[U-Boot] [PATCH 0/7] Add Rockchip RK3229 SoC
RK3229 is a Quad-core Cortex-A7 SoC, which supports: - 4K 10bit H.264/H.265,VP9. - 32KB internal memory; - eMMC 4.5.1, SD3.0; - DDR3, LPDDR2, LPDDR3; - HDMI 2.0 output, 4K@60Hz; - USB2.0 OTG and USB2.0 host;
Kever Yang (7): rockchip: mkimage: add support for rk322x soc rockchip: rk322x: add clock driver rockchip: rk322x: add pinctrl driver rockchip: rk322x: add dts file rockchip: rk322x: add basic soc support rockchip: rk322x: add sysreset driver rockchip: add evb_rk3229 board
arch/arm/dts/rk3229-evb.dts | 77 +++ arch/arm/dts/rk322x.dtsi | 710 ++++++++++++++++++++++++ arch/arm/include/asm/arch-rockchip/clock.h | 1 + arch/arm/include/asm/arch-rockchip/cru_rk322x.h | 215 +++++++ arch/arm/include/asm/arch-rockchip/grf_rk322x.h | 519 +++++++++++++++++ arch/arm/mach-rockchip/Kconfig | 14 + arch/arm/mach-rockchip/Makefile | 3 + arch/arm/mach-rockchip/rk322x-board-spl.c | 77 +++ arch/arm/mach-rockchip/rk322x-board.c | 159 ++++++ arch/arm/mach-rockchip/rk322x/Kconfig | 18 + arch/arm/mach-rockchip/rk322x/Makefile | 9 + arch/arm/mach-rockchip/rk322x/clk_rk322x.c | 33 ++ arch/arm/mach-rockchip/rk322x/syscon_rk322x.c | 22 + board/rockchip/evb_rk3229/Kconfig | 15 + board/rockchip/evb_rk3229/MAINTAINERS | 6 + board/rockchip/evb_rk3229/Makefile | 7 + board/rockchip/evb_rk3229/evb_rk3229.c | 12 + configs/evb-rk3229_defconfig | 44 ++ drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_rk322x.c | 413 ++++++++++++++ drivers/pinctrl/Kconfig | 10 + drivers/pinctrl/rockchip/Makefile | 1 + drivers/pinctrl/rockchip/pinctrl_rk322x.c | 295 ++++++++++ drivers/sysreset/sysreset_rk322x.c | 45 ++ include/configs/evb_rk3229.h | 60 ++ include/configs/rk322x_common.h | 92 +++ include/dt-bindings/clock/rk3228-cru.h | 247 +++++++++ tools/rkcommon.c | 1 + 28 files changed, 3106 insertions(+) create mode 100644 arch/arm/dts/rk3229-evb.dts create mode 100644 arch/arm/dts/rk322x.dtsi create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rk322x.h create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rk322x.h create mode 100644 arch/arm/mach-rockchip/rk322x-board-spl.c create mode 100644 arch/arm/mach-rockchip/rk322x-board.c create mode 100644 arch/arm/mach-rockchip/rk322x/Kconfig create mode 100644 arch/arm/mach-rockchip/rk322x/Makefile create mode 100644 arch/arm/mach-rockchip/rk322x/clk_rk322x.c create mode 100644 arch/arm/mach-rockchip/rk322x/syscon_rk322x.c create mode 100644 board/rockchip/evb_rk3229/Kconfig create mode 100644 board/rockchip/evb_rk3229/MAINTAINERS create mode 100644 board/rockchip/evb_rk3229/Makefile create mode 100644 board/rockchip/evb_rk3229/evb_rk3229.c create mode 100644 configs/evb-rk3229_defconfig create mode 100644 drivers/clk/rockchip/clk_rk322x.c create mode 100644 drivers/pinctrl/rockchip/pinctrl_rk322x.c create mode 100644 drivers/sysreset/sysreset_rk322x.c create mode 100644 include/configs/evb_rk3229.h create mode 100644 include/configs/rk322x_common.h create mode 100644 include/dt-bindings/clock/rk3228-cru.h
Add support for rk322x package header in mkimage tool.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
tools/rkcommon.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/rkcommon.c b/tools/rkcommon.c index fd95abc..6e9595f 100644 --- a/tools/rkcommon.c +++ b/tools/rkcommon.c @@ -74,6 +74,7 @@ struct spl_info { static struct spl_info spl_infos[] = { { "rk3036", "RK30", 0x1000, false, false }, { "rk3188", "RK31", 0x8000 - 0x800, true, false }, + { "rk322x", "RK32", 0x8000 - 0x1000, false, false }, { "rk3288", "RK32", 0x8000, false, false }, { "rk3328", "RK32", 0x8000 - 0x1000, false, false }, { "rk3399", "RK33", 0x20000, false, true },
- { "rk322x", "RK32", 0x8000 - 0x1000, false, false }, { "rk3288", "RK32", 0x8000, false, false }, { "rk3328", "RK32", 0x8000 - 0x1000, false, false }, { "rk3399", "RK33", 0x20000, false, true },
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Add clock driver init support for: - cpu, bus clock init; - emmc, sdmmc clock; - ddr clock;
arch/arm/include/asm/arch-rockchip/cru_rk322x.h | 215 ++++++++++++ drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_rk322x.c | 413 ++++++++++++++++++++++++ 3 files changed, 629 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rk322x.h create mode 100644 drivers/clk/rockchip/clk_rk322x.c
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk322x.h b/arch/arm/include/asm/arch-rockchip/cru_rk322x.h new file mode 100644 index 0000000..0a01f87 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/cru_rk322x.h @@ -0,0 +1,215 @@ +/* + * (C) Copyright 2015 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef _ASM_ARCH_CRU_RK322X_H +#define _ASM_ARCH_CRU_RK322X_H + +#include <common.h> + +#define MHz 1000000 +#define OSC_HZ (24 * MHz) + +#define APLL_HZ (600 * MHz) +#define GPLL_HZ (594 * MHz) + +#define CORE_PERI_HZ 150000000 +#define CORE_ACLK_HZ 300000000 + +#define BUS_ACLK_HZ 148500000 +#define BUS_HCLK_HZ 148500000 +#define BUS_PCLK_HZ 74250000 + +#define PERI_ACLK_HZ 148500000 +#define PERI_HCLK_HZ 148500000 +#define PERI_PCLK_HZ 74250000 + +/* Private data for the clock driver - used by rockchip_get_cru() */ +struct rk322x_clk_priv { + struct rk322x_cru *cru; + ulong rate; +}; + +struct rk322x_cru { + struct rk322x_pll { + unsigned int con0; + unsigned int con1; + unsigned int con2; + } pll[4]; + unsigned int reserved0[4]; + unsigned int cru_mode_con; + unsigned int cru_clksel_con[35]; + unsigned int cru_clkgate_con[16]; + unsigned int cru_softrst_con[9]; + unsigned int cru_misc_con; + unsigned int reserved1[2]; + unsigned int cru_glb_cnt_th; + unsigned int reserved2[3]; + unsigned int cru_glb_rst_st; + unsigned int reserved3[(0x1c0 - 0x150) / 4 - 1]; + unsigned int cru_sdmmc_con[2]; + unsigned int cru_sdio_con[2]; + unsigned int reserved4[2]; + unsigned int cru_emmc_con[2]; + unsigned int reserved5[4]; + unsigned int cru_glb_srst_fst_value; + unsigned int cru_glb_srst_snd_value; + unsigned int cru_pll_mask_con; +}; +check_member(rk322x_cru, cru_pll_mask_con, 0x01f8); + +struct pll_div { + u32 refdiv; + u32 fbdiv; + u32 postdiv1; + u32 postdiv2; + u32 frac; +}; + +enum { + /* PLLCON0*/ + PLL_BP_SHIFT = 15, + PLL_POSTDIV1_SHIFT = 12, + PLL_POSTDIV1_MASK = 7 << PLL_POSTDIV1_SHIFT, + PLL_FBDIV_SHIFT = 0, + PLL_FBDIV_MASK = 0xfff, + + /* PLLCON1 */ + PLL_RST_SHIFT = 14, + PLL_PD_SHIFT = 13, + PLL_PD_MASK = 1 << PLL_PD_SHIFT, + PLL_DSMPD_SHIFT = 12, + PLL_DSMPD_MASK = 1 << PLL_DSMPD_SHIFT, + PLL_LOCK_STATUS_SHIFT = 10, + PLL_LOCK_STATUS_MASK = 1 << PLL_LOCK_STATUS_SHIFT, + PLL_POSTDIV2_SHIFT = 6, + PLL_POSTDIV2_MASK = 7 << PLL_POSTDIV2_SHIFT, + PLL_REFDIV_SHIFT = 0, + PLL_REFDIV_MASK = 0x3f, + + /* CRU_MODE */ + GPLL_MODE_SHIFT = 12, + GPLL_MODE_MASK = 1 << GPLL_MODE_SHIFT, + GPLL_MODE_SLOW = 0, + GPLL_MODE_NORM, + CPLL_MODE_SHIFT = 8, + CPLL_MODE_MASK = 1 << CPLL_MODE_SHIFT, + CPLL_MODE_SLOW = 0, + CPLL_MODE_NORM, + DPLL_MODE_SHIFT = 4, + DPLL_MODE_MASK = 1 << DPLL_MODE_SHIFT, + DPLL_MODE_SLOW = 0, + DPLL_MODE_NORM, + APLL_MODE_SHIFT = 0, + APLL_MODE_MASK = 1 << APLL_MODE_SHIFT, + APLL_MODE_SLOW = 0, + APLL_MODE_NORM, + + /* CRU_CLK_SEL0_CON */ + BUS_ACLK_PLL_SEL_SHIFT = 13, + BUS_ACLK_PLL_SEL_MASK = 3 << BUS_ACLK_PLL_SEL_SHIFT, + BUS_ACLK_PLL_SEL_APLL = 0, + BUS_ACLK_PLL_SEL_GPLL, + BUS_ACLK_PLL_SEL_HDMIPLL, + BUS_ACLK_DIV_SHIFT = 8, + BUS_ACLK_DIV_MASK = 0x1f << BUS_ACLK_DIV_SHIFT, + CORE_CLK_PLL_SEL_SHIFT = 6, + CORE_CLK_PLL_SEL_MASK = 3 << CORE_CLK_PLL_SEL_SHIFT, + CORE_CLK_PLL_SEL_APLL = 0, + CORE_CLK_PLL_SEL_GPLL, + CORE_CLK_PLL_SEL_DPLL, + CORE_DIV_CON_SHIFT = 0, + CORE_DIV_CON_MASK = 0x1f << CORE_DIV_CON_SHIFT, + + /* CRU_CLK_SEL1_CON */ + BUS_PCLK_DIV_SHIFT = 12, + BUS_PCLK_DIV_MASK = 7 << BUS_PCLK_DIV_SHIFT, + BUS_HCLK_DIV_SHIFT = 8, + BUS_HCLK_DIV_MASK = 3 << BUS_HCLK_DIV_SHIFT, + CORE_ACLK_DIV_SHIFT = 4, + CORE_ACLK_DIV_MASK = 7 << CORE_ACLK_DIV_SHIFT, + CORE_PERI_DIV_SHIFT = 0, + CORE_PERI_DIV_MASK = 0xf << CORE_PERI_DIV_SHIFT, + + /* CRU_CLKSEL5_CON */ + GMAC_OUT_PLL_SHIFT = 15, + GMAC_OUT_PLL_MASK = 1 << GMAC_OUT_PLL_SHIFT, + GMAC_OUT_DIV_SHIFT = 8, + GMAC_OUT_DIV_MASK = 0x1f << GMAC_OUT_DIV_SHIFT, + MAC_PLL_SEL_SHIFT = 7, + MAC_PLL_SEL_MASK = 1 << MAC_PLL_SEL_SHIFT, + RMII_EXTCLK_SLE_SHIFT = 5, + RMII_EXTCLK_SEL_MASK = 1 << RMII_EXTCLK_SLE_SHIFT, + RMII_EXTCLK_SEL_INT = 0, + RMII_EXTCLK_SEL_EXT, + CLK_MAC_DIV_SHIFT = 0, + CLK_MAC_DIV_MASK = 0x1f << CLK_MAC_DIV_SHIFT, + + /* CRU_CLKSEL10_CON */ + PERI_PCLK_DIV_SHIFT = 12, + PERI_PCLK_DIV_MASK = 7 << PERI_PCLK_DIV_SHIFT, + PERI_PLL_SEL_SHIFT = 10, + PERI_PLL_SEL_MASK = 3 << PERI_PLL_SEL_SHIFT, + PERI_PLL_CPLL = 0, + PERI_PLL_GPLL, + PERI_PLL_HDMIPLL, + PERI_HCLK_DIV_SHIFT = 8, + PERI_HCLK_DIV_MASK = 3 << PERI_HCLK_DIV_SHIFT, + PERI_ACLK_DIV_SHIFT = 0, + PERI_ACLK_DIV_MASK = 0x1f << PERI_ACLK_DIV_SHIFT, + + /* CRU_CLKSEL11_CON */ + EMMC_PLL_SHIFT = 12, + EMMC_PLL_MASK = 3 << EMMC_PLL_SHIFT, + EMMC_SEL_APLL = 0, + EMMC_SEL_DPLL, + EMMC_SEL_GPLL, + EMMC_SEL_24M, + SDIO_PLL_SHIFT = 10, + SDIO_PLL_MASK = 3 << SDIO_PLL_SHIFT, + SDIO_SEL_APLL = 0, + SDIO_SEL_DPLL, + SDIO_SEL_GPLL, + SDIO_SEL_24M, + MMC0_PLL_SHIFT = 8, + MMC0_PLL_MASK = 3 << MMC0_PLL_SHIFT, + MMC0_SEL_APLL = 0, + MMC0_SEL_DPLL, + MMC0_SEL_GPLL, + MMC0_SEL_24M, + MMC0_DIV_SHIFT = 0, + MMC0_DIV_MASK = 0xff << MMC0_DIV_SHIFT, + + /* CRU_CLKSEL12_CON */ + EMMC_DIV_SHIFT = 8, + EMMC_DIV_MASK = 0xff << EMMC_DIV_SHIFT, + SDIO_DIV_SHIFT = 0, + SDIO_DIV_MASK = 0xff << SDIO_DIV_SHIFT, + + /* CRU_CLKSEL26_CON */ + DDR_CLK_PLL_SEL_SHIFT = 8, + DDR_CLK_PLL_SEL_MASK = 3 << DDR_CLK_PLL_SEL_SHIFT, + DDR_CLK_SEL_DPLL = 0, + DDR_CLK_SEL_GPLL, + DDR_CLK_SEL_APLL, + DDR_DIV_SEL_SHIFT = 0, + DDR_DIV_SEL_MASK = 3 << DDR_DIV_SEL_SHIFT, + + /* CRU_CLKSEL27_CON */ + VOP_DCLK_DIV_SHIFT = 8, + VOP_DCLK_DIV_MASK = 0xff << VOP_DCLK_DIV_SHIFT, + VOP_PLL_SEL_SHIFT = 1, + VOP_PLL_SEL_MASK = 1 << VOP_PLL_SEL_SHIFT, + + /* CRU_CLKSEL29_CON */ + GMAC_CLK_SRC_SHIFT = 12, + GMAC_CLK_SRC_MASK = 1 << GMAC_CLK_SRC_SHIFT, + + /* CRU_SOFTRST5_CON */ + DDRCTRL_PSRST_SHIFT = 11, + DDRCTRL_SRST_SHIFT = 10, + DDRPHY_PSRST_SHIFT = 9, + DDRPHY_SRST_SHIFT = 8, +}; +#endif diff --git a/drivers/clk/rockchip/Makefile b/drivers/clk/rockchip/Makefile index e404c0c..c50aff2 100644 --- a/drivers/clk/rockchip/Makefile +++ b/drivers/clk/rockchip/Makefile @@ -6,6 +6,7 @@
obj-$(CONFIG_ROCKCHIP_RK3036) += clk_rk3036.o obj-$(CONFIG_ROCKCHIP_RK3188) += clk_rk3188.o +obj-$(CONFIG_ROCKCHIP_RK322X) += clk_rk322x.o obj-$(CONFIG_ROCKCHIP_RK3288) += clk_rk3288.o obj-$(CONFIG_ROCKCHIP_RK3328) += clk_rk3328.o obj-$(CONFIG_ROCKCHIP_RK3368) += clk_rk3368.o diff --git a/drivers/clk/rockchip/clk_rk322x.c b/drivers/clk/rockchip/clk_rk322x.c new file mode 100644 index 0000000..582ef88 --- /dev/null +++ b/drivers/clk/rockchip/clk_rk322x.c @@ -0,0 +1,413 @@ +/* + * (C) Copyright 2015 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/cru_rk322x.h> +#include <asm/arch/hardware.h> +#include <dm/lists.h> +#include <dt-bindings/clock/rk3228-cru.h> +#include <linux/log2.h> + +DECLARE_GLOBAL_DATA_PTR; + +enum { + VCO_MAX_HZ = 3200U * 1000000, + VCO_MIN_HZ = 800 * 1000000, + OUTPUT_MAX_HZ = 3200U * 1000000, + OUTPUT_MIN_HZ = 24 * 1000000, +}; + +#define RATE_TO_DIV(input_rate, output_rate) \ + ((input_rate) / (output_rate) - 1); + +#define DIV_TO_RATE(input_rate, div) ((input_rate) / ((div) + 1)) + +#define PLL_DIVISORS(hz, _refdiv, _postdiv1, _postdiv2) {\ + .refdiv = _refdiv,\ + .fbdiv = (u32)((u64)hz * _refdiv * _postdiv1 * _postdiv2 / OSC_HZ), \ + .postdiv1 = _postdiv1, .postdiv2 = _postdiv2};\ + _Static_assert(((u64)hz * _refdiv * _postdiv1 * _postdiv2 / OSC_HZ) * \ + OSC_HZ / (_refdiv * _postdiv1 * _postdiv2) == hz, \ + #hz "Hz cannot be hit with PLL "\ + "divisors on line " __stringify(__LINE__)); + +/* use interge mode*/ +static const struct pll_div apll_init_cfg = PLL_DIVISORS(APLL_HZ, 1, 3, 1); +static const struct pll_div gpll_init_cfg = PLL_DIVISORS(GPLL_HZ, 2, 2, 1); + +static int rkclk_set_pll(struct rk322x_cru *cru, enum rk_clk_id clk_id, + const struct pll_div *div) +{ + int pll_id = rk_pll_id(clk_id); + struct rk322x_pll *pll = &cru->pll[pll_id]; + + /* All PLLs have same VCO and output frequency range restrictions. */ + uint vco_hz = OSC_HZ / 1000 * div->fbdiv / div->refdiv * 1000; + uint output_hz = vco_hz / div->postdiv1 / div->postdiv2; + + debug("PLL at %x: fb=%d, ref=%d, pst1=%d, pst2=%d, vco=%u Hz, output=%u Hz\n", + pll, div->fbdiv, div->refdiv, div->postdiv1, + div->postdiv2, vco_hz, output_hz); + assert(vco_hz >= VCO_MIN_HZ && vco_hz <= VCO_MAX_HZ && + output_hz >= OUTPUT_MIN_HZ && output_hz <= OUTPUT_MAX_HZ); + + /* use interger mode */ + rk_setreg(&pll->con1, 1 << PLL_DSMPD_SHIFT); + /* Power down */ + rk_setreg(&pll->con1, 1 << PLL_PD_SHIFT); + + rk_clrsetreg(&pll->con0, + PLL_POSTDIV1_MASK | PLL_FBDIV_MASK, + (div->postdiv1 << PLL_POSTDIV1_SHIFT) | div->fbdiv); + rk_clrsetreg(&pll->con1, PLL_POSTDIV2_MASK | PLL_REFDIV_MASK, + (div->postdiv2 << PLL_POSTDIV2_SHIFT | + div->refdiv << PLL_REFDIV_SHIFT)); + + /* Power Up */ + rk_clrreg(&pll->con1, 1 << PLL_PD_SHIFT); + + /* waiting for pll lock */ + while (readl(&pll->con1) & (1 << PLL_LOCK_STATUS_SHIFT)) + udelay(1); + + return 0; +} + +static void rkclk_init(struct rk322x_cru *cru) +{ + u32 aclk_div; + u32 hclk_div; + u32 pclk_div; + + /* pll enter slow-mode */ + rk_clrsetreg(&cru->cru_mode_con, + GPLL_MODE_MASK | APLL_MODE_MASK, + GPLL_MODE_SLOW << GPLL_MODE_SHIFT | + APLL_MODE_SLOW << APLL_MODE_SHIFT); + + /* init pll */ + rkclk_set_pll(cru, CLK_ARM, &apll_init_cfg); + rkclk_set_pll(cru, CLK_GENERAL, &gpll_init_cfg); + + /* + * select apll as cpu/core clock pll source and + * set up dependent divisors