[PATCH 1/2] spl: socfpga: Getting SPL boot device from DT
Current SPL boot device is harcoded with MMC1, this implementation would inhibit the support of other boot device. So, this patch is created to get the boot device from DT, user should define the boot device in property "u-boot,boot0". Default MMC1 would be boot device if no boot device is defined in DT.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- arch/arm/dts/socfpga_stratix10_socdk.dts | 1 + arch/arm/mach-socfpga/spl_s10.c | 65 ++++++++++++++++++++++++ 2 files changed, 66 insertions(+)
diff --git a/arch/arm/dts/socfpga_stratix10_socdk.dts b/arch/arm/dts/socfpga_stratix10_socdk.dts index 8aa55a60ab..c8e9261f48 100755 --- a/arch/arm/dts/socfpga_stratix10_socdk.dts +++ b/arch/arm/dts/socfpga_stratix10_socdk.dts @@ -16,6 +16,7 @@
chosen { stdout-path = "serial0:115200n8"; + u-boot,boot0 = <&mmc>; };
leds { diff --git a/arch/arm/mach-socfpga/spl_s10.c b/arch/arm/mach-socfpga/spl_s10.c index dad2ac5d0d..c4b82ebf14 100644 --- a/arch/arm/mach-socfpga/spl_s10.c +++ b/arch/arm/mach-socfpga/spl_s10.c @@ -13,6 +13,8 @@ #include <asm/utils.h> #include <common.h> #include <debug_uart.h> +#include <dm.h> +#include <dm/ofnode.h> #include <image.h> #include <spl.h> #include <asm/arch/clock_manager.h> @@ -27,6 +29,69 @@
DECLARE_GLOBAL_DATA_PTR;
+u32 spl_boot_device(void) +{ + int ret, size; + ofnode node; + const fdt32_t *phandle_p; + u32 phandle; + struct udevice *dev; + + node = ofnode_path("/chosen"); + if (!ofnode_valid(node)) { + debug("%s: /chosen node was not found.\n", __func__); + goto fallback; + } + + phandle_p = ofnode_get_property(node, "u-boot,boot0", &size); + if (!phandle_p) { + debug("%s: u-boot,boot0 property was not found.\n", + __func__); + goto fallback; + } + + phandle = fdt32_to_cpu(*phandle_p); + + node = ofnode_get_by_phandle(phandle); + + ret = device_get_global_by_ofnode(node, &dev); + if (ret) { + debug("%s: Boot device at not found, error: %d\n", __func__, + ret); + goto fallback; + } + + debug("%s: Found boot device %s\n", __func__, dev->name); + + switch (device_get_uclass_id(dev)) { + case UCLASS_SPI_FLASH: + return BOOT_DEVICE_SPI; + case UCLASS_MISC: + return BOOT_DEVICE_NAND; + case UCLASS_MMC: + return BOOT_DEVICE_MMC1; + default: + debug("%s: Booting from device uclass '%s' is not " + "supported\n", __func__, + dev_get_uclass_name(dev)); + } + +fallback: + /* Return default boot device */ + return BOOT_DEVICE_MMC1; +} + +#ifdef CONFIG_SPL_MMC_SUPPORT +u32 spl_mmc_boot_mode(const u32 boot_device) +{ +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) + return MMCSD_MODE_FS; +#else + return MMCSD_MODE_RAW; +#endif +} +#endif + void board_init_f(ulong dummy) { const struct cm_config *cm_default_cfg = cm_get_default_config();
Since Stratix10 and Agilex are using ARM64, there are some common codes in the SPL. Hence, spl_soc64.c is created to place the common codes.
