[U-Boot-Users] [PATCH 05/08]: mpc7448hpc2 board flash support
Mpc7448hpc2 board flash driver support.
Signed-off-by: Alexandre Bounine alexandreb@tundra.com Signed-off-by: Roy Zang tie-fei.zang@freescale.com
--- board/mpc7448hpc2/cfi_flash.c | 1273 +++++++++++++++++++++++++++++++++++++++++ 1 files changed, 1273 insertions(+), 0 deletions(-)
diff --git a/board/mpc7448hpc2/cfi_flash.c b/board/mpc7448hpc2/cfi_flash.c new file mode 100644 index 0000000..c901abf --- /dev/null +++ b/board/mpc7448hpc2/cfi_flash.c @@ -0,0 +1,1273 @@ +/* + * (C) Copyright 2002-2004 + * Brad Kemp, Seranoa Networks, Brad.Kemp@seranoa.com + * + * Copyright (C) 2003 Arabella Software Ltd. + * Yuli Barcohen yuli@arabellasw.com + * Modified to work with AMD flashes + * + * Copyright (C) 2004 + * Ed Okerson + * Modified to work with little-endian systems. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + * History + * 01/20/2004 - combined variants of original driver. + * 01/22/2004 - Write performance enhancements for parallel chips (Tolunay) + * 01/23/2004 - Support for x8/x16 chips (Rune Raknerud) + * 01/27/2004 - Little endian support Ed Okerson + * + * Tested Architectures + * Port Width Chip Width # of banks Flash Chip Board + * 32 16 1 28F128J3 seranoa/eagle + * 64 16 1 28F128J3 seranoa/falcon + * + */ + +/* The DEBUG define must be before common to enable debugging */ +/* #define DEBUG */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/byteorder.h> +#include <linux/byteorder/swab.h> +#ifdef CFG_HPC2_FLASH_CFI_DRIVER + +/* + * This file implements a Common Flash Interface (CFI) driver for U-Boot. + * The width of the port and the width of the chips are determined at initialization. + * These widths are used to calculate the address for access CFI data structures. + * It has been tested on an Intel Strataflash implementation and AMD 29F016D. + * + * References + * JEDEC Standard JESD68 - Common Flash Interface (CFI) + * JEDEC Standard JEP137-A Common Flash Interface (CFI) ID Codes + * Intel Application Note 646 Common Flash Interface (CFI) and Command Sets + * Intel 290667-008 3 Volt Intel StrataFlash Memory datasheet + * + * TODO + * + * Use Primary Extended Query table (PRI) and Alternate Algorithm Query + * Table (ALT) to determine if protection is available + * + * Add support for other command sets Use the PRI and ALT to determine command set + * Verify erase and program timeouts. + */ + +#ifndef CFG_FLASH_BANKS_LIST +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } +#endif + +#define FLASH_CMD_CFI 0x98 +#define FLASH_CMD_READ_ID 0x90 +#define FLASH_CMD_RESET 0xff +#define FLASH_CMD_BLOCK_ERASE 0x20 +#define FLASH_CMD_ERASE_CONFIRM 0xD0 +#define FLASH_CMD_WRITE 0x40 +#define FLASH_CMD_PROTECT 0x60 +#define FLASH_CMD_PROTECT_SET 0x01 +#define FLASH_CMD_PROTECT_CLEAR 0xD0 +#define FLASH_CMD_CLEAR_STATUS 0x50 +#define FLASH_CMD_WRITE_TO_BUFFER 0xE8 +#define FLASH_CMD_WRITE_BUFFER_CONFIRM 0xD0 + +#define FLASH_STATUS_DONE 0x80 +#define FLASH_STATUS_ESS 0x40 +#define FLASH_STATUS_ECLBS 0x20 +#define FLASH_STATUS_PSLBS 0x10 +#define FLASH_STATUS_VPENS 0x08 +#define FLASH_STATUS_PSS 0x04 +#define FLASH_STATUS_DPS 0x02 +#define FLASH_STATUS_R 0x01 +#define FLASH_STATUS_PROTECT 0x01 + +#define AMD_CMD_RESET 0xF0 +#define AMD_CMD_WRITE 0xA0 +#define AMD_CMD_ERASE_START 0x80 +#define AMD_CMD_ERASE_SECTOR 0x30 +#define AMD_CMD_UNLOCK_START 0xAA +#define AMD_CMD_UNLOCK_ACK 0x55 + +#define AMD_STATUS_TOGGLE 0x40 +#define AMD_STATUS_ERROR 0x20 +#define AMD_ADDR_ERASE_START 0x555 +#define AMD_ADDR_START 0x555 +#define AMD_ADDR_ACK 0x2AA + +#define FLASH_OFFSET_CFI 0x55 +#define FLASH_OFFSET_CFI_RESP 0x10 +#define FLASH_OFFSET_PRIMARY_VENDOR 0x13 +#define FLASH_OFFSET_WTOUT 0x1F +#define FLASH_OFFSET_WBTOUT 0x20 +#define FLASH_OFFSET_ETOUT 0x21 +#define FLASH_OFFSET_CETOUT 0x22 +#define FLASH_OFFSET_WMAX_TOUT 0x23 +#define FLASH_OFFSET_WBMAX_TOUT 0x24 +#define FLASH_OFFSET_EMAX_TOUT 0x25 +#define FLASH_OFFSET_CEMAX_TOUT 0x26 +#define FLASH_OFFSET_SIZE 0x27 +#define FLASH_OFFSET_INTERFACE 0x28 +#define FLASH_OFFSET_BUFFER_SIZE 0x2A +#define FLASH_OFFSET_NUM_ERASE_REGIONS 0x2C +#define FLASH_OFFSET_ERASE_REGIONS 0x2D +#define FLASH_OFFSET_PROTECT 0x02 +#define FLASH_OFFSET_USER_PROTECTION 0x85 +#define FLASH_OFFSET_INTEL_PROTECTION 0x81 + +#define FLASH_MAN_CFI 0x01000000 + +#define CFI_CMDSET_NONE 0 +#define CFI_CMDSET_INTEL_EXTENDED 1 +#define CFI_CMDSET_AMD_STANDARD 2 +#define CFI_CMDSET_INTEL_STANDARD 3 +#define CFI_CMDSET_AMD_EXTENDED 4 +#define CFI_CMDSET_MITSU_STANDARD 256 +#define CFI_CMDSET_MITSU_EXTENDED 257 +#define CFI_CMDSET_SST 258 + +typedef union { + unsigned char c; + unsigned short w; + unsigned long l; + unsigned long long ll; +} cfiword_t; + +typedef union { + volatile unsigned char *cp; + volatile unsigned short *wp; + volatile unsigned long *lp; + volatile unsigned long long *llp; +} cfiptr_t; + +#define NUM_ERASE_REGIONS 4 + +static ulong bank_base[CFG_MAX_FLASH_BANKS] = CFG_FLASH_BANKS_LIST; + +flash_info_t flash_info[CFG_MAX_FLASH_BANKS]; /* info for FLASH chips */ + +/*--------------------------------------------------------------------- -- + * Functions + */ + +typedef unsigned long flash_sect_t; + +static void flash_add_byte(flash_info_t * info, cfiword_t * cword, uchar c); +static void flash_make_cmd(flash_info_t * info, uchar cmd, void *cmdbuf); +static void flash_write_cmd(flash_info_t * info, flash_sect_t sect, uint offset, + uchar cmd); +static void flash_unlock_seq(flash_info_t * info, flash_sect_t sect); +static int flash_isequal(flash_info_t * info, flash_sect_t sect, uint offset, + uchar cmd); +static int flash_isset(flash_info_t * info, flash_sect_t sect, uint offset, + uchar cmd); +static int flash_toggle(flash_info_t * info, flash_sect_t sect, uint offset, + uchar cmd); +static int flash_detect_cfi(flash_info_t * info); +static ulong flash_get_size(ulong base, int banknum); +static int flash_write_cfiword(flash_info_t * info, ulong dest, + cfiword_t cword); +static int flash_full_status_check(flash_info_t * info, flash_sect_t sector, + ulong tout, char *prompt); +#ifdef CFG_FLASH_USE_BUFFER_WRITE +static int flash_write_cfibuffer(flash_info_t * info, ulong dest, uchar * cp, + int len); +#endif + +/*--------------------------------------------------------------------- -- + * create an address based on the offset and the port width + */ +inline uchar *flash_make_addr(flash_info_t * info, flash_sect_t sect, + uint offset) +{ + return ((uchar *) (info->start[sect] + (offset * info->portwidth))); +} + +#ifdef DEBUG +/*--------------------------------------------------------------------- -- + * Debug support + */ +void print_longlong(char *str, unsigned long long data) +{ + int i; + char *cp; + + cp = (unsigned char *)&data; + for (i = 0; i < 8; i++) + sprintf(&str[i * 2], "%2.2x", *cp++); +} +static void flash_printqry(flash_info_t * info, flash_sect_t sect) +{ + cfiptr_t cptr; + int x, y; + + for (x = 0; x < 0x40; x += 16 / info->portwidth) { + cptr.cp = + flash_make_addr(info, sect, x + FLASH_OFFSET_CFI_RESP); + debug("%p : ", cptr.cp); + for (y = 0; y < 16; y++) { + debug("%2.2x ", cptr.cp[y]); + } + debug(" "); + for (y = 0; y < 16; y++) { + if (cptr.cp[y] >= 0x20 && cptr.cp[y] <= 0x7e) { + debug("%c", cptr.cp[y]); + } else { + debug("."); + } + } + debug("\n"); + } +} +#endif + +/*--------------------------------------------------------------------- -- + * read a character at a port width address + */ +inline uchar flash_read_uchar(flash_info_t * info, uint offset) +{ + uchar *cp; + + cp = flash_make_addr(info, 0, offset); +#if defined(__LITTLE_ENDIAN) || defined(CONFIG_MPC7448HPC2) + return (cp[0]); +#else + return (cp[info->portwidth - 1]); +#endif +} + +/*--------------------------------------------------------------------- -- + * read a short word by swapping for ppc format. + */ +ushort flash_read_ushort(flash_info_t * info, flash_sect_t sect, uint offset) +{ + uchar *addr; + ushort retval; + +#ifdef DEBUG + int x; +#endif + addr = flash_make_addr(info, sect, offset); + +#ifdef DEBUG + debug("ushort addr is at %p info->portwidth = %d\n", addr, + info->portwidth); + for (x = 0; x < 2 * info->portwidth; x++) { + debug("addr[%x] = 0x%x\n", x, addr[x]); + } +#endif +#if defined(__LITTLE_ENDIAN) || defined(CONFIG_MPC7448HPC2) + retval = ((addr[(info->portwidth)] << 8) | addr[0]); +#else + retval = ((addr[(2 * info->portwidth) - 1] << 8) | + addr[info->portwidth - 1]); +#endif + + debug("retval = 0x%x\n", retval); + return retval; +} + +/*--------------------------------------------------------------------- -- + * read a long word by picking the least significant byte of each maiximum + * port size word. Swap for ppc format. + */ +ulong flash_read_long(flash_info_t * info, flash_sect_t sect, uint offset) +{ + uchar *addr; + ulong retval; + +#ifdef DEBUG + int x; +#endif + addr = flash_make_addr(info, sect, offset); + +#ifdef DEBUG + debug("long addr is at %p info->portwidth = %d\n", addr, + info->portwidth); + for (x = 0; x < 4 * info->portwidth; x++) { + debug("addr[%x] = 0x%x\n", x, addr[x]); + } +#endif +#if defined(__LITTLE_ENDIAN) || defined(CONFIG_MPC7448HPC2) + retval = (addr[0] << 16) | (addr[(info->portwidth)] << 24) | + (addr[(2 * info->portwidth)]) | (addr[(3 * info->portwidth)] << 8); +#else + retval = (addr[(2 * info->portwidth) - 1] << 24) | + (addr[(info->portwidth) - 1] << 16) | + (addr[(4 * info->portwidth) - 1] << 8) | + addr[(3 * info->portwidth) - 1]; +#endif + return retval; +} + +/*--------------------------------------------------------------------- -- + */ +unsigned long flash_init(void) +{ + unsigned long size = 0; + int i; + + /* Init: no FLASHes known */ + for (i = 0; i < CFG_MAX_FLASH_BANKS; ++i) { + flash_info[i].flash_id = FLASH_UNKNOWN; + size += flash_info[i].size = flash_get_size(bank_base[i], i); + if (flash_info[i].flash_id == FLASH_UNKNOWN) { + debug + ("## Unknown FLASH on Bank %d - Size = 0x%08lx = %ld MB\n", + i, flash_info[i].size, flash_info[i].size << 20); + } + } + + /* Monitor protection ON by default */ +#if (CFG_MONITOR_BASE >= CFG_FLASH_BASE) + flash_protect(FLAG_PROTECT_SET, + CFG_MONITOR_BASE, + CFG_MONITOR_BASE + CFG_MONITOR_LEN - 1, &flash_info[0]); +#endif + + return (size); +} + +/*--------------------------------------------------------------------- -- + */ +int flash_erase(flash_info_t * info, int s_first, int s_last) +{ + int rcode = 0; + int prot; + flash_sect_t sect; + + if (info->flash_id != FLASH_MAN_CFI) { + puts("Can't erase unknown flash type - aborted\n"); + return 1; + } + if ((s_first < 0) || (s_first > s_last)) { + puts("- no sectors to erase\n"); + return 1; + } + + prot = 0; + for (sect = s_first; sect <= s_last; ++sect) { + if (info->protect[sect]) { + prot++; + } + } + if (prot) { + printf("- Warning: %d protected sectors will not be erased!\n", + prot); + } else { + putc('\n'); + } + + for (sect = s_first; sect <= s_last; sect++) { + if (info->protect[sect] == 0) { /* not protected */ + switch (info->vendor) { + case CFI_CMDSET_INTEL_STANDARD: + case CFI_CMDSET_INTEL_EXTENDED: + flash_write_cmd(info, sect, 0, + FLASH_CMD_CLEAR_STATUS); + flash_write_cmd(info, sect, 0, + FLASH_CMD_BLOCK_ERASE); + flash_write_cmd(info, sect, 0, + FLASH_CMD_ERASE_CONFIRM); + break; + case CFI_CMDSET_AMD_STANDARD: + case CFI_CMDSET_AMD_EXTENDED: + flash_unlock_seq(info, sect); + flash_write_cmd(info, sect, + AMD_ADDR_ERASE_START, + AMD_CMD_ERASE_START); + flash_unlock_seq(info, sect); + flash_write_cmd(info, sect, 0, + AMD_CMD_ERASE_SECTOR); + break; + default: + debug("Unkown flash vendor %d\n", info->vendor); + break; + } + + if (flash_full_status_check + (info, sect, info->erase_blk_tout, "erase")) { + rcode = 1; + } else + putc('.'); + } + } + puts(" done\n"); + return rcode; +} + +/*--------------------------------------------------------------------- -- + */ +void