[U-Boot] [PATCH v2 0/3] Simplify dts/Makefile and support multiple DTBs generation
1/3 re-writes dts/Makefile more simply. It does not change the behavior except removal of ./u-boot.dts
2/3 moves *.dts from board/$(VENDOR)/dts to arch/$(ARCH)/dts
3/3 adds multipe DTBs generation
This patch uses my Kbuild series as a prerequisite. "Switch over to real Kbuild" series version 9 must be applied beforehand.
Changes in v2: - Rebase on Kbuild series v9 - Add ';' which was missing in arch/arm/lib/board.c - Add 2/3 and 3/3
Masahiro Yamada (3): dts: re-write dts/Makefile more simply with Kbuild dts: move device tree sources to arch/$(ARCH)/dts/ dts: generate multiple device tree blobs
.gitignore | 1 - Makefile | 16 ++--- arch/arm/dts/.gitignore | 1 + arch/arm/dts/Makefile | 37 ++++++++++ .../arm}/dts/exynos5250-arndale.dts | 0 .../arm}/dts/exynos5250-smdk5250.dts | 0 .../samsung => arch/arm}/dts/exynos5250-snow.dts | 0 .../arm}/dts/exynos5420-smdk5420.dts | 0 .../nvidia => arch/arm}/dts/tegra114-dalmore.dts | 0 .../arm}/dts/tegra20-colibri_t20_iris.dts | 0 {board/nvidia => arch/arm}/dts/tegra20-harmony.dts | 0 .../arm}/dts/tegra20-medcom-wide.dts | 0 {board/compal => arch/arm}/dts/tegra20-paz00.dts | 0 .../arm}/dts/tegra20-plutux.dts | 0 .../nvidia => arch/arm}/dts/tegra20-seaboard.dts | 0 .../arm}/dts/tegra20-tamonten.dtsi | 0 .../arm}/dts/tegra20-tec.dts | 0 .../arm}/dts/tegra20-trimslice.dts | 0 {board/nvidia => arch/arm}/dts/tegra20-ventana.dts | 0 .../nvidia => arch/arm}/dts/tegra20-whistler.dts | 0 {board/nvidia => arch/arm}/dts/tegra30-beaver.dts | 0 {board/nvidia => arch/arm}/dts/tegra30-cardhu.dts | 0 .../arm}/dts/tegra30-tamonten.dtsi | 0 .../arm}/dts/tegra30-tec-ng.dts | 0 {board/xilinx => arch/arm}/dts/zynq-microzed.dts | 0 {board/xilinx => arch/arm}/dts/zynq-zc702.dts | 0 {board/xilinx => arch/arm}/dts/zynq-zc706.dts | 0 .../xilinx => arch/arm}/dts/zynq-zc770-xm010.dts | 0 .../xilinx => arch/arm}/dts/zynq-zc770-xm012.dts | 0 .../xilinx => arch/arm}/dts/zynq-zc770-xm013.dts | 0 {board/xilinx => arch/arm}/dts/zynq-zed.dts | 0 arch/arm/lib/board.c | 2 +- arch/microblaze/dts/.gitignore | 1 + arch/microblaze/dts/Makefile | 11 +++ .../microblaze}/dts/microblaze-generic.dts | 0 arch/microblaze/lib/board.c | 2 +- arch/x86/dts/.gitignore | 1 + arch/x86/dts/Makefile | 12 ++++ {board/chromebook-x86 => arch/x86}/dts/alex.dts | 0 {board/chromebook-x86 => arch/x86}/dts/link.dts | 0 arch/x86/lib/init_helpers.c | 2 +- common/board_f.c | 2 +- dts/.gitignore | 2 + dts/Makefile | 81 ++++++++-------------- include/common.h | 2 +- scripts/Makefile.lib | 11 ++- 46 files changed, 112 insertions(+), 72 deletions(-) create mode 100644 arch/arm/dts/.gitignore create mode 100644 arch/arm/dts/Makefile rename {board/samsung => arch/arm}/dts/exynos5250-arndale.dts (100%) rename {board/samsung => arch/arm}/dts/exynos5250-smdk5250.dts (100%) rename {board/samsung => arch/arm}/dts/exynos5250-snow.dts (100%) rename {board/samsung => arch/arm}/dts/exynos5420-smdk5420.dts (100%) rename {board/nvidia => arch/arm}/dts/tegra114-dalmore.dts (100%) rename {board/toradex => arch/arm}/dts/tegra20-colibri_t20_iris.dts (100%) rename {board/nvidia => arch/arm}/dts/tegra20-harmony.dts (100%) rename {board/avionic-design => arch/arm}/dts/tegra20-medcom-wide.dts (100%) rename {board/compal => arch/arm}/dts/tegra20-paz00.dts (100%) rename {board/avionic-design => arch/arm}/dts/tegra20-plutux.dts (100%) rename {board/nvidia => arch/arm}/dts/tegra20-seaboard.dts (100%) rename {board/avionic-design => arch/arm}/dts/tegra20-tamonten.dtsi (100%) rename {board/avionic-design => arch/arm}/dts/tegra20-tec.dts (100%) rename {board/compulab => arch/arm}/dts/tegra20-trimslice.dts (100%) rename {board/nvidia => arch/arm}/dts/tegra20-ventana.dts (100%) rename {board/nvidia => arch/arm}/dts/tegra20-whistler.dts (100%) rename {board/nvidia => arch/arm}/dts/tegra30-beaver.dts (100%) rename {board/nvidia => arch/arm}/dts/tegra30-cardhu.dts (100%) rename {board/avionic-design => arch/arm}/dts/tegra30-tamonten.dtsi (100%) rename {board/avionic-design => arch/arm}/dts/tegra30-tec-ng.dts (100%) rename {board/xilinx => arch/arm}/dts/zynq-microzed.dts (100%) rename {board/xilinx => arch/arm}/dts/zynq-zc702.dts (100%) rename {board/xilinx => arch/arm}/dts/zynq-zc706.dts (100%) rename {board/xilinx => arch/arm}/dts/zynq-zc770-xm010.dts (100%) rename {board/xilinx => arch/arm}/dts/zynq-zc770-xm012.dts (100%) rename {board/xilinx => arch/arm}/dts/zynq-zc770-xm013.dts (100%) rename {board/xilinx => arch/arm}/dts/zynq-zed.dts (100%) create mode 100644 arch/microblaze/dts/.gitignore create mode 100644 arch/microblaze/dts/Makefile rename {board/xilinx => arch/microblaze}/dts/microblaze-generic.dts (100%) create mode 100644 arch/x86/dts/.gitignore create mode 100644 arch/x86/dts/Makefile rename {board/chromebook-x86 => arch/x86}/dts/alex.dts (100%) rename {board/chromebook-x86 => arch/x86}/dts/link.dts (100%) create mode 100644 dts/.gitignore
Useful rules in scripts/Makefile.lib allows us to easily generate a device tree blob and wrap it in assembly code.