for PERI and ACLK clocks. + * core hz : apll = 1:1 + */ + aclk_div = APLL_HZ / CORE_ACLK_HZ - 1; + assert((aclk_div + 1) * CORE_ACLK_HZ == APLL_HZ && aclk_div < 0x7); + + pclk_div = APLL_HZ / CORE_PERI_HZ - 1; + assert((pclk_div + 1) * CORE_PERI_HZ == APLL_HZ && pclk_div < 0xf); + + rk_clrsetreg(&cru->cru_clksel_con[0], + CORE_CLK_PLL_SEL_MASK | CORE_DIV_CON_MASK, + CORE_CLK_PLL_SEL_APLL << CORE_CLK_PLL_SEL_SHIFT | + 0 << CORE_DIV_CON_SHIFT); + + rk_clrsetreg(&cru->cru_clksel_con[1], + CORE_ACLK_DIV_MASK | CORE_PERI_DIV_MASK, + aclk_div << CORE_ACLK_DIV_SHIFT | + pclk_div << CORE_PERI_DIV_SHIFT); + + /* + * select apll as pd_bus bus clock source and + * set up dependent divisors for PCLK/HCLK and ACLK clocks. + */ + aclk_div = GPLL_HZ / BUS_ACLK_HZ - 1; + assert((aclk_div + 1) * BUS_ACLK_HZ == GPLL_HZ && aclk_div <= 0x1f); + + pclk_div = GPLL_HZ / BUS_PCLK_HZ - 1; + assert((pclk_div + 1) * BUS_PCLK_HZ == GPLL_HZ && pclk_div <= 0x7); + + hclk_div = GPLL_HZ / BUS_HCLK_HZ - 1; + assert((hclk_div + 1) * BUS_HCLK_HZ == GPLL_HZ && hclk_div <= 0x3); + + rk_clrsetreg(&cru->cru_clksel_con[0], + BUS_ACLK_PLL_SEL_MASK | BUS_ACLK_DIV_MASK, + BUS_ACLK_PLL_SEL_GPLL << BUS_ACLK_PLL_SEL_SHIFT | + aclk_div << BUS_ACLK_DIV_SHIFT); + + rk_clrsetreg(&cru->cru_clksel_con[1], + BUS_PCLK_DIV_MASK | BUS_HCLK_DIV_MASK, + pclk_div << BUS_PCLK_DIV_SHIFT | + hclk_div << BUS_HCLK_DIV_SHIFT); + + /* + * select gpll as pd_peri bus clock source and + * set up dependent divisors for PCLK/HCLK and ACLK clocks. + */ + aclk_div = GPLL_HZ / PERI_ACLK_HZ - 1; + assert((aclk_div + 1) * PERI_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f); + + hclk_div = ilog2(PERI_ACLK_HZ / PERI_HCLK_HZ); + assert((1 << hclk_div) * PERI_HCLK_HZ == + PERI_ACLK_HZ && (hclk_div < 0x4)); + + pclk_div = ilog2(PERI_ACLK_HZ / PERI_PCLK_HZ); + assert((1 << pclk_div) * PERI_PCLK_HZ == + PERI_ACLK_HZ && pclk_div < 0x8); + + rk_clrsetreg(&cru->cru_clksel_con[10], + PERI_PLL_SEL_MASK | PERI_PCLK_DIV_MASK | + PERI_HCLK_DIV_MASK | PERI_ACLK_DIV_MASK, + PERI_PLL_GPLL << PERI_PLL_SEL_SHIFT | + pclk_div << PERI_PCLK_DIV_SHIFT | + hclk_div << PERI_HCLK_DIV_SHIFT | + aclk_div << PERI_ACLK_DIV_SHIFT); + + /* PLL enter normal-mode */ + rk_clrsetreg(&cru->cru_mode_con, + GPLL_MODE_MASK | APLL_MODE_MASK, + GPLL_MODE_NORM << GPLL_MODE_SHIFT | + APLL_MODE_NORM << APLL_MODE_SHIFT); +} + +/* Get pll rate by id */ +static uint32_t rkclk_pll_get_rate(struct rk322x_cru *cru, + enum rk_clk_id clk_id) +{ + uint32_t refdiv, fbdiv, postdiv1, postdiv2; + uint32_t con; + int pll_id = rk_pll_id(clk_id); + struct rk322x_pll *pll = &cru->pll[pll_id]; + static u8 clk_shift[CLK_COUNT] = { + 0xff, APLL_MODE_SHIFT, DPLL_MODE_SHIFT, 0xff, + GPLL_MODE_SHIFT, 0xff + }; + static u32 clk_mask[CLK_COUNT] = { + 0xff, APLL_MODE_MASK, DPLL_MODE_MASK, 0xff, + GPLL_MODE_MASK, 0xff + }; + uint shift; + uint mask; + + con = readl(&cru->cru_mode_con); + shift = clk_shift[clk_id]; + mask = clk_mask[clk_id]; + + switch ((con & mask) >> shift) { + case GPLL_MODE_SLOW: + return OSC_HZ; + case GPLL_MODE_NORM: + + /* normal mode */ + con = readl(&pll->con0); + postdiv1 = (con & PLL_POSTDIV1_MASK) >> PLL_POSTDIV1_SHIFT; + fbdiv = (con & PLL_FBDIV_MASK) >> PLL_FBDIV_SHIFT; + con = readl(&pll->con1); + postdiv2 = (con & PLL_POSTDIV2_MASK) >> PLL_POSTDIV2_SHIFT; + refdiv = (con & PLL_REFDIV_MASK) >> PLL_REFDIV_SHIFT; + return (24 * fbdiv / (refdiv * postdiv1 * postdiv2)) * 1000000; + default: + return 32768; + } +} + +static ulong rockchip_mmc_get_clk(struct rk322x_cru *cru, uint clk_general_rate, + int periph) +{ + uint src_rate; + uint div, mux; + u32 con; + + switch (periph) { + case HCLK_EMMC: + case SCLK_EMMC: + con = readl(&cru->cru_clksel_con[11]); + mux = (con & EMMC_PLL_MASK) >> EMMC_PLL_SHIFT; + con = readl(&cru->cru_clksel_con[12]); + div = (con & EMMC_DIV_MASK) >> EMMC_DIV_SHIFT; + break; + case HCLK_SDMMC: + case SCLK_SDMMC: + con = readl(&cru->cru_clksel_con[11]); + mux = (con & MMC0_PLL_MASK) >> MMC0_PLL_SHIFT; + div = (con & MMC0_DIV_MASK) >> MMC0_DIV_SHIFT; + break; + default: + return -EINVAL; + } + + src_rate = mux == EMMC_SEL_24M ? OSC_HZ : clk_general_rate; + return DIV_TO_RATE(src_rate, div); +} + +static ulong rockchip_mmc_set_clk(struct rk322x_cru *cru, uint clk_general_rate, + int periph, uint freq) +{ + int src_clk_div; + int mux; + + debug("%s: clk_general_rate=%u\n", __func__, clk_general_rate); + + /* mmc clock auto divide 2 in internal */ + src_clk_div = (clk_general_rate / 2 + freq - 1) / freq; + + if (src_clk_div > 0x7f) { + src_clk_div = (OSC_HZ / 2 + freq - 1) / freq; + mux = EMMC_SEL_24M; + } else { + mux = EMMC_SEL_GPLL; + } + + switch (periph) { + case HCLK_EMMC: + case SCLK_EMMC: + rk_clrsetreg(&cru->cru_clksel_con[11], + EMMC_PLL_MASK, + mux << EMMC_PLL_SHIFT); + rk_clrsetreg(&cru->cru_clksel_con[12], + EMMC_DIV_MASK, + (src_clk_div - 1) << EMMC_DIV_SHIFT); + break; + case HCLK_SDMMC: + case SCLK_SDMMC: + rk_clrsetreg(&cru->cru_clksel_con[11], + MMC0_PLL_MASK | MMC0_DIV_MASK, + mux << MMC0_PLL_SHIFT | + (src_clk_div - 1) << MMC0_DIV_SHIFT); + break; + default: + return -EINVAL; + } + + return rockchip_mmc_get_clk(cru, clk_general_rate, periph); +} + +static int rk322x_ddr_set_clk(struct rk322x_cru *cru, unsigned int set_rate) +{ + struct pll_div dpll_cfg; + + /* clk_ddrc == DPLL = 24MHz / refdiv * fbdiv / postdiv1 / postdiv2 */ + switch (set_rate) { + case 400*MHz: + dpll_cfg = (struct pll_div) + {.refdiv = 1, .fbdiv = 50, .postdiv1 = 3, .postdiv2 = 1}; + break; + case 600*MHz: + dpll_cfg = (struct pll_div) + {.refdiv = 1, .fbdiv = 75, .postdiv1 = 3, .postdiv2 = 1}; + break; + case 800*MHz: + dpll_cfg = (struct pll_div) + {.refdiv = 1, .fbdiv = 100, .postdiv1 = 3, .postdiv2 = 1}; + break; + } + + /* pll enter slow-mode */ + rk_clrsetreg(&cru->cru_mode_con, DPLL_MODE_MASK, + DPLL_MODE_SLOW << DPLL_MODE_SHIFT); + rkclk_set_pll(cru, CLK_DDR, &dpll_cfg); + /* PLL enter normal-mode */ + rk_clrsetreg(&cru->cru_mode_con, DPLL_MODE_MASK, + DPLL_MODE_NORM << DPLL_MODE_SHIFT); + + return set_rate; +} +static ulong rk322x_clk_get_rate(struct clk *clk) +{ + struct rk322x_clk_priv *priv = dev_get_priv(clk->dev); + ulong rate, gclk_rate; + + gclk_rate = rkclk_pll_get_rate(priv->cru, CLK_GENERAL); + switch (clk->id) { + case 0 ... 63: + rate = rkclk_pll_get_rate(priv->cru, clk->id); + break; + case HCLK_EMMC: + case SCLK_EMMC: + case HCLK_SDMMC: + case SCLK_SDMMC: + rate = rockchip_mmc_get_clk(priv->cru, gclk_rate, clk->id); + break; + default: + return -ENOENT; + } + + return rate; +} + +static ulong rk322x_clk_set_rate(struct clk *clk, ulong rate) +{ + struct rk322x_clk_priv *priv = dev_get_priv(clk->dev); + ulong new_rate, gclk_rate; + + gclk_rate = rkclk_pll_get_rate(priv->cru, CLK_GENERAL); + switch (clk->id) { + case HCLK_EMMC: + case SCLK_EMMC: + case HCLK_SDMMC: + case SCLK_SDMMC: + new_rate = rockchip_mmc_set_clk(priv->cru, gclk_rate, + clk->id, rate); + break; + case CLK_DDR: + new_rate = rk322x_ddr_set_clk(priv->cru, rate); + break; + default: + return -ENOENT; + } + + return new_rate; +} + +static struct clk_ops rk322x_clk_ops = { + .get_rate = rk322x_clk_get_rate, + .set_rate = rk322x_clk_set_rate, +}; + +static int rk322x_clk_ofdata_to_platdata(struct udevice *dev) +{ + struct rk322x_clk_priv *priv = dev_get_priv(dev); + + priv->cru = (struct rk322x_cru *)devfdt_get_addr(dev); + + return 0; +} + +static int rk322x_clk_probe(struct udevice *dev) +{ + struct rk322x_clk_priv *priv = dev_get_priv(dev); + + rkclk_init(priv->cru); + + return 0; +} + +static int rk322x_clk_bind(struct udevice *dev) +{ + int ret; + + /* The reset driver does not have a device node, so bind it here */ + ret = device_bind_driver(gd->dm_root, "rk322x_sysreset", "reset", &dev); + if (ret) + debug("Warning: No RK3036 reset driver: ret=%d\n", ret); + + return 0; +} + +static const struct udevice_id rk322x_clk_ids[] = { + { .compatible = "rockchip,rk3228-cru" }, + { } +}; + +U_BOOT_DRIVER(rockchip_rk322x_cru) = { + .name = "clk_rk322x", + .id = UCLASS_CLK, + .of_match = rk322x_clk_ids, + .priv_auto_alloc_size = sizeof(struct rk322x_clk_priv), + .ofdata_to_platdata = rk322x_clk_ofdata_to_platdata, + .ops = &rk322x_clk_ops, + .bind = rk322x_clk_bind, + .probe = rk322x_clk_probe, +};
- ddr clock;
- (C) Copyright 2015 Rockchip Electronics Co., Ltd
- struct rk322x_cru *cru;
- ulong rate;
- struct rk322x_pll {
unsigned int con0;
unsigned int con1;
unsigned int con2;
- } pll[4];
- unsigned int reserved0[4];
- unsigned int cru_mode_con;
- unsigned int cru_clksel_con[35];
- unsigned int cru_clkgate_con[16];
- unsigned int cru_softrst_con[9];
- unsigned int cru_misc_con;
- unsigned int reserved1[2];
- unsigned int cru_glb_cnt_th;
- unsigned int reserved2[3];
- unsigned int cru_glb_rst_st;
- unsigned int reserved3[(0x1c0 - 0x150) / 4 - 1];
It took me a moment to understand why the 'minus one'.
Could you introduce a macro for this along the lines of U32_ELEMS_START_TO_LAST(0x1c0, 0x14c) or something similar... I fail to come up with a concise name that clearly says "from 0x1c0 and covering up to, but excluding, the address 0x150").
- unsigned int cru_sdmmc_con[2];
- unsigned int cru_sdio_con[2];
- unsigned int reserved4[2];
- unsigned int cru_emmc_con[2];
- unsigned int reserved5[4];
- unsigned int cru_glb_srst_fst_value;
- unsigned int cru_glb_srst_snd_value;
- unsigned int cru_pll_mask_con;
+struct pll_div {
- u32 refdiv;
- u32 fbdiv;
- u32 postdiv1;
- u32 postdiv2;
- u32 frac;
+enum {
- /* PLLCON0*/
- PLL_BP_SHIFT = 15,
- PLL_POSTDIV1_SHIFT = 12,
- PLL_POSTDIV1_MASK = 7 << PLL_POSTDIV1_SHIFT,
- PLL_FBDIV_SHIFT = 0,
- PLL_FBDIV_MASK = 0xfff,
- /* PLLCON1 */
- PLL_RST_SHIFT = 14,
- PLL_PD_SHIFT = 13,
- PLL_PD_MASK = 1 << PLL_PD_SHIFT,
- PLL_DSMPD_SHIFT = 12,
- PLL_DSMPD_MASK = 1 << PLL_DSMPD_SHIFT,
- PLL_LOCK_STATUS_SHIFT = 10,
- PLL_LOCK_STATUS_MASK = 1 << PLL_LOCK_STATUS_SHIFT,
- PLL_POSTDIV2_SHIFT = 6,
- PLL_POSTDIV2_MASK = 7 << PLL_POSTDIV2_SHIFT,
- PLL_REFDIV_SHIFT = 0,
- PLL_REFDIV_MASK = 0x3f,
- /* CRU_MODE */
- GPLL_MODE_SHIFT = 12,
- GPLL_MODE_MASK = 1 << GPLL_MODE_SHIFT,
- GPLL_MODE_SLOW = 0,
- GPLL_MODE_NORM,
- CPLL_MODE_SHIFT = 8,
- CPLL_MODE_MASK = 1 << CPLL_MODE_SHIFT,
- CPLL_MODE_SLOW = 0,
- CPLL_MODE_NORM,
- DPLL_MODE_SHIFT = 4,
- DPLL_MODE_MASK = 1 << DPLL_MODE_SHIFT,
- DPLL_MODE_SLOW = 0,
- DPLL_MODE_NORM,
- APLL_MODE_SHIFT = 0,
- APLL_MODE_MASK = 1 << APLL_MODE_SHIFT,
- APLL_MODE_SLOW = 0,
- APLL_MODE_NORM,
- /* CRU_CLK_SEL0_CON */
- BUS_ACLK_PLL_SEL_SHIFT = 13,
- BUS_ACLK_PLL_SEL_MASK = 3 << BUS_ACLK_PLL_SEL_SHIFT,
- BUS_ACLK_PLL_SEL_APLL = 0,
- BUS_ACLK_PLL_SEL_GPLL,
- BUS_ACLK_PLL_SEL_HDMIPLL,
- BUS_ACLK_DIV_SHIFT = 8,
- BUS_ACLK_DIV_MASK = 0x1f << BUS_ACLK_DIV_SHIFT,
- CORE_CLK_PLL_SEL_SHIFT = 6,
- CORE_CLK_PLL_SEL_MASK = 3 << CORE_CLK_PLL_SEL_SHIFT,
- CORE_CLK_PLL_SEL_APLL = 0,
- CORE_CLK_PLL_SEL_GPLL,
- CORE_CLK_PLL_SEL_DPLL,
- CORE_DIV_CON_SHIFT = 0,
- CORE_DIV_CON_MASK = 0x1f << CORE_DIV_CON_SHIFT,
- /* CRU_CLK_SEL1_CON */
- BUS_PCLK_DIV_SHIFT = 12,
- BUS_PCLK_DIV_MASK = 7 << BUS_PCLK_DIV_SHIFT,
- BUS_HCLK_DIV_SHIFT = 8,
- BUS_HCLK_DIV_MASK = 3 << BUS_HCLK_DIV_SHIFT,
- CORE_ACLK_DIV_SHIFT = 4,
- CORE_ACLK_DIV_MASK = 7 << CORE_ACLK_DIV_SHIFT,
- CORE_PERI_DIV_SHIFT = 0,
- CORE_PERI_DIV_MASK = 0xf << CORE_PERI_DIV_SHIFT,
- /* CRU_CLKSEL5_CON */
- GMAC_OUT_PLL_SHIFT = 15,
- GMAC_OUT_PLL_MASK = 1 << GMAC_OUT_PLL_SHIFT,
- GMAC_OUT_DIV_SHIFT = 8,
- GMAC_OUT_DIV_MASK = 0x1f << GMAC_OUT_DIV_SHIFT,
- MAC_PLL_SEL_SHIFT = 7,
- MAC_PLL_SEL_MASK = 1 << MAC_PLL_SEL_SHIFT,
- RMII_EXTCLK_SLE_SHIFT = 5,
- RMII_EXTCLK_SEL_MASK = 1 << RMII_EXTCLK_SLE_SHIFT,
- RMII_EXTCLK_SEL_INT = 0,
- RMII_EXTCLK_SEL_EXT,
- CLK_MAC_DIV_SHIFT = 0,
- CLK_MAC_DIV_MASK = 0x1f << CLK_MAC_DIV_SHIFT,
- /* CRU_CLKSEL10_CON */
- PERI_PCLK_DIV_SHIFT = 12,
- PERI_PCLK_DIV_MASK = 7 << PERI_PCLK_DIV_SHIFT,
- PERI_PLL_SEL_SHIFT = 10,
- PERI_PLL_SEL_MASK = 3 << PERI_PLL_SEL_SHIFT,
- PERI_PLL_CPLL = 0,
- PERI_PLL_GPLL,
- PERI_PLL_HDMIPLL,
- PERI_HCLK_DIV_SHIFT = 8,
- PERI_HCLK_DIV_MASK = 3 << PERI_HCLK_DIV_SHIFT,
- PERI_ACLK_DIV_SHIFT = 0,
- PERI_ACLK_DIV_MASK = 0x1f << PERI_ACLK_DIV_SHIFT,
- /* CRU_CLKSEL11_CON */
- EMMC_PLL_SHIFT = 12,
- EMMC_PLL_MASK = 3 << EMMC_PLL_SHIFT,
- EMMC_SEL_APLL = 0,
- EMMC_SEL_DPLL,
- EMMC_SEL_GPLL,
- EMMC_SEL_24M,
- SDIO_PLL_SHIFT = 10,
- SDIO_PLL_MASK = 3 << SDIO_PLL_SHIFT,
- SDIO_SEL_APLL = 0,
- SDIO_SEL_DPLL,
- SDIO_SEL_GPLL,
- SDIO_SEL_24M,
- MMC0_PLL_SHIFT = 8,
- MMC0_PLL_MASK = 3 << MMC0_PLL_SHIFT,
- MMC0_SEL_APLL = 0,
- MMC0_SEL_DPLL,
- MMC0_SEL_GPLL,
- MMC0_SEL_24M,
- MMC0_DIV_SHIFT = 0,
- MMC0_DIV_MASK = 0xff << MMC0_DIV_SHIFT,
- /* CRU_CLKSEL12_CON */
- EMMC_DIV_SHIFT = 8,
- EMMC_DIV_MASK = 0xff << EMMC_DIV_SHIFT,
- SDIO_DIV_SHIFT = 0,
- SDIO_DIV_MASK = 0xff << SDIO_DIV_SHIFT,
- /* CRU_CLKSEL26_CON */
- DDR_CLK_PLL_SEL_SHIFT = 8,
- DDR_CLK_PLL_SEL_MASK = 3 << DDR_CLK_PLL_SEL_SHIFT,
- DDR_CLK_SEL_DPLL = 0,
- DDR_CLK_SEL_GPLL,
- DDR_CLK_SEL_APLL,
- DDR_DIV_SEL_SHIFT = 0,
- DDR_DIV_SEL_MASK = 3 << DDR_DIV_SEL_SHIFT,
- /* CRU_CLKSEL27_CON */
- VOP_DCLK_DIV_SHIFT = 8,
- VOP_DCLK_DIV_MASK = 0xff << VOP_DCLK_DIV_SHIFT,
- VOP_PLL_SEL_SHIFT = 1,
- VOP_PLL_SEL_MASK = 1 << VOP_PLL_SEL_SHIFT,
- /* CRU_CLKSEL29_CON */
- GMAC_CLK_SRC_SHIFT = 12,
- GMAC_CLK_SRC_MASK = 1 << GMAC_CLK_SRC_SHIFT,
- /* CRU_SOFTRST5_CON */
- DDRCTRL_PSRST_SHIFT = 11,
- DDRCTRL_SRST_SHIFT = 10,
- DDRPHY_PSRST_SHIFT = 9,
- DDRPHY_SRST_SHIFT = 8,
- (C) Copyright 2015 Google, Inc
+enum {
- VCO_MAX_HZ = 3200U * 1000000,
- VCO_MIN_HZ = 800 * 1000000,
- OUTPUT_MAX_HZ = 3200U * 1000000,
- OUTPUT_MIN_HZ = 24 * 1000000,
- ((input_rate) / (output_rate) - 1);
The RATE_TO_DIV macro remains unused below.
