[PATCH] clk: Always use the supplied struct clk
CCF clocks should always use the struct clock passed to their methods for extracting the driver-specific clock information struct. Previously, many functions would use the clk->dev->priv if the device was bound. This could cause problems with composite clocks. The individual clocks in a composite clock did not have the ->dev field filled in. This was fine, because the device-specific clock information would be used. However, since there was no ->dev, there was no way to get the parent clock. This caused the recalc_rate method of the CCF divider clock to fail. One option would be to use the clk->priv field to get the composite clock and from there get the appropriate parent device. However, this would tie the implementation to the composite clock. In general, different devices should not rely on the contents of ->priv from another device.
The simple solution to this problem is to just always use the supplied struct clock. The composite clock now fills in the ->dev pointer of its child clocks. This allows child clocks to make calls like clk_get_parent() without issue.
imx avoided the above problem by using a custom get_rate function with composite clocks.
Signed-off-by: Sean Anderson seanga2@gmail.com --- drivers/clk/clk-composite.c | 8 ++++++++ drivers/clk/clk-divider.c | 6 ++---- drivers/clk/clk-fixed-factor.c | 3 +-- drivers/clk/clk-gate.c | 6 ++---- drivers/clk/clk-gate2.c | 4 ++-- drivers/clk/clk-mux.c | 12 ++++-------- 6 files changed, 19 insertions(+), 20 deletions(-)
diff --git a/drivers/clk/clk-composite.c b/drivers/clk/clk-composite.c index a5626c33d1..d0f273d47f 100644 --- a/drivers/clk/clk-composite.c +++ b/drivers/clk/clk-composite.c @@ -145,6 +145,14 @@ struct clk *clk_register_composite(struct device *dev, const char *name, goto err; }
+ if (composite->mux) + composite->mux->dev = clk->dev; + if (composite->rate) + composite->rate->dev = clk->dev; + if (composite->gate) + composite->gate->dev = clk->dev; + + return clk;
err: diff --git a/drivers/clk/clk-divider.c b/drivers/clk/clk-divider.c index 822e09b084..bfa05f24a3 100644 --- a/drivers/clk/clk-divider.c +++ b/drivers/clk/clk-divider.c @@ -70,8 +70,7 @@ unsigned long divider_recalc_rate(struct clk *hw, unsigned long parent_rate,
static ulong clk_divider_recalc_rate(struct clk *clk) { - struct clk_divider *divider = to_clk_divider(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_divider *divider = to_clk_divider(clk); unsigned long parent_rate = clk_get_parent_rate(clk); unsigned int val;
@@ -150,8 +149,7 @@ int divider_get_val(unsigned long rate, unsigned long parent_rate,
static ulong clk_divider_set_rate(struct clk *clk, unsigned long rate) { - struct clk_divider *divider = to_clk_divider(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_divider *divider = to_clk_divider(clk); unsigned long parent_rate = clk_get_parent_rate(clk); int value; u32 val; diff --git a/drivers/clk/clk-fixed-factor.c b/drivers/clk/clk-fixed-factor.c index 711b0588bc..d2401cf440 100644 --- a/drivers/clk/clk-fixed-factor.c +++ b/drivers/clk/clk-fixed-factor.c @@ -18,8 +18,7 @@
static ulong clk_factor_recalc_rate(struct clk *clk) { - struct clk_fixed_factor *fix = - to_clk_fixed_factor(dev_get_clk_ptr(clk->dev)); + struct clk_fixed_factor *fix = to_clk_fixed_factor(clk); unsigned long parent_rate = clk_get_parent_rate(clk); unsigned long long int rate;
diff --git a/drivers/clk/clk-gate.c b/drivers/clk/clk-gate.c index 70b8794554..b2933bc24a 100644 --- a/drivers/clk/clk-gate.c +++ b/drivers/clk/clk-gate.c @@ -43,8 +43,7 @@ */ static void clk_gate_endisable(struct clk *clk, int enable) { - struct clk_gate *gate = to_clk_gate(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_gate *gate = to_clk_gate(clk); int set = gate->flags & CLK_GATE_SET_TO_DISABLE ? 1 : 0; u32 reg;
@@ -86,8 +85,7 @@ static int clk_gate_disable(struct clk *clk)
int clk_gate_is_enabled(struct clk *clk) { - struct clk_gate *gate = to_clk_gate(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_gate *gate = to_clk_gate(clk); u32 reg;
#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) diff --git a/drivers/clk/clk-gate2.c b/drivers/clk/clk-gate2.c index 565d9e49ca..93ec862ad9 100644 --- a/drivers/clk/clk-gate2.c +++ b/drivers/clk/clk-gate2.c @@ -25,7 +25,7 @@
static int clk_gate2_enable(struct clk *clk) { - struct clk_gate2 *gate = to_clk_gate2(dev_get_clk_ptr(clk->dev)); + struct clk_gate2 *gate = to_clk_gate2(clk); u32 reg;
reg = readl(gate->reg); @@ -42,7 +42,7 @@ static int clk_gate2_enable(struct clk *clk)
static int clk_gate2_disable(struct clk *clk) { - struct clk_gate2 *gate = to_clk_gate2(dev_get_clk_ptr(clk->dev)); + struct clk_gate2 *gate = to_clk_gate2(clk); u32 reg;
reg = readl(gate->reg); diff --git a/drivers/clk/clk-mux.c b/drivers/clk/clk-mux.c index 5acc0b8cbd..67b4afef28 100644 --- a/drivers/clk/clk-mux.c +++ b/drivers/clk/clk-mux.c @@ -35,8 +35,7 @@ int clk_mux_val_to_index(struct clk *clk, u32 *table, unsigned int flags, unsigned int val) { - struct clk_mux *mux = to_clk_mux(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_mux *mux = to_clk_mux(clk); int num_parents = mux->num_parents;
if (table) { @@ -79,8 +78,7 @@ unsigned int clk_mux_index_to_val(u32 *table, unsigned int flags, u8 index)
u8 clk_mux_get_parent(struct clk *clk) { - struct clk_mux *mux = to_clk_mux(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_mux *mux = to_clk_mux(clk); u32 val;
#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) @@ -97,8 +95,7 @@ u8 clk_mux_get_parent(struct clk *clk) static int clk_fetch_parent_index(struct clk *clk, struct clk *parent) { - struct clk_mux *mux = to_clk_mux(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_mux *mux = to_clk_mux(clk);
int i;
@@ -115,8 +112,7 @@ static int clk_fetch_parent_index(struct clk *clk,
static int clk_mux_set_parent(struct clk *clk, struct clk *parent) { - struct clk_mux *mux = to_clk_mux(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_mux *mux = to_clk_mux(clk); int index; u32 val; u32 reg;
Sean Anderson
