[U-Boot] [PATCH v4] disk: convert to Kconfig
This converts the following to Kconfig: CONFIG_PARTITIONS CONFIG_MAC_PARTITION CONFIG_DOS_PARTITION CONFIG_ISO_PARTITION CONFIG_AMIGA_PARTITION CONFIG_EFI_PARTITION CONFIG_PARTITION_UUIDS CONFIG_PARTITION_TYPE_GUID
Specific SPL config are added to reduce SPL size for some target and solve compilation issues
CONFIG_SPL_MAC_PARTITION CONFIG_SPL_DOS_PARTITION CONFIG_SPL_ISO_PARTITION CONFIG_SPL_AMIGA_PARTITION CONFIG_SPL_EFI_PARTITION
Associated test are updated to the correct CONFIG (SPL or not) by using macro CONFIG_IS_ENABLED
To update the U-Boot code I use : 0- Resync with savedefconfig /tools/moveconfig.py -s -Cy
1- update defconfig for new SPL option ./tools/moveconfig.py --spl --commit \ PARTITIONS MAC_PARTITION DOS_PARTITION \ ISO_PARTITION AMIGA_PARTITION EFI_PARTITION \ PARTITION_UUIDS PARTITION_TYPE_GUID
then replace CONFIG by CONFIG_SPL in defconfig sed -i "s/CONFIG_(DOS|EFI|ISO|MAC|AMIGA)_PARTITION/CONFIG_SPL_\1_PARTITION/" \ configs/*
2- update defconfig for existing option ./tools/moveconfig.py --commit --yes \ PARTITIONS MAC_PARTITION DOS_PARTITION \ ISO_PARTITION AMIGA_PARTITION EFI_PARTITION \ PARTITION_UUIDS PARTITION_TYPE_GUID
=> squash the 2 modifications
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Patrick Delaunay patrick.delaunay73@gmail.com --- move disk to Kconfig as proposed by Simon Glass in thread [Resend RFC PATCH v1 1/3] add support of GPT partitioning over MTD
NB: I create _SPL_ config because I have issue with size of SPL for some platform
=> list of supported partition type is not the same between SPL and U-Boot, that allow size reduction for SPL build (CONFIG are under compilation flag CONFIG_SPL_BUILD in .h)
I compile this patch on v2016.11 without issue linked to this code on all platform and this commit is rebased on master
Changes in v4: - rebase on v2017.01 - correct many issue in defconfig update (missing some "is not set") - check with buildman that the patch is size neutral
Changes in v3: change Kconfig to reduce impact in platform defconfig after Tom Rini review - default y for all SPL config - MAC DOS ISO and EFI enable by default for some platforms - DOS enable with command FAT or USB storage
Changes in v2: - solve compilation issue for config_fallback.h (CONFIG_IS_ENABLED unknown) - rebase on master branch - default y for DOS partition as proposed by Tom Rini - removed not related changes in defconfig files
Kconfig | 2 + arch/arm/include/asm/arch-ls102xa/config.h | 1 - cmd/bootefi.c | 4 +- cmd/reiser.c | 2 +- cmd/zfs.c | 2 +- common/fb_mmc.c | 4 +- configs/A10-OLinuXino-Lime_defconfig | 3 + configs/A10s-OLinuXino-M_defconfig | 3 + configs/A13-OLinuXinoM_defconfig | 3 + configs/A13-OLinuXino_defconfig | 1 + configs/A20-OLinuXino-Lime2_defconfig | 2 + configs/A20-OLinuXino-Lime_defconfig | 3 + configs/A20-OLinuXino_MICRO_defconfig | 3 + configs/A20-Olimex-SOM-EVB_defconfig | 3 + configs/A33-OLinuXino_defconfig | 3 + configs/Ainol_AW1_defconfig | 3 + configs/Ampe_A76_defconfig | 3 + configs/Auxtek-T003_defconfig | 3 + configs/Auxtek-T004_defconfig | 3 + configs/Bananapi_defconfig | 3 + configs/Bananapro_defconfig | 3 + configs/C29XPCIE_NAND_defconfig | 1 + configs/C29XPCIE_NOR_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_defconfig | 1 + configs/C29XPCIE_defconfig | 1 + configs/CHIP_defconfig | 3 + configs/CPCI4052_defconfig | 1 + configs/CSQ_CS908_defconfig | 3 + configs/Chuwi_V7_CW0825_defconfig | 3 + configs/Colombus_defconfig | 3 + configs/Cubieboard2_defconfig | 3 + configs/Cubieboard4_defconfig | 3 + configs/Cubieboard_defconfig | 3 + configs/Cubietruck_defconfig | 2 + configs/Cubietruck_plus_defconfig | 3 + configs/Empire_electronix_d709_defconfig | 3 + configs/Empire_electronix_m712_defconfig | 3 + configs/Hummingbird_A31_defconfig | 3 + configs/Hyundai_A7HD_defconfig | 3 + configs/Itead_Ibox_A20_defconfig | 3 + configs/Lamobo_R1_defconfig | 3 + configs/Linksprite_pcDuino3_Nano_defconfig | 3 + configs/Linksprite_pcDuino3_defconfig | 3 + configs/Linksprite_pcDuino_defconfig | 3 + configs/M5253DEMO_defconfig | 1 + configs/M5253EVBE_defconfig | 1 + configs/M54455EVB_a66_defconfig | 1 + configs/M54455EVB_defconfig | 1 + configs/M54455EVB_i66_defconfig | 1 + configs/M54455EVB_intel_defconfig | 1 + configs/M54455EVB_stm33_defconfig | 1 + configs/MIP405T_defconfig | 2 + configs/MIP405_defconfig | 2 + configs/MK808C_defconfig | 3 + configs/MPC8610HPCD_defconfig | 1 + configs/MPC8641HPCN_36BIT_defconfig | 1 + configs/MPC8641HPCN_defconfig | 1 + configs/MSI_Primo73_defconfig | 3 + configs/MSI_Primo81_defconfig | 3 + configs/Marsboard_A10_defconfig | 3 + configs/Mele_A1000G_quad_defconfig | 3 + configs/Mele_A1000_defconfig | 3 + configs/Mele_I7_defconfig | 3 + configs/Mele_M3_defconfig | 3 + configs/Mele_M5_defconfig | 3 + configs/Mele_M9_defconfig | 3 + configs/Merrii_A80_Optimus_defconfig | 3 + configs/Mini-X_defconfig | 3 + configs/MiniFAP_defconfig | 2 + configs/Nintendo_NES_Classic_Edition_defconfig | 3 + configs/O2D300_defconfig | 2 + configs/O2DNT2_RAMBOOT_defconfig | 2 + configs/O2DNT2_defconfig | 2 + configs/O2D_defconfig | 2 + configs/O2I_defconfig | 2 + configs/O2MNT_O2M110_defconfig | 2 + configs/O2MNT_O2M112_defconfig | 2 + configs/O2MNT_O2M113_defconfig | 2 + configs/O2MNT_defconfig | 2 + configs/O3DNT_defconfig | 2 + configs/Orangepi_defconfig | 3 + configs/Orangepi_mini_defconfig | 3 + configs/PIP405_defconfig | 2 + configs/PLU405_defconfig | 1 + configs/PMC440_defconfig | 2 + configs/Sinlinx_SinA31s_defconfig | 3 + configs/Sinlinx_SinA33_defconfig | 2 + configs/Sinovoip_BPI_M2_defconfig | 3 + configs/Sinovoip_BPI_M3_defconfig | 3 + configs/TQM5200S_HIGHBOOT_defconfig | 2 + configs/TQM5200S_defconfig | 2 + configs/TQM5200_B_HIGHBOOT_defconfig | 2 + configs/TQM5200_B_defconfig | 2 + configs/TQM5200_STK100_defconfig | 2 + configs/TQM5200_defconfig | 2 + configs/TQM823L_LCD_defconfig | 2 + configs/TQM823L_defconfig | 2 + configs/TQM823M_defconfig | 2 + configs/TQM850L_defconfig | 2 + configs/TQM850M_defconfig | 2 + configs/TQM855L_defconfig | 2 + configs/TQM855M_defconfig | 2 + configs/TQM860L_defconfig | 2 + configs/TQM860M_defconfig | 2 + configs/TQM862L_defconfig | 2 + configs/TQM862M_defconfig | 2 + configs/TQM866M_defconfig | 2 + configs/TQM885D_defconfig | 2 + configs/TTTech_defconfig | 2 + configs/UTOO_P66_defconfig | 3 + configs/Wexler_TAB7200_defconfig | 3 + configs/Wits_Pro_A20_DKT_defconfig | 3 + configs/Wobo_i5_defconfig | 3 + configs/Yones_Toptech_BD1078_defconfig | 3 + configs/Yones_Toptech_BS1078_V2_defconfig | 3 + configs/a4m072_defconfig | 1 + configs/acadia_defconfig | 2 + configs/am335x_baltos_defconfig | 2 + configs/am335x_igep0033_defconfig | 2 + configs/am335x_shc_defconfig | 4 + configs/am335x_shc_ict_defconfig | 4 + configs/am335x_shc_netboot_defconfig | 4 + configs/am335x_shc_prompt_defconfig | 4 + configs/am335x_shc_sdboot_defconfig | 4 + configs/am335x_shc_sdboot_prompt_defconfig | 4 + configs/am3517_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 2 + configs/am43xx_evm_ethboot_defconfig | 2 + configs/am43xx_evm_qspiboot_defconfig | 2 + configs/am43xx_evm_usbhost_boot_defconfig | 2 + configs/am43xx_hs_evm_defconfig | 2 + configs/am57xx_evm_defconfig | 2 + configs/am57xx_evm_nodt_defconfig | 2 + configs/am57xx_hs_evm_defconfig | 2 + configs/ap121_defconfig | 1 + configs/ap143_defconfig | 1 + configs/ap325rxa_defconfig | 1 + configs/apalis_t30_defconfig | 3 + configs/arches_defconfig | 3 + configs/ba10_tv_box_defconfig | 3 + configs/bamboo_defconfig | 2 + configs/bayleybay_defconfig | 3 + configs/bcm11130_defconfig | 2 + configs/bcm11130_nand_defconfig | 2 + configs/bcm23550_w1d_defconfig | 2 + configs/bcm28155_ap_defconfig | 2 + configs/bcm28155_w1d_defconfig | 2 + configs/beaver_defconfig | 3 + configs/bg0900_defconfig | 1 + configs/birdland_bav335a_defconfig | 2 + configs/birdland_bav335b_defconfig | 2 + configs/boston32r2_defconfig | 2 + configs/boston32r2el_defconfig | 2 + configs/boston64r2_defconfig | 2 + configs/boston64r2el_defconfig | 2 + configs/cairo_defconfig | 2 + configs/cam5200_defconfig | 3 + configs/cam5200_niosflash_defconfig | 3 + configs/canyonlands_defconfig | 2 + configs/cardhu_defconfig | 3 + configs/cei-tk1-som_defconfig | 3 + configs/charon_defconfig | 2 + configs/chromebit_mickey_defconfig | 5 + configs/chromebook_jerry_defconfig | 5 + configs/chromebook_link_defconfig | 3 + configs/chromebook_minnie_defconfig | 5 + configs/chromebook_samus_defconfig | 3 + configs/chromebox_panther_defconfig | 3 + configs/cl-som-am57x_defconfig | 2 + configs/clearfog_defconfig | 2 + configs/cm5200_defconfig | 2 + configs/cm_t335_defconfig | 2 + configs/cm_t43_defconfig | 2 + configs/cm_t54_defconfig | 2 + configs/colibri_t20_defconfig | 3 + configs/colibri_t30_defconfig | 3 + configs/colorfly_e708_q1_defconfig | 3 + ...conga-qeval20-qa3-e3845-internal-uart_defconfig | 3 + configs/conga-qeval20-qa3-e3845_defconfig | 3 + .../controlcenterd_TRAILBLAZER_DEVELOP_defconfig | 1 + configs/controlcenterd_TRAILBLAZER_defconfig | 1 + configs/coreboot-x86_defconfig | 3 + configs/cougarcanyon2_defconfig | 3 + configs/crownbay_defconfig | 3 + configs/d2net_v2_defconfig | 3 + configs/dalmore_defconfig | 3 + configs/db-88f6720_defconfig | 1 + configs/db-88f6820-amc_defconfig | 2 + configs/db-88f6820-gp_defconfig | 2 + configs/db-mv784mp-gp_defconfig | 2 + configs/dbau1000_defconfig | 2 + configs/dbau1100_defconfig | 2 + configs/dbau1500_defconfig | 2 + configs/dbau1550_defconfig | 1 + configs/dbau1550_el_defconfig | 1 + configs/devconcenter_defconfig | 2 + configs/devkit8000_defconfig | 2 + configs/dfi-bt700-q7x-151_defconfig | 3 + configs/difrnce_dit4350_defconfig | 3 + configs/dns325_defconfig | 1 + configs/dockstar_defconfig | 1 + configs/dra7xx_evm_defconfig | 2 + configs/dra7xx_hs_evm_defconfig | 2 + configs/draco_defconfig | 1 + configs/dreamplug_defconfig | 1 + configs/ds109_defconfig | 2 + configs/ds414_defconfig | 1 + configs/dserve_dsrv9703c_defconfig | 3 + configs/duovero_defconfig | 1 + configs/edb9315a_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/efi-x86_defconfig | 3 + configs/etamin_defconfig | 1 + configs/evb-rk3036_defconfig | 5 + configs/evb-rk3288_defconfig | 5 + configs/evb-rk3399_defconfig | 2 + configs/fennec-rk3288_defconfig | 5 + configs/firefly-rk3288_defconfig | 5 + configs/fo300_defconfig | 2 + configs/ga10h_v1_1_defconfig | 3 + configs/galileo_defconfig | 3 + configs/ge_b450v3_defconfig | 1 + configs/ge_b650v3_defconfig | 1 + configs/ge_b850v3_defconfig | 1 + configs/glacier_defconfig | 3 + configs/glacier_ramboot_defconfig | 3 + configs/goflexhome_defconfig | 1 + configs/gplugd_defconfig | 1 + configs/gt90h_v4_defconfig | 3 + configs/gurnard_defconfig | 1 + configs/guruplug_defconfig | 1 + configs/h8_homlet_v2_defconfig | 3 + configs/harmony_defconfig | 3 + configs/highbank_defconfig | 3 + configs/hrcon_defconfig | 1 + configs/hrcon_dh_defconfig | 1 + configs/i12-tvbox_defconfig | 3 + configs/iNet_3F_defconfig | 3 + configs/iNet_3W_defconfig | 3 + configs/iNet_86VS_defconfig | 3 + configs/iNet_D978_rev2_defconfig | 3 + configs/ib62x0_defconfig | 1 + configs/icnova-a20-swac_defconfig | 3 + configs/iconnect_defconfig | 1 + configs/igep0020_defconfig | 2 + configs/imgtec_xilfpga_defconfig | 1 + configs/inet1_defconfig | 3 + configs/inet86dz_defconfig | 3 + configs/inet97fv2_defconfig | 3 + configs/inet98v_rev2_defconfig | 3 + configs/inet9f_rev03_defconfig | 3 + configs/inet_q972_defconfig | 3 + configs/inetspace_v2_defconfig | 3 + configs/inka4x0_defconfig | 2 + configs/intip_defconfig | 2 + configs/jesurun_q5_defconfig | 3 + configs/jetson-tk1_defconfig | 3 + configs/jupiter_defconfig | 3 + configs/k2e_evm_defconfig | 2 + configs/k2g_evm_defconfig | 2 + configs/k2hk_evm_defconfig | 2 + configs/k2l_evm_defconfig | 2 + configs/kc1_defconfig | 2 + configs/kmcoge4_defconfig | 1 + configs/kmlion1_defconfig | 1 + configs/kylin-rk3036_defconfig | 5 + configs/ls1012afrdm_qspi_defconfig | 1 + configs/ls1021aiot_qspi_defconfig | 1 + configs/ls1021aiot_sdcard_defconfig | 1 + configs/ls2080a_emu_defconfig | 4 + configs/ls2080a_simu_defconfig | 3 + configs/ls2080aqds_SECURE_BOOT_defconfig | 3 + configs/ls2080aqds_defconfig | 3 + configs/ls2080aqds_nand_defconfig | 3 + configs/ls2080aqds_qspi_defconfig | 3 + configs/lschlv2_defconfig | 3 + configs/lsxhl_defconfig | 1 + configs/lwmon5_defconfig | 2 + configs/malta64_defconfig | 1 + configs/malta64el_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + configs/medcom-wide_defconfig | 3 + configs/miniarm-rk3288_defconfig | 5 + configs/minnowmax_defconfig | 3 + configs/mixtile_loftq_defconfig | 3 + configs/mk802_a10s_defconfig | 3 + configs/mk802_defconfig | 3 + configs/mk802ii_defconfig | 3 + configs/mpc5121ads_defconfig | 2 + configs/mpc5121ads_rev2_defconfig | 2 + configs/ms7720se_defconfig | 1 + configs/mvebu_db-88f3720_defconfig | 3 + configs/mvebu_db-88f7040_defconfig | 3 + configs/mvebu_db-88f8040_defconfig | 3 + configs/mx35pdk_defconfig | 2 + configs/nanopi_neo_defconfig | 3 + configs/nas220_defconfig | 3 + configs/net2big_v2_defconfig | 3 + configs/netspace_lite_v2_defconfig | 3 + configs/netspace_max_v2_defconfig | 3 + configs/netspace_mini_v2_defconfig | 2 + configs/netspace_v2_defconfig | 3 + configs/nsa310s_defconfig | 1 + configs/nyan-big_defconfig | 3 + configs/odroid-c2_defconfig | 4 + configs/odroid_defconfig | 2 + configs/omap3_evm_defconfig | 2 + configs/omap3_logic_defconfig | 2 + configs/omap3_overo_defconfig | 2 + configs/omap3_zoom1_defconfig | 2 + configs/omap5_uevm_defconfig | 2 + configs/openrd_base_defconfig | 1 + configs/openrd_client_defconfig | 1 + configs/openrd_ultimate_defconfig | 1 + configs/orangepi_2_defconfig | 3 + configs/orangepi_lite_defconfig | 3 + configs/orangepi_one_defconfig | 3 + configs/orangepi_pc_defconfig | 3 + configs/orangepi_pc_plus_defconfig | 3 + configs/orangepi_plus2e_defconfig | 3 + configs/orangepi_plus_defconfig | 3 + configs/origen_defconfig | 2 + configs/parrot_r16_defconfig | 2 + configs/paz00_defconfig | 3 + configs/pb1000_defconfig | 1 + configs/pcm051_rev1_defconfig | 2 + configs/pcm051_rev3_defconfig | 2 + configs/pcm058_defconfig | 3 + configs/pengwyn_defconfig | 2 + configs/pepper_defconfig | 2 + configs/pic32mzdask_defconfig | 2 + configs/plutux_defconfig | 3 + configs/pogo_e02_defconfig | 1 + configs/polaroid_mid2407pxe03_defconfig | 3 + configs/polaroid_mid2809pxe04_defconfig | 3 + configs/popmetal-rk3288_defconfig | 5 + configs/pov_protab2_ips9_defconfig | 3 + configs/q8_a13_tablet_defconfig | 3 + configs/q8_a23_tablet_800x480_defconfig | 3 + configs/q8_a33_tablet_1024x600_defconfig | 3 + configs/q8_a33_tablet_800x480_defconfig | 3 + configs/qemu-ppce500_defconfig | 1 + configs/qemu-x86_defconfig | 3 + configs/qemu-x86_efi_payload32_defconfig | 3 + configs/qemu-x86_efi_payload64_defconfig | 3 + configs/qemu_mips64_defconfig | 1 + configs/qemu_mips64el_defconfig | 1 + configs/qemu_mips_defconfig | 1 + configs/qemu_mipsel_defconfig | 1 + configs/r2dplus_defconfig | 1 + configs/r7-tv-dongle_defconfig | 3 + configs/r7780mp_defconfig | 1 + configs/rainier_defconfig | 2 + configs/rainier_ramboot_defconfig | 2 + configs/rastaban_defconfig | 1 + configs/rock2_defconfig | 5 + configs/s5p_goni_defconfig | 1 + configs/s5pc210_universal_defconfig | 2 + configs/salvator-x_defconfig | 1 + configs/sandbox_defconfig | 5 + configs/sandbox_noblk_defconfig | 5 + configs/sandbox_spl_defconfig | 6 ++ configs/sbc8641d_defconfig | 1 + configs/seaboard_defconfig | 3 + configs/sequoia_defconfig | 2 + configs/sequoia_ramboot_defconfig | 2 + configs/sh7752evb_defconfig | 2 + configs/sh7753evb_defconfig | 2 + configs/sh7757lcr_defconfig | 2 + configs/sh7785lcr_32bit_defconfig | 1 + configs/sh7785lcr_defconfig | 1 + configs/sheevaplug_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/smdkv310_defconfig | 2 + configs/sniper_defconfig | 2 + configs/som-db5800-som-6867_defconfig | 3 + configs/strider_con_defconfig | 1 + configs/strider_con_dp_defconfig | 1 + configs/strider_cpu_defconfig | 1 + configs/strider_cpu_dp_defconfig | 1 + configs/sunxi_Gemei_G9_defconfig | 3 + configs/taurus_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/tec-ng_defconfig | 3 + configs/tec_defconfig | 3 + configs/theadorable-x86-dfi-bt700_defconfig | 3 + configs/theadorable_debug_defconfig | 2 + configs/theadorable_defconfig | 2 + configs/thuban_defconfig | 1 + configs/tplink_wdr4300_defconfig | 1 + configs/trats2_defconfig | 2 + configs/trats_defconfig | 2 + configs/trimslice_defconfig | 3 + configs/udoo_neo_defconfig | 2 + configs/update.sh | 15 +++ configs/v38b_defconfig | 1 + configs/vct_platinum_onenand_small_defconfig | 1 + configs/vct_platinum_small_defconfig | 1 + configs/vct_platinumavc_defconfig | 1 + configs/vct_platinumavc_onenand_defconfig | 1 + configs/vct_platinumavc_onenand_small_defconfig | 1 + configs/vct_platinumavc_small_defconfig | 1 + configs/vct_premium_onenand_small_defconfig | 1 + configs/vct_premium_small_defconfig | 1 + configs/venice2_defconfig | 3 + configs/ventana_defconfig | 3 + configs/vexpress_aemv8a_dram_defconfig | 3 + configs/vexpress_aemv8a_juno_defconfig | 3 + configs/vexpress_aemv8a_semi_defconfig | 3 + configs/vinco_defconfig | 1 + configs/vining_2000_defconfig | 1 + configs/warp7_defconfig | 1 + configs/warp7_secure_defconfig | 1 + configs/whistler_defconfig | 3 + configs/woodburn_defconfig | 2 + configs/woodburn_sd_defconfig | 2 + configs/work_92105_defconfig | 1 + configs/wtk_defconfig | 2 + configs/xilinx_zynqmp_ep_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 1 + configs/xilinx_zynqmp_zcu102_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 + configs/yellowstone_defconfig | 3 + configs/yosemite_defconfig | 2 + disk/Kconfig | 103 +++++++++++++++++++++ disk/Makefile | 12 +-- disk/part.c | 10 +- disk/part_amiga.h | 2 +- disk/part_efi.c | 2 +- disk/part_mac.h | 2 +- include/config_defaults.h | 1 - include/config_distro_bootcmd.h | 1 - include/config_distro_defaults.h | 3 - include/config_fallbacks.h | 1 + include/configs/B4860QDS.h | 1 - include/configs/BSC9131RDB.h | 1 - include/configs/BSC9132QDS.h | 6 -- include/configs/C29XPCIE.h | 1 - include/configs/CPCI4052.h | 3 - include/configs/M52277EVB.h | 3 - include/configs/M5253DEMO.h | 2 - include/configs/M5253EVBE.h | 2 - include/configs/M54455EVB.h | 2 - include/configs/M5475EVB.h | 1 - include/configs/M5485EVB.h | 1 - include/configs/MIP405.h | 3 - include/configs/MPC8308RDB.h | 1 - include/configs/MPC8315ERDB.h | 1 - include/configs/MPC8349ITX.h | 1 - include/configs/MPC837XEMDS.h | 2 - include/configs/MPC837XERDB.h | 2 - include/configs/MPC8536DS.h | 5 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8569MDS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/P1010RDB.h | 3 - include/configs/P1022DS.h | 5 - include/configs/P1023RDB.h | 1 - include/configs/P2041RDB.h | 3 - include/configs/PIP405.h | 3 - include/configs/PLU405.h | 3 - include/configs/PMC440.h | 3 - include/configs/T102xQDS.h | 3 - include/configs/T102xRDB.h | 2 - include/configs/T1040QDS.h | 3 - include/configs/T104xRDB.h | 3 - include/configs/T208xQDS.h | 3 - include/configs/T208xRDB.h | 3 - include/configs/T4240QDS.h | 2 - include/configs/T4240RDB.h | 4 - include/configs/TQM5200.h | 3 - include/configs/TQM823L.h | 3 - include/configs/TQM823M.h | 3 - include/configs/TQM850L.h | 3 - include/configs/TQM850M.h | 3 - include/configs/TQM855L.h | 3 - include/configs/TQM855M.h | 3 - include/configs/TQM860L.h | 3 - include/configs/TQM860M.h | 3 - include/configs/TQM862L.h | 3 - include/configs/TQM862M.h | 3 - include/configs/TQM866M.h | 3 - include/configs/TQM885D.h | 3 - include/configs/UCP1020.h | 5 - include/configs/a4m072.h | 2 - include/configs/ac14xx.h | 6 -- include/configs/acadia.h | 3 - include/configs/adp-ag101p.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/am335x_evm.h | 3 - include/configs/am335x_shc.h | 4 - include/configs/am335x_sl50.h | 3 - include/configs/am3517_crane.h | 1 - include/configs/am3517_evm.h | 2 - include/configs/am43xx_evm.h | 1 - include/configs/am57xx_evm.h | 1 - include/configs/ap325rxa.h | 1 - include/configs/apalis_imx6.h | 1 - include/configs/apf27.h | 1 - include/configs/apx4devkit.h | 1 - include/configs/aria.h | 6 -- include/configs/at91rm9200ek.h | 1 - include/configs/at91sam9260ek.h | 3 - include/configs/at91sam9261ek.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9m10g45ek.h | 4 - include/configs/at91sam9n12ek.h | 3 - include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 3 - include/configs/atngw100.h | 1 - include/configs/atngw100mkii.h | 1 - include/configs/atstk1002.h | 1 - include/configs/axs10x.h | 1 - include/configs/baltos.h | 4 - include/configs/bamboo.h | 3 - include/configs/bav335x.h | 3 - include/configs/bcm23550_w1d.h | 2 - include/configs/bcm28155_ap.h | 2 - include/configs/bcm_ep_board.h | 1 - include/configs/bf533-stamp.h | 1 - include/configs/bf537-stamp.h | 1 - include/configs/bfin_adi_common.h | 3 - include/configs/bg0900.h | 1 - include/configs/brppt1.h | 1 - include/configs/brxre1.h | 1 - include/configs/canyonlands.h | 3 - include/configs/cl-som-am57x.h | 1 - include/configs/clearfog.h | 2 - include/configs/cm5200.h | 3 - include/configs/cm_t35.h | 1 - include/configs/cm_t3517.h | 1 - include/configs/cm_t43.h | 1 - include/configs/colibri_imx6.h | 1 - include/configs/colibri_vf.h | 1 - include/configs/controlcenterd.h | 1 - include/configs/corenet_ds.h | 3 - include/configs/corvus.h | 1 - include/configs/cyrus.h | 3 - include/configs/da850evm.h | 3 - include/configs/db-88f6820-amc.h | 2 - include/configs/db-88f6820-gp.h | 2 - include/configs/db-mv784mp-gp.h | 2 - include/configs/dbau1x00.h | 1 - include/configs/devkit3250.h | 1 - include/configs/digsy_mtc.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/draco.h | 2 - include/configs/dragonboard410c.h | 1 - include/configs/ds414.h | 2 - include/configs/duovero.h | 2 - include/configs/ecovec.h | 2 - include/configs/edminiv2.h | 3 - include/configs/etamin.h | 1 - include/configs/ethernut5.h | 1 - include/configs/exynos-common.h | 1 - include/configs/ge_bx50v3.h | 1 - include/configs/gplugd.h | 2 - include/configs/gr_cpci_ax2000.h | 3 - include/configs/gr_ep2s60.h | 3 - include/configs/gr_xc3s_1500.h | 3 - include/configs/grsim.h | 3 - include/configs/grsim_leon2.h | 3 - include/configs/hrcon.h | 1 - include/configs/ib62x0.h | 1 - include/configs/icon.h | 1 - include/configs/imx27lite-common.h | 1 - include/configs/inka4x0.h | 3 - include/configs/intip.h | 3 - include/configs/ipek01.h | 1 - include/configs/jupiter.h | 3 - include/configs/katmai.h | 1 - include/configs/kc1.h | 1 - include/configs/km/kmp204x-common.h | 1 - include/configs/kzm9g.h | 1 - include/configs/lacie_kw.h | 2 - include/configs/legoev3.h | 3 - include/configs/ls1012aqds.h | 2 - include/configs/ls1012ardb.h | 2 - include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 2 - include/configs/ls1021atwr.h | 2 - include/configs/ls1043a_common.h | 1 - include/configs/ls1043aqds.h | 1 - include/configs/ls1043ardb.h | 1 - include/configs/ls1046a_common.h | 1 - include/configs/ls1046aqds.h | 1 - include/configs/ls1046ardb.h | 1 - include/configs/ls2080a_simu.h | 1 - include/configs/ls2080aqds.h | 2 - include/configs/ls2080ardb.h | 2 - include/configs/lsxl.h | 3 - include/configs/lwmon5.h | 3 - include/configs/m28evk.h | 1 - include/configs/m53evk.h | 1 - include/configs/ma5d4evk.h | 1 - include/configs/manroland/common.h | 1 - include/configs/mcx.h | 1 - include/configs/mecp5123.h | 1 - include/configs/motionpro.h | 1 - include/configs/mpc5121ads.h | 5 - include/configs/ms7720se.h | 1 - include/configs/mv-common.h | 2 - include/configs/mvebu_armada-8k.h | 5 - include/configs/mvebu_db-88f3720.h | 5 - include/configs/mx23_olinuxino.h | 1 - include/configs/mx23evk.h | 1 - include/configs/mx25pdk.h | 2 - include/configs/mx28evk.h | 1 - include/configs/mx35pdk.h | 3 - include/configs/mx51evk.h | 1 - include/configs/mx53ard.h | 1 - include/configs/mx53cx9020.h | 1 - include/configs/mx53evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx53smd.h | 1 - include/configs/mx6_common.h | 1 - include/configs/mx7_common.h | 1 - include/configs/nas220.h | 2 - include/configs/nokia_rx51.h | 1 - include/configs/nsa310s.h | 1 - include/configs/o2dnt-common.h | 3 - include/configs/omap3_evm.h | 2 - include/configs/omap5_uevm.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/p1_p2_rdb_pc.h | 2 - include/configs/p1_twr.h | 2 - include/configs/pb1x00.h | 2 - include/configs/pcm030.h | 1 - include/configs/pcm052.h | 1 - include/configs/pic32mzdask.h | 2 - include/configs/pico-imx6ul.h | 1 - include/configs/picosam9g45.h | 4 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/pm9g45.h | 1 - include/configs/pxa-common.h | 1 - include/configs/qemu-mips.h | 1 - include/configs/qemu-mips64.h | 1 - include/configs/qemu-ppce500.h | 2 - include/configs/r2dplus.h | 1 - include/configs/r7780mp.h | 1 - include/configs/rastaban.h | 2 - include/configs/rcar-gen2-common.h | 1 - include/configs/rcar-gen3-common.h | 1 - include/configs/rk3036_common.h | 1 - include/configs/rk3288_common.h | 1 - include/configs/rockchip-common.h | 1 - include/configs/rpi.h | 1 - include/configs/s32v234evb.h | 1 - include/configs/s5p_goni.h | 4 - include/configs/sama5d2_ptc.h | 1 - include/configs/sama5d2_xplained.h | 4 - include/configs/sama5d3_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 4 - include/configs/sama5d4ek.h | 4 - include/configs/sandbox.h | 7 -- include/configs/sansa_fuze_plus.h | 1 - include/configs/sbc8641d.h | 1 - include/configs/sc_sps_1.h | 1 - include/configs/sequoia.h | 3 - include/configs/sh7752evb.h | 2 - include/configs/sh7753evb.h | 2 - include/configs/sh7757lcr.h | 2 - include/configs/sh7785lcr.h | 3 - include/configs/sheevaplug.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/smdkc100.h | 2 - include/configs/snapper9260.h | 1 - include/configs/snapper9g45.h | 2 - include/configs/sniper.h | 1 - include/configs/socfpga_arria5_socdk.h | 1 - include/configs/socfpga_cyclone5_socdk.h | 1 - include/configs/socfpga_de0_nano_soc.h | 1 - include/configs/socfpga_de1_soc.h | 1 - include/configs/socfpga_is1.h | 1 - include/configs/socfpga_mcvevk.h | 1 - include/configs/socfpga_sockit.h | 1 - include/configs/socfpga_socrates.h | 1 - include/configs/socfpga_sr1500.h | 1 - include/configs/socfpga_vining_fpga.h | 1 - include/configs/socrates.h | 1 - include/configs/strider.h | 1 - include/configs/sunxi-common.h | 1 - include/configs/t4qds.h | 2 - include/configs/tam3517-common.h | 1 - include/configs/tao3530.h | 1 - include/configs/tbs2910.h | 2 - include/configs/tegra-common-post.h | 9 -- include/configs/tegra-common.h | 1 - include/configs/theadorable.h | 2 - include/configs/thuban.h | 2 - include/configs/ti814x_evm.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/ti_armv7_common.h | 2 - include/configs/ti_armv7_keystone2.h | 1 - include/configs/tplink_wdr4300.h | 2 - include/configs/tricorder.h | 1 - include/configs/ts4600.h | 1 - include/configs/ts4800.h | 1 - include/configs/uniphier.h | 1 - include/configs/usb_a9263.h | 1 - include/configs/v38b.h | 2 - include/configs/vct.h | 3 - include/configs/vexpress_aemv8a.h | 1 - include/configs/vf610twr.h | 1 - include/configs/vinco.h | 6 -- include/configs/vining_2000.h | 2 - include/configs/warp7.h | 1 - include/configs/woodburn_common.h | 3 - include/configs/work_92105.h | 1 - include/configs/x600.h | 1 - include/configs/x86-common.h | 5 - include/configs/xfi3.h | 1 - include/configs/xilinx_zynqmp.h | 5 - include/configs/xpedite550x.h | 1 - include/configs/yosemite.h | 3 - include/configs/zipitz2.h | 1 - include/configs/zmx25.h | 1 - include/configs/zynq-common.h | 1 - include/part.h | 4 +- lib/efi_loader/efi_disk.c | 2 +- scripts/config_whitelist.txt | 8 -- 730 files changed, 1097 insertions(+), 586 deletions(-) create mode 100644 configs/update.sh create mode 100644 disk/Kconfig
