[U-Boot-Users] [PATCH 02/07 v2]: mpc7448hpc2 platform support (part 1/4 header file)
Add mpc7448hpc2 (mpc7448 + tsi108) board associated code support. The original one is too big and divided into 4 parts for review. the board support header file.
Signed-off-by: Alexandre Bounine alexandreb@tundra.com Signed-off-by: Roy Zang tie-fei.zang@freescale.com
--- include/configs/mpc7448hpc2.h | 440 +++++++++++++++++++++++++++++++++++++++++ 1 files changed, 440 insertions(+), 0 deletions(-)
diff --git a/include/configs/mpc7448hpc2.h b/include/configs/mpc7448hpc2.h new file mode 100644 index 0000000..5a1b8e2 --- /dev/null +++ b/include/configs/mpc7448hpc2.h @@ -0,0 +1,440 @@ +/* + * Copyright (c) 2005 Freescale Semiconductor, Inc. + * + * (C) Copyright 2006 + * Alex Bounine , Tundra Semiconductor Corp. + * Roy Zang , Freescale Corp. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/**************************************************************** + * + * board specific configuration options for Freescale + * MPC7448HPC2 (High-Performance Computing II) (Taiga) board + * + ****************************************************************/ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#undef DEBUG + +/* Board Configuration Definitions */ +/* MPC7448HPC2 (High-Performance Computing II) (Taiga) board */ + +#define CONFIG_MPC7448HPC2 + +#define CONFIG_74xx +#define CONFIG_750FX /* this option to enable init of extended BATs */ +#define CONFIG_ALTIVEC /* undef to disable */ + +#define CFG_BOARD_NAME "MPC7448 HPC II" +#define CONFIG_IDENT_STRING " Freescale MPC7448 HPC II" + +#define CFG_OCN_CLK 133000000 /* 133 MHz */ +#define CFG_CONFIG_BUS_CLK 133000000 + +#define CFG_CLK_SPREAD /* Enable Spread-Spectrum Clock generation */ + +#undef CONFIG_ECC /* disable ECC support */ + +/* Board-specific Initialization Functions to be called */ +#define CFG_BOARD_ASM_INIT +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_EARLY_INIT_R +#define CONFIG_MISC_INIT_R + +/* Default MAC Addresses for on-chip GIGE Controller */ + +#define CONFIG_ETHADDR 00:06:D2:00:00:01 + +#define CONFIG_HAS_ETH1 +#define CONFIG_ETH1ADDR 00:06:D2:00:00:02 + +#define CONFIG_ENV_OVERWRITE + +/* + * High Level Configuration Options + * (easy to change) + */ + +#define CONFIG_BAUDRATE 115200 /* console baudrate = 115000 */ + +/*#define CFG_HUSH_PARSER */ +#undef CFG_HUSH_PARSER + +#define CFG_PROMPT_HUSH_PS2 "> " + +/* + * The following defines let you select what serial you want to use + * for your console driver. + * + * what to do: + * If you have hacked a serial cable onto the second DUART channel, change the CFG_DUART port from 1 + * to 0 below. + * + */ + +#define CONFIG_CONS_INDEX 1 +#define CFG_NS16550 +#define CFG_NS16550_SERIAL +#define CFG_NS16550_REG_SIZE 1 +#define CFG_NS16550_CLK CFG_OCN_CLK * 8 + +#define CFG_NS16550_COM1 (CFG_TSI108_CSR_RST_BASE+0x7808) +#define CFG_NS16550_COM2 (CFG_TSI108_CSR_RST_BASE+0x7C08) +#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +#define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */ +#define CONFIG_ZERO_BOOTDELAY_CHECK + +#undef CONFIG_BOOTARGS +/*#define CONFIG_PREBOOT "echo;echo Type "run flash_nfs" to mount root filesystem over NFS;echo" */ + +#if (CONFIG_BOOTDELAY >= 0) +#define CONFIG_BOOTCOMMAND "tftpboot 0x400000 zImage.initrd.elf;\ + setenv bootargs $(bootargs) $(bootargs_root) nfsroot=$(serverip):$(rootpath) \ + ip=$(ipaddr):$(serverip)$(bootargs_end); bootm 0x400000; " + +#define CONFIG_BOOTARGS "console=ttyS0,115200" +#endif + +#undef CONFIG_EXTRA_ENV_SETTINGS + +#define CONFIG_SERIAL "No. 1" + +/* Networking Configuration */ + +#define KSEG1ADDR(a) (a) /* Needed by the rtl8139 driver */ + +#define CONFIG_TSI108_ETH +#define CONFIG_TSI108_ETH_NUM_PORTS 2 + +#define CONFIG_NET_MULTI + +#define CONFIG_IPADDR 172.27.234.48 +#define CONFIG_SERVERIP 172.27.234.10 +#define CONFIG_NETMASK 255.255.0.0 +#define CONFIG_GATEWAYIP 172.27.255.254 + +#define CONFIG_BOOTFILE zImage.initrd.elf +#define CONFIG_LOADADDR 0x400000 + +#define CONFIG_TESTDRAMDATA y +#define CONFIG_TESTDRAMADDRESS n +#define CONFIG_TESETDRAMWALK n + +/*--------------------------------------------------------------------- ----- */ + +#define CONFIG_LOADS_ECHO 0 /* echo off for serial download */ +#define CFG_LOADS_BAUD_CHANGE /* allow baudrate changes */ + +#undef CONFIG_WATCHDOG /* watchdog disabled */ + +#define CONFIG_BOOTP_MASK (CONFIG_BOOTP_DEFAULT | \ + CONFIG_BOOTP_BOOTFILESIZE) + +/* Flash banks JFFS2 should use */ +#define CFG_JFFS2_FIRST_BANK 1 +#define CFG_JFFS2_NUM_BANKS 1 + +#define CONFIG_COMMANDS (CONFIG_CMD_DFL \ + | CFG_CMD_ASKENV \ + | CFG_CMD_CACHE \ + | CFG_CMD_PCI \ + | CFG_CMD_I2C \ + | CFG_CMD_SDRAM \ + | CFG_CMD_EEPROM \ + | CFG_CMD_NET \ + | CFG_CMD_FLASH \ + | CFG_CMD_ENV \ + | CFG_CMD_BSP \ + | CFG_CMD_DHCP \ + | CFG_CMD_PING \ + | CFG_CMD_DATE) + +/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ +#include <cmd_confdefs.h> + +/*set date in u-boot*/ +#define CONFIG_RTC_M48T35A +#define CFG_NVRAM_BASE_ADDR 0xfc000000 +#define CFG_NVRAM_SIZE 0x8000 +/* + * Miscellaneous configurable options + */ +#define CONFIG_VERSION_VARIABLE 1 + +#define CFG_I2C_EEPROM_ADDR 0x50 /* I2C EEPROM page 1 */ +#define CFG_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ + +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_PROMPT "=> " /* Monitor Command Prompt */ + +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port at */ +#else +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#endif + +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ + +/* +#define CFG_DRAM_TEST + * DRAM tests + * CFG_DRAM_TEST - enables the following tests. + * + * CFG_DRAM_TEST_DATA - Enables test for shorted or open data lines + * Environment variable 'test_dram_data' must be + * set to 'y'. + * CFG_DRAM_TEST_DATA - Enables test to verify that each word is uniquely + * addressable. Environment variable + * 'test_dram_address' must be set to 'y'. + * CFG_DRAM_TEST_WALK - Enables test a 64-bit walking ones pattern test. + * This test takes about 6 minutes to test 64 MB. + * Environment variable 'test_dram_walk' must be + * set to 'y'. + */ +#define CFG_DRAM_TEST +#if defined(CFG_DRAM_TEST) +#define CFG_MEMTEST_START 0x00400000 /* memtest works on */ +#define CFG_MEMTEST_END 0x07c00000 /* 4 ... 