[U-Boot] [PATCH] arm: mach-k3: security: Clean image out of cache before authentication
On K3 systems U-Boot runs on both an R5 and a large ARM cores (usually A53 or A72). The large ARMs are coherent with the DMA controllers and the SYSFW that perform authentication. And previously the R5 core did not enable caches. Now that R5 does enable caching we need to be sure to clean out any of the image that may still only be in cache before we read it using external DMA for authentication.
Although not expected to happen, it may be possible that the data was read back into cache after the flush but before the external operation, in this case we must invalidate our stale local cached version.
Signed-off-by: Andrew F. Davis afd@ti.com --- arch/arm/mach-k3/security.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/mach-k3/security.c b/arch/arm/mach-k3/security.c index 4e011ee10e..83b037f189 100644 --- a/arch/arm/mach-k3/security.c +++ b/arch/arm/mach-k3/security.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <cpu_func.h> #include <dm.h> #include <linux/soc/ti/ti_sci_protocol.h> #include <mach/spl.h> @@ -22,8 +23,14 @@ void board_fit_image_post_process(void **p_image, size_t *p_size) int ret;
image_addr = (uintptr_t)*p_image; + image_size = *p_size;
debug("Authenticating image at address 0x%016llx\n", image_addr); + debug("Authenticating image of size %d bytes\n", image_size); + + flush_dcache_range((unsigned long)image_addr, + ALIGN((unsigned long)image_addr + image_size, + ARCH_DMA_MINALIGN));
/* Authenticate image */ ret = proc_ops->proc_auth_boot_image(ti_sci, &image_addr, &image_size); @@ -32,6 +39,11 @@ void board_fit_image_post_process(void **p_image, size_t *p_size) hang(); }
+ if (image_size) + invalidate_dcache_range((unsigned long)image_addr, + ALIGN((unsigned long)image_addr + + image_size, ARCH_DMA_MINALIGN)); + /* * The image_size returned may be 0 when the authentication process has * moved the image. When this happens no further processing on the
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
- if (image_size)
- The image_size returned may be 0 when the authentication process has
- moved the image. When this happens no further processing on the
Andrew F. Davis
Lokesh Vutla