diff --git a/Kconfig b/Kconfig index a44ac91..de1dcb9 100644 --- a/Kconfig +++ b/Kconfig @@ -313,6 +313,8 @@ source "common/Kconfig"
source "cmd/Kconfig"
+source "disk/Kconfig" + source "dts/Kconfig"
source "net/Kconfig" diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index fccd4ff..60f0a04 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -90,7 +90,6 @@ #define CONFIG_SYS_SCSI_MAX_LUN 1 #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ CONFIG_SYS_SCSI_MAX_LUN) -#define CONFIG_DOS_PARTITION
#ifdef CONFIG_DDR_SPD #define CONFIG_VERY_BIG_RAM diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 97a0fc9..91c56b0 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -321,7 +321,7 @@ void efi_set_bootdev(const char *dev, const char *devnr, const char *path) char devname[32] = { 0 }; /* dp->str is u16[32] long */ char *colon;
-#if defined(CONFIG_BLK) || defined(CONFIG_ISO_PARTITION) +#if defined(CONFIG_BLK) || CONFIG_IS_ENABLED(ISO_PARTITION) desc = blk_get_dev(dev, simple_strtol(devnr, NULL, 10)); #endif
@@ -338,7 +338,7 @@ void efi_set_bootdev(const char *dev, const char *devnr, const char *path)
colon = strchr(devname, ':');
-#ifdef CONFIG_ISO_PARTITION +#if CONFIG_IS_ENABLED(ISO_PARTITION) /* For ISOs we create partition block devices */ if (desc && (desc->type != DEV_TYPE_UNKNOWN) && (desc->part_type == PART_TYPE_ISO)) { diff --git a/cmd/reiser.c b/cmd/reiser.c index cbdad36..9c3e9e9 100644 --- a/cmd/reiser.c +++ b/cmd/reiser.c @@ -18,7 +18,7 @@ #include <reiserfs.h> #include <part.h>
-#ifndef CONFIG_DOS_PARTITION +#if !CONFIG_IS_ENABLED(DOS_PARTITION) #error DOS partition support must be selected #endif
diff --git a/cmd/zfs.c b/cmd/zfs.c index 93067a9..3ed9912 100644 --- a/cmd/zfs.c +++ b/cmd/zfs.c @@ -24,7 +24,7 @@ #include <usb.h> #endif
-#if !defined(CONFIG_DOS_PARTITION) && !defined(CONFIG_EFI_PARTITION) +#if !CONFIG_IS_ENABLED(DOS_PARTITION) && !CONFIG_IS_ENABLED(EFI_PARTITION) #error DOS or EFI partition support must be selected #endif
diff --git a/common/fb_mmc.c b/common/fb_mmc.c index 81a3bd0..6cc113d 100644 --- a/common/fb_mmc.c +++ b/common/fb_mmc.c @@ -112,7 +112,7 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer, return; }
-#ifdef CONFIG_EFI_PARTITION +#if CONFIG_IS_ENABLED(EFI_PARTITION) if (strcmp(cmd, CONFIG_FASTBOOT_GPT_NAME) == 0) { printf("%s: updating MBR, Primary and Backup GPT(s)\n", __func__); @@ -133,7 +133,7 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer, } #endif
-#ifdef CONFIG_DOS_PARTITION +#if CONFIG_IS_ENABLED(DOS_PARTITION) if (strcmp(cmd, CONFIG_FASTBOOT_MBR_NAME) == 0) { printf("%s: updating MBR\n", __func__); if (is_valid_dos_buf(download_buffer)) { diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index 50436a7..9368c6d 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -14,6 +14,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index e2bebf8..6adb5bc 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -14,5 +14,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index 361d90a..264135b 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -17,5 +17,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index 3191098..3756ed5 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -22,6 +22,7 @@ CONFIG_SPL=y CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set CONFIG_DFU_RAM=y CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 8fd7c64..8db638e 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL=y CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set CONFIG_DFU_RAM=y CONFIG_RTL8211X_PHY_FORCE_MASTER=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index 26e6ace..dea2e6b 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -12,6 +12,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index d629eb1..703aee1 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -15,6 +15,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index b5d52db..fbc4fe0 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -17,6 +17,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_RTL8211X_PHY_FORCE_MASTER=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO3_VOLT=2800 diff --git a/configs/A33-OLinuXino_defconfig b/configs/A33-OLinuXino_defconfig index 2909987..e959240 100644 --- a/configs/A33-OLinuXino_defconfig +++ b/configs/A33-OLinuXino_defconfig @@ -19,5 +19,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/Ainol_AW1_defconfig b/configs/Ainol_AW1_defconfig index 46c5309..7284b9b 100644 --- a/configs/Ainol_AW1_defconfig +++ b/configs/Ainol_AW1_defconfig @@ -18,4 +18,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index 5020724..b7ff535 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -20,4 +20,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/Auxtek-T003_defconfig b/configs/Auxtek-T003_defconfig index 1e248a7..2220191 100644 --- a/configs/Auxtek-T003_defconfig +++ b/configs/Auxtek-T003_defconfig @@ -12,5 +12,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index 55f956e..9146fbb 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -10,5 +10,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 0f2ef1b..8fccea8 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -13,6 +13,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_NETCONSOLE=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index e3bb4b2..dda7080 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -15,6 +15,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_NETCONSOLE=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO4_VOLT=2500 diff --git a/configs/C29XPCIE_NAND_defconfig b/configs/C29XPCIE_NAND_defconfig index e2490dc..9e8c903 100644 --- a/configs/C29XPCIE_NAND_defconfig +++ b/configs/C29XPCIE_NAND_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/C29XPCIE_NOR_SECBOOT_defconfig b/configs/C29XPCIE_NOR_SECBOOT_defconfig index 801c10e..ea74ca7 100644 --- a/configs/C29XPCIE_NOR_SECBOOT_defconfig +++ b/configs/C29XPCIE_NOR_SECBOOT_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_DOS_PARTITION=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig index 0639457..96f1006 100644 --- a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig +++ b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_DOS_PARTITION=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/C29XPCIE_SPIFLASH_defconfig b/configs/C29XPCIE_SPIFLASH_defconfig index dc536a7..e072d64 100644 --- a/configs/C29XPCIE_SPIFLASH_defconfig +++ b/configs/C29XPCIE_SPIFLASH_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/C29XPCIE_defconfig b/configs/C29XPCIE_defconfig index 5d7f03e..4c46f40 100644 --- a/configs/C29XPCIE_defconfig +++ b/configs/C29XPCIE_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 65d0c98..9d567e1 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -13,6 +13,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_DFU_RAM=y CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_AXP_ALDO4_VOLT=3300 diff --git a/configs/CPCI4052_defconfig b/configs/CPCI4052_defconfig index b5135f7..d58ada0 100644 --- a/configs/CPCI4052_defconfig +++ b/configs/CPCI4052_defconfig @@ -16,5 +16,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index 448ce95..953ec25 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -11,6 +11,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_DLDO1_VOLT=3300 diff --git a/configs/Chuwi_V7_CW0825_defconfig b/configs/Chuwi_V7_CW0825_defconfig index 8507f73..af5e757 100644 --- a/configs/Chuwi_V7_CW0825_defconfig +++ b/configs/Chuwi_V7_CW0825_defconfig @@ -18,6 +18,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y CONFIG_VIDEO_LCD_SPI_CS="PA0" CONFIG_VIDEO_LCD_SPI_SCLK="PA1" diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index d8272c5..ac283a2 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -21,6 +21,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index dfeb66c..ca3c991 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -12,5 +12,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubieboard4_defconfig b/configs/Cubieboard4_defconfig index 4d36d39..97cef1f 100644 --- a/configs/Cubieboard4_defconfig +++ b/configs/Cubieboard4_defconfig @@ -15,4 +15,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP809_POWER=y diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 64aebed..0389d4c 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -12,4 +12,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 10f3237..dc46e2f 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -19,6 +19,8 @@ CONFIG_SPL=y CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set CONFIG_DFU_RAM=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index dbe3336..1a59e93 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -18,6 +18,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO3_VOLT=2500 CONFIG_AXP_DLDO4_VOLT=3300 CONFIG_AXP_FLDO1_VOLT=1200 diff --git a/configs/Empire_electronix_d709_defconfig b/configs/Empire_electronix_d709_defconfig index 831949a..93aeaf4 100644 --- a/configs/Empire_electronix_d709_defconfig +++ b/configs/Empire_electronix_d709_defconfig @@ -21,4 +21,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/Empire_electronix_m712_defconfig b/configs/Empire_electronix_m712_defconfig index 4b51380..160f846 100644 --- a/configs/Empire_electronix_m712_defconfig +++ b/configs/Empire_electronix_m712_defconfig @@ -20,4 +20,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index dc4133d..c1cbbc8 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -13,6 +13,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Hyundai_A7HD_defconfig b/configs/Hyundai_A7HD_defconfig index 41cb877..58be283 100644 --- a/configs/Hyundai_A7HD_defconfig +++ b/configs/Hyundai_A7HD_defconfig @@ -19,4 +19,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index baca3e8..7d0b8ed 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -12,5 +12,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 6fe79e2..d37fa02 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -13,5 +13,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 622d35c..0663c46 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -14,5 +14,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index 9d2dfa5a..e116345 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -12,5 +12,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index ab094a6..8b310fa 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -11,4 +11,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_EHCI_HCD=y diff --git a/configs/M5253DEMO_defconfig b/configs/M5253DEMO_defconfig index 621cb8f..e17ba1a 100644 --- a/configs/M5253DEMO_defconfig +++ b/configs/M5253DEMO_defconfig @@ -8,3 +8,4 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y diff --git a/configs/M5253EVBE_defconfig b/configs/M5253EVBE_defconfig index 4b81ba4..2be75d6 100644 --- a/configs/M5253EVBE_defconfig +++ b/configs/M5253EVBE_defconfig @@ -8,3 +8,4 @@ CONFIG_BOOTDELAY=5 CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y diff --git a/configs/M54455EVB_a66_defconfig b/configs/M54455EVB_a66_defconfig index a59421f..07a10a4 100644 --- a/configs/M54455EVB_a66_defconfig +++ b/configs/M54455EVB_a66_defconfig @@ -15,5 +15,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_defconfig b/configs/M54455EVB_defconfig index 89150a7..751a059 100644 --- a/configs/M54455EVB_defconfig +++ b/configs/M54455EVB_defconfig @@ -16,5 +16,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_i66_defconfig b/configs/M54455EVB_i66_defconfig index 862003d..7fb20d7 100644 --- a/configs/M54455EVB_i66_defconfig +++ b/configs/M54455EVB_i66_defconfig @@ -15,5 +15,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_intel_defconfig b/configs/M54455EVB_intel_defconfig index b568e2a..bfce3a6 100644 --- a/configs/M54455EVB_intel_defconfig +++ b/configs/M54455EVB_intel_defconfig @@ -15,5 +15,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_stm33_defconfig b/configs/M54455EVB_stm33_defconfig index a1ce1b2..830ab65 100644 --- a/configs/M54455EVB_stm33_defconfig +++ b/configs/M54455EVB_stm33_defconfig @@ -15,5 +15,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index 76d0ef4..6ef03bd 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -18,6 +18,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_VIDEO_CT69000=y diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index 0c358f9..22e55e1 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -19,6 +19,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/MK808C_defconfig b/configs/MK808C_defconfig index 1e8f9db..1b8319c 100644 --- a/configs/MK808C_defconfig +++ b/configs/MK808C_defconfig @@ -9,4 +9,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_EHCI_HCD=y diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 563896d..2f3eead 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y diff --git a/configs/MPC8641HPCN_36BIT_defconfig b/configs/MPC8641HPCN_36BIT_defconfig index 9bd0e3d..1a4dba5 100644 --- a/configs/MPC8641HPCN_36BIT_defconfig +++ b/configs/MPC8641HPCN_36BIT_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y diff --git a/configs/MPC8641HPCN_defconfig b/configs/MPC8641HPCN_defconfig index 43a5290..a32a1ae 100644 --- a/configs/MPC8641HPCN_defconfig +++ b/configs/MPC8641HPCN_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y diff --git a/configs/MSI_Primo73_defconfig b/configs/MSI_Primo73_defconfig index 87fd3b9..9e19ec4 100644 --- a/configs/MSI_Primo73_defconfig +++ b/configs/MSI_Primo73_defconfig @@ -14,3 +14,6 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index 8847271..08a7db2 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -16,6 +16,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index 0d381ff..34e78f1 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -9,5 +9,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index 4097e5b..8f03835 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -12,6 +12,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 820d5ed..5047ba4 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -12,4 +12,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index eb3c74c..572b521 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -11,6 +11,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index 037e768..31e8aaf 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -14,5 +14,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index e64e452..6993894 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -14,5 +14,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index c4e5993..a9dc159 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -11,6 +11,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 diff --git a/configs/Merrii_A80_Optimus_defconfig b/configs/Merrii_A80_Optimus_defconfig index 6397de5..8bc751c 100644 --- a/configs/Merrii_A80_Optimus_defconfig +++ b/configs/Merrii_A80_Optimus_defconfig @@ -15,4 +15,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP809_POWER=y diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index 87fac82..4a32875 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -10,5 +10,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/MiniFAP_defconfig b/configs/MiniFAP_defconfig index ff79c12..7e6dc7e 100644 --- a/configs/MiniFAP_defconfig +++ b/configs/MiniFAP_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CONSOLE_EXTRA_INFO=y diff --git a/configs/Nintendo_NES_Classic_Edition_defconfig b/configs/Nintendo_NES_Classic_Edition_defconfig index fcda1be..5515918 100644 --- a/configs/Nintendo_NES_Classic_Edition_defconfig +++ b/configs/Nintendo_NES_Classic_Edition_defconfig @@ -14,6 +14,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_ELDO2_VOLT=1800 CONFIG_USB_MUSB_GADGET=y diff --git a/configs/O2D300_defconfig b/configs/O2D300_defconfig index 36c55b6..5fe4218 100644 --- a/configs/O2D300_defconfig +++ b/configs/O2D300_defconfig @@ -11,5 +11,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2DNT2_RAMBOOT_defconfig b/configs/O2DNT2_RAMBOOT_defconfig index b374c28..ccfa82b 100644 --- a/configs/O2DNT2_RAMBOOT_defconfig +++ b/configs/O2DNT2_RAMBOOT_defconfig @@ -15,5 +15,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2DNT2_defconfig b/configs/O2DNT2_defconfig index 00a713b..a074d55 100644 --- a/configs/O2DNT2_defconfig +++ b/configs/O2DNT2_defconfig @@ -14,5 +14,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2D_defconfig b/configs/O2D_defconfig index 9bc2342..e044afe 100644 --- a/configs/O2D_defconfig +++ b/configs/O2D_defconfig @@ -11,5 +11,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2I_defconfig b/configs/O2I_defconfig index 2f3276c..2c8d3e1 100644 --- a/configs/O2I_defconfig +++ b/configs/O2I_defconfig @@ -11,5 +11,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M110_defconfig b/configs/O2MNT_O2M110_defconfig index 57c9f7b..3c8b69b 100644 --- a/configs/O2MNT_O2M110_defconfig +++ b/configs/O2MNT_O2M110_defconfig @@ -12,5 +12,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M112_defconfig b/configs/O2MNT_O2M112_defconfig index 3afa43b..a1aefde 100644 --- a/configs/O2MNT_O2M112_defconfig +++ b/configs/O2MNT_O2M112_defconfig @@ -12,5 +12,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M113_defconfig b/configs/O2MNT_O2M113_defconfig index a543a3b..a2220a9 100644 --- a/configs/O2MNT_O2M113_defconfig +++ b/configs/O2MNT_O2M113_defconfig @@ -12,5 +12,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_defconfig b/configs/O2MNT_defconfig index 859ba73..fa8d0ad 100644 --- a/configs/O2MNT_defconfig +++ b/configs/O2MNT_defconfig @@ -11,5 +11,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O3DNT_defconfig b/configs/O3DNT_defconfig index c4f2f69..3bc637b 100644 --- a/configs/O3DNT_defconfig +++ b/configs/O3DNT_defconfig @@ -11,5 +11,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index ccece01..6faad87 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -16,5 +16,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index febdcd0..0224ee7 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -18,5 +18,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 229448f..52b0e58 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -19,6 +19,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/PLU405_defconfig b/configs/PLU405_defconfig index fe26fed..9ee7dbd 100644 --- a/configs/PLU405_defconfig +++ b/configs/PLU405_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_MAC_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/PMC440_defconfig b/configs/PMC440_defconfig index 8c4454e..53e331b 100644 --- a/configs/PMC440_defconfig +++ b/configs/PMC440_defconfig @@ -17,6 +17,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index 9ac8912..54c975a 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -15,6 +15,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index 26b119a..12b8f47 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -17,6 +17,8 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_DFU=y # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set CONFIG_DFU_RAM=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index 267aaf8..dbff234 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -11,6 +11,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_ALDO2_VOLT=1800 diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index d15ac20..aec3f7d 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -19,6 +19,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DCDC5_VOLT=1200 CONFIG_AXP_DLDO3_VOLT=2500 CONFIG_AXP_SW_ON=y diff --git a/configs/TQM5200S_HIGHBOOT_defconfig b/configs/TQM5200S_HIGHBOOT_defconfig index df873ee..b54c494 100644 --- a/configs/TQM5200S_HIGHBOOT_defconfig +++ b/configs/TQM5200S_HIGHBOOT_defconfig @@ -17,6 +17,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200S_defconfig b/configs/TQM5200S_defconfig index 2a59758..20106bc 100644 --- a/configs/TQM5200S_defconfig +++ b/configs/TQM5200S_defconfig @@ -17,6 +17,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_B_HIGHBOOT_defconfig b/configs/TQM5200_B_HIGHBOOT_defconfig index 73ff161..520f89e 100644 --- a/configs/TQM5200_B_HIGHBOOT_defconfig +++ b/configs/TQM5200_B_HIGHBOOT_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CONSOLE_EXTRA_INFO=y diff --git a/configs/TQM5200_B_defconfig b/configs/TQM5200_B_defconfig index c0d5c4b..6856043 100644 --- a/configs/TQM5200_B_defconfig +++ b/configs/TQM5200_B_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CONSOLE_EXTRA_INFO=y diff --git a/configs/TQM5200_STK100_defconfig b/configs/TQM5200_STK100_defconfig index 5868912..31e1506 100644 --- a/configs/TQM5200_STK100_defconfig +++ b/configs/TQM5200_STK100_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CONSOLE_EXTRA_INFO=y diff --git a/configs/TQM5200_defconfig b/configs/TQM5200_defconfig index 9d0e915..10dd8aa 100644 --- a/configs/TQM5200_defconfig +++ b/configs/TQM5200_defconfig @@ -19,6 +19,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CONSOLE_EXTRA_INFO=y diff --git a/configs/TQM823L_LCD_defconfig b/configs/TQM823L_LCD_defconfig index 0c6b2d9..de4d51b 100644 --- a/configs/TQM823L_LCD_defconfig +++ b/configs/TQM823L_LCD_defconfig @@ -12,6 +12,8 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM823L_defconfig b/configs/TQM823L_defconfig index 7081ed6..aa99a9e 100644 --- a/configs/TQM823L_defconfig +++ b/configs/TQM823L_defconfig @@ -10,5 +10,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM823M_defconfig b/configs/TQM823M_defconfig index 496dc06..d98bc3b 100644 --- a/configs/TQM823M_defconfig +++ b/configs/TQM823M_defconfig @@ -10,5 +10,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM850L_defconfig b/configs/TQM850L_defconfig index 0f711d1..3d70c18 100644 --- a/configs/TQM850L_defconfig +++ b/configs/TQM850L_defconfig @@ -10,5 +10,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM850M_defconfig b/configs/TQM850M_defconfig index 7a72ce9..731b49a 100644 --- a/configs/TQM850M_defconfig +++ b/configs/TQM850M_defconfig @@ -10,5 +10,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM855L_defconfig b/configs/TQM855L_defconfig index b034a04..4791204 100644 --- a/configs/TQM855L_defconfig +++ b/configs/TQM855L_defconfig @@ -10,5 +10,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM855M_defconfig b/configs/TQM855M_defconfig index 05b4518..49b9c5f 100644 --- a/configs/TQM855M_defconfig +++ b/configs/TQM855M_defconfig @@ -10,5 +10,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM860L_defconfig b/configs/TQM860L_defconfig index 5d8a088..25e2551 100644 --- a/configs/TQM860L_defconfig +++ b/configs/TQM860L_defconfig @@ -10,5 +10,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM860M_defconfig b/configs/TQM860M_defconfig index 023751d..fb7b327 100644 --- a/configs/TQM860M_defconfig +++ b/configs/TQM860M_defconfig @@ -10,5 +10,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM862L_defconfig b/configs/TQM862L_defconfig index 628d687..40aaec2 100644 --- a/configs/TQM862L_defconfig +++ b/configs/TQM862L_defconfig @@ -10,5 +10,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM862M_defconfig b/configs/TQM862M_defconfig index d1cf91c..172edc1 100644 --- a/configs/TQM862M_defconfig +++ b/configs/TQM862M_defconfig @@ -10,5 +10,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM866M_defconfig b/configs/TQM866M_defconfig index e0cf770..bad4137 100644 --- a/configs/TQM866M_defconfig +++ b/configs/TQM866M_defconfig @@ -10,5 +10,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM885D_defconfig b/configs/TQM885D_defconfig index 889de7b..d0061c4 100644 --- a/configs/TQM885D_defconfig +++ b/configs/TQM885D_defconfig @@ -13,5 +13,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TTTech_defconfig b/configs/TTTech_defconfig index 97e4330..c941eb4 100644 --- a/configs/TTTech_defconfig +++ b/configs/TTTech_defconfig @@ -12,6 +12,8 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/UTOO_P66_defconfig b/configs/UTOO_P66_defconfig index 205c9e2..c957b8b 100644 --- a/configs/UTOO_P66_defconfig +++ b/configs/UTOO_P66_defconfig @@ -24,5 +24,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/Wexler_TAB7200_defconfig b/configs/Wexler_TAB7200_defconfig index ecde5db..b889f69 100644 --- a/configs/Wexler_TAB7200_defconfig +++ b/configs/Wexler_TAB7200_defconfig @@ -17,5 +17,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index 0735055..6385a79 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -17,5 +17,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Wobo_i5_defconfig b/configs/Wobo_i5_defconfig index 907afe5..1b7e807 100644 --- a/configs/Wobo_i5_defconfig +++ b/configs/Wobo_i5_defconfig @@ -11,6 +11,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig index 1e42a68..1e8e751 100644 --- a/configs/Yones_Toptech_BD1078_defconfig +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -23,4 +23,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/Yones_Toptech_BS1078_V2_defconfig b/configs/Yones_Toptech_BS1078_V2_defconfig index 958104e..3cbf41e 100644 --- a/configs/Yones_Toptech_BS1078_V2_defconfig +++ b/configs/Yones_Toptech_BS1078_V2_defconfig @@ -19,5 +19,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/a4m072_defconfig b/configs/a4m072_defconfig index f68b966..a701a2a 100644 --- a/configs/a4m072_defconfig +++ b/configs/a4m072_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/acadia_defconfig b/configs/acadia_defconfig index 790d8a9..f7dbd71 100644 --- a/configs/acadia_defconfig +++ b/configs/acadia_defconfig @@ -15,6 +15,8 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index afef344..15e30ef 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -44,6 +44,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/am335x_igep0033_defconfig b/configs/am335x_igep0033_defconfig index 6149beb..1130e2c 100644 --- a/configs/am335x_igep0033_defconfig +++ b/configs/am335x_igep0033_defconfig @@ -38,5 +38,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 9b73f46..7a362d8 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -32,5 +32,9 @@ CONFIG_AUTOBOOT_STOP_STR="noautoboot" CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index ff70580..8f2cc16 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -32,5 +32,9 @@ CONFIG_AUTOBOOT_STOP_STR="noautoboot" CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index 520d17c..5374b93 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -33,5 +33,9 @@ CONFIG_AUTOBOOT_STOP_STR="noautoboot" CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_prompt_defconfig b/configs/am335x_shc_prompt_defconfig index d6cc315..20631eb 100644 --- a/configs/am335x_shc_prompt_defconfig +++ b/configs/am335x_shc_prompt_defconfig @@ -30,5 +30,9 @@ CONFIG_AUTOBOOT_STOP_STR="noautoboot" CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index b4e36b5..f22ea55 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -32,5 +32,9 @@ CONFIG_AUTOBOOT_STOP_STR="noautoboot" CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_sdboot_prompt_defconfig b/configs/am335x_shc_sdboot_prompt_defconfig index b4e36b5..f22ea55 100644 --- a/configs/am335x_shc_sdboot_prompt_defconfig +++ b/configs/am335x_shc_sdboot_prompt_defconfig @@ -32,5 +32,9 @@ CONFIG_AUTOBOOT_STOP_STR="noautoboot" CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 291f570..8e7c255 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_PARTITION_UUIDS=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 00f186a..2d7101b 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" CONFIG_DM=y diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index 7090fd1..1095af5 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -32,6 +32,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index a3f3abd..1251b99 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -27,6 +27,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 6a881dd..08b7bcd 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -37,6 +37,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" CONFIG_DM=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 60b2122..e3dd438 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -37,6 +37,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DM=y # CONFIG_BLK is not set diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index a582055..5cb7fda 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -47,6 +47,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am572x-idk am571x-idk" CONFIG_DM=y diff --git a/configs/am57xx_evm_nodt_defconfig b/configs/am57xx_evm_nodt_defconfig index 7e08b0a..ab46152 100644 --- a/configs/am57xx_evm_nodt_defconfig +++ b/configs/am57xx_evm_nodt_defconfig @@ -38,6 +38,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 4dcfce4..5fce0cb 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -50,6 +50,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DM=y # CONFIG_BLK is not set diff --git a/configs/ap121_defconfig b/configs/ap121_defconfig index d21fa04..e9c82ce 100644 --- a/configs/ap121_defconfig +++ b/configs/ap121_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_SPI=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +# CONFIG_ISO_PARTITION is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/ap143_defconfig b/configs/ap143_defconfig index 5bb9350..2bb7884 100644 --- a/configs/ap143_defconfig +++ b/configs/ap143_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_SPI=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +# CONFIG_ISO_PARTITION is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/ap325rxa_defconfig b/configs/ap325rxa_defconfig index 818eb41..8256eca 100644 --- a/configs/ap325rxa_defconfig +++ b/configs/ap325rxa_defconfig @@ -19,4 +19,5 @@ CONFIG_VERSION_VARIABLE=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index 691148c..843c04a 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -20,6 +20,9 @@ CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/arches_defconfig b/configs/arches_defconfig index 88bf4df..694cf59 100644 --- a/configs/arches_defconfig +++ b/configs/arches_defconfig @@ -17,5 +17,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_SYS_NS16550=y diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index c60766c..c9a9e8e 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -14,5 +14,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/bamboo_defconfig b/configs/bamboo_defconfig index 54b8380..6f1db7a 100644 --- a/configs/bamboo_defconfig +++ b/configs/bamboo_defconfig @@ -19,6 +19,8 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI_PNP is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 63d17b1..ecd93ce 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -37,6 +37,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/bcm11130_defconfig b/configs/bcm11130_defconfig index bf2f1f7..28e399e 100644 --- a/configs/bcm11130_defconfig +++ b/configs/bcm11130_defconfig @@ -18,6 +18,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_KONA=y diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index 7df4a52..61caa9b 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -18,6 +18,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_KONA=y diff --git a/configs/bcm23550_w1d_defconfig b/configs/bcm23550_w1d_defconfig index 4c7709c..73c238e 100644 --- a/configs/bcm23550_w1d_defconfig +++ b/configs/bcm23550_w1d_defconfig @@ -24,6 +24,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_KONA=y diff --git a/configs/bcm28155_ap_defconfig b/configs/bcm28155_ap_defconfig index 3325a4d..e3cdf98 100644 --- a/configs/bcm28155_ap_defconfig +++ b/configs/bcm28155_ap_defconfig @@ -25,6 +25,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_KONA=y diff --git a/configs/bcm28155_w1d_defconfig b/configs/bcm28155_w1d_defconfig index b161d38..aa5216e 100644 --- a/configs/bcm28155_w1d_defconfig +++ b/configs/bcm28155_w1d_defconfig @@ -19,6 +19,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_KONA=y diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 5cb73c0..0365246 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -22,6 +22,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 319c3e2..c1a638b 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 5e1af1c..84237ee 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -43,6 +43,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_SPI_FLASH=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index f3771bb..38e059c 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -43,6 +43,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_SPI_FLASH=y diff --git a/configs/boston32r2_defconfig b/configs/boston32r2_defconfig index 6df5429..09e08c1 100644 --- a/configs/boston32r2_defconfig +++ b/configs/boston32r2_defconfig @@ -27,6 +27,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y diff --git a/configs/boston32r2el_defconfig b/configs/boston32r2el_defconfig index 8f8cb5f..3646683 100644 --- a/configs/boston32r2el_defconfig +++ b/configs/boston32r2el_defconfig @@ -28,6 +28,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y diff --git a/configs/boston64r2_defconfig b/configs/boston64r2_defconfig index 3c70f95..62350e5 100644 --- a/configs/boston64r2_defconfig +++ b/configs/boston64r2_defconfig @@ -28,6 +28,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y diff --git a/configs/boston64r2el_defconfig b/configs/boston64r2el_defconfig index b2f53dd..d620200 100644 --- a/configs/boston64r2el_defconfig +++ b/configs/boston64r2el_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index 67d6b61..e9ffb52 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -28,5 +28,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/cam5200_defconfig b/configs/cam5200_defconfig index 3bf1aa7..2d24e2f 100644 --- a/configs/cam5200_defconfig +++ b/configs/cam5200_defconfig @@ -14,5 +14,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/cam5200_niosflash_defconfig b/configs/cam5200_niosflash_defconfig index 602988e..fb59b3b 100644 --- a/configs/cam5200_niosflash_defconfig +++ b/configs/cam5200_niosflash_defconfig @@ -14,5 +14,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/canyonlands_defconfig b/configs/canyonlands_defconfig index fb1f9ec..b7fd0c8 100644 --- a/configs/canyonlands_defconfig +++ b/configs/canyonlands_defconfig @@ -21,6 +21,8 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SYS_NS16550=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index 0214758..77dac78 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -20,6 +20,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index 909b367..88b93cb 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -22,6 +22,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/charon_defconfig b/configs/charon_defconfig index 67d22b6..95801d7 100644 --- a/configs/charon_defconfig +++ b/configs/charon_defconfig @@ -19,6 +19,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CONSOLE_EXTRA_INFO=y diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index 9203f73..841b42d 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -31,6 +31,11 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 95e5f57..4cd9bc7 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -32,6 +32,11 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 8407731..06642fd 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -32,6 +32,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index 49cd640..1a03a40 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -32,6 +32,11 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index e08dffc..d9ad68c 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -32,6 +32,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index f8cf92b..5400cc1 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -29,6 +29,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/cl-som-am57x_defconfig b/configs/cl-som-am57x_defconfig index 9eadf42..219ebee 100644 --- a/configs/cl-som-am57x_defconfig +++ b/configs/cl-som-am57x_defconfig @@ -23,6 +23,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index 4587807..418994e 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPL_OF_TRANSLATE=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y diff --git a/configs/cm5200_defconfig b/configs/cm5200_defconfig index b09f31f..a3b0013 100644 --- a/configs/cm5200_defconfig +++ b/configs/cm5200_defconfig @@ -15,6 +15,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 36905fd..84891c0 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -35,5 +35,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 2d78841..dd3d8cc 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -41,6 +41,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_SPI_FLASH=y diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index e002e1c..5717e6e 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index a543246..9dff1a3 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -23,6 +23,9 @@ CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_UBI=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index 2ab6764..f412e28 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -20,6 +20,9 @@ CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/colorfly_e708_q1_defconfig b/configs/colorfly_e708_q1_defconfig index ae67c37..c0ed30e 100644 --- a/configs/colorfly_e708_q1_defconfig +++ b/configs/colorfly_e708_q1_defconfig @@ -19,6 +19,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_DLDO2_VOLT=1800 CONFIG_USB_MUSB_HOST=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index 812f516..7f8a9c3 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -38,6 +38,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index cff6cc2..3185097 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -37,6 +37,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig index d71e6af..446d4d9 100644 --- a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TPM=y +CONFIG_DOS_PARTITION=y CONFIG_DM=y # CONFIG_PCI is not set CONFIG_SYS_NS16550=y diff --git a/configs/controlcenterd_TRAILBLAZER_defconfig b/configs/controlcenterd_TRAILBLAZER_defconfig index 5c7f2c9..d6b98ed 100644 --- a/configs/controlcenterd_TRAILBLAZER_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TPM=y +CONFIG_DOS_PARTITION=y CONFIG_DM=y # CONFIG_PCI is not set CONFIG_SYS_NS16550=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 2195fc6..2bbd041 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -24,6 +24,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 233fe09..0a1f9c4 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -21,6 +21,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 784c1b3..4f4ae49 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -29,6 +29,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index 87686aa..421e286 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -20,6 +20,9 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index 0db2d1d..8aae0e1 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -22,6 +22,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig index 20539d1..8b72e58 100644 --- a/configs/db-88f6720_defconfig +++ b/configs/db-88f6720_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_DOS_PARTITION is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_MISC=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 5543be8..592f2e2 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPL_OF_TRANSLATE=y CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index bcc3128..4fa74dc 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -31,6 +31,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPL_OF_TRANSLATE=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index ffd9c50..a25e40a 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -32,6 +32,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPL_OF_TRANSLATE=y CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y diff --git a/configs/dbau1000_defconfig b/configs/dbau1000_defconfig index 996e2f7..80b5ea4 100644 --- a/configs/dbau1000_defconfig +++ b/configs/dbau1000_defconfig @@ -12,3 +12,5 @@ CONFIG_SYS_PROMPT="DbAu1xx0 # " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_MAC_PARTITION=y +# CONFIG_ISO_PARTITION is not set diff --git a/configs/dbau1100_defconfig b/configs/dbau1100_defconfig index 2b3ccd8..dad02e4 100644 --- a/configs/dbau1100_defconfig +++ b/configs/dbau1100_defconfig @@ -12,3 +12,5 @@ CONFIG_SYS_PROMPT="DbAu1xx0 # " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_MAC_PARTITION=y +# CONFIG_ISO_PARTITION is not set diff --git a/configs/dbau1500_defconfig b/configs/dbau1500_defconfig index 7459c63..26f6da0 100644 --- a/configs/dbau1500_defconfig +++ b/configs/dbau1500_defconfig @@ -12,3 +12,5 @@ CONFIG_SYS_PROMPT="DbAu1xx0 # " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_MAC_PARTITION=y +# CONFIG_ISO_PARTITION is not set diff --git a/configs/dbau1550_defconfig b/configs/dbau1550_defconfig index 964d8a8..0a10367 100644 --- a/configs/dbau1550_defconfig +++ b/configs/dbau1550_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_PROMPT="DbAu1xx0 # " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +# CONFIG_ISO_PARTITION is not set diff --git a/configs/dbau1550_el_defconfig b/configs/dbau1550_el_defconfig index dfe0102..7d50000 100644 --- a/configs/dbau1550_el_defconfig +++ b/configs/dbau1550_el_defconfig @@ -10,3 +10,4 @@ CONFIG_SYS_PROMPT="DbAu1xx0 # " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +# CONFIG_ISO_PARTITION is not set diff --git a/configs/devconcenter_defconfig b/configs/devconcenter_defconfig index 6ce8786..55f3d0a 100644 --- a/configs/devconcenter_defconfig +++ b/configs/devconcenter_defconfig @@ -23,6 +23,8 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index e603310..63d43de 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -18,5 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index b7eb006..0fa9887 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -36,6 +36,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/difrnce_dit4350_defconfig b/configs/difrnce_dit4350_defconfig index 6149c94..045f87c 100644 --- a/configs/difrnce_dit4350_defconfig +++ b/configs/difrnce_dit4350_defconfig @@ -20,4 +20,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index 3a31a66..8b7bf9a 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 2b13f00..0e2e18c 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 64fe038..3128b1b 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -47,6 +47,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm" CONFIG_DM=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index b890a06..43fd616 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -52,6 +52,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm" CONFIG_DM=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 0cb4412..2ab9359 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y CONFIG_CMD_UBI=y +# CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DFU_NAND=y diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index cb15755..23034f2 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 94d3c74..b5ecc12 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -11,6 +11,8 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index 502d6f8..82f91f4 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/dserve_dsrv9703c_defconfig b/configs/dserve_dsrv9703c_defconfig index ebcfe58..99fcbe3 100644 --- a/configs/dserve_dsrv9703c_defconfig +++ b/configs/dserve_dsrv9703c_defconfig @@ -18,4 +18,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index 33e70ee..3d9f597 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +# CONFIG_EFI_PARTITION is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/edb9315a_defconfig b/configs/edb9315a_defconfig index 9e8c6bb..35dab61 100644 --- a/configs/edb9315a_defconfig +++ b/configs/edb9315a_defconfig @@ -15,5 +15,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y +# CONFIG_DOS_PARTITION is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index df054d6..121eae9 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_EXT2=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index 1fe6142..962e021 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -21,6 +21,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DM_PCI=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 8fb6ebd..9a18909 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y CONFIG_CMD_UBI=y +# CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DFU_NAND=y diff --git a/configs/evb-rk3036_defconfig b/configs/evb-rk3036_defconfig index 6546db9..48fc1fb 100644 --- a/configs/evb-rk3036_defconfig +++ b/configs/evb-rk3036_defconfig @@ -23,6 +23,11 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index e5e550c..cfa5197 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -31,6 +31,11 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_REGMAP=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 6c27104..512ce1f 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -16,6 +16,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index eff5e15..092caf5 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -31,6 +31,11 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_REGMAP=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 4910c80..59c4b83 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -29,6 +29,11 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y diff --git a/configs/fo300_defconfig b/configs/fo300_defconfig index dd2f965..9cbc987 100644 --- a/configs/fo300_defconfig +++ b/configs/fo300_defconfig @@ -21,6 +21,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index 02a8a78..358a139 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -21,6 +21,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index 7da870f..3220933 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -32,6 +32,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y diff --git a/configs/ge_b450v3_defconfig b/configs/ge_b450v3_defconfig index 6550c9e..03e60a3 100644 --- a/configs/ge_b450v3_defconfig +++ b/configs/ge_b450v3_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FS_GENERIC=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/ge_b650v3_defconfig b/configs/ge_b650v3_defconfig index 7cf1899..974745c 100644 --- a/configs/ge_b650v3_defconfig +++ b/configs/ge_b650v3_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FS_GENERIC=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/ge_b850v3_defconfig b/configs/ge_b850v3_defconfig index 63025bc..4a13b34 100644 --- a/configs/ge_b850v3_defconfig +++ b/configs/ge_b850v3_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FS_GENERIC=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/glacier_defconfig b/configs/glacier_defconfig index 0343128..bb734f4 100644 --- a/configs/glacier_defconfig +++ b/configs/glacier_defconfig @@ -18,6 +18,9 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_CACHE=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SYS_NS16550=y diff --git a/configs/glacier_ramboot_defconfig b/configs/glacier_ramboot_defconfig index 31c9d0b..b1551d6 100644 --- a/configs/glacier_ramboot_defconfig +++ b/configs/glacier_ramboot_defconfig @@ -19,6 +19,9 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_CACHE=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SYS_NS16550=y diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 57a4c78..240c859 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/gplugd_defconfig b/configs/gplugd_defconfig index 3b22e6c..57bb432 100644 --- a/configs/gplugd_defconfig +++ b/configs/gplugd_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index 913a763..d7c2bb7 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -20,5 +20,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index 765f4e7..ce1e2f6 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -16,6 +16,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_PARTITION_UUIDS=y CONFIG_OF_CONTROL=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 73a1213..0d7d67e 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/h8_homlet_v2_defconfig b/configs/h8_homlet_v2_defconfig index 76dd833..368233a 100644 --- a/configs/h8_homlet_v2_defconfig +++ b/configs/h8_homlet_v2_defconfig @@ -14,6 +14,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index d8712d5..6163353 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -18,6 +18,9 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set diff --git a/configs/highbank_defconfig b/configs/highbank_defconfig index b1c8afd..5300fa3 100644 --- a/configs/highbank_defconfig +++ b/configs/highbank_defconfig @@ -20,4 +20,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_OF_LIBFDT=y diff --git a/configs/hrcon_defconfig b/configs/hrcon_defconfig index 4e92019..8c25cb8 100644 --- a/configs/hrcon_defconfig +++ b/configs/hrcon_defconfig @@ -18,5 +18,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/hrcon_dh_defconfig b/configs/hrcon_dh_defconfig index d7c9ee1..ed020c4 100644 --- a/configs/hrcon_dh_defconfig +++ b/configs/hrcon_dh_defconfig @@ -16,5 +16,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index 8012c07..8c35fe6 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -11,5 +11,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/iNet_3F_defconfig b/configs/iNet_3F_defconfig index 052454d..6e28c5b 100644 --- a/configs/iNet_3F_defconfig +++ b/configs/iNet_3F_defconfig @@ -18,4 +18,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/iNet_3W_defconfig b/configs/iNet_3W_defconfig index 03d7ec9..02eb34f 100644 --- a/configs/iNet_3W_defconfig +++ b/configs/iNet_3W_defconfig @@ -18,4 +18,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/iNet_86VS_defconfig b/configs/iNet_86VS_defconfig index 1901125..091b7e1 100644 --- a/configs/iNet_86VS_defconfig +++ b/configs/iNet_86VS_defconfig @@ -17,4 +17,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/iNet_D978_rev2_defconfig b/configs/iNet_D978_rev2_defconfig index d5e6309..b2febab 100644 --- a/configs/iNet_D978_rev2_defconfig +++ b/configs/iNet_D978_rev2_defconfig @@ -21,6 +21,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 9c95b47..38c716f9 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 78cc3bb..567eb9b 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -18,5 +18,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index d869628..b78737c 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index c25b6b8..ab6dfde 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -32,6 +32,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/imgtec_xilfpga_defconfig b/configs/imgtec_xilfpga_defconfig index 1e57273..02969da 100644 --- a/configs/imgtec_xilfpga_defconfig +++ b/configs/imgtec_xilfpga_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +# CONFIG_ISO_PARTITION is not set CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y diff --git a/configs/inet1_defconfig b/configs/inet1_defconfig index 4fcd2d4..9393db0 100644 --- a/configs/inet1_defconfig +++ b/configs/inet1_defconfig @@ -18,5 +18,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/inet86dz_defconfig b/configs/inet86dz_defconfig index 4ed94dc..c7753b3 100644 --- a/configs/inet86dz_defconfig +++ b/configs/inet86dz_defconfig @@ -20,5 +20,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/inet97fv2_defconfig b/configs/inet97fv2_defconfig index bef3cd8..496c2fe 100644 --- a/configs/inet97fv2_defconfig +++ b/configs/inet97fv2_defconfig @@ -17,4 +17,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/inet98v_rev2_defconfig b/configs/inet98v_rev2_defconfig index 7c306f8..e25859e 100644 --- a/configs/inet98v_rev2_defconfig +++ b/configs/inet98v_rev2_defconfig @@ -20,4 +20,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/inet9f_rev03_defconfig b/configs/inet9f_rev03_defconfig index cc051bd..815648e 100644 --- a/configs/inet9f_rev03_defconfig +++ b/configs/inet9f_rev03_defconfig @@ -17,4 +17,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/inet_q972_defconfig b/configs/inet_q972_defconfig index dcaaae4..d436005 100644 --- a/configs/inet_q972_defconfig +++ b/configs/inet_q972_defconfig @@ -18,6 +18,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index bbe20a1..5af916e 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -20,6 +20,9 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/inka4x0_defconfig b/configs/inka4x0_defconfig index cf21cfb..15383a2 100644 --- a/configs/inka4x0_defconfig +++ b/configs/inka4x0_defconfig @@ -11,5 +11,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/intip_defconfig b/configs/intip_defconfig index c929277..01bc79d 100644 --- a/configs/intip_defconfig +++ b/configs/intip_defconfig @@ -25,6 +25,8 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 6e4e6ca..c009fff 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -12,5 +12,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index b0aa3c7..58d4184 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -22,6 +22,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/jupiter_defconfig b/configs/jupiter_defconfig index 1558ab1..26942ff 100644 --- a/configs/jupiter_defconfig +++ b/configs/jupiter_defconfig @@ -6,4 +6,7 @@ CONFIG_BOOTDELAY=5 CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_SNTP=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 835d0c9..57eff54 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -35,6 +35,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 97f7187..7ffa225 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DM=y # CONFIG_BLK is not set diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 34defa8..85d7710 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -35,6 +35,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 75bcd9f..ce0e2a4 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -35,6 +35,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/kc1_defconfig b/configs/kc1_defconfig index 76226e9..1fa61a5 100644 --- a/configs/kc1_defconfig +++ b/configs/kc1_defconfig @@ -23,6 +23,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/kmcoge4_defconfig b/configs/kmcoge4_defconfig index 