124 MB in DRAM */ +#define CFG_DRAM_TEST_DATA +#define CFG_DRAM_TEST_ADDRESS +#define CFG_DRAM_TEST_WALK +#endif /* CFG_DRAM_TEST */ + +#define CFG_LOAD_ADDR 0x00400000 /* default load address */ + +#define CFG_HZ 1000 /* decr freq: 1ms ticks */ + +/* + * Low Level Configuration Settings + * (address mappings, register initial values, etc.) + * You should know what you are doing if you make changes here. + */ + +/*--------------------------------------------------------------------- -- + * Definitions for initial stack pointer and data area + */ + +/* + * When locking data in cache you should point the CFG_INIT_RAM_ADDRESS + * To an unused memory region. The stack will remain in cache until RAM + * is initialized +*/ +#undef CFG_INIT_RAM_LOCK +#define CFG_INIT_RAM_ADDR 0x07d00000 /* unused memory region */ +#define CFG_INIT_RAM_END 0x4000 /* larger space - we have SDRAM initialized */ + +#define CFG_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ +#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) + +/*--------------------------------------------------------------------- -- + * Start addresses for the final memory configuration + * (Set up by the startup code) + * Please note that CFG_SDRAM_BASE _must_ start at 0 + */ + +#define CFG_SDRAM_BASE 0x00000000 /* first 256 MB of SDRAM */ +#define CFG_SDRAM1_BASE 0x10000000 /* next 256MB of SDRAM */ + +#define CFG_SDRAM2_BASE 0x40000000 /* beginning of non-cacheable alias for SDRAM - first 256MB */ +#define CFG_SDRAM3_BASE 0x50000000 /* next Non-Cacheable 256MB of SDRAM */ + +#define CFG_PCI_PFM_BASE 0x80000000 /* Prefetchable (cacheable) PCI/X PFM and SDRAM OCN (128MB+128MB) */ + +#define CFG_PCI_MEM32_BASE 0xE0000000 /* Non-Cacheable PCI/X MEM and SDRAM OCN (128MB+128MB) */ + +#define CFG_MISC_REGION_BASE 0xf0000000 /* Base Address for (PCI/X + Flash) region */ + +#define CFG_FLASH_BASE 0xff000000 /* Base Address of Flash device */ +#define CFG_FLASH_BASE2 0xfe000000 /* Alternate Flash Base Address */ + +#define CONFIG_VERY_BIG_RAM /* we will use up to 256M memory for cause we are short of BATS */ + +#define PCI0_IO_BASE_BOOTM 0xfd000000 + +#define CFG_RESET_ADDRESS 0x3fffff00 +#define CFG_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ +#define CFG_MONITOR_BASE TEXT_BASE /* u-boot code base */ +#define CFG_MALLOC_LEN (256 << 10) /* Reserve 256 kB for malloc */ + +/* Peripheral Device section */ + +/******************************************************* + * Resources on the Tsi108 + *******************************************************/ + +#define CFG_TSI108_CSR_RST_BASE 0xC0000000 /* Tsi108 CSR base after reset */ +#define CFG_TSI108_CSR_BASE CFG_TSI108_CSR_RST_BASE /* Runtime Tsi108 CSR base */ + +#define ENABLE_PCI_CSR_BAR /* enables access to Tsi108 CSRs from the PCI/X bus */ + +#undef DISABLE_PBM + +/*--------------------------------------------------------------------- -- + * PCI stuff + *----------------------------------------------------------------------- + */ + +#define CONFIG_PCI /* include pci support */ +#define CONFIG_TSI108_PCI /* include tsi108 pci support */ + +#define PCI_HOST_ADAPTER 0 /* configure as pci adapter */ +#define PCI_HOST_FORCE 1 /* configure as pci host */ +#define PCI_HOST_AUTO 2 /* detected via arbiter enable */ + +#define CONFIG_PCI_HOST PCI_HOST_FORCE /* select pci host function */ +#define CONFIG_PCI_PNP /* do pci plug-and-play */ + +/* PCI MEMORY MAP section */ + +/* PCI view of System Memory */ +#define CFG_PCI_MEMORY_BUS 0x00000000 +#define CFG_PCI_MEMORY_PHYS 0x00000000 +#define CFG_PCI_MEMORY_SIZE 0x80000000 + +/* PCI Memory Space */ +#define CFG_PCI_MEM_BUS (CFG_PCI_MEM_PHYS) +#define CFG_PCI_MEM_PHYS (CFG_PCI_MEM32_BASE) //CFG_PCI_MEM32_BASE = 0xE0000000 +#define CFG_PCI_MEM_SIZE 0x10000000 /* 256 MB space for PCI/X Mem + SDRAM OCN */ + +/* PCI I/O Space */ +#define CFG_PCI_IO_BUS 0x00000000 +#define CFG_PCI_IO_PHYS 0xfa000000 /* Changed from fd000000 */ + +#define CFG_PCI_IO_SIZE 0x01000000 /* 16MB */ + +#define _IO_BASE 0x00000000 /* points to PCI I/O space */ + +/* PCI Config Space mapping */ +#define CFG_PCI_CFG_BASE 0xfb000000 /* Changed from FE000000 */ +#define CFG_PCI_CFG_SIZE 0x01000000 /* 16MB */ + +#define CFG_IBAT0U 0xFE0003FF +#define CFG_IBAT0L 0xFE000002 + +#define CFG_IBAT1U 0x00007FFF +#define CFG_IBAT1L 0x00000012 + +#define CFG_IBAT2U 0x80007FFF +#define CFG_IBAT2L 0x80000022 + +#define CFG_IBAT3U 0x00000000 +#define CFG_IBAT3L 0x00000000 + +#define CFG_IBAT4U 0x00000000 +#define CFG_IBAT4L 0x00000000 + +#define CFG_IBAT5U 0x00000000 +#define CFG_IBAT5L 0x00000000 + +#define CFG_IBAT6U 0x00000000 +#define CFG_IBAT6L 0x00000000 + +#define CFG_IBAT7U 0x00000000 +#define CFG_IBAT7L 0x00000000 + +#define CFG_DBAT0U 0xE0003FFF +#define CFG_DBAT0L 0xE000002A + +#define CFG_DBAT1U 0x00007FFF +#define CFG_DBAT1L 0x00000012 + +#define CFG_DBAT2U 0x00000000 +#define CFG_DBAT2L 0x00000000 + +#define CFG_DBAT3U 0xC0000003 +#define CFG_DBAT3L 0xC000002A + +#define CFG_DBAT4U 0x00000000 +#define CFG_DBAT4L 0x00000000 + +#define CFG_DBAT5U 0x00000000 +#define CFG_DBAT5L 0x00000000 + +#define CFG_DBAT6U 0x00000000 +#define CFG_DBAT6L 0x00000000 + +#define CFG_DBAT7U 0x00000000 +#define CFG_DBAT7L 0x00000000 + +/* I2C addresses for the two DIMM SPD chips */ +#define DIMM0_I2C_ADDR 0x51 +#define DIMM1_I2C_ADDR 0x52 + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CFG_BOOTMAPSZ (8<<20) /* Initial Memory map for Linux */ + +/*--------------------------------------------------------------------- -- + * FLASH organization + */ +#define CFG_MAX_FLASH_BANKS 1 /* Flash can be at one of two addresses */ +#define FLASH_BANK_SIZE 0x01000000 /* 16 MB Total */ +#define CFG_FLASH_BANKS_LIST {CFG_FLASH_BASE, CFG_FLASH_BASE2} + +#define CFG_FLASH_CFI_DRIVER +#define CFG_FLASH_CFI +#define CFG_FLASH_CFI_SWAP + +#define PHYS_FLASH_SIZE 0x01000000 +#define CFG_MAX_FLASH_SECT (128) + +#define CFG_ENV_IS_IN_NVRAM +#define CFG_ENV_ADDR 0xFC000000 + +#define CFG_ENV_OFFSET 0x00000000 /* Offset of Environment Sector */ +#define CFG_ENV_SIZE 0x00000400 /* Total Size of Environment Space */ + +/*--------------------------------------------------------------------- -- + * Cache Configuration + */ +#define CFG_CACHELINE_SIZE 32 /* For all MPC74xx CPUs */ +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + +/*--------------------------------------------------------------------- -- + * L2CR setup -- make sure this is right for your board! + * look in include/mpc74xx.h for the defines used here + */ +#undef CFG_L2 + +#define L2_INIT 0 +#define L2_ENABLE (L2_INIT | L2CR_L2E) + +/* + * Internal Definitions + * + * Boot Flags + */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ +#define CFG_EXCEPTION_AFTER_RELOCATE +#define CFG_SERIAL_HANG_IN_EXCEPTION +#endif /* __CONFIG_H */
Add mpc7448hpc2 (mpc7448 + tsi108) board associated code support. The mpc7448hpc2 board support low level assemble language init code .
