[U-Boot] [PATCH 0/4] fdt: Switch to the latest libfdt, sort-of
This series brings over the latest libfdt with some changes to deal with the recent code-size bloat.
With this change U-Boot size increases about 2.5KB on 'rock' and SPL reduces by about 128 bytes. This should be acceptable.
The 'assumptions' series is still under review, so we can sync that up later when complete.
Simon Glass (4): fdt: Add INT32_MAX to kernel.h for libfdt fdt: Add Kconfig options to control code size mx6: tbs2910: Minimise libfdt code size fdt: Sync up to the latest libfdt
configs/tbs2910_defconfig | 1 + include/linux/kernel.h | 2 + include/linux/libfdt_env.h | 1 + lib/Kconfig | 33 +++ lib/libfdt/Makefile | 3 +- lib/libfdt/fdt_ro.c | 420 ++++++++++++++++++++------- scripts/dtc/libfdt/Makefile.libfdt | 7 + scripts/dtc/libfdt/fdt.c | 182 ++++++++---- scripts/dtc/libfdt/fdt.h | 47 +-- scripts/dtc/libfdt/fdt_addresses.c | 94 +++--- scripts/dtc/libfdt/fdt_empty_tree.c | 47 +-- scripts/dtc/libfdt/fdt_overlay.c | 91 ++---- scripts/dtc/libfdt/fdt_ro.c | 341 +++++++++++++++------- scripts/dtc/libfdt/fdt_rw.c | 119 ++++---- scripts/dtc/libfdt/fdt_strerror.c | 47 +-- scripts/dtc/libfdt/fdt_sw.c | 241 ++++++++++----- scripts/dtc/libfdt/fdt_wip.c | 47 +-- scripts/dtc/libfdt/libfdt.h | 268 +++++++++++++---- scripts/dtc/libfdt/libfdt_env.h | 48 +-- scripts/dtc/libfdt/libfdt_internal.h | 144 +++++---- tools/libfdt/fdt_rw.c | 3 +- 21 files changed, 1314 insertions(+), 872 deletions(-)
Unfortunately libfdt needs this value now, which is present in the stdint.h header. That file is just a placeholder in U-Boot and these sorts of constants appear in the linux/kernel.h header instead.
To keep libfdt happy, add INT32_MAX too.
include/linux/kernel.h | 2 ++ include/linux/libfdt_env.h | 1 + 2 files changed, 3 insertions(+)
diff --git a/include/linux/kernel.h b/include/linux/kernel.h index a85c15d8dc..5c7e5f635b 100644 --- a/include/linux/kernel.h +++ b/include/linux/kernel.h @@ -37,6 +37,8 @@ #define UINT32_MAX U32_MAX #define UINT64_MAX U64_MAX
+#define INT32_MAX S32_MAX + #define STACK_MAGIC 0xdeadbeef
#define REPEAT_BYTE(x) ((~0ul / 0xff) * (x)) diff --git a/include/linux/libfdt_env.h b/include/linux/libfdt_env.h index e2bf79c7ee..cca7792acd 100644 --- a/include/linux/libfdt_env.h +++ b/include/linux/libfdt_env.h @@ -10,6 +10,7 @@ #define LIBFDT_ENV_H
#include <linux/string.h> +#include <linux/kernel.h>
#include <asm/byteorder.h>
For better or worse libfdt recent grew a lot of code that checks the validity of the device tree in great detail. When using unsigned or unverified data this makes things safer, but it does add to code size.
Add some controls to select the trade-off between safety and code size.
lib/Kconfig | 33 +++++++++++++++++++++++++++++++++ lib/libfdt/Makefile | 3 ++- 2 files changed, 35 insertions(+), 1 deletion(-)
diff --git a/lib/Kconfig b/lib/Kconfig index 135f0b372b..b8a8509d72 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -464,6 +464,17 @@ config OF_LIBFDT particular compatible nodes. The library operates on a flattened version of the device tree.
+config OF_LIBFDT_ASSUME_MASK + hex "Mask of conditions to assume for libfdt" + depends on OF_LIBFDT || FIT + default 0 + help + Use this to change the assumptions made by libfdt about the + device tree it is working with. A value of 0 means that no assumptions + are made, and libfdt is able to deal with malicious data. A value of + 0xff means all assumptions are made and any invalid data may cause + unsafe execution. See FDT_ASSUME_PERFECT, etc. in libfdt_internal.h + config OF_LIBFDT_OVERLAY bool "Enable the FDT library overlay support" depends on OF_LIBFDT @@ -481,6 +492,17 @@ config SPL_OF_LIBFDT particular compatible nodes. The library operates on a flattened version of the device tree.