- .refdiv = _refdiv,\
- .fbdiv = (u32)((u64)hz * _refdiv * _postdiv1 * _postdiv2 / OSC_HZ), \
- .postdiv1 = _postdiv1, .postdiv2 = _postdiv2};\
- _Static_assert(((u64)hz * _refdiv * _postdiv1 * _postdiv2 / OSC_HZ) * \
typo: integer
- int pll_id = rk_pll_id(clk_id);
- struct rk322x_pll *pll = &cru->pll[pll_id];
- /* All PLLs have same VCO and output frequency range restrictions. */
- uint vco_hz = OSC_HZ / 1000 * div->fbdiv / div->refdiv * 1000;
- uint output_hz = vco_hz / div->postdiv1 / div->postdiv2;
- debug("PLL at %x: fb=%d, ref=%d, pst1=%d, pst2=%d, vco=%u Hz, output=%u Hz\n",
- assert(vco_hz >= VCO_MIN_HZ && vco_hz <= VCO_MAX_HZ &&
- /* use interger mode */
- rk_setreg(&pll->con1, 1 << PLL_DSMPD_SHIFT);
- /* Power down */
- rk_setreg(&pll->con1, 1 << PLL_PD_SHIFT);
- rk_clrsetreg(&pll->con0,
- rk_clrsetreg(&pll->con1, PLL_POSTDIV2_MASK | PLL_REFDIV_MASK,
- /* Power Up */
- rk_clrreg(&pll->con1, 1 << PLL_PD_SHIFT);
- /* waiting for pll lock */
- while (readl(&pll->con1) & (1 << PLL_LOCK_STATUS_SHIFT))
udelay(1);
- u32 aclk_div;
- u32 hclk_div;
- u32 pclk_div;
- /* pll enter slow-mode */
- rk_clrsetreg(&cru->cru_mode_con,
- /* init pll */
- rkclk_set_pll(cru, CLK_ARM, &apll_init_cfg);
- rkclk_set_pll(cru, CLK_GENERAL, &gpll_init_cfg);
- aclk_div = APLL_HZ / CORE_ACLK_HZ - 1;
- assert((aclk_div + 1) * CORE_ACLK_HZ == APLL_HZ && aclk_div < 0x7);
- pclk_div = APLL_HZ / CORE_PERI_HZ - 1;
- assert((pclk_div + 1) * CORE_PERI_HZ == APLL_HZ && pclk_div < 0xf);
- rk_clrsetreg(&cru->cru_clksel_con[0],
- rk_clrsetreg(&cru->cru_clksel_con[1],
- aclk_div = GPLL_HZ / BUS_ACLK_HZ - 1;
- assert((aclk_div + 1) * BUS_ACLK_HZ == GPLL_HZ && aclk_div <= 0x1f);
- pclk_div = GPLL_HZ / BUS_PCLK_HZ - 1;
- assert((pclk_div + 1) * BUS_PCLK_HZ == GPLL_HZ && pclk_div <= 0x7);
- hclk_div = GPLL_HZ / BUS_HCLK_HZ - 1;
- assert((hclk_div + 1) * BUS_HCLK_HZ == GPLL_HZ && hclk_div <= 0x3);
- aclk_div = GPLL_HZ / PERI_ACLK_HZ - 1;
- assert((aclk_div + 1) * PERI_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f);
- hclk_div = ilog2(PERI_ACLK_HZ / PERI_HCLK_HZ);
- assert((1 << hclk_div) * PERI_HCLK_HZ ==
- pclk_div = ilog2(PERI_ACLK_HZ / PERI_PCLK_HZ);
- assert((1 << pclk_div) * PERI_PCLK_HZ ==
- rk_clrsetreg(&cru->cru_clksel_con[10],
- /* PLL enter normal-mode */
- uint32_t refdiv, fbdiv, postdiv1, postdiv2;
- uint32_t con;
- static u8 clk_shift[CLK_COUNT] = {
- static u32 clk_mask[CLK_COUNT] = {
- uint shift;
- uint mask;
- con = readl(&cru->cru_mode_con);
- shift = clk_shift[clk_id];
- mask = clk_mask[clk_id];
- switch ((con & mask) >> shift) {
- case GPLL_MODE_SLOW:
return OSC_HZ;
- case GPLL_MODE_NORM:
/* normal mode */
- default:
return 32768;
int periph)
- uint src_rate;
- uint div, mux;
- u32 con;
- switch (periph) {
- case HCLK_EMMC:
- case SCLK_EMMC:
break;
- case HCLK_SDMMC:
- case SCLK_SDMMC:
break;
- default:
return -EINVAL;
- src_rate = mux == EMMC_SEL_24M ? OSC_HZ : clk_general_rate;
- return DIV_TO_RATE(src_rate, div);
- int src_clk_div;
- int mux;
- debug("%s: clk_general_rate=%u\n", __func__, clk_general_rate);
- /* mmc clock auto divide 2 in internal */
- src_clk_div = (clk_general_rate / 2 + freq - 1) / freq;
- if (src_clk_div > 0x7f) {
mux = EMMC_SEL_24M;
- } else {
- switch (periph) {
- case HCLK_EMMC:
- case SCLK_EMMC:
EMMC_PLL_MASK,
EMMC_DIV_MASK,
break;
- case HCLK_SDMMC:
- case SCLK_SDMMC:
break;
- default:
return -EINVAL;
- return rockchip_mmc_get_clk(cru, clk_general_rate, periph);
- struct pll_div dpll_cfg;
- /* clk_ddrc == DPLL = 24MHz / refdiv * fbdiv / postdiv1 / postdiv2 */
- switch (set_rate) {
- case 400*MHz:
break;
- case 600*MHz:
break;
- case 800*MHz:
break;
- rk_clrsetreg(&cru->cru_mode_con, DPLL_MODE_MASK,
- rkclk_set_pll(cru, CLK_DDR, &dpll_cfg);
- return set_rate;
- struct rk322x_clk_priv *priv = dev_get_priv(clk->dev);
- ulong rate, gclk_rate;
- gclk_rate = rkclk_pll_get_rate(priv->cru, CLK_GENERAL);
- switch (clk->id) {
- case 0 ... 63:
break;
- case HCLK_EMMC:
- case SCLK_EMMC:
- case HCLK_SDMMC:
- case SCLK_SDMMC:
break;
- default:
return -ENOENT;
- return rate;
- ulong new_rate, gclk_rate;
- case HCLK_EMMC:
- case SCLK_EMMC:
- case HCLK_SDMMC:
- case SCLK_SDMMC:
clk->id, rate);
break;
- case CLK_DDR:
break;
- default:
return -ENOENT;
- return new_rate;
- .get_rate = rk322x_clk_get_rate,
- .set_rate = rk322x_clk_set_rate,
- struct rk322x_clk_priv *priv = dev_get_priv(dev);
- priv->cru = (struct rk322x_cru *)devfdt_get_addr(dev);
- rkclk_init(priv->cru);
- int ret;
- /* The reset driver does not have a device node, so bind it here */
- ret = device_bind_driver(gd->dm_root, "rk322x_sysreset", "reset", &dev);
- if (ret)
- { .compatible = "rockchip,rk3228-cru" },
- .name = "clk_rk322x",
- .id = UCLASS_CLK,
- .of_match = rk322x_clk_ids,
- .priv_auto_alloc_size = sizeof(struct rk322x_clk_priv),
- .ofdata_to_platdata = rk322x_clk_ofdata_to_platdata,
- .ops = &rk322x_clk_ops,
- .bind = rk322x_clk_bind,
- .probe = rk322x_clk_probe,
Hi Philipp,
- ddr clock;
- ulong rate;
unsigned int con0;
unsigned int con1;
unsigned int con2;
- } pll[4];
Well, I will keep it as-is for this patch set, because this is widely used for all other Rockchip SoCs, if we need to do this, we'd better have a clean for all of them.
Thanks, - Kever
On 23 Jun 2017, at 10:49, Kever Yang kever.yang@rock-chips.com wrote:
Hi Philipp,
- ddr clock;
- ulong rate;
unsigned int con0;
unsigned int con1;
unsigned int con2;
- } pll[4];
Ok. I’ll apply as is.
Add init pinctrl driver support for: - i2c; - spi; - uart; - pwm; - emmc/sdmmc;
arch/arm/include/asm/arch-rockchip/grf_rk322x.h | 519 ++++++++++++++++++++++++ drivers/pinctrl/Kconfig | 10 + drivers/pinctrl/rockchip/Makefile | 1 + drivers/pinctrl/rockchip/pinctrl_rk322x.c | 295 ++++++++++++++ 4 files changed, 825 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rk322x.h create mode 100644 drivers/pinctrl/rockchip/pinctrl_rk322x.c
diff --git a/arch/arm/include/asm/arch-rockchip/grf_rk322x.h b/arch/arm/include/asm/arch-rockchip/grf_rk322x.h new file mode 100644 index 0000000..26071c8 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/grf_rk322x.h @@ -0,0 +1,519 @@ +/* + * (C) Copyright 2017 Rockchip Electronics Co., Ltd. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef _ASM_ARCH_GRF_RK322X_H +#define _ASM_ARCH_GRF_RK322X_H + +#include <common.h> + +struct rk322x_grf { + unsigned int gpio0a_iomux; + unsigned int gpio0b_iomux; + unsigned int gpio0c_iomux; + unsigned int gpio0d_iomux; + + unsigned int gpio1a_iomux; + unsigned int gpio1b_iomux; + unsigned int gpio1c_iomux; + unsigned int gpio1d_iomux; + + unsigned int gpio2a_iomux; + unsigned int gpio2b_iomux; + unsigned int gpio2c_iomux; + unsigned int gpio2d_iomux; + + unsigned int gpio3a_iomux; + unsigned int gpio3b_iomux; + unsigned int gpio3c_iomux; + unsigned int gpio3d_iomux; + + unsigned int reserved1[4]; + unsigned int con_iomux; + unsigned int reserved2[(0x100 - 0x50) / 4 - 1]; + unsigned int gpio0_p[4]; + unsigned int gpio1_p[4]; + unsigned int gpio2_p[4]; + unsigned int gpio3_p[4]; + unsigned int reserved3[(0x200 - 0x13c) / 4 - 1]; + unsigned int gpio0_e[4]; + unsigned int gpio1_e[4]; + unsigned int gpio2_e[4]; + unsigned int gpio3_e[4]; + unsigned int reserved4[(0x400 - 0x23c) / 4 - 1]; + unsigned int soc_con[7]; + unsigned int reserved5[(0x480 - 0x418) / 4 - 1]; + unsigned int soc_status[3]; + unsigned int chip_id; + unsigned int reserved6[(0x500 - 0x48c) / 4 - 1]; + unsigned int cpu_con[4]; + unsigned int reserved7[4]; + unsigned int cpu_status[2]; + unsigned int reserved8[(0x5c8 - 0x524) / 4 - 1]; + unsigned int os_reg[8]; + unsigned int reserved9[(0x604 - 0x5e4) / 4 - 1]; + unsigned int ddrc_stat; +}; +check_member(rk322x_grf, ddrc_stat, 0x604); + +struct rk322x_sgrf { + unsigned int soc_con[11]; + unsigned int busdmac_con[4]; +}; + +/* GRF_GPIO0A_IOMUX */ +enum { + GPIO0A7_SHIFT = 14, + GPIO0A7_MASK = 3 << GPIO0A7_SHIFT, + GPIO0A7_GPIO = 0, + GPIO0A7_I2C3_SDA, + GPIO0A7_HDMI_DDCSDA, + + GPIO0A6_SHIFT = 12, + GPIO0A6_MASK = 3 << GPIO0A6_SHIFT, + GPIO0A6_GPIO = 0, + GPIO0A6_I2C3_SCL, + GPIO0A6_HDMI_DDCSCL, + + GPIO0A3_SHIFT = 6, + GPIO0A3_MASK = 3 << GPIO0A3_SHIFT, + GPIO0A3_GPIO = 0, + GPIO0A3_I2C1_SDA, + GPIO0A3_SDIO_CMD, + + GPIO0A2_SHIFT = 4, + GPIO0A2_MASK = 3 << GPIO0A2_SHIFT, + GPIO0A2_GPIO = 0, + GPIO0A2_I2C1_SCL, + + GPIO0A1_SHIFT = 2, + GPIO0A1_MASK = 3 << GPIO0A1_SHIFT, + GPIO0A1_GPIO = 0, + GPIO0A1_I2C0_SDA, + + GPIO0A0_SHIFT = 0, + GPIO0A0_MASK = 3 << GPIO0A0_SHIFT, + GPIO0A0_GPIO = 0, + GPIO0A0_I2C0_SCL, +}; + +/* GRF_GPIO0B_IOMUX */ +enum { + GPIO0B7_SHIFT = 14, + GPIO0B7_MASK = 3 << GPIO0B7_SHIFT, + GPIO0B7_GPIO = 0, + GPIO0B7_HDMI_HDP, + + GPIO0B6_SHIFT = 12, + GPIO0B6_MASK = 3 << GPIO0B6_SHIFT, + GPIO0B6_GPIO = 0, + GPIO0B6_I2S_SDI, + GPIO0B6_SPI_CSN0, + + GPIO0B5_SHIFT = 10, + GPIO0B5_MASK = 3 << GPIO0B5_SHIFT, + GPIO0B5_GPIO = 0, + GPIO0B5_I2S_SDO, + GPIO0B5_SPI_RXD, + + GPIO0B3_SHIFT = 6, + GPIO0B3_MASK = 3 << GPIO0B3_SHIFT, + GPIO0B3_GPIO = 0, + GPIO0B3_I2S1_LRCKRX, + GPIO0B3_SPI_TXD, + + GPIO0B1_SHIFT = 2, + GPIO0B1_MASK = 3 << GPIO0B1_SHIFT, + GPIO0B1_GPIO = 0, + GPIO0B1_I2S_SCLK, + GPIO0B1_SPI_CLK, + + GPIO0B0_SHIFT = 0, + GPIO0B0_MASK = 3, + GPIO0B0_GPIO = 0, + GPIO0B0_I2S_MCLK, +}; + +/* GRF_GPIO0C_IOMUX */ +enum { + GPIO0C4_SHIFT = 8, + GPIO0C4_MASK = 3 << GPIO0C4_SHIFT, + GPIO0C4_GPIO = 0, + GPIO0C4_HDMI_CECSDA, + + GPIO0C1_SHIFT = 2, + GPIO0C1_MASK = 3 << GPIO0C1_SHIFT, + GPIO0C1_GPIO = 0, + GPIO0C1_UART0_RSTN, + GPIO0C1_CLK_OUT1, +}; + +/* GRF_GPIO0D_IOMUX */ +enum { + GPIO0D6_SHIFT = 12, + GPIO0D6_MASK = 3 << GPIO0D6_SHIFT, + GPIO0D6_GPIO = 0, + GPIO0D6_SDIO_PWREN, + GPIO0D6_PWM11, + + + GPIO0D4_SHIFT = 8, + GPIO0D4_MASK = 3 << GPIO0D4_SHIFT, + GPIO0D4_GPIO = 0, + GPIO0D4_PWM2, + + GPIO0D3_SHIFT = 6, + GPIO0D3_MASK = 3 << GPIO0D3_SHIFT, + GPIO0D3_GPIO = 0, + GPIO0D3_PWM1, + + GPIO0D2_SHIFT = 4, + GPIO0D2_MASK = 3 << GPIO0D2_SHIFT, + GPIO0D2_GPIO = 0, + GPIO0D2_PWM0, +}; + +/* GRF_GPIO1A_IOMUX */ +enum { + GPIO1A7_SHIFT = 14, + GPIO1A7_MASK = 1, + GPIO1A7_GPIO = 0, + GPIO1A7_SDMMC_WRPRT, +}; + +/* GRF_GPIO1B_IOMUX */ +enum { + GPIO1B7_SHIFT = 14, + GPIO1B7_MASK = 3 << GPIO1B7_SHIFT, + GPIO1B7_GPIO = 0, + GPIO1B7_SDMMC_CMD, + + GPIO1B6_SHIFT = 12, + GPIO1B6_MASK = 3 << GPIO1B6_SHIFT, + GPIO1B6_GPIO = 0, + GPIO1B6_SDMMC_PWREN, + + GPIO1B4_SHIFT = 8, + GPIO1B4_MASK = 3 << GPIO1B4_SHIFT, + GPIO1B4_GPIO = 0, + GPIO1B4_SPI_CSN1, + GPIO1B4_PWM12, + + GPIO1B3_SHIFT = 6, + GPIO1B3_MASK = 3 << GPIO1B3_SHIFT, + GPIO1B3_GPIO = 0, + GPIO1B3_UART1_RSTN, + GPIO1B3_PWM13, + + GPIO1B2_SHIFT = 4, + GPIO1B2_MASK = 3 << GPIO1B2_SHIFT, + GPIO1B2_GPIO = 0, + GPIO1B2_UART1_SIN, + GPIO1B2_UART21_SIN, + + GPIO1B1_SHIFT = 2, + GPIO1B1_MASK = 3 << GPIO1B1_SHIFT, + GPIO1B1_GPIO = 0, + GPIO1B1_UART1_SOUT, + GPIO1B1_UART21_SOUT, +}; + +/* GRF_GPIO1C_IOMUX */ +enum { + GPIO1C7_SHIFT = 14, + GPIO1C7_MASK = 3 << GPIO1C7_SHIFT, + GPIO1C7_GPIO = 0, + GPIO1C7_NAND_CS3, + GPIO1C7_EMMC_RSTNOUT, + + GPIO1C6_SHIFT = 12, + GPIO1C6_MASK = 3 << GPIO1C6_SHIFT, + GPIO1C6_GPIO = 0, + GPIO1C6_NAND_CS2, + GPIO1C6_EMMC_CMD, + + + GPIO1C5_SHIFT = 10, + GPIO1C5_MASK = 3 << GPIO1C5_SHIFT, + GPIO1C5_GPIO = 0, + GPIO1C5_SDMMC_D3, + GPIO1C5_JTAG_TMS, + + GPIO1C4_SHIFT = 8, + GPIO1C4_MASK = 3 << GPIO1C4_SHIFT, + GPIO1C4_GPIO = 0, + GPIO1C4_SDMMC_D2, + GPIO1C4_JTAG_TCK, + + GPIO1C3_SHIFT = 6, + GPIO1C3_MASK = 3 << GPIO1C3_SHIFT, + GPIO1C3_GPIO = 0, + GPIO1C3_SDMMC_D1, + GPIO1C3_UART2_SIN, + + GPIO1C2_SHIFT = 4, + GPIO1C2_MASK = 3 << GPIO1C2_SHIFT , + GPIO1C2_GPIO = 0, + GPIO1C2_SDMMC_D0, + GPIO1C2_UART2_SOUT, + + GPIO1C1_SHIFT = 2, + GPIO1C1_MASK = 3 << GPIO1C1_SHIFT, + GPIO1C1_GPIO = 0, + GPIO1C1_SDMMC_DETN, + + GPIO1C0_SHIFT = 0, + GPIO1C0_MASK = 3 << GPIO1C0_SHIFT, + GPIO1C0_GPIO = 0, + GPIO1C0_SDMMC_CLKOUT, +}; + +/* GRF_GPIO1D_IOMUX */ +enum { + GPIO1D7_SHIFT = 14, + GPIO1D7_MASK = 3 << GPIO1D7_SHIFT, + GPIO1D7_GPIO = 0, + GPIO1D7_NAND_D7, + GPIO1D7_EMMC_D7, + + GPIO1D6_SHIFT = 12, + GPIO1D6_MASK = 3 << GPIO1D6_SHIFT, + GPIO1D6_GPIO = 0, + GPIO1D6_NAND_D6, + GPIO1D6_EMMC_D6, + + GPIO1D5_SHIFT = 10, + GPIO1D5_MASK = 3 << GPIO1D5_SHIFT, + GPIO1D5_GPIO = 0, + GPIO1D5_NAND_D5, + GPIO1D5_EMMC_D5, + + GPIO1D4_SHIFT = 8, + GPIO1D4_MASK = 3 << GPIO1D4_SHIFT, + GPIO1D4_GPIO = 0, + GPIO1D4_NAND_D4, + GPIO1D4_EMMC_D4, + + GPIO1D3_SHIFT = 6, + GPIO1D3_MASK = 3 << GPIO1D3_SHIFT, + GPIO1D3_GPIO = 0, + GPIO1D3_NAND_D3, + GPIO1D3_EMMC_D3, + + GPIO1D2_SHIFT = 4, + GPIO1D2_MASK = 3 << GPIO1D2_SHIFT, + GPIO1D2_GPIO = 0, + GPIO1D2_NAND_D2, + GPIO1D2_EMMC_D2, + + GPIO1D1_SHIFT = 2, + GPIO1D1_MASK = 3 << GPIO1D1_SHIFT, + GPIO1D1_GPIO = 0, + GPIO1D1_NAND_D1, + GPIO1D1_EMMC_D1, + + GPIO1D0_SHIFT = 0, + GPIO1D0_MASK = 3 << GPIO1D0_SHIFT, + GPIO1D0_GPIO = 0, + GPIO1D0_NAND_D0, + GPIO1D0_EMMC_D0, +}; + +/* GRF_GPIO2A_IOMUX */ +enum { + GPIO2A7_SHIFT = 14, + GPIO2A7_MASK = 3 << GPIO2A7_SHIFT, + GPIO2A7_GPIO = 0, + GPIO2A7_NAND_DQS, + GPIO2A7_EMMC_CLKOUT, + + GPIO2A5_SHIFT = 10, + GPIO2A5_MASK = 3 << GPIO2A5_SHIFT, + GPIO2A5_GPIO = 0, + GPIO2A5_NAND_WP, + GPIO2A5_EMMC_PWREN, + + GPIO2A4_SHIFT = 8, + GPIO2A4_MASK = 3 << GPIO2A4_SHIFT, + GPIO2A4_GPIO = 0, + GPIO2A4_NAND_RDY, + GPIO2A4_EMMC_CMD, + + GPIO2A3_SHIFT = 6, + GPIO2A3_MASK = 3 << GPIO2A3_SHIFT, + GPIO2A3_GPIO = 0, + GPIO2A3_NAND_RDN, + GPIO2A4_SPI1_CSN1, + + GPIO2A2_SHIFT = 4, + GPIO2A2_MASK = 3 << GPIO2A2_SHIFT, + GPIO2A2_GPIO = 0, + GPIO2A2_NAND_WRN, + GPIO2A4_SPI1_CSN0, + + GPIO2A1_SHIFT = 2, + GPIO2A1_MASK = 3 << GPIO2A1_SHIFT, + GPIO2A1_GPIO = 0, + GPIO2A1_NAND_CLE, + GPIO2A1_SPI1_TXD, + + GPIO2A0_SHIFT = 0, + GPIO2A0_MASK = 3 << GPIO2A0_SHIFT, + GPIO2A0_GPIO = 0, + GPIO2A0_NAND_ALE, + GPIO2A0_SPI1_RXD, +}; + +/* GRF_GPIO2B_IOMUX */ +enum { + GPIO2B7_SHIFT = 14, + GPIO2B7_MASK = 3 << GPIO2B7_SHIFT, + GPIO2B7_GPIO = 0, + GPIO2B7_GMAC_RXER, + + GPIO2B6_SHIFT = 12, + GPIO2B6_MASK = 3 << GPIO2B6_SHIFT, + GPIO2B6_GPIO = 0, + GPIO2B6_GMAC_CLK, + GPIO2B6_MAC_LINK, + + GPIO2B5_SHIFT = 10, + GPIO2B5_MASK = 3 << GPIO2B5_SHIFT, + GPIO2B5_GPIO = 0, + GPIO2B5_GMAC_TXEN, + + GPIO2B4_SHIFT = 8, + GPIO2B4_MASK = 3 << GPIO2B4_SHIFT, + GPIO2B4_GPIO = 0, + GPIO2B4_GMAC_MDIO, + + GPIO2B3_SHIFT = 6, + GPIO2B3_MASK = 3 << GPIO2B3_SHIFT, + GPIO2B3_GPIO = 0, + GPIO2B3_GMAC_RXCLK, + + GPIO2B2_SHIFT = 4, + GPIO2B2_MASK = 3 << GPIO2B2_SHIFT, + GPIO2B2_GPIO = 0, + GPIO2B2_GMAC_CRS, + + GPIO2B1_SHIFT = 2, + GPIO2B1_MASK = 3 << GPIO2B1_SHIFT, + GPIO2B1_GPIO = 0, + GPIO2B1_GMAC_TXCLK, + + + GPIO2B0_SHIFT = 0, + GPIO2B0_MASK = 3 << GPIO2B0_SHIFT, + GPIO2B0_GPIO = 0, + GPIO2B0_GMAC_RXDV, + GPIO2B0_MAC_SPEED_IOUT, +}; + +/* GRF_GPIO2C_IOMUX */ +enum { + GPIO2C7_SHIFT = 14, + GPIO2C7_MASK = 3 << GPIO2C7_SHIFT, + GPIO2C7_GPIO = 0, + GPIO2C7_GMAC_TXD3, + + GPIO2C6_SHIFT = 12, + GPIO2C6_MASK = 3 << GPIO2C6_SHIFT, + GPIO2C6_GPIO = 0, + GPIO2C6_GMAC_TXD2, + + GPIO2C5_SHIFT = 10, + GPIO2C5_MASK = 3 << GPIO2C5_SHIFT, + GPIO2C5_GPIO = 0, + GPIO2C5_I2C2_SCL, + GPIO2C5_GMAC_RXD2, + + GPIO2C4_SHIFT = 8, + GPIO2C4_MASK = 3 << GPIO2C4_SHIFT, + GPIO2C4_GPIO = 0, + GPIO2C4_I2C2_SDA, + GPIO2C4_GMAC_RXD3, + + GPIO2C3_SHIFT = 6, + GPIO2C3_MASK = 3 << GPIO2C3_SHIFT, + GPIO2C3_GPIO = 0, + GPIO2C3_GMAC_TXD0, + + GPIO2C2_SHIFT = 4, + GPIO2C2_MASK = 3 << GPIO2C2_SHIFT, + GPIO2C2_GPIO = 0, + GPIO2C2_GMAC_TXD1, + + GPIO2C1_SHIFT = 2, + GPIO2C1_MASK = 3 << GPIO2C1_SHIFT, + GPIO2C1_GPIO = 0, + GPIO2C1_GMAC_RXD0, + + GPIO2C0_SHIFT = 0, + GPIO2C0_MASK = 3 << GPIO2C0_SHIFT, + GPIO2C0_GPIO = 0, + GPIO2C0_GMAC_RXD1, +}; + +/* GRF_GPIO2D_IOMUX */ +enum { + GPIO2D1_SHIFT = 2, + GPIO2D1_MASK = 3 << GPIO2D1_SHIFT, + GPIO2D1_GPIO = 0, + GPIO2D1_GMAC_MDC, + + GPIO2D0_SHIFT = 0, + GPIO2D0_MASK = 3, + GPIO2D0_GPIO = 0, + GPIO2D0_GMAC_COL, +}; + +/* GRF_GPIO3C_IOMUX */ +enum { + GPIO3C6_SHIFT = 12, + GPIO3C6_MASK = 3 << GPIO3C6_SHIFT, + GPIO3C6_GPIO = 0, + GPIO3C6_DRV_VBUS1, + + GPIO3C5_SHIFT = 10, + GPIO3C5_MASK = 3 << GPIO3C5_SHIFT, + GPIO3C5_GPIO = 0, + GPIO3C5_PWM10, + + GPIO3C1_SHIFT = 2, + GPIO3C1_MASK = 3 << GPIO3C1_SHIFT, + GPIO3C1_GPIO = 0, + GPIO3C1_DRV_VBUS, +}; + +/* GRF_GPIO3D_IOMUX */ +enum { + GPIO3D2_SHIFT = 4, + GPIO3D2_MASK = 3 << GPIO3D2_SHIFT, + GPIO3D2_GPIO = 0, + GPIO3D2_PWM3, +}; + +/* GRF_CON_IOMUX */ +enum { + CON_IOMUX_GMAC_SHIFT = 15, + CON_IOMUX_GMAC_MASK = 1 << CON_IOMUX_GMAC_SHIFT, + CON_IOMUX_UART1SEL_SHIFT = 11, + CON_IOMUX_UART1SEL_MASK = 1 << CON_IOMUX_UART1SEL_SHIFT, + CON_IOMUX_UART2SEL_SHIFT = 8, + CON_IOMUX_UART2SEL_MASK = 1 << CON_IOMUX_UART2SEL_SHIFT, + CON_IOMUX_UART2SEL_2 = 0, + CON_IOMUX_UART2SEL_21, + CON_IOMUX_EMMCSEL_SHIFT = 7, + CON_IOMUX_EMMCSEL_MASK = 1 << CON_IOMUX_EMMCSEL_SHIFT, + CON_IOMUX_PWM3SEL_SHIFT = 3, + CON_IOMUX_PWM3SEL_MASK = 1 << CON_IOMUX_PWM3SEL_SHIFT, + CON_IOMUX_PWM2SEL_SHIFT = 2, + CON_IOMUX_PWM2SEL_MASK = 1 << CON_IOMUX_PWM2SEL_SHIFT, + CON_IOMUX_PWM1SEL_SHIFT = 1, + CON_IOMUX_PWM1SEL_MASK = 1 << CON_IOMUX_PWM1SEL_SHIFT, + CON_IOMUX_PWM0SEL_SHIFT = 0, + CON_IOMUX_PWM0SEL_MASK = 1 << CON_IOMUX_PWM0SEL_SHIFT, +}; +#endif diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 150c68d..7c5d269 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -177,6 +177,16 @@ config PINCTRL_ROCKCHIP_RK3188 the GPIO definitions and pin control functions for each available multiplex function.
+config PINCTRL_ROCKCHIP_RK322X + bool "Rockchip rk322x pin control driver" + depends on DM + help + Support pin multiplexing control on Rockchip rk322x SoCs. + + The driver is controlled by a device tree node which contains both + the GPIO definitions and pin control functions for each available + multiplex function. + config PINCTRL_ROCKCHIP_RK3288 bool "Rockchip rk3288 pin control driver" depends on DM diff --git a/drivers/pinctrl/rockchip/Makefile b/drivers/pinctrl/rockchip/Makefile index a1c655d..5251771 100644 --- a/drivers/pinctrl/rockchip/Makefile +++ b/drivers/pinctrl/rockchip/Makefile @@ -7,6 +7,7 @@
obj-$(CONFIG_PINCTRL_ROCKCHIP_RK3036) += pinctrl_rk3036.o obj-$(CONFIG_PINCTRL_ROCKCHIP_RK3188) += pinctrl_rk3188.o +obj-$(CONFIG_PINCTRL_ROCKCHIP_RK322X) += pinctrl_rk322x.o obj-$(CONFIG_PINCTRL_ROCKCHIP_RK3288) += pinctrl_rk3288.o obj-$(CONFIG_PINCTRL_ROCKCHIP_RK3328) += pinctrl_rk3328.o obj-$(CONFIG_PINCTRL_ROCKCHIP_RK3368) += pinctrl_rk3368.o diff --git a/drivers/pinctrl/rockchip/pinctrl_rk322x.c b/drivers/pinctrl/rockchip/pinctrl_rk322x.c new file mode 100644 index 0000000..5404008 --- /dev/null +++ b/drivers/pinctrl/rockchip/pinctrl_rk322x.c @@ -0,0 +1,295 @@ +/* + * Pinctrl driver for Rockchip 3036 SoCs + * (C) Copyright 2015 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/grf_rk322x.h> +#include <asm/arch/hardware.h> +#include <asm/arch/periph.h> +#include <dm/pinctrl.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct rk322x_pinctrl_priv { + struct rk322x_grf *grf; +}; + +static void pinctrl_rk322x_pwm_config(struct rk322x_grf *grf, int pwm_id) +{ + u32 mux_con = readl(&grf->con_iomux); + + switch (pwm_id) { + case PERIPH_ID_PWM0: + if (mux_con & CON_IOMUX_PWM0SEL_MASK) + rk_clrsetreg(&grf->gpio3c_iomux, GPIO3C5_MASK, + GPIO3C5_PWM10 << GPIO3C5_SHIFT); + else + rk_clrsetreg(&grf->gpio0d_iomux, GPIO0D2_MASK, + GPIO0D2_PWM0 << GPIO0D2_SHIFT); + break; + case PERIPH_ID_PWM1: + if (mux_con & CON_IOMUX_PWM1SEL_MASK) + rk_clrsetreg(&grf->gpio0d_iomux, GPIO0D6_MASK, + GPIO0D6_PWM11 << GPIO0D6_SHIFT); + else + rk_clrsetreg(&grf->gpio0d_iomux, GPIO0D3_MASK, + GPIO0D3_PWM1 << GPIO0D3_SHIFT); + break; + case PERIPH_ID_PWM2: + if (mux_con & CON_IOMUX_PWM2SEL_MASK) + rk_clrsetreg(&grf->gpio1b_iomux, GPIO1B4_MASK, + GPIO1B4_PWM12 << GPIO1B4_SHIFT); + else + rk_clrsetreg(&grf->gpio0d_iomux, GPIO0D4_MASK, + GPIO0D4_PWM2 << GPIO0D4_SHIFT); + break; + case PERIPH_ID_PWM3: + if (mux_con & CON_IOMUX_PWM3SEL_MASK) + rk_clrsetreg(&grf->gpio1b_iomux, GPIO1B3_MASK, + GPIO1B3_PWM13 << GPIO1B3_SHIFT); + else + rk_clrsetreg(&grf->gpio3d_iomux, GPIO3D2_MASK, + GPIO3D2_PWM3 << GPIO3D2_SHIFT); + break; + default: + debug("pwm id = %d iomux error!\n", pwm_id); + break; + } +} + +static void pinctrl_rk322x_i2c_config(struct rk322x_grf *grf, int i2c_id) +{ + switch (i2c_id) { + case PERIPH_ID_I2C0: + rk_clrsetreg(&grf->gpio0a_iomux, + GPIO0A1_MASK | GPIO0A0_MASK, + GPIO0A1_I2C0_SDA << GPIO0A1_SHIFT | + GPIO0A0_I2C0_SCL << GPIO0A0_SHIFT); + + break; + case PERIPH_ID_I2C1: + rk_clrsetreg(&grf->gpio0a_iomux, + GPIO0A3_MASK | GPIO0A2_MASK, + GPIO0A3_I2C1_SDA << GPIO0A3_SHIFT | + GPIO0A2_I2C1_SCL << GPIO0A2_SHIFT); + break; + case PERIPH_ID_I2C2: + rk_clrsetreg(&grf->gpio2c_iomux, + GPIO2C5_MASK | GPIO2C4_MASK, + GPIO2C5_I2C2_SCL << GPIO2C5_SHIFT | + GPIO2C4_I2C2_SDA << GPIO2C4_SHIFT); + break; + case PERIPH_ID_I2C3: + rk_clrsetreg(&grf->gpio0a_iomux, + GPIO0A7_MASK | GPIO0A6_MASK, + GPIO0A7_I2C3_SDA << GPIO0A7_SHIFT | + GPIO0A6_I2C3_SCL << GPIO0A6_SHIFT); + + break; + } +} + +static void pinctrl_rk322x_spi_config(struct rk322x_grf *grf, int cs) +{ + switch (cs) { + case 0: + rk_clrsetreg(&grf->gpio0b_iomux, GPIO0B6_MASK, + GPIO0B6_SPI_CSN0 << GPIO0B6_SHIFT); + break; + case 1: + rk_clrsetreg(&grf->gpio1b_iomux, GPIO1B4_MASK, + GPIO1B4_SPI_CSN1 << GPIO1B4_SHIFT); + break; + } + rk_clrsetreg(&grf->gpio0b_iomux, + GPIO0B1_MASK | GPIO0B3_MASK | GPIO0B5_MASK, + GPIO0B5_SPI_RXD << GPIO0B5_SHIFT | + GPIO0B3_SPI_TXD << GPIO0B3_SHIFT | + GPIO0B1_SPI_CLK << GPIO0B1_SHIFT); +} + +static void pinctrl_rk322x_uart_config(struct rk322x_grf *grf, int uart_id) +{ + u32 mux_con = readl(&grf->con_iomux); + + switch (uart_id) { + case PERIPH_ID_UART1: + if (!(mux_con & CON_IOMUX_UART1SEL_MASK)) + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B1_MASK | GPIO1B2_MASK, + GPIO1B1_UART1_SOUT << GPIO1B1_SHIFT | + GPIO1B2_UART1_SIN << GPIO1B2_SHIFT); + break; + case PERIPH_ID_UART2: + if (mux_con & CON_IOMUX_UART2SEL_MASK) + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B1_MASK | GPIO1B2_MASK, + GPIO1B1_UART21_SOUT << GPIO1B1_SHIFT | + GPIO1B2_UART21_SIN << GPIO1B2_SHIFT); + else + rk_clrsetreg(&grf->gpio1c_iomux, + GPIO1C3_MASK | GPIO1C2_MASK, + GPIO1C3_UART2_SIN << GPIO1C3_SHIFT | + GPIO1C2_UART2_SOUT << GPIO1C2_SHIFT); + break; + } +} + +static void pinctrl_rk322x_sdmmc_config(struct rk322x_grf *grf, int mmc_id) +{ + switch (mmc_id) { + case PERIPH_ID_EMMC: + rk_clrsetreg(&grf->gpio1d_iomux, 0xffff, + GPIO1D7_EMMC_D7 << GPIO1D7_SHIFT | + GPIO1D6_EMMC_D6 << GPIO1D6_SHIFT | + GPIO1D5_EMMC_D5 << GPIO1D5_SHIFT | + GPIO1D4_EMMC_D4 << GPIO1D4_SHIFT | + GPIO1D3_EMMC_D3 << GPIO1D3_SHIFT | + GPIO1D2_EMMC_D2 << GPIO1D2_SHIFT | + GPIO1D1_EMMC_D1 << GPIO1D1_SHIFT | + GPIO1D0_EMMC_D0 << GPIO1D0_SHIFT); + rk_clrsetreg(&grf->gpio2a_iomux, + GPIO2A5_MASK | GPIO2A7_MASK, + GPIO2A5_EMMC_PWREN << GPIO2A5_SHIFT | + GPIO2A7_EMMC_CLKOUT << GPIO2A7_SHIFT); + rk_clrsetreg(&grf->gpio1c_iomux, + GPIO1C6_MASK | GPIO1C7_MASK, + GPIO1C6_EMMC_CMD << GPIO1C6_SHIFT | + GPIO1C7_EMMC_RSTNOUT << GPIO1C6_SHIFT); + break; + case PERIPH_ID_SDCARD: + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B6_MASK | GPIO1B7_MASK, + GPIO1B6_SDMMC_PWREN << GPIO1B6_SHIFT | + GPIO1B7_SDMMC_CMD << GPIO1B6_SHIFT); + rk_clrsetreg(&grf->gpio1c_iomux, 0xfff, + GPIO1C5_SDMMC_D3 << GPIO1C5_SHIFT | + GPIO1C4_SDMMC_D2 << GPIO1C4_SHIFT | + GPIO1C3_SDMMC_D1 << GPIO1C3_SHIFT | + GPIO1C2_SDMMC_D0 << GPIO1C2_SHIFT | + GPIO1C1_SDMMC_DETN << GPIO1C1_SHIFT | + GPIO1C0_SDMMC_CLKOUT << GPIO1C0_SHIFT); + break; + } +} + +static int rk322x_pinctrl_request(struct udevice *dev, int func, int flags) +{ + struct rk322x_pinctrl_priv *priv = dev_get_priv(dev); + + debug("%s: func=%x, flags=%x\n", __func__, func, flags); + switch (func) { + case PERIPH_ID_PWM0: + case PERIPH_ID_PWM1: + case PERIPH_ID_PWM2: + case PERIPH_ID_PWM3: + pinctrl_rk322x_pwm_config(priv->grf, func); + break; + case PERIPH_ID_I2C0: + case PERIPH_ID_I2C1: + case PERIPH_ID_I2C2: + pinctrl_rk322x_i2c_config(priv->grf, func); + break; + case PERIPH_ID_SPI0: + pinctrl_rk322x_spi_config(priv->grf, flags); + break; + case PERIPH_ID_UART0: + case PERIPH_ID_UART1: + case PERIPH_ID_UART2: + pinctrl_rk322x_uart_config(priv->grf, func); + break; + case PERIPH_ID_SDMMC0: + case PERIPH_ID_SDMMC1: + pinctrl_rk322x_sdmmc_config(priv->grf, func); + break; + default: + return -EINVAL; + } + + return 0; +} + +static int rk322x_pinctrl_get_periph_id(struct udevice *dev, + struct udevice *periph) +{ + u32 cell[3]; + int ret; + + ret = fdtdec_get_int_array(gd->fdt_blob, dev_of_offset(periph), + "interrupts", cell, ARRAY_SIZE(cell)); + if (ret < 0) + return -EINVAL; + + switch (cell[1]) { + case 12: + return PERIPH_ID_SDCARD; + case 14: + return PERIPH_ID_EMMC; + case 36: + return PERIPH_ID_I2C0; + case 37: + return PERIPH_ID_I2C1; + case 38: + return PERIPH_ID_I2C2; + case 49: + return PERIPH_ID_SPI0; + case 50: + return PERIPH_ID_PWM0; + case 55: + return PERIPH_ID_UART0; + case 56: + return PERIPH_ID_UART1; + case 57: + return PERIPH_ID_UART2; + } + return -ENOENT; +} + +static int rk322x_pinctrl_set_state_simple(struct udevice *dev, + struct udevice *periph) +{ + int func; + + func = rk322x_pinctrl_get_periph_id(dev, periph); + if (func < 0) + return func; + return rk322x_pinctrl_request(dev, func, 0); +} + +static struct pinctrl_ops rk322x_pinctrl_ops = { + .set_state_simple = rk322x_pinctrl_set_state_simple, + .request = rk322x_pinctrl_request, + .get_periph_id = rk322x_pinctrl_get_periph_id, +}; + +static int rk322x_pinctrl_probe(struct udevice *dev) +{ + struct rk322x_pinctrl_priv *priv = dev_get_priv(dev); + + priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + debug("%s: grf=%p\n", __func__, priv->grf); + return 0; +} + +static const struct udevice_id rk322x_pinctrl_ids[] = { + { .compatible = "rockchip,rk322x-pinctrl" }, + { } +}; + +U_BOOT_DRIVER(pinctrl_rk322x) = { + .name = "pinctrl_rk322x", + .id = UCLASS_PINCTRL, + .of_match = rk322x_pinctrl_ids, + .priv_auto_alloc_size = sizeof(struct rk322x_pinctrl_priv), + .ops = &rk322x_pinctrl_ops, + .bind = dm_scan_fdt_dev, + .probe = rk322x_pinctrl_probe, +};
- i2c;
- spi;
- uart;
- pwm;
- emmc/sdmmc;
- (C) Copyright 2017 Rockchip Electronics Co., Ltd.
- unsigned int gpio0a_iomux;
- unsigned int gpio0b_iomux;
- unsigned int gpio0c_iomux;
- unsigned int gpio0d_iomux;
- unsigned int gpio1a_iomux;
- unsigned int gpio1b_iomux;
- unsigned int gpio1c_iomux;
- unsigned int gpio1d_iomux;
- unsigned int gpio2a_iomux;
- unsigned int gpio2b_iomux;
- unsigned int gpio2c_iomux;
- unsigned int gpio2d_iomux;
- unsigned int gpio3a_iomux;
- unsigned int gpio3b_iomux;
- unsigned int gpio3c_iomux;
- unsigned int gpio3d_iomux;
- unsigned int reserved1[4];
- unsigned int con_iomux;
- unsigned int reserved2[(0x100 - 0x50) / 4 - 1];
Using a macro for this would clarify things. See my earlier comment to the other patch from this series.
