[U-Boot] [PATCH] net: write enetaddr down to hardware on env_callback
If mac-address is changed using "setenv ethaddr ...." command the new mac-adress also must be written into the responsible ethernet driver.
Signed-off-by: Hannes Schmelzer oe5hpm@oevsv.at
net/eth-uclass.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/net/eth-uclass.c b/net/eth-uclass.c index c15cc4d..a32961e 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -227,6 +227,7 @@ static int on_ethaddr(const char *name, const char *value, enum env_op op, case env_op_create: case env_op_overwrite: eth_parse_enetaddr(value, pdata->enetaddr); + eth_write_hwaddr(dev); break; case env_op_delete: memset(pdata->enetaddr, 0, 6);
On Fri, Sep 2, 2016 at 9:00 PM, Joe Hershberger joe.hershberger@gmail.com wrote:
Why is this needed? The MAC address is supposed to be programmed in the driver's probe routine.
Regards, Bin
"U-Boot" u-boot-bounces@lists.denx.de schrieb am 06.09.2016 03:54:52:
Von: Bin Meng bmeng.cn@gmail.com An: Joe Hershberger joe.hershberger@gmail.com, Kopie: u-boot u-boot@lists.denx.de, Hannes Schmelzer
oe5hpm@oevsv.at, Joe
Hershberger joe.hershberger@ni.com Datum: 06.09.2016 03:57 Betreff: Re: [U-Boot] [PATCH] net: write enetaddr down to hardware on
env_callback
Gesendet von: "U-Boot" u-boot-bounces@lists.denx.de
Hi Bin,
For example on my custom ZYNQ board. The Ethernetcontroller within the ZYNQ has no ROM to store his own MAC-Address, further no MAC is stored within environment. So Ethernet gets probed with a "random MAC-Address" if configured.
Later somebody (like me) oder something (my bootscript) runs "setenv ethaddr ...." on the console. Result is (was before this patch), that all networking infrastructre is running this new mac, but hardware is running the old (random) one and networking is simple not functional.
ok?
Regards, Bin
cheers, Hannes
Hi Hannes,
On Tue, Sep 6, 2016 at 12:33 PM, Hannes Schmelzer Hannes.Schmelzer@br-automation.com wrote:
env_callback
Hi Bin,
This indicates that your ethernet driver does not program the latest MAC address everyone when it gets probed. The driver should be fixed.
ok?
Regards, Bin
Bin Meng bmeng.cn@gmail.com schrieb am 06.09.2016 09:07:39:
is
The driver doesn't get probed again if mac-address is changed using "setenv ethaddr", so it has no chance to program anything.
For program i understand, in this case with zynq, overtaking mac-address into his registers. There is per default no ROM to store some mac.
Regards, Bin
cheers, Hannes
Hi Hannes,
On Tue, Sep 6, 2016 at 3:23 PM, Hannes Schmelzer Hannes.Schmelzer@br-automation.com wrote:
is
Yes, driver is not probed when "setenv ethaddr", but next time when you type any ethernet related command (like tftpboot), the driver will be probed.
I have feeling that for some ethernet controllers, simply calling eth_write_hwaddr() may not change its MAC address correctly. It may need some special programming sequence like firstly turn off, reset, then program the MAC.
Regards, Bin
Bin Meng bmeng.cn@gmail.com schrieb am 06.09.2016 09:28:13:
Von: Bin Meng bmeng.cn@gmail.com An: Hannes Schmelzer Hannes.Schmelzer@br-automation.com, Kopie: Joe Hershberger joe.hershberger@gmail.com, Joe Hershberger joe.hershberger@ni.com, Hannes Schmelzer oe5hpm@oevsv.at, u-boot <u- boot@lists.denx.de>, U-Boot u-boot-bounces@lists.denx.de Datum: 06.09.2016 09:28 Betreff: Re: Re: Re: [U-Boot] [PATCH] net: write enetaddr down to
hardware on
env_callback
Hi Hannes,
in
"setenv
infrastructre
is
and
No. The ethernet driver isn't probed everytime a network transaction is coming. What i can see, the probe is done one time.
mac-address
That might be possible. Maybe this is the reason why not all drivers provide this function.
Regards, Bin
participants (5)
Bin Meng
Hannes Schmelzer
Hannes Schmelzer
Joe Hershberger
Joe Hershberger