flash_print_info(flash_info_t * info) +{ + int i; + + if (info->flash_id != FLASH_MAN_CFI) { + puts("missing or unknown FLASH type\n"); + return; + } + + printf("CFI conformant FLASH (%d x %d)", + (info->portwidth << 3), (info->chipwidth << 3)); + printf(" Size: %ld MB in %d Sectors\n", + info->size >> 20, info->sector_count); + printf + (" Erase timeout %ld ms, write timeout %ld ms, buffer write timeout %ld ms, buffer size %d\n", + info->erase_blk_tout, info->write_tout, info->buffer_write_tout, + info->buffer_size); + + puts(" Sector Start Addresses:"); + for (i = 0; i < info->sector_count; ++i) { +#ifdef CFG_FLASH_EMPTY_INFO + int k; + int size; + int erased; + volatile unsigned long *flash; + + /* + * Check if whole sector is erased + */ + if (i != (info->sector_count - 1)) + size = info->start[i + 1] - info->start[i]; + else + size = info->start[0] + info->size - info->start[i]; + erased = 1; + flash = (volatile unsigned long *)info->start[i]; + size = size >> 2; /* divide by 4 for longword access */ + for (k = 0; k < size; k++) { + if (*flash++ != 0xffffffff) { + erased = 0; + break; + } + } + + if ((i % 5) == 0) + printf("\n"); + /* print empty and read-only info */ + printf(" %08lX%s%s", + info->start[i], + erased ? " E" : " ", info->protect[i] ? "RO " : " "); +#else + if ((i % 5) == 0) + printf("\n "); + printf(" %08lX%s", + info->start[i], info->protect[i] ? " (RO)" : " "); +#endif + } + putc('\n'); + return; +} + +/*--------------------------------------------------------------------- -- + * Copy memory to flash, returns: + * 0 - OK + * 1 - write timeout + * 2 - Flash not erased + */ +int write_buff(flash_info_t * info, uchar * src, ulong addr, ulong cnt) +{ + ulong wp; + ulong cp; + int aln; + cfiword_t cword; + int i, rc; + +#ifdef CFG_FLASH_USE_BUFFER_WRITE + int buffered_size; +#endif + /* get lower aligned address */ + /* get lower aligned address */ + wp = (addr & ~(info->portwidth - 1)); + + /* handle unaligned start */ + if ((aln = addr - wp) != 0) { + cword.l = 0; + cp = wp; + for (i = 0; i < aln; ++i, ++cp) + flash_add_byte(info, &cword, (*(uchar *) cp)); + + for (; (i < info->portwidth) && (cnt > 0); i++) { + flash_add_byte(info, &cword, *src++); + cnt--; + cp++; + } + for (; (cnt == 0) && (i < info->portwidth); ++i, ++cp) + flash_add_byte(info, &cword, (*(uchar *) cp)); + if ((rc = flash_write_cfiword(info, wp, cword)) != 0) + return rc; + wp = cp; + } + + /* handle the aligned part */ +#ifdef CFG_FLASH_USE_BUFFER_WRITE + buffered_size = (info->portwidth / info->chipwidth); + buffered_size *= info->buffer_size; + while (cnt >= info->portwidth) { + i = buffered_size > cnt ? cnt : buffered_size; + if ((rc = flash_write_cfibuffer(info, wp, src, i)) != ERR_OK) + return rc; + wp += i; + src += i; + cnt -= i; + } +#else + while (cnt >= info->portwidth) { + cword.l = 0; + for (i = 0; i < info->portwidth; i++) { + flash_add_byte(info, &cword, *src++); + } + if ((rc = flash_write_cfiword(info, wp, cword)) != 0) + return rc; + wp += info->portwidth; + cnt -= info->portwidth; + } +#endif /* CFG_FLASH_USE_BUFFER_WRITE */ + if (cnt == 0) { + return (0); + } + + /* + * handle unaligned tail bytes + */ + cword.l = 0; + for (i = 0, cp = wp; (i < info->portwidth) && (cnt > 0); ++i, ++cp) { + flash_add_byte(info, &cword, *src++); + --cnt; + } + for (; i < info->portwidth; ++i, ++cp) { + flash_add_byte(info, &cword, (*(uchar *) cp)); + } + + return flash_write_cfiword(info, wp, cword); +} + +/*--------------------------------------------------------------------- -- + */ +#ifdef CFG_FLASH_PROTECTION + +int flash_real_protect(flash_info_t * info, long sector, int prot) +{ + int retcode = 0; + + flash_write_cmd(info, sector, 0, FLASH_CMD_CLEAR_STATUS); + flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT); + if (prot) + flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT_SET); + else + flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT_CLEAR); + + if ((retcode = + flash_full_status_check(info, sector, info->erase_blk_tout, + prot ? "protect" : "unprotect")) == 0) { + + info->protect[sector] = prot; + /* Intel's unprotect unprotects all locking */ + if (prot == 0) { + flash_sect_t i; + + for (i = 0; i < info->sector_count; i++) { + if (info->protect[i]) + flash_real_protect(info, i, 1); + } + } + } + return retcode; +} + +/*--------------------------------------------------------------------- -- + * flash_read_user_serial - read the OneTimeProgramming cells + */ +void flash_read_user_serial(flash_info_t * info, void *buffer, int offset, + int len) +{ + uchar *src; + uchar *dst; + + dst = buffer; + src = flash_make_addr(info, 0, FLASH_OFFSET_USER_PROTECTION); + flash_write_cmd(info, 0, 0, FLASH_CMD_READ_ID); + memcpy(dst, src + offset, len); + flash_write_cmd(info, 0, 0, FLASH_CMD_RESET); +} + +/* + * flash_read_factory_serial - read the device Id from the protection area + */ +void flash_read_factory_serial(flash_info_t * info, void *buffer, int offset, + int len) +{ + uchar *src; + + src = flash_make_addr(info, 0, FLASH_OFFSET_INTEL_PROTECTION); + flash_write_cmd(info, 0, 0, FLASH_CMD_READ_ID); + memcpy(buffer, src + offset, len); + flash_write_cmd(info, 0, 0, FLASH_CMD_RESET); +} + +#endif /* CFG_FLASH_PROTECTION */ + +/* + * flash_is_busy - check to see if the flash is busy + * This routine checks the status of the chip and returns true if the chip is busy + */ +static int flash_is_busy(flash_info_t * info, flash_sect_t sect) +{ + int retval; + + switch (info->vendor) { + case CFI_CMDSET_INTEL_STANDARD: + case CFI_CMDSET_INTEL_EXTENDED: + retval = !flash_isset(info, sect, 0, FLASH_STATUS_DONE); + break; + case CFI_CMDSET_AMD_STANDARD: + case CFI_CMDSET_AMD_EXTENDED: + retval = flash_toggle(info, sect, 0, AMD_STATUS_TOGGLE); + break; + default: + retval = 0; + } + debug("flash_is_busy: %d\n", retval); + return retval; +} + +/*--------------------------------------------------------------------- -- + * wait