[U-Boot-Users] Questions of uImage on sbc8260 board
The uImage is loaded onto RAM of sbc8260/ATM board. After starting the uImage, the msg shows:
=>bootm ## Booting image at 00100000 ... Image Name: Linux-2.4.24-pre2 Created: 2004-12-03 0:48:37 UTC Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 632448 Bytes = 617.6 kB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK ## Current stack ends at 0x03F75B60 => set upper limit to 0x00800000 ## cmdline at 0x007FFF00 ... 0x007FFF00 bd address = 0x03F75FB4 memstart = 0x00000000 memsize = 0x04000000 flashstart = 0x40000000 flashsize = 0x00400000 flashoffset = 0x00025000 sramstart = 0x00000000 sramsize = 0x00000000 immr_base = 0xF0000000 bootflags = 0x00000001 vco = 264 MHz sccfreq = 66 MHz brgfreq = 66 MHz intfreq = 198 MHz cpmfreq = 132 MHz busfreq = 33 MHz ethaddr = 00:A0:1E:A8:7B:CB IP addr = 10.0.0.99 baudrate = 115200 bps No initrd ## Transferring control to Linux (at address 00000000) ... Memory BAT mapping: BAT2=64Mb, BAT3=0Mb, residual: 0Mb Linux version 2.4.24-pre2 (root@localhost.localdomain) (gcc version 3.2.2 20030217 (Yellow Dog Linux 3.0 3.2.2-2a_1)) #1 Thu Dec 2 19:38:30 EST 2004 On node 0 totalpages: 16384 zone(0): 16384 pages. zone(1): 0 pages. zone(2): 0 pages. Kernel command line:
Warning: real time clock seems stuck! <<-- ???
Calibrating delay loop... 131.89 BogoMIPS Memory: 63220k available (1096k kernel code, 384k data, 56k init, 0k highmem) Dentry cache hash table entries: 8192 (order: 4, 65536 bytes) Inode cache hash table entries: 4096 (order: 3, 32768 bytes) Mount cache hash table entries: 512 (order: 0, 4096 bytes) Buffer cache hash table entries: 4096 (order: 2, 16384 bytes) Page-cache hash table entries: 16384 (order: 4, 65536 bytes) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Initializing RT netlink socket Starting kswapd JFFS2 version 2.1. (C) 2001 Red Hat, Inc., designed by Axis Communications AB. CPM UART driver version 0.01 ttyS0 on SMC1 at 0x0000, BRG7 ttyS1 on SMC2 at 0x0040, BRG8 ttyS2 on SCC1 at 0x8000, BRG1 ttyS3 on SCC2 at 0x8100, BRG2 pty: 256 Unix98 ptys configured eth0: FCC2 ENET Version 0.4, 00:A0:1E:A8:7B:CC RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
CFI: Found no TQM8260 Bank 0 device at location zero <<--??
TQM8260: No supported flash chips found! <<-- ??
NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 4096 bind 8192) NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
VFS: Cannot open root device "" or 00:00 <<--?? Please append a correct "root=" boot option <<--?? Kernel panic: VFS: Unable to mount root fs on 00:00 <<--??
<0>Rebooting in 180 seconds..
Then, system hung.
The u-boot envs are: => printenv bootcmd=version;echo;bootp;setenv bootargs root=/dev/nfs rw nfsroot=$(serverip):$(rootpath) ip=$(ipaddr):$(serverip):$(gatewayip):$(netmask):$(hostname)::off;bootm bootdelay=5 baudrate=9600 ethaddr=00:a0:1e:a8:7b:cb loads_echo=1 do_echo=1 ipaddr=10.0.0.99 serverip=10.0.0.2 netmask=255.0.0.0 hostname=sbc8260 stdin=serial stdout=serial stderr=serial ver=U-Boot 1.0.2 (Nov 27 2004 - 10:55:29)
Environment size: 392/262140 bytes
The uImage is build by using TQM8260_config.
Q1. Can the uImage build by using TQM8260_config can be used on sbc8260 board? If can not, which config I should use?
Q2. I marked several places above by "<<--??". Any one see those before? If you do, please let me know how to fix them.
Thanks,
dd
__________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
You're off topic here. This is the U-Boot mailing list. There are other lists for Linux.
Your real time clock does not tick.
You're using a TQM8260 configuration on a non-TQM8260 board. This cannot work.
You passed an empty (or blank-filled?) command line, so how should the kernel know where to find the root filesystem?
This makes no sense at all. Commands are execurted in order. SO you first boot the linux kernel (bootp), and then try to set bootargs - but the "then" will never happen as U-Boot dows not continue to run after Linux took over.
OK, so we finally got some U-Boot stuff here, and you are not completely off topic ;-)
Of course you can build an uImage using the TQM8260 configuration. But this uImage will only be useful for TQM8260 boards. You must not assume that it might run on any other hardware.
