[U-Boot] [PATCH 02/25] tools/ifdtool: Support writing multiple files (-w) simultaneously
Currently ifdtool only supports writing one file (-w) at a time. This looks verbose when generating u-boot.rom for x86 targets. This change allows at most 16 files to be written simultaneously.
Signed-off-by: Bin Meng bmeng.cn@gmail.com --- tools/ifdtool.c | 29 ++++++++++++++++++++++------- tools/ifdtool.h | 2 ++ 2 files changed, 24 insertions(+), 7 deletions(-)
diff --git a/tools/ifdtool.c b/tools/ifdtool.c index a4b481f..58640ca 100644 --- a/tools/ifdtool.c +++ b/tools/ifdtool.c @@ -732,6 +732,7 @@ static void print_usage(const char *name) " -x | --extract: extract intel fd modules\n" " -i | --inject <region>:<module> inject file <module> into region <region>\n" " -w | --write <addr>:<file> write file to appear at memory address <addr>\n" + " multiple files can be written simultaneously\n" " -s | --spifreq <20|33|50> set the SPI frequency\n" " -e | --em100 set SPI frequency to 20MHz and disable\n" " Dual Output Fast Read Support\n" @@ -782,7 +783,9 @@ int main(int argc, char *argv[]) char *addr_str = NULL; int region_type = -1, inputfreq = 0; enum spi_frequency spifreq = SPI_FREQUENCY_20MHZ; - unsigned int addr = 0; + unsigned int addr[WRITE_NUM] = { 0 }; + char *wr_fname[WRITE_NUM] = { NULL }; + unsigned char wr_idx, wr_num = 0; int rom_size = -1; bool write_it; char *filename; @@ -886,11 +889,17 @@ int main(int argc, char *argv[]) break; case 'w': mode_write = 1; - if (get_two_words(optarg, &addr_str, &src_fname)) { - print_usage(argv[0]); - exit(EXIT_FAILURE); + if (wr_num < WRITE_NUM) { + if (get_two_words(optarg, &addr_str, + &wr_fname[wr_num])) { + print_usage(argv[0]); + exit(EXIT_FAILURE); + } + addr[wr_num] = strtol(optarg, NULL, 0); + wr_num++; + } else { + fprintf(stderr, "The number of files to write simultaneously exceeds the limitation (%d)\n", WRITE_NUM); } - addr = strtol(optarg, NULL, 0); break; case 'x': mode_extract = 1; @@ -1002,8 +1011,14 @@ int main(int argc, char *argv[]) if (mode_inject) ret = inject_region(image, size, region_type, src_fname);
- if (mode_write) - ret = write_data(image, size, addr, src_fname); + if (mode_write) { + for (wr_idx = 0; wr_idx < wr_num; wr_idx++) { + ret = write_data(image, size, + addr[wr_idx], wr_fname[wr_idx]); + if (ret) + break; + } + }
if (mode_spifreq) set_spi_frequency(image, size, spifreq); diff --git a/tools/ifdtool.h b/tools/ifdtool.h index fbec421..72ba1de 100644 --- a/tools/ifdtool.h +++ b/tools/ifdtool.h @@ -14,6 +14,8 @@
#define IFDTOOL_VERSION "1.1-U-Boot"
+#define WRITE_NUM 16 + enum spi_frequency { SPI_FREQUENCY_20MHZ = 0, SPI_FREQUENCY_33MHZ = 1,
Hi Bin,
Do you need the initialiser?
exit(EXIT_FAILURE);
exit(EXIT_FAILURE);
wr_num++;
} else {
80cols.
if (mode_write)
if (mode_write) {
if (ret)
break;
} if (mode_spifreq) set_spi_frequency(image, size, spifreq);
How about WRITE_MAX?
enum spi_frequency { SPI_FREQUENCY_20MHZ = 0, SPI_FREQUENCY_33MHZ = 1, -- 1.8.2.1
Hi Simon,
On Fri, Dec 5, 2014 at 4:30 AM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
I don't think so. Will remove in v2.
exit(EXIT_FAILURE);
exit(EXIT_FAILURE);
wr_num++;
} else {
80cols.
Will fix.
if (mode_write)
if (mode_write) {
if (ret)
break;
Sure.
Regards, Bin
Bin Meng
