[U-Boot] [PATCH 1/3] imx: consolidate set_chipselect_size function
Move MX5 specific set_chipselect_size function into generic i.MX part, such that MX6 based boards are able to use this function as well.
While doing this the iomuxc gpr member needed to be consolidated between MX5 and MX6.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx5/soc.c | 31 ------------------------------- arch/arm/imx-common/cpu.c | 31 +++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-imx/cpu.h | 5 +++++ arch/arm/include/asm/arch-mx5/imx-regs.h | 12 ++---------- arch/arm/include/asm/arch-mx6/sys_proto.h | 1 + 5 files changed, 39 insertions(+), 41 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx5/soc.c b/arch/arm/cpu/armv7/mx5/soc.c index 2d53669..3753c14 100644 --- a/arch/arm/cpu/armv7/mx5/soc.c +++ b/arch/arm/cpu/armv7/mx5/soc.c @@ -85,37 +85,6 @@ void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) } #endif
-void set_chipselect_size(int const cs_size) -{ - unsigned int reg; - struct iomuxc *iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; - reg = readl(&iomuxc_regs->gpr1); - - switch (cs_size) { - case CS0_128: - reg &= ~0x7; /* CS0=128MB, CS1=0, CS2=0, CS3=0 */ - reg |= 0x5; - break; - case CS0_64M_CS1_64M: - reg &= ~0x3F; /* CS0=64MB, CS1=64MB, CS2=0, CS3=0 */ - reg |= 0x1B; - break; - case CS0_64M_CS1_32M_CS2_32M: - reg &= ~0x1FF; /* CS0=64MB, CS1=32MB, CS2=32MB, CS3=0 */ - reg |= 0x4B; - break; - case CS0_32M_CS1_32M_CS2_32M_CS3_32M: - reg &= ~0xFFF; /* CS0=32MB, CS1=32MB, CS2=32MB, CS3=32MB */ - reg |= 0x249; - break; - default: - printf("Unknown chip select size: %d\n", cs_size); - break; - } - - writel(reg, &iomuxc_regs->gpr1); -} - #ifdef CONFIG_MX53 void boot_mode_apply(unsigned cfg_val) { diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index 09fc227..24740b8 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -187,3 +187,34 @@ void arch_preboot_os(void) ipuv3_fb_shutdown(); } #endif + +void set_chipselect_size(int const cs_size) +{ + unsigned int reg; + struct iomuxc *iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; + reg = readl(&iomuxc_regs->gpr[1]); + + switch (cs_size) { + case CS0_128: + reg &= ~0x7; /* CS0=128MB, CS1=0, CS2=0, CS3=0 */ + reg |= 0x5; + break; + case CS0_64M_CS1_64M: + reg &= ~0x3F; /* CS0=64MB, CS1=64MB, CS2=0, CS3=0 */ + reg |= 0x1B; + break; + case CS0_64M_CS1_32M_CS2_32M: + reg &= ~0x1FF; /* CS0=64MB, CS1=32MB, CS2=32MB, CS3=0 */ + reg |= 0x4B; + break; + case CS0_32M_CS1_32M_CS2_32M_CS3_32M: + reg &= ~0xFFF; /* CS0=32MB, CS1=32MB, CS2=32MB, CS3=32MB */ + reg |= 0x249; + break; + default: + printf("Unknown chip select size: %d\n", cs_size); + break; + } + + writel(reg, &iomuxc_regs->gpr[1]); +} diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h index a3cc96f..254136e 100644 --- a/arch/arm/include/asm/arch-imx/cpu.h +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -12,3 +12,8 @@ #define MXC_CPU_MX6Q 0x63 #define MXC_CPU_MX6D 0x64 #define MXC_CPU_MX6SOLO 0x65 /* dummy ID */ + +#define CS0_128 0 +#define CS0_64M_CS1_64M 1 +#define CS0_64M_CS1_32M_CS2_32M 2 +#define CS0_32M_CS1_32M_CS2_32M_CS3_32M 3 diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 054c680..f059d0f 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -202,11 +202,6 @@ */ #define WBED 1
-#define CS0_128 0 -#define CS0_64M_CS1_64M 1 -#define CS0_64M_CS1_32M_CS2_32M 2 -#define CS0_32M_CS1_32M_CS2_32M_CS3_32M 3 - /* * CSPI register definitions */ @@ -414,8 +409,7 @@ struct weim {
#if defined(CONFIG_MX51) struct iomuxc { - u32 gpr0; - u32 gpr1; + u32 gpr[2]; u32 omux0; u32 omux1; u32 omux2; @@ -424,9 +418,7 @@ struct iomuxc { }; #elif defined(CONFIG_MX53) struct iomuxc { - u32 gpr0; - u32 gpr1; - u32 gpr2; + u32 gpr[3]; u32 omux0; u32 omux1; u32 omux2; diff --git a/arch/arm/include/asm/arch-mx6/sys_proto.h b/arch/arm/include/asm/arch-mx6/sys_proto.h index c35a905..28ba844 100644 --- a/arch/arm/include/asm/arch-mx6/sys_proto.h +++ b/arch/arm/include/asm/arch-mx6/sys_proto.h @@ -26,6 +26,7 @@ u32 get_cpu_rev(void);
const char *get_imx_type(u32 imxtype); unsigned imx_ddr_size(void); +void set_chipselect_size(int const);