See above.
This is normal for the sbc8260 and sbc8260ATM - there is no real-time clock chip on board. Don't worry about it.
Your using a build for the wrong board. There is a working build for the SBC8260 which should work for the ATM version.
You need to specify a valid boot line to tell the kernel to use NFS for the root file system.
Use the sbc8260_config. You may need to edit the sbc8260.h file for you clock settings, etc.
See comments above.
If you need more help then let me know. I don't have an SBC8260ATM to hand today, but I can get one.
Rich
Thanks for you and Wolfgong's help. Now I can just skip the msg of real time clock.
I made some changes of config file and the linux starts booting without FLASH error msgs.
1. NFS
00:00 You need to specify a valid boot line to tell the kernel to use NFS for the root file system.
Do I have to use NFS to boot ? My server has problem and I'm using serial port only now. Is there another way to avoid using server? If I can, what steps I should follow?
2. I'm trying to use ramdisk because the server is off and get errors. The kernel is build with reamdisk and loaded into RAM.
The envs are as: => printenv bootdelay=5 ethaddr=00:a0:1e:a8:7b:cb loads_echo=1 do_echo=1 ipaddr=10.0.0.99 serverip=10.0.0.2 netmask=255.0.0.0 hostname=SBC8260 rootpath=/opt/ELDK/ppc_82xx bootcmd=bootp filesize=1E661A bootargs=boot=/dev/ram rw stdin=serial stdout=serial stderr=serial ver=U-Boot 1.0.2 (Nov 27 2004 - 10:55:29) baudrate=57600
3. => bootm ## Booting image at 00400000 ... Image Name: Linux Multiboot-Image Created: 2004-12-07 18:20:37 UTC Image Type: PowerPC Linux Multi-File Image (gzip compressed) Data Size: 1992154 Bytes = 1.9 MB Load Address: 00000000 Entry Point: 00000000 Contents: Image 0: 591944 Bytes = 578.1 kB Image 1: 1400198 Bytes = 1.3 MB Verifying Checksum ... OK Uncompressing Multi-File Image ... OK ## Current stack ends at 0x03F75B60 => set upper limit to 0x00800000 ## cmdline at 0x007FFF00 ... 0x007FFF10 bd address = 0x03F75FB4 memstart = 0x00000000 memsize = 0x04000000 flashstart = 0x40000000 flashsize = 0x00400000 flashoffset = 0x00025000 sramstart = 0x00000000 sramsize = 0x00000000 immr_base = 0xF0000000 bootflags = 0x00000001 vco = 264 MHz sccfreq = 66 MHz brgfreq = 66 MHz intfreq = 198 MHz cpmfreq = 132 MHz busfreq = 33 MHz ethaddr = 00:A0:1E:A8:7B:CB IP addr = 10.0.0.99 baudrate = 57600 bps ## initrd at 0x00490894 ... 0x005E6619 (len=1400198=0x155D86) Loading Ramdisk to 03e1f000, end 03f74d86 ... OK ## Transferring control to Linux (at address 00000000) ... Memory BAT mapping: BAT2=64Mb, BAT3=0Mb, residual: 0Mb Linux version 2.4.24-pre2 (root@localhost.localdomain) (gcc version 3.2.2 20030217 (Yellow Dog Linux 3.0 3.2.2- 2a_1)) #1 Sun Dec 5 14:04:57 EST 2004 On node 0 totalpages: 16384 zone(0): 16384 pages. zone(1): 0 pages. zone(2): 0 pages. Kernel command line: boot=/dev/ram rw Calibrating delay loop... 131.89 BogoMIPS Memory: 61928k available (1028k kernel code, 376k data, 56k init, 0k highmem) Dentry cache hash table entries: 8192 (order: 4, 65536 bytes) Inode cache hash table entries: 4096 (order: 3, 32768 bytes) Mount cache hash table entries: 512 (order: 0, 4096 bytes) Buffer cache hash table entries: 4096 (order: 2, 16384 bytes) Page-cache hash table entries: 16384 (order: 4, 65536 bytes) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Initializing RT netlink socket Starting kswapd CPM UART driver version 0.01 ttyS0 on SMC1 at 0x0000, BRG7 ttyS1 on SMC2 at 0x0040, BRG8 ttyS2 on SCC1 at 0x8000, BRG1 ttyS3 on SCC2 at 0x8100, BRG2 pty: 256 Unix98 ptys configured eth0: FCC2 ENET Version 0.4, 00:A0:1E:A8:7B:CC RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize loop: loaded (max 8 devices) NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP, IGMP IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 4096 bind 8192) NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. RAMDISK: Compressed image found at block 0 crc error<6>Freeing initrd memory: 1367k freed <<--?? VFS: Cannot open root device "" or 00:00 <<-- Please append a correct "root=" boot option Kernel panic: VFS: Unable to mount root fs on 00:00 <<-- <0>Rebooting in 180 seconds..
