[U-Boot] [PATCH v2] SPL: FIT: Enable SPL_FIT_LOAD in RAM based boot mode
Support loading FIT in SPL for RAM bootmode. CONFIG_SPL_LOAD_FIT_ADRESS points to address where FIT image is stored in memory.
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: - Fix empty line - Fix addr name and remove SPL_LOAD_FIT macro
common/spl/spl.c | 45 ++++++++++++++++++++++++++++++++++++--------- 1 file changed, 36 insertions(+), 9 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 0fc5b058be31..3faa751e4b43 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -136,20 +136,47 @@ __weak void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) image_entry(); }
+#ifndef CONFIG_SPL_LOAD_FIT_ADDRESS +# define CONFIG_SPL_LOAD_FIT_ADDRESS 0 +#endif + #ifdef CONFIG_SPL_RAM_DEVICE +static ulong spl_ram_load_read(struct spl_load_info *load, ulong sector, + ulong count, void *buf) +{ + debug("%s: sector %lx, count %lx, buf %lx\n", + __func__, sector, count, (ulong)buf); + memcpy(buf, (void *)(CONFIG_SPL_LOAD_FIT_ADDRESS + sector), count); + return count; +} + static int spl_ram_load_image(void) { - const struct image_header *header; + struct image_header *header;
- /* - * Get the header. It will point to an address defined by handoff - * which will tell where the image located inside the flash. For - * now, it will temporary fixed to address pointed by U-Boot. - */ - header = (struct image_header *) - (CONFIG_SYS_TEXT_BASE - sizeof(struct image_header)); + header = (struct image_header *)CONFIG_SPL_LOAD_FIT_ADDRESS;
- spl_parse_image_header(header); + if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) && + image_get_magic(header) == FDT_MAGIC) { + struct spl_load_info load; + + debug("Found FIT\n"); + load.bl_len = 1; + load.read = spl_ram_load_read; + spl_load_simple_fit(&load, 0, header); + } else { + debug("Legacy image\n"); + /* + * Get the header. It will point to an address defined by + * handoff which will tell where the image located inside + * the flash. For now, it will temporary fixed to address + * pointed by U-Boot. + */ + header = (struct image_header *) + (CONFIG_SYS_TEXT_BASE - sizeof(struct image_header)); + + spl_parse_image_header(header); + }
return 0; }
Changes in v2:
Fix empty line
May be a good idea to default this to CONFIG_SYS_TEXT_BASE instead of 0?
Other than that patch looks good to me. Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
- debug("%s: sector %lx, count %lx, buf %lx\n",
- memcpy(buf, (void *)(CONFIG_SPL_LOAD_FIT_ADDRESS + sector), count);
- return count;
- static int spl_ram_load_image(void) {
- struct image_header *header;
- header = (struct image_header *)CONFIG_SPL_LOAD_FIT_ADDRESS;
load.bl_len = 1;
} else {
return 0; }
Changes in v2:
Fix empty line
The problem is that if u-boot is in FIT that it will be loaded to TEXT_BASE address. Maybe easier to just don't define any value which end up in compilation error.
Thanks, Michal
Changes in v2:
Fix empty line
Yeah, you were right. Initially I was thinking there won't be a problem overriding the data. You can leave it as is.
Thanks, Michal
Reviewed-by: Andreas Dannenberg dannenberg@ti.com
That's a very useful addition to the SPL FIT toolbox! I have a use case where I may need to decrypt/authenticate an SPL FIT image in its entirety before processing it so this can be used for this as well.
-- Andreas Dannenberg Texas Instruments Inc
Do you have also use case where you need to load more files from FIT? There is loadable entry in FIT config entry.
Thanks, Michal
Hi Michal,
Not yet but I may get there. I'm experimenting with using U-Boot to load and install a secure monitor mode application (specifically, OP-TEE OS), so that will need to come from somewhere eventually and FIT would be a natural place for that binary to reside since we can easily authenticate it.
Thanks and Regards, Andreas
Hi Andreas,
2016-05-19 20:16 GMT+02:00 Andreas Dannenberg dannenberg@ti.com:
Hi Michal,
entirety
ok what arch? What's the flow which you want to support? SPL to load OPTEE and ATF and full u-boot and jump to ATF which runs OPTEE and run to U-Boot?
Thanks, Michal
Hi Michael,
On Thu, May 19, 2016 at 08:33:28PM +0200, Michal Simek wrote:
Hi Andreas,
Hi Michal,
entirety
I working with TI's current SoCs and those are ARMv7-A and there is no ATF but instead a proprietary solution comprising ROM code and some low-level code that gets loaded/authenticated/executed by said ROM in a secure fashion before the regular boot flow starts (SPL, U-Boot, and so on). There is flexibility to load/install a new secure monitor code during SPL, U-Boot, or in fact at any other time (even after let's say Linux is booted up) but from an overall system architecture POV we need that new secure monitor (OP-TEE OS in this case) to be up before the Kernel is loaded.
Anyways the goal is not only to get it working but also to have a solution that plays nice with everything else and can be contributed upstream.
On 19.5.2016 21:26, Andreas Dannenberg wrote:
Hi Michael,
Hi Andreas,
Hi Michal,
entirety
Ok. I see. I will definitely keep my eyes on this one. Because I have sent SPL for ZynqMP and if you look closely to setting I use without FIT falcon bootmode to be able to load ATF and full u-boot to the memory. For FIT I have sent patches to extend format with fpga part which bootm supports. I have also additional patches (not in mainline) to load bitstream from SPL. But the goal should be that SPL will be able to load FPGA and several images. Just to make long story short support fpga and loadables sections in FIT format.
Thanks, Michal
Andreas Dannenberg
Lokesh Vutla
Michal Simek
Michal Simek