/* * Initializes on-chip ethernet controllers.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/include/asm/arch-mx6/imx-regs.h | 37 ++++++++++++++++++++++++++++++++ 1 file changed, 37 insertions(+)
diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index a159309..5314298 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -332,6 +332,43 @@ extern void imx_get_mac_from_fuse(int dev_id, unsigned char *mac); #define SRC_SCR_CORE_3_ENABLE_OFFSET 24 #define SRC_SCR_CORE_3_ENABLE_MASK (1<<SRC_SCR_CORE_3_ENABLE_OFFSET)
+/* WEIM registers */ +struct weim { + u32 cs0gcr1; + u32 cs0gcr2; + u32 cs0rcr1; + u32 cs0rcr2; + u32 cs0wcr1; + u32 cs0wcr2; + + u32 cs1gcr1; + u32 cs1gcr2; + u32 cs1rcr1; + u32 cs1rcr2; + u32 cs1wcr1; + u32 cs1wcr2; + + u32 cs2gcr1; + u32 cs2gcr2; + u32 cs2rcr1; + u32 cs2rcr2; + u32 cs2wcr1; + u32 cs2wcr2; + + u32 cs3gcr1; + u32 cs3gcr2; + u32 cs3rcr1; + u32 cs3rcr2; + u32 cs3wcr1; + u32 cs3wcr2; + + u32 unused[12]; + + u32 wcr; + u32 wiar; + u32 ear; +}; + /* System Reset Controller (SRC) */ struct src { u32 scr;
Best regards, Stefano Babic
mx6sabreauto boards come with 32 MiB of parallel NOR flash.
Add support for it:
U-Boot 2015.01-rc1-18107-g1543636-dirty (Nov 14 2014 - 11:11:04)
CPU: Freescale i.MX6Q rev1.2 at 792 MHz Reset cause: POR Board: MX6Q-Sabreauto revA I2C: ready DRAM: 2 GiB Flash: 32 MiB NAND: 0 MiB
Due to pin conflict with I2C3, only define configure I2C3 IOMUX when flash is not used.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx6qsabreauto/mx6qsabreauto.c | 80 ++++++++++++++++++++++++++- include/configs/mx6qsabreauto.h | 10 ++++ 2 files changed, 89 insertions(+), 1 deletion(-)
diff --git a/board/freescale/mx6qsabreauto/mx6qsabreauto.c b/board/freescale/mx6qsabreauto/mx6qsabreauto.c index c35dcaf..15df171 100644 --- a/board/freescale/mx6qsabreauto/mx6qsabreauto.c +++ b/board/freescale/mx6qsabreauto/mx6qsabreauto.c @@ -53,6 +53,10 @@ DECLARE_GLOBAL_DATA_PTR;
#define PC MUX_PAD_CTRL(I2C_PAD_CTRL)
+#define WEIM_NOR_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + int dram_init(void) { gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); @@ -97,6 +101,7 @@ static struct i2c_pads_info i2c_pad_info1 = { } };
+#ifndef CONFIG_SYS_FLASH_CFI /* * I2C3 MLB, Port Expanders (A, B, C), Video ADC, Light Sensor, * Compass Sensor, Accelerometer, Res Touch @@ -113,6 +118,7 @@ static struct i2c_pads_info i2c_pad_info2 = { .gp = IMX_GPIO_NR(3, 18) } }; +#endif
static iomux_v3_cfg_t const i2c3_pads[] = { MX6_PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL), @@ -160,6 +166,75 @@ static int port_exp_direction_output(unsigned gpio, int value) return 0; }
+static iomux_v3_cfg_t const eimnor_pads[] = { + MX6_PAD_EIM_D16__EIM_DATA16 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D17__EIM_DATA17 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D18__EIM_DATA18 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D19__EIM_DATA19 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D20__EIM_DATA20 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D21__EIM_DATA21 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D22__EIM_DATA22 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D23__EIM_DATA23 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D24__EIM_DATA24 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D25__EIM_DATA25 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D26__EIM_DATA26 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D27__EIM_DATA27 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D28__EIM_DATA28 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D29__EIM_DATA29 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D30__EIM_DATA30 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_D31__EIM_DATA31 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA0__EIM_AD00 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA1__EIM_AD01 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA2__EIM_AD02 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA3__EIM_AD03 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA4__EIM_AD04 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA5__EIM_AD05 