- unsigned int gpio0_p[4];
- unsigned int gpio1_p[4];
- unsigned int gpio2_p[4];
- unsigned int gpio3_p[4];
- unsigned int reserved3[(0x200 - 0x13c) / 4 - 1];
- unsigned int gpio0_e[4];
- unsigned int gpio1_e[4];
- unsigned int gpio2_e[4];
- unsigned int gpio3_e[4];
- unsigned int reserved4[(0x400 - 0x23c) / 4 - 1];
- unsigned int soc_con[7];
- unsigned int reserved5[(0x480 - 0x418) / 4 - 1];
- unsigned int soc_status[3];
- unsigned int chip_id;
- unsigned int reserved6[(0x500 - 0x48c) / 4 - 1];
- unsigned int cpu_con[4];
- unsigned int reserved7[4];
- unsigned int cpu_status[2];
- unsigned int reserved8[(0x5c8 - 0x524) / 4 - 1];
- unsigned int os_reg[8];
- unsigned int reserved9[(0x604 - 0x5e4) / 4 - 1];
- unsigned int ddrc_stat;
- unsigned int soc_con[11];
- unsigned int busdmac_con[4];
- GPIO0A7_SHIFT = 14,
- GPIO0A7_MASK = 3 << GPIO0A7_SHIFT,
- GPIO0A7_GPIO = 0,
- GPIO0A7_I2C3_SDA,
- GPIO0A7_HDMI_DDCSDA,
- GPIO0A6_SHIFT = 12,
- GPIO0A6_MASK = 3 << GPIO0A6_SHIFT,
- GPIO0A6_GPIO = 0,
- GPIO0A6_I2C3_SCL,
- GPIO0A6_HDMI_DDCSCL,
- GPIO0A3_SHIFT = 6,
- GPIO0A3_MASK = 3 << GPIO0A3_SHIFT,
- GPIO0A3_GPIO = 0,
- GPIO0A3_I2C1_SDA,
- GPIO0A3_SDIO_CMD,
- GPIO0A2_SHIFT = 4,
- GPIO0A2_MASK = 3 << GPIO0A2_SHIFT,
- GPIO0A2_GPIO = 0,
- GPIO0A2_I2C1_SCL,
- GPIO0A1_SHIFT = 2,
- GPIO0A1_MASK = 3 << GPIO0A1_SHIFT,
- GPIO0A1_GPIO = 0,
- GPIO0A1_I2C0_SDA,
- GPIO0A0_SHIFT = 0,
- GPIO0A0_MASK = 3 << GPIO0A0_SHIFT,
- GPIO0A0_GPIO = 0,
- GPIO0A0_I2C0_SCL,
- GPIO0B7_SHIFT = 14,
- GPIO0B7_MASK = 3 << GPIO0B7_SHIFT,
- GPIO0B7_GPIO = 0,
- GPIO0B7_HDMI_HDP,
- GPIO0B6_SHIFT = 12,
- GPIO0B6_MASK = 3 << GPIO0B6_SHIFT,
- GPIO0B6_GPIO = 0,
- GPIO0B6_I2S_SDI,
- GPIO0B6_SPI_CSN0,
- GPIO0B5_SHIFT = 10,
- GPIO0B5_MASK = 3 << GPIO0B5_SHIFT,
- GPIO0B5_GPIO = 0,
- GPIO0B5_I2S_SDO,
- GPIO0B5_SPI_RXD,
- GPIO0B3_SHIFT = 6,
- GPIO0B3_MASK = 3 << GPIO0B3_SHIFT,
- GPIO0B3_GPIO = 0,
- GPIO0B3_I2S1_LRCKRX,
- GPIO0B3_SPI_TXD,
- GPIO0B1_SHIFT = 2,
- GPIO0B1_MASK = 3 << GPIO0B1_SHIFT,
- GPIO0B1_GPIO = 0,
- GPIO0B1_I2S_SCLK,
- GPIO0B1_SPI_CLK,
- GPIO0B0_SHIFT = 0,
- GPIO0B0_MASK = 3,
- GPIO0B0_GPIO = 0,
- GPIO0B0_I2S_MCLK,
- GPIO0C4_SHIFT = 8,
- GPIO0C4_MASK = 3 << GPIO0C4_SHIFT,
- GPIO0C4_GPIO = 0,
- GPIO0C4_HDMI_CECSDA,
- GPIO0C1_SHIFT = 2,
- GPIO0C1_MASK = 3 << GPIO0C1_SHIFT,
- GPIO0C1_GPIO = 0,
- GPIO0C1_UART0_RSTN,
- GPIO0C1_CLK_OUT1,
- GPIO0D6_SHIFT = 12,
- GPIO0D6_MASK = 3 << GPIO0D6_SHIFT,
- GPIO0D6_GPIO = 0,
- GPIO0D6_SDIO_PWREN,
- GPIO0D6_PWM11,
- GPIO0D4_SHIFT = 8,
- GPIO0D4_MASK = 3 << GPIO0D4_SHIFT,
- GPIO0D4_GPIO = 0,
- GPIO0D4_PWM2,
- GPIO0D3_SHIFT = 6,
- GPIO0D3_MASK = 3 << GPIO0D3_SHIFT,
- GPIO0D3_GPIO = 0,
- GPIO0D3_PWM1,
- GPIO0D2_SHIFT = 4,
- GPIO0D2_MASK = 3 << GPIO0D2_SHIFT,
- GPIO0D2_GPIO = 0,
- GPIO0D2_PWM0,
- GPIO1A7_SHIFT = 14,
- GPIO1A7_MASK = 1,
- GPIO1A7_GPIO = 0,
- GPIO1A7_SDMMC_WRPRT,
- GPIO1B7_SHIFT = 14,
- GPIO1B7_MASK = 3 << GPIO1B7_SHIFT,
- GPIO1B7_GPIO = 0,
- GPIO1B7_SDMMC_CMD,
- GPIO1B6_SHIFT = 12,
- GPIO1B6_MASK = 3 << GPIO1B6_SHIFT,
- GPIO1B6_GPIO = 0,
- GPIO1B6_SDMMC_PWREN,
- GPIO1B4_SHIFT = 8,
- GPIO1B4_MASK = 3 << GPIO1B4_SHIFT,
- GPIO1B4_GPIO = 0,
- GPIO1B4_SPI_CSN1,
- GPIO1B4_PWM12,
- GPIO1B3_SHIFT = 6,
- GPIO1B3_MASK = 3 << GPIO1B3_SHIFT,
- GPIO1B3_GPIO = 0,
- GPIO1B3_UART1_RSTN,
- GPIO1B3_PWM13,
- GPIO1B2_SHIFT = 4,
- GPIO1B2_MASK = 3 << GPIO1B2_SHIFT,
- GPIO1B2_GPIO = 0,
- GPIO1B2_UART1_SIN,
- GPIO1B2_UART21_SIN,
- GPIO1B1_SHIFT = 2,
- GPIO1B1_MASK = 3 << GPIO1B1_SHIFT,
- GPIO1B1_GPIO = 0,
- GPIO1B1_UART1_SOUT,
- GPIO1B1_UART21_SOUT,
- GPIO1C7_SHIFT = 14,
- GPIO1C7_MASK = 3 << GPIO1C7_SHIFT,
- GPIO1C7_GPIO = 0,
- GPIO1C7_NAND_CS3,
- GPIO1C7_EMMC_RSTNOUT,
- GPIO1C6_SHIFT = 12,
- GPIO1C6_MASK = 3 << GPIO1C6_SHIFT,
- GPIO1C6_GPIO = 0,
- GPIO1C6_NAND_CS2,
- GPIO1C6_EMMC_CMD,
- GPIO1C5_SHIFT = 10,
- GPIO1C5_MASK = 3 << GPIO1C5_SHIFT,
- GPIO1C5_GPIO = 0,
- GPIO1C5_SDMMC_D3,
- GPIO1C5_JTAG_TMS,
- GPIO1C4_SHIFT = 8,
- GPIO1C4_MASK = 3 << GPIO1C4_SHIFT,
- GPIO1C4_GPIO = 0,
- GPIO1C4_SDMMC_D2,
- GPIO1C4_JTAG_TCK,
- GPIO1C3_SHIFT = 6,
- GPIO1C3_MASK = 3 << GPIO1C3_SHIFT,
- GPIO1C3_GPIO = 0,
- GPIO1C3_SDMMC_D1,
- GPIO1C3_UART2_SIN,
- GPIO1C2_SHIFT = 4,
- GPIO1C2_MASK = 3 << GPIO1C2_SHIFT ,
- GPIO1C2_GPIO = 0,
- GPIO1C2_SDMMC_D0,
- GPIO1C2_UART2_SOUT,
- GPIO1C1_SHIFT = 2,
- GPIO1C1_MASK = 3 << GPIO1C1_SHIFT,
- GPIO1C1_GPIO = 0,
- GPIO1C1_SDMMC_DETN,
- GPIO1C0_SHIFT = 0,
- GPIO1C0_MASK = 3 << GPIO1C0_SHIFT,
- GPIO1C0_GPIO = 0,
- GPIO1C0_SDMMC_CLKOUT,
- GPIO1D7_SHIFT = 14,
- GPIO1D7_MASK = 3 << GPIO1D7_SHIFT,
- GPIO1D7_GPIO = 0,
- GPIO1D7_NAND_D7,
- GPIO1D7_EMMC_D7,
- GPIO1D6_SHIFT = 12,
- GPIO1D6_MASK = 3 << GPIO1D6_SHIFT,
- GPIO1D6_GPIO = 0,
- GPIO1D6_NAND_D6,
- GPIO1D6_EMMC_D6,
- GPIO1D5_SHIFT = 10,
- GPIO1D5_MASK = 3 << GPIO1D5_SHIFT,
- GPIO1D5_GPIO = 0,
- GPIO1D5_NAND_D5,
- GPIO1D5_EMMC_D5,
- GPIO1D4_SHIFT = 8,
- GPIO1D4_MASK = 3 << GPIO1D4_SHIFT,
- GPIO1D4_GPIO = 0,
- GPIO1D4_NAND_D4,
- GPIO1D4_EMMC_D4,
- GPIO1D3_SHIFT = 6,
- GPIO1D3_MASK = 3 << GPIO1D3_SHIFT,
- GPIO1D3_GPIO = 0,
- GPIO1D3_NAND_D3,
- GPIO1D3_EMMC_D3,
- GPIO1D2_SHIFT = 4,
- GPIO1D2_MASK = 3 << GPIO1D2_SHIFT,
- GPIO1D2_GPIO = 0,
- GPIO1D2_NAND_D2,
- GPIO1D2_EMMC_D2,
- GPIO1D1_SHIFT = 2,
- GPIO1D1_MASK = 3 << GPIO1D1_SHIFT,
- GPIO1D1_GPIO = 0,
- GPIO1D1_NAND_D1,
- GPIO1D1_EMMC_D1,
- GPIO1D0_SHIFT = 0,
- GPIO1D0_MASK = 3 << GPIO1D0_SHIFT,
- GPIO1D0_GPIO = 0,
- GPIO1D0_NAND_D0,
- GPIO1D0_EMMC_D0,
- GPIO2A7_SHIFT = 14,
- GPIO2A7_MASK = 3 << GPIO2A7_SHIFT,
- GPIO2A7_GPIO = 0,
- GPIO2A7_NAND_DQS,
- GPIO2A7_EMMC_CLKOUT,
- GPIO2A5_SHIFT = 10,
- GPIO2A5_MASK = 3 << GPIO2A5_SHIFT,
- GPIO2A5_GPIO = 0,
- GPIO2A5_NAND_WP,
- GPIO2A5_EMMC_PWREN,
- GPIO2A4_SHIFT = 8,
- GPIO2A4_MASK = 3 << GPIO2A4_SHIFT,
- GPIO2A4_GPIO = 0,
- GPIO2A4_NAND_RDY,
- GPIO2A4_EMMC_CMD,
- GPIO2A3_SHIFT = 6,
- GPIO2A3_MASK = 3 << GPIO2A3_SHIFT,
- GPIO2A3_GPIO = 0,
- GPIO2A3_NAND_RDN,
- GPIO2A4_SPI1_CSN1,
- GPIO2A2_SHIFT = 4,
- GPIO2A2_MASK = 3 << GPIO2A2_SHIFT,
- GPIO2A2_GPIO = 0,
- GPIO2A2_NAND_WRN,
- GPIO2A4_SPI1_CSN0,
- GPIO2A1_SHIFT = 2,
- GPIO2A1_MASK = 3 << GPIO2A1_SHIFT,
- GPIO2A1_GPIO = 0,
- GPIO2A1_NAND_CLE,
- GPIO2A1_SPI1_TXD,
- GPIO2A0_SHIFT = 0,
- GPIO2A0_MASK = 3 << GPIO2A0_SHIFT,
- GPIO2A0_GPIO = 0,
- GPIO2A0_NAND_ALE,
- GPIO2A0_SPI1_RXD,
- GPIO2B7_SHIFT = 14,
- GPIO2B7_MASK = 3 << GPIO2B7_SHIFT,
- GPIO2B7_GPIO = 0,
- GPIO2B7_GMAC_RXER,
- GPIO2B6_SHIFT = 12,
- GPIO2B6_MASK = 3 << GPIO2B6_SHIFT,
- GPIO2B6_GPIO = 0,
- GPIO2B6_GMAC_CLK,
- GPIO2B6_MAC_LINK,
- GPIO2B5_SHIFT = 10,
- GPIO2B5_MASK = 3 << GPIO2B5_SHIFT,
- GPIO2B5_GPIO = 0,
- GPIO2B5_GMAC_TXEN,
- GPIO2B4_SHIFT = 8,
- GPIO2B4_MASK = 3 << GPIO2B4_SHIFT,
- GPIO2B4_GPIO = 0,
- GPIO2B4_GMAC_MDIO,
- GPIO2B3_SHIFT = 6,
- GPIO2B3_MASK = 3 << GPIO2B3_SHIFT,
- GPIO2B3_GPIO = 0,
- GPIO2B3_GMAC_RXCLK,
- GPIO2B2_SHIFT = 4,
- GPIO2B2_MASK = 3 << GPIO2B2_SHIFT,
- GPIO2B2_GPIO = 0,
- GPIO2B2_GMAC_CRS,
- GPIO2B1_SHIFT = 2,
- GPIO2B1_MASK = 3 << GPIO2B1_SHIFT,
- GPIO2B1_GPIO = 0,
- GPIO2B1_GMAC_TXCLK,
- GPIO2B0_SHIFT = 0,
- GPIO2B0_MASK = 3 << GPIO2B0_SHIFT,
- GPIO2B0_GPIO = 0,
- GPIO2B0_GMAC_RXDV,
- GPIO2B0_MAC_SPEED_IOUT,
- GPIO2C7_SHIFT = 14,
- GPIO2C7_MASK = 3 << GPIO2C7_SHIFT,
- GPIO2C7_GPIO = 0,
- GPIO2C7_GMAC_TXD3,
- GPIO2C6_SHIFT = 12,
- GPIO2C6_MASK = 3 << GPIO2C6_SHIFT,
- GPIO2C6_GPIO = 0,
- GPIO2C6_GMAC_TXD2,
- GPIO2C5_SHIFT = 10,
- GPIO2C5_MASK = 3 << GPIO2C5_SHIFT,
- GPIO2C5_GPIO = 0,
- GPIO2C5_I2C2_SCL,
- GPIO2C5_GMAC_RXD2,
- GPIO2C4_SHIFT = 8,
- GPIO2C4_MASK = 3 << GPIO2C4_SHIFT,
- GPIO2C4_GPIO = 0,
- GPIO2C4_I2C2_SDA,
- GPIO2C4_GMAC_RXD3,
- GPIO2C3_SHIFT = 6,
- GPIO2C3_MASK = 3 << GPIO2C3_SHIFT,
- GPIO2C3_GPIO = 0,
- GPIO2C3_GMAC_TXD0,
- GPIO2C2_SHIFT = 4,
- GPIO2C2_MASK = 3 << GPIO2C2_SHIFT,
- GPIO2C2_GPIO = 0,
- GPIO2C2_GMAC_TXD1,
- GPIO2C1_SHIFT = 2,
- GPIO2C1_MASK = 3 << GPIO2C1_SHIFT,
- GPIO2C1_GPIO = 0,
- GPIO2C1_GMAC_RXD0,
- GPIO2C0_SHIFT = 0,
- GPIO2C0_MASK = 3 << GPIO2C0_SHIFT,
- GPIO2C0_GPIO = 0,
- GPIO2C0_GMAC_RXD1,
- GPIO2D1_SHIFT = 2,
- GPIO2D1_MASK = 3 << GPIO2D1_SHIFT,
- GPIO2D1_GPIO = 0,
- GPIO2D1_GMAC_MDC,
- GPIO2D0_SHIFT = 0,
- GPIO2D0_MASK = 3,
- GPIO2D0_GPIO = 0,
- GPIO2D0_GMAC_COL,
- GPIO3C6_SHIFT = 12,
- GPIO3C6_MASK = 3 << GPIO3C6_SHIFT,
- GPIO3C6_GPIO = 0,
- GPIO3C6_DRV_VBUS1,
- GPIO3C5_SHIFT = 10,
- GPIO3C5_MASK = 3 << GPIO3C5_SHIFT,
- GPIO3C5_GPIO = 0,
- GPIO3C5_PWM10,
- GPIO3C1_SHIFT = 2,
- GPIO3C1_MASK = 3 << GPIO3C1_SHIFT,
- GPIO3C1_GPIO = 0,
- GPIO3C1_DRV_VBUS,
- GPIO3D2_SHIFT = 4,
- GPIO3D2_MASK = 3 << GPIO3D2_SHIFT,
- GPIO3D2_GPIO = 0,
- GPIO3D2_PWM3,
- CON_IOMUX_GMAC_SHIFT = 15,
- CON_IOMUX_GMAC_MASK = 1 << CON_IOMUX_GMAC_SHIFT,
- CON_IOMUX_UART1SEL_SHIFT = 11,
- CON_IOMUX_UART1SEL_MASK = 1 << CON_IOMUX_UART1SEL_SHIFT,
- CON_IOMUX_UART2SEL_SHIFT = 8,
- CON_IOMUX_UART2SEL_MASK = 1 << CON_IOMUX_UART2SEL_SHIFT,
- CON_IOMUX_UART2SEL_2 = 0,
- CON_IOMUX_UART2SEL_21,
- CON_IOMUX_EMMCSEL_SHIFT = 7,
- CON_IOMUX_EMMCSEL_MASK = 1 << CON_IOMUX_EMMCSEL_SHIFT,
- CON_IOMUX_PWM3SEL_SHIFT = 3,
- CON_IOMUX_PWM3SEL_MASK = 1 << CON_IOMUX_PWM3SEL_SHIFT,
- CON_IOMUX_PWM2SEL_SHIFT = 2,
- CON_IOMUX_PWM2SEL_MASK = 1 << CON_IOMUX_PWM2SEL_SHIFT,
- CON_IOMUX_PWM1SEL_SHIFT = 1,
- CON_IOMUX_PWM1SEL_MASK = 1 << CON_IOMUX_PWM1SEL_SHIFT,
- CON_IOMUX_PWM0SEL_SHIFT = 0,
- CON_IOMUX_PWM0SEL_MASK = 1 << CON_IOMUX_PWM0SEL_SHIFT,
- bool "Rockchip rk322x pin control driver"
- depends on DM
- help
multiplex function.
