[U-Boot] [PATCH] tools: mksunxiboot: Fix problems on big endian systems
Now my PS3 can be also used to build u-boot for sunxi devices.
Signed-off-by: Siarhei Siamashka siarhei.siamashka@gmail.com --- tools/mksunxiboot.c | 14 ++++++++------ 1 file changed, 8 insertions(+), 6 deletions(-)
diff --git a/tools/mksunxiboot.c b/tools/mksunxiboot.c index 1f0fbae..0035f6e 100644 --- a/tools/mksunxiboot.c +++ b/tools/mksunxiboot.c @@ -43,19 +43,19 @@ int gen_check_sum(struct boot_file_head *head_p) uint32_t i; uint32_t sum;
- length = head_p->length; + length = le32_to_cpu(head_p->length); if ((length & 0x3) != 0) /* must 4-byte-aligned */ return -1; buf = (uint32_t *)head_p; - head_p->check_sum = STAMP_VALUE; /* fill stamp */ + head_p->check_sum = cpu_to_le32(STAMP_VALUE); /* fill stamp */ loop = length >> 2;
/* calculate the sum */ for (i = 0, sum = 0; i < loop; i++) - sum += buf[i]; + sum += le32_to_cpu(buf[i]);
/* write back check sum */ - head_p->check_sum = sum; + head_p->check_sum = cpu_to_le32(sum);
return 0; } @@ -125,10 +125,12 @@ int main(int argc, char *argv[]) memcpy(img.header.magic, BOOT0_MAGIC, 8); /* no '0' termination */ img.header.length = ALIGN(file_size + sizeof(struct boot_file_head), BLOCK_SIZE); + img.header.b_instruction = cpu_to_le32(img.header.b_instruction); + img.header.length = cpu_to_le32(img.header.length); gen_check_sum(&img.header);
- count = write(fd_out, &img, img.header.length); - if (count != img.header.length) { + count = write(fd_out, &img, le32_to_cpu(img.header.length)); + if (count != le32_to_cpu(img.header.length)) { perror("Writing output"); return EXIT_FAILURE; }
Thanks, applied to u-boot-sunxi/next and included in the pull-req which I've just send out.
Regards,
Hans
- length = le32_to_cpu(head_p->length); if ((length & 0x3) != 0) /* must 4-byte-aligned */ return -1; buf = (uint32_t *)head_p;
sum += buf[i];
return 0; }
- img.header.b_instruction = cpu_to_le32(img.header.b_instruction);
- img.header.length = cpu_to_le32(img.header.length); gen_check_sum(&img.header);
- count = write(fd_out, &img, le32_to_cpu(img.header.length));
- if (count != le32_to_cpu(img.header.length)) { perror("Writing output"); return EXIT_FAILURE; }
Hans de Goede
Siarhei Siamashka