+config SPL_OF_LIBFDT_ASSUME_MASK + hex "Mask of conditions to assume for libfdt" + depends on SPL_OF_LIBFDT || FIT + default 0xff + help + Use this to change the assumptions made by libfdt in SPL about the + device tree it is working with. A value of 0 means that no assumptions + are made, and libfdt is able to deal with malicious data. A value of + 0xff means all assumptions are made and any invalid data may cause + unsafe execution. See FDT_ASSUME_PERFECT, etc. in libfdt_internal.h + config TPL_OF_LIBFDT bool "Enable the FDT library for TPL" default y if TPL_OF_CONTROL @@ -491,6 +513,17 @@ config TPL_OF_LIBFDT particular compatible nodes. The library operates on a flattened version of the device tree.
+config TPL_OF_LIBFDT_ASSUME_MASK + hex "Mask of conditions to assume for libfdt" + depends on TPL_OF_LIBFDT || FIT + default 0xff + help + Use this to change the assumptions made by libfdt in TPL about the + device tree it is working with. A value of 0 means that no assumptions + are made, and libfdt is able to deal with malicious data. A value of + 0xff means all assumptions are made and any invalid data may cause + unsafe execution. See FDT_ASSUME_PERFECT, etc. in libfdt_internal.h + config FDT_FIXUP_PARTITIONS bool "overwrite MTD partitions in DTS through defined in 'mtdparts'" depends on OF_LIBFDT diff --git a/lib/libfdt/Makefile b/lib/libfdt/Makefile index ef5b6e29d4..5d3ae4e2f1 100644 --- a/lib/libfdt/Makefile +++ b/lib/libfdt/Makefile @@ -22,4 +22,5 @@ obj-y += fdt_ro.o # U-Boot own file obj-y += fdt_region.o
-ccflags-y := -I$(srctree)/scripts/dtc/libfdt +ccflags-y := -I$(srctree)/scripts/dtc/libfdt \ + -DFDT_ASSUME_MASK=$(CONFIG_$(SPL_TPL_)OF_LIBFDT_ASSUME_MASK)
- hex "Mask of conditions to assume for libfdt"
- depends on OF_LIBFDT || FIT
- default 0
- help
What do you mean by malicious here?
The checks in libfdt are about inconsistent FDT files. But they would not discover malicious settings like a destructive voltage or frequency.
Would FDT_ASSUME_SANE match what we have been checking up to now? Why not use 1 as the default here to reduce the code size of U-Boot?
- config OF_LIBFDT_OVERLAY bool "Enable the FDT library overlay support" depends on OF_LIBFDT
- depends on SPL_OF_LIBFDT || FIT
- default 0xff
On some devices the device tree is provided by the device (e.g. QEMU). Is it wise to set FDT_ASSUME_LATEST in this case?
Best regards
Heinrich
- help
- config TPL_OF_LIBFDT bool "Enable the FDT library for TPL" default y if TPL_OF_CONTROL
- depends on TPL_OF_LIBFDT || FIT
- default 0xff
- help
- config FDT_FIXUP_PARTITIONS bool "overwrite MTD partitions in DTS through defined in 'mtdparts'" depends on OF_LIBFDT
- -DFDT_ASSUME_MASK=$(CONFIG_$(SPL_TPL_)OF_LIBFDT_ASSUME_MASK)
Hi Heinrich,
default 0
help
Someone trying to compromise the system with a carefully crafted DT.
That's right. To cover that people should probably use verified boot.
Possibly. I'm open to changing this as the code size increase is a paind.
But most of the new checking code could be dropped by enabling FDT_ASSUME_FRIENDLY. Take a look at that and see what you think.
default 0xff
Well I think we have been on the current version for about 13 years, so probably.
Regards, Simon [..]
On Sun, Oct 27, 2019 at 12:49:28PM -0600, Simon Glass wrote:
Hi Heinrich,
default 0
help
Right, so the help text can be clarified a little bit more to be clear that it's checking for various types of formatting and construction problems with that data only.
We also need to be careful as the defaults we push here are the defaults that will be used when companies build their product on top. I'm in favor of the default being as much sanity checking as we an afford and to note and allow for instances where other safeguards exist, or more risk is tolerated to save some size.