--- board/mpc7448hpc2/asm_init.S | 955 ++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 955 insertions(+), 0 deletions(-)
diff --git a/board/mpc7448hpc2/asm_init.S b/board/mpc7448hpc2/asm_init.S new file mode 100644 index 0000000..8c15a3d --- /dev/null +++ b/board/mpc7448hpc2/asm_init.S @@ -0,0 +1,955 @@ +/***************************************************************************** + * (C) Copyright 2004-05; Tundra Semiconductor Corp. + * + * Added automatic detect of SDC settings + * Copyright (c) 2005 Freescale Semiconductor, Inc. + * Maintainer tie-fei.zang@freescale.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + ****************************************************************************/ + +/*---------------------------------------------------------------------------- + * FILENAME: asm_init.s + * + * Originator: Alex Bounine + * + * DESCRIPTION: + * Initialization code for the Tundra Tsi108 bridge chip + * + *---------------------------------------------------------------------------*/ + +#include <config.h> +#include <version.h> + +#include <ppc_asm.tmpl> +#include <ppc_defs.h> +#include <asm/processor.h> + +#include <tsi108.h> + +/*=========================================================================== + * Build Configuration Options + */ + +/* #define DISABLE_PBM disables usage of PB Master */ +/* #define SDC_HARDCODED_INIT config SDRAM controller with hardcoded values */ +/* #define SDC_AUTOPRECH_EN enable SDRAM auto precharge */ + +/* =========================================================================== + * Hardcoded SDC settings + */ + +#ifdef SDC_HARDCODED_INIT + +/* Micron MT9HTF6472AY-40EA1 : Unbuffered, 512MB, 400, CL3, Single Rank */ + +#define VAL_SD_REFRESH (0x61A) +#define VAL_SD_TIMING (0x0308336b) +#define VAL_SD_D0_CTRL (0x07100021) /* auto-precharge disabled */ +#define VAL_SD_D0_BAR (0x0FE00000) /* 512MB @ 0x00000000 */ +#define VAL_SD_D1_CTRL (0x07100021) /* auto-precharge disabled */ +#define VAL_SD_D1_BAR (0x0FE00200) /* 512MB @ 0x20000000 */ + +#endif /* SDC_HARDCODED_INIT */ + +/*--------------------------------------------------------------------------- + CPU Configuration: + + CPU Address and Data Parity enables. + +#define CPU_AP +#define CPU_DP + +=========================================================================== + Macros + + !!! Attention !!! Macros LOAD_PTR, LOAD_U32 and LOAD_MEM defined below are + expected to work correctly for the CSR space within 32KB range. + + LOAD_PTR and LOAD_U32 - load specified register with a 32 bit constant. + These macros are absolutely identical except their names. This difference + is provided intentionally for better readable code. + -------------------------------------------------------------------------*/ + +#define LOAD_PTR(reg,const32) \ + addis reg,r0,const32@h; ori reg,reg,const32@l + +#define LOAD_U32(reg,const32) \ + addis reg,r0,const32@h; ori reg,reg,const32@l + +/* LOADMEM initializes a register with the contents of a specified 32-bit memory + location, usually a CSR value.*/ + +#define LOAD_MEM(reg,addr32) \ + addis reg,r0,addr32@ha; lwz reg,addr32@l(reg) + +#ifndef SDC_HARDCODED_INIT +sdc_clk_sync: + /* MHz: 0,0,183,100,133,167,200,233 */ + .long 0,0, 6, 10, 8, 6, 5, 4 /* nSec */ +#endif + +/*=========================================================================== + board_asm_init() - early initialization function. Coded to be portable to + dual-CPU configuration. + Checks CPU number and performs board HW initialization if called for CPU0. + + Registers used: r3,r4,r5,r6,r19,r29 +=========================================================================== + +--------------------------------------------------------------------------- + NOTE: For dual-CPU configuration only CPU0 is allowed to configure Tsi108 + and the rest of the board. Current implementation demonstrates two + possible ways to identify CPU number: + - for MPC74xx platform: uses MSSCR0[ID] bit as defined in UM. + - for PPC750FX/GX boards: uses WHO_AM_I bit reported by Tsi108. +---------------------------------------------------------------------------*/ + + .globl board_asm_init +board_asm_init: + + mflr r19 /* Save LR to be able return later. */ + + bl icache_enable /* Enable icache to reduce reads from flash. */ + + /* Initialize pointer to Tsi108 register space + -------------------------------------------------------------------------*/ + + LOAD_PTR(r29,CFG_TSI108_CSR_RST_BASE)/* r29 - pointer to tsi108 CSR space */ + ori r4,r29,TSI108_PB_REG_OFFSET + + /*------------------------------------------------------------------------- + Check Processor Version Number */ + + mfspr r3, PVR + rlwinm r3,r3,16,16,23 /* get ((Processor Version Number) & 0xFF00) */ + + cmpli 0,0,r3,0x8000 /* MPC74xx */ + bne cont_brd_init + + /* ------------------------------------------ + For MPC744x/5x enable extended BATs[4-7] + Sri: Set HIGH_BAT_EN and XBSEN, and SPD =1 + to disable prefetch + */ + + mfspr r5, HID0 + oris r5, r5, 0x0080 /* Set HID0[HIGH_BAT_EN] bit #8 */ + ori r5, r5, 0x0380 /* Set SPD,XBSEN,SGE bits #22,23,24 */ + mtspr HID0, r5 + isync + sync + + /* Adding code to disable external interventions in MPX bus mode */ + mfspr r3, 1014 + oris r3, r3, 0x0100 /* Set the EIDIS bit in MSSCR0: bit 7 */ + mtspr 1014, r3 + isync + sync + + /* Sri: code to enable FP unit */ + mfmsr r3 + ori r3, r3, 0x2000 + mtmsr r3 + isync + sync + +#if(1) /* def CONFIG_DUAL_CPU + ------------------------------------------------------------------------- + For MPC74xx processor, use MSSCR0[ID] bit to identify CPU number. + */ + + mfspr r3,1014 /* read MSSCR0 */ + rlwinm. r3,r3,27,31,31 /* get processor ID number */ + mtspr SPRN_PIR,r3 /* Save CPU ID */ + sync + bne init_done + b do_tsi108_init + +cont_brd_init: + + /* An alternative method of checking the processor number (in addition + to configuration using MSSCR0[ID] bit on MPC74xx). + Good for IBM PPC750FX/GX. + */ + + lwz r3,PB_BUS_MS_SELECT(r4) /* read PB_ID register */ + rlwinm. r3,r3,24,31,31 /* get processor ID number */ + + bne init_done + +#else + +cont_brd_init: + +#endif /* CONFIG_DUAL_CPU */ + + /* Initialize Tsi108 chip + --------------------------------------------------------------------------- + */ + +do_tsi108_init: + + /*-------------------------------------------------------------------------- + Adjust