[U-Boot] [PATCH] kbuild: fix parallel build race caused by u-boot.cfg regeneration
Multiple people have reported intermittent build failure in parallel building.
Kever Yang reported this issue some time ago [1], but I could not get enough clue at that time.
This time, Richard Purdie provided a complete build log [2], which was very helpful for me to root-cause it.
The cause of the problem is commit 0d982c585330 ("Makefile: add dependencies to regenerate u-boot.cfg when lost").
That commit added the 'cfg' as the prerequisite of the 'all' target, so the parallel build tries to run it simultaneously, then regenerates a symlink while building objects.
When u-boot.cfg is accidentally lost, lets' rebuild it before descending into any subdirectories.
Also, what is annoying is u-boot.cfg is currently regenerated every time since it depends on FORCE. We can get rid of all the prerequisites of u-boot.cfg because u-boot.cfg is rebuilt anyway as the byproduct of auto.conf when a user updates the .config file.
[1] https://lists.denx.de/pipermail/u-boot/2018-June/330341.html [2] https://autobuilder.yoctoproject.org/typhoon/#/builders/65/builds/160/steps/...
Fixes: 0d982c585330 ("Makefile: add dependencies to regenerate u-boot.cfg when lost") Reported-by: Kever Yang kever.yang@rock-chips.com Reported-by: Richard Purdie richard.purdie@linuxfoundation.org Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Makefile | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/Makefile b/Makefile index eeb299f..363ebc8 100644 --- a/Makefile +++ b/Makefile @@ -534,7 +534,7 @@ include/config/%.conf: $(KCONFIG_CONFIG) include/config/auto.conf.cmd @# Otherwise, 'make silentoldconfig' would be invoked twice. $(Q)touch include/config/auto.conf
-u-boot.cfg spl/u-boot.cfg tpl/u-boot.cfg: include/config.h FORCE +u-boot.cfg spl/u-boot.cfg tpl/u-boot.cfg: $(Q)$(MAKE) -f $(srctree)/scripts/Makefile.autoconf $(@)
-include include/autoconf.mk @@ -910,7 +910,7 @@ quiet_cmd_cfgcheck = CFGCHK $2 cmd_cfgcheck = $(srctree)/scripts/check-config.sh $2 \ $(srctree)/scripts/config_whitelist.txt $(srctree)
-all: $(ALL-y) cfg +all: $(ALL-y) ifeq ($(CONFIG_DM_I2C_COMPAT)$(CONFIG_SANDBOX),y) @echo >&2 "===================== WARNING ======================" @echo >&2 "This board uses CONFIG_DM_I2C_COMPAT. Please remove" @@ -1549,7 +1549,7 @@ prepare0: archprepare FORCE $(Q)$(MAKE) $(build)=.
# All the preparing.. -prepare: prepare0 +prepare: prepare0 cfg
# Generate some files # ---------------------------------------------------------------------------
On Wed, 9 Jan 2019 at 00:32, Masahiro Yamada yamada.masahiro@socionext.com wrote:
On Wed, Jan 9, 2019 at 4:33 PM Masahiro Yamada yamada.masahiro@socionext.com wrote:
I noticed this is still unsafe because prepare0 descends into ./Kbuild and generates asm-offset things.
I will send v2.
2.7.4
Masahiro Yamada
