Hi Tom,
This PR includes the following x86 changes for v2021.04:
- Various minor fixes for x86
Azure results: PASS https://dev.azure.com/bmeng/GitHub/_build/results?buildId=337&view=resul...
The following changes since commit 472c5484bca41a477f8b86a263e559f6e992c7f8:
Merge tag 'u-boot-amlogic-20210308' of https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic (2021-03-08 07:41:50 -0500)
https://source.denx.de/u-boot/custodians/u-boot-x86
for you to fetch changes up to 736ecc643de4b329e2edcb3207edd58bf7ed0d9d:
x86: Select advanced Intel code only if allowed (2021-03-09 09:42:12 +0800)
---------------------------------------------------------------- Heinrich Schuchardt (1): x86: sizeof-array-div error in lpc_common_early_init
Simon Glass (3): x86: Fix member check in intel_gnvs x86: Move INTEL_ACPIGEN to arch/x86 x86: Select advanced Intel code only if allowed
arch/x86/Kconfig | 24 ++++++++++++++++++++++++ arch/x86/cpu/apollolake/Kconfig | 1 + arch/x86/cpu/intel_common/lpc.c | 2 +- arch/x86/include/asm/intel_gnvs.h | 4 ++++ drivers/core/Kconfig | 9 --------- 5 files changed, 30 insertions(+), 10 deletions(-)
Regards, Bin
On Tue, Mar 09, 2021 at 01:15:22PM +0800, Bin Meng wrote:
Hi Tom,
Bin Meng
