[PATCH] imx6: Remove unneeded CONFIG_DM_MDIO
As explained in the CONFIG_DM_MDIO text inside drivers/net/Kconfig:
"Useful in particular for systems that support DM_ETH and have a stand-alone MDIO hardware block shared by multiple Ethernet interfaces."
i.MX6 has a single FEC instance, so there is no need to select CONFIG_DM_MDIO.
Remove it from the i.MX6 defconfig files.
Signed-off-by: Fabio Estevam festevam@gmail.com --- configs/apalis_imx6_defconfig | 1 - configs/colibri_imx6_defconfig | 1 - configs/dh_imx6_defconfig | 1 - configs/mx6sabreauto_defconfig | 1 - configs/mx6sabresd_defconfig | 1 - 5 files changed, 5 deletions(-)
diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 34d939a0e9..e162f0a5e8 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -74,7 +74,6 @@ CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y -CONFIG_DM_MDIO=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 11cd1da26e..ffa773b581 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -73,7 +73,6 @@ CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y -CONFIG_DM_MDIO=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index d91ff77a4a..e643ade2e6 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -77,7 +77,6 @@ CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y -CONFIG_DM_MDIO=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 56fe307e63..106c967652 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -76,7 +76,6 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y -CONFIG_DM_MDIO=y CONFIG_FEC_MXC=y CONFIG_RGMII=y CONFIG_MII=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 24bc8630f1..f88c629fbf 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -83,7 +83,6 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y -CONFIG_DM_MDIO=y CONFIG_FEC_MXC=y CONFIG_RGMII=y CONFIG_MII=y
Hi Fabio,
This has a side-effect because it breaks mx6memcal. I propose to let this in and to fix mx6memcal as follows:
diff --git a/configs/mx6memcal_defconfig b/configs/mx6memcal_defconfig index 57e44a14ba..01a0fff6e0 100644 --- a/configs/mx6memcal_defconfig +++ b/configs/mx6memcal_defconfig @@ -39,6 +39,7 @@ CONFIG_SYS_MEMTEST_END=0x20000000 CONFIG_CMD_CACHE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_NET is not set +CONFIG_DM=y # CONFIG_MMC is not set CONFIG_FSL_USDHC=y CONFIG_USB=y @@ -47,4 +48,5 @@ CONFIG_USB_GADGET_MANUFACTURER="FSL" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y -CONFIG_REGEX=y +CONFIG_OF_LIBFDT=y +# CONFIG_EFI_LOADER is not set
(I will send afterwards a proper patch).
What do you think ?
Stefano
Hi Stefano,
I was not able to reproduce the build break on mx6memcal_defconfig here.
Just applied the patch against U-Boot master and mx6memcal_defconfig built fine.
Could you please share the build error log?
This patch does not touch mx6memcal, so not sure how it breaks it.
Thanks
On 16.07.20 14:18, Fabio Estevam wrote:
Hi Stefano,
Right - it looks like that CONFIG_DM is removed at all from mx6memcal, removing an implicit OF_LIBFDT.
https://travis-ci.org/github/sbabic/u-boot-imx/jobs/708667322
Stefano
Hi Stefano,
I think your proposed patch makes sense.
I have compared the .config file generated from mx6memcal_defconfig before and after my patch and they are identical.
Thanks
On 16.07.20 15:03, Fabio Estevam wrote:
Hi Stefano,
I do not think the issue is caused by your patch - it is like a side effect and implicitely some CONFIG_ are turned off for memcal.
I send a formal patch.
Regards, Stefano
As explained in the CONFIG_DM_MDIO text inside drivers/net/Kconfig: "Useful in particular for systems that support DM_ETH and have a stand-alone MDIO hardware block shared by multiple Ethernet interfaces."
i.MX6 has a single FEC instance, so there is no need to select CONFIG_DM_MDIO. Remove it from the i.MX6 defconfig files. Signed-off-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Fabio Estevam
sbabic@denx.de
Stefano Babic