We do not need to parse a linker script to get output format and arch.
This commit deletes ./u-boot.dtb since it is a copy of dts/dt.dtb
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
.gitignore | 1 - Makefile | 16 +++++----- arch/arm/lib/board.c | 2 +- arch/microblaze/lib/board.c | 2 +- arch/x86/lib/init_helpers.c | 2 +- common/board_f.c | 2 +- dts/.gitignore | 2 ++ dts/Makefile | 72 +++++++++++++-------------------------------- include/common.h | 2 +- scripts/Makefile.lib | 12 ++++---- 10 files changed, 41 insertions(+), 72 deletions(-) create mode 100644 dts/.gitignore
diff --git a/.gitignore b/.gitignore index 24019b3..5882ff5 100644 --- a/.gitignore +++ b/.gitignore @@ -48,7 +48,6 @@ /u-boot.lds /u-boot.ubl /u-boot.ais -/u-boot.dtb /u-boot.sb
# diff --git a/Makefile b/Makefile index cb9c243..b425bfb 100644 --- a/Makefile +++ b/Makefile @@ -722,7 +722,7 @@ ALL-$(CONFIG_RAMBOOT_PBL) += u-boot.pbl ALL-$(CONFIG_SPL) += spl/u-boot-spl.bin ALL-$(CONFIG_SPL_FRAMEWORK) += u-boot.img ALL-$(CONFIG_TPL) += tpl/u-boot-tpl.bin -ALL-$(CONFIG_OF_SEPARATE) += u-boot.dtb u-boot-dtb.bin +ALL-$(CONFIG_OF_SEPARATE) += u-boot-dtb.bin ifneq ($(CONFIG_SPL_TARGET),) ALL-$(CONFIG_SPL) += $(CONFIG_SPL_TARGET:"%"=%) endif @@ -746,11 +746,11 @@ endif
all: $(ALL-y)
-u-boot.dtb: checkdtc u-boot - $(MAKE) $(build)=dts binary - mv dts/dt.dtb $@ +PHONY += dtbs +dtbs dts/dt.dtb: checkdtc u-boot + $(Q)$(MAKE) $(build)=dts dtbs
-u-boot-dtb.bin: u-boot.bin u-boot.dtb +u-boot-dtb.bin: u-boot.bin dts/dt.dtb cat $^ >$@
u-boot.hex: u-boot @@ -877,8 +877,8 @@ u-boot-nodtb-tegra.bin: spl/u-boot-spl.bin u-boot.bin rm spl/u-boot-spl-pad.bin
ifeq ($(CONFIG_OF_SEPARATE),y) -u-boot-dtb-tegra.bin: u-boot-nodtb-tegra.bin u-boot.dtb - cat u-boot-nodtb-tegra.bin u-boot.dtb > $@ +u-boot-dtb-tegra.bin: u-boot-nodtb-tegra.bin dts/dt.dtb + cat $^ > $@ endif endif
@@ -1173,7 +1173,7 @@ include/license.h: tools/bin2header COPYING # Directories & files removed with 'make clean' CLEAN_DIRS += $(MODVERDIR) CLEAN_FILES += u-boot.lds include/bmp_logo.h include/bmp_logo_data.h \ - board/*/config.tmp board/*/*/config.tmp dts/*.tmp \ + board/*/config.tmp board/*/*/config.tmp \ include/autoconf.mk* include/spl-autoconf.mk \ include/tpl-autoconf.mk
diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index b770e25..38b9c7d 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -280,7 +280,7 @@ void board_init_f(ulong bootflag) gd->mon_len = _bss_end_ofs; #ifdef CONFIG_OF_EMBED /* Get a pointer to the FDT */ - gd->fdt_blob = _binary_dt_dtb_start; + gd->fdt_blob = __dtb_db_begin; #elif defined CONFIG_OF_SEPARATE /* FDT is at end of image */ gd->fdt_blob = (void *)(_end_ofs + _TEXT_BASE); diff --git a/arch/microblaze/lib/board.c b/arch/microblaze/lib/board.c index 896e73a..0f10c88 100644 --- a/arch/microblaze/lib/board.c +++ b/arch/microblaze/lib/board.c @@ -76,7 +76,7 @@ void board_init_f(ulong not_used)
#ifdef CONFIG_OF_EMBED /* Get a pointer to the FDT */ - gd->fdt_blob = _binary_dt_dtb_start; + gd->fdt_blob = __dtb_dt_begin; #elif defined CONFIG_OF_SEPARATE /* FDT is at end of image */ gd->fdt_blob = (void *)__end; diff --git a/arch/x86/lib/init_helpers.c b/arch/x86/lib/init_helpers.c index 582c0ff..b5d937f 100644 --- a/arch/x86/lib/init_helpers.c +++ b/arch/x86/lib/init_helpers.c @@ -92,7 +92,7 @@ int find_fdt(void) { #ifdef CONFIG_OF_EMBED /* Get a pointer to the FDT */ - gd->fdt_blob = _binary_dt_dtb_start; + gd->fdt_blob = __dtb_dt_begin; #elif defined CONFIG_OF_SEPARATE /* FDT is at end of image */ gd->fdt_blob = (ulong *)&_end; diff --git a/common/board_f.c b/common/board_f.c index aa70c3e..d0ee6f7 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -360,7 +360,7 @@ static int setup_fdt(void) { #ifdef CONFIG_OF_EMBED /* Get a pointer to the FDT */ - gd->fdt_blob = _binary_dt_dtb_start; + gd->fdt_blob = __dtb_dt_begin; #elif defined CONFIG_OF_SEPARATE /* FDT is at end of image */ # ifdef CONFIG_SYS_SYM_OFFSETS diff --git a/dts/.gitignore b/dts/.gitignore new file mode 100644 index 0000000..1b37180 --- /dev/null +++ b/dts/.gitignore @@ -0,0 +1,2 @@ +*.dtb +*.dtb.S diff --git a/dts/Makefile b/dts/Makefile index 1e7609a..c47fba7 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -7,64 +7,32 @@ # This Makefile builds the internal U-Boot fdt if CONFIG_OF_CONTROL is # enabled. See doc/README.fdt-control for more details.