HLP/Flash parameters. By default after reset the HLP port is set + to support slow devices. Better performance can be achived when an optimal + parameters are used for specific EPROM device. + NOTE: This should be performed ASAP for the emulation platform because + it has 5MHz HLP clocking. + */ + +#ifdef CONFIG_TSI108EMU + ori r4,r29,TSI108_HLP_REG_OFFSET + LOAD_U32(r5,0x434422c0) + stw r5,0x08(r4) /* set HLP B0_CTRL0 */ + sync + LOAD_U32(r5,0xd0012000) + stw r5,0x0c(r4) /* set HLP B0_CTRL1 */ + sync +#endif + + /* ------------------------------------------------------------------------- + * Initialize PB interface. + */ + + ori r4,r29,TSI108_PB_REG_OFFSET + +#if (CFG_TSI108_CSR_BASE != CFG_TSI108_CSR_RST_BASE) + /* Relocate (if required) Tsi108 registers. Set new value for PB_REG_BAR: + * Note we are in the 32-bit address mode. + */ + LOAD_U32(r5,(CFG_TSI108_CSR_BASE | 0x01)) /* value for PB_REG_BAR: BA + EN*/ + stw r5,PB_REG_BAR(r4) + andis. r29,r5,0xFFFF + sync + + ori r4,r29,TSI108_PB_REG_OFFSET +#endif + + /* Set PB Slave configuration register */ + +/* LOAD_U32(r5,0x000024C7) value for PB_SCR: TEA enabled,AACK delay = 7 */ + LOAD_U32(r5,0x00002481) /* value for PB_SCR: TEA enabled,AACK delay = 1 */ + lwz r3, PB_RSR(r4) /* get PB bus mode */ + xori r3,r3,0x0001 /* mask PB_BMODE: r3 -> (0 = 60X, 1 = MPX) */ + rlwimi r5,r3,14,17,17 /* for MPX: set DTI_MODE bit */ + stw r5,PB_SCR(r4) + sync + + /* Configure PB Arbiter */ + + lwz r5,PB_ARB_CTRL(r4) /* Read PB Arbiter Control Register */ + li r3, 0x00F0 /* ARB_PIPELINE_DEP mask */ +#ifdef DISABLE_PBM + ori r3,r3,0x1000 /* add PBM_EN to clear (enabled by default) */ +#endif + andc r5,r5,r3 /* Clear the masked bit fields */ +/* ori r5,r5,0x0040 Set pipeline depth 4 + ori r5,r5,0x0080 Set pipeline depth 8 + ori r5,r5,0x0020 !!!avb Testing: set pipeline depth 2 */ + ori r5,r5,0x0001 + stw r5,PB_ARB_CTRL(r4) + +#if (0) /* currently using the default settings for PBM after reset */ + LOAD_U32(r5,0x) /* value for PB_MCR */ + stw r5,PB_MCR(r4) + sync + + LOAD_U32(r5,0x) /* value for PB_MCMD */ + stw r5,PB_MCMD(r4) + sync +#endif + +/* Disable or enable PVT based on processor bus frequency + 1. Read CG_PWRUP_STATUS register field bits 18,17,16 + 2. See if the value is < or > 133mhz (18:16 = 100) + 3. If > enable PVT + */ + + LOAD_U32(r3,0xC0002234) + lwz r3,0(r3) + rlwinm r3,r3,16,29,31 + + cmpi 0,0,r3,0x0004 + bgt sdc_init + +#ifndef CONFIG_TSI108EMU + /* FIXME: Disable PB calibration control for any real Tsi108 board */ + li r5,0x0101 /* disable calibration control */ + stw r5,PB_PVT_CTRL2(r4) + sync +#endif + +/*--------------------------------------------------------------------------- + Initialize SDRAM controller. +----------------------------------------------------------------------------*/ + +sdc_init: + +#ifndef SDC_HARDCODED_INIT + /* get SDC clock prior doing sdram controller autoconfig */ + ori r4,r29,TSI108_CLK_REG_OFFSET /* r4 - ptr to CG registers */ + lwz r3, CG_PWRUP_STATUS(r4) /* get CG configuration */ + rlwinm r3,r3,12,29,31 /* r3 - SD clk */ + lis r5,sdc_clk_sync@h + ori r5,r5,sdc_clk_sync@l + /* Sri: At this point check if r3 = 001. If yes, + * the memory frequency should be same as the + * MPX bus frequency + */ + cmpi 0,0,r3,0x0001 + bne get_nsec + lwz r6, CG_PWRUP_STATUS(r4) + rlwinm r6,r6,16,29,31 + mr r3,r6 + +get_nsec: + rlwinm r3,r3,2,0,31 + lwzx r9,r5,r3 /* get SD clk rate in nSec */ + /* ATTN: r9 will be used by SPD routine */ +#endif /* !SDC_HARDCODED_INIT */ + + ori r4,r29,TSI108_SD_REG_OFFSET /* r4 - ptr to SDRAM registers */ + + /* Initialize SDRAM controller. SDRAM Size = 512MB, One DIMM. */ + + LOAD_U32(r5,0x00) + stw r5,SD_INT_ENABLE(r4) /* Ensure that interrupts are disabled */ +#ifdef ENABLE_SDRAM_ECC + li r5, 0x01 +#endif /* ENABLE_SDRAM_ECC */ + stw r5,SD_ECC_CTRL(r4) /* Enable/Disable ECC */ + sync + +#ifdef SDC_HARDCODED_INIT /* config sdram controller with hardcoded values */ + + /* First read the CG_PWRUP_STATUS register to get the + memory speed from bits 22,21,20 */ + + LOAD_U32(r3,0xC0002234) + lwz r3,0(r3) + rlwinm r3,r3,12,29,31 + + /* Now first check for 166, then 200, or default */ + + cmpi 0,0,r3,0x0005 + bne check_for_200mhz + + /* set values for 166 Mhz memory speed */ + + /* Set refresh rate and timing parameters */ + LOAD_U32(r5,0x00000515) + stw r5,SD_REFRESH(r4) + LOAD_U32(r5,0x03073368) + stw r5,SD_TIMING(r4) + sync + + /* Initialize DIMM0 control and BAR registers */ + LOAD_U32(r5,VAL_SD_D0_CTRL) /* auto-precharge disabled */ +#ifdef SDC_AUTOPRECH_EN + oris r5,r5,0x0001 /* set auto precharge EN bit */ +#endif + stw r5,SD_D0_CTRL(r4) + LOAD_U32(r5,VAL_SD_D0_BAR) + stw r5,SD_D0_BAR(r4) + sync + + /* Initialize DIMM1 control and BAR registers + * (same as dimm 0, next 512MB, disabled) + */ + LOAD_U32(r5,VAL_SD_D1_CTRL) /* auto-precharge disabled */ +#ifdef SDC_AUTOPRECH_EN + oris r5,r5,0x0001 /* set auto precharge EN bit */ +#endif + stw r5,SD_D1_CTRL(r4) + LOAD_U32(r5,VAL_SD_D1_BAR) + stw r5,SD_D1_BAR(r4) + sync + + b sdc_init_done + +check_for_200mhz: + + cmpi 0,0,r3,0x0006 + bne set_default_values + + /* set values for 200Mhz memory speed */ + + /* Set refresh rate and timing parameters */ + LOAD_U32(r5,0x0000061a) + stw r5,SD_REFRESH(r4) + LOAD_U32(r5,0x03083348) + stw r5,SD_TIMING(r4) + sync + + /* Initialize DIMM0 control and BAR registers */ + LOAD_U32(r5,VAL_SD_D0_CTRL) /* auto-precharge disabled */ +#ifdef SDC_AUTOPRECH_EN + oris r5,r5,0x0001 /* set auto precharge EN bit */ +#endif + stw r5,SD_D0_CTRL(r4) + LOAD_U32(r5,VAL_SD_D0_BAR) + stw r5,SD_D0_BAR(r4) + sync + + /* Initialize DIMM1 control and BAR registers + * (same as dimm 0, next 512MB, disabled) + */ + LOAD_U32(r5,VAL_SD_D1_CTRL) /* auto-precharge disabled */ +#ifdef SDC_AUTOPRECH_EN + oris r5,r5,0x0001 /* set auto precharge EN bit */ +#endif + stw r5,SD_D1_CTRL(r4) + LOAD_U32(r5,VAL_SD_D1_BAR) + stw r5,SD_D1_BAR(r4) + sync + + b sdc_init_done + +set_default_values: + + /* Set refresh rate and timing parameters */ + LOAD_U32(r5,VAL_SD_REFRESH) + stw r5,SD_REFRESH(r4) + LOAD_U32(r5,VAL_SD_TIMING) + stw r5,SD_TIMING(r4) + sync + + /* Initialize DIMM0 control and BAR registers */ + LOAD_U32(r5,VAL_SD_D0_CTRL) /* auto-precharge disabled */ +#ifdef SDC_AUTOPRECH_EN + oris r5,r5,0x0001 /* set auto precharge EN bit */ +#endif + stw r5,SD_D0_CTRL(r4) + LOAD_U32(r5,VAL_SD_D0_BAR) + stw r5,SD_D0_BAR(r4) + sync + + /* Initialize DIMM1 control and BAR registers + * (same as dimm 0, next 512MB, disabled) + */ + LOAD_U32(r5,VAL_SD_D1_CTRL) /* auto-precharge disabled */ +#ifdef SDC_AUTOPRECH_EN + oris r5,r5,0x0001 /* set auto precharge EN bit */ +#endif + stw r5,SD_D1_CTRL(r4) + LOAD_U32(r5,VAL_SD_D1_BAR) + stw r5,SD_D1_BAR(r4) + sync + +#else /* !SDC_HARDCODED_INIT */ + + bl tsi108_sdram_spd /* automatically detect SDC settings */ + +#endif /* SDC_HARDCODED_INIT */ + +sdc_init_done: + +#ifdef DISABLE_PBM + LOAD_U32(r5,0x00000030) /* PB_EN + OCN_EN */ +#else + LOAD_U32(r5,0x00000230) /* PB_EN + OCN_EN + PB/OCN=80/20 */ +#endif /* DISABLE_PBM */ + +#ifdef CONFIG_TSI108EMU + oris r5,r5,0x0010 /* set EMULATION_MODE bit */ +#endif + + stw r5,SD_CTRL(r4) + eieio + sync + + /* Enable SDRAM access */ + + oris r5,r5,0x8000 /* start SDC: set SD_CTRL[ENABLE] bit */ + stw r5,SD_CTRL(r4) + sync + +wait_init_complete: + lwz r5,SD_STATUS(r4) + andi. r5,r5,0x0001 + beq wait_init_complete /* wait until SDRAM initialization is complete */ + +/*--------------------------------------------------------------------------- + Map SDRAM into the processor bus address space +---------------------------------------------------------------------------*/ + + ori r4,r29,TSI108_PB_REG_OFFSET + + /* Setup BARs associated with direct path PB<->SDRAM */ + + /* PB_SDRAM_BAR1: + provides a direct path to the main system memory (cacheable SDRAM) */ + + LOAD_U32(r5, 0x00000011) /* BA=0,Size=512MB, ENable, No Addr.Translation */ + stw r5,PB_SDRAM_BAR1(r4) + sync + + /* Make sure that PB_SDRAM_BAR1 decoder is set + (to allow following immediate read from SDRAM) */ + lwz r5,PB_SDRAM_BAR1(r4) + sync + + /* PB_SDRAM_BAR2: + provides non-cacheable alias (via the direct path) to main system memory. + Size = 512MB, ENable, Addr.Translation - ON, + BA = 0x0_40000000, TA = 0x0_00000000 */ + + LOAD_U32(r5, 0x40010011) + stw r5,PB_SDRAM_BAR2(r4) + sync + + /* Make sure that PB_SDRAM_BAR2 decoder is set + (to allow following immediate read from SDRAM) */ + lwz r5,PB_SDRAM_BAR2(r4) + sync + + +init_done: + + /* All done. Restore LR and return. */ + mtlr r19 + blr + +#if (0) +/*=========================================================================== + init_cpu1 + + This routine enables CPU1 on the dual-processor system. +===========================================================================*/ + + .global enable_cpu1 +enable_cpu1: + + lis r3,Tsi108_Base@ha /* Get Grendel CSR Base Addr */ + addi r3,r3,Tsi108_Base@l + lwz r3,0(r3) /* R3 = CSR Base Addr */ + ori r4,r3,TSI108_PB_REG_OFFSET + lwz r3,PB_ARB_CTRL(r4) /* Read PB Arbiter Control Register */ + ori r3,r3,0x0200 /* Set M1_EN bit */ + stw r3,PB_ARB_CTRL(r4) + + blr +#endif + +/*=========================================================================== + enable_EI + + Enable CPU core external interrupt +===========================================================================*/ + + .global enable_EI +enable_EI: + mfmsr r3 + ori r3,r3,0x8000 /* set EE bit */ + mtmsr r3 + blr + +/*=========================================================================== + disable_EI + + Disable CPU core external interrupt +===========================================================================*/ + + .global disable_EI +disable_EI: + mfmsr r3 + li r4,-32768 /* aka "li r4,0x8000" */ + andc r3,r3,r4 /* clear EE bit */ + mtmsr r3 + blr + +#ifdef ENABLE_SDRAM_ECC +/*=========================================================================== + enable_ECC + + enables SDRAM ECC +===========================================================================*/ + + .global enable_ECC +enable_ECC: + ori r4,r29,TSI108_SD_REG_OFFSET + lwz r3,SD_ECC_CTRL(r4) /* Read SDRAM ECC Control Register */ + ori r3,r3,0x0001 /* Set ECC_EN bit */ + stw r3,SD_ECC_CTRL(r4) + blr + +/*=========================================================================== + clear_ECC_err + + Clears all pending SDRAM ECC errors + (normally after SDRAM scrubbing/initialization) +===========================================================================*/ + + .global clear_ECC_err +clear_ECC_err: + ori r4,r29,TSI108_SD_REG_OFFSET +/* lwz r3,SD_INT_STATUS(r4) Read SDRAM ECC Control Register */ + ori r3,r0,0x0030 /* ECC_UE_INT + ECC_CE_INT bits */ + stw r3,SD_INT_STATUS(r4) + blr + +#endif /* ENABLE_SDRAM_ECC */ + +#ifndef SDC_HARDCODED_INIT + +/******************************************************************** + * SDRAM SPD Support + */ + +#define SD_I2C_CTRL1 (0x400) +#define SD_I2C_CTRL2 (0x404) +#define SD_I2C_RD_DATA (0x408) +#define SD_I2C_WR_DATA (0x40C) + +/* + * SDRAM SPD Support Macros + */ + +#define SPD_DIMM0 (0x00000100) +#define SPD_DIMM1 (0x00000200) /* SPD_DIMM1 was 0x00000000 */ + +#define SPD_RDIMM (0x01) +#define SPD_UDIMM (0x02) + +#define SPD_CAS_3 0x8 +#define SPD_CAS_4 0x10 +#define SPD_CAS_5 0x20 + +#define ERR_NO_DIMM_FOUND (0xdb0) +#define ERR_TRAS_FAIL (0xdb1) +#define ERR_TRCD_FAIL (0xdb2) +#define ERR_TRP_FAIL (0xdb3) +#define ERR_TWR_FAIL (0xdb4) +#define ERR_UNKNOWN_PART (0xdb5) +#define ERR_NRANK_INVALID (0xdb6) +#define ERR_DIMM_SIZE (0xdb7) +#define ERR_ADDR_MODE (0xdb8) +#define ERR_RFRSH_RATE (0xdb9) +#define ERR_DIMM_TYPE (0xdba) +#define ERR_CL_VALUE (0xdbb) +#define ERR_TRFC_FAIL (0xdbc) + +/* READ_SPD requirements: + * byte - byte address in SPD device (0 - 255) + * r3 = will return data read from I2C Byte location + * r4 - unchanged (SDC base addr) + * r5 - clobbered in routine (I2C status) + * r10 - number of DDR slot where first SPD device is detected + */ + +#define READ_SPD(byte_num) \ + addis r3, 0, byte_num@l;\ + or r3, r3, r10;\ + ori r3, r3, 0x0A;\ + stw r3, SD_I2C_CTRL1(r4);\ + li r3, I2C_CNTRL2_START;\ + stw r3, SD_I2C_CTRL2(r4);\ + eieio;\ + sync;\ + li r3, 0x100;\ +1: ;\ + addic. r3, r3, -1;\ + bne 1b;\ +2: ;\ + lwz r5, SD_I2C_CTRL2(r4);\ + rlwinm. r3,r5,0,23,23;\ + bne 2b;\ + rlwinm. r3,r5,0,3,3;\ + lwz r3, SD_I2C_RD_DATA(r4) + +#define SPD_MIN_RFRSH (0x80) +#define SPD_MAX_RFRSH (0x85) + +refresh_rates: /* in nSec */ + .long 15625 /* Normal (0x80) */ + .long 3900 /* Reduced 0.25x (0x81) */ + .long 7800 /* Reduced 0.5x (0x82) */ + .long 31300 /* Extended 2x (0x83) */ + .long 62500 /* Extended 4x (0x84) */ + .long 125000 /* Extended 8x (0x85) */ + +/*=========================================================================== + * tsi108_sdram_spd + * + * Inittializes SDRAM Controller using DDR2 DIMM Serial Presence Detect data + * Uses registers: r4 - SDC base address (not changed) + * r9 - SDC clocking period in nSec + * Changes registers: r3,r5,r6,r7,r8,r10,r11 + *==========================================================================*/ + +tsi108_sdram_spd: + + li r10,SPD_DIMM0 + xor r11,r11,r11 /* DIMM Base Address: starts from 0 */ + +do_first_dimm: + + /************************************** + * Program Refresh Rate Register + */ + + READ_SPD(12) /* get Refresh Rate */ + beq check_next_slot + li r5, ERR_RFRSH_RATE + cmpi 0,0,r3,SPD_MIN_RFRSH + ble spd_fail + cmpi 0,0,r3,SPD_MAX_RFRSH + bgt spd_fail + addi r3,r3,-SPD_MIN_RFRSH + rlwinm r3,r3,2,0,31 + lis r5,refresh_rates@h + ori r5,r5,refresh_rates@l + lwzx r5,r5,r3 /* get refresh rate in nSec */ + divwu r5,r5,r9 /* calculate # of SDC clocks */ + stw r5,SD_REFRESH(r4) /* Set refresh rate */ + sync + + /************************************** + * Program SD Timing Register + */ + + li r7, 0 /* clear r7 prior parameter collection */ + + READ_SPD(20) /* get DIMM type: Registered or Unbuffered */ + beq spd_read_fail + li r5, ERR_DIMM_TYPE + cmpi 0,0,r3,SPD_UDIMM + beq do_cl + cmpi 0,0,r3,SPD_RDIMM + bne spd_fail + oris r7,r7,0x1000 /* set SD_TIMING[DIMM_TYPE] bit */ + +do_cl: + READ_SPD(18) /* Get CAS Latency */ + beq spd_read_fail + li r5,ERR_CL_VALUE + andi. r6,r3,SPD_CAS_3 + beq cl_4 + li r6,3 + b set_cl +cl_4: + andi. r6,r3,SPD_CAS_4 + beq cl_5 + li r6,4 + b set_cl +cl_5: + andi. r6,r3,SPD_CAS_5 + beq spd_fail + li r6,5 +set_cl: + rlwimi r7,r6,24,5,7 + + READ_SPD(30) /* Get tRAS */ + beq spd_read_fail + divwu r6,r3,r9 + mullw r8,r6,r9 + subf. r8,r8,r3 + beq set_tras + addi r6,r6,1 +set_tras: + li r5,ERR_TRAS_FAIL + cmpi 0,0,r6,0x0F /* max supported value */ + bgt spd_fail + rlwimi r7,r6,16,12,15 + + READ_SPD(29) /* Get tRCD */ + beq spd_read_fail + rlwinm r3,r3,30,2,31/* right shift tRCD by 2 bits as per DDR2 spec */ + divwu r6,r3,r9 + mullw r8,r6,r9 + subf. r8,r8,r3 + beq set_trcd + addi r6,r6,1 +set_trcd: + li r5,ERR_TRCD_FAIL + cmpi 0,0,r6,0x07 /* max supported value */ + bgt spd_fail + rlwimi r7,r6,12,17,19 + + READ_SPD(27) /* Get tRP value */ + beq spd_read_fail + rlwinm r3,r3,30,2,31 /* right shift tRP by 2 bits as per DDR2 spec */ + divwu r6,r3,r9 + mullw r8,r6,r9 + subf. r8,r8,r3 + beq set_trp + addi r6,r6,1 +set_trp: + li r5,ERR_TRP_FAIL + cmpi 0,0,r6,0x07 /* max supported value */ + bgt spd_fail + rlwimi r7,r6,8,21,23 + + READ_SPD(36) /* Get tWR value */ + beq spd_read_fail + rlwinm r3,r3,30,2,31 /* right shift tWR by 2 bits as per DDR2 spec */ + divwu r6,r3,r9 + mullw r8,r6,r9 + subf. r8,r8,r3 + beq set_twr + addi r6,r6,1 +set_twr: + addi r6,r6,-1 /* Tsi108 SDC always gives one extra clock */ + li r5,ERR_TWR_FAIL + cmpi 0,0,r6,0x07 /* max supported value */ + bgt spd_fail + rlwimi r7,r6,5,24,26 + + READ_SPD(42) /* Get tRFC */ + beq spd_read_fail + li r5, ERR_TRFC_FAIL + /* Tsi108 spec: tRFC=(tRFC + 1)/2 */ + addi r3,r3,1 + rlwinm. r3,r3,31,1,31 /* divide by 2 */ + beq spd_fail + divwu r6,r3,r9 + mullw r8,r6,r9 + subf. r8,r8,r3 + beq set_trfc + addi r6,r6,1 +set_trfc: + cmpi 0,0,r6,0x1F /* max supported value */ + bgt spd_fail + rlwimi r7,r6,0,27,31 + + stw r7,SD_TIMING(r4) + sync + + /*===================================================================== + * The following two registers are set on per-DIMM basis. + * The SD_REFRESH and SD_TIMING settings are common for both DIMMS + *===================================================================== + */ + +do_each_dimm: + + /***************************************** + * Program SDRAM DIMM Control Register + */ + + li r7, 0 /* clear r7 prior parameter collection */ + + READ_SPD(13) /* Get Primary SDRAM Width */ + beq spd_read_fail + cmpi 0,0,r3,4 /* Check for 4-bit SDRAM */ + beq do_nbank + oris r7,r7,0x0010 /* Set MEM_WIDTH bit */ + +do_nbank: + READ_SPD(17) /* Get Number of banks on SDRAM device */ + beq spd_read_fail + /* Grendel only distinguish betw. 4 or 8-bank memory parts */ + li r5,ERR_UNKNOWN_PART /* non-supported memory part */ + cmpi 0,0,r3,4 + beq do_nrank + cmpi 0,0,r3,8 + bne spd_fail + ori r7,r7,0x1000 + +do_nrank: + READ_SPD(5) /* Get # of Ranks */ + beq spd_read_fail + li r5,ERR_NRANK_INVALID + andi. r6,r3,0x7 /* Use bits [2..0] only */ + beq do_addr_mode + cmpi 0,0,r6,1 + bgt spd_fail + rlwimi r7,r6,8,23,23 + +do_addr_mode: + READ_SPD(4) /* Get # of Column Addresses */ + beq spd_read_fail + li r5, ERR_ADDR_MODE + andi. r3,r3,0x0f /* cut off reserved bits */ + cmpi 0,0,r3,8 + ble spd_fail + cmpi 0,0,r3,15 + bgt spd_fail + addi r6,r3,-8 /* calculate ADDR_MODE parameter */ + rlwimi r7,r6,4,24,27 /* set ADDR_MODE field */ + +set_dimm_ctrl: +#ifdef SDC_AUTOPRECH_EN + oris r7,r7,0x0001 /* set auto precharge EN bit */ +#endif + ori r7,r7,1 /* set ENABLE bit */ + cmpi 0,0,r10,SPD_DIMM0 + bne 1f + stw r7,SD_D0_CTRL(r4) + sync + b set_dimm_bar +1: + stw r7,SD_D1_CTRL(r4) + sync + + + /******************************************** + * Program SDRAM DIMMx Base Address Register + */ + +set_dimm_bar: + READ_SPD(5) /* get # of Ranks */ + beq spd_read_fail + andi.r7,r3,0x7 + addi r7,r7,1 + READ_SPD(31) /* Read DIMM rank density */ + beq spd_read_fail + rlwinm r5,r3,27,29,31 + rlwinm r6,r3,3,24,28 + or r5,r6,r5 /* r5 = Normalized Rank Density byte */ + lis r8, 0x0080 /* 128MB >> 4 */ + mullw r8,r8,r5 /* r8 = (rank_size >> 4) */ + mullw r8,r8,r7 /* r8 = (DIMM_size >> 4) */ + neg r7,r8 + rlwinm r7,r7,28,4,31 + or r7,r7,r11 /* set ADDR field */ + rlwinm r8,r8,12,20,31 + add r11,r11,r8 /* set Base Addr for next DIMM */ + + cmpi 0,0,r10,SPD_DIMM0 + bne set_dimm1_size + stw r7,SD_D0_BAR(r4) + sync + li r10,SPD_DIMM1 + READ_SPD(0) + bne do_each_dimm + b spd_done + +set_dimm1_size: + stw r7,SD_D1_BAR(r4) + sync +spd_done: + blr + +check_next_slot: + cmpi 0,0,r10,SPD_DIMM1 + beq spd_read_fail + li r10,SPD_DIMM1 + b do_first_dimm +spd_read_fail: + ori r3,r0,0xdead + b err_hung +spd_fail: + li r3,0x0bad + sync +err_hung: /* hang here for debugging */ + nop + nop + b err_hung + +#endif /* !SDC_HARDCODED_INIT */ +
Add mpc7448hpc2 (mpc7448 + tsi108) board associated code support. The mpc7448hpc2 board support header file.
