[U-Boot] list files on tftp / large kernel-image
is it possible to list files on tftp so i can write a script to let user select kernel-image to load?
have anybody tried to load a kernelimage larger than 20MB?
i use dnsmasq as tftp and uboot 2014-version (because 2018-11 für mt7623 currently has no ethernetdriver). If kernelimage is larger than ~20MB loading file hangs...tried setting blocksize, but it's the same behaviour, only more/less #-symbols. I don't know how much data is loaded, because there is loadedbytes-counter (i only can count the # and multiply with blocksize if i know it). do i have any chance to debug that or is this already known/fixed?
regards Frank
Unless I'm mistaken, the tftp protocol does not support file listing.
We are successfully loading FIT images of > ~26 MByte via tftp (containing Kernel, FPGA and Initrd) without problems.
I'm using current mainline, of course. Things might have changed in the last 4 years... ;-)
Simon
regards Frank _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hi Simon, thanks for fast answer
i hope mediatek release ethernet soon (i know it's a more complex driver for r2 than the other 18 patches ), than i can drop the old uboot ;)
for list tftp, it seems to be a protocol limitation. here https://unix.stackexchange.com/questions/76400/download-directory-structure-... the server creates a textfile...this can be a workaround
can i download (to memory) and display it (without writing it)? i only have loaded kernel and executed it's address. I don't know how to print a "Textfile" (if it's in memory i need to know it's size and print this "data block"). maybe there is a way to load the data directly to an env-var
regards Frank
Gesendet: Mittwoch, 14. November 2018 um 16:34 Uhr Von: "Simon Goldschmidt" simon.k.r.goldschmidt@gmail.com An: "Frank Wunderlich" frank-w@public-files.de, u-boot@lists.denx.de Betreff: Re: [U-Boot] list files on tftp / large kernel-image
On Wed, Nov 14, 2018 at 4:52 PM Frank Wunderlich frank-w@public-files.de wrote:
Have you tried the 'strings' command? Is that enough?
Simon
can you give me an example how to download and display it, seems i only have tftpboot which runs kernel directly?
also found no strings-command in https://www.denx.de/wiki/DULG/Manual
Frank
Gesendet: Montag, 19. November 2018 um 12:29 Uhr Von: "Simon Goldschmidt" simon.k.r.goldschmidt@gmail.com An: "Frank Wunderlich" frank-w@public-files.de Cc: "U-Boot Mailing List" u-boot@lists.denx.de Betreff: Re: Re: [U-Boot] list files on tftp / large kernel-image
Simon
i've walked through code and it seems i've found it in cmd/strings.c
strings display strings <addr> [byte count] - display strings at <addr> for at least [byte count] or first double NUL
does tftp add the "double NUL" if i do this:
tftp 0x80200000 filelist.txt strings 0x80200000
or do i need to add ${filesize} to strings-command (if this is set via tftp)
regards Frank
Gesendet: Sonntag, 02. Dezember 2018 um 10:33 Uhr Von: "Frank Wunderlich" frank-w@public-files.de An: "Simon Goldschmidt" simon.k.r.goldschmidt@gmail.com Cc: u-boot@lists.denx.de Betreff: Re: [U-Boot] list files on tftp / large kernel-image
Frank
Simon
Am 02.12.2018 um 10:33 schrieb Frank Wunderlich:
=> tftp ${loadaddr} 192.168.1.1:list.txt Speed: 100, full duplex Using ethernet@ff702000 device TFTP from server 192.168.1.1; our IP address is 192.168.1.101 Filename 'list.txt'. Load address: 0x1000000 Loading: # 12.7 KiB/s done Bytes transferred = 158 (9e hex) => strings ${loadaddr} 9e dhcppkgstyle.xsl dhcpstyle.xsl favicon.ico index.html ldlinux.c32 list.txt mini.iso netboot.tar.gz pxelinux.0 pxelinux.cfg RJ45_5.JPG RJ45_52.JPG ã(Ðå =>
The 'strings' command has to be enabled under "Command line interface" -> "Memory commands". It helps to show the contents, but not really for scripting...