-DTS_INCDIRS = $(SRCTREE)/board/$(VENDOR)/$(BOARD)/dts -DTS_INCDIRS += $(SRCTREE)/board/$(VENDOR)/dts -DTS_INCDIRS += $(SRCTREE)/arch/$(ARCH)/dts +DEVICE_TREE ?= $(CONFIG_DEFAULT_DEVICE_TREE:"%"=%) +ifeq ($(DEVICE_TREE),) +DEVICE_TREE := notfound +endif
-DTS_CPPFLAGS := -x assembler-with-cpp -undef -D__DTS__ \ - -nostdinc $(addprefix -I,$(DTS_INCDIRS)) +DTS := $(srctree)/board/$(VENDOR)/dts/$(DEVICE_TREE).dts
-DTC_FLAGS := -R 4 -p 0x1000 \ - $(addprefix -i ,$(DTS_INCDIRS)) +DTC_FLAGS += -i $(srctree)/arch/$(ARCH)/dts -R 4 -p 0x1000
-# Use a constant name for this so we can access it from C code. -# objcopy doesn't seem to allow us to set the symbol name independently of -# the filename. -DT_BIN := $(obj)/dt.dtb +$(obj)/dt.dtb: $(DTS) FORCE + $(call if_changed_dep,dtc)
-DEVICE_TREE ?= $(CONFIG_DEFAULT_DEVICE_TREE:"%"=%) -ifeq ($(DEVICE_TREE),) -$(DT_BIN): FORCE - echo >&2 "Please define CONFIG_DEFAULT_DEVICE_TREE in your board header file" -else -$(DT_BIN): $(TOPDIR)/board/$(VENDOR)/dts/$(DEVICE_TREE).dts - $(CPP) $(DTS_CPPFLAGS) $< -o $(DT_BIN).dts.tmp - $(DTC) $(DTC_FLAGS) -O dtb -o ${DT_BIN} $(DT_BIN).dts.tmp -endif +targets += dt.dtb
-process_lds = \ - $(1) | sed -r -n 's/^OUTPUT_$(2)[ ("]*([^")]*).*/\1/p' +$(DTS): + @echo >&2 + @echo >&2 "Device Tree Source is not specified." + @echo >&2 "Please define 'CONFIG_DEFAULT_DEVICE_TREE'" + @echo >&2 "or build with 'DEVICE_TREE=<dts-file-name>' argument" + @/bin/false
-# Run the compiler and get the link script from the linker -GET_LDS = $(CC) $(c_flags) $(ld_flags) -Wl,--verbose 2>&1 +.SECONDARY: $(obj)/dt.dtb.S
-$(obj)/dt.o: $(DT_BIN) - # We want the output format and arch. - # We also hope to win a prize for ugliest Makefile / shell interaction - # We look in the LDSCRIPT first. - # Then try the linker which should give us the answer. - # Then check it worked. - [ -n "$(LDSCRIPT)" ] && \ - oformat=`$(call process_lds,cat $(LDSCRIPT),FORMAT)` && \ - oarch=`$(call process_lds,cat $(LDSCRIPT),ARCH)` ;\ - \ - [ -z $${oformat} ] && \ - oformat=`$(call process_lds,$(GET_LDS),FORMAT)` ;\ - [ -z $${oarch} ] && \ - oarch=`$(call process_lds,$(GET_LDS),ARCH)` ;\ - \ - [ -z $${oformat} ] && \ - echo "Cannot read OUTPUT_FORMAT from lds file $(LDSCRIPT)" && \ - exit 1 || true ;\ - [ -z $${oarch} ] && \ - echo "Cannot read OUTPUT_ARCH from lds file $(LDSCRIPT)" && \ - exit 1 || true ;\ - \ - cd $(dir ${DT_BIN}) && \ - $(OBJCOPY) -I binary -O $${oformat} -B $${oarch} \ - $(notdir ${DT_BIN}) $(notdir $@) - rm $(DT_BIN) +obj-$(CONFIG_OF_EMBED) := dt.dtb.o
-obj-$(CONFIG_OF_EMBED) := dt.o +dtbs: $(obj)/dt.dtb + @:
-binary: $(DT_BIN) +clean-files := dt.dtb.S diff --git a/include/common.h b/include/common.h index c15e5a4..b590f3a 100644 --- a/include/common.h +++ b/include/common.h @@ -302,7 +302,7 @@ int checkdram (void); int last_stage_init(void); extern ulong monitor_flash_len; int mac_read_from_eeprom(void); -extern u8 _binary_dt_dtb_start[]; /* embedded device tree blob */ +extern u8 __dtb_dt_begin[]; /* embedded device tree blob */ int set_cpu_clk_info(void); int print_cpuinfo(void); int update_flash_size(int flash_size); diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index d4b5cb5..ee3ceac 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -151,9 +151,10 @@ cpp_flags = -Wp,-MD,$(depfile) $(NOSTDINC_FLAGS) $(UBOOTINCLUDE) \
ld_flags = $(LDFLAGS) $(ldflags-y)
+# Modified for U-Boot dtc_cpp_flags = -Wp,-MD,$(depfile).pre.tmp -nostdinc \ - -I$(srctree)/arch/$(SRCARCH)/boot/dts \ - -I$(srctree)/arch/$(SRCARCH)/boot/dts/include \ + -I$(srctree)/board/$(VENDOR)/dts/ \ + -I$(srctree)/arch/$(ARCH)/dts \ -undef -D__DTS__
# Finds the multi-part object the current object will be linked into @@ -247,25 +248,24 @@ cmd_gzip = (cat $(filter-out FORCE,$^) | gzip -n -f -9 > $@) || \
# Generate an assembly file to wrap the output of the device tree compiler quiet_cmd_dt_S_dtb= DTB $@ +# Modified for U-Boot cmd_dt_S_dtb= \ ( \ - echo '#include <asm-generic/vmlinux.lds.h>'; \ echo '.section .dtb.init.rodata,"a"'; \ - echo '.balign STRUCT_ALIGNMENT'; \ echo '.global __dtb_$(*F)_begin'; \ echo '__dtb_$(*F)_begin:'; \ echo '.incbin "$<" '; \ echo '__dtb_$(*F)_end:'; \ echo '.global __dtb_$(*F)_end'; \ - echo '.balign STRUCT_ALIGNMENT'; \ ) > $@
$(obj)/%.dtb.S: $(obj)/%.dtb $(call cmd,dt_S_dtb)
quiet_cmd_dtc = DTC $@ +# Modified for U-Boot cmd_dtc = $(CPP) $(dtc_cpp_flags) -x assembler-with-cpp -o $(dtc-tmp) $< ; \ - $(objtree)/scripts/dtc/dtc -O dtb -o $@ -b 0 \ + dtc -O dtb -o $@ -b 0 \ -i $(dir $<) $(DTC_FLAGS) \ -d $(depfile).dtc.tmp $(dtc-tmp) ; \ cat $(depfile).pre.tmp $(depfile).dtc.tmp > $(depfile)
Hi Masahiro,
I'd rather have the former and delete the latter temporary file as part of the build. u-boot.dtb is currently a build output.
