Re: [U-Boot] [PATCH 1/6 V4] EXYNOS5: Fix system register structure
Hi Marek,
On Wed, May 14, 2012 at 11:56 PM, Marek Vasut <marex@denx.dechander.kashyap@linaro.org
wrote:
Dear Rajeshwari Shinde,
This patch corrects the SYSREG structure.
What is the exact difference between this patchset and V3 one? It's a good practice to sum such things up below diffstat.
Yes, Change is in [PATCH 4/6 V4] EXYNOS: Add power Enable/Disable for USB-EHCI, and mentioned in the same.
We have removed the sysreg.h added in the previous patchset version as the sysreg structure is already defined in system.h.
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Minkyu Kang mk7.kang@samsung.com
arch/arm/include/asm/arch-exynos/system.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/system.h b/arch/arm/include/asm/arch-exynos/system.h index c85f949..c1d880f 100644 --- a/arch/arm/include/asm/arch-exynos/system.h +++ b/arch/arm/include/asm/arch-exynos/system.h @@ -42,6 +42,7 @@ struct exynos5_sysreg { unsigned int reserved; unsigned int ispblk_cfg; unsigned int usb20phy_cfg;
unsigned char res2[0x29c]; unsigned int mipi_dphy; unsigned int dptx_dphy; unsigned int phyclk_sel;
Best regards, Marek Vasut _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
-- with warm regards, Chander Kashyap
Best regards Vivek Gautam
Dear Vivek Gautam,
Hi Marek,
What exact change please?
Hi Marek,
The exact change is in "[PATCH 4/6 V4] EXYNOS: Add power Enable/Disable for USB-EHCI", It is : Renamed exynos5_set_usb_phy_ctrl and set_usb_phy_ctrl to exynos5_set_usbhost_phy_ctrl and set_usbhost_phy_ctrl.
On Wed, May 16, 2012 at 6:53 PM, Marek Vasut marex@denx.de wrote:
Dear Vivek Gautam,
Hi Marek,
- unsigned char res2[0x29c];
Regards, Rajeshwari Shinde.
Dear Rajeshwari Birje,
Hi Marek,
Thank you for clearing this up. I'm now waiting for pullrq from albert to hit mainline.
Dear Vivek Gautam,
Hi Marek,
Rajeshwari Birje
Vivek Gautam