--- include/configs/mpc7448hpc2.h | 453 +++++++++++++++++++++++++++++++++++++++++ 1 files changed, 453 insertions(+), 0 deletions(-)
diff --git a/include/configs/mpc7448hpc2.h b/include/configs/mpc7448hpc2.h new file mode 100644 index 0000000..9243d58 --- /dev/null +++ b/include/configs/mpc7448hpc2.h @@ -0,0 +1,453 @@ +/* + * Copyright (c) 2005 Freescale Semiconductor, Inc. + * + * (C) Copyright 2006 + * Alex Bounine , Tundra Semiconductor Corp. + * Roy Zang , Freescale Corp. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/**************************************************************** + * + * board specific configuration options for Freescale + * MPC7448HPC2 (High-Performance Computing II) (Taiga) board + * + ****************************************************************/ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#undef DEBUG + +/* Board Configuration Definitions */ +/* MPC7448HPC2 (High-Performance Computing II) (Taiga) board */ + +#define CONFIG_MPC7448HPC2 + +#define CONFIG_74xx +#define CONFIG_750FX /* this option to enable init of extended BATs */ +#define CONFIG_ALTIVEC /* undef to disable */ + +#define CFG_BOARD_NAME "MPC7448 HPC II" +#define CONFIG_IDENT_STRING " Freescale MPC7448 HPC II" + +#define CFG_OCN_CLK 133000000 /* 133 MHz */ +#define CFG_CONFIG_BUS_CLK 133000000 + +#define CFG_CLK_SPREAD /* Enable Spread-Spectrum Clock generation */ + +#undef CONFIG_ECC /* disable ECC support */ + +/* Board-specific Initialization Functions to be called */ +#define CFG_BOARD_ASM_INIT +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_EARLY_INIT_R +#define CONFIG_MISC_INIT_R + +/* Default MAC Addresses for on-chip GIGE Controller */ + +#define CONFIG_ETHADDR 00:06:D2:00:00:01 + +#define CONFIG_HAS_ETH1 +#define CONFIG_ETH1ADDR 00:06:D2:00:00:02 + +#define CONFIG_ENV_OVERWRITE + +/* + * High Level Configuration Options + * (easy to change) + */ + +#define CONFIG_BAUDRATE 115200 /* console baudrate = 115000 */ + +/*#define CFG_HUSH_PARSER */ +#undef CFG_HUSH_PARSER + +#define CFG_PROMPT_HUSH_PS2 "> " + +/* Pass open firmware flat tree */ +#define CONFIG_OF_FLAT_TREE 1 +#define CONFIG_OF_BOARD_SETUP 1 + +/* maximum size of the flat tree (8K) */ +#define OF_FLAT_TREE_MAX_SIZE 8192 + +#define OF_CPU "PowerPC,7448@0" +#define OF_TSI "tsi108@c0000000" +#define OF_TBCLK (bd->bi_busfreq / 8) +#define OF_STDOUT_PATH "/tsi108@c0000000/serial@7808" + +/* + * The following defines let you select what serial you want to use + * for your console driver. + * + * what to do: + * If you have hacked a serial cable onto the second DUART channel, change the CFG_DUART port from 1 + * to 0 below. + * + */ + +#define CONFIG_CONS_INDEX 1 +#define CFG_NS16550 +#define CFG_NS16550_SERIAL +#define CFG_NS16550_REG_SIZE 1 +#define CFG_NS16550_CLK CFG_OCN_CLK * 8 + +#define CFG_NS16550_COM1 (CFG_TSI108_CSR_RST_BASE+0x7808) +#define CFG_NS16550_COM2 (CFG_TSI108_CSR_RST_BASE+0x7C08) +#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +#define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */ +#define CONFIG_ZERO_BOOTDELAY_CHECK + +#undef CONFIG_BOOTARGS +/*#define CONFIG_PREBOOT "echo;echo Type "run flash_nfs" to mount root filesystem over NFS;echo" */ + +#if (CONFIG_BOOTDELAY >= 0) +#define CONFIG_BOOTCOMMAND "tftpboot 0x400000 zImage.initrd.elf;\ + setenv bootargs $(bootargs) $(bootargs_root) nfsroot=$(serverip):$(rootpath) \ + ip=$(ipaddr):$(serverip)$(bootargs_end); bootm 0x400000; " + +#define CONFIG_BOOTARGS "console=ttyS0,115200" +#endif + +#undef CONFIG_EXTRA_ENV_SETTINGS + +#define CONFIG_SERIAL "No. 1" + +/* Networking Configuration */ + +#define KSEG1ADDR(a) (a) /* Needed by the rtl8139 driver */ + +#define CONFIG_TSI108_ETH +#define CONFIG_TSI108_ETH_NUM_PORTS 2 + +#define CONFIG_NET_MULTI + +#define CONFIG_IPADDR 172.27.234.48 +#define CONFIG_SERVERIP 172.27.234.10 +#define CONFIG_NETMASK 255.255.0.0 +#define CONFIG_GATEWAYIP 172.27.255.254 + +#define CONFIG_BOOTFILE zImage.initrd.elf +#define CONFIG_LOADADDR 0x400000 + +#define CONFIG_TESTDRAMDATA y +#define CONFIG_TESTDRAMADDRESS n +#define CONFIG_TESETDRAMWALK n + +/*-------------------------------------------------------------------------- */ + +#define CONFIG_LOADS_ECHO 0 /* echo off for serial download */ +#define CFG_LOADS_BAUD_CHANGE /* allow baudrate changes */ + +#undef CONFIG_WATCHDOG /* watchdog disabled */ + +#define CONFIG_BOOTP_MASK (CONFIG_BOOTP_DEFAULT | \ + CONFIG_BOOTP_BOOTFILESIZE) + +/* Flash banks JFFS2 should use */ +#define CFG_JFFS2_FIRST_BANK 1 +#define CFG_JFFS2_NUM_BANKS 1 + +#define CONFIG_COMMANDS (CONFIG_CMD_DFL \ + | CFG_CMD_ASKENV \ + | CFG_CMD_CACHE \ + | CFG_CMD_PCI \ + | CFG_CMD_I2C \ + | CFG_CMD_SDRAM \ + | CFG_CMD_EEPROM \ + | CFG_CMD_NET \ + | CFG_CMD_FLASH \ + | CFG_CMD_ENV \ + | CFG_CMD_BSP \ + | CFG_CMD_DHCP \ + | CFG_CMD_PING \ + | CFG_CMD_DATE) + +/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ +#include <cmd_confdefs.h> + +/*set date in u-boot*/ +#define CONFIG_RTC_M48T35A +#define CFG_NVRAM_BASE_ADDR 0xfc000000 +#define CFG_NVRAM_SIZE 0x8000 +/* + * Miscellaneous configurable options + */ +#define CONFIG_VERSION_VARIABLE 1 +#define CONFIG_TSI108_I2C + +#define CFG_I2C_EEPROM_ADDR 0x50 /* I2C EEPROM page 1 */ +#define CFG_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ + +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_PROMPT "=> " /* Monitor Command Prompt */ + +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port at */ +#else +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#endif + +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ + +/* +#define CFG_DRAM_TEST + * DRAM tests + * CFG_DRAM_TEST - enables the following tests. + * + * CFG_DRAM_TEST_DATA - Enables test for shorted or open data lines + * Environment variable 'test_dram_data' must be + * set to 'y'. + * CFG_DRAM_TEST_DATA - Enables test to verify that each word is uniquely + * addressable. Environment variable + * 'test_dram_address' must be set to 'y'. + * CFG_DRAM_TEST_WALK - Enables test a 64-bit walking ones pattern test. + * This test takes about 6 minutes to test 64 MB. + * Environment variable 'test_dram_walk' must be + * set to 'y'. + */ +#define CFG_DRAM_TEST +#if defined(CFG_DRAM_TEST) +#define CFG_MEMTEST_START 0x00400000 /* memtest works on */ +#define CFG_MEMTEST_END 0x07c00000 /* 4 ... 124 MB in DRAM */ +#define CFG_DRAM_TEST_DATA +#define CFG_DRAM_TEST_ADDRESS +#define CFG_DRAM_TEST_WALK +#endif /* CFG_DRAM_TEST */ + +#define CFG_LOAD_ADDR 0x00400000 /* default load address */ + +#define CFG_HZ 1000 /* decr freq: 1ms ticks */ + +/* + * Low Level Configuration Settings + * (address mappings, register initial values, etc.) + * You should know what you are doing if you make changes here. + */ + +/*----------------------------------------------------------------------- + * Definitions for initial stack pointer and data area + */ + +/* + * When locking data in cache you should point the CFG_INIT_RAM_ADDRESS + * To an unused memory region. The stack will remain in cache until RAM + * is initialized +*/ +#undef CFG_INIT_RAM_LOCK +#define CFG_INIT_RAM_ADDR 0x07d00000 /* unused memory region */ +#define CFG_INIT_RAM_END 0x4000 /* larger space - we have SDRAM initialized */ + +#define CFG_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ +#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) + +/*----------------------------------------------------------------------- + * Start addresses for the final memory configuration + * (Set up by the startup code) + * Please note that CFG_SDRAM_BASE _must_ start at 0 + */ + +#define CFG_SDRAM_BASE 0x00000000 /* first 256 MB