Hello Simon,
This is what I have said in the thread Re: [PATCH] dts: re-write dts/Makefile more simply with Kbuild
We must keep dts/dt.dtb to suppress the re-generation of dts/dt.dtb.
Besides, dts/dt.dtb is a prerequisite of dts/dt.dtb.S when CONFIG_OF_EMBED is enabled.
I believe keeping dts/dt.dtb is reasonable enough.
Better to keep both?
Best Regards Masahiro Yamada
Hi Masahiro,
On 18 February 2014 01:27, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hello Simon,
OK. From memory when I did this, it was just a temporary file which was used to create dts/dt.o. Make deleted it at the end of the build, I think. But I may remember wrong, and it doesn't matter anyway.
Yes I think so.
Hello Simon,
On Tue, 18 Feb 2014 21:45:12 -0800 Simon Glass sjg@chromium.org wrote:
Hi Masahiro,
Hello Simon,
I think dts/dt.o was deleted at the end only when CONFIG_OF_SEPARATE=y by the following rule.
$(obj)u-boot.dtb: checkdtc $(obj)u-boot $(MAKE) $(build) dts binary mv $(obj)dts/dt.dtb $@
It moves, not copies dts/dt.dtb.
Yes I think so.
OK. I will revive ./u-boot.dtb and post a new version.
And I will send it as a single patch dropping 2/3 and 3/3. Do you think it's better?
Many kbuild-related patches are being stuck on patchwork and my local branch is getting messed up. I don't want to delay this patch any more.
Hi Masahiro,
On 18 February 2014 22:06, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hello Simon,
Hi Masahiro,
Hello Simon,
Yes I think so.
Agreed, I look forward to all your series being merged, a bit step forward for U-Boot.
Unlike Linux Kernel, U-Boot historically had *.dts files under board/$(VENDOR)/dts/ and *.dtsi files under arch/$(ARCH)/dts/.
I think arch/$(ARCH)/dts dicretory is a better location to store both *.dts and *.dtsi files.
For example, before this commit, board/xilinx/dts directory had both MicroBlaze dts (microblaze-generic.dts) and ARM dts (zynq-*.dts), which are totally unrelated.
This commit moves *.dts to arch/$(ARCH)/dts/ directories, allowing us to describe nicely mutiple DTBs generation in the next commit.
Changes in v2: - Newly added
{board/samsung => arch/arm}/dts/exynos5250-arndale.dts | 0 {board/samsung => arch/arm}/dts/exynos5250-smdk5250.dts | 0 {board/samsung => arch/arm}/dts/exynos5250-snow.dts | 0 {board/samsung => arch/arm}/dts/exynos5420-smdk5420.dts | 0 {board/nvidia => arch/arm}/dts/tegra114-dalmore.dts | 0 {board/toradex => arch/arm}/dts/tegra20-colibri_t20_iris.dts | 0 {board/nvidia => arch/arm}/dts/tegra20-harmony.dts | 0 {board/avionic-design => arch/arm}/dts/tegra20-medcom-wide.dts | 0 {board/compal => arch/arm}/dts/tegra20-paz00.dts | 0 {board/avionic-design => arch/arm}/dts/tegra20-plutux.dts | 0 {board/nvidia => arch/arm}/dts/tegra20-seaboard.dts | 0 {board/avionic-design => arch/arm}/dts/tegra20-tamonten.dtsi | 0 {board/avionic-design => arch/arm}/dts/tegra20-tec.dts | 0 {board/compulab => arch/arm}/dts/tegra20-trimslice.dts | 0 {board/nvidia => arch/arm}/dts/tegra20-ventana.dts | 0 {board/nvidia => arch/arm}/dts/tegra20-whistler.dts | 0 {board/nvidia => arch/arm}/dts/tegra30-beaver.dts | 0 {board/nvidia => arch/arm}/dts/tegra30-cardhu.dts | 0 {board/avionic-design => arch/arm}/dts/tegra30-tamonten.dtsi | 0 {board/avionic-design => arch/arm}/dts/tegra30-tec-ng.dts | 0 {board/xilinx => arch/arm}/dts/zynq-microzed.dts | 0 {board/xilinx => arch/arm}/dts/zynq-zc702.dts | 0 {board/xilinx => arch/arm}/dts/zynq-zc706.dts | 0 {board/xilinx => arch/arm}/dts/zynq-zc770-xm010.dts | 0 {board/xilinx => arch/arm}/dts/zynq-zc770-xm012.dts | 0 {board/xilinx => arch/arm}/dts/zynq-zc770-xm013.dts | 0 {board/xilinx => arch/arm}/dts/zynq-zed.dts | 0 {board/xilinx => arch/microblaze}/dts/microblaze-generic.dts | 0 {board/chromebook-x86 => arch/x86}/dts/alex.dts | 0 {board/chromebook-x86 => arch/x86}/dts/link.dts | 0 dts/Makefile | 4 ++-- scripts/Makefile.lib | 1 - 32 files changed, 2 insertions(+), 3 deletions(-) rename {board/samsung => arch/arm}/dts/exynos5250-arndale.dts (100%) rename {board/samsung => arch/arm}/dts/exynos5250-smdk5250.dts (100%) rename {board/samsung => arch/arm}/dts/exynos5250-snow.dts (100%) rename {board/samsung => arch/arm}/dts/exynos5420-smdk5420.dts (100%) rename {board/nvidia => arch/arm}/dts/tegra114-dalmore.dts (100%) rename {board/toradex => arch/arm}/dts/tegra20-colibri_t20_iris.dts (100%) rename {board/nvidia => arch/arm}/dts/tegra20-harmony.dts (100%) rename {board/avionic-design => arch/arm}/dts/tegra20-medcom-wide.dts (100%) rename {board/compal => arch/arm}/dts/tegra20-paz00.dts (100%) rename {board/avionic-design => arch/arm}/dts/tegra20-plutux.dts (100%) rename {board/nvidia => arch/arm}/dts/tegra20-seaboard.dts (100%) rename {board/avionic-design => arch/arm}/dts/tegra20-tamonten.dtsi (100%) rename {board/avionic-design => arch/arm}/dts/tegra20-tec.dts (100%) rename {board/compulab => arch/arm}/dts/tegra20-trimslice.dts (100%) rename {board/nvidia => arch/arm}/dts/tegra20-ventana.dts (100%) rename {board/nvidia => arch/arm}/dts/tegra20-whistler.dts (100%) rename {board/nvidia => arch/arm}/dts/tegra30-beaver.dts (100%) rename {board/nvidia => arch/arm}/dts/tegra30-cardhu.dts (100%) rename {board/avionic-design => arch/arm}/dts/tegra30-tamonten.dtsi (100%) rename {board/avionic-design => arch/arm}/dts/tegra30-tec-ng.dts (100%) rename {board/xilinx => arch/arm}/dts/zynq-microzed.dts (100%) rename {board/xilinx => arch/arm}/dts/zynq-zc702.dts (100%) rename {board/xilinx => arch/arm}/dts/zynq-zc706.dts (100%) rename {board/xilinx => arch/arm}/dts/zynq-zc770-xm010.dts (100%) rename {board/xilinx => arch/arm}/dts/zynq-zc770-xm012.dts (100%) rename {board/xilinx => arch/arm}/dts/zynq-zc770-xm013.dts (100%) rename {board/xilinx => arch/arm}/dts/zynq-zed.dts (100%) rename {board/xilinx => arch/microblaze}/dts/microblaze-generic.dts (100%) rename {board/chromebook-x86 => arch/x86}/dts/alex.dts (100%) rename {board/chromebook-x86 => arch/x86}/dts/link.dts (100%)
diff --git a/board/samsung/dts/exynos5250-arndale.dts b/arch/arm/dts/exynos5250-arndale.dts similarity index 100% rename from board/samsung/dts/exynos5250-arndale.dts rename to arch/arm/dts/exynos5250-arndale.dts diff --git a/board/samsung/dts/exynos5250-smdk5250.dts b/arch/arm/dts/exynos5250-smdk5250.dts similarity index 100% rename from board/samsung/dts/exynos5250-smdk5250.dts rename to arch/arm/dts/exynos5250-smdk5250.dts diff --git a/board/samsung/dts/exynos5250-snow.dts b/arch/arm/dts/exynos5250-snow.dts similarity index 100% rename from board/samsung/dts/exynos5250-snow.dts rename to arch/arm/dts/exynos5250-snow.dts diff --git a/board/samsung/dts/exynos5420-smdk5420.dts b/arch/arm/dts/exynos5420-smdk5420.dts similarity index 100% rename from board/samsung/dts/exynos5420-smdk5420.dts rename to arch/arm/dts/exynos5420-smdk5420.dts diff --git a/board/nvidia/dts/tegra114-dalmore.dts b/arch/arm/dts/tegra114-dalmore.dts similarity index 100% rename from board/nvidia/dts/tegra114-dalmore.dts rename to arch/arm/dts/tegra114-dalmore.dts diff --git a/board/toradex/dts/tegra20-colibri_t20_iris.dts b/arch/arm/dts/tegra20-colibri_t20_iris.dts similarity index 100% rename from board/toradex/dts/tegra20-colibri_t20_iris.dts rename to arch/arm/dts/tegra20-colibri_t20_iris.dts diff --git a/board/nvidia/dts/tegra20-harmony.dts b/arch/arm/dts/tegra20-harmony.dts similarity index 100% rename from board/nvidia/dts/tegra20-harmony.dts rename to arch/arm/dts/tegra20-harmony.dts diff --git a/board/avionic-design/dts/tegra20-medcom-wide.dts b/arch/arm/dts/tegra20-medcom-wide.dts similarity index 100% rename from board/avionic-design/dts/tegra20-medcom-wide.dts rename to arch/arm/dts/tegra20-medcom-wide.dts diff --git a/board/compal/dts/tegra20-paz00.dts b/arch/arm/dts/tegra20-paz00.dts similarity index 100% rename from board/compal/dts/tegra20-paz00.dts rename to arch/arm/dts/tegra20-paz00.dts diff --git a/board/avionic-design/dts/tegra20-plutux.dts b/arch/arm/dts/tegra20-plutux.dts similarity index 100% rename from board/avionic-design/dts/tegra20-plutux.dts rename to arch/arm/dts/tegra20-plutux.dts diff --git a/board/nvidia/dts/tegra20-seaboard.dts b/arch/arm/dts/tegra20-seaboard.dts similarity index 100% rename from board/nvidia/dts/tegra20-seaboard.dts rename to arch/arm/dts/tegra20-seaboard.dts diff --git a/board/avionic-design/dts/tegra20-tamonten.dtsi b/arch/arm/dts/tegra20-tamonten.dtsi similarity index 100% rename from board/avionic-design/dts/tegra20-tamonten.dtsi rename to arch/arm/dts/tegra20-tamonten.dtsi diff --git a/board/avionic-design/dts/tegra20-tec.dts b/arch/arm/dts/tegra20-tec.dts similarity index 100% rename from board/avionic-design/dts/tegra20-tec.dts rename to arch/arm/dts/tegra20-tec.dts diff --git a/board/compulab/dts/tegra20-trimslice.dts b/arch/arm/dts/tegra20-trimslice.dts similarity index 100% rename from board/compulab/dts/tegra20-trimslice.dts rename to arch/arm/dts/tegra20-trimslice.dts diff --git a/board/nvidia/dts/tegra20-ventana.dts b/arch/arm/dts/tegra20-ventana.dts similarity index 100% rename from board/nvidia/dts/tegra20-ventana.dts rename to arch/arm/dts/tegra20-ventana.dts diff --git a/board/nvidia/dts/tegra20-whistler.dts b/arch/arm/dts/tegra20-whistler.dts similarity index 100% rename from board/nvidia/dts/tegra20-whistler.dts rename