for XSR.7 to be set. Time out with an error if it does not. + * This routine does not set the flash to read-array mode. + */ +static int flash_status_check(flash_info_t * info, flash_sect_t sector, + ulong tout, char *prompt) +{ + ulong start; + + /* Wait for command completion */ + start = get_timer(0); + while (flash_is_busy(info, sector)) { + if (get_timer(start) > info->erase_blk_tout * CFG_HZ) { + printf("Flash %s timeout at address %lx data %lx\n", + prompt, info->start[sector], + flash_read_long(info, sector, 0)); + flash_write_cmd(info, sector, 0, info->cmd_reset); + return ERR_TIMOUT; + } + } + return ERR_OK; +} + +/*--------------------------------------------------------------------- -- + * Wait for XSR.7 to be set, if it times out print an error, otherwise do a full status check. + * This routine sets the flash to read-array mode. + */ +static int flash_full_status_check(flash_info_t * info, flash_sect_t sector, + ulong tout, char *prompt) +{ + int retcode; + + retcode = flash_status_check(info, sector, tout, prompt); + switch (info->vendor) { + case CFI_CMDSET_INTEL_EXTENDED: + case CFI_CMDSET_INTEL_STANDARD: + if ((retcode != ERR_OK) + && !flash_isequal(info, sector, 0, FLASH_STATUS_DONE)) { + retcode = ERR_INVAL; + printf("Flash %s error at address %lx\n", prompt, + info->start[sector]); + if (flash_isset + (info, sector, 0, + FLASH_STATUS_ECLBS | FLASH_STATUS_PSLBS)) { + puts("Command Sequence Error.\n"); + } else + if (flash_isset + (info, sector, 0, FLASH_STATUS_ECLBS)) { + puts("Block Erase Error.\n"); + retcode = ERR_NOT_ERASED; + } else + if (flash_isset + (info, sector, 0, FLASH_STATUS_PSLBS)) { + puts("Locking Error\n"); + } + if (flash_isset(info, sector, 0, FLASH_STATUS_DPS)) { + puts("Block locked.\n"); + retcode = ERR_PROTECTED; + } + if (flash_isset(info, sector, 0, FLASH_STATUS_VPENS)) + puts("Vpp Low Error.\n"); + } + flash_write_cmd(info, sector, 0, FLASH_CMD_RESET); + break; + default: + break; + } + return retcode; +} + +/*--------------------------------------------------------------------- -- + */ +static void flash_add_byte(flash_info_t * info, cfiword_t * cword, uchar c) +{ +#if defined(__LITTLE_ENDIAN) + unsigned short w; + unsigned int l; + unsigned long long ll; +#endif + + switch (info->portwidth) { + case FLASH_CFI_8BIT: + cword->c = c; + break; + case FLASH_CFI_16BIT: +#if defined(__LITTLE_ENDIAN) + w = c; + w <<= 8; + cword->w = (cword->w >> 8) | w; +#else + cword->w = (cword->w << 8) | c; +#endif + break; + case FLASH_CFI_32BIT: +#if defined(__LITTLE_ENDIAN) + l = c; + l <<= 24; + cword->l = (cword->l >> 8) | l; +#else + cword->l = (cword->l << 8) | c; +#endif + break; + case FLASH_CFI_64BIT: +#if defined(__LITTLE_ENDIAN) + ll = c; + ll <<= 56; + cword->ll = (cword->ll >> 8) | ll; +#else + cword->ll = (cword->ll << 8) | c; +#endif + break; + } +} + +/*--------------------------------------------------------------------- -- + * make a proper sized command based on the port and chip widths + */ +static void flash_make_cmd(flash_info_t * info, uchar cmd, void *cmdbuf) +{ + int i; + +#if defined(__LITTLE_ENDIAN) || defined(CONFIG_MPC7448HPC2) + ushort stmpw; + uint stmpi; + uint stmpi2; +#endif + uchar *cp = (uchar *) cmdbuf; + + for (i = 0; i < info->portwidth; i++) + *cp++ = ((i + 1) % info->chipwidth) ? '\0' : cmd; +#if defined(__LITTLE_ENDIAN) || defined(CONFIG_MPC7448HPC2) + switch (info->portwidth) { + case FLASH_CFI_8BIT: + break; + case FLASH_CFI_16BIT: + stmpw = *(ushort *) cmdbuf; + *(ushort *) cmdbuf = __swab16(stmpw); + break; + case FLASH_CFI_32BIT: + stmpi = *(uint *) cmdbuf; + *(uint *) cmdbuf = __swab32(stmpi); + break; + case FLASH_CFI_64BIT: + cp = (uchar *) cmdbuf; + stmpi = *(uint *) cp; + cp += 4; + stmpi2 = *(uint *) cp; + cp -= 4; + *(uint *) cp = __swab32(stmpi2); + cp += 4; + *(uint *) cp = __swab32(stmpi); + break; + default: + puts("WARNING: flash_make_cmd: unsuppported LittleEndian mode\n"); + break; + } +#endif +} + +/* + * Write a proper sized command to the correct address + */ +static void flash_write_cmd(flash_info_t * info, flash_sect_t sect, uint offset, + uchar cmd) +{ + + volatile cfiptr_t addr; + cfiword_t cword; + + addr.cp = flash_make_addr(info, sect, offset); + flash_make_cmd(info, cmd, &cword); + switch (info->portwidth) { + case FLASH_CFI_8BIT: + debug("fwc addr %p cmd %x %x 8bit x %d bit\n", addr.cp, cmd, + cword.c, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + *addr.cp = cword.c; + break; + case FLASH_CFI_16BIT: + debug("fwc addr %p cmd %x %4.4x 16bit x %d bit\n", addr.wp, + cmd, cword.w, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + *addr.wp = cword.w; + break; + case FLASH_CFI_32BIT: + debug("fwc addr %p cmd %x %8.8lx 32bit x %d bit\n", addr.lp, + cmd, cword.l, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + *addr.lp = cword.l; + break; + case FLASH_CFI_64BIT: +#ifdef DEBUG + { + char str[20]; + + print_longlong(str, cword.ll); + + debug("fwrite addr %p cmd %x %s 64 bit x %d bit\n", + addr.llp, cmd, str, + info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + } +#endif + *addr.llp = cword.ll; + break; + } +} + +static void flash_unlock_seq(flash_info_t * info, flash_sect_t sect) +{ + flash_write_cmd(info, sect, AMD_ADDR_START, AMD_CMD_UNLOCK_START); + flash_write_cmd(info, sect, AMD_ADDR_ACK, AMD_CMD_UNLOCK_ACK); +} + +/*--------------------------------------------------------------------- -- + */ +static int flash_isequal(flash_info_t * info, flash_sect_t sect, uint offset, + uchar cmd) +{ + cfiptr_t cptr; + cfiword_t cword; + int retval; + + cptr.cp = flash_make_addr(info, sect, offset); + flash_make_cmd(info, cmd, &cword); + + debug("is= cmd %x(%c) addr %p ", cmd, cmd, cptr.cp); + switch (info->portwidth) { + case FLASH_CFI_8BIT: + debug("is= %x %x\n", cptr.cp[0], cword.c); + retval = (cptr.cp[0] == cword.c); + break; + case FLASH_CFI_16BIT: + debug("is= %4.4x %4.4x\n", cptr.wp[0], cword.w); + retval = (cptr.wp[0] == cword.w); + break; + case FLASH_CFI_32BIT: + debug("is= %8.8lx %8.8lx\n", cptr.lp[0], cword.l); + retval = (cptr.lp[0] == cword.l); + break; + case FLASH_CFI_64BIT: +#ifdef DEBUG + { + char str1[20]; + char str2[20]; + + print_longlong(str1, cptr.llp[0]); + print_longlong(str2, cword.ll); + debug("is= %s %s\n", str1, str2); + } +#endif + retval = (cptr.llp[0] == cword.ll); + break; + default: + retval = 0; + break; + } + return retval; +} + +/*--------------------------------------------------------------------- -- + */ +static int flash_isset(flash_info_t * info, flash_sect_t sect, uint offset, + uchar cmd) +{ + cfiptr_t cptr; + cfiword_t cword; + int retval; + + cptr.cp = flash_make_addr(info, sect, offset); + flash_make_cmd(info, cmd, &cword); + switch (info->portwidth) { + case FLASH_CFI_8BIT: + retval = ((cptr.cp[0] & cword.c) == cword.c); + break; + case FLASH_CFI_16BIT: + retval = ((cptr.wp[0] & cword.w) == cword.w); + break; + case FLASH_CFI_32BIT: + retval = ((cptr.lp[0] & cword.l) == cword.l); + break; + case FLASH_CFI_64BIT: + retval = ((cptr.llp[0] & cword.ll) == cword.ll); + break; + default: + retval = 0; + break; + } + return retval; +} + +/*--------------------------------------------------------------------- -- + */ +static int flash_toggle(flash_info_t * info, flash_sect_t sect, uint offset, + uchar cmd) +{ + cfiptr_t cptr; + cfiword_t cword; + int retval; + + cptr.cp = flash_make_addr(info, sect, offset); + flash_make_cmd(info, cmd, &cword); + switch (info->portwidth) { + case FLASH_CFI_8BIT: + retval = ((cptr.cp[0] & cword.c) != (cptr.cp[0] & cword.c)); + break; + case FLASH_CFI_16BIT: + retval = ((cptr.wp[0] & cword.w) != (cptr.wp[0] & cword.w)); + break; + case FLASH_CFI_32BIT: + retval = ((cptr.lp[0] & cword.l) != (cptr.lp[0] & cword.l)); + break; + case FLASH_CFI_64BIT: + retval = ((cptr.llp[0] & cword.ll) != (cptr.llp[0] & cword.ll)); + break; + default: + retval = 0; + break; + } + return retval; +} + +/*--------------------------------------------------------------------- -- + * detect if flash is compatible with the Common Flash Interface (CFI) + * http://www.jedec.org/download/search/jesd68.pdf + * +*/ +static int flash_detect_cfi(flash_info_t * info) +{ + debug("flash detect cfi\n"); + + for (info->portwidth = FLASH_CFI_8BIT; + info->portwidth <= FLASH_CFI_64BIT; info->portwidth <<= 1) { + for (info->chipwidth = FLASH_CFI_BY8; + info->chipwidth <= info->portwidth; + info->chipwidth <<= 1) { + flash_write_cmd(info, 0, 0, FLASH_CMD_RESET); + flash_write_cmd(info, 0, FLASH_OFFSET_CFI, + FLASH_CMD_CFI); + if (flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP, 'Q') + && flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 1, + 'R') + && flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 2, + 'Y')) { + info->interface = + flash_read_ushort(info, 0, + FLASH_OFFSET_INTERFACE); + debug("device interface is %d\n", + info->interface); + debug("found port %d chip %d ", info->portwidth, + info->chipwidth); + debug("port %d bits chip %d bits\n", + info->portwidth << CFI_FLASH_SHIFT_WIDTH, + info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + return 1; + } + } + } + debug("not found\n"); + return 0; +} + +/* + * The following code cannot be run from FLASH! + * + */ +static ulong flash_get_size(ulong base, int banknum) +{ + flash_info_t *info = &flash_info[banknum]; + int i, j; + flash_sect_t sect_cnt; + unsigned long sector; + unsigned long tmp; + int size_ratio; + uchar num_erase_regions; + int erase_region_size; + int erase_region_count; + + info->start[0] = base; + + if (flash_detect_cfi(info)) { + info->vendor = + flash_read_ushort(info, 0, FLASH_OFFSET_PRIMARY_VENDOR); +#ifdef DEBUG + flash_printqry(info, 0); +#endif + switch (info->vendor) { + case CFI_CMDSET_INTEL_STANDARD: + case CFI_CMDSET_INTEL_EXTENDED: + default: + info->cmd_reset = FLASH_CMD_RESET; + break; + case CFI_CMDSET_AMD_STANDARD: + case CFI_CMDSET_AMD_EXTENDED: + info->cmd_reset = AMD_CMD_RESET; + break; + } + + debug("manufacturer is %d\n", info->vendor); + size_ratio = info->portwidth / info->chipwidth; + /* if the chip is x8/x16 reduce the ratio by half */ + if ((info->interface == FLASH_CFI_X8X16) + && (info->chipwidth == FLASH_CFI_BY8)) { + size_ratio >>= 1; + } + num_erase_regions = + flash_read_uchar(info, FLASH_OFFSET_NUM_ERASE_REGIONS); + debug("size_ratio %d port %d bits chip %d bits\n", size_ratio, + info->portwidth << CFI_FLASH_SHIFT_WIDTH, + info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + debug("found %d erase regions\n", num_erase_regions); + sect_cnt = 0; + sector = base; + for (i = 0; i < num_erase_regions; i++) { + if (i > NUM_ERASE_REGIONS) { + printf("%d erase regions found, only %d used\n", + num_erase_regions, NUM_ERASE_REGIONS); + break; + } + tmp = flash_read_long(info, 0, + FLASH_OFFSET_ERASE_REGIONS + + i * 4); + erase_region_size = + (tmp & 0xffff) ? ((tmp & 0xffff) * 256) : 128; + tmp >>= 16; + erase_region_count = (tmp & 0xffff) + 1; + debug + ("erase_region_count = %d erase_region_size = %d\n", + erase_region_count, erase_region_size); + for (j = 0; j < erase_region_count; j++) { + info->start[sect_cnt] = sector; + sector += (erase_region_size * size_ratio); + info->protect[sect_cnt] = + flash_isset(info, sect_cnt, + FLASH_OFFSET_PROTECT, + FLASH_STATUS_PROTECT); + sect_cnt++; + } + } + + info->sector_count = sect_cnt; + /* multiply the size by the number of chips */ + info->size = + (1 << flash_read_uchar(info, FLASH_OFFSET_SIZE)) * + size_ratio; + info->buffer_size = + (1 << flash_read_ushort(info, 0, FLASH_OFFSET_BUFFER_SIZE)); + tmp = 1 << flash_read_uchar(info, FLASH_OFFSET_ETOUT); + info->erase_blk_tout = + (tmp * + (1 << flash_read_uchar(info, FLASH_OFFSET_EMAX_TOUT))); + tmp = 1 << flash_read_uchar(info, FLASH_OFFSET_WBTOUT); + info->buffer_write_tout = + (tmp * + (1 << flash_read_uchar(info, FLASH_OFFSET_WBMAX_TOUT))); + tmp = 1 << flash_read_uchar(info, FLASH_OFFSET_WTOUT); + info->write_tout = + (tmp * + (1 << flash_read_uchar(info, FLASH_OFFSET_WMAX_TOUT))) / + 1000; + info->flash_id = FLASH_MAN_CFI; + if ((info->interface == FLASH_CFI_X8X16) + && (info->chipwidth == FLASH_CFI_BY8)) { + info->portwidth >>= 1; /* XXX - Need to test on x8/x16 in parallel. */ + } + flash_write_cmd(info, 0, 0, FLASH_CMD_RESET); + } + + return (info->size); +} + +/*--------------------------------------------------------------------- -- + */ +static int flash_write_cfiword(flash_info_t * info, ulong dest, cfiword_t cword) +{ + + cfiptr_t ctladdr; + cfiptr_t cptr; + int flag; + + ctladdr.cp = flash_make_addr(info, 0, 0); + cptr.cp = (uchar *) dest; + + /* Check if Flash is (sufficiently) erased */ + switch (info->portwidth) { + case FLASH_CFI_8BIT: + flag = ((cptr.cp[0] & cword.c) == cword.c); + break; + case FLASH_CFI_16BIT: + flag = ((cptr.wp[0] & cword.w) == cword.w); + break; + case FLASH_CFI_32BIT: + flag = ((cptr.lp[0] & cword.l) == cword.l); + break; + case FLASH_CFI_64BIT: + flag = ((cptr.lp[0] & cword.ll) == cword.ll); + break; + default: + return 2; + } + if (!flag) + return 2; + + /* Disable interrupts which might cause a timeout here */ + flag = disable_interrupts(); + + switch (info->vendor) { + case CFI_CMDSET_INTEL_EXTENDED: + case CFI_CMDSET_INTEL_STANDARD: + flash_write_cmd(info, 0, 0, FLASH_CMD_CLEAR_STATUS); + flash_write_cmd(info, 0, 0, FLASH_CMD_WRITE); + break; + case CFI_CMDSET_AMD_EXTENDED: + case CFI_CMDSET_AMD_STANDARD: + flash_unlock_seq(info, 0); + flash_write_cmd(info, 0, AMD_ADDR_START, AMD_CMD_WRITE); + break; + } + + switch (info->portwidth) { + case FLASH_CFI_8BIT: + cptr.cp[0] = cword.c; + break; + case FLASH_CFI_16BIT: + cptr.wp[0] = cword.w; + break; + case FLASH_CFI_32BIT: + cptr.lp[0] = cword.l; + break; + case FLASH_CFI_64BIT: + cptr.llp[0] = cword.ll; + break; + } + + /* re-enable interrupts if necessary */ + if (flag) + enable_interrupts(); + + return flash_full_status_check(info, 0, info->write_tout, "write"); +} + +#ifdef CFG_FLASH_USE_BUFFER_WRITE + +/* loop through the sectors from the highest address + * when the passed address is greater or equal to the sector address + * we have a match + */ +static flash_sect_t find_sector(flash_info_t * info, ulong addr) +{ + flash_sect_t sector; + + for (sector = info->sector_count - 1; sector >= 0; sector--) { + if (addr >= info->start[sector]) + break; + } + return sector; +} + +static int flash_write_cfibuffer(flash_info_t * info, ulong dest, uchar * cp, + int len) +{ + flash_sect_t sector; + int cnt; + int retcode; + volatile cfiptr_t src; + volatile cfiptr_t dst; + /* buffered writes in the AMD chip set is not supported yet */ + if ((info->vendor == CFI_CMDSET_AMD_STANDARD) || + (info->vendor == CFI_CMDSET_AMD_EXTENDED)) + return ERR_INVAL; + + src.cp = cp; + dst.cp = (uchar *) dest; + sector = find_sector(info, dest); + flash_write_cmd(info, sector, 0, FLASH_CMD_CLEAR_STATUS); + flash_write_cmd(info, sector, 0, FLASH_CMD_WRITE_TO_BUFFER); + if ((retcode = + flash_status_check(info, sector, info->buffer_write_tout, + "write to buffer")) == ERR_OK) { + /* reduce the number of loops by the width of the port */ + switch (info->portwidth) { + case FLASH_CFI_8BIT: + cnt = len; + break; + case FLASH_CFI_16BIT: + cnt = len >> 1; + break; + case FLASH_CFI_32BIT: + cnt = len >> 2; + break; + case FLASH_CFI_64BIT: + cnt = len >> 3; + break; + default: + return ERR_INVAL; + break; + } + flash_write_cmd(info, sector, 0, (uchar) cnt - 1); + while (cnt-- > 0) { + switch (info->portwidth) { + case FLASH_CFI_8BIT: + *dst.cp++ = *src.cp++; + break; + case FLASH_CFI_16BIT: + *dst.wp++ = *src.wp++; + break; + case FLASH_CFI_32BIT: + *dst.lp++ = *src.lp++; + break; + case FLASH_CFI_64BIT: + *dst.llp++ = *src.llp++; + break; + default: + return ERR_INVAL; + break; + } + } + flash_write_cmd(info, sector, 0, + FLASH_CMD_WRITE_BUFFER_CONFIRM); + retcode = + flash_full_status_check(info, sector, + info->buffer_write_tout, + "buffer write"); + } + flash_write_cmd(info, sector, 0, FLASH_CMD_CLEAR_STATUS); + return retcode; +} +#endif /* CFG_USE_FLASH_BUFFER_WRITE */ +#endif /* CFG_FLASH_CFI */
Any reason why to use another CFI Flash driver but not the one in the box?
Thanks,
Sam
__________________________________________________ 赶快注册雅虎超大容量免费邮箱? http://cn.mail.yahoo.com
The reason is due to some byte swap issue. I will move it into the general flash driver in the further. Thanks. Roy
In message 7EA18FDD2DC2154AA3BD6D2F22A62A0E0D2CC7@zch01exm23.fsl.freescale.net you wrote:
No. Please clean up first, and then submit.
I will not accept such code duplication.
There are some differences. Another reason I keep the driver in my board directory is that I do not want to affect other board behavior. At lease, I am not sure.
Is it right that I add some "ifdef BOARD_BYPE" in the general driver code? What's your comment?
Should I move the tsi108 feature to the general directory or just keep it in my board directory? Thanks. Roy
In message 7EA18FDD2DC2154AA3BD6D2F22A62A0E0D2CDE@zch01exm23.fsl.freescale.net you wrote:
Differences are small compared to the toal size of the file. Duplication is always bad, as it will cause a maintenance nightmare. It may slip though occasionally, but when I get aware of it I will not accept such duplicated code.
Submit a patch on the list for testing?
There must be no board dependent code in the CFI driver. If you want to add support for a special feature, use some CFG_HAVE_FEATURE_FOO or the like, but only when *really* necessary.
Normally, the need for such a feature in the CFI driver is an indication of some design error on your side.
Please move to the drivers directory.
I will erase the duplication. I never intend to slip though.
lease, I am
not sure.
No, They are not for testing. I have tested them thousands of times :). My original intend is to keep the code in my board directory..
general driver
code?
