[U-Boot] u-boot for P2020-RDP
15 Dec
2010
15 Dec
'10
2:48 a.m.
Hello,
I built u-boot-2010.09 for Freescale's P2020-RDB.
It works great !!!
The setup I used for SW4 is according to the startup guide. SW4[7] is on.
When SW4[7] is off u-boot hangs. It means:
"boot sequencer enabled and configuration information loaded from I2C ROM. A valid ROM must be present. If not the card will hang".
I do not need the I2C ROM but for some reason, vxWorks 6.8 needs it. I'm using u-boot to download vxWorks via tftp and run it (using bootelf)
What does u-boot hangs when SW4[7] is off ? What should this I2C ROM contain ? How can I flash this ROM ?
According to the manual, this board contains I2C ROM.
Thanks, Zvika Vered
5259
Zvi Vered
