Linking Error on env_get("loadaddr")
Hello list,
I try to use env_get("loadaddr") for a board specific CMD and included env.h. But I get the following linking error in nvedit.c. Some clue what I miss here? I still use v2020.07.
start=$(aarch64-linux-gnu-nm u-boot | grep __rel_dyn_start | cut -f 1 -d ' '); end=$(aarch64-linux-gnu-nm u-boot | grep __rel_dyn_end | cut -f 1 -d ' '); tools/relocate-rela u-boot-nodtb.bin 0x80020000 $start $end CC spl/arch/arm/cpu/armv8/fwcall.o LD spl/arch/arm/cpu/armv8/built-in.o CC spl/common/spl/spl.o LD spl/common/spl/built-in.o CC spl/lib/display_options.o LD spl/lib/built-in.o LD spl/u-boot-spl cmd/built-in.o: In function `env_match': /home/graute/u-boot-test/cmd/nvedit.c:804: undefined reference to `env_get_char' /home/graute/u-boot-test/cmd/nvedit.c:808: undefined reference to `env_get_char' cmd/built-in.o: In function `env_get_f': /home/graute/u-boot-test/cmd/nvedit.c:713: undefined reference to `env_get_char' /home/graute/u-boot-test/cmd/nvedit.c:716: undefined reference to `env_get_char' /home/graute/u-boot-test/cmd/nvedit.c:729: undefined reference to `env_get_char' cmd/built-in.o: In function `env_get': /home/graute/u-boot-test/cmd/nvedit.c:677: undefined reference to `env_htab' /home/graute/u-boot-test/cmd/nvedit.c:677: undefined reference to `env_htab' lib/built-in.o: In function `hsearch_r': /home/graute/u-boot-test/lib/hashtable.c:402: undefined reference to `env_flags_init' scripts/Makefile.spl:422: recipe for target 'spl/u-boot-spl' failed make[1]: *** [spl/u-boot-spl] Error 1 Makefile:1926: recipe for target 'spl/u-boot-spl' failed make: *** [spl/u-boot-spl] Error 2
Best Regards,
Oliver
On 11/2/20 11:09 PM, Oliver Graute wrote:
Hello list,
Did you check whether CONFIG_SPL_ENV_SUPPORT is enabled?
Best Regards,
Oliver
Hello list,
thx this solved my issue.
Best Regards,
Oliver
Jaehoon Chung
Oliver Graute
Oliver Graute