The difference is caused by ENDIAN issue. Anyway, I will consider it carefully.
or just keep
OK, I will collect the feedback and refine my code. Thanks. Roy
In message 7EA18FDD2DC2154AA3BD6D2F22A62A0E0D2DCB@zch01exm23.fsl.freescale.net you wrote:
lease, I am
not sure.
You wrote: "not want to affect other board behavior". Sounds as if your code needs testing on these other boards ?
Oops? Can you program your flash for exanmple with a BDI200?
lease, I am
not sure.
of times :).
No, I suppose it should not. While, before submit, I tested the code on other boards in my hand: mpc8540ads, mpc8560ads, mpc8555cds. They worked.
consider it
carefully.
Hardware issue. I can program it with BDI2000, PowerTAP and UsbTAP under CodeWarrior. Any suggestion? Thanks. Roy
In message 7EA18FDD2DC2154AA3BD6D2F22A62A0E0D2E89@zch01exm23.fsl.freescale.net you wrote:
consider it
carefully.
Please explain. When the BDI can program the flash, the CFI driver should be able to do the same. What exactly is the problem?
consider it
carefully.
mpc7448 processor is BIG ENDIAN, while the tsi108 bridge connects the flash chip by little ENDIA mode. When I set __LITTLE_ENDIA in the cfi_flash driver, everything seems OK, but the written bytes are swapped (see the following log). Now, It seems that if I define CFG_FLASH_USE_BUFFER_WRITE in my config file, this issue can be solved. I will do more test on my board. While, how can I set __LITTLE_ENDIA mode for cfi_driver file in a BIG ENDIA system? Thanks.
//////////////////////////////////////////////////////////////////////// ////////////////////////////////////////////// Please see the following log with general cfi_driver. The log shows my problem . //////////////////////////////////////////////////////////////////////// ////////////////////////////////////////////// U-Boot 1.1.4-ge4f3fb8b-dirty (Aug 2 2006 - 10:01:47) Freescale MPC7448 HPC II
CPU: MPC7448 v2.0 @ 1336 MHz BOARD: MPC7448 HPC II DRAM: 512 MB FLASH: ## Unknown FLASH on Bank 1 - Size = 0x00000000 = 0 MB 16 MB In: serial Out: serial Err: serial BUS: 167 MHz MEM: 200 MHz CACHE: L1 Instruction cache - 32KB 8-way ENABLED L1 Data cache - 32KB 8-way ENABLED Unified L2 cache - 1MB 8-way DISABLED Net: TSI108_eth0, TSI108_eth1 Hit any key to stop autoboot: 0 => fli
Bank # 1: CFI conformant FLASH (32 x 16) Size: 16 MB in 128 Sectors Erase timeout 16384 ms, write timeout 1 ms, buffer write timeout 5 ms, buffer s ize 32 Sector Start Addresses: FF000000 FF020000 FF040000 FF060000 FF080000 FF0A0000 FF0C0000 FF0E0000 FF100000 FF120000 FF140000 FF160000 FF180000 FF1A0000 FF1C0000 FF1E0000 FF200000 FF220000 FF240000 FF260000 FF280000 FF2A0000 FF2C0000 FF2E0000 FF300000 FF320000 FF340000 FF360000 FF380000 FF3A0000 FF3C0000 FF3E0000 FF400000 FF420000 FF440000 FF460000 FF480000 FF4A0000 FF4C0000 FF4E0000 FF500000 FF520000 FF540000 FF560000 FF580000 FF5A0000 FF5C0000 FF5E0000 FF600000 FF620000 FF640000 FF660000 FF680000 FF6A0000 FF6C0000 FF6E0000 FF700000 FF720000 FF740000 FF760000 FF780000 FF7A0000 FF7C0000 FF7E0000 FF800000 FF820000 FF840000 FF860000 FF880000 FF8A0000 FF8C0000 FF8E0000 FF900000 FF920000 FF940000 FF960000 FF980000 FF9A0000 FF9C0000 FF9E0000 FFA00000 FFA20000 FFA40000 FFA60000 FFA80000 FFAA0000 FFAC0000 FFAE0000 FFB00000 FFB20000 FFB40000 FFB60000 FFB80000 FFBA0000 FFBC0000 FFBE0000 FFC00000 FFC20000 FFC40000 FFC60000 FFC80000 FFCA0000 FFCC0000 FFCE0000 FFD00000 FFD20000 FFD40000 FFD60000 FFD80000 FFDA0000 FFDC0000 FFDE0000 FFE00000 FFE20000 FFE40000 FFE60000 FFE80000 FFEA0000 FFEC0000 FFEE0000 FFF00000 FFF20000 FFF40000 FFF60000 FFF80000 FFFA0000 FFFC0000 FFFE0000
Bank # 2: missing or unknown FLASH type => md ff000000 ff000000: 27051956 552d426f 6f742031 2e312e34 '..VU-Boot 1.1.4 ff000010: 2d673230 38653063 38312d64 69727479 -g208e0c81-dirty ff000020: 20284a75 6c203131 20323030 36202d20 (Jul 11 2006 - ff000030: 31313a34 343a3333 29204672 65657363 11:44:33) Freesc ff000040: 616c6520 4d504337 34343820 48504320 ale MPC7448 HPC ff000050: 49490000 00000000 00000000 00000000 II.............. ff000060: 00000000 00000000 00000000 00000000 ................ ff000070: 00000000 00000000 00000000 00000000 ................ ff000080: 00000000 00000000 00000000 00000000 ................ ff000090: 00000000 00000000 00000000 00000000 ................ ff0000a0: 00000000 00000000 00000000 00000000 ................ ff0000b0: 00000000 00000000 00000000 00000000 ................ ff0000c0: 00000000 00000000 00000000 00000000 ................ ff0000d0: 00000000 00000000 00000000 00000000 ................ ff0000e0: 00000000 00000000 00000000 00000000 ................ ff0000f0: 00000000 00000000 00000000 00000000 ................ => erase fff80000 fff9ffff
. done Erased 1 sectors => cp.b ff000000 fff80000 20000 Copy to Flash... done => md fff80000 fff80000: 56190527 6f422d55 3120746f 342e312e V..'oB-U1 to4.1. fff80010: 3032672d 63306538 642d3138 79747269 02g-c0e8d-18ytri fff80020: 754a2820 3131206c 30303220 202d2036 uJ( 11 l002 - 6 fff80030: 343a3131 33333a34 72462029 63736565 4:1133:4rF )csee fff80040: 20656c61 3743504d 20383434 20435048 ela7CPM 844 CPH fff80050: 00004949 00000000 00000000 00000000 ..II............ fff80060: 00000000 00000000 00000000 00000000 ................ fff80070: 00000000 00000000 00000000 00000000 ................ fff80080: 00000000 00000000 00000000 00000000 ................ fff80090: 00000000 00000000 00000000 00000000 ................ fff800a0: 00000000 00000000 00000000 00000000 ................ fff800b0: 00000000 00000000 00000000 00000000 ................ fff800c0: 00000000 00000000 00000000 00000000 ................ fff800d0: 00000000 00000000 00000000 00000000 ................ fff800e0: 00000000 00000000 00000000 00000000 ................ fff800f0: 00000000 00000000 00000000 00000000 ................ =>
In message 7EA18FDD2DC2154AA3BD6D2F22A62A0E0D2F42@zch01exm23.fsl.freescale.net you wrote:
Please check your keyboard; the 'N' key seems to fail quite often.