This board appears to be very near its size limit and cannot accept the new checking code in libfdt. Disable this code so this the board can continue to build.
configs/tbs2910_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 42e6f58eee..6d4d4c8f9f 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -78,4 +78,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_I2C_EDID=y CONFIG_VIDEO_IPUV3=y CONFIG_VIDEO=y +CONFIG_OF_LIBFDT_ASSUME_MASK=0xff # CONFIG_EFI_LOADER is not set
Applied to u-boot-fdt
Bring over the fdt from this commit:
430419c (origin/master) tests: fix some python warnings
adding in the 'assumptions' series designed to reduce code size.
lib/libfdt/fdt_ro.c | 420 ++++++++++++++++++++------- scripts/dtc/libfdt/Makefile.libfdt | 7 + scripts/dtc/libfdt/fdt.c | 182 ++++++++---- scripts/dtc/libfdt/fdt.h | 47 +-- scripts/dtc/libfdt/fdt_addresses.c | 94 +++--- scripts/dtc/libfdt/fdt_empty_tree.c | 47 +-- scripts/dtc/libfdt/fdt_overlay.c | 91 ++---- scripts/dtc/libfdt/fdt_ro.c | 341 +++++++++++++++------- scripts/dtc/libfdt/fdt_rw.c | 119 ++++---- scripts/dtc/libfdt/fdt_strerror.c | 47 +-- scripts/dtc/libfdt/fdt_sw.c | 241 ++++++++++----- scripts/dtc/libfdt/fdt_wip.c | 47 +-- scripts/dtc/libfdt/libfdt.h | 268 +++++++++++++---- scripts/dtc/libfdt/libfdt_env.h | 48 +-- scripts/dtc/libfdt/libfdt_internal.h | 144 +++++---- tools/libfdt/fdt_rw.c | 3 +- 16 files changed, 1275 insertions(+), 871 deletions(-)
diff --git a/lib/libfdt/fdt_ro.c b/lib/libfdt/fdt_ro.c index 693de9aa5a..560041b603 100644 --- a/lib/libfdt/fdt_ro.c +++ b/lib/libfdt/fdt_ro.c @@ -14,12 +14,13 @@
#include "libfdt_internal.h"
-static int _fdt_nodename_eq(const void *fdt, int offset, +static int fdt_nodename_eq_(const void *fdt, int offset, const char *s, int len) { - const char *p = fdt_offset_ptr(fdt, offset + FDT_TAGSIZE, len+1); + int olen; + const char *p = fdt_get_name(fdt, offset, &olen);
- if (!p) + if (!p || (fdt_chk_extra() && olen < len)) /* short match */ return 0;
@@ -34,46 +35,85 @@ static int _fdt_nodename_eq(const void *fdt, int offset, return 0; }
-const char *fdt_string(const void *fdt, int stroffset) -{ - return (const char *)fdt + fdt_off_dt_strings(fdt) + stroffset; -} - -static int _fdt_string_eq(const void *fdt, int stroffset, - const char *s, int len) +const char *fdt_get_string(const void *fdt, int stroffset, int *lenp) { - const char *p = fdt_string(fdt, stroffset); + int32_t totalsize; + uint32_t absoffset; + size_t len; + int err; + const char *s, *n;
- return (strnlen(p, len + 1) == len) && (memcmp(p, s, len) == 0); -} + if (!fdt_chk_extra()) { + s = (const char *)fdt + fdt_off_dt_strings(fdt) + stroffset;
-uint32_t fdt_get_max_phandle(const void *fdt) -{ - uint32_t max_phandle = 0; - int offset; + if (lenp) + *lenp = strlen(s); + return s; + } + totalsize = fdt_ro_probe_(fdt); + err = totalsize; + if (totalsize < 0) + goto fail; + + err = -FDT_ERR_BADOFFSET; + absoffset = stroffset + fdt_off_dt_strings(fdt); + if (absoffset >= totalsize) + goto fail; + len = totalsize - absoffset; + + if (fdt_magic(fdt) == FDT_MAGIC) { + if (stroffset < 0) + goto fail; + if (!fdt_chk_version() || fdt_version(fdt) >= 17) { + if (stroffset >= fdt_size_dt_strings(fdt)) + goto fail; + if ((fdt_size_dt_strings(fdt) - stroffset) < len) + len = fdt_size_dt_strings(fdt) - stroffset; + } + } else if (fdt_magic(fdt) == FDT_SW_MAGIC) { + if ((stroffset >= 0) + || (stroffset < -fdt_size_dt_strings(fdt))) + goto fail; + if ((-stroffset) < len) + len = -stroffset; + } else { + err = -FDT_ERR_INTERNAL; + goto fail; + }
