[U-Boot] [PATCH v2] fsl_esdhc: Only modify the field we are changing in WML
When we set the read or write watermark in WML we should maintain the rest of the register as is, rather than using some hard coded value.
Signed-off-by: Roy Zang tie-fei.zang@freescale.com Acked-by: Stefano Babic sbabic@denx.de Signed-off-by: Kumar Gala galak@kernel.crashing.org --- * Fixed line length
drivers/mmc/fsl_esdhc.c | 9 ++++----- include/fsl_esdhc.h | 2 ++ 2 files changed, 6 insertions(+), 5 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 999b581..0f6f8b1 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -110,8 +110,7 @@ static int esdhc_setup_data(struct mmc *mmc, struct mmc_data *data) if (wml_value > 0x10) wml_value = 0x10;
- wml_value = 0x100000 | wml_value; - + esdhc_clrsetbits32(®s->wml, WML_RD_WML_MASK, wml_value); esdhc_write32(®s->dsaddr, (u32)data->dest); } else { if (wml_value > 0x80) @@ -120,12 +119,12 @@ static int esdhc_setup_data(struct mmc *mmc, struct mmc_data *data) printf("\nThe SD card is locked. Can not write to a locked card.\n\n"); return TIMEOUT; } - wml_value = wml_value << 16 | 0x10; + + esdhc_clrsetbits32(®s->wml, WML_WR_WML_MASK, + wml_value << 16); esdhc_write32(®s->dsaddr, (u32)data->src); }
- esdhc_write32(®s->wml, wml_value); - esdhc_write32(®s->blkattr, data->blocks << 16 | data->blocksize);
/* Calculate the timeout period for data transactions */ diff --git a/include/fsl_esdhc.h b/include/fsl_esdhc.h index 5f02018..f9ae15a 100644 --- a/include/fsl_esdhc.h +++ b/include/fsl_esdhc.h @@ -133,6 +133,8 @@
#define WML 0x2e044 #define WML_WRITE 0x00010000 +#define WML_RD_WML_MASK 0xff +#define WML_WR_WML_MASK 0xff0000
#define BLKATTR 0x2e004 #define BLKATTR_CNT(x) ((x & 0xffff) << 16)
-----Original Message----- From: Kumar Gala [mailto:galak@kernel.crashing.org] Sent: Monday, March 22, 2010 2:12 AM To: u-boot@lists.denx.de Cc: Zang Roy-R61911 Subject: [PATCH v2] fsl_esdhc: Only modify the field we are changing in WML
- Fixed line length
Thanks. I have posted this about one month ago: http://lists.denx.de/pipermail/u-boot/2010-February/068020.html Roy
Kumar Gala
Zang Roy-R61911