=> fli
Bank # 1: CFI conformant FLASH (32 x 16) Size: 16 MB in 128 Sectors Erase timeout 16384 ms, write timeout 1 ms, buffer write timeout 5 ms, buffer size 32
Stop. What's this. First we see a report of "Unknown FLASH on Bank 1", and that the size has been set to 0, and here we get different information?
And what's this about Bank # 2???
This seems to be a bug. Please fix this first.
So you are copying some area within the *same* memory device (your flash memory)...
You read from memory, write to the same memory device, and read the written data back from the same memory device, and find the data to be swapped?
That would mean that reading and writing memory use different byte order. If this is true, then you're screwed.
=> fli
This is a bug in u-boot I already reported in May. Maybe it has been ignored because of the missing changelog and signed-off-by?
Regards, Andreas Engel
In message
<7EA18FDD2DC2154AA3BD6D2F22A62A0E0D2F42@zch01exm23.fsl.freesca le.net> you wrote:
=> fli
128 Sectors
on Bank
different
information?
FF080000
It should be fixed in u-boot. Roy
connects the
flash chip by little ENDIAN mode. When I set __LITTLE_ENDIAN in the
in my config
file, this issue can be solved. I will do more test on my board. While, how can I set __LITTLE_ENDIAN mode for cfi_driver
file in a BIG
ENDIAN system?
Sorry, I have changed my keyboard:).
=> fli
128 Sectors
timeout 5 ms,
buffer size 32
That first "Bank1 " is not this "Bank #1". this "BANK #1" should refer the Bank index 0. It might be a bug in u-boot. Please compare the following code in u-boot.
in file cfi_flash.c : unsigned long flash_init (void) { ... /* Init: no FLASHes known */ for (i = 0; i < CFG_MAX_FLASH_BANKS; ++i) { flash_info[i].flash_id = FLASH_UNKNOWN; size += flash_info[i].size = flash_get_size (bank_base[i], i); if (flash_info[i].flash_id == FLASH_UNKNOWN) { #ifndef CFG_FLASH_QUIET_TEST printf ("## Unknown FLASH on Bank %d - Size = 0x%08lx = %ld MB\n", i, flash_info[i].size, flash_info[i].size << 20); #endif /* CFG_FLASH_QUIET_TEST */ ... The index start from 0.
in file cmd_flash.c int do_flinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { ... if (argc == 1) { /* print info for all FLASH banks */ for (bank=0; bank <CFG_MAX_FLASH_BANKS; ++bank) { printf ("\nBank # %ld: ", bank+1);
flash_print_info (&flash_info[bank]); } return 0; } ... the print information start from bank+1.
Should they be unified?
It is not a bug. This "Bank #2 " refer to the previous "## Unknown FLASH on Bank 1". This device is a flash emulator (PromJet) on my board. If you are unhappy with this information, I can remove it by setting my CFG_MAX_FLASH_BANKS to 1.
Sure!
Sorry. I do not touch alcohol these days :). it is the same phenomena copying data from DDR ram to flash. The only modification I do is introducing a define __LITTLE_ENDIAN in file cfi_flash.c. Just as I said, If I define CFG_FLASH_USE_BUFFER_WRITE , it will be OK. I will explore this. Any comment?
Roy
=> fli
128 Sectors
timeout 5 ms,
buffer size 32
How about this?
FF080000
Sure!
The issue should locate at function write_buff() for my board. if define __LITTLE_ENDIAN, the function flash_add_byte() will swap the bytes. define CFG_FLASH_USE_BUFFER_WRITE can not solve all the problems. For handling unaligned head and tail bytes, the byte swap issue also exists. For example => cp.b 400002 fff80002 12 (from ram to flash). To solve the issue of general cfi_flash driver for my board. I introduce a flag CFG_FLASH_TSI_SWAP (tsi108/108 swap issue) and add the following patch. Is there any comment? Thanks. Roy
diff --git a/drivers/cfi_flash.c b/drivers/cfi_flash.c index fd0a186..0d92a99 100644 --- a/drivers/cfi_flash.c +++ b/drivers/cfi_flash.c @@ -268,7 +268,7 @@ inline uchar flash_read_uchar (flash_inf uchar *cp;
cp = flash_make_addr (info, 0, offset); -#if defined(__LITTLE_ENDIAN) +#if defined(__LITTLE_ENDIAN) || defined(CFG_FLASH_TSI_SWAP) return (cp[0]); #else return (cp[info->portwidth - 1]); @@ -295,7 +295,7 @@ #ifdef DEBUG debug ("addr[%x] = 0x%x\n", x, addr[x]); } #endif -#if defined(__LITTLE_ENDIAN) +#if defined(__LITTLE_ENDIAN) || defined(CFG_FLASH_TSI_SWAP) retval = ((addr[(info->portwidth)] << 8) | addr[0]); #else retval = ((addr[(2 * info->portwidth) - 1] << 8) | @@ -327,7 +327,7 @@ #ifdef DEBUG debug ("addr[%x] = 0x%x\n", x, addr[x]); } #endif -#if defined(__LITTLE_ENDIAN) +#if defined(__LITTLE_ENDIAN) || defined(CFG_FLASH_TSI_SWAP) retval = (addr[0] << 16) | (addr[(info->portwidth)] << 24) | (addr[(2 * info->portwidth)]) | (addr[(3 * info->portwidth)] << 8); #else @@ -596,7 +596,6 @@ #ifdef CFG_FLASH_USE_BUFFER_WRITE int buffered_size; #endif /* get lower aligned address */ - /* get lower aligned address */ wp = (addr & ~(info->portwidth - 1));
/* handle unaligned start */ @@ -892,7 +891,7 @@ static void flash_make_cmd (flash_info_t int i; uchar *cp = (uchar *) cmdbuf;
-#if defined(__LITTLE_ENDIAN) +#if defined(__LITTLE_ENDIAN) || defined(CFG_FLASH_TSI_SWAP) for (i = info->portwidth; i > 0; i--) #else for (i = 1; i <= info->portwidth; i++)
In message 7EA18FDD2DC2154AA3BD6D2F22A62A0E0D319B@zch01exm23.fsl.freescale.net you wrote:
How about this?
I will check in Andreas Engel's patch ASAP - as time permits.
As mentioned before, I will not accept board specific code in this file. Please chose a generic name for the #define which desribes the problem, not your board.
In message <7EA18FDD2DC2154AA3BD6D2F22A62A0E0D319B@zch01exm23.fsl.freesca le.net> you wrote:
How about this?
I always remember your word:). CFG_FLASH_TSI_SWAP is not my board specific code. My board name is MPC7448HPC2:). This flag deals with such type of systems: (1) 74xx + tsi108/9 (2) The flash data line is connected with tsi108 data line by little Endian mode. I will consider a more reasonable name. Thanks. Roy
In message 7EA18FDD2DC2154AA3BD6D2F22A62A0E0D31AE@zch01exm23.fsl.freescale.net you wrote:
Excellent to know. So I finally know whom to ask when I can't remember :-)
That is OK!
In file cfi_flash.c, why there are two same comments? int buffered_size; #endif /* get lower aligned address */ - /* get lower aligned address */ wp = (addr & ~(info->portwidth - 1));
it seems strange. Roy
Andreas Engel
Sam Song
Zang Roy-r61911