9b3061c..af3b9cc 100644 --- a/configs/kmcoge4_defconfig +++ b/configs/kmcoge4_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmlion1_defconfig b/configs/kmlion1_defconfig index 6f18dbc..190fe45 100644 --- a/configs/kmlion1_defconfig +++ b/configs/kmlion1_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index a4281c9..94787bb 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -24,6 +24,11 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/ls1012afrdm_qspi_defconfig b/configs/ls1012afrdm_qspi_defconfig index 9b2ca4f..a92b935 100644 --- a/configs/ls1012afrdm_qspi_defconfig +++ b/configs/ls1012afrdm_qspi_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/ls1021aiot_qspi_defconfig b/configs/ls1021aiot_qspi_defconfig index 21464cb..dcc683e 100644 --- a/configs/ls1021aiot_qspi_defconfig +++ b/configs/ls1021aiot_qspi_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AIOT=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-iot-duart" CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" +CONFIG_DOS_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index 1369fe6..6531aee 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 +CONFIG_DOS_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls2080a_emu_defconfig b/configs/ls2080a_emu_defconfig index 2d20c28..a515569 100644 --- a/configs/ls2080a_emu_defconfig +++ b/configs/ls2080a_emu_defconfig @@ -23,6 +23,10 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +# CONFIG_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +# CONFIG_PARTITION_UUIDS is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls2080a_simu_defconfig b/configs/ls2080a_simu_defconfig index 5a72bd4..1729981 100644 --- a/configs/ls2080a_simu_defconfig +++ b/configs/ls2080a_simu_defconfig @@ -23,6 +23,9 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +# CONFIG_PARTITION_UUIDS is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index b443be3..06abc65 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -15,6 +15,9 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +# CONFIG_PARTITION_UUIDS is not set CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index d26f1b6..3f97544 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -15,6 +15,9 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +# CONFIG_PARTITION_UUIDS is not set CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 91b3b57..c3651a1 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -23,6 +23,9 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +# CONFIG_PARTITION_UUIDS is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 803d3bb..6010255 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -15,6 +15,9 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +# CONFIG_PARTITION_UUIDS is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index b6d95e9..2d94a82 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -22,6 +22,9 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index 1da81b9..75bd46d 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +# CONFIG_PARTITION_UUIDS is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index dab49e7..bb10cf8 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -21,6 +21,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/malta64_defconfig b/configs/malta64_defconfig index 4308b4f..4d118f5 100644 --- a/configs/malta64_defconfig +++ b/configs/malta64_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_PROMPT="malta # " CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y +# CONFIG_ISO_PARTITION is not set CONFIG_OF_EMBED=y CONFIG_PCI=y CONFIG_SYS_NS16550=y diff --git a/configs/malta64el_defconfig b/configs/malta64el_defconfig index b3b1401..8b602f7 100644 --- a/configs/malta64el_defconfig +++ b/configs/malta64el_defconfig @@ -13,6 +13,7 @@ CONFIG_SYS_PROMPT="maltael # " CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y +# CONFIG_ISO_PARTITION is not set CONFIG_OF_EMBED=y CONFIG_PCI=y CONFIG_SYS_NS16550=y diff --git a/configs/malta_defconfig b/configs/malta_defconfig index f1c8118..a3b237c 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_PROMPT="malta # " CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y +# CONFIG_ISO_PARTITION is not set CONFIG_OF_EMBED=y CONFIG_PCI=y CONFIG_SYS_NS16550=y diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index 88012c7..15aaf8d 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_PROMPT="maltael # " CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y +# CONFIG_ISO_PARTITION is not set CONFIG_OF_EMBED=y CONFIG_PCI=y CONFIG_SYS_NS16550=y diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index a65c3ad..a811506 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -19,6 +19,9 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set diff --git a/configs/miniarm-rk3288_defconfig b/configs/miniarm-rk3288_defconfig index 1e273a6..ac2c80b 100644 --- a/configs/miniarm-rk3288_defconfig +++ b/configs/miniarm-rk3288_defconfig @@ -31,6 +31,11 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_REGMAP=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index f7ac94d..6a0a2f7 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -37,6 +37,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 8ca8467..ec6a438 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -12,6 +12,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/mk802_a10s_defconfig b/configs/mk802_a10s_defconfig index bfd591a..18ed3d4 100644 --- a/configs/mk802_a10s_defconfig +++ b/configs/mk802_a10s_defconfig @@ -11,5 +11,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index 47bbf62..0bd957b 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -9,5 +9,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/mk802ii_defconfig b/configs/mk802ii_defconfig index f9516d1..10ff960 100644 --- a/configs/mk802ii_defconfig +++ b/configs/mk802ii_defconfig @@ -8,4 +8,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_EHCI_HCD=y diff --git a/configs/mpc5121ads_defconfig b/configs/mpc5121ads_defconfig index fff0e9b..be10c32 100644 --- a/configs/mpc5121ads_defconfig +++ b/configs/mpc5121ads_defconfig @@ -14,6 +14,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mpc5121ads_rev2_defconfig b/configs/mpc5121ads_rev2_defconfig index 4007351..81ea470 100644 --- a/configs/mpc5121ads_rev2_defconfig +++ b/configs/mpc5121ads_rev2_defconfig @@ -15,6 +15,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/ms7720se_defconfig b/configs/ms7720se_defconfig index a02760a..c19c56b 100644 --- a/configs/ms7720se_defconfig +++ b/configs/ms7720se_defconfig @@ -23,4 +23,5 @@ CONFIG_VERSION_VARIABLE=y CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index 0605174..3f90322 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -27,6 +27,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_BLOCK_CACHE=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y diff --git a/configs/mvebu_db-88f7040_defconfig b/configs/mvebu_db-88f7040_defconfig index 8dc455a..39ebe39 100644 --- a/configs/mvebu_db-88f7040_defconfig +++ b/configs/mvebu_db-88f7040_defconfig @@ -30,6 +30,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_BLOCK_CACHE=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/mvebu_db-88f8040_defconfig b/configs/mvebu_db-88f8040_defconfig index 4a43e73..05ee2ae 100644 --- a/configs/mvebu_db-88f8040_defconfig +++ b/configs/mvebu_db-88f8040_defconfig @@ -30,6 +30,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_BLOCK_CACHE=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/mx35pdk_defconfig b/configs/mx35pdk_defconfig index c44681f..a65fd7a 100644 --- a/configs/mx35pdk_defconfig +++ b/configs/mx35pdk_defconfig @@ -15,6 +15,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/nanopi_neo_defconfig b/configs/nanopi_neo_defconfig index 5164245..89f5687 100644 --- a/configs/nanopi_neo_defconfig +++ b/configs/nanopi_neo_defconfig @@ -11,5 +11,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 9d42a03..249a884 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -18,6 +18,9 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 0fb0cde..f022ff6 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -20,6 +20,9 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 72f761a..e9a8132 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -20,6 +20,9 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 3eb1188..2251894 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -20,6 +20,9 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 16f544c..b33e929 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -19,6 +19,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 5b5954b..7ce4b62 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -20,6 +20,9 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index 7233354..9d6fd58 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index e6f862d..63f1a6f 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -27,6 +27,9 @@ CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig index 7d0b2b1..b146733 100644 --- a/configs/odroid-c2_defconfig +++ b/configs/odroid-c2_defconfig @@ -15,6 +15,10 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_ETH=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index e12208c..13597fd 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DFU_MMC=y CONFIG_DM_I2C_COMPAT=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 6ca7e2c..e4e3a08 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -19,6 +19,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index ac1a6a3..d8e8d2d 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index b902283..877b851 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -31,6 +31,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index e7f8fd0..436a28e 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -24,5 +24,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index 18843d2..7e88e5d 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -27,6 +27,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_SYS_NS16550=y diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index 0168579..067ddbc 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index 84fa149..b90ead1 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index 026204d..2bc8ace 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/orangepi_2_defconfig b/configs/orangepi_2_defconfig index 4727aca..74712c6 100644 --- a/configs/orangepi_2_defconfig +++ b/configs/orangepi_2_defconfig @@ -13,6 +13,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_lite_defconfig b/configs/orangepi_lite_defconfig index 8545835..38f4583 100644 --- a/configs/orangepi_lite_defconfig +++ b/configs/orangepi_lite_defconfig @@ -11,4 +11,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_one_defconfig b/configs/orangepi_one_defconfig index 01b4ece..56c9a87 100644 --- a/configs/orangepi_one_defconfig +++ b/configs/orangepi_one_defconfig @@ -11,5 +11,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_pc_defconfig b/configs/orangepi_pc_defconfig index 910d68e..8d331bd 100644 --- a/configs/orangepi_pc_defconfig +++ b/configs/orangepi_pc_defconfig @@ -12,6 +12,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_pc_plus_defconfig b/configs/orangepi_pc_plus_defconfig index f43682b..636599c 100644 --- a/configs/orangepi_pc_plus_defconfig +++ b/configs/orangepi_pc_plus_defconfig @@ -13,6 +13,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_plus2e_defconfig b/configs/orangepi_plus2e_defconfig index df05d37..60f4eaa 100644 --- a/configs/orangepi_plus2e_defconfig +++ b/configs/orangepi_plus2e_defconfig @@ -14,6 +14,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index bf88fef..78be69e 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -15,6 +15,9 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/origen_defconfig b/configs/origen_defconfig index 0dcc9e8..2d23ffa 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -27,6 +27,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DFU_MMC=y CONFIG_MMC_SDHCI=y diff --git a/configs/parrot_r16_defconfig b/configs/parrot_r16_defconfig index ffe15e5..616992d 100644 --- a/configs/parrot_r16_defconfig +++ b/configs/parrot_r16_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index b3d6f90..0ad0974 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -18,6 +18,9 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set diff --git a/configs/pb1000_defconfig b/configs/pb1000_defconfig index 5a7fa80..a84a434 100644 --- a/configs/pb1000_defconfig +++ b/configs/pb1000_defconfig @@ -14,3 +14,4 @@ CONFIG_SYS_PROMPT="Pb1x00 # " CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_ISO_PARTITION is not set diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index bc6e92d..3ffbbb3 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -42,6 +42,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index acdf192..7721509 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -42,6 +42,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index b2f70ea..8a268d4 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -36,6 +36,9 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_DM=y CONFIG_MTD=y CONFIG_SPI_FLASH=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 2da2126..e3d249c 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -42,6 +42,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index 0592ed9..fa139ea 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -34,5 +34,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/pic32mzdask_defconfig b/configs/pic32mzdask_defconfig index 852eb0a..90a0d32 100644 --- a/configs/pic32mzdask_defconfig +++ b/configs/pic32mzdask_defconfig @@ -21,6 +21,8 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_RARP=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_BLK is not set diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 3c45b9d..0c6c65e 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -18,6 +18,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index b98093e..fbf4d3e 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/polaroid_mid2407pxe03_defconfig b/configs/polaroid_mid2407pxe03_defconfig index 2ac6f4c..3beba97 100644 --- a/configs/polaroid_mid2407pxe03_defconfig +++ b/configs/polaroid_mid2407pxe03_defconfig @@ -20,5 +20,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/polaroid_mid2809pxe04_defconfig b/configs/polaroid_mid2809pxe04_defconfig index d9bcd4f..bbf2819 100644 --- a/configs/polaroid_mid2809pxe04_defconfig +++ b/configs/polaroid_mid2809pxe04_defconfig @@ -20,5 +20,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index 663724e..d00d9d1 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -31,6 +31,11 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_REGMAP=y diff --git a/configs/pov_protab2_ips9_defconfig b/configs/pov_protab2_ips9_defconfig index 8e81e69..0905ad0 100644 --- a/configs/pov_protab2_ips9_defconfig +++ b/configs/pov_protab2_ips9_defconfig @@ -18,4 +18,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/q8_a13_tablet_defconfig b/configs/q8_a13_tablet_defconfig index 6b516db..af094f1 100644 --- a/configs/q8_a13_tablet_defconfig +++ b/configs/q8_a13_tablet_defconfig @@ -20,4 +20,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index 971dcea..5ad67d7 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -20,5 +20,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index f99e347..0e3bc13 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -20,5 +20,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index 182bd9a..b5b7782 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -20,5 +20,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index 6413567..4ed526c 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_GREPENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 4566d37..db88be3 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -28,6 +28,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index f580d45..a96a0ad 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -25,6 +25,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index 975714b..6bfc479 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -26,6 +26,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/qemu_mips64_defconfig b/configs/qemu_mips64_defconfig index b013a17..a345a34 100644 --- a/configs/qemu_mips64_defconfig +++ b/configs/qemu_mips64_defconfig @@ -11,4 +11,5 @@ CONFIG_CMD_RARP=y CONFIG_CMD_DHCP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_ISO_PARTITION is not set CONFIG_SYS_NS16550=y diff --git a/configs/qemu_mips64el_defconfig b/configs/qemu_mips64el_defconfig index bffa1a3..2f3cc95 100644 --- a/configs/qemu_mips64el_defconfig +++ b/configs/qemu_mips64el_defconfig @@ -12,4 +12,5 @@ CONFIG_CMD_RARP=y CONFIG_CMD_DHCP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_ISO_PARTITION is not set CONFIG_SYS_NS16550=y diff --git a/configs/qemu_mips_defconfig b/configs/qemu_mips_defconfig index 9cab7dd..5995b3e 100644 --- a/configs/qemu_mips_defconfig +++ b/configs/qemu_mips_defconfig @@ -9,4 +9,5 @@ CONFIG_SYS_PROMPT="qemu-mips # " CONFIG_CMD_DHCP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_ISO_PARTITION is not set CONFIG_SYS_NS16550=y diff --git a/configs/qemu_mipsel_defconfig b/configs/qemu_mipsel_defconfig index b9226a8..bb1679b 100644 --- a/configs/qemu_mipsel_defconfig +++ b/configs/qemu_mipsel_defconfig @@ -10,4 +10,5 @@ CONFIG_SYS_PROMPT="qemu-mipsel # " CONFIG_CMD_DHCP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_ISO_PARTITION is not set CONFIG_SYS_NS16550=y diff --git a/configs/r2dplus_defconfig b/configs/r2dplus_defconfig index 2637723..291c887 100644 --- a/configs/r2dplus_defconfig +++ b/configs/r2dplus_defconfig @@ -5,6 +5,7 @@ CONFIG_BOOTDELAY=-1 CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_NETDEVICES=y CONFIG_RTL8139=y CONFIG_PCI=y diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index afbc9a6..e5c305f 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -10,5 +10,8 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/r7780mp_defconfig b/configs/r7780mp_defconfig index 77d9c06..fccaf05 100644 --- a/configs/r7780mp_defconfig +++ b/configs/r7780mp_defconfig @@ -20,5 +20,6 @@ CONFIG_BOOTDELAY=3 CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_PCI=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/rainier_defconfig b/configs/rainier_defconfig index c76b7b9..0bf3812 100644 --- a/configs/rainier_defconfig +++ b/configs/rainier_defconfig @@ -18,5 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/rainier_ramboot_defconfig b/configs/rainier_ramboot_defconfig index 7bb948d..a94b237 100644 --- a/configs/rainier_ramboot_defconfig +++ b/configs/rainier_ramboot_defconfig @@ -18,5 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index d3ac645..76e84b7 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y CONFIG_CMD_UBI=y +# CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DFU_NAND=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 9e332bc..eb78ae9 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -30,6 +30,11 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_ISO_PARTITION=y +# CONFIG_SPL_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent" CONFIG_REGMAP=y diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index cb04a3f..b441f69 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DM_I2C_GPIO=y CONFIG_MMC_SDHCI=y diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index b6cefb1..685472d 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -27,6 +27,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DFU_MMC=y CONFIG_MMC_SDHCI=y diff --git a/configs/salvator-x_defconfig b/configs/salvator-x_defconfig index bf8f7c7..d1f53db 100644 --- a/configs/salvator-x_defconfig +++ b/configs/salvator-x_defconfig @@ -12,3 +12,4 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_DOS_PARTITION=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 8ac231d..6f0d459 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -50,6 +50,11 @@ CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_MAC_PARTITION=y +# CONFIG_ISO_PARTITION is not set +CONFIG_AMIGA_PARTITION=y +# CONFIG_EFI_PARTITION is not set +# CONFIG_PARTITION_UUIDS is not set CONFIG_OF_CONTROL=y CONFIG_OF_HOSTFILE=y CONFIG_NETCONSOLE=y diff --git a/configs/sandbox_noblk_defconfig b/configs/sandbox_noblk_defconfig index a9456cc..89e44b3 100644 --- a/configs/sandbox_noblk_defconfig +++ b/configs/sandbox_noblk_defconfig @@ -57,6 +57,11 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_AMIGA_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_OF_CONTROL=y CONFIG_OF_HOSTFILE=y CONFIG_NETCONSOLE=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index f4b656c..dbe7b37 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -57,6 +57,12 @@ CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_MAC_PARTITION=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +CONFIG_AMIGA_PARTITION=y +# CONFIG_EFI_PARTITION is not set +# CONFIG_PARTITION_UUIDS is not set CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_HOSTFILE=y diff --git a/configs/sbc8641d_defconfig b/configs/sbc8641d_defconfig index 24305da..97b4c4f 100644 --- a/configs/sbc8641d_defconfig +++ b/configs/sbc8641d_defconfig @@ -10,5 +10,6 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_DOS_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index c3119dc..3e5549c 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -18,6 +18,9 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set diff --git a/configs/sequoia_defconfig b/configs/sequoia_defconfig index 33261b8..ff20dd5 100644 --- a/configs/sequoia_defconfig +++ b/configs/sequoia_defconfig @@ -19,6 +19,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/sequoia_ramboot_defconfig b/configs/sequoia_ramboot_defconfig index 000be91..8fc2735 100644 --- a/configs/sequoia_ramboot_defconfig +++ b/configs/sequoia_ramboot_defconfig @@ -19,6 +19,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/sh7752evb_defconfig b/configs/sh7752evb_defconfig index ae5e038..0978f25 100644 --- a/configs/sh7752evb_defconfig +++ b/configs/sh7752evb_defconfig @@ -25,6 +25,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/sh7753evb_defconfig b/configs/sh7753evb_defconfig index f8b9d86..7073047 100644 --- a/configs/sh7753evb_defconfig +++ b/configs/sh7753evb_defconfig @@ -24,6 +24,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/sh7757lcr_defconfig b/configs/sh7757lcr_defconfig index b12c11e..8291865 100644 --- a/configs/sh7757lcr_defconfig +++ b/configs/sh7757lcr_defconfig @@ -25,6 +25,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/sh7785lcr_32bit_defconfig b/configs/sh7785lcr_32bit_defconfig index 7d8a230..6d1f334 100644 --- a/configs/sh7785lcr_32bit_defconfig +++ b/configs/sh7785lcr_32bit_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y CONFIG_PCI=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/sh7785lcr_defconfig b/configs/sh7785lcr_defconfig index c9c9b08..02c0bd2 100644 --- a/configs/sh7785lcr_defconfig +++ b/configs/sh7785lcr_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y CONFIG_PCI=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index e15355d..63973eb 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index eab598e..7b53ca1 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DFU_NAND=y diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index a75a1f0..6c1702b 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -22,6 +22,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_S5P=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index 6f55503..37569da 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -24,6 +24,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index a3ba8c1..24a60eb 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -34,6 +34,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/strider_con_defconfig b/configs/strider_con_defconfig index 6ab1f51..115fe89 100644 --- a/configs/strider_con_defconfig +++ b/configs/strider_con_defconfig @@ -20,5 +20,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/strider_con_dp_defconfig b/configs/strider_con_dp_defconfig index 71193d0..1857cd1 100644 --- a/configs/strider_con_dp_defconfig +++ b/configs/strider_con_dp_defconfig @@ -20,5 +20,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/strider_cpu_defconfig b/configs/strider_cpu_defconfig index 61963be..b1afa45 100644 --- a/configs/strider_cpu_defconfig +++ b/configs/strider_cpu_defconfig @@ -20,5 +20,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/strider_cpu_dp_defconfig b/configs/strider_cpu_dp_defconfig index 560dc65..0ca8590 100644 --- a/configs/strider_cpu_dp_defconfig +++ b/configs/strider_cpu_dp_defconfig @@ -20,5 +20,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sunxi_Gemei_G9_defconfig b/configs/sunxi_Gemei_G9_defconfig index 7309022..cec147f 100644 --- a/configs/sunxi_Gemei_G9_defconfig +++ b/configs/sunxi_Gemei_G9_defconfig @@ -15,4 +15,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_EHCI_HCD=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 793de29..47e4c43 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_DFU=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +# CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DFU_NAND=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 9fefa5f..2b3edd1 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y CONFIG_DM=y CONFIG_PCI=y CONFIG_DM_THERMAL=y diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index f52f19b..cd9b507 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -21,6 +21,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 1ccec73..1dd8a1e 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -19,6 +19,9 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index f3c2c86..47b6c5b 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -36,6 +36,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index b97c128..47d863f 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -38,6 +38,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_GPIO=y diff --git a/configs/theadorable_defconfig b/configs/theadorable_defconfig index 3c2e140..c19443a 100644 --- a/configs/theadorable_defconfig +++ b/configs/theadorable_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_GPIO=y CONFIG_SPI_FLASH=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 7e1b63b..bffa231 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y CONFIG_CMD_UBI=y +# CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DFU_NAND=y diff --git a/configs/tplink_wdr4300_defconfig b/configs/tplink_wdr4300_defconfig index 8d8908d..438b2b1 100644 --- a/configs/tplink_wdr4300_defconfig +++ b/configs/tplink_wdr4300_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +# CONFIG_ISO_PARTITION is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index 9e88201..ea0fa9d 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DFU_MMC=y CONFIG_MMC_SDHCI=y diff --git a/configs/trats_defconfig b/configs/trats_defconfig index 92cf3f7..da590cb 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DFU_MMC=y CONFIG_MMC_SDHCI=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index a145ff8..455f4b2 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -20,6 +20,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index 2788ac9..d5707ab 