- Pinctrl driver for Rockchip 3036 SoCs
- struct rk322x_grf *grf;
- u32 mux_con = readl(&grf->con_iomux);
- switch (pwm_id) {
- case PERIPH_ID_PWM0:
else
break;
- case PERIPH_ID_PWM1:
else
break;
- case PERIPH_ID_PWM2:
else
break;
- case PERIPH_ID_PWM3:
else
break;
- default:
break;
- switch (i2c_id) {
- case PERIPH_ID_I2C0:
break;
- case PERIPH_ID_I2C1:
break;
- case PERIPH_ID_I2C2:
break;
- case PERIPH_ID_I2C3:
break;
- switch (cs) {
- case 0:
break;
- case 1:
break;
- rk_clrsetreg(&grf->gpio0b_iomux,
- switch (uart_id) {
- case PERIPH_ID_UART1:
break;
- case PERIPH_ID_UART2:
else
break;
- switch (mmc_id) {
- case PERIPH_ID_EMMC:
break;
- case PERIPH_ID_SDCARD:
break;
- struct rk322x_pinctrl_priv *priv = dev_get_priv(dev);
- debug("%s: func=%x, flags=%x\n", __func__, func, flags);
- switch (func) {
break;
break;
- case PERIPH_ID_SPI0:
break;
- case PERIPH_ID_UART0:
break;
- case PERIPH_ID_SDMMC0:
- case PERIPH_ID_SDMMC1:
break;
- default:
return -EINVAL;
- u32 cell[3];
- int ret;
- ret = fdtdec_get_int_array(gd->fdt_blob, dev_of_offset(periph),
- if (ret < 0)
return -EINVAL;
- switch (cell[1]) {
- case 12:
- case 14:
- case 36:
- case 37:
- case 38:
- case 49:
- case 50:
- case 55:
- case 56:
- case 57:
- return -ENOENT;
- int func;
- func = rk322x_pinctrl_get_periph_id(dev, periph);
- if (func < 0)
return func;
- return rk322x_pinctrl_request(dev, func, 0);
- .set_state_simple = rk322x_pinctrl_set_state_simple,
- .request = rk322x_pinctrl_request,
- .get_periph_id = rk322x_pinctrl_get_periph_id,
- priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF);
- debug("%s: grf=%p\n", __func__, priv->grf);
- { .compatible = "rockchip,rk322x-pinctrl" },
- .name = "pinctrl_rk322x",
- .id = UCLASS_PINCTRL,
- .of_match = rk322x_pinctrl_ids,
- .priv_auto_alloc_size = sizeof(struct rk322x_pinctrl_priv),
- .ops = &rk322x_pinctrl_ops,
- .bind = dm_scan_fdt_dev,
- .probe = rk322x_pinctrl_probe,
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
The dts files are from kernel and with modify to adapt U-Boot.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/dts/rk3229-evb.dts | 77 ++++ arch/arm/dts/rk322x.dtsi | 710 +++++++++++++++++++++++++++++++++ include/dt-bindings/clock/rk3228-cru.h | 247 ++++++++++++ 3 files changed, 1034 insertions(+) create mode 100644 arch/arm/dts/rk3229-evb.dts create mode 100644 arch/arm/dts/rk322x.dtsi create mode 100644 include/dt-bindings/clock/rk3228-cru.h
diff --git a/arch/arm/dts/rk3229-evb.dts b/arch/arm/dts/rk3229-evb.dts new file mode 100644 index 0000000..ccdac1c --- /dev/null +++ b/arch/arm/dts/rk3229-evb.dts @@ -0,0 +1,77 @@ +/* + * (C) Copyright 2017 Rockchip Electronics Co., Ltd. + * + * SPDX-License-Identifier: GPL-2.0+ X11 + */ + +/dts-v1/; + +#include "rk322x.dtsi" + +/ { + model = "Rockchip RK3229 Evaluation board"; + compatible = "rockchip,rk3229-evb", "rockchip,rk3229"; + + chosen { + stdout-path = &uart2; + }; + + memory@60000000 { + device_type = "memory"; + reg = <0x60000000 0x40000000>; + }; + + ext_gmac: ext_gmac { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "ext_gmac"; + #clock-cells = <0>; + }; + + vcc_phy: vcc-phy-regulator { + compatible = "regulator-fixed"; + enable-active-high; + regulator-name = "vcc_phy"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; +}; + +&dmc { + rockchip,sdram-channel = /bits/ 8 <1 10 3 2 1 0 15 15>; + rockchip,pctl-timing = <0x96 0xC8 0x1F3 0xF 0x8000004D 0x4 0x4E 0x6 0x3 + 0x0 0x6 0x5 0xC 0x10 0x6 0x4 0x4 + 0x5 0x4 0x200 0x3 0xA 0x40 0x0 0x1 + 0x5 0x5 0x3 0xC 0x1E 0x100 0x0 0x4 + 0x0 0x924>; + rockchip,phy-timing = <0x220 0x1 0x0 0x0 0x0 0x4 0x60>; + rockchip,sdram-params = <0x428B188 0x0 0x21 0x472 0x15 + 0 300 3 0 120>; +}; + +&gmac { + assigned-clocks = <&cru SCLK_MAC_EXTCLK>, <&cru SCLK_MAC>; + assigned-clock-parents = <&ext_gmac>, <&cru SCLK_MAC_EXTCLK>; + clock_in_out = "input"; + phy-supply = <&vcc_phy>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio2 RK_PD0 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 1000000>; + tx_delay = <0x30>; + rx_delay = <0x10>; + status = "okay"; +}; + +&emmc { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; diff --git a/arch/arm/dts/rk322x.dtsi b/arch/arm/dts/rk322x.dtsi new file mode 100644 index 0000000..7237da4 --- /dev/null +++ b/arch/arm/dts/rk322x.dtsi @@ -0,0 +1,710 @@ +/* + * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/clock/rk3228-cru.h> +#include <dt-bindings/thermal/thermal.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + + interrupt-parent = <&gic>; + + aliases { + serial0 = &uart0; + serial1 = &uart1; + serial2 = &uart2; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu0: cpu@f00 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0xf00>; + resets = <&cru SRST_CORE0>; + operating-points = < + /* KHz uV */ + 816000 1000000 + >; + #cooling-cells = <2>; /* min followed by max */ + clock-latency = <40000>; + clocks = <&cru ARMCLK>; + }; + + cpu1: cpu@f01 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0xf01>; + resets = <&cru SRST_CORE1>; + }; + + cpu2: cpu@f02 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0xf02>; + resets = <&cru SRST_CORE2>; + }; + + cpu3: cpu@f03 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0xf03>; + resets = <&cru SRST_CORE3>; + }; + }; + + amba { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + pdma: pdma@110f0000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x110f0000 0x4000>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + clocks = <&cru ACLK_DMAC>; + clock-names = "apb_pclk"; + }; + }; + + arm-pmu { + compatible = "arm,cortex-a7-pmu"; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; + }; + + timer { + compatible = "arm,armv7-timer"; + arm,cpu-registers-not-fw-configured; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + clock-frequency = <24000000>; + }; + + xin24m: oscillator { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "xin24m"; + #clock-cells = <0>; + }; + + bus_intmem@10080000 { + compatible = "mmio-sram"; + reg = <0x10080000 0x9000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x10080000 0x9000>; + smp-sram@0 { + compatible = "rockchip,rk322x-smp-sram"; + reg = <0x00 0x10>; + }; + ddr_sram: ddr-sram@1000 { + compatible = "rockchip,rk322x-ddr-sram"; + reg = <0x1000 0x8000>; + }; + }; + + i2s1: i2s1@100b0000 { + compatible = "rockchip,rk3228-i2s", "rockchip,rk3066-i2s"; + reg = <0x100b0000 0x4000>; + interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + clock-names = "i2s_clk", "i2s_hclk"; + clocks = <&cru SCLK_I2S1>, <&cru HCLK_I2S1_8CH>; + dmas = <&pdma 14>, <&pdma 15>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&i2s1_bus>; + status = "disabled"; + }; + + i2s0: i2s0@100c0000 { + compatible = "rockchip,rk3228-i2s", "rockchip,rk3066-i2s"; + reg = <0x100c0000 0x4000>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + clock-names = "i2s_clk", "i2s_hclk"; + clocks = <&cru SCLK_I2S0>, <&cru HCLK_I2S0_8CH>; + dmas = <&pdma 11>, <&pdma 12>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + i2s2: i2s2@100e0000 { + compatible = "rockchip,rk3228-i2s", "rockchip,rk3066-i2s"; + reg = <0x100e0000 0x4000>; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + clock-names = "i2s_clk", "i2s_hclk"; + clocks = <&cru SCLK_I2S2>, <&cru HCLK_I2S2_2CH>; + dmas = <&pdma 0>, <&pdma 1>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + grf: syscon@11000000 { + u-boot,dm-pre-reloc; + compatible = "rockchip,rk3228-grf", "syscon"; + reg = <0x11000000 0x1000>; + }; + + uart0: serial@11010000 { + compatible = "snps,dw-apb-uart"; + reg = <0x11010000 0x100>; + interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <24000000>; + clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; + clock-names = "baudclk", "apb_pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart1: serial@11020000 { + compatible = "snps,dw-apb-uart"; + reg = <0x11020000 0x100>; + interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <24000000>; + clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; + clock-names = "baudclk", "apb_pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&uart1_xfer>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart2: serial@11030000 { + compatible = "snps,dw-apb-uart"; + reg = <0x11030000 0x100>; + interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <24000000>; + clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; + clock-names = "baudclk", "apb_pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&uart2_xfer>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + i2c0: i2c@11050000 { + compatible = "rockchip,rk3228-i2c"; + reg = <0x11050000 0x1000>; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + clock-names = "i2c"; + clocks = <&cru PCLK_I2C0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_xfer>; + status = "disabled"; + }; + + i2c1: i2c@11060000 { + compatible = "rockchip,rk3228-i2c"; + reg = <0x11060000 0x1000>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + clock-names = "i2c"; + clocks = <&cru PCLK_I2C1>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_xfer>; + status = "disabled"; + }; + + i2c2: i2c@11070000 { + compatible = "rockchip,rk3228-i2c"; + reg = <0x11070000 0x1000>; + interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + clock-names = "i2c"; + clocks = <&cru PCLK_I2C2>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_xfer>; + status = "disabled"; + }; + + i2c3: i2c@11080000 { + compatible = "rockchip,rk3228-i2c"; + reg = <0x11080000 0x1000>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + clock-names = "i2c"; + clocks = <&cru PCLK_I2C3>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c3_xfer>; + status = "disabled"; + }; + + pwm0: pwm@110b0000 { + compatible = "rockchip,rk3288-pwm"; + reg = <0x110b0000 0x10>; + #pwm-cells = <3>; + clocks = <&cru PCLK_PWM>; + clock-names = "pwm"; + pinctrl-names = "default"; + pinctrl-0 = <&pwm0_pin>; + status = "disabled"; + }; + + pwm1: pwm@110b0010 { + compatible = "rockchip,rk3288-pwm"; + reg = <0x110b0010 0x10>; + #pwm-cells = <3>; + clocks = <&cru PCLK_PWM>; + clock-names = "pwm"; + pinctrl-names = "default"; + pinctrl-0 = <&pwm1_pin>; + status = "disabled"; + }; + + pwm2: pwm@110b0020 { + compatible = "rockchip,rk3288-pwm"; + reg = <0x110b0020 0x10>; + #pwm-cells = <3>; + clocks = <&cru PCLK_PWM>; + clock-names = "pwm"; + pinctrl-names = "default"; + pinctrl-0 = <&pwm2_pin>; + status = "disabled"; + }; + + pwm3: pwm@110b0030 { + compatible = "rockchip,rk3288-pwm"; + reg = <0x110b0030 0x10>; + #pwm-cells = <2>; + clocks = <&cru PCLK_PWM>; + clock-names = "pwm"; + pinctrl-names = "default"; + pinctrl-0 = <&pwm3_pin>; + status = "disabled"; + }; + + timer: timer@110c0000 { + compatible = "rockchip,rk3288-timer"; + reg = <0x110c0000 0x20>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&xin24m>, <&cru PCLK_TIMER>; + clock-names = "timer", "pclk"; + }; + + cru: clock-controller@110e0000 { + u-boot,dm-pre-reloc; + compatible = "rockchip,rk3228-cru"; + reg = <0x110e0000 0x1000>; + rockchip,grf = <&grf>; + #clock-cells = <1>; + #reset-cells = <1>; + assigned-clocks = <&cru PLL_GPLL>; + assigned-clock-rates = <594000000>; + }; + + thermal-zones { + cpu_thermal: cpu-thermal { + polling-delay-passive = <100>; /* milliseconds */ + polling-delay = <5000>; /* milliseconds */ + + thermal-sensors = <&tsadc 0>; + + trips { + cpu_alert0: cpu_alert0 { + temperature = <70000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + cpu_alert1: cpu_alert1 { + temperature = <75000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + cpu_crit: cpu_crit { + temperature = <90000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu_alert0>; + cooling-device = + <&cpu0 THERMAL_NO_LIMIT 6>; + }; + map1 { + trip = <&cpu_alert1>; + cooling-device = + <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + }; + + tsadc: tsadc@11150000 { + compatible = "rockchip,rk3228-tsadc"; + reg = <0x11150000 0x100>; + interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>; + clock-names = "tsadc", "apb_pclk"; + resets = <&cru SRST_TSADC>; + reset-names = "tsadc-apb"; + pinctrl-names = "init", "default", "sleep"; + pinctrl-0 = <&otp_gpio>; + pinctrl-1 = <&otp_out>; + pinctrl-2 = <&otp_gpio>; + #thermal-sensor-cells = <0>; + rockchip,hw-tshut-temp = <95000>; + status = "disabled"; + }; + + emmc: dwmmc@30020000 { + compatible = "rockchip,rk3288-dw-mshc"; + reg = <0x30020000 0x4000>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <37500000>; + max-frequency = <37500000>; + clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, + <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; + clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + bus-width = <8>; + default-sample-phase = <158>; + num-slots = <1>; + fifo-depth = <0x100>; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; + resets = <&cru SRST_EMMC>; + reset-names = "reset"; + status = "disabled"; + }; + + gmac: ethernet@30200000 { + compatible = "rockchip,rk3228-gmac"; + reg = <0x30200000 0x10000>; + interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + clocks = <&cru SCLK_MAC>, <&cru SCLK_MAC_RX>, + <&cru SCLK_MAC_TX>, <&cru SCLK_MAC_REF>, + <&cru SCLK_MAC_REFOUT>, <&cru ACLK_GMAC>, + <&cru PCLK_GMAC>; + clock-names = "stmmaceth", "mac_clk_rx", + "mac_clk_tx", "clk_mac_ref", + "clk_mac_refout", "aclk_mac", + "pclk_mac"; + resets = <&cru SRST_GMAC>; + reset-names = "stmmaceth"; + rockchip,grf = <&grf>; + status = "disabled"; + }; + + gic: interrupt-controller@32010000 { + compatible = "arm,gic-400"; + interrupt-controller; + #interrupt-cells = <3>; + #address-cells = <0>; + + reg = <0x32011000 0x1000>, + <0x32012000 0x2000>, + <0x32014000 0x2000>, + <0x32016000 0x2000>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + }; + + pinctrl: pinctrl { + compatible = "rockchip,rk3228-pinctrl"; + rockchip,grf = <&grf>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + gpio0: gpio0@11110000 { + compatible = "rockchip,gpio-bank"; + reg = <0x11110000 0x100>; + interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_GPIO0>; + + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio1: gpio1@11120000 { + compatible = "rockchip,gpio-bank"; + reg = <0x11120000 0x100>; + interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_GPIO1>; + + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio2@11130000 { + compatible = "rockchip,gpio-bank"; + reg = <0x11130000 0x100>; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_GPIO2>; + + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio3@11140000 { + compatible = "rockchip,gpio-bank"; + reg = <0x11140000 0x100>; + interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_GPIO3>; + + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + pcfg_pull_up: pcfg-pull-up { + bias-pull-up; + }; + + pcfg_pull_down: pcfg-pull-down { + bias-pull-down; + }; + + pcfg_pull_none: pcfg-pull-none { + bias-disable; + }; + + pcfg_pull_none_drv_12ma: pcfg-pull-none-drv-12ma { + drive-strength = <12>; + }; + + emmc { + emmc_clk: emmc-clk { + rockchip,pins = <2 RK_PA7 RK_FUNC_2 &pcfg_pull_none>; + }; + + emmc_cmd: emmc-cmd { + rockchip,pins = <1 RK_PC6 RK_FUNC_2 &pcfg_pull_none>; + }; + + emmc_bus8: emmc-bus8 { + rockchip,pins = <1 RK_PD0 RK_FUNC_2 &pcfg_pull_none>, + <1 RK_PD1 RK_FUNC_2 &pcfg_pull_none>, + <1 RK_PD2 RK_FUNC_2 &pcfg_pull_none>, + <1 RK_PD3 RK_FUNC_2 &pcfg_pull_none>, + <1 RK_PD4 RK_FUNC_2 &pcfg_pull_none>, + <1 RK_PD5 RK_FUNC_2 &pcfg_pull_none>, + <1 RK_PD6 RK_FUNC_2 &pcfg_pull_none>, + <1 RK_PD7 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + gmac { + rgmii_pins: rgmii-pins { + rockchip,pins = <2 RK_PB6 RK_FUNC_1 &pcfg_pull_none>, + <2 RK_PB4 RK_FUNC_1 &pcfg_pull_none>, + <2 RK_PD1 RK_FUNC_1 &pcfg_pull_none>, + <2 RK_PC3 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC2 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC6 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC7 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, + <2 RK_PB1 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, + <2 RK_PB5 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC1 RK_FUNC_1 &pcfg_pull_none>, + <2 RK_PC0 RK_FUNC_1 &pcfg_pull_none>, + <2 RK_PC5 RK_FUNC_2 &pcfg_pull_none>, + <2 RK_PC4 RK_FUNC_2 &pcfg_pull_none>, + <2 RK_PB3 RK_FUNC_1 &pcfg_pull_none>, + <2 RK_PB0 RK_FUNC_1 &pcfg_pull_none>; + }; + + rmii_pins: rmii-pins { + rockchip,pins = <2 RK_PB6 RK_FUNC_1 &pcfg_pull_none>, + <2 RK_PB4 RK_FUNC_1 &pcfg_pull_none>, + <2 RK_PD1 RK_FUNC_1 &pcfg_pull_none>, + <2 RK_PC3 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC2 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, + <2 RK_PB5 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC1 RK_FUNC_1 &pcfg_pull_none>, + <2 RK_PC0 RK_FUNC_1 &pcfg_pull_none>, + <2 RK_PB0 RK_FUNC_1 &pcfg_pull_none>, + <2 RK_PB7 RK_FUNC_1 &pcfg_pull_none>; + }; + + phy_pins: phy-pins { + rockchip,pins = <2 RK_PB6 RK_FUNC_2 &pcfg_pull_none>, + <2 RK_PB0 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + i2c0 { + i2c0_xfer: i2c0-xfer { + rockchip,pins = <0 RK_PA0 RK_FUNC_1 &pcfg_pull_none>, + <0 RK_PA1 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2c1 { + i2c1_xfer: i2c1-xfer { + rockchip,pins = <0 RK_PA2 RK_FUNC_1 &pcfg_pull_none>, + <0 RK_PA3 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2c2 { + i2c2_xfer: i2c2-xfer { + rockchip,pins = <2 RK_PC4 RK_FUNC_1 &pcfg_pull_none>, + <2 RK_PC5 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2c3 { + i2c3_xfer: i2c3-xfer { + rockchip,pins = <0 RK_PA6 RK_FUNC_1 &pcfg_pull_none>, + <0 RK_PA7 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2s1 { + i2s1_bus: i2s1-bus { + rockchip,pins = <0 RK_PB0 RK_FUNC_1 &pcfg_pull_none>, + <0 RK_PB1 RK_FUNC_1 &pcfg_pull_none>, + <0 RK_PB3 RK_FUNC_1 &pcfg_pull_none>, + <0 RK_PB4 RK_FUNC_1 &pcfg_pull_none>, + <0 RK_PB5 RK_FUNC_1 &pcfg_pull_none>, + <0 RK_PB6 RK_FUNC_1 &pcfg_pull_none>, + <1 RK_PA2 RK_FUNC_1 &pcfg_pull_none>, + <1 RK_PA4 RK_FUNC_1 &pcfg_pull_none>, + <1 RK_PA5 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + pwm0 { + pwm0_pin: pwm0-pin { + rockchip,pins = <3 RK_PC5 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + pwm1 { + pwm1_pin: pwm1-pin { + rockchip,pins = <0 RK_PD6 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + pwm2 { + pwm2_pin: pwm2-pin { + rockchip,pins = <1 RK_PB4 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + pwm3 { + pwm3_pin: pwm3-pin { + rockchip,pins = <1 RK_PB3 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + tsadc { + otp_gpio: otp-gpio { + rockchip,pins = <0 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + otp_out: otp-out { + rockchip,pins = <0 RK_PD0 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + uart0 { + uart0_xfer: uart0-xfer { + rockchip,pins = <2 RK_PD2 RK_FUNC_1 &pcfg_pull_none>, + <2 RK_PD3 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart0_cts: uart0-cts { + rockchip,pins = <2 RK_PD5 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart0_rts: uart0-rts { + rockchip,pins = <0 RK_PC1 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + uart1 { + uart1_xfer: uart1-xfer { + rockchip,pins = <1 RK_PB1 RK_FUNC_1 &pcfg_pull_none>, + <1 RK_PB2 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart1_cts: uart1-cts { + rockchip,pins = <1 RK_PB0 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart1_rts: uart1-rts { + rockchip,pins = <1 RK_PB3 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + uart2 { + uart2_xfer: uart2-xfer { + rockchip,pins = <1 RK_PC2 RK_FUNC_2 &pcfg_pull_none>, + <1 RK_PC3 RK_FUNC_2 &pcfg_pull_none>; + }; + + uart2_cts: uart2-cts { + rockchip,pins = <0 RK_PD1 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart2_rts: uart2-rts { + rockchip,pins = <0 RK_PD0 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + }; + + dmc: dmc@11200000 { + u-boot,dm-pre-reloc; + compatible = "rockchip,rk3228-dmc", "syscon"; + rockchip,cru = <&cru>; + rockchip,grf = <&grf>; + rockchip,msch = <&service_msch>; + reg = <0x11200000 0x3fc + 0x12000000 0x400>; + rockchip,sram = <&ddr_sram>; + }; + + service_msch: syscon@31090000 { + u-boot,dm-pre-reloc; + compatible = "rockchip,rk3228-msch", "syscon"; + reg = <0x31090000 0x2000>; + }; +}; diff --git a/include/dt-bindings/clock/rk3228-cru.h b/include/dt-bindings/clock/rk3228-cru.h new file mode 100644 index 0000000..b27e2b1 --- /dev/null +++ b/include/dt-bindings/clock/rk3228-cru.h @@ -0,0 +1,247 @@ +/* + * Copyright (c) 2015 Rockchip Electronics Co. Ltd. + * Author: Jeffy Chen jeffy.chen@rock-chips.