Simon
Frank
Simon
seems like strings breaks my (older 2014-04) uboot:
BPI-IoT> tftp ${loadaddr} 192.168.0.10:files.lst Using mtk_eth device TFTP from server 192.168.0.10; our IP address is 192.168.0.11 Filename 'files.lst'. Load address: 0x84000000 Loading: # 43 KiB/s done Bytes transferred = 89 (59 hex) BPI-IoT> echo ${filesize} 59 BPI-IoT> strings ${loadaddr} ${filesize} lߟA�����������������c���_���=�������������w�������{ߟ��wo�W�������������y�_ BPI-IoT> Minicom2.7Minicom2.7�߅_k�|UZ���߿����������0�������Ż��{������� �
also tested with bytecount 20 instead of filesize-var, same result
cannot use here new uboot till ethernet-driver is not ready
regards Frank
Gesendet: Sonntag, 02. Dezember 2018 um 11:34 Uhr Von: "Simon Goldschmidt" simon.k.r.goldschmidt@gmail.com An: "Frank Wunderlich" frank-w@public-files.de Cc: u-boot@lists.denx.de Betreff: Re: [U-Boot] list files on tftp / large kernel-image
Simon
Frank
Simon
after mt7623 ethernet-driver is available for uboot-upstream i tested this again with it and this happens:
U-Boot> tftp ${loadaddr} 192.168.0.10:files.lst Using ethernet@1b100000 device TFTP from server 192.168.0.10; our IP address is 192.168.0.11 Filename 'files.lst'. Load address: 0x80200000 Loading: # 43 KiB/s done Bytes transferred = 89 (59 hex) U-Boot> echo ${filesize} 59 U-Boot> strings ${loadaddr} ${filesize} uImage_4.14.73 uImage_4.14-rd uImage_4.18.11 uImage_4.19.0-main uImage_4.19.0-rc1-hdmiv5 ����������������o�������W���������������~�����移�����e����9�w���������߿���������ںmr����m�\��������������������鯿��ϯV��������������������������������c��_����������....
[16:58] frank@bpi-r2-e:/var/lib/tftp$ cat files.lst uImage_4.14.73 uImage_4.14-rd uImage_4.18.11 uImage_4.19.0-main uImage_4.19.0-rc1-hdmiv5 [16:58] frank@bpi-r2-e:/var/lib/tftp$ ls -lh files.lst -rw-r--r-- 1 frank frank 89 Dez 2 16:18 files.lst
so it seems strings does not stop after bytes-parameter
U-Boot> help strings strings - display strings
Usage: strings <addr> [byte count] - display strings at <addr> for at least [byte count] or first double NUL U-Boot>
so it should stop after 0x59 bytes...but it does not :( looks like a bug for me.
i do not fully understand cmd/strings.c
http://git.denx.de/?p=u-boot.git;a=blob;f=cmd/strings.c
especially flag CMD_FLAG_REPEAT last_addr is treated as hex of argv[2] this seems correct, but it is used as address and not as count
tried to fix it this way:
last_addr = (char *)(start_addr + simple_strtoul(argv[2], NULL, 16)-1);
but same
added a printf for checking calculation:
printf("%p - %p",start_addr,last_addr);
prints correctly 80200000 - 80200058
so it looks like the bug is inside the loop...
http://www.cplusplus.com/reference/cstdio/puts/
says puts waits prints till \0 so i guess this is missing in my case so i did a memory display:
U-Boot> md 0x80200000 80200000: 616d4975 345f6567 2e34312e 750a3337 uImage_4.14.73.u 80200010: 67616d49 2e345f65 722d3431 49750a64 Image_4.14-rd.uI 80200020: 6567616d 312e345f 31312e38 6d49750a mage_4.18.11.uIm 80200030: 5f656761 39312e34 6d2d302e 0a6e6961 age_4.19.0-main. 80200040: 616d4975 345f6567 2e39312e 63722d30 uImage_4.19.0-rc 80200050: 64682d31 3576696d ffffff0a fcffbff7 1-hdmiv5........