Signed-off-by: Ooi, Joyce joyce.ooi@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- arch/arm/mach-socfpga/spl_s10.c | 63 --------------------------- arch/arm/mach-socfpga/spl_soc64.c | 71 +++++++++++++++++++++++++++++-- 2 files changed, 67 insertions(+), 67 deletions(-)
diff --git a/arch/arm/mach-socfpga/spl_s10.c b/arch/arm/mach-socfpga/spl_s10.c index c4b82ebf14..fb807acf27 100644 --- a/arch/arm/mach-socfpga/spl_s10.c +++ b/arch/arm/mach-socfpga/spl_s10.c @@ -29,69 +29,6 @@
-u32 spl_boot_device(void) -{ - int ret, size; - ofnode node; - const fdt32_t *phandle_p; - u32 phandle; - struct udevice *dev; - - node = ofnode_path("/chosen"); - if (!ofnode_valid(node)) { - debug("%s: /chosen node was not found.\n", __func__); - goto fallback; - } - - phandle_p = ofnode_get_property(node, "u-boot,boot0", &size); - if (!phandle_p) { - debug("%s: u-boot,boot0 property was not found.\n", - __func__); - goto fallback; - } - - phandle = fdt32_to_cpu(*phandle_p); - - node = ofnode_get_by_phandle(phandle); - - ret = device_get_global_by_ofnode(node, &dev); - if (ret) { - debug("%s: Boot device at not found, error: %d\n", __func__, - ret); - goto fallback; - } - - debug("%s: Found boot device %s\n", __func__, dev->name); - - switch (device_get_uclass_id(dev)) { - case UCLASS_SPI_FLASH: - return BOOT_DEVICE_SPI; - case UCLASS_MISC: - return BOOT_DEVICE_NAND; - case UCLASS_MMC: - return BOOT_DEVICE_MMC1; - default: - debug("%s: Booting from device uclass '%s' is not " - "supported\n", __func__, - dev_get_uclass_name(dev)); - } - -fallback: - /* Return default boot device */ - return BOOT_DEVICE_MMC1; -} - -#ifdef CONFIG_SPL_MMC_SUPPORT -u32 spl_mmc_boot_mode(const u32 boot_device) -{ -#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) - return MMCSD_MODE_FS; -#else - return MMCSD_MODE_RAW; -#endif -} -#endif - void board_init_f(ulong dummy) { const struct cm_config *cm_default_cfg = cm_get_default_config(); diff --git a/arch/arm/mach-socfpga/spl_soc64.c b/arch/arm/mach-socfpga/spl_soc64.c index ba6efc1d86..ea1acaf309 100644 --- a/arch/arm/mach-socfpga/spl_soc64.c +++ b/arch/arm/mach-socfpga/spl_soc64.c @@ -4,22 +4,85 @@ * */
+#include <asm/io.h> +#include <asm/u-boot.h> +#include <asm/utils.h> #include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <dm/ofnode.h> +#include <image.h> +#include <log.h> #include <spl.h> +#include <asm/arch/clock_manager.h> +#include <asm/arch/firewall.h> +#include <asm/arch/mailbox_s10.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> +#include <asm/arch/smmu_s10.h> +#include <watchdog.h> +#include <dm/uclass.h>
u32 spl_boot_device(void) { + int ret, size; + ofnode node; + const fdt32_t *phandle_p; + u32 phandle; + struct udevice *dev; + + node = ofnode_path("/chosen"); + if (!ofnode_valid(node)) { + debug("%s: /chosen node was not found.\n", __func__); + goto fallback; + } + + phandle_p = ofnode_get_property(node, "u-boot,boot0", &size); + if (!phandle_p) { + debug("%s: u-boot,boot0 property was not found.\n", + __func__); + goto fallback; + } + + phandle = fdt32_to_cpu(*phandle_p); + + node = ofnode_get_by_phandle(phandle); + + ret = device_get_global_by_ofnode(node, &dev); + if (ret) { + debug("%s: Boot device at not found, error: %d\n", __func__, + ret); + goto fallback; + } + + debug("%s: Found boot device %s\n", __func__, dev->name); + + switch (device_get_uclass_id(dev)) { + case UCLASS_SPI_FLASH: + return BOOT_DEVICE_SPI; + case UCLASS_MISC: + return BOOT_DEVICE_NAND; + case UCLASS_MMC: + return BOOT_DEVICE_MMC1; + default: + debug("%s: Booting from device uclass '%s' is not supported\n", + __func__, dev_get_uclass_name(dev)); + } + +fallback: + /* Return default boot device */ return BOOT_DEVICE_MMC1; }
#if IS_ENABLED(CONFIG_SPL_MMC) u32 spl_boot_mode(const u32 boot_device) { - if (IS_ENABLED(CONFIG_SPL_FS_FAT) || IS_ENABLED(CONFIG_SPL_FS_EXT4)) - return MMCSD_MODE_FS; - else - return MMCSD_MODE_RAW; +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) + return MMCSD_MODE_FS; +#else + return MMCSD_MODE_RAW; +#endif } #endif
Hi Jit Loon Lim,
Isn't u-boot,spl-boot-order DT property what you're after? We use this property to specify the order in which the listed media will be tried for loading U-Boot proper from the SPL. Is this what you're trying to do with u-boot,boot0 ? (you'll still need to implement the same logic I'm just arguing about the name that was picked for the property).
Cheers, Quentin
leds {
- int ret, size;
- ofnode node;
- u32 phandle;
goto fallback;
- if (!phandle_p) {
__func__);
goto fallback;
- if (ret) {
ret);
goto fallback;
- case UCLASS_MISC:
- case UCLASS_MMC:
- default:
+fallback:
+#else
+#endif +} +#endif
Jit Loon Lim
Quentin Schulz