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -27,4 +27,6 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_LIBFDT=y diff --git a/configs/update.sh b/configs/update.sh new file mode 100644 index 0000000..3bcaffe --- /dev/null +++ b/configs/update.sh @@ -0,0 +1,15 @@ +for f in ls *_defconfig +do + +echo "processing $f" + +for s in $(cat ~/toto.txt) +do +val=$(grep $s $f | wc -l) +if [ "$val" = "0" ]; then +echo "# $s is not set" >> $f +echo "check $s => $f updated" +fi +done + +done diff --git a/configs/v38b_defconfig b/configs/v38b_defconfig index fb198b6..e6b1fba 100644 --- a/configs/v38b_defconfig +++ b/configs/v38b_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y # CONFIG_PCI is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/vct_platinum_onenand_small_defconfig b/configs/vct_platinum_onenand_small_defconfig index 50d2619..0e4964b 100644 --- a/configs/vct_platinum_onenand_small_defconfig +++ b/configs/vct_platinum_onenand_small_defconfig @@ -21,4 +21,5 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set CONFIG_CMD_UBI=y +# CONFIG_ISO_PARTITION is not set CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinum_small_defconfig b/configs/vct_platinum_small_defconfig index b22401c..1eb4c13 100644 --- a/configs/vct_platinum_small_defconfig +++ b/configs/vct_platinum_small_defconfig @@ -17,4 +17,5 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set +# CONFIG_ISO_PARTITION is not set CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinumavc_defconfig b/configs/vct_platinumavc_defconfig index 9778dc3..c0fc268 100644 --- a/configs/vct_platinumavc_defconfig +++ b/configs/vct_platinumavc_defconfig @@ -9,4 +9,5 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_NET is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +# CONFIG_ISO_PARTITION is not set CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinumavc_onenand_defconfig b/configs/vct_platinumavc_onenand_defconfig index ee3b400..d690e19 100644 --- a/configs/vct_platinumavc_onenand_defconfig +++ b/configs/vct_platinumavc_onenand_defconfig @@ -13,4 +13,5 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_UBI=y +# CONFIG_ISO_PARTITION is not set CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinumavc_onenand_small_defconfig b/configs/vct_platinumavc_onenand_small_defconfig index 8fb374d..5b443cf 100644 --- a/configs/vct_platinumavc_onenand_small_defconfig +++ b/configs/vct_platinumavc_onenand_small_defconfig @@ -21,4 +21,5 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set CONFIG_CMD_UBI=y +# CONFIG_ISO_PARTITION is not set CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinumavc_small_defconfig b/configs/vct_platinumavc_small_defconfig index 8046c32..aa0df38 100644 --- a/configs/vct_platinumavc_small_defconfig +++ b/configs/vct_platinumavc_small_defconfig @@ -17,4 +17,5 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set +# CONFIG_ISO_PARTITION is not set CONFIG_SYS_NS16550=y diff --git a/configs/vct_premium_onenand_small_defconfig b/configs/vct_premium_onenand_small_defconfig index 023f22f..8eca0a5 100644 --- a/configs/vct_premium_onenand_small_defconfig +++ b/configs/vct_premium_onenand_small_defconfig @@ -21,4 +21,5 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set CONFIG_CMD_UBI=y +# CONFIG_ISO_PARTITION is not set CONFIG_SYS_NS16550=y diff --git a/configs/vct_premium_small_defconfig b/configs/vct_premium_small_defconfig index 18d8b42..ed8ffb6 100644 --- a/configs/vct_premium_small_defconfig +++ b/configs/vct_premium_small_defconfig @@ -17,4 +17,5 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set +# CONFIG_ISO_PARTITION is not set CONFIG_SYS_NS16550=y diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index 8ff879f..1b0e646 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -22,6 +22,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index 1f2809a..486861b 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -17,6 +17,9 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set diff --git a/configs/vexpress_aemv8a_dram_defconfig b/configs/vexpress_aemv8a_dram_defconfig index 9fa1095..c899be0 100644 --- a/configs/vexpress_aemv8a_dram_defconfig +++ b/configs/vexpress_aemv8a_dram_defconfig @@ -22,6 +22,9 @@ CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +# CONFIG_PARTITION_UUIDS is not set CONFIG_DM=y CONFIG_DM_SERIAL=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index ae0a691..2267362 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -22,6 +22,9 @@ CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +# CONFIG_PARTITION_UUIDS is not set CONFIG_DM=y CONFIG_DM_SERIAL=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index 97505da..02740a4 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -22,6 +22,9 @@ CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +# CONFIG_PARTITION_UUIDS is not set CONFIG_DM=y CONFIG_DM_SERIAL=y CONFIG_OF_LIBFDT=y diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 34a02bd..f8e605d 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/vining_2000_defconfig b/configs/vining_2000_defconfig index 9410703..95415a8 100644 --- a/configs/vining_2000_defconfig +++ b/configs/vining_2000_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y CONFIG_PCI=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 66c1f16..cde769a 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_PARTITION_UUIDS=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DFU_MMC=y CONFIG_USB=y diff --git a/configs/warp7_secure_defconfig b/configs/warp7_secure_defconfig index c12fc01..06972de 100644 --- a/configs/warp7_secure_defconfig +++ b/configs/warp7_secure_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_PARTITION_UUIDS=y CONFIG_DFU_MMC=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/whistler_defconfig b/configs/whistler_defconfig index b7c3ed9..6c27b36 100644 --- a/configs/whistler_defconfig +++ b/configs/whistler_defconfig @@ -18,6 +18,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index aa5d587..55370cc 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -15,3 +15,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index 085c2df..23bba19 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -25,3 +25,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index a705e8b..1c28544 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_DOS_PARTITION=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_DM_GPIO=y diff --git a/configs/wtk_defconfig b/configs/wtk_defconfig index fa2eea0..f1e9e2b 100644 --- a/configs/wtk_defconfig +++ b/configs/wtk_defconfig @@ -12,6 +12,8 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y # CONFIG_PCI is not set CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index ef7bf8b..a735401 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_ISO_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 0663e16..e48a439 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_ISO_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index d0b19f4..dac22b6 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_ISO_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index 7c75abb..817d066 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_ISO_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index 401c0d6..9d15846 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_ISO_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SPL_DM=y diff --git a/configs/xilinx_zynqmp_zcu102_defconfig b/configs/xilinx_zynqmp_zcu102_defconfig index 71ada10..1db35d2 100644 --- a/configs/xilinx_zynqmp_zcu102_defconfig +++ b/configs/xilinx_zynqmp_zcu102_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_ISO_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 64aa32f..47dcdab 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_ISO_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/yellowstone_defconfig b/configs/yellowstone_defconfig index c26c844..f3394a0 100644 --- a/configs/yellowstone_defconfig +++ b/configs/yellowstone_defconfig @@ -16,6 +16,9 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_MAC_PARTITION=y +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI_PNP is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/yosemite_defconfig b/configs/yosemite_defconfig index c77cd22..0e8ac18 100644 --- a/configs/yosemite_defconfig +++ b/configs/yosemite_defconfig @@ -19,6 +19,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y # CONFIG_PCI_PNP is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/disk/Kconfig b/disk/Kconfig new file mode 100644 index 0000000..7d0b7af --- /dev/null +++ b/disk/Kconfig @@ -0,0 +1,103 @@ + +menu "Partition Types" + +config PARTITIONS + bool "Enable Partition Labels (disklabels) support" + default y + help + Partition Labels (disklabels) Supported: + Zero or more of the following: + - CONFIG_MAC_PARTITION Apple's MacOS partition table. + - CONFIG_DOS_PARTITION MS Dos partition table, traditional on the + Intel architecture, USB sticks, etc. + - CONFIG_ISO_PARTITION ISO partition table, used on CDROM etc. + - CONFIG_EFI_PARTITION GPT partition table, common when EFI is the + bootloader. Note 2TB partition limit; see + disk/part_efi.c + - CONFIG_MTD_PARTITIONS Memory Technology Device partition table. + If IDE or SCSI support is enabled (CONFIG_CMD_IDE or CONFIG_SCSI) + you must configure support for at least one non-MTD partition type + as well. + +config MAC_PARTITION + bool "Enable Apple's MacOS partition table" + depends on PARTITIONS + default y if SPARC + help + Say Y here if you would like to use device under U-Boot which + were partitioned on a Macintosh. + +config SPL_MAC_PARTITION + bool "Enable Apple's MacOS partition table for SPL" + depends on SPL && PARTITIONS + default y if MAC_PARTITION + +config DOS_PARTITION + bool "Enable MS Dos partition table" + depends on PARTITIONS + default y if DISTRO_DEFAULTS + default y if x86 || SPARC || CMD_FAT || USB_STORAGE + help + traditional on the Intel architecture, USB sticks, etc. + +config SPL_DOS_PARTITION + bool "Enable MS Dos partition table for SPL" + depends on SPL && PARTITIONS + default y if DOS_PARTITION + +config ISO_PARTITION + bool "Enable ISO partition table" + depends on PARTITIONS + default y if DISTRO_DEFAULTS + default y if SPARC || MIPS || TEGRA + +config SPL_ISO_PARTITION + bool "Enable ISO partition table for SPL" + depends on SPL && PARTITIONS + default y if ISO_PARTITION + +config AMIGA_PARTITION + bool "Enable AMIGA partition table" + depends on PARTITIONS + help + Say Y here if you would like to use device under U-Boot which + were partitioned under AmigaOS. + +config SPL_AMIGA_PARTITION + bool "Enable AMIGA partition table for SPL" + depends on SPL && PARTITIONS + default y if AMIGA_PARTITION + +config EFI_PARTITION + bool "Enable EFI GPT partition table" + depends on PARTITIONS + default y if DISTRO_DEFAULTS + default y if TEGRA + help + Say Y here if you would like to use device under U-Boot which + were partitioned using EFI GPT. + common when EFI is the bootloader. Note 2TB partition limit; + see disk/part_efi.c + +config SPL_EFI_PARTITION + bool "Enable EFI GPT partition table for SPL" + depends on SPL && PARTITIONS + default y if EFI_PARTITION + +config PARTITION_UUIDS + bool "Enable support of UUID for partition" + depends on PARTITIONS + default y if DISTRO_DEFAULTS + default y if EFI_PARTITION + help + Activate the configuration of UUID for partition + +config PARTITION_TYPE_GUID + bool "Enable support of GUID for partition type" + depends on PARTITIONS + depends on EFI_PARTITION + help + Activate the configuration of GUID type + for EFI partition + +endmenu diff --git a/disk/Makefile b/disk/Makefile index 6970cec..523e34d 100644 --- a/disk/Makefile +++ b/disk/Makefile @@ -7,9 +7,9 @@
#ccflags-y += -DET_DEBUG -DDEBUG
-obj-$(CONFIG_PARTITIONS) += part.o -obj-$(CONFIG_MAC_PARTITION) += part_mac.o -obj-$(CONFIG_DOS_PARTITION) += part_dos.o -obj-$(CONFIG_ISO_PARTITION) += part_iso.o -obj-$(CONFIG_AMIGA_PARTITION) += part_amiga.o -obj-$(CONFIG_EFI_PARTITION) += part_efi.o +obj-$(CONFIG_PARTITIONS) += part.o +obj-$(CONFIG_$(SPL_)MAC_PARTITION) += part_mac.o +obj-$(CONFIG_$(SPL_)DOS_PARTITION) += part_dos.o +obj-$(CONFIG_$(SPL_)ISO_PARTITION) += part_iso.o +obj-$(CONFIG_$(SPL_)AMIGA_PARTITION) += part_amiga.o +obj-$(CONFIG_$(SPL_)EFI_PARTITION) += part_efi.o diff --git a/disk/part.c b/disk/part.c index 4e37735..cd14e98 100644 --- a/disk/part.c +++ b/disk/part.c @@ -234,11 +234,11 @@ void part_init(struct blk_desc *dev_desc)
static void print_part_header(const char *type, struct blk_desc *dev_desc) { -#if defined(CONFIG_MAC_PARTITION) || \ - defined(CONFIG_DOS_PARTITION) || \ - defined(CONFIG_ISO_PARTITION) || \ - defined(CONFIG_AMIGA_PARTITION) || \ - defined(CONFIG_EFI_PARTITION) +#if CONFIG_IS_ENABLED(MAC_PARTITION) || \ + CONFIG_IS_ENABLED(DOS_PARTITION) || \ + CONFIG_IS_ENABLED(ISO_PARTITION) || \ + CONFIG_IS_ENABLED(AMIGA_PARTITION) || \ + CONFIG_IS_ENABLED(EFI_PARTITION) puts ("\nPartition Map for "); switch (dev_desc->if_type) { case IF_TYPE_IDE: diff --git a/disk/part_amiga.h b/disk/part_amiga.h index 0f04e97..a3fe1a9 100644 --- a/disk/part_amiga.h +++ b/disk/part_amiga.h @@ -10,7 +10,7 @@ #define _DISK_PART_AMIGA_H #include <common.h>
-#ifdef CONFIG_ISO_PARTITION +#if CONFIG_IS_ENABLED(ISO_PARTITION) /* Make the buffers bigger if ISO partition support is enabled -- CD-ROMS have 2048 byte blocks */ #define DEFAULT_SECTOR_SIZE 2048 diff --git a/disk/part_efi.c b/disk/part_efi.c index 1924338..f1b7116 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -171,7 +171,7 @@ static void prepare_backup_gpt_header(gpt_header *gpt_h) gpt_h->header_crc32 = cpu_to_le32(calc_crc32); }
-#ifdef CONFIG_EFI_PARTITION +#if CONFIG_IS_ENABLED(EFI_PARTITION) /* * Public Functions (include/part.h) */ diff --git a/disk/part_mac.h b/disk/part_mac.h index 7b754e1..6735144 100644 --- a/disk/part_mac.h +++ b/disk/part_mac.h @@ -73,7 +73,7 @@ typedef struct mac_partition { __u32 boot_cksum; /* boot code checksum */ uchar processor[16]; /* Type of Processor */ __u16 part_pad[188]; /* reserved */ -#ifdef CONFIG_ISO_PARTITION +#if CONFIG_IS_ENABLED(ISO_PARTITION) uchar iso_dummy[2048];/* Reservere enough room for an ISO partition block to fit */ #endif } mac_partition_t; diff --git a/include/config_defaults.h b/include/config_defaults.h index ad08c1d..7ef928b 100644 --- a/include/config_defaults.h +++ b/include/config_defaults.h @@ -18,6 +18,5 @@
#define CONFIG_GZIP 1 #define CONFIG_ZLIB 1 -#define CONFIG_PARTITIONS 1
#endif diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index 9ecaf38..e946d10 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -27,7 +27,6 @@ */
/* We need the part command */ -#define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART
#define BOOTENV_SHARED_BLKDEV_BODY(devtypel) \ diff --git a/include/config_distro_defaults.h b/include/config_distro_defaults.h index f2e87ee..41bbfb9 100644 --- a/include/config_distro_defaults.h +++ b/include/config_distro_defaults.h @@ -23,9 +23,6 @@ #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_LONGHELP -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION -#define CONFIG_ISO_PARTITION #define CONFIG_SUPPORT_RAW_INITRD #define CONFIG_ENV_VARS_UBOOT_CONFIG
diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index 3800932..a1562c8 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -57,6 +57,7 @@
#if (defined(CONFIG_PARTITION_UUIDS) || \ defined(CONFIG_EFI_PARTITION) || \ + defined(CONFIG_SPL_EFI_PARTITION) || \ defined(CONFIG_RANDOM_UUID) || \ defined(CONFIG_CMD_UUID) || \ defined(CONFIG_BOOTP_PXE)) && \ diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 3ad9f80..fc99b96 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -675,7 +675,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_PCI_INDIRECT_BRIDGE
#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_DOS_PARTITION #endif /* CONFIG_PCI */
#ifdef CONFIG_FMAN_ENET diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index a6f73f2..761457d 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -301,7 +301,6 @@ extern unsigned long get_sdram_size(void); */ #define CONFIG_CMD_ERRATA #define CONFIG_CMD_IRQ -#define CONFIG_DOS_PARTITION #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 8aec315..1e6907d 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -97,7 +97,6 @@ #define CONFIG_SYS_PCIE1_IO_PHYS 0xC0010000
#define CONFIG_ENV_OVERWRITE @@ -479,7 +478,6 @@ combinations. this should be removed later #endif /* CONFIG_TSEC_ENET */
#ifdef CONFIG_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_FSL_ESDHC #define CONFIG_GENERIC_MMC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR @@ -536,10 +534,6 @@ combinations. this should be removed later #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO
-#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) -#define CONFIG_DOS_PARTITION -#endif - /* Hash command with SHA acceleration supported in hardware */ #ifdef CONFIG_FSL_CAAM #define CONFIG_CMD_HASH diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 53ee98c..e1ce7ad 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -97,7 +97,6 @@ #define CONFIG_SYS_PCIE1_IO_PHYS 0xfffc00000ull
#define CONFIG_TSEC_ENET diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index fb6e0ef..e9ca80f 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -70,9 +70,6 @@ #define CONFIG_CMD_BSP #define CONFIG_CMD_EEPROM
-#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - #define CONFIG_SUPPORT_VFAT
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/M52277EVB.h b/include/configs/M52277EVB.h index 6230948..98ccbe3 100644 --- a/include/configs/M52277EVB.h +++ b/include/configs/M52277EVB.h @@ -92,9 +92,6 @@ /* USB */ #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION #define CONFIG_SYS_USB_EHCI_REGS_BASE 0xFC0B0000 #define CONFIG_SYS_USB_EHCI_CPU_INIT #endif diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index 6c90700..2733457 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -42,8 +42,6 @@
#ifdef CONFIG_CMD_IDE /* ATA */ -# define CONFIG_DOS_PARTITION -# define CONFIG_MAC_PARTITION # define CONFIG_IDE_RESET 1 # define CONFIG_IDE_PREINIT 1 # define CONFIG_ATAPI diff --git a/include/configs/M5253EVBE.h b/include/configs/M5253EVBE.h index faad970..5cba541 100644 --- a/include/configs/M5253EVBE.h +++ b/include/configs/M5253EVBE.h @@ -50,8 +50,6 @@ #define CONFIG_CMD_IDE
/* ATA */ -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION #define CONFIG_IDE_RESET 1 #define CONFIG_IDE_PREINIT 1 #define CONFIG_ATAPI diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index abec373..0eed59e 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -119,8 +119,6 @@ #endif
/* ATA configuration */ -#define CONFIG_ISO_PARTITION -#define CONFIG_DOS_PARTITION #define CONFIG_IDE_RESET 1 #define CONFIG_IDE_PREINIT 1 #define CONFIG_ATAPI diff --git a/include/configs/M5475EVB.h b/include/configs/M5475EVB.h index 3b40cd0..f10c3f0 100644 --- a/include/configs/M5475EVB.h +++ b/include/configs/M5475EVB.h @@ -75,7 +75,6 @@ # define CONFIG_CMD_PCI # endif # define CONFIG_PCI_OHCI -# define CONFIG_DOS_PARTITION
# undef CONFIG_SYS_USB_OHCI_BOARD_INIT # undef CONFIG_SYS_USB_OHCI_CPU_INIT diff --git a/include/configs/M5485EVB.h b/include/configs/M5485EVB.h index 2c18e98..2ae8d25 100644 --- a/include/configs/M5485EVB.h +++ b/include/configs/M5485EVB.h @@ -69,7 +69,6 @@ #endif
#ifdef CONFIG_CMD_USB -# define CONFIG_DOS_PARTITION # define CONFIG_USB_OHCI_NEW # ifndef CONFIG_CMD_PCI # define CONFIG_CMD_PCI diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index f7fc652..952ee4a 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -327,9 +327,6 @@ /************************************************************ * DISK Partition support ************************************************************/ -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION /* Experimental */
/************************************************************ * Video support diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 7107a47..f833450 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_FSL_ESDHC_USE_PIO
#define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index bd25c0b..1d6be41 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -418,7 +418,6 @@ #ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 5f7eca0..fcc1a73 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -487,7 +487,6 @@ boards, we say we have two, but don't display a message if we find only one. */
#if defined(CONFIG_COMPACT_FLASH) || defined(CONFIG_SATA_SIL3114) \ || defined(CONFIG_USB_STORAGE) - #define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_VFAT #endif
diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index f86b008..40f1d4a 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -439,7 +439,6 @@ extern int board_pci_host_broken(void); #ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
/* @@ -488,7 +487,6 @@ extern int board_pci_host_broken(void); #define CONFIG_FSL_ESDHC_PIN_MUX #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC83xx_ESDHC_ADDR #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index d843bd1..6be81c3 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -451,7 +451,6 @@ #ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
/* @@ -500,7 +499,6 @@ #define CONFIG_FSL_ESDHC_PIN_MUX #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC83xx_ESDHC_ADDR #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index ce33405..5feff76 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -526,7 +526,6 @@ #ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
#if defined(CONFIG_TSEC_ENET) @@ -622,10 +621,6 @@ #endif #endif
-#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) -#define CONFIG_DOS_PARTITION -#endif - /* * Miscellaneous configurable options */ diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index b9c62e1..5d76996 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -282,7 +282,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #endif
#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_DOS_PARTITION #define CONFIG_SCSI_AHCI
#ifdef CONFIG_SCSI_AHCI diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 3e00f69..0746166 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -465,7 +465,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_FSL_ESDHC_PIN_MUX #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 5ca01e8..b933d21 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -471,7 +471,6 @@ #endif
#ifdef CONFIG_SCSI_AHCI diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index c5f3634..8946f36 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -286,7 +286,6 @@ #define PCI_IDSEL_NUMBER 0x0c /* slot0->3(IDSEL)=12->15 */ #endif
#ifdef CONFIG_SCSI_AHCI diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index fb66bb6..0e5bbc0 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -374,7 +374,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */
#ifdef CONFIG_SCSI_AHCI diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index cd9cd9a..2fbc995 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -193,7 +193,6 @@ #endif
#define CONFIG_TSEC_ENET @@ -670,7 +669,6 @@ extern unsigned long get_sdram_size(void); #endif /* #ifdef CONFIG_FSL_SATA */
#ifdef CONFIG_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_FSL_ESDHC #define CONFIG_GENERIC_MMC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR @@ -745,7 +743,6 @@ extern unsigned long get_sdram_size(void);
#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) \ || defined(CONFIG_FSL_SATA) -#define CONFIG_DOS_PARTITION #endif
/* Hash command with SHA acceleration supported in hardware */ diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 505b417..b4f8670 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -501,7 +501,6 @@ #ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
#ifdef CONFIG_MMC @@ -510,10 +509,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #endif
-#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) -#define CONFIG_DOS_PARTITION -#endif - #define CONFIG_TSEC_ENET #ifdef CONFIG_TSEC_ENET
diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index d8ff10e..4d48412 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -260,7 +260,6 @@ extern unsigned long get_clock_freq(void); #ifdef CONFIG_USB_EHCI #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_FSL -#define CONFIG_DOS_PARTITION #endif #endif
diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 3cd5c3c..2b0b6d7 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -534,7 +534,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_PCI_INDIRECT_BRIDGE
/* SATA */ @@ -554,7 +553,6 @@ unsigned long get_board_sys_clk(unsigned long dummy);
#ifdef CONFIG_FMAN_ENET @@ -610,7 +608,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* Hash command with SHA acceleration supported in hardware */ diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 3dcb6ac..f14ab47 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -287,9 +287,6 @@ /************************************************************ * DISK Partition support ************************************************************/ -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION /* Experimental */
/************************************************************ * Video support diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index 0967577..6797f18 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -64,9 +64,6 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index 2e7f6e4..731560f 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -259,9 +259,6 @@ #define USB_2_0_DEVICE
/* Partitions */ -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION -#define CONFIG_ISO_PARTITION
#define CONFIG_CMD_BSP #define CONFIG_CMD_DATE diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index c9a1334..0643ba5 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -623,7 +623,6 @@ unsigned long get_board_ddr_clk(void); #endif
/* @@ -639,7 +638,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
/* @@ -660,7 +658,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* Qman/Bman */ diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 36eba4e..ce9e2c3 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -642,7 +642,6 @@ unsigned long get_board_ddr_clk(void); #endif
/* @@ -663,7 +662,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* Qman/Bman */ diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 8d6d986..2be9411 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -507,7 +507,6 @@ unsigned long get_board_ddr_clk(void); #endif
/* SATA */ @@ -526,7 +525,6 @@ unsigned long get_board_ddr_clk(void);
/* @@ -548,7 +546,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_FSL_ESDHC_ADAPTER_IDENT #endif
diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index d574bbb..a231aac 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -621,7 +621,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #endif
/* SATA */ @@ -637,7 +636,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg
/* @@ -658,7 +656,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* Qman/Bman */ diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 210d8d8..606c928 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -591,7 +591,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_PCI_INDIRECT_BRIDGE #define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_DOS_PARTITION #endif
/* Qman/Bman */ @@ -702,7 +701,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
/* @@ -724,7 +722,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_FSL_ESDHC_ADAPTER_IDENT #endif
diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 1941188..825bf25 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -529,7 +529,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_PCI_INDIRECT_BRIDGE #define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata LSZ ADD */ #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_DOS_PARTITION #endif
/* Qman/Bman */ @@ -652,7 +651,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
/* @@ -673,7 +671,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 78ad86c..91aa12d 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -493,7 +493,6 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_FMAN_ENET @@ -521,7 +520,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_ESDHC_DETECT_QUIRK \ (!(readb(QIXIS_BASE + QIXIS_BRDCFG5) & QIXIS_MUX_SDHC) || \ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index e15b0ea..be18f66 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -241,7 +241,6 @@ #define CONFIG_PCI_INDIRECT_BRIDGE
/* SATA */ @@ -259,7 +258,6 @@
#ifdef CONFIG_FMAN_ENET @@ -681,7 +679,6 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_FMAN_ENET @@ -703,7 +700,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #endif
diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 708eb76..6d30268 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -108,9 +108,6 @@ #endif /* #ifndef CONFIG_TQM5200S */
/* USB */ #if defined(CONFIG_CHARON) || defined(CONFIG_FO300) || \ diff --git a/include/configs/TQM823L.h b/include/configs/TQM823L.h index 2fd5fa3..5f21338 100644 --- a/include/configs/TQM823L.h +++ b/include/configs/TQM823L.h @@ -93,9 +93,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
-#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - #define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */
/* diff --git a/include/configs/TQM823M.h b/include/configs/TQM823M.h index 11bba09..46518a1 100644 --- a/include/configs/TQM823M.h +++ b/include/configs/TQM823M.h @@ -91,9 +91,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM850L.h b/include/configs/TQM850L.h index 548f1bc..114b63a 100644 --- a/include/configs/TQM850L.h +++ b/include/configs/TQM850L.h @@ -82,9 +82,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM850M.h b/include/configs/TQM850M.h index 582b934..e51f145 100644 --- a/include/configs/TQM850M.h +++ b/include/configs/TQM850M.h @@ -82,9 +82,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM855L.h b/include/configs/TQM855L.h index 814290f..04a58d5 100644 --- a/include/configs/TQM855L.h +++ b/include/configs/TQM855L.h @@ -84,9 +84,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM855M.h b/include/configs/TQM855M.h index 4a657ff..e121052 100644 --- a/include/configs/TQM855M.h +++ b/include/configs/TQM855M.h @@ -113,9 +113,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM860L.h b/include/configs/TQM860L.h index bdfe509..3af079f 100644 --- a/include/configs/TQM860L.h +++ b/include/configs/TQM860L.h @@ -84,9 +84,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index ce6b404..3f566a6 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -84,9 +84,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM862L.h b/include/configs/TQM862L.h index 66dbcb6..3e40107 100644 --- a/include/configs/TQM862L.h +++ b/include/configs/TQM862L.h @@ -87,9 +87,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM862M.h b/include/configs/TQM862M.h index 478f16b..b66b7f0 100644 --- a/include/configs/TQM862M.h +++ b/include/configs/TQM862M.h @@ -87,9 +87,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM866M.h b/include/configs/TQM866M.h index 5501622..89e109c 100644 --- a/include/configs/TQM866M.h +++ b/include/configs/TQM866M.h @@ -125,9 +125,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
-#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - #undef CONFIG_RTC_MPC8xx /* MPC866 does not support RTC */
#define CONFIG_TIMESTAMP /* but print image timestmps */ diff --git a/include/configs/TQM885D.h b/include/configs/TQM885D.h index b246926..f12b4bf 100644 --- a/include/configs/TQM885D.h +++ b/include/configs/TQM885D.h @@ -121,9 +121,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
-#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - #undef CONFIG_RTC_MPC8xx /* MPC885 does not support RTC */
#define CONFIG_TIMESTAMP /* but print image timestmps */ diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index f32fb4d..999523c 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -380,7 +380,6 @@ #define CONFIG_CMD_PCI
/* @@ -479,10 +478,6 @@ #define CONFIG_GENERIC_MMC #endif
-#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) || defined(CONFIG_FSL_SATA) -#define CONFIG_DOS_PARTITION -#endif - /* Misc Extra Settings */ #undef CONFIG_WATCHDOG /* watchdog disabled */
diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h index b41ebe0..bf848c6 100644 --- a/include/configs/a4m072.h +++ b/include/configs/a4m072.h @@ -61,8 +61,6 @@ #undef CONFIG_EEPRO100
/* USB */ #define CONFIG_USB_OHCI_NEW diff --git a/include/configs/ac14xx.h b/include/configs/ac14xx.h index 2d1c099..a7a6bfe 100644 --- a/include/configs/ac14xx.h +++ b/include/configs/ac14xx.h @@ -396,12 +396,6 @@ #define CONFIG_CMD_PCI #endif
-#if defined(CONFIG_CMD_IDE) || defined(CONFIG_CMD_EXT2) -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION -#endif /* defined(CONFIG_CMD_IDE) */ - /* * Miscellaneous configurable options */ diff --git a/include/configs/acadia.h b/include/configs/acadia.h index c10c646..39121ed 100644 --- a/include/configs/acadia.h +++ b/include/configs/acadia.h @@ -155,9 +155,6 @@ #define CONFIG_USB_OHCI
diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index 93fa614..dbf85e1 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -101,7 +101,6 @@ * SD (MMC) controller */ #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_FTSDC010 #define CONFIG_FTSDC010_NUMBER 1 #define CONFIG_FTSDC010_SDIO diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 99f9ef7..cea846b 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -57,7 +57,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_GENERIC_MMC #define CONFIG_BOUNCE_BUFFER -#define CONFIG_DOS_PARTITION
/* USB Configs */ #define CONFIG_USB_EHCI diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 49c14df..229dd02 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -42,7 +42,6 @@
/* Enhance our eMMC support / experience. */ #define CONFIG_CMD_GPT -#define CONFIG_EFI_PARTITION
#ifdef CONFIG_NAND #define NANDARGS \ @@ -305,8 +304,6 @@ #undef CONFIG_ENV_IS_IN_NAND /* disable host part of MUSB in SPL */ /* disable EFI partitions and partition UUID support */ -#undef CONFIG_PARTITION_UUIDS -#undef CONFIG_EFI_PARTITION #endif
/* USB Device Firmware Update support */ diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index 32f93d2..6764ebb 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -85,10 +85,6 @@
/* Enhance our eMMC support / experience. */ #define CONFIG_CMD_GPT -#define CONFIG_EFI_PARTITION -#ifdef CONFIG_SPL_BUILD -#undef CONFIG_ISO_PARTITION -#endif #ifndef CONFIG_SHC_ICT /* * In builds other than ICT, reset to retry after timeout diff --git a/include/configs/am335x_sl50.h b/include/configs/am335x_sl50.h index ca5bb1a..14238cc 100644 --- a/include/configs/am335x_sl50.h +++ b/include/configs/am335x_sl50.h @@ -30,7 +30,6 @@
#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
@@ -99,8 +98,6 @@ /* disable host part of MUSB in SPL */ #undef CONFIG_MUSB_HOST /* disable EFI partitions and partition UUID support */ -#undef CONFIG_PARTITION_UUIDS -#undef CONFIG_EFI_PARTITION #endif
#if defined(CONFIG_EMMC_BOOT) diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index ad0de2c8..466415c 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -77,7 +77,6 @@ 115200} #define CONFIG_GENERIC_MMC 1 #define CONFIG_OMAP_HSMMC 1 -#define CONFIG_DOS_PARTITION 1
/* * USB configuration diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 3247a4a..37f3e24 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -79,7 +79,6 @@ /* SD/MMC */ #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
/* * USB configuration @@ -260,7 +259,6 @@ #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP -#define CONFIG_PARTITION_UUIDS
/* We set the max number of command args high to avoid HUSH bugs. */ #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index b47acb2..2cc1c79 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -170,7 +170,6 @@
#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index cfd1f14..9a0fee6 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -71,7 +71,6 @@
/* Enhance our eMMC support / experience. */ #define CONFIG_CMD_GPT -#define CONFIG_EFI_PARTITION #define CONFIG_RANDOM_UUID #define CONFIG_HSMMC2_8BIT
diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index c86ce05..053a184 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -15,7 +15,6 @@
#define CONFIG_CMD_SDRAM #define CONFIG_CMD_IDE -#define CONFIG_DOS_PARTITION
#define CONFIG_BAUDRATE 38400 #define CONFIG_BOOTARGS "console=ttySC2,38400" diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index fdf9ed0..1bf606c 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -72,7 +72,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_BOUNCE_BUFFER #define CONFIG_FAT_WRITE -#define CONFIG_DOS_PARTITION
#ifdef CONFIG_MX6Q #define CONFIG_CMD_SATA diff --git a/include/configs/apf27.h b/include/configs/apf27.h index e9d8232..d1fdff6 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -241,7 +241,6 @@ */ #define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS -#define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_VFAT
/* diff --git a/include/configs/apx4devkit.h b/include/configs/apx4devkit.h index babaf26..3252aea 100644 --- a/include/configs/apx4devkit.h +++ b/include/configs/apx4devkit.h @@ -21,7 +21,6 @@
/* U-Boot Commands */ #define CONFIG_SYS_NO_FLASH -#define CONFIG_DOS_PARTITION
#define CONFIG_CMD_DATE #define CONFIG_CMD_NAND diff --git a/include/configs/aria.h b/include/configs/aria.h index f385852..d408d54 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -403,12 +403,6 @@ #define CONFIG_CMD_PCI #endif
-#if defined(CONFIG_CMD_IDE) || defined(CONFIG_CMD_EXT2) -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION -#endif /* defined(CONFIG_CMD_IDE) */ - /* * Dynamic MTD partition support */ diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index ed0daf5..a02e9cc 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -144,7 +144,6 @@ #define CONFIG_USB_ATMEL 1 #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_DOS_PARTITION 1
#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_USB_HOST_BASE diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index f07366e..f610ae5 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -151,9 +151,6 @@ #endif
/* FAT */ -#ifdef CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION -#endif
/* NOR flash - no real flash on this board */ #define CONFIG_SYS_NO_FLASH 1 diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index cc37236..67a721b 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -127,7 +127,6 @@ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW -#define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 /* AT91SAM9261_UHP_BASE */ #ifdef CONFIG_AT91SAM9G10EK diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 6806cc7..6f626c3 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -267,7 +267,6 @@ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00a00000 /* AT91SAM9263_UHP_BASE */ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 12a92c2..0710cd5 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -103,10 +103,6 @@ #define CONFIG_GENERIC_ATMEL_MCI #endif
-#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_DOS_PARTITION -#endif - /* Ethernet */ #define CONFIG_MACB #define CONFIG_RMII diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 9c9e809..32d5777 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -128,9 +128,6 @@ #endif
/* Ethernet */ #define CONFIG_KS8851_MLL diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index b5aebe6..c174339 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -108,7 +108,6 @@ #ifdef CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #define CONFIG_GENERIC_ATMEL_MCI -#define CONFIG_DOS_PARTITION #endif
/* Ethernet - not present */ diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 6dee45a..298ada4 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -116,9 +116,6 @@ #endif
/* Ethernet */ #define CONFIG_MACB diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index 00a8c79..00b8911 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -48,7 +48,6 @@ #define CONFIG_USART_BASE ATMEL_BASE_USART1 #define CONFIG_USART_ID 1 /* User serviceable stuff */ -#define CONFIG_DOS_PARTITION
#define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS diff --git a/include/configs/atngw100mkii.h b/include/configs/atngw100mkii.h index d1f61b3..ac6736a 100644 --- a/include/configs/atngw100mkii.h +++ b/include/configs/atngw100mkii.h @@ -67,7 +67,6 @@ #define CONFIG_USART_ID 1
#define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 3d17ae1..e75ea1a 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -64,7 +64,6 @@ #define CONFIG_USART_ID 1
#define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS diff --git a/include/configs/axs10x.h b/include/configs/axs10x.h index 296fbd1..56db81e 100644 --- a/include/configs/axs10x.h +++ b/include/configs/axs10x.h @@ -87,7 +87,6 @@ */ #define CONFIG_GENERIC_MMC #define CONFIG_DWMMC -#define CONFIG_DOS_PARTITION
/* * Ethernet PHY configuration diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 06f5ceb..86913fe 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -35,8 +35,6 @@
/* Enhance our eMMC support / experience. */ #define CONFIG_CMD_GPT -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART
/* FIT support */ @@ -311,8 +309,6 @@ #if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USBETH_SUPPORT) /* disable host part of MUSB in SPL */ /* disable EFI partitions and partition UUID support */ -#undef CONFIG_PARTITION_UUIDS -#undef CONFIG_EFI_PARTITION /* * Disable CPSW SPL support so we fit within the 101KiB limit. */ diff --git a/include/configs/bamboo.h b/include/configs/bamboo.h index 1b22a37..8d31a97 100644 --- a/include/configs/bamboo.h +++ b/include/configs/bamboo.h @@ -194,9 +194,6 @@ #define CONFIG_SUPPORT_VFAT
/*----------------------------------------------------------------------- * PCI stuff diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index 2f51e2c..cd844df 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -45,7 +45,6 @@
#ifdef CONFIG_NAND #define NANDARGS \ @@ -457,8 +456,6 @@ DEFAULT_LINUX_BOOT_ENV \ #if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USBETH_SUPPORT) /* disable host part of MUSB in SPL */ /* disable EFI partitions and partition UUID support */ -#undef CONFIG_PARTITION_UUIDS -#undef CONFIG_EFI_PARTITION #endif
/* USB Device Firmware Update support */ diff --git a/include/configs/bcm23550_w1d.h b/include/configs/bcm23550_w1d.h index 8f062e2..ab26a25 100644 --- a/include/configs/bcm23550_w1d.h +++ b/include/configs/bcm23550_w1d.h @@ -105,8 +105,6 @@ * This is necessary for the fatls command to work on an SD card * for example. */ -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION
/* version string, parser, etc */ #define CONFIG_AUTO_COMPLETE diff --git a/include/configs/bcm28155_ap.h b/include/configs/bcm28155_ap.h index 0882531..0c49563 100644 --- a/include/configs/bcm28155_ap.h +++ b/include/configs/bcm28155_ap.h @@ -104,8 +104,6 @@ * This is necessary for the fatls command to work on an SD card * for example. */ -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION
/* version string, parser, etc */ #define CONFIG_AUTO_COMPLETE diff --git a/include/configs/bcm_ep_board.h b/include/configs/bcm_ep_board.h index b68fa1e..c830e37 100644 --- a/include/configs/bcm_ep_board.h +++ b/include/configs/bcm_ep_board.h @@ -65,7 +65,6 @@ * This is necessary for the fatls command to work on an SD card * for example. */ -#define CONFIG_DOS_PARTITION
/* version string, parser, etc */ #define CONFIG_AUTO_COMPLETE diff --git a/include/configs/bf533-stamp.h b/include/configs/bf533-stamp.h index ec4d93c..28041a9 100644 --- a/include/configs/bf533-stamp.h +++ b/include/configs/bf533-stamp.h @@ -152,7 +152,6 @@ /* #define CONFIG_STAMP_CF */ #if defined(CONFIG_STAMP_CF) #define CONFIG_MISC_INIT_R -#define CONFIG_DOS_PARTITION 1 #undef CONFIG_IDE_8xx_DIRECT /* no pcmcia interface required */ #undef CONFIG_IDE_LED /* no led for ide supported */ #undef CONFIG_IDE_RESET /* no reset for ide supported */ diff --git a/include/configs/bf537-stamp.h b/include/configs/bf537-stamp.h index 6517705..ab777e5 100644 --- a/include/configs/bf537-stamp.h +++ b/include/configs/bf537-stamp.h @@ -184,7 +184,6 @@
#if defined(CONFIG_BFIN_IDE)
-#define CONFIG_DOS_PARTITION 1 /* * IDE/ATA stuff */ diff --git a/include/configs/bfin_adi_common.h b/include/configs/bfin_adi_common.h index c401b73..72099bf 100644 --- a/include/configs/bfin_adi_common.h +++ b/include/configs/bfin_adi_common.h @@ -21,10 +21,8 @@ # endif # ifdef CONFIG_LIBATA # define CONFIG_CMD_SATA -# define CONFIG_DOS_PARTITION # endif # ifdef CONFIG_MMC -# define CONFIG_DOS_PARTITION # define CONFIG_SYS_MMC_MAX_BLK_COUNT 127 # endif # ifdef CONFIG_MMC_SPI @@ -32,7 +30,6 @@ # endif # ifdef CONFIG_USB # define CONFIG_CMD_USB_STORAGE -# define CONFIG_DOS_PARTITION # endif # if defined(CONFIG_NAND_PLAT) || defined(CONFIG_DRIVER_NAND_BFIN) # define CONFIG_CMD_NAND diff --git a/include/configs/bg0900.h b/include/configs/bg0900.h index 57a6985..fdb044d 100644 --- a/include/configs/bg0900.h +++ b/include/configs/bg0900.h @@ -11,7 +11,6 @@
#define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index eb2419c..956aedc 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -283,7 +283,6 @@ MMCARGS * enabled a number of useful commands and support. */ #if defined(CONFIG_MMC) || defined(CONFIG_USB_STORAGE) -#define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE #define CONFIG_FS_EXT4 #define CONFIG_EXT4_WRITE diff --git a/include/configs/brxre1.h b/include/configs/brxre1.h index ac338c4..b2dfd1e 100644 --- a/include/configs/brxre1.h +++ b/include/configs/brxre1.h @@ -129,7 +129,6 @@ BUR_COMMON_ENV \ * enabled a number of useful commands and support. */ #if defined(CONFIG_MMC) || defined(CONFIG_USB_STORAGE) -#define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE #endif /* CONFIG_MMC, ... */
diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index 1d189d2..42946b6 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -396,9 +396,6 @@ #endif
/*----------------------------------------------------------------------- * PCI stuff diff --git a/include/configs/cl-som-am57x.h b/include/configs/cl-som-am57x.h index 8297182..4a4fc21 100644 --- a/include/configs/cl-som-am57x.h +++ b/include/configs/cl-som-am57x.h @@ -98,7 +98,6 @@
/* GPT */ #define CONFIG_CMD_GPT -#define CONFIG_EFI_PARTITION
/* USB xHCI HOST */ #define CONFIG_USB_XHCI_OMAP diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index e520b1a..1ad0969 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -47,8 +47,6 @@ #define CONFIG_SYS_MMC_BASE MVEBU_SDIO_BASE
/* Partition support */ -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION
/* Additional FS support/configuration */ #define CONFIG_SUPPORT_VFAT diff --git a/include/configs/cm5200.h b/include/configs/cm5200.h index b65ca3e..b3a98df 100644 --- a/include/configs/cm5200.h +++ b/include/configs/cm5200.h @@ -225,9 +225,6 @@ #define CONFIG_USB_CLOCK 0x0001BBBB #define CONFIG_USB_CONFIG 0x00001000 /* Partitions (for USB) */ -#define CONFIG_MAC_PARTITION 1 -#define CONFIG_DOS_PARTITION 1 -#define CONFIG_ISO_PARTITION 1
/* * Invoke our last_stage_init function - needed by fwupdate diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index 1ce27e3..87247b3 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -82,7 +82,6 @@
/* USB */ #define CONFIG_USB_OMAP3 diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index bae9697..ec7459a 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -89,7 +89,6 @@
/* USB */ #define CONFIG_USB_MUSB_AM35X diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 9c24ba9..8bba58e 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -107,7 +107,6 @@
#define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x80200000\0" \ diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index b05fca6..d1e95d2 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -70,7 +70,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_BOUNCE_BUFFER #define CONFIG_FAT_WRITE -#define CONFIG_DOS_PARTITION
/* Network */ #define CONFIG_FEC_MXC diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 4cfd5b9..eef3fcd 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -61,7 +61,6 @@ #define CONFIG_SYS_FSL_ESDHC_NUM 1
#define CONFIG_RBTREE #define CONFIG_LZO diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 1736097..3bd1505 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -376,7 +376,6 @@ #define CONFIG_HW_WATCHDOG #define CONFIG_LOADS_ECHO #define CONFIG_SYS_LOADS_BAUD_CHANGE -#define CONFIG_DOS_PARTITION
/* * For booting Linux, the board info and command line data diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index c9c00c5..a507d5e 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -550,7 +550,6 @@ #define CONFIG_PCI_INDIRECT_BRIDGE
/* SATA */ @@ -568,7 +567,6 @@
#ifdef CONFIG_FMAN_ENET @@ -624,7 +622,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* Hash command with SHA acceleration supported in hardware */ diff --git a/include/configs/corvus.h b/include/configs/corvus.h index e6a52d8..c9059e4 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -103,7 +103,6 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_ATMEL #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 -#define CONFIG_DOS_PARTITION
/* USB DFU support */ #define CONFIG_CMD_MTDPARTS diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index 14e207e..dc4da58 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -381,7 +381,6 @@ #define CONFIG_NET_MULTI
/* SATA */ @@ -399,7 +398,6 @@
#ifdef CONFIG_FMAN_ENET @@ -446,7 +444,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index ceb9cea..4d740ae 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -322,9 +322,6 @@ * Enable MMC commands only when * MMC support is present */ -#ifdef CONFIG_MMC -#define CONFIG_DOS_PARTITION -#endif
#ifndef CONFIG_DIRECT_NOR_BOOT /* defines for SPL */ diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 4834828..6d05776 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -41,8 +41,6 @@ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_3
/* Additional FS support/configuration */ #define CONFIG_SUPPORT_VFAT diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index 519f2d3..beb14bc 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -58,8 +58,6 @@ CONFIG_SYS_SCSI_MAX_LUN)
/* Additional FS support/configuration */ #define CONFIG_SUPPORT_VFAT diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index 26508c2..656c8c3 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -62,8 +62,6 @@ #define CONFIG_SATA_MV #define CONFIG_LIBATA #define CONFIG_LBA48 -#define CONFIG_EFI_PARTITION -#define CONFIG_DOS_PARTITION
/* Additional FS support/configuration */ #define CONFIG_SUPPORT_VFAT diff --git a/include/configs/dbau1x00.h b/include/configs/dbau1x00.h index 182e8ab..ad7667e 100644 --- a/include/configs/dbau1x00.h +++ b/include/configs/dbau1x00.h @@ -173,7 +173,6 @@ #define CONFIG_PCMCIA_SLOT_A
#define CONFIG_ATAPI 1 -#define CONFIG_MAC_PARTITION 1
/* We run CF in "true ide" mode or a harddrive via pcmcia */ #define CONFIG_IDE_PCMCIA 1 diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index a71f67c..e0df470 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -137,7 +137,6 @@
#define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING -#define CONFIG_DOS_PARTITION
/* * Pass open firmware flat tree diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index ae0d3d4..9bfc1ef 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -64,7 +64,6 @@ /* * Partitions */ -#define CONFIG_DOS_PARTITION #define CONFIG_BZIP2
/* diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 980ab40..208d3a9 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -102,7 +102,6 @@
diff --git a/include/configs/draco.h b/include/configs/draco.h index 7c4179d..bc85cf3 100644 --- a/include/configs/draco.h +++ b/include/configs/draco.h @@ -31,8 +31,6 @@ "led0=103,1,0\0" \ "led1=64,0,1\0"
-#undef CONFIG_DOS_PARTITION - #define CONFIG_BOARD_LATE_INIT
/* Physical Memory Map */ diff --git a/include/configs/dragonboard410c.h b/include/configs/dragonboard410c.h index e6bb919..9fa814c 100644 --- a/include/configs/dragonboard410c.h +++ b/include/configs/dragonboard410c.h @@ -66,7 +66,6 @@
/* Partition table support */ #define HAVE_BLOCK_DEVICE /* Needed for partition commands */ -#define CONFIG_PARTITION_UUIDS
#include <config_distro_defaults.h>
diff --git a/include/configs/ds414.h b/include/configs/ds414.h index 0be8800..9d5a5f7 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -81,8 +81,6 @@ #endif
/* why is this only defined in mv-common.h if CONFIG_DM is undefined? */ -#define CONFIG_DOS_PARTITION -#define CONFIG_ISO_PARTITION #define CONFIG_SUPPORT_VFAT #define CONFIG_SYS_MVFS
diff --git a/include/configs/duovero.h b/include/configs/duovero.h index b5bd3ba..c0c8a41 100644 --- a/include/configs/duovero.h +++ b/include/configs/duovero.h @@ -21,8 +21,6 @@
#include <configs/ti_omap4_common.h>
-#undef CONFIG_EFI_PARTITION - #undef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS #define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index 6470327..020f4a0 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -32,8 +32,6 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_ENV
-#define CONFIG_DOS_PARTITION - #define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC0,115200"
diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index af7b470..71f416c 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -145,7 +145,6 @@ #ifdef CONFIG_CMD_IDE #define __io #define CONFIG_IDE_PREINIT -#define CONFIG_DOS_PARTITION /* ED Mini V has an IDE-compatible SATA connector for port 1 */ #define CONFIG_MVSATA_IDE #define CONFIG_MVSATA_IDE_USE_PORT1 @@ -176,8 +175,6 @@ #define CONFIG_USB_EHCI /* Enable EHCI USB support */ #define CONFIG_USB_EHCI_MARVELL #define ORION5X_USB20_HOST_PORT_BASE ORION5X_USB20_PORT0_BASE -#define CONFIG_DOS_PARTITION -#define CONFIG_ISO_PARTITION #define CONFIG_SUPPORT_VFAT #endif /* CONFIG_CMD_USB */
diff --git a/include/configs/etamin.h b/include/configs/etamin.h index eb17d68..7c1ddb9 100644 --- a/include/configs/etamin.h +++ b/include/configs/etamin.h @@ -88,7 +88,6 @@ "led4=60,0,1\0" \ "led5=63,0,1\0"