to arch/arm/dts/tegra20-whistler.dts diff --git a/board/nvidia/dts/tegra30-beaver.dts b/arch/arm/dts/tegra30-beaver.dts similarity index 100% rename from board/nvidia/dts/tegra30-beaver.dts rename to arch/arm/dts/tegra30-beaver.dts diff --git a/board/nvidia/dts/tegra30-cardhu.dts b/arch/arm/dts/tegra30-cardhu.dts similarity index 100% rename from board/nvidia/dts/tegra30-cardhu.dts rename to arch/arm/dts/tegra30-cardhu.dts diff --git a/board/avionic-design/dts/tegra30-tamonten.dtsi b/arch/arm/dts/tegra30-tamonten.dtsi similarity index 100% rename from board/avionic-design/dts/tegra30-tamonten.dtsi rename to arch/arm/dts/tegra30-tamonten.dtsi diff --git a/board/avionic-design/dts/tegra30-tec-ng.dts b/arch/arm/dts/tegra30-tec-ng.dts similarity index 100% rename from board/avionic-design/dts/tegra30-tec-ng.dts rename to arch/arm/dts/tegra30-tec-ng.dts diff --git a/board/xilinx/dts/zynq-microzed.dts b/arch/arm/dts/zynq-microzed.dts similarity index 100% rename from board/xilinx/dts/zynq-microzed.dts rename to arch/arm/dts/zynq-microzed.dts diff --git a/board/xilinx/dts/zynq-zc702.dts b/arch/arm/dts/zynq-zc702.dts similarity index 100% rename from board/xilinx/dts/zynq-zc702.dts rename to arch/arm/dts/zynq-zc702.dts diff --git a/board/xilinx/dts/zynq-zc706.dts b/arch/arm/dts/zynq-zc706.dts similarity index 100% rename from board/xilinx/dts/zynq-zc706.dts rename to arch/arm/dts/zynq-zc706.dts diff --git a/board/xilinx/dts/zynq-zc770-xm010.dts b/arch/arm/dts/zynq-zc770-xm010.dts similarity index 100% rename from board/xilinx/dts/zynq-zc770-xm010.dts rename to arch/arm/dts/zynq-zc770-xm010.dts diff --git a/board/xilinx/dts/zynq-zc770-xm012.dts b/arch/arm/dts/zynq-zc770-xm012.dts similarity index 100% rename from board/xilinx/dts/zynq-zc770-xm012.dts rename to arch/arm/dts/zynq-zc770-xm012.dts diff --git a/board/xilinx/dts/zynq-zc770-xm013.dts b/arch/arm/dts/zynq-zc770-xm013.dts similarity index 100% rename from board/xilinx/dts/zynq-zc770-xm013.dts rename to arch/arm/dts/zynq-zc770-xm013.dts diff --git a/board/xilinx/dts/zynq-zed.dts b/arch/arm/dts/zynq-zed.dts similarity index 100% rename from board/xilinx/dts/zynq-zed.dts rename to arch/arm/dts/zynq-zed.dts diff --git a/board/xilinx/dts/microblaze-generic.dts b/arch/microblaze/dts/microblaze-generic.dts similarity index 100% rename from board/xilinx/dts/microblaze-generic.dts rename to arch/microblaze/dts/microblaze-generic.dts diff --git a/board/chromebook-x86/dts/alex.dts b/arch/x86/dts/alex.dts similarity index 100% rename from board/chromebook-x86/dts/alex.dts rename to arch/x86/dts/alex.dts diff --git a/board/chromebook-x86/dts/link.dts b/arch/x86/dts/link.dts similarity index 100% rename from board/chromebook-x86/dts/link.dts rename to arch/x86/dts/link.dts diff --git a/dts/Makefile b/dts/Makefile index c47fba7..5d2abd9 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -12,9 +12,9 @@ ifeq ($(DEVICE_TREE),) DEVICE_TREE := notfound endif
-DTS := $(srctree)/board/$(VENDOR)/dts/$(DEVICE_TREE).dts +DTS := $(srctree)/arch/$(ARCH)/dts/$(DEVICE_TREE).dts
-DTC_FLAGS += -i $(srctree)/arch/$(ARCH)/dts -R 4 -p 0x1000 +DTC_FLAGS += -R 4 -p 0x1000
$(obj)/dt.dtb: $(DTS) FORCE $(call if_changed_dep,dtc) diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index ee3ceac..02b17b1 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -153,7 +153,6 @@ ld_flags = $(LDFLAGS) $(ldflags-y)
# Modified for U-Boot dtc_cpp_flags = -Wp,-MD,$(depfile).pre.tmp -nostdinc \ - -I$(srctree)/board/$(VENDOR)/dts/ \ -I$(srctree)/arch/$(ARCH)/dts \ -undef -D__DTS__
Hi Masahiro,
What is the motivation for this? I worry that we might end up with a lot of files in one directory. One benefit of the current approach is that .dts files are split up by vendor. Even if we put the SoC .dtsi files in arch/arm, perhaps there is a benefit in leaving the board .dts files in board/<vendor>?
I don't have strong feelings, just questing this...
Changes in v2:
- Newly added
-- 1.8.3.2
Hello Simon,
Hi Masahiro,
We have only 35 .dtsi and .dts for ARM. I think it will be OK at least until we have 500.
Linux v3.13 has 500 .dtsi and .dts files in arch/arm/boot/dts/ and they are still adding device trees to that directory.
I have no idea if they will keep going, or someone will scream and turn around.
Anyway, when Linux guys someday invents a nice idea to work arond increasing device trees, we can import it to U-Boot. It should be easy for us because we already have a similar build system.
I don't like the idea to split up by vendor.
Now Xilinx has device trees both for ARM and Microblaze, resulting in totally unrelated device trees in one directory.
