[U-Boot] Please pull u-boot-ti/master
Hello,
The following changes since commit 32ec258f829808dd7cf74fd83ba999fdaaeab715: Marek Vasut (1): IXP: Fix GPIO_INT_ACT_LOW_SET()
git://git.denx.de/u-boot-ti master
Simon Schwarz (8): Add cmd_spl command devkit8000: add config for spl command omap-common: Add NAND SPL linux booting devkit8000/spl: init GPMC for dm9000 in SPL omap-common/spl: Add linux boot to SPL omap/spl: change output of spl_parse_image_header devkit8000: Implement and activate direct OS boot arm: Add Prep subcommand support to bootm
Stefano Babic (4): Add cache functions to SPL for armv7 OMAP3: SPL: do not call I2C init if no I2C is set. SPL: call cleanup_before_linux() before booting Linux OMAP3: twister: add support to boot Linux from SPL
Tom Rini (1): cam_enc_4xx: Rename 'images' to 'imgs'
arch/arm/cpu/armv7/Makefile | 2 - arch/arm/cpu/armv7/cpu.c | 2 + arch/arm/cpu/armv7/omap-common/spl.c | 46 ++++- arch/arm/cpu/armv7/omap-common/spl_nand.c | 47 ++++- arch/arm/cpu/armv7/omap3/board.c | 2 + arch/arm/include/asm/bootm.h | 26 +++ arch/arm/include/asm/omap_common.h | 2 + arch/arm/lib/Makefile | 5 +- arch/arm/lib/bootm.c | 341 +++++++++++++++-------------- board/ait/cam_enc_4xx/cam_enc_4xx.c | 48 ++-- board/technexion/twister/twister.c | 23 ++ board/timll/devkit8000/devkit8000.c | 37 +++ common/Makefile | 1 + common/cmd_spl.c | 188 ++++++++++++++++ doc/README.commands.spl | 31 +++ include/cmd_spl.h | 31 +++ include/configs/devkit8000.h | 15 +- include/configs/twister.h | 12 + include/image.h | 2 + 19 files changed, 662 insertions(+), 199 deletions(-) create mode 100644 arch/arm/include/asm/bootm.h create mode 100644 common/cmd_spl.c create mode 100644 doc/README.commands.spl create mode 100644 include/cmd_spl.h
These patches have been in progress for quite some time and Wolfgang has requested that they go in now rather than after the upcoming release.
On Mon, Mar 19, 2012 at 11:29:06AM -0700, Tom Rini wrote:
Hello,
[snip]
This pull request is now updated as such:
Christian Riesch (1): calimain, enbw_cmc: Fix typo in comments
Grazvydas Ignotas (1): twl4030: fix potential power supply handling issues
Stefano Babic (8): Add cache functions to SPL for armv7 OMAP3: SPL: do not call I2C init if no I2C is set. SPL: call cleanup_before_linux() before booting Linux OMAP3: twister: add support to boot Linux from SPL NAND: TI: fix warnings in omap_gpmc.c OMAP3: mt_ventoux: updated timing for FPGA OMAP3: mt_ventoux: sets its own mtdparts Davinci: ea20: use gpio framework to access gpios
jacopo mondi (1): omap3_spi: receive transmit mode
arch/arm/cpu/armv7/Makefile | 2 - arch/arm/cpu/armv7/cpu.c | 2 + arch/arm/cpu/armv7/omap-common/spl.c | 46 ++++- arch/arm/cpu/armv7/omap-common/spl_nand.c | 47 ++++- arch/arm/cpu/armv7/omap3/board.c | 2 + arch/arm/include/asm/bootm.h | 26 +++ arch/arm/include/asm/omap_common.h | 2 + arch/arm/lib/Makefile | 5 +- arch/arm/lib/bootm.c | 341 +++++++++++++++-------------- board/ait/cam_enc_4xx/cam_enc_4xx.c | 48 ++-- board/davinci/ea20/ea20.c | 38 +--- board/enbw/enbw_cmc/enbw_cmc.c | 2 +- board/omicron/calimain/calimain.c | 2 +- board/technexion/twister/twister.c | 23 ++ board/teejet/mt_ventoux/mt_ventoux.h | 11 +- board/timll/devkit8000/devkit8000.c | 37 +++ common/Makefile | 1 + common/cmd_spl.c | 188 ++++++++++++++++ doc/README.commands.spl | 31 +++ drivers/mtd/nand/omap_gpmc.c | 14 +- drivers/power/twl4030.c | 18 ++- drivers/spi/omap3_spi.c | 66 ++++++- drivers/spi/omap3_spi.h | 2 + include/cmd_spl.h | 31 +++ include/configs/devkit8000.h | 15 +- include/configs/ea20.h | 2 + include/configs/mt_ventoux.h | 10 + include/configs/twister.h | 12 + include/image.h | 2 + 29 files changed, 777 insertions(+), 249 deletions(-) create mode 100644 arch/arm/include/asm/bootm.h create mode 100644 common/cmd_spl.c create mode 100644 doc/README.commands.spl create mode 100644 include/cmd_spl.h
Hi Tom,
Hello,
[snip]
Applied to u-boot-arm/master, thanks.
Amicalement,
Le 26/03/2012 22:45, Albert ARIBAUD a écrit :
Hi Tom,
Hello,
[snip]
Amicalement,
Correction: the "arm: Add Prep subcommand support to bootm" commit does not apply cleanly to the u-boot tree. I am rolling by my tree. Please rebase on it and re-request a pull.
Amicalement,
Albert ARIBAUD