-#undef CONFIG_DOS_PARTITION #undef CONFIG_CMD_FAT
#define CONFIG_BOARD_LATE_INIT diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index c78eebf..35e704b 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -195,7 +195,6 @@ #endif #if defined(CONFIG_CMD_REISER) || defined(CONFIG_CMD_EXT2) || \ defined(CONFIG_CMD_USB) || defined(CONFIG_MMC) -#define CONFIG_DOS_PARTITION #endif #define CONFIG_LZO #define CONFIG_RBTREE diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index 9328a22..7e050db 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -50,7 +50,6 @@ #define CONFIG_FAT_WRITE
#define CONFIG_CMD_PART -#define CONFIG_PARTITION_UUIDS
/* Miscellaneous configurable options */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 0039c8c..02cdbac 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -69,7 +69,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_GENERIC_MMC #define CONFIG_BOUNCE_BUFFER -#define CONFIG_DOS_PARTITION
/* USB Configs */ #ifdef CONFIG_USB diff --git a/include/configs/gplugd.h b/include/configs/gplugd.h index 37b0a8c..4f8a0c5 100644 --- a/include/configs/gplugd.h +++ b/include/configs/gplugd.h @@ -99,8 +99,6 @@ #define CONFIG_EHCI_IS_TDI #endif /* CONFIG_CMD_USB */
#endif /* __CONFIG_GPLUGD_H */ diff --git a/include/configs/gr_cpci_ax2000.h b/include/configs/gr_cpci_ax2000.h index 211dc38..7f6586f 100644 --- a/include/configs/gr_cpci_ax2000.h +++ b/include/configs/gr_cpci_ax2000.h @@ -49,9 +49,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 }
/* Partitions */ -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION
/* * Supported commands diff --git a/include/configs/gr_ep2s60.h b/include/configs/gr_ep2s60.h index ad0c126..4d28a97 100644 --- a/include/configs/gr_ep2s60.h +++ b/include/configs/gr_ep2s60.h @@ -43,9 +43,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 }
/* * Supported commands diff --git a/include/configs/gr_xc3s_1500.h b/include/configs/gr_xc3s_1500.h index b0e9001..b91ab85 100644 --- a/include/configs/gr_xc3s_1500.h +++ b/include/configs/gr_xc3s_1500.h @@ -30,9 +30,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 }
/* * Supported commands diff --git a/include/configs/grsim.h b/include/configs/grsim.h index 17cac5a..8c1c8b4 100644 --- a/include/configs/grsim.h +++ b/include/configs/grsim.h @@ -41,9 +41,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 }
/* * Supported commands diff --git a/include/configs/grsim_leon2.h b/include/configs/grsim_leon2.h index 1642793..3651017 100644 --- a/include/configs/grsim_leon2.h +++ b/include/configs/grsim_leon2.h @@ -36,9 +36,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 }
/* * Supported commands diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index b224706..e92f5d5 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -28,7 +28,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC83xx_ESDHC_ADDR
#define CONFIG_CMD_FPGAD #define CONFIG_CMD_IOLOOP diff --git a/include/configs/ib62x0.h b/include/configs/ib62x0.h index f686c7f..ec209a1 100644 --- a/include/configs/ib62x0.h +++ b/include/configs/ib62x0.h @@ -92,7 +92,6 @@ #ifdef CONFIG_CMD_IDE #define __io #define CONFIG_IDE_PREINIT -#define CONFIG_DOS_PARTITION #define CONFIG_MVSATA_IDE_USE_PORT0 #define CONFIG_MVSATA_IDE_USE_PORT1 #define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET diff --git a/include/configs/icon.h b/include/configs/icon.h index b15016b..3bf7383 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -224,7 +224,6 @@ #define CONFIG_SYSTEMACE /* Enable SystemACE support */ #define CONFIG_SYS_SYSTEMACE_WIDTH 16 /* Data bus width is 16 */ #define CONFIG_SYS_SYSTEMACE_BASE CONFIG_SYS_ACE_BASE -#define CONFIG_DOS_PARTITION
/* * External Bus Controller (EBC) Setup diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index 30168bc..d82325d 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -139,7 +139,6 @@ */ #define CONFIG_GENERIC_MMC #define CONFIG_MXC_MMC -#define CONFIG_DOS_PARTITION
/* * GPIO diff --git a/include/configs/inka4x0.h b/include/configs/inka4x0.h index 79a716e..b2131e8 100644 --- a/include/configs/inka4x0.h +++ b/include/configs/inka4x0.h @@ -61,9 +61,6 @@ #define CONFIG_SYS_XLB_PIPELINING 1
/* * BOOTP options diff --git a/include/configs/intip.h b/include/configs/intip.h index e61005b..4db067f 100644 --- a/include/configs/intip.h +++ b/include/configs/intip.h @@ -280,9 +280,6 @@ #define CONFIG_CMD_SDRAM
/* * PCI stuff diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index 3bd938e..a790271 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -78,7 +78,6 @@ #define CONFIG_SYS_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */
/* USB */ #define CONFIG_USB_OHCI_NEW diff --git a/include/configs/jupiter.h b/include/configs/jupiter.h index e073528..4b7ea6d 100644 --- a/include/configs/jupiter.h +++ b/include/configs/jupiter.h @@ -64,9 +64,6 @@ #define CONFIG_SYS_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */
#define CONFIG_TIMESTAMP /* Print image info with timestamp */
diff --git a/include/configs/katmai.h b/include/configs/katmai.h index a41c127..f531381 100644 --- a/include/configs/katmai.h +++ b/include/configs/katmai.h @@ -238,7 +238,6 @@ #define CONFIG_SYSTEMACE 1 /* Enable SystemACE support */ #define CONFIG_SYS_SYSTEMACE_WIDTH 16 /* Data bus width is 16 */ #define CONFIG_SYS_SYSTEMACE_BASE CONFIG_SYS_ACE_BASE -#define CONFIG_DOS_PARTITION 1
/*----------------------------------------------------------------------- * External Bus Controller (EBC) Setup diff --git a/include/configs/kc1.h b/include/configs/kc1.h index 7a4ba09..bb9477d 100644 --- a/include/configs/kc1.h +++ b/include/configs/kc1.h @@ -107,7 +107,6 @@ * Partitions */
/* diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index b4cdb67..4244c19 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -346,7 +346,6 @@ int get_scl(void); #define CONFIG_PCI_INDIRECT_BRIDGE
/* RGMII (FM1@DTESC5) is used as debug itf, it's the only one configured */ #define CONFIG_SYS_FM1_DTSEC5_PHY_ADDR 0x11 diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 9402aca..06cf308 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -23,7 +23,6 @@ #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_DOS_PARTITION
#define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "root=/dev/null console=ttySC4,115200" diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 4804fe0..1d9224c 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -135,8 +135,6 @@ /* * Partition support */ -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION
/* * File systems support diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index 3b118bb..27ca12c 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -223,9 +223,6 @@ * Enable MMC commands only when * MMC support is present */ -#ifdef CONFIG_MMC -#define CONFIG_DOS_PARTITION -#endif
/* additions for new relocation code, must added to all boards */ #define CONFIG_SYS_SDRAM_BASE 0xc0000000 diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index b5b4d7e..4c04093 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -135,7 +135,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* SATA */ @@ -144,7 +143,6 @@ #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_CMD_SCSI -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
#define CONFIG_SYS_SATA AHCI_BASE_ADDR diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index f35fd31..ed28d79 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -48,7 +48,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* SATA */ @@ -57,7 +56,6 @@ #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_CMD_SCSI -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
#define CONFIG_SYS_SATA AHCI_BASE_ADDR diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index ae8ee24..c03e34f 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -178,7 +178,6 @@ CONFIG_SYS_SCSI_MAX_LUN)
#define CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION
/* SPI */ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 6f857a7..ff4a283 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -396,8 +396,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESDHC #define CONFIG_GENERIC_MMC
-#define CONFIG_DOS_PARTITION - /* SPI */ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) /* QSPI */ diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index b48cd00..6c387a1 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -297,8 +297,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_GENERIC_MMC
-#define CONFIG_DOS_PARTITION - /* SPI */ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) /* QSPI */ diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 3e70464..8d38c0e 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -151,7 +151,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* DSPI */ diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 561a05a..374bcf2 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -97,7 +97,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_SCSI -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
/* EEPROM */ diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 71c26bd..c69a0aa 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -300,7 +300,6 @@ #ifndef CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT2 #endif -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT #define CONFIG_SYS_SCSI_MAX_SCSI_ID 2 #define CONFIG_SYS_SCSI_MAX_LUN 2 diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 40e6af8..9b705ca 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -119,7 +119,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
#define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 29e0aa5..538e724 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -140,7 +140,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_SCSI -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
/* EEPROM */ diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 2fe8fc1..68065b0 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -216,7 +216,6 @@ #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_SCSI -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
#define CONFIG_SYS_SATA AHCI_BASE_ADDR diff --git a/include/configs/ls2080a_simu.h b/include/configs/ls2080a_simu.h index 07be30c..31d28c7 100644 --- a/include/configs/ls2080a_simu.h +++ b/include/configs/ls2080a_simu.h @@ -137,7 +137,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* Debug Server firmware */ diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 37d5704..a0b8bec 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -53,7 +53,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_SCSI -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
#define CONFIG_SYS_SATA1 AHCI_BASE_ADDR1 @@ -359,7 +358,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* Initial environment variables */ diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 713e86b..224701b 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -61,7 +61,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_SCSI -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
#define CONFIG_SYS_SATA1 AHCI_BASE_ADDR1 @@ -303,7 +302,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
#define CONFIG_MISC_INIT_R diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 0caca4c..7ec82cd 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -48,9 +48,6 @@ #define CONFIG_CMD_ENV #define CONFIG_CMD_IDE
-#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION - /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 638682f..8f38e47 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -372,9 +372,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* re-init HCD after CMD_RESET */
/* * BOOTP options diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index 25884b4..51825f2 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -16,7 +16,6 @@
/* U-Boot Commands */ #define CONFIG_SYS_NO_FLASH -#define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE
#define CONFIG_CMD_BMP diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 8ec98fd..5fa8941 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -23,7 +23,6 @@ /* * U-Boot Commands */ -#define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE
#define CONFIG_CMD_BMP diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index de83d6c..112869e 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -19,7 +19,6 @@ /* * U-Boot Commands */ -#define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE
/* diff --git a/include/configs/manroland/common.h b/include/configs/manroland/common.h index 937febe..d97d938 100644 --- a/include/configs/manroland/common.h +++ b/include/configs/manroland/common.h @@ -16,7 +16,6 @@ #define CONFIG_BOARD_EARLY_INIT_R
/* * Command line configuration. diff --git a/include/configs/mcx.h b/include/configs/mcx.h index f15abd3..503e824 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -83,7 +83,6 @@ 115200} #define CONFIG_OMAP_HSMMC #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION
/* EHCI */ #define CONFIG_OMAP3_GPIO_2 diff --git a/include/configs/mecp5123.h b/include/configs/mecp5123.h index 4f90c34..7f88b79 100644 --- a/include/configs/mecp5123.h +++ b/include/configs/mecp5123.h @@ -295,7 +295,6 @@ #undef CONFIG_CMD_FUSE #undef CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_DOS_PARTITION
/* * Watchdog timeout = CONFIG_SYS_WATCHDOG_VALUE * 65536 / IPS clock. diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index 917350f..6217015 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -257,7 +257,6 @@ #define CONFIG_SYS_ATA_DATA_OFFSET 0x0060 #define CONFIG_SYS_ATA_REG_OFFSET CONFIG_SYS_ATA_DATA_OFFSET #define CONFIG_SYS_ATA_STRIDE 4 -#define CONFIG_DOS_PARTITION
/* * I2C configuration diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index c36141a..77f1850 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -438,11 +438,6 @@ "mpc5121.nand:-(data)"
#if defined(CONFIG_CMD_IDE) || defined(CONFIG_CMD_EXT2) || defined(CONFIG_CMD_USB) - -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION - #define CONFIG_SUPPORT_VFAT
#endif /* defined(CONFIG_CMD_IDE) */ diff --git a/include/configs/ms7720se.h b/include/configs/ms7720se.h index 87f8712..e074350 100644 --- a/include/configs/ms7720se.h +++ b/include/configs/ms7720se.h @@ -92,7 +92,6 @@
#define CONFIG_SYS_PIO_MODE 1 #define CONFIG_SYS_IDE_MAXBUS 1 -#define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_ATA_BASE_ADDR CONFIG_SYS_MARUBUN_IO /* base address */ #define CONFIG_SYS_ATA_IDE0_OFFSET 0x01F0 /* ide0 offste */ #define CONFIG_SYS_ATA_DATA_OFFSET 0 /* data reg offset */ diff --git a/include/configs/mv-common.h b/include/configs/mv-common.h index b28030c..e239eb0 100644 --- a/include/configs/mv-common.h +++ b/include/configs/mv-common.h @@ -125,8 +125,6 @@ */ #if defined(CONFIG_CMD_USB) && !defined(CONFIG_DM) #define CONFIG_USB_EHCI /* Enable EHCI USB support */ -#define CONFIG_DOS_PARTITION -#define CONFIG_ISO_PARTITION #define CONFIG_SUPPORT_VFAT #endif /* CONFIG_CMD_USB */
diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index 8ab5bbe..eece1cc 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -120,13 +120,8 @@ #define CONFIG_SUPPORT_VFAT
/* DISK Partition support */ -#define CONFIG_EFI_PARTITION -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION /* Experimental */
/* * PCI configuration diff --git a/include/configs/mvebu_db-88f3720.h b/include/configs/mvebu_db-88f3720.h index 7ddde8c..917233f 100644 --- a/include/configs/mvebu_db-88f3720.h +++ b/include/configs/mvebu_db-88f3720.h @@ -131,12 +131,7 @@ #define CONFIG_SUPPORT_VFAT
#endif /* _CONFIG_MVEBU_DB_88F3720_H */ diff --git a/include/configs/mx23_olinuxino.h b/include/configs/mx23_olinuxino.h index 36ff7ce..a04f7f3 100644 --- a/include/configs/mx23_olinuxino.h +++ b/include/configs/mx23_olinuxino.h @@ -12,7 +12,6 @@
#define CONFIG_CMD_LED
diff --git a/include/configs/mx23evk.h b/include/configs/mx23evk.h index ecb6e4d..4494bf6 100644 --- a/include/configs/mx23evk.h +++ b/include/configs/mx23evk.h @@ -15,7 +15,6 @@
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index 3853c05..4616f4c 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -99,8 +99,6 @@ #define CONFIG_POWER_FSL_MC34704 #define CONFIG_SYS_FSL_PMIC_I2C_ADDR 0x54
-#define CONFIG_DOS_PARTITION - /* I2C Configs */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 5963d39..85ea54a 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -17,7 +17,6 @@
#define CONFIG_CMD_DATE #define CONFIG_CMD_NAND diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index c0fb8d1..749fb05 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -86,9 +86,6 @@ #define CONFIG_NET_RETRY_COUNT 100 #define CONFIG_CMD_DATE
#define CONFIG_LOADADDR 0x80800000 /* loadaddr env var */
diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index b62360b..097e8a3 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -68,7 +68,6 @@ #define CONFIG_SYS_FSL_ESDHC_NUM 2
/* * Eth Configs diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index d84d524..21d97f7 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -54,7 +54,6 @@ #define CONFIG_SYS_FSL_ESDHC_NUM 2
/* Eth Configs */ #define CONFIG_HAS_ETH1 diff --git a/include/configs/mx53cx9020.h b/include/configs/mx53cx9020.h index 8fec94e..c037011 100644 --- a/include/configs/mx53cx9020.h +++ b/include/configs/mx53cx9020.h @@ -41,7 +41,6 @@ #define CONFIG_GENERIC_MMC
/* bootz: zImage/initrd.img support */ -#define CONFIG_DOS_PARTITION
/* Eth Configs */ #define CONFIG_MII diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index aa82928..0b8b5d9 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -53,7 +53,6 @@ #define CONFIG_SYS_FSL_ESDHC_NUM 2
/* Eth Configs */ #define CONFIG_MII diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 6cc5f0f..2652493 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -39,7 +39,6 @@ #define CONFIG_SYS_FSL_ESDHC_NUM 2
/* Eth Configs */ #define CONFIG_MII diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index ad4964c..427b34e 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -44,7 +44,6 @@ #define CONFIG_SYS_FSL_ESDHC_NUM 1
/* Eth Configs */ #define CONFIG_HAS_ETH1 diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index 0a1563c..5b38aa2 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -65,7 +65,6 @@
/* Filesystems and image support */ #define CONFIG_SUPPORT_RAW_INITRD -#define CONFIG_DOS_PARTITION
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index 16fedfb..144890c 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -40,7 +40,6 @@ #define CONFIG_BAUDRATE 115200
/* Filesystems and image support */ -#define CONFIG_DOS_PARTITION
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP diff --git a/include/configs/nas220.h b/include/configs/nas220.h index 7cfdacd..6ec83da 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -100,7 +100,6 @@ #define CONFIG_USB_EHCI /* Enable EHCI USB support */ #define CONFIG_USB_EHCI_KIRKWOOD /* on Kirkwood platform */ #define CONFIG_EHCI_IS_TDI -#define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_VFAT #endif /* CONFIG_CMD_USB */
@@ -128,7 +127,6 @@ /* * EFI partition */ -#define CONFIG_EFI_PARTITION
/* * Date Time diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 99ce60f..003a5dc 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -95,7 +95,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 4800, 9600, 19200, 38400, 57600, 115200 } #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
/* USB */ #define CONFIG_USB_MUSB_UDC diff --git a/include/configs/nsa310s.h b/include/configs/nsa310s.h index 1987164..366ee55 100644 --- a/include/configs/nsa310s.h +++ b/include/configs/nsa310s.h @@ -84,7 +84,6 @@ #ifdef CONFIG_CMD_IDE #define __io #define CONFIG_IDE_PREINIT -#define CONFIG_DOS_PARTITION #define CONFIG_MVSATA_IDE_USE_PORT0 #define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET #endif /* CONFIG_CMD_IDE */ diff --git a/include/configs/o2dnt-common.h b/include/configs/o2dnt-common.h index c51ea3d..8a414c3 100644 --- a/include/configs/o2dnt-common.h +++ b/include/configs/o2dnt-common.h @@ -61,9 +61,6 @@ #define CONFIG_SYS_XLB_PIPELINING 1
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 1a67584..d5c86cb 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -55,8 +55,6 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
/* Partition tables */ -#define CONFIG_EFI_PARTITION -#define CONFIG_DOS_PARTITION
/* USB * diff --git a/include/configs/omap5_uevm.h b/include/configs/omap5_uevm.h index 736d804..3ab96d7 100644 --- a/include/configs/omap5_uevm.h +++ b/include/configs/omap5_uevm.h @@ -44,7 +44,6 @@
/* Enhance our eMMC support / experience. */ #define CONFIG_CMD_GPT -#define CONFIG_EFI_PARTITION #define CONFIG_HSMMC2_8BIT #define CONFIG_SUPPORT_EMMC_BOOT
diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index cdc93c3..f7ccf53 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -332,7 +332,6 @@ #define CONFIG_DAVINCI_MMC
#ifdef CONFIG_MMC -#define CONFIG_DOS_PARTITION #undef CONFIG_ENV_IS_IN_MMC #endif
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index f91a762..1fbf777 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -698,7 +698,6 @@ #define CONFIG_CMD_PCI
#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_DOS_PARTITION #endif /* CONFIG_PCI */
#if defined(CONFIG_TSEC_ENET) @@ -848,7 +847,6 @@
#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) \ || defined(CONFIG_FSL_SATA) -#define CONFIG_DOS_PARTITION #endif
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index 63825b0..39e5d3f 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -274,7 +274,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_CMD_PCI
#if defined(CONFIG_TSEC_ENET) @@ -414,7 +413,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/pb1x00.h b/include/configs/pb1x00.h index c92948f..10d39e0 100644 --- a/include/configs/pb1x00.h +++ b/include/configs/pb1x00.h @@ -104,7 +104,6 @@ /*---USB -------------------------------------------*/ #if 0 #define CONFIG_USB_OHCI -#define CONFIG_DOS_PARTITION #endif
/*---ATA PCMCIA ------------------------------------*/ @@ -114,7 +113,6 @@ #define CONFIG_PCMCIA_SLOT_A
/* We run CF in "true ide" mode or a harddrive via pcmcia */ #define CONFIG_IDE_PCMCIA 1 diff --git a/include/configs/pcm030.h b/include/configs/pcm030.h index 4fb9966..bd0203d 100644 --- a/include/configs/pcm030.h +++ b/include/configs/pcm030.h @@ -397,7 +397,6 @@ RTC configuration #define CONFIG_ATAPI 1
/* we enable IDE and FAT support, so we also need partition support */ -#define CONFIG_DOS_PARTITION 1
/* USB */ #define CONFIG_USB_OHCI diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index f3cf954..9041df5 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -72,7 +72,6 @@ /*#define CONFIG_ESDHC_DETECT_USE_EXTERN_IRQ1*/
#define CONFIG_FEC_MXC #define CONFIG_MII diff --git a/include/configs/pic32mzdask.h b/include/configs/pic32mzdask.h index e6fd249..78c216a 100644 --- a/include/configs/pic32mzdask.h +++ b/include/configs/pic32mzdask.h @@ -102,8 +102,6 @@ * File System Configuration */ /* FAT FS */ -#define CONFIG_DOS_PARTITION -#define CONFIG_PARTITION_UUIDS #define CONFIG_SUPPORT_VFAT #define CONFIG_FS_FAT #define CONFIG_FAT_WRITE diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index 2bd7076..fe59a5c 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -38,7 +38,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC1_BASE_ADDR
#define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_EMMC_BOOT
/* USB Configs */ diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index 20fb036..53b398e 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -96,10 +96,6 @@ #define CONFIG_GENERIC_ATMEL_MCI #endif
-#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_DOS_PARTITION -#endif - /* Ethernet */ #define CONFIG_MACB #define CONFIG_RMII diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index c19e7dc..54b0d7a 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -226,7 +226,6 @@ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9261" diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index eddc81a..07f1e52 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -255,7 +255,6 @@ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00a00000 /* AT91SAM9263_UHP_BASE */ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 28690c2..3263f26 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -111,7 +111,6 @@ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_UPLL #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00700000 /* _UHP_OHCI_BASE */ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9g45" diff --git a/include/configs/pxa-common.h b/include/configs/pxa-common.h index 4598bd9..800c12c 100644 --- a/include/configs/pxa-common.h +++ b/include/configs/pxa-common.h @@ -24,7 +24,6 @@ #ifdef CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #define CONFIG_PXA_MMC_GENERIC -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index a6abba7..6fdf50b 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -54,7 +54,6 @@ #define CONFIG_CONS_INDEX 1
#ifdef CONFIG_SYS_BIG_ENDIAN #define CONFIG_IDE_SWAP_IO diff --git a/include/configs/qemu-mips64.h b/include/configs/qemu-mips64.h index 7297a81..4ad230c 100644 --- a/include/configs/qemu-mips64.h +++ b/include/configs/qemu-mips64.h @@ -54,7 +54,6 @@ #define CONFIG_CONS_INDEX 1
#ifdef CONFIG_SYS_BIG_ENDIAN #define CONFIG_IDE_SWAP_IO diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index 9517674..1bede6c 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -114,11 +114,9 @@ extern unsigned long long get_phys_ccsrbar_addr_early(void); #define CONFIG_PCI_INDIRECT_BRIDGE
#define CONFIG_LBA48 -#define CONFIG_DOS_PARTITION
/* * Environment diff --git a/include/configs/r2dplus.h b/include/configs/r2dplus.h index 0e954af..7024fdc 100644 --- a/include/configs/r2dplus.h +++ b/include/configs/r2dplus.h @@ -13,7 +13,6 @@ */ #define CONFIG_CMD_PCI #define CONFIG_CMD_IDE -#define CONFIG_DOS_PARTITION #define CONFIG_CMD_SH_ZIMAGEBOOT
/* SCIF */ diff --git a/include/configs/r7780mp.h b/include/configs/r7780mp.h index baadd87..9322f27 100644 --- a/include/configs/r7780mp.h +++ b/include/configs/r7780mp.h @@ -23,7 +23,6 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_PCI #define CONFIG_CMD_IDE -#define CONFIG_DOS_PARTITION
#define CONFIG_SCIF_CONSOLE 1 #define CONFIG_BAUDRATE 115200 diff --git a/include/configs/rastaban.h b/include/configs/rastaban.h index d6fead2..64f305f 100644 --- a/include/configs/rastaban.h +++ b/include/configs/rastaban.h @@ -34,8 +34,6 @@ "led4=60,0,1\0" \ "led5=63,0,1\0"
/* Physical Memory Map */ diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index 459b077..120ea9b 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -18,7 +18,6 @@
/* Support File sytems */ #define CONFIG_FAT_WRITE -#define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_VFAT #define CONFIG_FS_EXT4 #define CONFIG_EXT4_WRITE diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index ec4d54e..99097e8 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -27,7 +27,6 @@
