[U-Boot] [PATCH 2/3] B4860QDS: SGMII related updates
- Enable SGMII support for 0x8d Serdes 2 protocol. - Correct Phy address for DTSECx for 0x8d/0xb2 Serdes 2 protocol. - Updated debug statement - Add Alternate LC VCO protocols(0x8d-->0x8c, 0xb2-->0xb1) - Rename onboard PHY address defines for more readability - Add these new Defines in B4860QDS.h file
Signed-off-by: Shaveta Leekha shaveta@freescale.com Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Suresh Gupta suresh.gupta@freescale.com Change-Id: I4d9a8c602bdaac8404577ab9642f8c5f37ac7cdc Reviewed-on: http://git.am.freescale.net:8181/23353 Tested-by: Review Code-CDREVIEW CDREVIEW@freescale.com Reviewed-by: Yusong Sun yorksun@freescale.com --- board/freescale/b4860qds/eth_b4860qds.c | 64 ++++++++++++++++++------------ include/configs/B4860QDS.h | 4 +- 2 files changed, 40 insertions(+), 28 deletions(-)
diff --git a/board/freescale/b4860qds/eth_b4860qds.c b/board/freescale/b4860qds/eth_b4860qds.c index 12df9a8..2726cd2 100644 --- a/board/freescale/b4860qds/eth_b4860qds.c +++ b/board/freescale/b4860qds/eth_b4860qds.c @@ -112,7 +112,10 @@ static void initialize_lane_to_slot(void) * Lanes: A,B,C,D: PCI * Lanes: E,F,G,H: XAUI2 */ + case 0xb1: case 0xb2: + case 0x8c: + case 0x8d: /* * Configuration: * SERDES: 2 @@ -195,34 +198,34 @@ int board_eth_init(bd_t *bis) * all SGMII. RGMII is not supported on this board. Setting SGMII 5 and * 6 to on board SGMII phys */ - fm_info_set_phy_address(FM1_DTSEC5, CONFIG_SYS_FM1_DTSEC5_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC6, CONFIG_SYS_FM1_DTSEC6_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC5, CONFIG_SYS_FM1_ONBOARD_PHY1_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, CONFIG_SYS_FM1_ONBOARD_PHY2_ADDR);
switch (serdes1_prtcl) { case 0x29: case 0x2a: /* Serdes 1: A-B SGMII, Configuring DTSEC 5 and 6 */ - debug("Setting phy addresses for FM1_DTSEC5: %x and" - "FM1_DTSEC6: %x\n", CONFIG_SYS_FM1_DTSEC5_PHY_ADDR, - CONFIG_SYS_FM1_DTSEC6_PHY_ADDR); + debug("Set phy addresses for FM1_DTSEC5:%x, FM1_DTSEC6:%x\n", + CONFIG_SYS_FM1_ONBOARD_PHY1_ADDR, + CONFIG_SYS_FM1_ONBOARD_PHY2_ADDR); fm_info_set_phy_address(FM1_DTSEC5, - CONFIG_SYS_FM1_DTSEC5_PHY_ADDR); + CONFIG_SYS_FM1_ONBOARD_PHY1_ADDR); fm_info_set_phy_address(FM1_DTSEC6, - CONFIG_SYS_FM1_DTSEC6_PHY_ADDR); + CONFIG_SYS_FM1_ONBOARD_PHY2_ADDR); break; #ifdef CONFIG_PPC_B4420 case 0x17: case 0x18: /* Serdes 1: A-D SGMII, Configuring on board dual SGMII Phy */ - debug("Setting phy addresses for FM1_DTSEC3: %x and" - "FM1_DTSEC4: %x\n", CONFIG_SYS_FM1_DTSEC5_PHY_ADDR, - CONFIG_SYS_FM1_DTSEC6_PHY_ADDR); + debug("Set phy addresses for FM1_DTSEC3:%x, FM1_DTSEC4:%x\n", + CONFIG_SYS_FM1_ONBOARD_PHY1_ADDR, + CONFIG_SYS_FM1_ONBOARD_PHY2_ADDR); /* Fixing Serdes clock by programming FPGA register */ QIXIS_WRITE(brdcfg[4], QIXIS_SRDS1CLK_125); fm_info_set_phy_address(FM1_DTSEC3, - CONFIG_SYS_FM1_DTSEC5_PHY_ADDR); + CONFIG_SYS_FM1_ONBOARD_PHY1_ADDR); fm_info_set_phy_address(FM1_DTSEC4, - CONFIG_SYS_FM1_DTSEC6_PHY_ADDR); + CONFIG_SYS_FM1_ONBOARD_PHY2_ADDR); break; #endif default: @@ -233,8 +236,8 @@ int board_eth_init(bd_t *bis) switch (serdes2_prtcl) { case 0x17: case 0x18: - debug("Setting phy addresses on SGMII Riser card for" - "FM1_DTSEC ports: \n"); + debug("Set phy address on SGMII Riser for FM1_DTSEC1:%x\n", + CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR); fm_info_set_phy_address(FM1_DTSEC1, CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR); fm_info_set_phy_address(FM1_DTSEC2, @@ -246,8 +249,8 @@ int board_eth_init(bd_t *bis) break; case 0x48: case 0x49: - debug("Setting phy addresses on SGMII Riser card for" - "FM1_DTSEC ports: \n"); + debug("Set phy address on SGMII Riser for FM1_DTSEC1:%x\n", + CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR); fm_info_set_phy_address(FM1_DTSEC1, CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR); fm_info_set_phy_address(FM1_DTSEC2, @@ -255,10 +258,12 @@ int board_eth_init(bd_t *bis) fm_info_set_phy_address(FM1_DTSEC3, CONFIG_SYS_FM1_DTSEC3_RISER_PHY_ADDR); break; - case 0x8d: + case 0xb1: case 0xb2: - debug("Setting phy addresses on SGMII Riser card for" - "FM1_DTSEC ports: \n"); + case 0x8c: + case 0x8d: + debug("Set phy addresses on SGMII Riser for FM1_DTSEC1:%x\n", + CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR); fm_info_set_phy_address(FM1_DTSEC3, CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR); fm_info_set_phy_address(FM1_DTSEC4, @@ -266,18 +271,18 @@ int board_eth_init(bd_t *bis) break; case 0x98: /* XAUI in Slot1 and Slot2 */ - debug("Setting phy addresses on B4860 QDS AMC2PEX-2S for FM1_10GEC1: %x\n", + debug("Set phy address of AMC2PEX-2S for FM1_10GEC1:%x\n", CONFIG_SYS_FM1_10GEC1_PHY_ADDR); fm_info_set_phy_address(FM1_10GEC1, CONFIG_SYS_FM1_10GEC1_PHY_ADDR); - debug("Setting phy addresses on B4860 QDS AMC2PEX-2S for FM1_10GEC2: %x\n", + debug("Set phy address of AMC2PEX-2S for FM1_10GEC2:%x\n", CONFIG_SYS_FM1_10GEC2_PHY_ADDR); fm_info_set_phy_address(FM1_10GEC2, CONFIG_SYS_FM1_10GEC2_PHY_ADDR); break; case 0x9E: /* XAUI in Slot2 */ - debug("Setting phy addresses on B4860 QDS AMC2PEX-2S for FM1_10GEC2: %x\n", + debug("Sett phy address of AMC2PEX-2S for FM1_10GEC2:%x\n", CONFIG_SYS_FM1_10GEC2_PHY_ADDR); fm_info_set_phy_address(FM1_10GEC2, CONFIG_SYS_FM1_10GEC2_PHY_ADDR); @@ -329,17 +334,20 @@ int board_eth_init(bd_t *bis) switch (fm_info_get_enet_if(i)) { case PHY_INTERFACE_MODE_XGMII: fm_info_set_mdio(i, - miiphy_get_dev_by_name(DEFAULT_FM_TGEC_MDIO_NAME)); + miiphy_get_dev_by_name + (DEFAULT_FM_TGEC_MDIO_NAME)); + break; + case PHY_INTERFACE_MODE_NONE: + fm_info_set_phy_address(i, 0); break; default: - printf("Fman1: 10GSEC%u set to unknown interface %i\n", + printf("Fman1: TGEC%u set to unknown interface %i\n", idx + 1, fm_info_get_enet_if(i)); fm_info_set_phy_address(i, 0); break; } }
- cpu_eth_init(bis); #endif
@@ -357,15 +365,19 @@ void board_ft_fman_fixup_port(void *fdt, char *compat, phys_addr_t addr,
sprintf(alias, "phy_sgmii_%x", phy); fdt_set_phy_handle(fdt, compat, addr, alias); + fdt_status_okay_by_alias(fdt, alias); } }
+/* + * Set status to disabled for unused ethernet node + */ void fdt_fixup_board_enet(void *fdt) { int i; char alias[32];
- for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) { + for (i = FM1_DTSEC1; i <= FM1_10GEC2; i++) { switch (fm_info_get_enet_if(i)) { case PHY_INTERFACE_MODE_NONE: sprintf(alias, "ethernet%u", i); diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index dc1a9bc..b47b9de 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -713,8 +713,8 @@ unsigned long get_board_ddr_clk(void); #endif /* CONFIG_PCI */
#ifdef CONFIG_FMAN_ENET -#define CONFIG_SYS_FM1_DTSEC5_PHY_ADDR 0x10 -#define CONFIG_SYS_FM1_DTSEC6_PHY_ADDR 0x11 +#define CONFIG_SYS_FM1_ONBOARD_PHY1_ADDR 0x10 +#define CONFIG_SYS_FM1_ONBOARD_PHY2_ADDR 0x11
/*B4860 QDS AMC2PEX-2S default PHY_ADDR */ #define CONFIG_SYS_FM1_10GEC1_PHY_ADDR 0x7 /*SLOT 1*/
Applied to u-boot-mpc85xx, awaiting upstream.
York
Shaveta Leekha
York Sun
