[U-Boot] [PATCH] net: macb: Fix rx buffer cache handling
With commit c6d07bf440bc ("net/macb: increase RX buffer size for GEM") ethernet support does not work any more with d-cache enabled on the AT91SAM. The reason is, that MACB_RX_BUFFER_SIZE was changed from 4096 to 128 but this change was not refected in the rx_buffer flush and invalidate functions, as these also use this macro.
This patch now fixes this by calculating the rx buffer size correctly again in those functions. With this change, ethernet works again reliably on my AT91SAM board.
Signed-off-by: Stefan Roese sr@denx.de Cc: Ramon Fried rfried.dev@gmail.com Cc: Eugen Hristev eugen.hristev@microchip.com Cc: Anup Patel anup.patel@wdc.com Cc: Bin Meng bmeng.cn@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/macb.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index c99cf663a4..fca380d012 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -296,13 +296,15 @@ static inline void macb_flush_ring_desc(struct macb_device *macb, bool rx) static inline void macb_flush_rx_buffer(struct macb_device *macb) { flush_dcache_range(macb->rx_buffer_dma, macb->rx_buffer_dma + - ALIGN(MACB_RX_BUFFER_SIZE, PKTALIGN)); + ALIGN(MACB_RX_BUFFER_SIZE * MACB_RX_RING_SIZE, + PKTALIGN)); }
static inline void macb_invalidate_rx_buffer(struct macb_device *macb) { invalidate_dcache_range(macb->rx_buffer_dma, macb->rx_buffer_dma + - ALIGN(MACB_RX_BUFFER_SIZE, PKTALIGN)); + ALIGN(MACB_RX_BUFFER_SIZE * MACB_RX_RING_SIZE, + PKTALIGN)); }
#if defined(CONFIG_CMD_NET)
Hi Stefan,
PKTALIGN));
This looks wrong to me.
Shouldn't it be:
flush_dcache_range(macb->rx_buffer_dma, macb->rx_buffer_dma + ALIGN(macb->rx_buffer_size, PKTALIGN));
PKTALIGN));
Regards, Bin
On Fri, Aug 23, 2019 at 5:17 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Stefan,
PKTALIGN));
Shouldn't it be:
Ah, for MACB, looks it should be "MACB_RX_BUFFER_SIZE * MACB_RX_RING_SIZE", but for GEM, I am not sure.
Should it be:
flush_dcache_range(macb->rx_buffer_dma, macb->rx_buffer_dma + ALIGN(macb->rx_buffer_size * MACB_RX_RING_SIZE, PKTALIGN));
PKTALIGN));
Regards, Bin
Hi Bin,
Hi Stefan,
PKTALIGN));
Shouldn't it be:
Should it be:
Yes, this looks correct. v2 will follow soon.
Thanks, Stefan
On Fri, Aug 23, 2019 at 1:37 PM Stefan Roese sr@denx.de wrote:
Hi Bin,
Hi Stefan,
PKTALIGN));
Shouldn't it be:
Should it be:
Thanks, Stefan
Thanks Stefan, Can you fix your commit message to show: Fixes:...
You can use the following bash alias to generate the line: (pass c6d07bf440bc as argument) alias gfixes='git --no-pager show -s --abbrev-commit --abbrev=12 --pretty=format:"Fixes: %h ("%s")%n"'
Should it be:
Thanks, Stefan
The entire cache handling is broken in this driver, I will fix it in future patches. Thanks, Ramon.
Hi Stefan,
PKTALIGN));
Shouldn't it be:
Should it be:
Good catch !, I'll issue a fix soon. Thanks, Ramon
PKTALIGN));
Regards, Bin
Bin Meng
Ramon Fried
Stefan Roese