/* Support File sytems */ #define CONFIG_FAT_WRITE -#define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_VFAT #define CONFIG_FS_EXT4 #define CONFIG_EXT4_WRITE diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index 27dfbce..a088ad2 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -42,7 +42,6 @@ #define CONFIG_BOUNCE_BUFFER
#define CONFIG_FAT_WRITE -#define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART
#define CONFIG_SYS_SDRAM_BASE 0x60000000 diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 535797a..b830fbc 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -45,7 +45,6 @@ #define CONFIG_BOUNCE_BUFFER
/* RAW SD card / eMMC locations. */ diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index 9ec71c4..a7341dc 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -19,7 +19,6 @@ /* Enable gpt partition table */ #define CONFIG_CMD_GPT #define CONFIG_RANDOM_UUID -#define CONFIG_PARTITION_UUIDS #define PARTS_DEFAULT \ "uuid_disk=${uuid_gpt_disk};" \ "name=loader1,start=32K,size=4000K,uuid=${uuid_gpt_loader1};" \ diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 45d8824..5b4b03c 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -128,7 +128,6 @@ #define CONFIG_COMMAND_HISTORY
/* Commands */ -#define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART
/* ATAGs support for bootm/bootz */ diff --git a/include/configs/s32v234evb.h b/include/configs/s32v234evb.h index 9ee68dd..b506323 100644 --- a/include/configs/s32v234evb.h +++ b/include/configs/s32v234evb.h @@ -85,7 +85,6 @@ #define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC /* #define CONFIG_CMD_EXT2 EXT2 Support */ -#define CONFIG_DOS_PARTITION
#if 0
diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 6a61e5c..788e44d 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -214,15 +214,11 @@ #define CONFIG_SAMSUNG_ONENAND 1 #define CONFIG_SYS_ONENAND_BASE 0xB0000000
-#define CONFIG_DOS_PARTITION 1 - /* write support for filesystems */ #define CONFIG_FAT_WRITE #define CONFIG_EXT4_WRITE
/* GPT */ -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000)
diff --git a/include/configs/sama5d2_ptc.h b/include/configs/sama5d2_ptc.h index 7a049d4..6fbd053 100644 --- a/include/configs/sama5d2_ptc.h +++ b/include/configs/sama5d2_ptc.h @@ -84,7 +84,6 @@
#if defined(CONFIG_CMD_USB) #define CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION #endif
/* Ethernet Hardware */ diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index 4f72c83..4800791 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -53,10 +53,6 @@ #define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "Atmel SAMA5D2 XPlained"
-#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_DOS_PARTITION -#endif - /* I2C */ #define AT24MAC_ADDR 0x5c #define AT24MAC_REG 0x9a diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index b840315..daf634f 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -96,7 +96,6 @@ #define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_BASE_OHCI #define CONFIG_SYS_USB_OHCI_SLOT_NAME "SAMA5D3 Xplained" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 -#define CONFIG_DOS_PARTITION #endif
#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 831a45c..bfb7f3b 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -128,7 +128,6 @@ #define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_BASE_OHCI #define CONFIG_SYS_USB_OHCI_SLOT_NAME "sama5d3" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 3 -#define CONFIG_DOS_PARTITION #endif
/* USB device */ diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index bcd5c37..520552f 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -82,10 +82,6 @@ #define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "Atmel SAMA5D4EK"
-#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_DOS_PARTITION -#endif - /* Ethernet Hardware */ #define CONFIG_MACB #define CONFIG_RMII diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index 9009730..4cd016d 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -82,10 +82,6 @@ #define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "Atmel SAMA5D4EK"
-#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_DOS_PARTITION -#endif - /* Ethernet Hardware */ #define CONFIG_MACB #define CONFIG_RMII diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 2daf02d..bcc13a4 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -44,17 +44,10 @@ #define CONFIG_CMD_CBFS #define CONFIG_CMD_CRAMFS #define CONFIG_CMD_PART -#define CONFIG_DOS_PARTITION #define CONFIG_HOST_MAX_DEVICES 4 #define CONFIG_CMD_MD5SUM
#define CONFIG_CMD_GPT -#define CONFIG_PARTITION_UUIDS -#define CONFIG_AMIGA_PARTITION -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION -#define CONFIG_ISO_PARTITION -#define CONFIG_MAC_PARTITION
/* * Size of malloc() pool, before and after relocation diff --git a/include/configs/sansa_fuze_plus.h b/include/configs/sansa_fuze_plus.h index 0b2821d..d97b15f 100644 --- a/include/configs/sansa_fuze_plus.h +++ b/include/configs/sansa_fuze_plus.h @@ -11,7 +11,6 @@
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index f02634b..3afe884 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -302,7 +302,6 @@
-#define CONFIG_DOS_PARTITION #undef CONFIG_SCSI_AHCI
#ifdef CONFIG_SCSI_AHCI diff --git a/include/configs/sc_sps_1.h b/include/configs/sc_sps_1.h index 56a23a6..b79ba49 100644 --- a/include/configs/sc_sps_1.h +++ b/include/configs/sc_sps_1.h @@ -16,7 +16,6 @@
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index ed8a51c..86a7eb4 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -219,9 +219,6 @@ #endif /* CONFIG_440EPX */
/* Partitions */ -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION -#define CONFIG_ISO_PARTITION
/* * Commands additional to the ones defined in amcc-common.h diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index e2af82d..9a59eec 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -18,8 +18,6 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_MD5SUM #define CONFIG_MD5 -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION
#define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp" diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index 0859109..c2b96a3 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -18,8 +18,6 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_MD5SUM #define CONFIG_MD5 -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION
#define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp" diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index 05b5faa..6fae73e 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -18,8 +18,6 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_MD5SUM #define CONFIG_MD5 -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION
#define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp" diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index a74fd60..1c3b701 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -16,9 +16,6 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_SH_ZIMAGEBOOT
-#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION - #define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC1,115200 root=/dev/nfs ip=dhcp"
diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index 9f22d4c..79dfe50 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -94,7 +94,6 @@ #ifdef CONFIG_CMD_IDE #define __io #define CONFIG_IDE_PREINIT -#define CONFIG_DOS_PARTITION #define CONFIG_MVSATA_IDE_USE_PORT0 #define CONFIG_MVSATA_IDE_USE_PORT1 #define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index e4d0ad9..2a9afb8 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -79,7 +79,6 @@
#define CONFIG_SPI #define CONFIG_OMAP3_SPI diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index 4292566..f605f10 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -187,8 +187,6 @@ #define CONFIG_SAMSUNG_ONENAND 1 #define CONFIG_SYS_ONENAND_BASE 0xE7100000
-#define CONFIG_DOS_PARTITION 1 - #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000)
/* diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index 8bd5806..0e079b0 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -64,7 +64,6 @@ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW -#define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_UHP_BASE #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h index a19a38b..d084fc5 100644 --- a/include/configs/snapper9g45.h +++ b/include/configs/snapper9g45.h @@ -67,8 +67,6 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_ATMEL #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 -#define CONFIG_DOS_PARTITION -#define CONFIG_PARTITION_UUIDS
/* MMC */ #define CONFIG_GENERIC_MMC diff --git a/include/configs/sniper.h b/include/configs/sniper.h index 0a3d242..4fbcee6 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -114,7 +114,6 @@ * Partitions */
/* diff --git a/include/configs/socfpga_arria5_socdk.h b/include/configs/socfpga_arria5_socdk.h index 3b0b416..bc4d3cd 100644 --- a/include/configs/socfpga_arria5_socdk.h +++ b/include/configs/socfpga_arria5_socdk.h @@ -10,7 +10,6 @@
/* U-Boot Commands */ #define CONFIG_SYS_NO_FLASH -#define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE #define CONFIG_HW_WATCHDOG
diff --git a/include/configs/socfpga_cyclone5_socdk.h b/include/configs/socfpga_cyclone5_socdk.h index 7ced6a6..5e317bb 100644 --- a/include/configs/socfpga_cyclone5_socdk.h +++ b/include/configs/socfpga_cyclone5_socdk.h @@ -10,7 +10,6 @@
diff --git a/include/configs/socfpga_de0_nano_soc.h b/include/configs/socfpga_de0_nano_soc.h index 6b9546e..361019c 100644 --- a/include/configs/socfpga_de0_nano_soc.h +++ b/include/configs/socfpga_de0_nano_soc.h @@ -10,7 +10,6 @@
diff --git a/include/configs/socfpga_de1_soc.h b/include/configs/socfpga_de1_soc.h index deec647..5e7a712 100644 --- a/include/configs/socfpga_de1_soc.h +++ b/include/configs/socfpga_de1_soc.h @@ -10,7 +10,6 @@
diff --git a/include/configs/socfpga_is1.h b/include/configs/socfpga_is1.h index cc07253..f102a18 100644 --- a/include/configs/socfpga_is1.h +++ b/include/configs/socfpga_is1.h @@ -11,7 +11,6 @@
diff --git a/include/configs/socfpga_mcvevk.h b/include/configs/socfpga_mcvevk.h index d1b31c4..d36fac6 100644 --- a/include/configs/socfpga_mcvevk.h +++ b/include/configs/socfpga_mcvevk.h @@ -10,7 +10,6 @@
diff --git a/include/configs/socfpga_sockit.h b/include/configs/socfpga_sockit.h index 3fceb31..16a85ae 100644 --- a/include/configs/socfpga_sockit.h +++ b/include/configs/socfpga_sockit.h @@ -10,7 +10,6 @@
diff --git a/include/configs/socfpga_socrates.h b/include/configs/socfpga_socrates.h index c9473df..0c8da60 100644 --- a/include/configs/socfpga_socrates.h +++ b/include/configs/socfpga_socrates.h @@ -10,7 +10,6 @@
diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index 0407f03..8624bb3 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -11,7 +11,6 @@ #define CONFIG_BOARD_EARLY_INIT_F
#define CONFIG_HW_WATCHDOG diff --git a/include/configs/socfpga_vining_fpga.h b/include/configs/socfpga_vining_fpga.h index c5555e6..205b10b 100644 --- a/include/configs/socfpga_vining_fpga.h +++ b/include/configs/socfpga_vining_fpga.h @@ -10,7 +10,6 @@
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 6480116..1bc5203 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -403,6 +403,5 @@ #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "ohci_pci" #define CONFIG_SYS_OHCI_SWAP_REG_ACCESS 1 -#define CONFIG_DOS_PARTITION 1
#endif /* __CONFIG_H */ diff --git a/include/configs/strider.h b/include/configs/strider.h index 3be2597..e052b5d 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -28,7 +28,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC83xx_ESDHC_ADDR
#define CONFIG_SYS_ALT_MEMTEST
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index b0bfc0d..508d8d5 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -337,7 +337,6 @@ extern int soft_i2c_gpio_scl;
#ifdef CONFIG_MMC #define CONFIG_FASTBOOT_FLASH_MMC_DEV 0 -#define CONFIG_EFI_PARTITION #endif #endif
diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index 0f59eb1..15c0e89 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -208,7 +208,6 @@ #define CONFIG_PCI_INDIRECT_BRIDGE
/* SATA */ @@ -226,7 +225,6 @@
#define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
#ifdef CONFIG_FMAN_ENET diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 44201a2..57eb63d 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -75,7 +75,6 @@ 115200} #define CONFIG_OMAP_HSMMC #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION
/* EHCI */ #define CONFIG_OMAP3_GPIO_5 diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index 03fc42c..cef482d 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -72,7 +72,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
/* GPIO banks */ #define CONFIG_OMAP3_GPIO_2 /* GPIO32 ..63 is in GPIO bank 2 */ diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 0dc4a28..0ef5a8e 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -53,8 +53,6 @@ #define CONFIG_CMD_PART
/* Filesystems / image support */ -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS
/* MMC */ #define CONFIG_SYS_FSL_USDHC_NUM 3 diff --git a/include/configs/tegra-common-post.h b/include/configs/tegra-common-post.h index 5144d5a..ac33c2f 100644 --- a/include/configs/tegra-common-post.h +++ b/include/configs/tegra-common-post.h @@ -125,12 +125,6 @@ #endif
/* remove partitions/filesystems */ -#ifdef CONFIG_DOS_PARTITION -#undef CONFIG_DOS_PARTITION -#endif -#ifdef CONFIG_EFI_PARTITION -#undef CONFIG_EFI_PARTITION -#endif #ifdef CONFIG_FS_EXT4 #undef CONFIG_FS_EXT4 #endif @@ -149,9 +143,6 @@ #endif
/* remove part command support */ -#ifdef CONFIG_PARTITION_UUIDS -#undef CONFIG_PARTITION_UUIDS -#endif
#ifdef CONFIG_CMD_PART #undef CONFIG_CMD_PART diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 23a0e78..11c75b2 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -55,7 +55,6 @@ #define CONFIG_COMMAND_HISTORY
/* turn on commonly used storage-related commands */ -#define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART
#define CONFIG_SYS_NO_FLASH diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 281593a..5db0b8c 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -76,8 +76,6 @@ #define CONFIG_SATA_MV #define CONFIG_LIBATA #define CONFIG_LBA48 -#define CONFIG_EFI_PARTITION -#define CONFIG_DOS_PARTITION
/* Additional FS support/configuration */ #define CONFIG_SUPPORT_VFAT diff --git a/include/configs/thuban.h b/include/configs/thuban.h index a235253..fc0fa63 100644 --- a/include/configs/thuban.h +++ b/include/configs/thuban.h @@ -27,8 +27,6 @@ "led0=103,1,0\0" \ "led1=64,0,1\0"
/* Physical Memory Map */ diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 86ab1e0..84d9796 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -115,7 +115,6 @@ #define CONFIG_OMAP_GPIO #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
/** * Physical Memory Map diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index d909f25..45411a4 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -54,7 +54,6 @@ #define CONFIG_OMAP_GPIO #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index dbe494a..b31b776 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -222,9 +222,7 @@ * enabled a number of useful commands and support. */ #if defined(CONFIG_MMC) || defined(CONFIG_USB_STORAGE) -#define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE -#define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART #endif
diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 28a80f5..2ec860c 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -194,7 +194,6 @@ /* USB Configuration */ #define CONFIG_USB_XHCI_KEYSTONE #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 -#define CONFIG_EFI_PARTITION #define CONFIG_FS_FAT #define CONFIG_USB_SS_BASE KS2_USB_SS_BASE #define CONFIG_USB_HOST_XHCI_BASE KS2_USB_HOST_XHCI_BASE diff --git a/include/configs/tplink_wdr4300.h b/include/configs/tplink_wdr4300.h index fefc902..6a10f12 100644 --- a/include/configs/tplink_wdr4300.h +++ b/include/configs/tplink_wdr4300.h @@ -64,8 +64,6 @@ #define CONFIG_EHCI_DESC_BIG_ENDIAN #define CONFIG_EHCI_IS_TDI
-#define CONFIG_DOS_PARTITION - /* * Diagnostics */ diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 1c36d07..f491fb4 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -90,7 +90,6 @@ /* MMC */ #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/ts4600.h b/include/configs/ts4600.h index 9b7bd1b..2219a53 100644 --- a/include/configs/ts4600.h +++ b/include/configs/ts4600.h @@ -19,7 +19,6 @@
/* U-Boot Commands */ #define CONFIG_SYS_NO_FLASH /* No NOR Flash */ -#define CONFIG_DOS_PARTITION
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/ts4800.h b/include/configs/ts4800.h index a451acf..94a277e 100644 --- a/include/configs/ts4800.h +++ b/include/configs/ts4800.h @@ -60,7 +60,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR MMC_SDHC1_BASE_ADDR
/* * Eth Configs diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 74f1373..e2e8e1f 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -123,7 +123,6 @@ /* USB */ #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 4 #define CONFIG_FAT_WRITE -#define CONFIG_DOS_PARTITION
/* SD/MMC */ #define CONFIG_SUPPORT_EMMC_BOOT diff --git a/include/configs/usb_a9263.h b/include/configs/usb_a9263.h index 075d9c9..a1ba428 100644 --- a/include/configs/usb_a9263.h +++ b/include/configs/usb_a9263.h @@ -104,7 +104,6 @@ #ifdef CONFIG_CMD_USB #define CONFIG_USB_ATMEL #define CONFIG_USB_OHCI_NEW -#define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00a00000 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" diff --git a/include/configs/v38b.h b/include/configs/v38b.h index 229c242..eabdd62 100644 --- a/include/configs/v38b.h +++ b/include/configs/v38b.h @@ -60,8 +60,6 @@ /* * Partitions */ -#define CONFIG_MAC_PARTITION 1 -#define CONFIG_DOS_PARTITION 1
/* * USB diff --git a/include/configs/vct.h b/include/configs/vct.h index 6ff22c2..22f170c 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -97,9 +97,6 @@ #endif
#if defined(CONFIG_CMD_USB) -#define CONFIG_DOS_PARTITION -#define CONFIG_ISO_PARTITION - #define CONFIG_SUPPORT_VFAT
/* diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index f026f35..3a4bfe8 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -128,7 +128,6 @@ /*#define CONFIG_MENU_SHOW*/ #define CONFIG_CMD_UNZIP #define CONFIG_CMD_ENV -#define CONFIG_DOS_PARTITION
/* BOOTP options */ #define CONFIG_BOOTP_BOOTFILESIZE diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index f122c98..5edd7b6 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -69,7 +69,6 @@ #define CONFIG_SYS_FSL_ESDHC_NUM 1
#define CONFIG_FEC_MXC #define CONFIG_MII diff --git a/include/configs/vinco.h b/include/configs/vinco.h index 07fe616..ae4b2ec 100644 --- a/include/configs/vinco.h +++ b/include/configs/vinco.h @@ -63,9 +63,7 @@ #define CONFIG_SYS_MMC_CLK_OD 500000
/* For generating MMC partitions */ -#define CONFIG_PARTITION_UUIDS #define CONFIG_RANDOM_UUID -#define CONFIG_EFI_PARTITION #define CONFIG_CMD_GPT
#endif @@ -83,10 +81,6 @@ #define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "L+G VInCo"
-#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_DOS_PARTITION -#endif - /* Ethernet Hardware */ #define CONFIG_PHY_SMSC #define CONFIG_MACB diff --git a/include/configs/vining_2000.h b/include/configs/vining_2000.h index 235574d..57cf9f5 100644 --- a/include/configs/vining_2000.h +++ b/include/configs/vining_2000.h @@ -112,8 +112,6 @@
#ifdef CONFIG_ENV_IS_IN_MMC #define CONFIG_SUPPORT_EMMC_BOOT -#define CONFIG_EFI_PARTITION -#define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_EMMC_RPMB #define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC4 eMMC */ /* 0=user, 1=boot0, 2=boot1, * 4..7=general0..3. */ diff --git a/include/configs/warp7.h b/include/configs/warp7.h index f4a9231..83285f5 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE #define CONFIG_SYS_MMC_IMG_LOAD_PART 1
#define CONFIG_DFU_ENV_SETTINGS \ diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index 4aaeea9..6b7af82 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -86,9 +86,6 @@
-#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION - #define CONFIG_MXC_GPIO
#define CONFIG_NET_RETRY_COUNT 100 diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index b08641f..cf9976b 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -108,7 +108,6 @@
/* * No NOR diff --git a/include/configs/x600.h b/include/configs/x600.h index 5e51f65..45bcf49 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -120,7 +120,6 @@
/* Filesystem support (for USB key) */ #define CONFIG_SUPPORT_VFAT -#define CONFIG_DOS_PARTITION
/* diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index 04d151b..52ff4b0 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -70,16 +70,11 @@ /************************************************************ * DISK Partition support ************************************************************/ -#define CONFIG_EFI_PARTITION -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION /* Experimental */
#define CONFIG_CMD_PART #ifdef CONFIG_SYS_COREBOOT #define CONFIG_CMD_CBFS #endif -#define CONFIG_PARTITION_UUIDS
/* x86 GPIOs are accessed through a PCI device */ #define CONFIG_INTEL_ICH6_GPIO diff --git a/include/configs/xfi3.h b/include/configs/xfi3.h index ae9ab71..8e9b5d7 100644 --- a/include/configs/xfi3.h +++ b/include/configs/xfi3.h @@ -11,7 +11,6 @@
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 74cbfcf..d7a9bab 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -56,11 +56,6 @@
/* Command line configuration */ #define CONFIG_CMD_ENV -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION -#ifndef CONFIG_SPL_BUILD -# define CONFIG_ISO_PARTITION -#endif #define CONFIG_MP
/* BOOTP options */ diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index 35e6350..6346f84 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -337,7 +337,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_DOS_PARTITION
/* * Command configuration. diff --git a/include/configs/yosemite.h b/include/configs/yosemite.h index a355112..55dd365 100644 --- a/include/configs/yosemite.h +++ b/include/configs/yosemite.h @@ -158,9 +158,6 @@ #define CONFIG_PHY1_ADDR 3
#ifdef CONFIG_440EP /* USB */ diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index a30aefb..7c2a92d 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -65,7 +65,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_PXA_MMC_GENERIC #define CONFIG_SYS_MMC_BASE 0xF0000000 -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index 7038e6b..6df4761 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -91,7 +91,6 @@ #define CONFIG_MXC_USB_PORTSC MXC_EHCI_MODE_SERIAL #define CONFIG_MXC_USB_FLAGS (MXC_EHCI_INTERNAL_PHY | MXC_EHCI_IPPUE_DOWN) #define CONFIG_EHCI_IS_TDI -#define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_VFAT #endif /* CONFIG_CMD_USB */
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 2fe6897..3ec760b 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -133,7 +133,6 @@ #if defined(CONFIG_ZYNQ_SDHCI) || defined(CONFIG_ZYNQ_USB) # define CONFIG_SUPPORT_VFAT # define CONFIG_FAT_WRITE -# define CONFIG_DOS_PARTITION #endif
#if defined(CONFIG_ZYNQ_I2C0) || defined(CONFIG_ZYNQ_I2C1) diff --git a/include/part.h b/include/part.h index 0979005..243bcfd 100644 --- a/include/part.h +++ b/include/part.h @@ -255,7 +255,7 @@ struct part_driver { #define U_BOOT_PART_TYPE(__name) \ ll_entry_declare(struct part_driver, __name, part_driver)
-#ifdef CONFIG_EFI_PARTITION +#if CONFIG_IS_ENABLED(EFI_PARTITION) #include <part_efi.h> /* disk/part_efi.c */ /** @@ -365,7 +365,7 @@ int gpt_verify_partitions(struct blk_desc *dev_desc, gpt_header *gpt_head, gpt_entry **gpt_pte); #endif
-#ifdef CONFIG_DOS_PARTITION +#if CONFIG_IS_ENABLED(DOS_PARTITION) /** * is_valid_dos_buf() - Ensure that a DOS MBR image is valid * diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 1e3dca4..39e602a 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -251,7 +251,7 @@ static int efi_disk_create_eltorito(struct blk_desc *desc, const char *pdevname) { int disks = 0; -#ifdef CONFIG_ISO_PARTITION +#if CONFIG_IS_ENABLED(ISO_PARTITION) char devname[32] = { 0 }; /* dp->str is u16[32] long */ disk_partition_t info; int part = 1; diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 00ee3f1..e85e75d 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -93,7 +93,6 @@ CONFIG_AMCC_DEF_ENV_PPC CONFIG_AMCC_DEF_ENV_PPC_OLD CONFIG_AMCC_DEF_ENV_ROOTPATH CONFIG_AMCORE -CONFIG_AMIGA_PARTITION CONFIG_ANDES_PCU CONFIG_ANDES_PCU_BASE CONFIG_AP325RXA @@ -851,7 +850,6 @@ CONFIG_DMC_DDRTR1 CONFIG_DMC_DDRTR2 CONFIG_DNET_AUTONEG_TIMEOUT CONFIG_DNP5370_EXT_WD_DISABLE -CONFIG_DOS_PARTITION CONFIG_DP_DDR_CTRL CONFIG_DP_DDR_DIMM_SLOTS_PER_CTLR CONFIG_DP_DDR_NUM_CTRLS @@ -984,7 +982,6 @@ CONFIG_EEPRO100_SROM_WRITE CONFIG_EEPROM_BUS_ADDRESS CONFIG_EEPROM_CHIP_ADDRESS CONFIG_EEPROM_LAYOUT_HELP_STRING -CONFIG_EFI_PARTITION CONFIG_EFLASH_PROTSECTORS CONFIG_EHCI_DESC_BIG_ENDIAN CONFIG_EHCI_HCD_INIT_AFTER_RESET @@ -1668,7 +1665,6 @@ CONFIG_IRAM_SIZE CONFIG_IRAM_STACK CONFIG_IRAM_TOP CONFIG_IRDA_BASE -CONFIG_ISO_PARTITION CONFIG_ISP1362_USB CONFIG_IS_BUILTIN CONFIG_IS_ENABLED @@ -2967,7 +2963,6 @@ CONFIG_MACRESET_TIMEOUT CONFIG_MAC_ADDR_IN_EEPROM CONFIG_MAC_ADDR_IN_SPIFLASH CONFIG_MAC_OFFSET -CONFIG_MAC_PARTITION CONFIG_MAKALU CONFIG_MALLOC_F_ADDR CONFIG_MALTA @@ -3333,9 +3328,6 @@ CONFIG_PALMAS_SMPS7_FPWM CONFIG_PALMAS_USB_SS_PWR CONFIG_PANIC_HANG CONFIG_PARAVIRT -CONFIG_PARTITIONS -CONFIG_PARTITION_TYPE_GUID -CONFIG_PARTITION_UUIDS CONFIG_PATA_BFIN CONFIG_PATI CONFIG_PB1000
On Tue, Jan 24, 2017 at 10:56:55AM +0100, Patrick Delaunay wrote:
This converts the following to Kconfig: CONFIG_PARTITIONS CONFIG_MAC_PARTITION CONFIG_DOS_PARTITION CONFIG_ISO_PARTITION CONFIG_AMIGA_PARTITION CONFIG_EFI_PARTITION CONFIG_PARTITION_UUIDS CONFIG_PARTITION_TYPE_GUID
Specific SPL config are added to reduce SPL size for some target and solve compilation issues
CONFIG_SPL_MAC_PARTITION CONFIG_SPL_DOS_PARTITION CONFIG_SPL_ISO_PARTITION CONFIG_SPL_AMIGA_PARTITION CONFIG_SPL_EFI_PARTITION
Associated test are updated to the correct CONFIG (SPL or not) by using macro CONFIG_IS_ENABLED
To update the U-Boot code I use : 0- Resync with savedefconfig /tools/moveconfig.py -s -Cy
1- update defconfig for new SPL option ./tools/moveconfig.py --spl --commit \ PARTITIONS MAC_PARTITION DOS_PARTITION \ ISO_PARTITION AMIGA_PARTITION EFI_PARTITION \ PARTITION_UUIDS PARTITION_TYPE_GUID
then replace CONFIG by CONFIG_SPL in defconfig sed -i "s/CONFIG_\(DOS\|EFI\|ISO\|MAC\|AMIGA\)_PARTITION/CONFIG_SPL_\1_PARTITION/" \ configs/*
2- update defconfig for existing option ./tools/moveconfig.py --commit --yes \ PARTITIONS MAC_PARTITION DOS_PARTITION \ ISO_PARTITION AMIGA_PARTITION EFI_PARTITION \ PARTITION_UUIDS PARTITION_TYPE_GUID
=> squash the 2 modifications
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Patrick Delaunay patrick.delaunay73@gmail.com
I played with this a lot tonight. I think, sadly, we're going the wrong direction in this conversion. I believe I had originally suggested a patch, but that's not right. Lets get one patch per partition type, as that will make finding and correcting the conversion easier. Thanks!
Patrick Delaunay