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3228_H +#define _DT_BINDINGS_CLK_ROCKCHIP_RK3228_H + +/* core clocks */ +#define PLL_APLL 1 +#define PLL_DPLL 2 +#define PLL_CPLL 3 +#define PLL_GPLL 4 +#define ARMCLK 5 + +/* sclk gates (special clocks) */ +#define SCLK_SPI0 65 +#define SCLK_NANDC 67 +#define SCLK_SDMMC 68 +#define SCLK_SDIO 69 +#define SCLK_EMMC 71 +#define SCLK_TSADC 72 +#define SCLK_UART0 77 +#define SCLK_UART1 78 +#define SCLK_UART2 79 +#define SCLK_I2S0 80 +#define SCLK_I2S1 81 +#define SCLK_I2S2 82 +#define SCLK_SPDIF 83 +#define SCLK_TIMER0 85 +#define SCLK_TIMER1 86 +#define SCLK_TIMER2 87 +#define SCLK_TIMER3 88 +#define SCLK_TIMER4 89 +#define SCLK_TIMER5 90 +#define SCLK_I2S_OUT 113 +#define SCLK_SDMMC_DRV 114 +#define SCLK_SDIO_DRV 115 +#define SCLK_EMMC_DRV 117 +#define SCLK_SDMMC_SAMPLE 118 +#define SCLK_SDIO_SAMPLE 119 +#define SCLK_EMMC_SAMPLE 121 +#define SCLK_VOP 122 +#define SCLK_HDMI_HDCP 123 +#define SCLK_MAC_SRC 124 +#define SCLK_MAC_EXTCLK 125 +#define SCLK_MAC 126 +#define SCLK_MAC_REFOUT 127 +#define SCLK_MAC_REF 128 +#define SCLK_MAC_RX 129 +#define SCLK_MAC_TX 130 +#define SCLK_MAC_PHY 131 +#define SCLK_MAC_OUT 132 + +/* dclk gates */ +#define DCLK_VOP 190 +#define DCLK_HDMI_PHY 191 + +/* aclk gates */ +#define ACLK_DMAC 194 +#define ACLK_PERI 210 +#define ACLK_VOP 211 +#define ACLK_GMAC 212 + +/* pclk gates */ +#define PCLK_GPIO0 320 +#define PCLK_GPIO1 321 +#define PCLK_GPIO2 322 +#define PCLK_GPIO3 323 +#define PCLK_GRF 329 +#define PCLK_I2C0 332 +#define PCLK_I2C1 333 +#define PCLK_I2C2 334 +#define PCLK_I2C3 335 +#define PCLK_SPI0 338 +#define PCLK_UART0 341 +#define PCLK_UART1 342 +#define PCLK_UART2 343 +#define PCLK_TSADC 344 +#define PCLK_PWM 350 +#define PCLK_TIMER 353 +#define PCLK_PERI 363 +#define PCLK_HDMI_CTRL 364 +#define PCLK_HDMI_PHY 365 +#define PCLK_GMAC 367 + +/* hclk gates */ +#define HCLK_I2S0_8CH 442 +#define HCLK_I2S1_8CH 443 +#define HCLK_I2S2_2CH 444 +#define HCLK_SPDIF_8CH 445 +#define HCLK_VOP 452 +#define HCLK_NANDC 453 +#define HCLK_SDMMC 456 +#define HCLK_SDIO 457 +#define HCLK_EMMC 459 +#define HCLK_PERI 478 + +#define CLK_NR_CLKS (HCLK_PERI + 1) + +/* soft-reset indices */ +#define SRST_CORE0_PO 0 +#define SRST_CORE1_PO 1 +#define SRST_CORE2_PO 2 +#define SRST_CORE3_PO 3 +#define SRST_CORE0 4 +#define SRST_CORE1 5 +#define SRST_CORE2 6 +#define SRST_CORE3 7 +#define SRST_CORE0_DBG 8 +#define SRST_CORE1_DBG 9 +#define SRST_CORE2_DBG 10 +#define SRST_CORE3_DBG 11 +#define SRST_TOPDBG 12 +#define SRST_ACLK_CORE 13 +#define SRST_NOC 14 +#define SRST_L2C 15 + +#define SRST_CPUSYS_H 18 +#define SRST_BUSSYS_H 19 +#define SRST_SPDIF 20 +#define SRST_INTMEM 21 +#define SRST_ROM 22 +#define SRST_OTG_ADP 23 +#define SRST_I2S0 24 +#define SRST_I2S1 25 +#define SRST_I2S2 26 +#define SRST_ACODEC_P 27 +#define SRST_DFIMON 28 +#define SRST_MSCH 29 +#define SRST_EFUSE1024 30 +#define SRST_EFUSE256 31 + +#define SRST_GPIO0 32 +#define SRST_GPIO1 33 +#define SRST_GPIO2 34 +#define SRST_GPIO3 35 +#define SRST_PERIPH_NOC_A 36 +#define SRST_PERIPH_NOC_BUS_H 37 +#define SRST_PERIPH_NOC_P 38 +#define SRST_UART0 39 +#define SRST_UART1 40 +#define SRST_UART2 41 +#define SRST_PHYNOC 42 +#define SRST_I2C0 43 +#define SRST_I2C1 44 +#define SRST_I2C2 45 +#define SRST_I2C3 46 + +#define SRST_PWM 48 +#define SRST_A53_GIC 49 +#define SRST_DAP 51 +#define SRST_DAP_NOC 52 +#define SRST_CRYPTO 53 +#define SRST_SGRF 54 +#define SRST_GRF 55 +#define SRST_GMAC 56 +#define SRST_PERIPH_NOC_H 58 +#define SRST_MACPHY 63 + +#define SRST_DMA 64 +#define SRST_NANDC 68 +#define SRST_USBOTG 69 +#define SRST_OTGC 70 +#define SRST_USBHOST0 71 +#define SRST_HOST_CTRL0 72 +#define SRST_USBHOST1 73 +#define SRST_HOST_CTRL1 74 +#define SRST_USBHOST2 75 +#define SRST_HOST_CTRL2 76 +#define SRST_USBPOR0 77 +#define SRST_USBPOR1 78 +#define SRST_DDRMSCH 79 + +#define SRST_SMART_CARD 80 +#define SRST_SDMMC 81 +#define SRST_SDIO 82 +#define SRST_EMMC 83 +#define SRST_SPI 84 +#define SRST_TSP_H 85 +#define SRST_TSP 86 +#define SRST_TSADC 87 +#define SRST_DDRPHY 88 +#define SRST_DDRPHY_P 89 +#define SRST_DDRCTRL 90 +#define SRST_DDRCTRL_P 91 +#define SRST_HOST0_ECHI 92 +#define SRST_HOST1_ECHI 93 +#define SRST_HOST2_ECHI 94 +#define SRST_VOP_NOC_A 95 + +#define SRST_HDMI_P 96 +#define SRST_VIO_ARBI_H 97 +#define SRST_IEP_NOC_A 98 +#define SRST_VIO_NOC_H 99 +#define SRST_VOP_A 100 +#define SRST_VOP_H 101 +#define SRST_VOP_D 102 +#define SRST_UTMI0 103 +#define SRST_UTMI1 104 +#define SRST_UTMI2 105 +#define SRST_UTMI3 106 +#define SRST_RGA 107 +#define SRST_RGA_NOC_A 108 +#define SRST_RGA_A 109 +#define SRST_RGA_H 110 +#define SRST_HDCP_A 111 + +#define SRST_VPU_A 112 +#define SRST_VPU_H 113 +#define SRST_VPU_NOC_A 116 +#define SRST_VPU_NOC_H 117 +#define SRST_RKVDEC_A 118 +#define SRST_RKVDEC_NOC_A 119 +#define SRST_RKVDEC_H 120 +#define SRST_RKVDEC_NOC_H 121 +#define SRST_RKVDEC_CORE 122 +#define SRST_RKVDEC_CABAC 123 +#define SRST_IEP_A 124 +#define SRST_IEP_H 125 +#define SRST_GPU_A 126 +#define SRST_GPU_NOC_A 127 + +#define SRST_CORE_DBG 128 +#define SRST_DBG_P 129 +#define SRST_TIMER0 130 +#define SRST_TIMER1 131 +#define SRST_TIMER2 132 +#define SRST_TIMER3 133 +#define SRST_TIMER4 134 +#define SRST_TIMER5 135 +#define SRST_VIO_H2P 136 +#define SRST_HDMIPHY 139 +#define SRST_VDAC 140 +#define SRST_TIMER_6CH_P 141 + +#endif
- SPDX-License-Identifier: GPL-2.0+ X11
+/dts-v1/;
- model = "Rockchip RK3229 Evaluation board";
- compatible = "rockchip,rk3229-evb", "rockchip,rk3229";
- chosen {
- memory@60000000 {
- ext_gmac: ext_gmac {
#clock-cells = <0>;
- vcc_phy: vcc-phy-regulator {
enable-active-high;
regulator-boot-on;
+&dmc {
- rockchip,sdram-channel = /bits/ 8 <1 10 3 2 1 0 15 15>;
- rockchip,pctl-timing = <0x96 0xC8 0x1F3 0xF 0x8000004D 0x4 0x4E 0x6 0x3
0x0 0x924>;
- rockchip,phy-timing = <0x220 0x1 0x0 0x0 0x0 0x4 0x60>;
- rockchip,sdram-params = <0x428B188 0x0 0x21 0x472 0x15
0 300 3 0 120>;
+&gmac {
- assigned-clocks = <&cru SCLK_MAC_EXTCLK>, <&cru SCLK_MAC>;
- assigned-clock-parents = <&ext_gmac>, <&cru SCLK_MAC_EXTCLK>;
- clock_in_out = "input";
- phy-supply = <&vcc_phy>;
- phy-mode = "rgmii";
- pinctrl-names = "default";
- pinctrl-0 = <&rgmii_pins>;
- snps,reset-gpio = <&gpio2 RK_PD0 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 10000 1000000>;
- tx_delay = <0x30>;
- rx_delay = <0x10>;
- status = "okay";
+&emmc {
- u-boot,dm-pre-reloc;
- status = "okay";
+&uart2 {
- status = "okay";
- Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd.
- #address-cells = <1>;
- #size-cells = <1>;
- interrupt-parent = <&gic>;
- aliases {
serial0 = &uart0;
serial1 = &uart1;
serial2 = &uart2;
- cpus {
#size-cells = <0>;
cpu0: cpu@f00 {
reg = <0xf00>;
/* KHz uV */
816000 1000000
cpu1: cpu@f01 {
reg = <0xf01>;
cpu2: cpu@f02 {
reg = <0xf02>;
cpu3: cpu@f03 {
reg = <0xf03>;
- amba {
#size-cells = <1>;
ranges;
#dma-cells = <1>;
- arm-pmu {
- timer {
- xin24m: oscillator {
#clock-cells = <0>;
- bus_intmem@10080000 {
#size-cells = <1>;
smp-sram@0 {
reg = <0x00 0x10>;
- i2s1: i2s1@100b0000 {
#size-cells = <0>;
- i2s0: i2s0@100c0000 {
#size-cells = <0>;
- i2s2: i2s2@100e0000 {
#size-cells = <0>;
- grf: syscon@11000000 {
- uart0: serial@11010000 {
reg-shift = <2>;
reg-io-width = <4>;
- uart1: serial@11020000 {
reg-shift = <2>;
reg-io-width = <4>;
- uart2: serial@11030000 {
reg-shift = <2>;
reg-io-width = <4>;
- i2c0: i2c@11050000 {
#size-cells = <0>;
- i2c1: i2c@11060000 {
#size-cells = <0>;
- i2c2: i2c@11070000 {
#size-cells = <0>;
- i2c3: i2c@11080000 {
#size-cells = <0>;
- pwm0: pwm@110b0000 {
#pwm-cells = <3>;
- pwm1: pwm@110b0010 {
#pwm-cells = <3>;
- pwm2: pwm@110b0020 {
#pwm-cells = <3>;
- pwm3: pwm@110b0030 {
#pwm-cells = <2>;
- timer: timer@110c0000 {
- cru: clock-controller@110e0000 {
#clock-cells = <1>;
#reset-cells = <1>;
- thermal-zones {
trips {
type = "passive";
type = "passive";
type = "critical";
cooling-maps {
map0 {
cooling-device =
map1 {
cooling-device =
- tsadc: tsadc@11150000 {
- emmc: dwmmc@30020000 {
bus-width = <8>;
num-slots = <1>;
- gmac: ethernet@30200000 {
<&cru PCLK_GMAC>;
"pclk_mac";
- gic: interrupt-controller@32010000 {
- pinctrl: pinctrl {
#size-cells = <1>;
ranges;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
bias-pull-up;
bias-pull-down;
bias-disable;
emmc {
gmac {
i2c0 {
i2c1 {
i2c2 {
i2c3 {
i2s1 {
pwm0 {
pwm1 {
pwm2 {
pwm3 {
tsadc {
otp_out: otp-out {
uart0 {
uart1 {
uart2 {
- dmc: dmc@11200000 {
0x12000000 0x400>;
- service_msch: syscon@31090000 {
- Copyright (c) 2015 Rockchip Electronics Co. Ltd.
- Author: Jeffy Chen jeffy.chen@rock-chips.com
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
Enable soc support for SPL and U-boot skeleton.
arch/arm/include/asm/arch-rockchip/clock.h | 1 + arch/arm/mach-rockchip/Kconfig | 13 +++ arch/arm/mach-rockchip/Makefile | 3 + arch/arm/mach-rockchip/rk322x-board-spl.c | 77 +++++++++++++ arch/arm/mach-rockchip/rk322x-board.c | 159 ++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk322x/Kconfig | 18 +++ arch/arm/mach-rockchip/rk322x/Makefile | 9 ++ arch/arm/mach-rockchip/rk322x/clk_rk322x.c | 33 ++++++ arch/arm/mach-rockchip/rk322x/syscon_rk322x.c | 22 ++++ include/configs/rk322x_common.h | 92 +++++++++++++++ 10 files changed, 427 insertions(+) create mode 100644 arch/arm/mach-rockchip/rk322x-board-spl.c create mode 100644 arch/arm/mach-rockchip/rk322x-board.c create mode 100644 arch/arm/mach-rockchip/rk322x/Kconfig create mode 100644 arch/arm/mach-rockchip/rk322x/Makefile create mode 100644 arch/arm/mach-rockchip/rk322x/clk_rk322x.c create mode 100644 arch/arm/mach-rockchip/rk322x/syscon_rk322x.c create mode 100644 include/configs/rk322x_common.h
diff --git a/arch/arm/include/asm/arch-rockchip/clock.h b/arch/arm/include/asm/arch-rockchip/clock.h index b06bb6c..641df58 100644 --- a/arch/arm/include/asm/arch-rockchip/clock.h +++ b/arch/arm/include/asm/arch-rockchip/clock.h @@ -19,6 +19,7 @@ enum { ROCKCHIP_SYSCON_PMUGRF, ROCKCHIP_SYSCON_PMUSGRF, ROCKCHIP_SYSCON_CIC, + ROCKCHIP_SYSCON_MSCH, };
/* Standard Rockchip clock numbers */ diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 9b2ef29..33bd17f 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -28,6 +28,19 @@ config ROCKCHIP_RK3188 Peripherals include Fast Ethernet, USB2 host and OTG, SDIO, I2S, UART, SPI, I2C and PWMs.
+config ROCKCHIP_RK322X + bool "Support Rockchip RK3228/RK3229" + select CPU_V7 + select SUPPORT_SPL + select SPL + select ROCKCHIP_BROM_HELPER + select DEBUG_UART_BOARD_INIT + help + The Rockchip RK3229 is a ARM-based SoC with a dual-core Cortex-A7 + including NEON and GPU, Mali-400 graphics, several DDR3 options + and video codec support. Peripherals include Gigabit Ethernet, + USB2 host and OTG, SDIO, I2S, UART, SPI, I2C and PWMs. + config ROCKCHIP_RK3288 bool "Support Rockchip RK3288" select CPU_V7 diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 87d2019..71dd66d 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -12,11 +12,13 @@ obj-$(CONFIG_ROCKCHIP_BROM_HELPER) += save_boot_param.o else ifdef CONFIG_SPL_BUILD obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board-spl.o +obj-$(CONFIG_ROCKCHIP_RK322X) += rk322x-board-spl.o obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board-spl.o obj-$(CONFIG_ROCKCHIP_RK3399) += rk3399-board-spl.o obj-$(CONFIG_ROCKCHIP_BROM_HELPER) += save_boot_param.o else obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board.o +obj-$(CONFIG_ROCKCHIP_RK322X) += rk322x-board.o obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board.o obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board.o endif @@ -29,6 +31,7 @@ ifndef CONFIG_TPL_BUILD obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188/ endif
+obj-$(CONFIG_ROCKCHIP_RK322X) += rk322x/ obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288/ obj-$(CONFIG_ROCKCHIP_RK3328) += rk3328/ obj-$(CONFIG_ROCKCHIP_RK3368) += rk3368/ diff --git a/arch/arm/mach-rockchip/rk322x-board-spl.c b/arch/arm/mach-rockchip/rk322x-board-spl.c new file mode 100644 index 0000000..b2d0635 --- /dev/null +++ b/arch/arm/mach-rockchip/rk322x-board-spl.c @@ -0,0 +1,77 @@ +/* + * (C) Copyright 2015 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <ram.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/arch/bootrom.h> +#include <asm/arch/cru_rk322x.h> +#include <asm/arch/grf_rk322x.h> +#include <asm/arch/hardware.h> +#include <asm/arch/timer.h> +#include <asm/arch/uart.h> + +u32 spl_boot_device(void) +{ + return BOOT_DEVICE_MMC1; +} +DECLARE_GLOBAL_DATA_PTR; + +#define GRF_BASE 0x11000000 +#define SGRF_BASE 0x10140000 + +#define DEBUG_UART_BASE 0x11030000 + +void board_debug_uart_init(void) +{ +static struct rk322x_grf * const grf = (void *)GRF_BASE; + /* Enable early UART2 channel 1 on the RK322x */ + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B1_MASK | GPIO1B2_MASK, + GPIO1B2_UART21_SIN << GPIO1B2_SHIFT | + GPIO1B1_UART21_SOUT << GPIO1B1_SHIFT); + /* Set channel C as UART2 input */ + rk_clrsetreg(&grf->con_iomux, + CON_IOMUX_UART2SEL_MASK, + CON_IOMUX_UART2SEL_21 << CON_IOMUX_UART2SEL_SHIFT); +} +void board_init_f(ulong dummy) +{ + struct udevice *dev; + int ret; + + /* + * Debug UART can be used from here if required: + * + * debug_uart_init(); + * printch('a'); + * printhex8(0x1234); + * printascii("string"); + */ + debug_uart_init(); + printascii("SPL Init"); + + ret = spl_early_init(); + if (ret) { + debug("spl_early_init() failed: %d\n", ret); + hang(); + } + + rockchip_timer_init(); + printf("timer init done\n"); + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + printf("DRAM init failed: %d\n", ret); + return; + } + +#if defined(CONFIG_ROCKCHIP_SPL_BACK_TO_BROM) && !defined(CONFIG_SPL_BOARD_INIT) + back_to_bootrom(); +#endif +} diff --git a/arch/arm/mach-rockchip/rk322x-board.c b/arch/arm/mach-rockchip/rk322x-board.c new file mode 100644 index 0000000..1d4fa72 --- /dev/null +++ b/arch/arm/mach-rockchip/rk322x-board.c @@ -0,0 +1,159 @@ +/* + * (C) Copyright 2015 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <ram.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/periph.h> +#include <asm/arch/grf_rk322x.h> +#include <asm/arch/boot_mode.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define GRF_BASE 0x11000000 + +static void setup_boot_mode(void) +{ + struct rk322x_grf *const grf = (void *)GRF_BASE; + int boot_mode = readl(&grf->os_reg[4]); + + debug("boot mode %x.\n", boot_mode); + + /* Clear boot mode */ + writel(BOOT_NORMAL, &grf->os_reg[4]); + + switch (boot_mode) { + case BOOT_FASTBOOT: + printf("enter fastboot!\n"); + setenv("preboot", "setenv preboot; fastboot usb0"); + break; + case BOOT_UMS: + printf("enter UMS!