[U-Boot] [PATCH] net: eth-uclass: call stop only for active devices
Currently stop is being called unconditionally without even checking if start is called. In case of multiple instances eth being present many devices might just be initialized without a start call in such cases stop might lead unpredictable behaviors including aborts and crashes. Hence add a check before calling stop.
Signed-off-by: Keerthy j-keerthy@ti.com --- net/eth-uclass.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/net/eth-uclass.c b/net/eth-uclass.c index 2ef20df192..26f7e0b8cd 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -531,7 +531,8 @@ static int eth_pre_remove(struct udevice *dev) { struct eth_pdata *pdata = dev->platdata;
- eth_get_ops(dev)->stop(dev); + if (eth_is_active(dev)) + eth_get_ops(dev)->stop(dev);
/* clear the MAC address */ memset(pdata->enetaddr, 0, ARP_HLEN);
eth_get_ops(dev)->stop(dev); /* clear the MAC address */ memset(pdata->enetaddr, 0, ARP_HLEN);
-- 2.17.1
Could you please provide a test case?
Regards, Bin
Presumably that test should live in test/dm/eth.c with some potential support needed by drivers/net/sandbox.c
Thanks, -Joe
Regards, Bin _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
This seems reasonable... What was the case that provoked an issue? Which driver was having trouble?
-- 2.17.1
I am trying to implement pru based ethernet driver(multiple instances) with cpsw driver on top on am654-evm. I observed that even though i had not started a particular instance of my pru based device stop was getting called and it was crashing right at the end.
-- 2.17.1
Please add a proper test case in test/dm/eth.c to cover such scenarios. Thanks!
Regards, Bin
Joe,
I am yet to implement a test case for this. Can this patch be applied independently?
Regards, Keerthy
/* clear the MAC address */ memset(pdata->enetaddr, 0, ARP_HLEN); -- 2.17.1
participants (5)
Bin Meng
Joe Hershberger
Keerthy
Keerthy
