DRAM actually accessible. At the moment there is no documentation or source -code available which would do this. -There are currently two ways to overcome this situation: using a tainted 32-bit -SPL (involving some hacks and resulting in a non-redistributable binary, thus -not described here) or using the Allwinner boot0 blob. - -boot0 method -------------- +NOR flash +--------- +The Pine64 board can be booted via an SPI NOR flash chip connected to SPI0/CS0 +on the PI-2 headers. The SoPine module and the Pinebook notebook come with +a SPI flash soldered already. +Create the SPL and FIT image like described above for the SD card. +Now connect either an "A to A" USB cable to the upper USB port on the Pine64 +or get an adaptor and use a regular A-microB cable connected to it. +Remove a microSD card from the slot and power on the board. +On your host computer download and build the sunxi-tools package[2], then +use "sunxi-fel" to access the board: +$ ./sunxi-fel ver -v -p +This should give you an output starting with: AWUSBFEX soc=00001689(A64) ... +Now use the sunxi-fel tool to write to the NOR flash: +$ ./sunxi-fel spiflash-write 0 spl/sunxi-spl.bin +$ ./sunxi-fel spiflash-write 32768 u-boot.itb +Now boot the board without an SD card inserted and you should see the +U-Boot prompt on the serial console. + +(Legacy) boot0 method +--------------------- boot0 is Allwiner's secondary program loader and it can be used as some kind -of SPL replacement to get U-Boot up and running. -The binary is a 32 KByte blob and contained on every Pine64 image distributed -so far. It can be easily extracted from a micro SD card or an image file: +of SPL replacement to get U-Boot up and running from an microSD card. +For some time using boot0 was the only option to get the Pine64 booted. +With working DRAM init code in U-Boot's SPL this is no longer necessary, +but this method is described here for the sake of completeness. + +The boot0 binary is a 32 KByte blob and contained in the official Pine64 images +distributed by Pine64 or Allwinner. It can be easily extracted from a micro +SD card or an image file: # dd if=/dev/sd<x> of=boot0.bin bs=8k skip=1 count=4 where /dev/sd<x> is the device name of the uSD card or the name of the image file. Apparently Allwinner allows re-distribution of this proprietary code as-is. -For the time being this boot0 blob is the only redistributable way of making -U-Boot work on the Pine64. Beside loading the various parts of the (original) -firmware it also switches the core into AArch64 mode. +This boot0 blob takes care of DRAM initialisation and loads the remaining +firmware parts, then switches the core into AArch64 mode. The original boot0 code looks for U-Boot at a certain place on an uSD card (at 19096 KB), also it expects a header with magic bytes and a checksum. -There is a tool called boot0img[1] which takes a boot0.bin image and a compiled +There is a tool called boot0img[3] which takes a boot0.bin image and a compiled U-Boot binary (plus other binaries) and will populate that header accordingly. To make space for the magic header, the pine64_plus_defconfig will make sure there is sufficient space at the beginning of the U-Boot binary. @@ -85,14 +140,12 @@ places on the uSD card and works around unused, but mandatory parts by using trampoline code. See the output of "boot0img -h" for more information. boot0img can also patch boot0 to avoid loading U-Boot from 19MB, instead fetching it from just behind the boot0 binary (-B option). +$ ./boot0img -o firmware.img -B boot0.img -u u-boot-dtb.bin -e -s bl31.bin \ +-a 0x44008 -d trampoline64:0x44000 +Then write this image to a microSD card, replacing /dev/sdx with the right +device file (see above): +$ dd if=firmware.img of=/dev/sdx bs=8k seek=1
-FEL boot -========= -FEL is the name of the Allwinner defined USB boot protocol built-in the -mask ROM of most Allwinner SoCs. It allows to bootstrap a board solely -by using the USB-OTG interface and a host port on another computer. -Since FEL boot does not work with boot0, it requires the libdram hack, which -is not described here. - -[1] https://github.com/apritzel/pine64/ -[2] https://github.com/apritzel/arm-trusted-firmware.git +[1] https://github.com/apritzel/arm-trusted-firmware.git +[2] git://github.com/linux-sunxi/sunxi-tools.git +[3] https://github.com/apritzel/pine64/
Hi Andre,
On 27 March 2017 at 18:45, Andre Przywara andre.przywara@arm.com wrote:
A fixed version of the SPL FIT loading series. The error handling has been improved, also quite some comments and documentation has been added. The README.pine64 file has been totally reworked to reflect the new way of building the firmware for the Pine64 (and other 64-bit Allwinner SoCs, really). Some minor bugs have been fixed and Reviewed-by: tags have been added.
The first five patches introduce the core of the extened SPL FIT loading support, see below for a description. Patches 6-9 make some room in the sunxi 64-bit SPL to allow compiling in the FIT loading bits. Patch 10 and 11 let the SPL choose the proper DT from the FIT image. The next two patches add the infrastructure and an actual generator script, so the FIT image is automatically created at build time. Patches 14 and 15 enable the SPL FIT support in the Pine64 and the OrangePi PC 2 defconfigs. The following two patches store a DT file name in the SPL header, so U-Boot can easily pick the proper DT when scanning the FIT image. The idea is that this DT name should stay with the board, ideally on eMMC or SPI flash. So both U-Boot and a firmware update tool could identify a board, updating with compatible firmware while keeping the DT name in place. Ideally a board vendor would once seed this name onto on-board storage like SPI flash. I kept those two patches in, as the work on replacing mksunxiboot with an mkimage extension is not ready yet. Feel free to drop those from the series if this is a problem. The final patch updates the Pine64 README file to document the current way of building U-Boot, which now includes the ARM Trusted Firmware build in its image.
I would be delighted if that series can make it into the next release, as this finally enables the fully open source firmware for the 64-bit Allwinner SoCs (including the ATF binary).
This series is based on sunxi/master, rebased upon origin/master.
This is marked as v2 but I don't see a change log on each patch. Do you have one please, or did I miss it?
participants (5)
Andre Przywara
Dr. Philipp Tomsich
Maxime Ripard