What if Freescale decided to adopt device tree? They support various boards on ARM, PowerPC, M68K.
Renesus is the same. They have ARM and SuperH boards.
On the other hand, different vendors can produce similar boards. For example avionic design, which develops Tegra boards, are using nVidia's sources.
When I saw board/nvidia/common/common.mk and board/avionic-design/*/Makefile, etc., I think we're screwed up with <vendor> directory.
Hi Masahiro,
On 5 February 2014 22:50, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hello Simon,
Hi Masahiro,
Hmm, but would it be such a big problem to keep the general ARM and SOC stuff in arch/arm/dts and the board-specific stuff in board/ ?
One of the problems with Linux is that their board-specific code is spread all over the place, and I'm not sure we want to emulate it?
Shouldn't the SoC part go in arch/arm and arch/microblaze? Then just the board-specific stuff can go in board/
I'm not convinced yet. I think maybe you have forgotten about the .dtsi files for SoCs. They are common, but no one is going to include a board .dts file (nor can they), so putting them in a common area does not seem like a win to me.
Well the probably as I see it is that board/nvidia has some SoC code that other boards want to use. The solution to that might be to move the code to arch/arm/cpu/armv7/tegra... instead?
Hello Simon,
Hmm, but would it be such a big problem to keep the general ARM and SOC stuff in arch/arm/dts and the board-specific stuff in board/ ? One of the problems with Linux is that their board-specific code is spread all over the place, and I'm not sure we want to emulate it?
Opposite. Board-specific code mostly resides under arch/arm/mach-* or arch/arm/plat-*. And what else is arch/arm/configs and arch/arm/boot/dts. That's it.
We have board-specific part - entries in boards.cfg - include/configs/<board_config>.h - board/<vendor>/<board> or board/<board> - arch/<ARCH>/include/am/arch-<soc> includes sometimes board-specific headers as well as SoC specific headers. (Because there is no other place to store board-specific header files)
Various stuff under include/, for exmple - include/xilinx.h: vendor specific? - include/sandboxblockdev.h: arch specific?
And we often missed to remove remainders of dead boards.
U-Boot has more troublesome directory structure.
What is SoC part? What is Board part?
I do know that *.dtsi files are included from others, while *.dts files are not included from anywhere. And I understand your policy, *.dtsi to arch dir and *.dts to vendor dir. (No that I care, we have two exceptions: ./board/avionic-design/dts/tegra20-tamonten.dtsi ./board/avionic-design/dts/tegra30-tamonten.dtsi)
If I have to mention a win, we can save makefiles by not putting almost same ones in vendor directories.
Anyway, we have 3 structures proposed so far.
[1] board/$(VENDOR)/dts/ (current structure) [2] arch/$(ARCH)/dts/ (suggested by me) [3] dts/ for all architectures (suggested by Scott)
In my option, [2] and [3] seem to be reasonable enough.
If we cannot reach an agreement, shall we postpone 2/3 and 3/3 and apply only 1/3?
Concerning the result, board/nvidia/common turned out to be SoC-specific code, not Vendor-specific (board-specific) code.
But I guess the difference between SoC-specific code and board-specific code was not clear when nVidia develpers posted that code first.
Maybe I am digressing, but it also happens to me quite often. It is difficult for me to decide whether each code should go to board/panasonic or arch/arm/cpu/armv7/uniphier.
I'd say, vendor (and board) directories are harmful.
Hi Masahiro,
On 18 February 2014 01:43, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hello Simon,
Well Linux got board-specific directories and systems only relatively recently I suppose. U-Boot has the benefit of many years of legacy :-)
Well SoC is the chip from a vendor like Nvidia. Normally they would provide a set of .dtsi files, say for example tegra20.dtsi, tegra30.dtsi, etc. It makes sense to have a common SoC directory that all boards can use.
Then a board that uses say a Tegra SoC on it can just include those files and connect things up as required.
I don't want to hold up progress, but I am not sure that the Linux approach is a great idea. I prefer this:
arch/$(ARCH)/dts - SoC .dtsi files board/$(VENDOR)/dts - Board-specific .dts files (which include the above)
but as you say we don't have a lot of files so it is not a huge deal.
Agreed, but we don't put .dtsi files in there, so that is a different problem.
Interesting...the idea with board files I think is that it is for code specific to a board. My hope is that there would be less of that with device tree, but it is early days.
You are right about the common directory in board/<vendor>. But this is probably worth a wider discussion than just device tree files.
On Thu, Feb 06, 2014 at 02:50:50PM +0900, Masahiro Yamada wrote:
Hello Simon,
Hi Masahiro,
Last I saw the plan, still, is to remove them from the kernel "someday". Hopefully when that happens we can also leverage what comes next.
True.
This, I think is backwards. Xilinx has (and Freescale and others are or will be joining them) a lot of things shared between them as IP blocks get reused from non-ARM to ARM CPUs. So there's a level of DT sharing for these blocks between the CPUs. The kernel is going to start having this problem as vendors start dropping their arm IP blocks into ARMv8 SoCs, and those would be in arch/arm64/. The question is, will people care enough about the duplication, or just live with it.
Hello Simon,
Hi Masahiro,
True.
We share all soft IP drivers between ARM and Microblaze and we will continue in this style. The point is to have the same binding which we have. We are using device-tree generator to get the latest binding which is in sync with kernel. When we adopt u-boot configured by device-tree (when variable handling in u-boot is fixed) we will use the same binding in uboot too.
I personally don't care where DTS files will be placed because we will generate them as we are doing now.
Thanks, Michal
On Wed, 2014-02-05 at 14:47 -0700, Simon Glass wrote:
Hi Masahiro,
Having all the device trees in one place (I don't even see why it should be split by arch; some common dtsi files may be shared by multiple arches) is nice for grepping and maintenance. If it gets too large it can grow an internal hierarchy.
Just like net drivers go under drivers/net regardless of arch, etc.
-Scott
It is convenient to have all device trees on the same SoC compiled. It allows for later easy repackaging without the need to re-run the make file.
