[U-Boot] [PATCH] ARM64: rockchip: split RK3399-Q7 board off the RK3399-EVB board
From: Klaus Goger klaus.goger@theobroma-systems.com
The RK3399-Q7 SoM is a Qseven-compatible (70mm x 70mm, MXM-230 connector) system-on-module from Theobroma Systems, featuring the Rockchip RK3399.
It provides the following feature set: * up to 4GB DDR3 * on-module SPI-NOR flash * on-module eMMC (with 8-bit interace) * SD card (on a baseboad) via edge connector * Gigabit Ethernet w/ on-module Micrel KSZ9031 GbE PHY * HDMI/eDP/MIPI displays * 2x MIPI-CSI * USB - 1x USB 3.0 dual-role (direct connection) - 2x USB 3.0 host + 1x USB 2.0 (on-module USB 3.0 hub) * on-module STM32 Cortex-M0 companion controller, implementing: - low-power RTC functionality (ISL1208 emulation) - fan controller (AMC6821 emulation) - USB<->CAN bridge controller
Signed-off-by: Klaus Goger klaus.goger@theobroma-systems.com Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
arch/arm/mach-rockchip/rk3399/Kconfig | 19 ++++++ board/theobroma-systems/puma_rk3399/Kconfig | 15 +++++ board/theobroma-systems/puma_rk3399/MAINTAINERS | 10 +++ board/theobroma-systems/puma_rk3399/Makefile | 7 +++ board/theobroma-systems/puma_rk3399/README | 73 ++++++++++++++++++++++ .../theobroma-systems/puma_rk3399/fit_spl_atf.its | 57 +++++++++++++++++ board/theobroma-systems/puma_rk3399/puma-rk3399.c | 69 ++++++++++++++++++++ configs/puma-rk3399_defconfig | 3 +- include/configs/puma_rk3399.h | 26 ++++++++ 9 files changed, 278 insertions(+), 1 deletion(-) create mode 100644 board/theobroma-systems/puma_rk3399/Kconfig create mode 100644 board/theobroma-systems/puma_rk3399/MAINTAINERS create mode 100644 board/theobroma-systems/puma_rk3399/Makefile create mode 100644 board/theobroma-systems/puma_rk3399/README create mode 100644 board/theobroma-systems/puma_rk3399/fit_spl_atf.its create mode 100644 board/theobroma-systems/puma_rk3399/puma-rk3399.c create mode 100644 include/configs/puma_rk3399.h
diff --git a/arch/arm/mach-rockchip/rk3399/Kconfig b/arch/arm/mach-rockchip/rk3399/Kconfig index 83bd04a..415466a 100644 --- a/arch/arm/mach-rockchip/rk3399/Kconfig +++ b/arch/arm/mach-rockchip/rk3399/Kconfig @@ -10,6 +10,24 @@ config TARGET_EVB_RK3399 with full function and phisical connectors support like type-C ports, usb2.0 host ports, LVDS, JTAG, MAC, SDcard, HDMI, USB-2-serial...
+config TARGET_PUMA_RK3399 + bool "Theobroma Systems RK3399-Q7 (Puma)" + help + The RK3399-Q7 (Puma) is a system-on-module (designed and + marketed by Theobroma Systems) featuring the Rockchip RK3399 + in a Qseven-compatible form-factor (running of a single 5V + supply and exposing its external interfaces on a MXM-230 + connector). + + Key features of the RK3399-Q7 include: + * on-module USB 3.0 hub (2x USB 3.0 host + 1x USB 2.0 host) + * USB 3.0 dual-role + * on-module Micrel KSZ9031 GbE PHY + * on-module eMMC (up to 256GB configurations available) + * on-module DDR3 (1GB, 2GB and 4GB configurations available) + * HDMI, eDP, MIPI-DSI, MIPI-DSI/CSI and MIPI-CSI + * SPI, I2C, I2S, UART, GPIO, ... + endchoice
config SYS_SOC @@ -19,5 +37,6 @@ config SYS_MALLOC_F_LEN default 0x0800
source "board/rockchip/evb_rk3399/Kconfig" +source "board/theobroma-systems/puma_rk3399/Kconfig"
