[U-Boot] blank line repeats last command
Now I've turned on command history, if I hit "return" on a blank line it is the same as hitting up arrow and return - in other words it repeats the last command.
That isn't helpful behaviour to my mind.
David Collier
www.dexdyne.com
(for a subset of commands)
David Collier
That is intentional behavior and has been that way (nearly) forever. It is configured via the command definition macro on a per-command basis. "Dangerous" commands do *not* repeat, commands that may be useful to repeat (e.g. displaying memory) do.
Hey, you were just complaining that you had to retype the IP address for repeated pings - now you are complaining that you don't have to type anything to repeat a command. Make up you mind if you want shortcuts or not! :-P
Best regards, gvb
ah - much more subtle than I was guessing then... if dangerous stuff doesn't do it, I'm much happier
:-P back
For my money, I'd want to see what I'd repeated, so I'd have been happy to have to use up-arrow, enter, rather then just enter.
But my views don't always prevail.
D
Best regards, gvb
David Collier
www.dexdyne.com
[snip]
D
Command repeating predates the implementation of command line history and works even if you don't have command line editing / history enabled.
Also, on commands like memory display, it auto-advances the address so that you can hit <return> multiple times to see the next chunk of memory. Command history requires you to edit the address manually to get the next chunk. (FWIIW, I would be happy to see most command repeats turned off, but memory display auto-advance is really nice.)
gvb
On Fri, Oct 23, 2009 at 1:55 PM, Jerry Van Baren gerald.vanbaren@ge.com wrote:
[snip]
D
I partly agree with David Collier on this matter. Before I discovered this was a feature, I was sure this was a bug, but I understand some of you reasoning.. just not all. For instance, I can understand why it's handy when dumping memory, but what's the rationale behind having 'cp.b' repeating? It's annoying when writing large files to slow (NOR) flash.
Best regards, Frank
gvb _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Indeed it is.
IMHO, rather than select a few "dangerous" commands to exempt from autorepeat, it should be off for most commands and selectively enabled for a handful of commands where it's really useful (such as autoincrement dumps).
-Scott
Indeed it is.
+1 - it generally annoys me too:)
Peter
Dear "David Collier",
In message <memo.20091023115619.2092P@postmaster+dexdyne.com.cix.co.uk> you wrote:
Please READ THE DOCUMENTATION.
participants (6)
David Collier
Frank Svendsbøe
Jerry Van Baren
Peter Tyser
Scott Wood
