Re: [U-Boot] m68k: Fix warnings with gcc 4.6
Hi Jason,
On 24 June 2014 07:06, Jason.Jin@freescale.com Jason.Jin@freescale.com wrote:
[snip]
-----Original Message----- From: Tom Rini [mailto:tom.rini@gmail.com] On Behalf Of Tom Rini
Well, lets cycle back and see if we can get some answers, before we need to start taking some more drastic action perhaps. Jason, is there a toolchain for which MAKEALL -a m68k works? If not, do we need to start removing some no longer used / maintained boards? Thanks!
It's not relate to the used or no longer used boards. For ColdFire with MMU and non-MMU part, we need two different toolchain, so currently we cannot use MAKEALL -a m68k to build all the ColdFire boards. Thanks.
Jason
Thank seems a bit unfortunate. I wonder if there is a way to distinguish the two boards from their boards.cfg entry? We could perhaps add a feature to buildman to support building the same arch with two different toolchains if that is what it takes?
Also, can you please send a link so I can download the two toolchains?