- Build device trees with the same SoC under arch/$(ARCH)/dts - Copy the one specified by CONFIG_DEFAULT_DEVICE_TREE or DEVICE_TREE=... to dts/dt.dtb
arch/arm/dts/.gitignore | 1 + arch/arm/dts/Makefile | 37 +++++++++++++++++++++++++++++++++++++ arch/microblaze/dts/.gitignore | 1 + arch/microblaze/dts/Makefile | 11 +++++++++++ arch/x86/dts/.gitignore | 1 + arch/x86/dts/Makefile | 12 ++++++++++++ dts/Makefile | 31 ++++++++++++++++++++----------- 7 files changed, 83 insertions(+), 11 deletions(-) create mode 100644 arch/arm/dts/.gitignore create mode 100644 arch/arm/dts/Makefile create mode 100644 arch/microblaze/dts/.gitignore create mode 100644 arch/microblaze/dts/Makefile create mode 100644 arch/x86/dts/.gitignore create mode 100644 arch/x86/dts/Makefile
diff --git a/arch/arm/dts/.gitignore b/arch/arm/dts/.gitignore new file mode 100644 index 0000000..b60ed20 --- /dev/null +++ b/arch/arm/dts/.gitignore @@ -0,0 +1 @@ +*.dtb diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile new file mode 100644 index 0000000..2658911 --- /dev/null +++ b/arch/arm/dts/Makefile @@ -0,0 +1,37 @@ +dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ + exynos5250-snow.dtb \ + exynos5250-smdk5250.dtb \ + exynos5420-smdk5420.dtb + +dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ + tegra20-medcom-wide.dtb \ + tegra20-paz00.dtb \ + tegra20-plutux.dtb \ + tegra20-seaboard.dtb \ + tegra20-tec.dtb \ + tegra20-trimslice.dtb \ + tegra20-ventana.dtb \ + tegra20-whistler.dtb \ + tegra20-colibri_t20_iris.dtb \ + tegra30-beaver.dtb \ + tegra30-cardhu.dtb \ + tegra30-tec-ng.dtb \ + tegra114-dalmore.dtb + +dtb-$(CONFIG_ZYNQ) += zynq-zc702.dtb \ + zynq-zc706.dtb \ + zynq-zed.dtb \ + zynq-microzed.dtb \ + zynq-zc770-xm010.dtb \ + zynq-zc770-xm012.dtb \ + zynq-zc770-xm013.dtb + +targets += $(dtb-y) + +DTC_FLAGS += -R 4 -p 0x1000 + +PHONY += dtbs +dtbs: $(addprefix $(obj)/, $(dtb-y)) + @: + +clean-files := *.dtb diff --git a/arch/microblaze/dts/.gitignore b/arch/microblaze/dts/.gitignore new file mode 100644 index 0000000..b60ed20 --- /dev/null +++ b/arch/microblaze/dts/.gitignore @@ -0,0 +1 @@ +*.dtb diff --git a/arch/microblaze/dts/Makefile b/arch/microblaze/dts/Makefile new file mode 100644 index 0000000..6d4a11f --- /dev/null +++ b/arch/microblaze/dts/Makefile @@ -0,0 +1,11 @@ +dtb-y += microblaze-generic.dtb + +targets += $(dtb-y) + +DTC_FLAGS += -R 4 -p 0x1000 + +PHONY += dtbs +dtbs: $(addprefix $(obj)/, $(dtb-y)) + @: + +clean-files := *.dtb diff --git a/arch/x86/dts/.gitignore b/arch/x86/dts/.gitignore new file mode 100644 index 0000000..b60ed20 --- /dev/null +++ b/arch/x86/dts/.gitignore @@ -0,0 +1 @@ +*.dtb diff --git a/arch/x86/dts/Makefile b/arch/x86/dts/Makefile new file mode 100644 index 0000000..27374a4 --- /dev/null +++ b/arch/x86/dts/Makefile @@ -0,0 +1,12 @@ +dtb-y += link.dts \ + alex.dts + +targets += $(dtb-y) + +DTC_FLAGS += -R 4 -p 0x1000 + +PHONY += dtbs +dtbs: $(addprefix $(obj)/, $(dtb-y)) + @: + +clean-files := *.dtb diff --git a/dts/Makefile b/dts/Makefile index 5d2abd9..5a432c7 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -9,24 +9,30 @@
DEVICE_TREE ?= $(CONFIG_DEFAULT_DEVICE_TREE:"%"=%) ifeq ($(DEVICE_TREE),) -DEVICE_TREE := notfound +DEVICE_TREE := unset endif
-DTS := $(srctree)/arch/$(ARCH)/dts/$(DEVICE_TREE).dts +DTB := arch/$(ARCH)/dts/$(DEVICE_TREE).dtb
-DTC_FLAGS += -R 4 -p 0x1000 +quiet_cmd_cp = CP $@ +cmd_cp = cp $< $@
-$(obj)/dt.dtb: $(DTS) FORCE - $(call if_changed_dep,dtc) +$(obj)/dt.dtb: $(DTB) FORCE + $(call if_changed,cp)
targets += dt.dtb
-$(DTS): - @echo >&2 - @echo >&2 "Device Tree Source is not specified." - @echo >&2 "Please define 'CONFIG_DEFAULT_DEVICE_TREE'" - @echo >&2 "or build with 'DEVICE_TREE=<dts-file-name>' argument" - @/bin/false +$(DTB): arch-dtbs + $(Q)test -e $@ || ( \ + echo >&2; \ + echo >&2 "Device Tree Source is not correctly specified."; \ + echo >&2 "Please define 'CONFIG_DEFAULT_DEVICE_TREE'"; \ + echo >&2 "or build with 'DEVICE_TREE=<dts-file>' argument"; \ + echo >&2; \ + /bin/false) + +arch-dtbs: + $(Q)$(MAKE) $(build)=arch/$(ARCH)/dts dtbs
@@ -36,3 +42,6 @@ dtbs: $(obj)/dt.dtb @:
clean-files := dt.dtb.S + +# Let clean descend into dts directories +subdir- += ../arch/*/dts
Hi Masahiro,
Changes in v2:
- Newly added
tegra20-paz00.dtb \
tegra20-tec.dtb \
zynq-zc706.dtb \
zynq-zed.dtb \
zynq-microzed.dtb \
This better matches what the kernel does, but I'm not 100% comfortable about putting all these files in arch/arm. Granted the vendor directory may not correspond to a particular SoC, but we can put tegra20.dtsi in arch/arm/dts so that all tegra boards can use it, for example.
participants (5)
Masahiro Yamada
Michal Simek
Scott Wood