\n"); + setenv("preboot", "setenv preboot; ums mmc 0"); + break; + } +} + +__weak int rk_board_late_init(void) +{ + return 0; +} + +int board_late_init(void) +{ + setup_boot_mode(); + + return rk_board_late_init(); +} + +int board_init(void) +{ +#include <asm/arch/grf_rk322x.h> + /* Enable early UART2 channel 1 on the RK322x */ +#define GRF_BASE 0x11000000 + struct rk322x_grf * const grf = (void *)GRF_BASE; + + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B1_MASK | GPIO1B2_MASK, + GPIO1B2_UART21_SIN << GPIO1B2_SHIFT | + GPIO1B1_UART21_SOUT << GPIO1B1_SHIFT); + /* Set channel C as UART2 input */ + rk_clrsetreg(&grf->con_iomux, + CON_IOMUX_UART2SEL_MASK, + CON_IOMUX_UART2SEL_21 << CON_IOMUX_UART2SEL_SHIFT); + + return 0; +} + +int dram_init_banksize(void) +{ + /* Reserve 0x200000 for OPTEE */ + gd->bd->bi_dram[0].start = 0x60000000; + gd->bd->bi_dram[0].size = 0x8400000; + gd->bd->bi_dram[1].start = 0x6a400000; + gd->bd->bi_dram[1].size = 0x40000000 - 0xa400000; + + return 0; +} + +int dram_init(void) +{ + struct ram_info ram; + struct udevice *dev; + int ret; + + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + debug("DRAM init failed: %d\n", ret); + return ret; + } + ret = ram_get_info(dev, &ram); + if (ret) { + debug("Cannot get DRAM size: %d\n", ret); + return ret; + } + debug("SDRAM base=%x, size=%x\n", + (unsigned int)ram.base, (unsigned int)ram.size); + gd->ram_size = ram.size; + + return 0; +} + +#ifndef CONFIG_SYS_DCACHE_OFF +void enable_caches(void) +{ + /* Enable D-cache. I-cache is already enabled in start.S */ + dcache_enable(); +} +#endif + +#if defined(CONFIG_USB_GADGET) && defined(CONFIG_USB_GADGET_DWC2_OTG) +#include <usb.h> +#include <usb/dwc2_udc.h> + +static struct dwc2_plat_otg_data rk322x_otg_data = { + .rx_fifo_sz = 512, + .np_tx_fifo_sz = 16, + .tx_fifo_sz = 128, +}; + +int board_usb_init(int index, enum usb_init_type init) +{ + int node; + const char *mode; + bool matched = false; + const void *blob = gd->fdt_blob; + + /* find the usb_otg node */ + node = fdt_node_offset_by_compatible(blob, -1, + "rockchip,rk3288-usb"); + + while (node > 0) { + mode = fdt_getprop(blob, node, "dr_mode", NULL); + if (mode && strcmp(mode, "otg") == 0) { + matched = true; + break; + } + + node = fdt_node_offset_by_compatible(blob, node, + "rockchip,rk3288-usb"); + } + if (!matched) { + debug("Not found usb_otg device\n"); + return -ENODEV; + } + rk322x_otg_data.regs_otg = fdtdec_get_addr(blob, node, "reg"); + + return dwc2_udc_probe(&rk322x_otg_data); +} + +int board_usb_cleanup(int index, enum usb_init_type init) +{ + return 0; +} +#endif diff --git a/arch/arm/mach-rockchip/rk322x/Kconfig b/arch/arm/mach-rockchip/rk322x/Kconfig new file mode 100644 index 0000000..dc8071e --- /dev/null +++ b/arch/arm/mach-rockchip/rk322x/Kconfig @@ -0,0 +1,18 @@ +if ROCKCHIP_RK322X + +config TARGET_EVB_RK3229 + bool "EVB_RK3229" + select BOARD_LATE_INIT + +config SYS_SOC + default "rockchip" + +config SYS_MALLOC_F_LEN + default 0x400 + +config SPL_SERIAL_SUPPORT + default y + +source "board/rockchip/evb_rk3229/Kconfig" + +endif diff --git a/arch/arm/mach-rockchip/rk322x/Makefile b/arch/arm/mach-rockchip/rk322x/Makefile new file mode 100644 index 0000000..ecb3e8d --- /dev/null +++ b/arch/arm/mach-rockchip/rk322x/Makefile @@ -0,0 +1,9 @@ +# +# (C) Copyright 2017 Rockchip Electronics Co., Ltd. +# +# SPDX-License-Identifier: GPL-2.0+ +# + + +obj-y += clk_rk322x.o +obj-y += syscon_rk322x.o diff --git a/arch/arm/mach-rockchip/rk322x/clk_rk322x.c b/arch/arm/mach-rockchip/rk322x/clk_rk322x.c new file mode 100644 index 0000000..6e8be93 --- /dev/null +++ b/arch/arm/mach-rockchip/rk322x/clk_rk322x.c @@ -0,0 +1,33 @@ +/* + * Copyright (C) 2016 Google, Inc + * Written by Simon Glass sjg@chromium.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <syscon.h> +#include <asm/arch/clock.h> +#include <asm/arch/cru_rk322x.h> + +int rockchip_get_clk(struct udevice **devp) +{ + return uclass_get_device_by_driver(UCLASS_CLK, + DM_GET_DRIVER(rockchip_rk322x_cru), devp); +} + +void *rockchip_get_cru(void) +{ + struct rk322x_clk_priv *priv; + struct udevice *dev; + int ret; + + ret = rockchip_get_clk(&dev); + if (ret) + return ERR_PTR(ret); + + priv = dev_get_priv(dev); + + return priv->cru; +} diff --git a/arch/arm/mach-rockchip/rk322x/syscon_rk322x.c b/arch/arm/mach-rockchip/rk322x/syscon_rk322x.c new file mode 100644 index 0000000..c5cae32 --- /dev/null +++ b/arch/arm/mach-rockchip/rk322x/syscon_rk322x.c @@ -0,0 +1,22 @@ +/* + * (C) Copyright 2015 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <syscon.h> +#include <asm/arch/clock.h> + +static const struct udevice_id rk322x_syscon_ids[] = { + { .compatible = "rockchip,rk3228-grf", .data = ROCKCHIP_SYSCON_GRF }, + { .compatible = "rockchip,rk3228-msch", .data = ROCKCHIP_SYSCON_MSCH }, + { } +}; + +U_BOOT_DRIVER(syscon_rk322x) = { + .name = "rk322x_syscon", + .id = UCLASS_SYSCON, + .of_match = rk322x_syscon_ids, +}; diff --git a/include/configs/rk322x_common.h b/include/configs/rk322x_common.h new file mode 100644 index 0000000..23b1707 --- /dev/null +++ b/include/configs/rk322x_common.h @@ -0,0 +1,92 @@ +/* + * (C) Copyright 2015 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __CONFIG_RK322X_COMMON_H +#define __CONFIG_RK322X_COMMON_H + +#include <asm/arch/hardware.h> +#include "rockchip-common.h" + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_MALLOC_LEN (32 << 20) +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */ + +#define CONFIG_SYS_TIMER_RATE (24 * 1000 * 1000) +#define CONFIG_SYS_TIMER_BASE 0x110c00a0 /* TIMER5 */ +#define CONFIG_SYS_TIMER_COUNTER (CONFIG_SYS_TIMER_BASE + 8) + +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_TEXT_BASE 0x60000000 +#define CONFIG_SYS_INIT_SP_ADDR 0x60100000 +#define CONFIG_SYS_LOAD_ADDR 0x60800800 +#define CONFIG_SPL_STACK 0x10088000 +#define CONFIG_SPL_TEXT_BASE 0x10081004 + +#define CONFIG_ROCKCHIP_MAX_INIT_SIZE (28 << 10) +#define CONFIG_ROCKCHIP_CHIP_TAG "RK32" + +/* MMC/SD IP block */ +#define CONFIG_BOUNCE_BUFFER + +#define CONFIG_SYS_SDRAM_BASE 0x60000000 +#define CONFIG_NR_DRAM_BANKS 2 +#define SDRAM_BANK_SIZE (512UL << 20UL) + +#ifndef CONFIG_SPL_BUILD +/* usb otg */ +#define CONFIG_USB_GADGET +#define CONFIG_USB_GADGET_DUALSPEED +#define CONFIG_USB_GADGET_DWC2_OTG +#define CONFIG_USB_GADGET_VBUS_DRAW 0 + +/* fastboot */ +#define CONFIG_CMD_FASTBOOT +#define CONFIG_USB_FUNCTION_FASTBOOT +#define CONFIG_FASTBOOT_FLASH +#define CONFIG_FASTBOOT_FLASH_MMC_DEV 0 +#define CONFIG_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR +#define CONFIG_FASTBOOT_BUF_SIZE 0x08000000 + +/* usb mass storage */ +#define CONFIG_USB_FUNCTION_MASS_STORAGE +#define CONFIG_CMD_USB_MASS_STORAGE + +#define CONFIG_USB_GADGET_DOWNLOAD +#define CONFIG_G_DNL_MANUFACTURER "Rockchip" +#define CONFIG_G_DNL_VENDOR_NUM 0x2207 +#define CONFIG_G_DNL_PRODUCT_NUM 0x320a + +/* usb host */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_DWC2 +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_SMSC95XX +#define CONFIG_USB_ETHER_ASIX +#endif +#define ENV_MEM_LAYOUT_SETTINGS \ + "scriptaddr=0x60000000\0" \ + "pxefile_addr_r=0x60100000\0" \ + "fdt_addr_r=0x61f00000\0" \ + "kernel_addr_r=0x62000000\0" \ + "ramdisk_addr_r=0x64000000\0" + +#include <config_distro_bootcmd.h> + +/* Linux fails to load the fdt if it's loaded above 512M on a evb-rk3036 board, + * so limit the fdt reallocation to that */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0x7fffffff\0" \ + "partitions=" PARTS_DEFAULT \ + ENV_MEM_LAYOUT_SETTINGS \ + BOOTENV +#endif + +#define CONFIG_PREBOOT + +#endif
- ROCKCHIP_SYSCON_MSCH,
- bool "Support Rockchip RK3228/RK3229"
- select CPU_V7
- select SUPPORT_SPL
- select SPL
- select ROCKCHIP_BROM_HELPER
- select DEBUG_UART_BOARD_INIT
- help
- (C) Copyright 2015 Rockchip Electronics Co., Ltd
- return BOOT_DEVICE_MMC1;
- /* Enable early UART2 channel 1 on the RK322x */
- rk_clrsetreg(&grf->gpio1b_iomux,
- /* Set channel C as UART2 input */
- rk_clrsetreg(&grf->con_iomux,
- struct udevice *dev;
- int ret;
* printch('a');
- debug_uart_init();
- printascii("SPL Init");
- ret = spl_early_init();
- if (ret) {
hang();
- rockchip_timer_init();
- printf("timer init done\n");
- ret = uclass_get_device(UCLASS_RAM, 0, &dev);
- if (ret) {
return;
- back_to_bootrom();
- struct rk322x_grf *const grf = (void *)GRF_BASE;
- int boot_mode = readl(&grf->os_reg[4]);
- debug("boot mode %x.\n", boot_mode);
- /* Clear boot mode */
- writel(BOOT_NORMAL, &grf->os_reg[4]);
- switch (boot_mode) {
- case BOOT_FASTBOOT:
break;
- case BOOT_UMS:
break;
- setup_boot_mode();
- return rk_board_late_init();
- struct rk322x_grf * const grf = (void *)GRF_BASE;
- /* Reserve 0x200000 for OPTEE */
- gd->bd->bi_dram[0].start = 0x60000000;
- gd->bd->bi_dram[0].size = 0x8400000;
- gd->bd->bi_dram[1].start = 0x6a400000;
- gd->bd->bi_dram[1].size = 0x40000000 - 0xa400000;
- struct ram_info ram;
- int ret;
- if (ret) {
return ret;
- ret = ram_get_info(dev, &ram);
- if (ret) {
return ret;
- debug("SDRAM base=%x, size=%x\n",
- gd->ram_size = ram.size;
- /* Enable D-cache. I-cache is already enabled in start.S */
- dcache_enable();
+} +#endif
- .rx_fifo_sz = 512,
- .np_tx_fifo_sz = 16,
- .tx_fifo_sz = 128,
- int node;
- const char *mode;
- bool matched = false;
- const void *blob = gd->fdt_blob;
- /* find the usb_otg node */
- node = fdt_node_offset_by_compatible(blob, -1,
- while (node > 0) {
matched = true;
break;
- if (!matched) {
return -ENODEV;
- rk322x_otg_data.regs_otg = fdtdec_get_addr(blob, node, "reg");
- return dwc2_udc_probe(&rk322x_otg_data);
- bool "EVB_RK3229"
- select BOARD_LATE_INIT
+config SYS_SOC
- default "rockchip"
- default 0x400
- default y
- Copyright (C) 2016 Google, Inc
- Written by Simon Glass sjg@chromium.org
- return uclass_get_device_by_driver(UCLASS_CLK,
- struct rk322x_clk_priv *priv;
- int ret;
- ret = rockchip_get_clk(&dev);
- if (ret)
- priv = dev_get_priv(dev);
- return priv->cru;
- { .compatible = "rockchip,rk3228-grf", .data = ROCKCHIP_SYSCON_GRF },
- { .compatible = "rockchip,rk3228-msch", .data = ROCKCHIP_SYSCON_MSCH },
- .name = "rk322x_syscon",
- .id = UCLASS_SYSCON,
- .of_match = rk322x_syscon_ids,
- "scriptaddr=0x60000000\0" \
- "pxefile_addr_r=0x60100000\0" \
- "fdt_addr_r=0x61f00000\0" \
- "kernel_addr_r=0x62000000\0" \
- "ramdisk_addr_r=0x64000000\0"
- so limit the fdt reallocation to that */
- "fdt_high=0x7fffffff\0" \
- "partitions=" PARTS_DEFAULT \
- ENV_MEM_LAYOUT_SETTINGS \
- BOOTENV
Rockchip rk322x sysreset is much like rk3036 and other Rockchip SoCs, only difference is that the target register address is different.
drivers/sysreset/sysreset_rk322x.c | 45 ++++++++++++++++++++++++++++++++++++++ 1 file changed, 45 insertions(+) create mode 100644 drivers/sysreset/sysreset_rk322x.c
diff --git a/drivers/sysreset/sysreset_rk322x.c b/drivers/sysreset/sysreset_rk322x.c new file mode 100644 index 0000000..5fce79b --- /dev/null +++ b/drivers/sysreset/sysreset_rk322x.c @@ -0,0 +1,45 @@ +/* + * (C) Copyright 2017 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <sysreset.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/cru_rk322x.h> +#include <asm/arch/hardware.h> +#include <linux/err.h> + +int rk322x_sysreset_request(struct udevice *dev, enum sysreset_t type) +{ + struct rk322x_cru *cru = rockchip_get_cru(); + + if (IS_ERR(cru)) + return PTR_ERR(cru); + switch (type) { + case SYSRESET_WARM: + writel(0xeca8, &cru->cru_glb_srst_snd_value); + break; + case SYSRESET_COLD: + writel(0xfdb9, &cru->cru_glb_srst_fst_value); + break; + default: + return -EPROTONOSUPPORT; + } + + return -EINPROGRESS; +} + +static struct sysreset_ops rk322x_sysreset = { + .request = rk322x_sysreset_request, +}; + +U_BOOT_DRIVER(sysreset_rk322x) = { + .name = "rk322x_sysreset", + .id = UCLASS_SYSRESET, + .ops = &rk322x_sysreset, +};
- (C) Copyright 2017 Rockchip Electronics Co., Ltd
- struct rk322x_cru *cru = rockchip_get_cru();
- if (IS_ERR(cru))
- switch (type) {
- case SYSRESET_WARM:
Please make this a symbolic constant, thanks.
break;
- case SYSRESET_COLD:
Same.
break;
- default:
- return -EINPROGRESS;
- .request = rk322x_sysreset_request,
- .name = "rk322x_sysreset",
- .id = UCLASS_SYSRESET,
- .ops = &rk322x_sysreset,
Hi Philipp,
- if (IS_ERR(cru))
- switch (type) {
Do you mean define a MACRO and use it?
Thanks, - Kever
break;
Same.
break;
- default:
Kever,
On 23 Jun 2017, at 10:41, Kever Yang kever.yang@rock-chips.com wrote:
Hi Philipp,
- if (IS_ERR(cru))
- switch (type) {
I think the way this has been done in the past for the Rockchip sub-architecture was to use an enum…
Personally, I would prefer a ‘static const u32’, but let’s keep consistent and stick with enums.
Thanks,
- Kever
break;
Same.
break;
- default:
Kever,
On 23 Jun 2017, at 10:46, Dr. Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
- if (IS_ERR(cru))
- switch (type) {
I just took another look and see that the constant isn’t needed anywhere outside the sysrequest driver. So you could just use a ‘const u32 [put-symbolic-name-here] = 0xeca8’ in the function itself. The compiler will take care of handling this in an optimal way from there.
Regards, Philipp.
evb_rk3229 is a RK3229 based board, with: - 8GB eMMC; - 1GB DDR SDRAM; - 2 USB2.0 HOST port; - 1 MAC port; - 1 HDMI port; - IR; - WiFi;
arch/arm/mach-rockchip/Kconfig | 1 + board/rockchip/evb_rk3229/Kconfig | 15 +++++++++ board/rockchip/evb_rk3229/MAINTAINERS | 6 ++++ board/rockchip/evb_rk3229/Makefile | 7 ++++ board/rockchip/evb_rk3229/evb_rk3229.c | 12 +++++++ configs/evb-rk3229_defconfig | 44 +++++++++++++++++++++++++ include/configs/evb_rk3229.h | 60 ++++++++++++++++++++++++++++++++++ 7 files changed, 145 insertions(+) create mode 100644 board/rockchip/evb_rk3229/Kconfig create mode 100644 board/rockchip/evb_rk3229/MAINTAINERS create mode 100644 board/rockchip/evb_rk3229/Makefile create mode 100644 board/rockchip/evb_rk3229/evb_rk3229.c create mode 100644 configs/evb-rk3229_defconfig create mode 100644 include/configs/evb_rk3229.h
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 33bd17f..bb44c61 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -124,6 +124,7 @@ config SPL_MMC_SUPPORT
source "arch/arm/mach-rockchip/rk3036/Kconfig" source "arch/arm/mach-rockchip/rk3188/Kconfig" +source "arch/arm/mach-rockchip/rk322x/Kconfig" source "arch/arm/mach-rockchip/rk3288/Kconfig" source "arch/arm/mach-rockchip/rk3328/Kconfig" source "arch/arm/mach-rockchip/rk3368/Kconfig" diff --git a/board/rockchip/evb_rk3229/Kconfig b/board/rockchip/evb_rk3229/Kconfig new file mode 100644 index 0000000..361dcb1 --- /dev/null +++ b/board/rockchip/evb_rk3229/Kconfig @@ -0,0 +1,15 @@ +if TARGET_EVB_RK3229 + +config SYS_BOARD + default "evb_rk3229" + +config SYS_VENDOR + default "rockchip" + +config SYS_CONFIG_NAME + default "evb_rk3229" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/rockchip/evb_rk3229/MAINTAINERS b/board/rockchip/evb_rk3229/MAINTAINERS new file mode 100644 index 0000000..dfa1090 --- /dev/null +++ b/board/rockchip/evb_rk3229/MAINTAINERS @@ -0,0 +1,6 @@ +EVB-RK3229 +M: Kever Yang kever.yang@rock-chips.com +S: Maintained +F: board/rockchip/evb_rk3229 +F: include/configs/evb_rk3229.h +F: configs/evb-rk3229_defconfig diff --git a/board/rockchip/evb_rk3229/Makefile b/board/rockchip/evb_rk3229/Makefile new file mode 100644 index 0000000..65dcd8b --- /dev/null +++ b/board/rockchip/evb_rk3229/Makefile @@ -0,0 +1,7 @@ +# +# (C) Copyright 2015 Google, Inc +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += evb_rk3229.o diff --git a/board/rockchip/evb_rk3229/evb_rk3229.c b/board/rockchip/evb_rk3229/evb_rk3229.c new file mode 100644 index 0000000..6c4ec2cd --- /dev/null +++ b/board/rockchip/evb_rk3229/evb_rk3229.c @@ -0,0 +1,12 @@ +/* + * (C) Copyright 2015 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <asm/io.h> +#include <asm/arch/uart.h> + +DECLARE_GLOBAL_DATA_PTR; diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig new file mode 100644 index 0000000..0c3b6f7 --- /dev/null +++ b/configs/evb-rk3229_defconfig @@ -0,0 +1,44 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x800 +CONFIG_ROCKCHIP_RK322X=y +CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y +CONFIG_TARGET_EVB_RK3229=y +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEFAULT_DEVICE_TREE="rk3229-evb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x200 +CONFIG_FASTBOOT=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ROCKCHIP_RK322X=y +# CONFIG_SPL_PINCTRL_FULL is not set +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0x11030000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550=y +CONFIG_SYSRESET=y +CONFIG_ERRNO_STR=y diff --git a/include/configs/evb_rk3229.h b/include/configs/evb_rk3229.h new file mode 100644 index 0000000..13fc834 --- /dev/null +++ b/include/configs/evb_rk3229.h @@ -0,0 +1,60 @@ +/* + * (C) Copyright 2015 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <configs/rk322x_common.h> + + +/* Store env in emmc */ +#undef CONFIG_ENV_SIZE +#define CONFIG_ENV_SIZE (32 << 10) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_PART 0 +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT + +#ifndef CONFIG_SPL_BUILD +/* Enable gpt partition table */ +#undef PARTS_DEFAULT +#define PARTS_DEFAULT \ + "uuid_disk=${uuid_gpt_disk};" \ + "name=loader_a,start=4M,size=4M,uuid=${uuid_gpt_loader};" \ + "name=loader_b,size=4M,uuid=${uuid_gpt_reserved};" \ + "name=trust_a,size=4M,uuid=${uuid_gpt_reserved};" \ + "name=trust_b,size=4M,uuid=${uuid_gpt_reserved};" \ + "name=misc,size=4M,uuid=${uuid_gpt_misc};" \ + "name=metadata,size=16M,uuid=${uuid_gpt_metadata};" \ + "name=boot_a,size=32M,uuid=${uuid_gpt_boot_a};" \ + "name=boot_b,size=32M,uuid=${uuid_gpt_boot_b};" \ + "name=system_a,size=818M,uuid=${uuid_gpt_system_a};" \ + "name=system_b,size=818M,uuid=${uuid_gpt_system_b};" \ + "name=vendor_a,size=50M,uuid=${uuid_gpt_vendor_a};" \ + "name=vendor_b,size=50M,uuid=${uuid_gpt_vendor_b};" \ + "name=cache,size=100M,uuid=${uuid_gpt_cache};" \ + "name=persist,size=4M,uuid=${uuid_gpt_persist};" \ + "name=userdata,size=-,uuid=${uuid_gpt_userdata};\0" \ + +#define CONFIG_PREBOOT + +#define CONFIG_ANDROID_BOOT_IMAGE +#define CONFIG_SYS_BOOT_RAMDISK_HIGH + +#undef CONFIG_BOOTCOMMAND +#define CONFIG_BOOTCOMMAND \ + "mmc read 0x61000000 0x8000 0x5000;" \ + "bootm 0x61000000" \ + +/* Enable atags */ +#define CONFIG_SYS_BOOTPARAMS_LEN (64*1024) +#define CONFIG_INITRD_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG + +#endif + +#endif
- 8GB eMMC;
- 1GB DDR SDRAM;
- 1 MAC port;
- 1 HDMI port;
- IR;
- WiFi;
+config SYS_BOARD
- default "evb_rk3229"
+config SYS_VENDOR
- def_bool y
- "uuid_disk=${uuid_gpt_disk};" \
- "name=loader_a,start=4M,size=4M,uuid=${uuid_gpt_loader};" \
- "name=loader_b,size=4M,uuid=${uuid_gpt_reserved};" \
- "name=trust_a,size=4M,uuid=${uuid_gpt_reserved};" \
- "name=trust_b,size=4M,uuid=${uuid_gpt_reserved};" \
- "name=misc,size=4M,uuid=${uuid_gpt_misc};" \
- "name=metadata,size=16M,uuid=${uuid_gpt_metadata};" \
- "name=boot_a,size=32M,uuid=${uuid_gpt_boot_a};" \
- "name=boot_b,size=32M,uuid=${uuid_gpt_boot_b};" \
- "name=system_a,size=818M,uuid=${uuid_gpt_system_a};" \
- "name=system_b,size=818M,uuid=${uuid_gpt_system_b};" \
- "name=vendor_a,size=50M,uuid=${uuid_gpt_vendor_a};" \
- "name=vendor_b,size=50M,uuid=${uuid_gpt_vendor_b};" \
- "name=cache,size=100M,uuid=${uuid_gpt_cache};" \
- "name=persist,size=4M,uuid=${uuid_gpt_persist};" \
- "name=userdata,size=-,uuid=${uuid_gpt_userdata};\0" \
- "mmc read 0x61000000 0x8000 0x5000;" \
- "bootm 0x61000000" \
Dr. Philipp Tomsich
Kever Yang
Philipp Tomsich