memory at "fileend" is ff instead of 00
i tried setting this to 0
U-Boot> mw 0x80200059 00
but this resets my board...any idea?
regards Frank
fixed now this way (maybe not the best way...because now stringlists (multiple strings divided by \0) cannot displayed):
index 41b1665926..780c3d67b0 100644 --- a/cmd/strings.c +++ b/cmd/strings.c @@ -20,18 +20,28 @@ int do_strings(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if ((flag & CMD_FLAG_REPEAT) == 0) { start_addr = (char *)simple_strtoul(argv[1], NULL, 16); if (argc > 2) - last_addr = (char *)simple_strtoul(argv[2], NULL, 16); + last_addr = (char *)(start_addr + simple_strtoul(argv[2], NULL, 16)-1); else last_addr = (char *)-1; + printf("%p - %p",start_addr,last_addr); }
char *addr = start_addr; - do { - puts(addr); - puts("\n"); - addr += strlen(addr) + 1; - } while (addr[0] && addr < last_addr);
+ if (argc>2) + { + do { + putc((int)addr[0]); + addr++; + } while (addr[0] && addr < last_addr); + }else { + do { + puts(addr); + puts("\n"); + addr += strlen(addr) + 1; + } while (addr[0] && addr < last_addr); + } + puts("\n"); last_addr = addr + (last_addr - start_addr); start_addr = addr;
results in:
U-Boot> tftp ${loadaddr} 192.168.0.10:files.lst Using ethernet@1b100000 device TFTP from server 192.168.0.10; our IP address is 192.168.0.11 Filename 'files.lst'. Load address: 0x80200000 Loading: # 86.9 KiB/s done Bytes transferred = 89 (59 hex) U-Boot> strings ${loadaddr} ${filesize} 80200000 - 80200058uImage_4.14.73 uImage_4.14-rd uImage_4.18.11 uImage_4.19.0-main uImage_4.19.0-rc1-hdmiv5 U-Boot>
maybe you have a better idea
regards Frank
Gesendet: Donnerstag, 20. Dezember 2018 um 17:33 Uhr Von: "Frank Wunderlich" frank-w@public-files.de An: "Simon Goldschmidt" simon.k.r.goldschmidt@gmail.com Cc: u-boot@lists.denx.de Betreff: Re: [U-Boot] list files on tftp / large kernel-image
but same
Am 20.12.2018 um 18:43 schrieb Frank Wunderlich:
Your patch might work for you but it changes the existing behaviour. The help for command 'strings' says: "for at least [byte count] or first double NUL".
Now I do think this could be improved (a maximum range is always good), but you see here the limitation of implementing commands by argument index instead of by argument string: your patch might break usage of 'strings' for others.
Also, if we touched this command, would it make sense to only output strings of printable characters? 'puts' just prints everything until '\0'...
printf("%p - %p",start_addr,last_addr); } char *addr = start_addr;
do {
puts(addr);
puts("\n");
if (argc>2)
do {
putc((int)addr[0]);
addr++;
}else {
do {
puts(addr);
puts("\n");
results in:
regards Frank
but same
Your right, i don't want to send it as Patch. Only show how i got working. A small bug is there: after strings done and i press only return (normally recall previous command) i also get non-printable chars. Maybe it is because last 3 lines (adress calculation) which i left untouched.
The best way currently should be adding 0-byte after my downloaded content (to make puts stop),but it seems i do something wrong with mw-command because it resets my board. I load kernels at same address so 1 0byte at this position should not be a problem.
mw is also strange in my eyes, maybe you can explain me
U-Boot> md 80200000 18 80200000: 616d4975 345f6567 2e34312e 750a3337 uImage_4.14.73.u 80200010: 67616d49 2e345f65 722d3431 49750a64 Image_4.14-rd.uI 80200020: 6567616d 312e345f 31312e38 6d49750a mage_4.18.11.uIm 80200030: 5f656761 39312e34 6d2d302e 0a6e6961 age_4.19.0-main. 80200040: 616d4975 345f6567 2e39312e 63722d30 uImage_4.19.0-rc 80200050: 64682d31 0076696d ffff0000 fcffbdf7 1-hdmiv.........