endif diff --git a/board/theobroma-systems/puma_rk3399/Kconfig b/board/theobroma-systems/puma_rk3399/Kconfig new file mode 100644 index 0000000..a645590 --- /dev/null +++ b/board/theobroma-systems/puma_rk3399/Kconfig @@ -0,0 +1,15 @@ +if TARGET_PUMA_RK3399 + +config SYS_BOARD + default "puma_rk3399" + +config SYS_VENDOR + default "theobroma-systems" + +config SYS_CONFIG_NAME + default "puma_rk3399" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/theobroma-systems/puma_rk3399/MAINTAINERS b/board/theobroma-systems/puma_rk3399/MAINTAINERS new file mode 100644 index 0000000..ccec09c --- /dev/null +++ b/board/theobroma-systems/puma_rk3399/MAINTAINERS @@ -0,0 +1,10 @@ +PUMA-RK3399 +M: Philipp Tomsich philipp.tomsich@theobroma-systems.com +M: Klaus Goger klaus.goger@theobroma-systems.com +S: Maintained +F: board/theobroma-systems/puma_rk3399 +F: include/configs/puma_rk3399.h +F: arch/arm/dts/rk3399-puma.dts +F: configs/puma-rk3399_defconfig +W: https://www.theobroma-systems.com/rk3399-q7/tech-specs +T: git git://git.theobroma-systems.com/puma-u-boot.git diff --git a/board/theobroma-systems/puma_rk3399/Makefile b/board/theobroma-systems/puma_rk3399/Makefile new file mode 100644 index 0000000..d962b56 --- /dev/null +++ b/board/theobroma-systems/puma_rk3399/Makefile @@ -0,0 +1,7 @@ +# +# (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += puma-rk3399.o diff --git a/board/theobroma-systems/puma_rk3399/README b/board/theobroma-systems/puma_rk3399/README new file mode 100644 index 0000000..472e5cd --- /dev/null +++ b/board/theobroma-systems/puma_rk3399/README @@ -0,0 +1,73 @@ +Introduction +============ + +The RK3399-Q7 (Puma) is a system-on-module featuring the Rockchip +RK3399 in a Qseven-compatible form-factor. + +RK3399-Q7 features: + * CPU: ARMv8 64bit Big-Little architecture, + * Big: dual-core Cortex-A72 + * Little: quad-core Cortex-A53 + * IRAM: 200KB + * DRAM: 4GB-128MB dual-channel + * eMMC: onboard eMMC + * SD/MMC + * GbE (onboard Micrel KSZ9031) Gigabit ethernet PHY + * USB: + * USB3.0 dual role port + * 2x USB3.0 host, 1x USB2.0 host via onboard USB3.0 hub + * Display: HDMI/eDP/MIPI + * Camera: 2x CSI (one on the edge connector, one on the Q7 specified CSI ZIF) + * NOR Flash: onboard SPI NOR + * Companion Controller: onboard additional Cortex-M0 microcontroller + * RTC + * fan controller + * CAN + +Here is the step-by-step to boot to U-Boot on rk3399. + +Get the Source and build ATF/Cortex-M0 binaries +=============================================== + + > git clone git://git.theobroma-systems.com/arm-trusted-firmware.git + > git clone git://git.theobroma-systems.com/rk3399-cortex-m0.git + +Compile the ATF +=============== + + > cd arm-trusted-firmware + > make CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399 bl31 + > cp build/rk3399/release/bl31.bin ../u-boot + +Compile the M0 firmware +======================= + + > cd ../rk3399-cortex-m0 + > make CROSS_COMPILE=arm-cortex_m0-eabi- + > cp rk3399m0.bin ../u-boot + +Compile the U-Boot +================== + + > cd ../u-boot + > make CROSS_COMPILE=aarch64-linux-gnu- puma-rk3399_defconfig all + +Package the image +================= + + > tools/mkimage -n rk3399 -T rksd -d spl/u-boot-spl.bin spl.img + > tools/mkimage -f board/theobroma/puma_rk3399/fit_spl_atf.its \ + -E rk3399_bl3x.itb + +Flash the image +=============== + +Copy the SPL to offset 32k and the FIT image containing the payloads +(U-Boot proper, ATF, M0 Firmware, devicetree) to offset 256k on a SD +card. + + > dd if=spl.img of=/dev/sdb seek=64 + > dd if=rk3399_bl3x.itb of=/dev/sde seek=512 + +After powering up the board (with the inserted SD card), you should see +a U-Boot console on UART0 (115200n8). diff --git a/board/theobroma-systems/puma_rk3399/fit_spl_atf.its b/board/theobroma-systems/puma_rk3399/fit_spl_atf.its new file mode 100644 index 0000000..f93c251 --- /dev/null +++ b/board/theobroma-systems/puma_rk3399/fit_spl_atf.its @@ -0,0 +1,57 @@ +/* + * Copyright (C) 2017 Theobroma Systems Design und Consulting GmbH + * + * Minimal dts for a SPL FIT image payload. + * + * SPDX-License-Identifier: GPL-2.0+ X11 + */ + +/dts-v1/; + +/ { + description = "FIT image with U-Boot proper, ATF bl31, M0 Firmware, DTB"; + #address-cells = <1>; + + images { + uboot@1 { + description = "U-Boot (64-bit)"; + data = /incbin/("../../../u-boot-nodtb.bin"); + type = "standalone"; + arch = "arm64"; + compression = "none"; + load = <0x00200000>; + }; + atf@1 { + description = "ARM Trusted Firmware"; + data = /incbin/("../../../bl31.bin"); + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <0x00001000>; + entry = <0x00001000>; + }; + pmu@1 { + description = "Cortex-M0 firmware"; + data = /incbin/("../../../rk3399m0.bin"); + type = "pmu-firmware"; + compression = "none"; + load = <0xff8c0000>; + }; + fdt@1 { + description = "RK3399-Q7 (Puma) flat device-tree"; + data = /incbin/("../../../u-boot.dtb"); + type = "flat_dt"; + compression = "none"; + }; + }; + + configurations { + default = "conf@1"; + conf@1 { + description = "Theobroma Systems RK3399-Q7 (Puma) SoM"; + firmware = "uboot@1"; + loadables = "atf@1"; + fdt = "fdt@1"; + }; + }; +}; diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c new file mode 100644 index 0000000..e1bf751 --- /dev/null +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -0,0 +1,69 @@ +/* + * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <dm.h> +#include <dm/pinctrl.h> +#include <dm/uclass-internal.h> +#include <asm/arch/periph.h> +#include <power/regulator.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + struct udevice *pinctrl, *regulator; + int ret; + + /* + * The PWM does not have decicated interrupt number in dts and can + * not get periph_id by pinctrl framework, so let's init them here. + * The PWM2 and PWM3 are for pwm regulators. + */ + ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); + if (ret) { + debug("%s: Cannot find pinctrl device\n", __func__); + goto out; + } + + ret = pinctrl_request_noflags(pinctrl, PERIPH_ID_PWM2); + if (ret) { + debug("%s PWM2 pinctrl init fail!\n", __func__); + goto out; + } + + /* rk3399 need to init vdd_center to get the correct output voltage */ + ret = regulator_get_by_platname("vdd_center", ®ulator); + if (ret) + debug("%s: Cannot get vdd_center regulator\n", __func__); + + ret = regulator_get_by_platname("vcc5v0_host", ®ulator); + if (ret) { + debug("%s vcc5v0_host init fail! ret %d\n", __func__, ret); + goto out; + } + + ret = regulator_set_enable(regulator, true); + if (ret) { + debug("%s vcc5v0-host-en set fail!\n", __func__); + goto out; + } + +out: + return 0; +} + +int dram_init(void) +{ + gd->ram_size = 0x80000000; + return 0; +} + +void dram_init_banksize(void) +{ + /* Reserve 0x200000 for ATF bl31 */ + gd->bd->bi_dram[0].start = 0x200000; + gd->bd->bi_dram[0].size = 0x7e000000; +} diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index d4e12d7..500f220 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y +CONFIG_TARGET_PUMA_RK3399=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x4000 @@ -11,7 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3399-puma" CONFIG_FIT=y CONFIG_SPL_FIT=y CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_SOURCE="board/rockchip/evb_rk3399/fit_spl_atf.its" +CONFIG_SPL_FIT_SOURCE="board/theobroma-systems/puma_rk3399/fit_spl_atf.its" # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_LEGACY_IMAGE_SUPPORT is not set diff --git a/include/configs/puma_rk3399.h b/include/configs/puma_rk3399.h new file mode 100644 index 0000000..6e9364b --- /dev/null +++ b/include/configs/puma_rk3399.h @@ -0,0 +1,26 @@ +/* + * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __PUMA_RK3399_H +#define __PUMA_RK3399_H + +/* + * SPL @ 32kB for ~130kB + * ENV @ 240KB for 8kB + * FIT payload (ATF, U-Boot, FDT) @ 256kB + */ +#define CONFIG_ENV_OFFSET (240 * 1024) + +#include <configs/rk3399_common.h> + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 1 + +#define SDRAM_BANK_SIZE (2UL << 30) + +#define CONFIG_SYS_WHITE_ON_BLACK + +#endif
Philipp Tomsich
