Pull request, u-boot-tegra/master
Tom,
Please pull u-boot-tegra/master into U-Boot/master. Thanks.
The following changes since commit 92a8bc6b419f548230f10a924db2b3ef10a5edad:
Merge tag 'efi-2022-07-rc5' of https://source.denx.de/u-boot/custodians/u-boot-efi (2022-06-13 09:33:37 -0400)
https://source.denx.de/u-boot/custodians/u-boot-tegra.git master
for you to fetch changes up to 8f27bf114ef48e681f00fcb38ad48d4ab581d0ca:
board: apalis_t30/tk1/colibri_t20/t30: integrate mac address via dt (2022-06-13 15:31:15 -0700)
---------------------------------------------------------------- Marcel Ziswiler (1): board: apalis_t30/tk1/colibri_t20/t30: integrate mac address via dt
Peter Robinson (3): ARM: tegra: XUSB padctl: Add new lines for errors pci: tegra: Update error prints with new lines arm: tegra: Update some DT compatibles
arch/arm/mach-tegra/xusb-padctl-common.c | 12 ++++++------ board/toradex/apalis-tk1/apalis-tk1.c | 19 +++++++++++++++++++ board/toradex/apalis_t30/apalis_t30.c | 20 ++++++++++++++++++++ board/toradex/colibri_t20/colibri_t20.c | 19 +++++++++++++++++++ board/toradex/colibri_t30/colibri_t30.c | 20 ++++++++++++++++++++ drivers/i2c/tegra_i2c.c | 1 + drivers/pci/pci_tegra.c | 4 ++-- drivers/video/tegra124/dp.c | 1 + 8 files changed, 88 insertions(+), 8 deletions(-)
On Tue, Jun 14, 2022 at 09:05:11AM -0700, Tom Warren wrote:
Tom,
Tom,
That said, please put things through CI before sending a PR. I did a quick local build test, and found a warning being introduced because of a missing include. I fixed that and figured it was enough, which is on me. Next up: commit 0d2105ae5e32ef5c87246054b2638fe50e62448c Author: Peter Robinson pbrobinson@gmail.com Date: Tue May 3 09:32:54 2022 +0100 arm: tegra: Update some DT compatibles
breaks the dtoc tests: https://source.denx.de/u-boot/u-boot/-/jobs/448215 and I'm going to fix that momentarily.
Tom Warren