4. I did not rebuild the ramdisk image, just use the one from SELF. Do I need rebuild it?
Thanks again,
dd
zero
00:00
can
I
should use?
one
how to
fix them.
See comments above.
Rich
Please take this discussion off this list. It has nothing to do with U-Boot and is off topic here.
duo dong wrote:
- NFS
No, you do not _have_ to use NFS, but it is a lot easier than using a RAMDISK when your developing apps.
- I'm trying to use ramdisk because the server is off
How exactly are you loading the kernel/ramdisk image?
- => bootm
<snip>
I'm not sure what is causing this, was the image corrupted when you downloaded? Maybe someone else can help us here..?
Your boot options should have root=/dev/ram0
- I did not rebuild the ramdisk image, just use the
I used one of the Denx ramdisks with no problems and didn't need to rebuild anything. I didn't build a unified kernel/ramdisk image though, I just loaded the kernel and then the example ramdisk unchanged. Try that.
Rich
Sorry all, didn't mean to reply to the whole list.
Rich
Richard Danter wrote:
duo dong wrote:
- NFS
- => bootm
<snip>
Rich
SF email is sponsored by - The IT Product Guide Read honest & candid reviews on hundreds of IT Products from real users. Discover which products truly live up to the hype. Start reading now. http://productguide.itmanagersjournal.com/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
This time, I loaded the uImage to 100000 and pRamdis to 200000. The boot code transfers control to Linux as following: ## Transferring control to Linux (at address 00000000) ... Memory BAT mapping: BAT2=64Mb, BAT3=0Mb, residual: 0Mb Linux version 2.4.24-pre2 (root@localhost.localdomain) (gcc version 3.2.2 20030217 (Yellow Dog Linux 3.0 3.2.2-2a_1)) #1 Sun Dec 5 14:04:57 EST 2004 On node 0 totalpages: 16384 zone(0): 16384 pages. zone(1): 0 pages. zone(2): 0 pages. Kernel command line: root=/dev/ram0 rw Warning: real time clock seems stuck! Calibrating delay loop... 131.89 BogoMIPS Memory: 61928k available (1028k kernel code, 376k data, 56k init, 0k highmem) Dentry cache hash table entries: 8192 (order: 4, 65536 bytes) Inode cache hash table entries: 4096 (order: 3, 32768 bytes) Mount cache hash table entries: 512 (order: 0, 4096 bytes) Buffer cache hash table entries: 4096 (order: 2, 16384 bytes) Page-cache hash table entries: 16384 (order: 4, 65536 bytes) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Initializing RT netlink socket Starting kswapd CPM UART driver version 0.01 ttyS0 on SMC1 at 0x0000, BRG7 ttyS1 on SMC2 at 0x0040, BRG8 ttyS2 on SCC1 at 0x8000, BRG1 ttyS3 on SCC2 at 0x8100, BRG2 pty: 256 Unix98 ptys configured eth0: FCC2 ENET Version 0.4, 00:A0:1E:A8:7B:CC RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize loop: loaded (max 8 devices) NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP, IGMP IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 4096 bind 8192) NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. RAMDISK: Compressed image found at block 0
The crc error is still there as: RAMDISK: Compressed image found at block 0 crc error<6>Freeing initrd memory: 1367k freed VFS: Mounted root (ext2 filesystem). Freeing unused kernel memory: 56k init
Then, system stuck.
Someoen can help on this?? please!!
boot=/dev/ram rw.
Thanks, I made a mistake, it should be root=/dev/ram0 rw, not boot=/...
Sorry I response too late. I have another project on hand, so I can only work on this one couple hours a day.
dd
I think I told you before: this is the U-Boot mailing list, and general Linux questions are OFF TOPIC here.
That ain't good ;)
<0>Rebooting in 180 seconds.. The u-boot envs are: => printenv bootcmd=version;echo;bootp;setenv bootargs root=/dev/nfs rw nfsroot=$(serverip):$(rootpath) ip=$(ipaddr):$(serverip):$(gatewayip):$(netmask):$(hostname)::off;bootm bootdelay=5 baudrate=9600 ethaddr=00:a0:1e:a8:7b:cb loads_echo=1 do_echo=1 ipaddr=10.0.0.99 serverip=10.0.0.2 netmask=255.0.0.0 hostname=sbc8260 stdin=serial stdout=serial stderr=serial ver=U-Boot 1.0.2 (Nov 27 2004 - 10:55:29)
you don't have any "bootargs" setup!! this might be it
If I understand correctly your problem, it is quite simple actually. You need a variable "bootargs" to be passed to the kernel... you could do something like that:
setenv console=ttyS0,9600 ip=$(ipaddr) root=$(root)
type that and with your u-boot settings, it should work.
good luck Raphaël
Ccool
duo dong
Richard Danter