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA6__EIM_AD06 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA7__EIM_AD07 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA8__EIM_AD08 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA9__EIM_AD09 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA10__EIM_AD10 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA11__EIM_AD11 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL) , + MX6_PAD_EIM_DA12__EIM_AD12 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA13__EIM_AD13 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA14__EIM_AD14 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_DA15__EIM_AD15 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_A16__EIM_ADDR16 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_A17__EIM_ADDR17 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_A18__EIM_ADDR18 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_A19__EIM_ADDR19 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_A20__EIM_ADDR20 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_A21__EIM_ADDR21 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_A22__EIM_ADDR22 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_A23__EIM_ADDR23 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), + MX6_PAD_EIM_OE__EIM_OE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_RW__EIM_RW | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_CS0__EIM_CS0_B | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void eimnor_cs_setup(void) +{ + struct weim *weim_regs = (struct weim *)WEIM_BASE_ADDR; + + writel(0x00020181, &weim_regs->cs0gcr1); + writel(0x00000001, &weim_regs->cs0gcr2); + writel(0x0a020000, &weim_regs->cs0rcr1); + writel(0x0000c000, &weim_regs->cs0rcr2); + writel(0x0804a240, &weim_regs->cs0wcr1); + writel(0x00000120, &weim_regs->wcr); + + set_chipselect_size(CS0_128); +} + +static void setup_iomux_eimnor(void) +{ + imx_iomux_v3_setup_multiple_pads(eimnor_pads, ARRAY_SIZE(eimnor_pads)); + + gpio_direction_output(IMX_GPIO_NR(5, 4), 0); + + eimnor_cs_setup(); +} + static void setup_iomux_enet(void) { imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); @@ -402,6 +477,7 @@ int board_early_init_f(void) #ifdef CONFIG_NAND_MXS setup_gpmi_nand(); #endif + return 0; }
@@ -415,11 +491,13 @@ int board_init(void) /* I2C 3 Steer */ gpio_direction_output(IMX_GPIO_NR(5, 4), 1); imx_iomux_v3_setup_multiple_pads(i2c3_pads, ARRAY_SIZE(i2c3_pads)); +#ifndef CONFIG_SYS_FLASH_CFI setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2); - +#endif gpio_direction_output(IMX_GPIO_NR(1, 15), 1); imx_iomux_v3_setup_multiple_pads(port_exp, ARRAY_SIZE(port_exp));
+ setup_iomux_eimnor(); return 0; }
diff --git a/include/configs/mx6qsabreauto.h b/include/configs/mx6qsabreauto.h index 3f1c88e..559937a 100644 --- a/include/configs/mx6qsabreauto.h +++ b/include/configs/mx6qsabreauto.h @@ -37,6 +37,16 @@
#include "mx6sabre_common.h"
+#undef CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_FLASH_BASE WEIM_ARB_BASE_ADDR +#define CONFIG_SYS_FLASH_SECT_SIZE (128 * 1024) +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ +#define CONFIG_SYS_FLASH_CFI /* Flash memory is CFI compliant */ +#define CONFIG_FLASH_CFI_DRIVER /* Use drivers/cfi_flash.c */ +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* Use buffered writes*/ +#define CONFIG_SYS_FLASH_EMPTY_INFO + #define CONFIG_SYS_FSL_USDHC_NUM 2 #if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_SYS_MMC_ENV_DEV 0
Add support for it:
- unsigned int reg;
- case CS0_128:
reg |= 0x5;
break;
reg |= 0x1B;
break;
reg |= 0x4B;
break;
reg |= 0x249;
break;
- default:
break;
- unsigned int reg;
- reg = readl(&iomuxc_regs->gpr[1]);
- case CS0_128:
reg |= 0x5;
break;
reg |= 0x1B;
break;
reg |= 0x4B;
break;
reg |= 0x249;
break;
- default:
break;
- writel(reg, &iomuxc_regs->gpr[1]);
- CSPI register definitions
- u32 gpr0;
- u32 gpr1;
- u32 gpr[2]; u32 omux0; u32 omux1; u32 omux2;
- u32 gpr0;
- u32 gpr1;
- u32 gpr2;
- u32 gpr[3]; u32 omux0; u32 omux1; u32 omux2;
- Initializes on-chip ethernet controllers.
Fabio Estevam
Stefano Babic
