[PATCH 1/2] fdtgrep: fix typos in error output
Fix function name and parenthesis.
Signed-off-by: Anatolij Gustschin agust@denx.de --- tools/fdtgrep.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/fdtgrep.c b/tools/fdtgrep.c index 8f44f599c1..052d419692 100644 --- a/tools/fdtgrep.c +++ b/tools/fdtgrep.c @@ -824,7 +824,7 @@ static int do_fdtgrep(struct display_info *disp, const char *filename) if (count <= max_regions) break; free(region); - fprintf(stderr, "Internal error with fdtgrep_find_region)(\n"); + fprintf(stderr, "Internal error with fdtgrep_find_regions()\n"); return -1; }
With some device trees (i.e. i.MX6 SoC) and longer REMOVE_PROPS list the fdtgrep tool stops with "Internal error with fdtgrep_find_regions()". Increase 'max_regions' count to avoid such errors.
diff --git a/tools/fdtgrep.c b/tools/fdtgrep.c index 052d419692..8f71b1cd7f 100644 --- a/tools/fdtgrep.c +++ b/tools/fdtgrep.c @@ -778,7 +778,7 @@ static int do_fdtgrep(struct display_info *disp, const char *filename) { struct fdt_region *region = NULL; int max_regions; - int count = 100; + int count = 110; char path[1024]; char *blob; int i, ret;
Wow that's a lot. I wonder if we should adjust it to be unlimited?
From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Simon Glass Sent: jeudi 9 janvier 2020 21:04
I see the same issue for device-tree when number of pincontrol node > 100 in SPL (only see for debug use case).
But normally it is managed in the function (2 loops and re-alloc for the second loop if size > 100).
But the loop is not correctly managed, I think it is a issue introduced by Commit e178db1d7736a92951fdc7f1fd9b8ecf4d2877ba fdtgrep: Fix logic of free() in do_fdtgrep()
=> retrun -1 added for the 1rst loop.
I have locally a patch, but I don't yet upstream it.... It is done today with: "tools: ftdgrep: correct the find regions loop in do_fdtgrep" http://patchwork.ozlabs.org/project/uboot/list/?series=152371
Anatolij can you confirm that my patch correct also your issue ?
Regards
Patrick
Hi Patrick,
On Fri, 10 Jan 2020 07:58:41 +0000 Patrick DELAUNAY patrick.delaunay@st.com wrote: ...
Yes, your patch helps. Thanks!
-- Anatolij
Anatolij Gustschin
Patrick DELAUNAY