U-Boot> mw.b 8020005a 0 U-Boot> md 80200000 18 80200000: 616d4975 345f6567 2e34312e 750a3337 uImage_4.14.73.u 80200010: 67616d49 2e345f65 722d3431 49750a64 Image_4.14-rd.uI 80200020: 6567616d 312e345f 31312e38 6d49750a mage_4.18.11.uIm 80200030: 5f656761 39312e34 6d2d302e 0a6e6961 age_4.19.0-main. 80200040: 616d4975 345f6567 2e39312e 63722d30 uImage_4.19.0-rc 80200050: 64682d31 0076696d ff000000 fcffbdf7 1-hdmiv.........
seems to set 59 (00 after ff)
U-Boot> mw.b 8020005b 0 U-Boot> md 80200000 18 80200000: 616d4975 345f6567 2e34312e 750a3337 uImage_4.14.73.u 80200010: 67616d49 2e345f65 722d3431 49750a64 Image_4.14-rd.uI 80200020: 6567616d 312e345f 31312e38 6d49750a mage_4.18.11.uIm 80200030: 5f656761 39312e34 6d2d302e 0a6e6961 age_4.19.0-main. 80200040: 616d4975 345f6567 2e39312e 63722d30 uImage_4.19.0-rc 80200050: 64682d31 0076696d 00000000 fcffbdf7 1-hdmiv.........
seems to set 58 (was ff before)
any idea why higher address counts backwards?
U-Boot> mw.b 8020005c 0 U-Boot> md 80200000 18 80200000: 616d4975 345f6567 2e34312e 750a3337 uImage_4.14.73.u 80200010: 67616d49 2e345f65 722d3431 49750a64 Image_4.14-rd.uI 80200020: 6567616d 312e345f 31312e38 6d49750a mage_4.18.11.uIm 80200030: 5f656761 39312e34 6d2d302e 0a6e6961 age_4.19.0-main. 80200040: 616d4975 345f6567 2e39312e 63722d30 uImage_4.19.0-rc 80200050: 64682d31 0076696d 00000000 fcffbd00 1-hdmiv.........
it seems it gets first the dword at address and then sets the byte x in this dword...not as expected by me
is there a way to calculate the address (loadaddr+filesize) to pass to mw? this way works to display my textfile with strings, but calculation is a bit tricky and have to be done manually at the moment
regards Frank
little endian integer representation! Try 'md.b' instead of 'md'.
Lothar Waßmann
Thank you Lothar for clarification, now it works like expected
U-Boot> mw.b 80200059 00 U-Boot> md.b 80200000 60 80200000: 75 49 6d 61 67 65 5f 34 2e 31 34 2e 37 33 0a 75 uImage_4.14.73.u 80200010: 49 6d 61 67 65 5f 34 2e 31 34 2d 72 64 0a 75 49 Image_4.14-rd.uI 80200020: 6d 61 67 65 5f 34 2e 31 38 2e 31 31 0a 75 49 6d mage_4.18.11.uIm 80200030: 61 67 65 5f 34 2e 31 39 2e 30 2d 6d 61 69 6e 0a age_4.19.0-main. 80200040: 75 49 6d 61 67 65 5f 34 2e 31 39 2e 30 2d 72 63 uImage_4.19.0-rc 80200050: 31 2d 68 64 6d 69 76 35 0a 00 ff ff ff bf ff fc 1-hdmiv5........
can i do this calculation (loadaddr+${filesize}) automaticly? so i need additional commands like eval or setexpr?
regards Frank
have done it now this way:
U-Boot> printenv lstftp lstftp=tftp ${loadaddr} ${serverip}:files.lst;setexpr listend ${loadaddr} + ${filesize};mw.b ${listend} 00 2;md.b ${loadaddr} 60;strings ${loadaddr};
strings-command needs 2 0-bytes to break.
files.lst is a simple textfile on tftp-server which will be created on server by script (ls -1)
thanks to all who helped
regards Frank
Frank Wunderlich
Lothar Waßmann
Simon Goldschmidt
