[PATCH 1/2] pico-imx6: Add DM_SERIAL support
The conversion to DM_SERIAL is mandatory, so add support for it.
Signed-off-by: Fabio Estevam festevam@denx.de --- configs/pico-imx6_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/pico-imx6_defconfig b/configs/pico-imx6_defconfig index a6ed013f8b..f79b7ec520 100644 --- a/configs/pico-imx6_defconfig +++ b/configs/pico-imx6_defconfig @@ -83,6 +83,7 @@ CONFIG_RGMII=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_USB=y CONFIG_USB_GADGET=y
Originally, the mmc aliases node was present in imx6qdl-pico.dtsi.
After the sync with Linux in commit d0399a46e7cd ("imx6dl/imx6qdl: synchronise device trees with linux"), the aliases node is gone as the upstream version does not have it.
This causes a boot regression in which the eMMC card cannot be found anymore.
Fix it by passing the alias node in the u-boot.dtsi file to restore the original behaviour where the eMMC (esdhc3) was mapped to mmc0.
Fixes: d0399a46e7cd ("imx6dl/imx6qdl: synchronise device trees with linux") Signed-off-by: Fabio Estevam festevam@denx.de --- arch/arm/dts/imx6dl-pico-u-boot.dtsi | 7 +++++++ 1 file changed, 7 insertions(+) create mode 100644 arch/arm/dts/imx6dl-pico-u-boot.dtsi
diff --git a/arch/arm/dts/imx6dl-pico-u-boot.dtsi b/arch/arm/dts/imx6dl-pico-u-boot.dtsi new file mode 100644 index 0000000000..e2ef9bcc14 --- /dev/null +++ b/arch/arm/dts/imx6dl-pico-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT + +/ { + aliases { + mmc0 = &usdhc3; + }; +};
Applied to u-boot-imx, next, thanks !
Best regards, Stefano Babic
Hi Tom and Stefano,
Since this one fixes a boot regression, could it be applied to 2023.04?
Thanks
On Mon, Apr 03, 2023 at 09:25:11AM -0300, Fabio Estevam wrote:
Hi Tom and Stefano,
I have cherry-picked this to master.
The conversion to DM_SERIAL is mandatory, so add support for it. Signed-off-by: Fabio Estevam festevam@denx.de
Fabio Estevam
Fabio Estevam
sbabic@denx.de