of SDRAM */ +#define CFG_SDRAM1_BASE 0x10000000 /* next 256MB of SDRAM */ + +#define CFG_SDRAM2_BASE 0x40000000 /* beginning of non-cacheable alias for SDRAM - first 256MB */ +#define CFG_SDRAM3_BASE 0x50000000 /* next Non-Cacheable 256MB of SDRAM */ + +#define CFG_PCI_PFM_BASE 0x80000000 /* Prefetchable (cacheable) PCI/X PFM and SDRAM OCN (128MB+128MB) */ + +#define CFG_PCI_MEM32_BASE 0xE0000000 /* Non-Cacheable PCI/X MEM and SDRAM OCN (128MB+128MB) */ + +#define CFG_MISC_REGION_BASE 0xf0000000 /* Base Address for (PCI/X + Flash) region */ + +#define CFG_FLASH_BASE 0xff000000 /* Base Address of Flash device */ +#define CFG_FLASH_BASE2 0xfe000000 /* Alternate Flash Base Address */ + +#define CONFIG_VERY_BIG_RAM /* we will use up to 256M memory for cause we are short of BATS */ + +#define PCI0_IO_BASE_BOOTM 0xfd000000 + +#define CFG_RESET_ADDRESS 0x3fffff00 +#define CFG_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ +#define CFG_MONITOR_BASE TEXT_BASE /* u-boot code base */ +#define CFG_MALLOC_LEN (256 << 10) /* Reserve 256 kB for malloc */ + +/* Peripheral Device section */ + +/******************************************************* + * Resources on the Tsi108 + *******************************************************/ + +#define CFG_TSI108_CSR_RST_BASE 0xC0000000 /* Tsi108 CSR base after reset */ +#define CFG_TSI108_CSR_BASE CFG_TSI108_CSR_RST_BASE /* Runtime Tsi108 CSR base */ + +#define ENABLE_PCI_CSR_BAR /* enables access to Tsi108 CSRs from the PCI/X bus */ + +#undef DISABLE_PBM + +/*----------------------------------------------------------------------- + * PCI stuff + *----------------------------------------------------------------------- + */ + +#define CONFIG_PCI /* include pci support */ +#define CONFIG_TSI108_PCI /* include tsi108 pci support */ + +#define PCI_HOST_ADAPTER 0 /* configure as pci adapter */ +#define PCI_HOST_FORCE 1 /* configure as pci host */ +#define PCI_HOST_AUTO 2 /* detected via arbiter enable */ + +#define CONFIG_PCI_HOST PCI_HOST_FORCE /* select pci host function */ +#define CONFIG_PCI_PNP /* do pci plug-and-play */ + +/* PCI MEMORY MAP section */ + +/* PCI view of System Memory */ +#define CFG_PCI_MEMORY_BUS 0x00000000 +#define CFG_PCI_MEMORY_PHYS 0x00000000 +#define CFG_PCI_MEMORY_SIZE 0x80000000 + +/* PCI Memory Space */ +#define CFG_PCI_MEM_BUS (CFG_PCI_MEM_PHYS) +#define CFG_PCI_MEM_PHYS (CFG_PCI_MEM32_BASE) //CFG_PCI_MEM32_BASE = 0xE0000000 +#define CFG_PCI_MEM_SIZE 0x10000000 /* 256 MB space for PCI/X Mem + SDRAM OCN */ + +/* PCI I/O Space */ +#define CFG_PCI_IO_BUS 0x00000000 +#define CFG_PCI_IO_PHYS 0xfa000000 /* Changed from fd000000 */ + +#define CFG_PCI_IO_SIZE 0x01000000 /* 16MB */ + +#define _IO_BASE 0x00000000 /* points to PCI I/O space */ + +/* PCI Config Space mapping */ +#define CFG_PCI_CFG_BASE 0xfb000000 /* Changed from FE000000 */ +#define CFG_PCI_CFG_SIZE 0x01000000 /* 16MB */ + +#define CFG_IBAT0U 0xFE0003FF +#define CFG_IBAT0L 0xFE000002 + +#define CFG_IBAT1U 0x00007FFF +#define CFG_IBAT1L 0x00000012 + +#define CFG_IBAT2U 0x80007FFF +#define CFG_IBAT2L 0x80000022 + +#define CFG_IBAT3U 0x00000000 +#define CFG_IBAT3L 0x00000000 + +#define CFG_IBAT4U 0x00000000 +#define CFG_IBAT4L 0x00000000 + +#define CFG_IBAT5U 0x00000000 +#define CFG_IBAT5L 0x00000000 + +#define CFG_IBAT6U 0x00000000 +#define CFG_IBAT6L 0x00000000 + +#define CFG_IBAT7U 0x00000000 +#define CFG_IBAT7L 0x00000000 + +#define CFG_DBAT0U 0xE0003FFF +#define CFG_DBAT0L 0xE000002A + +#define CFG_DBAT1U 0x00007FFF +#define CFG_DBAT1L 0x00000012 + +#define CFG_DBAT2U 0x00000000 +#define CFG_DBAT2L 0x00000000 + +#define CFG_DBAT3U 0xC0000003 +#define CFG_DBAT3L 0xC000002A + +#define CFG_DBAT4U 0x00000000 +#define CFG_DBAT4L 0x00000000 + +#define CFG_DBAT5U 0x00000000 +#define CFG_DBAT5L 0x00000000 + +#define CFG_DBAT6U 0x00000000 +#define CFG_DBAT6L 0x00000000 + +#define CFG_DBAT7U 0x00000000 +#define CFG_DBAT7L 0x00000000 + +/* I2C addresses for the two DIMM SPD chips */ +#define DIMM0_I2C_ADDR 0x51 +#define DIMM1_I2C_ADDR 0x52 + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CFG_BOOTMAPSZ (8<<20) /* Initial Memory map for Linux */ + +/*----------------------------------------------------------------------- + * FLASH organization + */ +#define CFG_MAX_FLASH_BANKS 1 /* Flash can be at one of two addresses */ +#define FLASH_BANK_SIZE 0x01000000 /* 16 MB Total */ +#define CFG_FLASH_BANKS_LIST {CFG_FLASH_BASE, CFG_FLASH_BASE2} + +#define CFG_FLASH_CFI_DRIVER +#define CFG_FLASH_CFI +#define CFG_FLASH_CFI_SWAP + +#define PHYS_FLASH_SIZE 0x01000000 +#define CFG_MAX_FLASH_SECT (128) + +#define CFG_ENV_IS_IN_NVRAM +#define CFG_ENV_ADDR 0xFC000000 + +#define CFG_ENV_OFFSET 0x00000000 /* Offset of Environment Sector */ +#define CFG_ENV_SIZE 0x00000400 /* Total Size of Environment Space */ + +/*----------------------------------------------------------------------- + * Cache Configuration + */ +#define CFG_CACHELINE_SIZE 32 /* For all MPC74xx CPUs */ +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + +/*----------------------------------------------------------------------- + * L2CR setup -- make sure this is right for your board! + * look in include/mpc74xx.h for the defines used here + */ +#undef CFG_L2 + +#define L2_INIT 0 +#define L2_ENABLE (L2_INIT | L2CR_L2E) + +/* + * Internal Definitions + * + * Boot Flags + */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ +#define CFG_EXCEPTION_AFTER_RELOCATE +#define CFG_SERIAL_HANG_IN_EXCEPTION +#endif /* __CONFIG_H */
The following feedback can be considered for next fixes. Not to take effect on this patchset apply.
Zang Roy-r61911 tie-fei.zang@freescale.com wrote: [snip]
I don't know the meaning of this stuff. Ummm, where are they applied?
Without CFG_CMD_JFFS2 marco, what's the purpose of this?
| CFG_CMD_ASKENV \
| CFG_CMD_CACHE \
| CFG_CMD_PCI \
| CFG_CMD_I2C \
| CFG_CMD_SDRAM \
| CFG_CMD_EEPROM \
| CFG_CMD_NET \
CFG_CMD_NET has been included in DFL.
| CFG_CMD_FLASH \
Also check this one, pls.
| CFG_CMD_ENV \
And this one as well.
Why enable DRAM test process during boot up? Seems it's common to disable this option.
- DRAM tests
- CFG_DRAM_TEST - enables the following tests.
- CFG_DRAM_TEST_DATA - Enables test for shorted
or open data lines
be
set to 'y'.
- CFG_DRAM_TEST_DATA - Enables test to verify
Two CFG_DRAM_TEST_DATAs have different meaning?
Thanks,
Sam
___________________________________________________________ 雅虎免费邮箱-3.5G容量,20M附件 http://cn.mail.yahoo.com/
Removed.
| CFG_CMD_ASKENV \
| CFG_CMD_CACHE \
| CFG_CMD_PCI \
| CFG_CMD_I2C \
| CFG_CMD_SDRAM \
| CFG_CMD_EEPROM \
| CFG_CMD_NET \
Removed.
| CFG_CMD_FLASH \
| CFG_CMD_ENV \
I have checked these two. They can be kept.
disabled.
- DRAM tests
or open data lines
be
set to 'y'.
Should be CFG_DRAM_TEST_ADDRESS in the comments.
Thanks,
Sam
Sam, Based on your comments, I have generate the following patch base on my previous patch(v3 version). At the same time, the update is reflected on my git repo
http://opensource.freescale.com/git?p=u-boot-7448hpc2.git;a=summary
Thanks for your comment.
Roy
===================================================================== Change the TEXT_BASE from 0xFFF00000 to 0xFF000000. Both work. 0xFF000000 seems more reasonable.
board/mpc7448hpc2/config.mk | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/mpc7448hpc2/config.mk b/board/mpc7448hpc2/config.mk index 9147a5c..2e58858 100644 --- a/board/mpc7448hpc2/config.mk +++ b/board/mpc7448hpc2/config.mk @@ -21,7 +21,7 @@ # MA 02111-1307 USA #
# Flash address -TEXT_BASE = 0xFFF00000 +TEXT_BASE = 0xFF000000 # RAM address #TEXT_BASE = 0x00400000
Sam Song
Zang Roy-r61911