- for (offset = fdt_next_node(fdt, -1, NULL);; - offset = fdt_next_node(fdt, offset, NULL)) { - uint32_t phandle; + s = (const char *)fdt + absoffset; + n = memchr(s, '\0', len); + if (!n) { + /* missing terminating NULL */ + err = -FDT_ERR_TRUNCATED; + goto fail; + }
- if (offset == -FDT_ERR_NOTFOUND) - return max_phandle; + if (lenp) + *lenp = n - s; + return s;
- if (offset < 0) - return (uint32_t)-1; +fail: + if (lenp) + *lenp = err; + return NULL; +}
- phandle = fdt_get_phandle(fdt, offset); - if (phandle == (uint32_t)-1) - continue; +const char *fdt_string(const void *fdt, int stroffset) +{ + return fdt_get_string(fdt, stroffset, NULL); +}
- if (phandle > max_phandle) - max_phandle = phandle; - } +static int fdt_string_eq_(const void *fdt, int stroffset, + const char *s, int len) +{ + int slen; + const char *p = fdt_get_string(fdt, stroffset, &slen);
- return 0; + return p && (slen == len) && (memcmp(p, s, len) == 0); }
-int fdt_generate_phandle(const void *fdt, uint32_t *phandle) +int fdt_find_max_phandle(const void *fdt, uint32_t *phandle) { uint32_t max = 0; int offset = -1; @@ -95,6 +135,21 @@ int fdt_generate_phandle(const void *fdt, uint32_t *phandle) max = value; }
+ if (phandle) + *phandle = max; + + return 0; +} + +int fdt_generate_phandle(const void *fdt, uint32_t *phandle) +{ + uint32_t max; + int err; + + err = fdt_find_max_phandle(fdt, &max); + if (err < 0) + return err; + if (max == FDT_MAX_PHANDLE) return -FDT_ERR_NOPHANDLES;
@@ -104,24 +159,48 @@ int fdt_generate_phandle(const void *fdt, uint32_t *phandle) return 0; }
+static const struct fdt_reserve_entry *fdt_mem_rsv(const void *fdt, int n) +{ + int offset = n * sizeof(struct fdt_reserve_entry); + int absoffset = fdt_off_mem_rsvmap(fdt) + offset; + + if (fdt_chk_extra()) { + if (absoffset < fdt_off_mem_rsvmap(fdt)) + return NULL; + if (absoffset > fdt_totalsize(fdt) - + sizeof(struct fdt_reserve_entry)) + return NULL; + } + return fdt_mem_rsv_(fdt, n); +} + int fdt_get_mem_rsv(const void *fdt, int n, uint64_t *address, uint64_t *size) { - FDT_CHECK_HEADER(fdt); - *address = fdt64_to_cpu(fdt_mem_rsv_(fdt, n)->address); - *size = fdt64_to_cpu(fdt_mem_rsv_(fdt, n)->size); + const struct fdt_reserve_entry *re; + + FDT_RO_PROBE(fdt); + re = fdt_mem_rsv(fdt, n); + if (fdt_chk_extra() && !re) + return -FDT_ERR_BADOFFSET; + + *address = fdt64_ld(&re->address); + *size = fdt64_ld(&re->size); return 0; }
int fdt_num_mem_rsv(const void *fdt) { - int i = 0; + int i; + const struct fdt_reserve_entry *re;
- while (fdt64_to_cpu(fdt_mem_rsv_(fdt, i)->size) != 0) - i++; - return i; + for (i = 0; (re = fdt_mem_rsv(fdt, i)) != NULL; i++) { + if (fdt64_ld(&re->size) == 0) + return i; + } + return -FDT_ERR_TRUNCATED; }
-static int _nextprop(const void *fdt, int offset) +static int nextprop_(const void *fdt, int offset) { uint32_t tag; int nextoffset; @@ -150,13 +229,13 @@ int fdt_subnode_offset_namelen(const void *fdt, int offset, { int depth;
- FDT_CHECK_HEADER(fdt); + FDT_RO_PROBE(fdt);
for (depth = 0; (offset >= 0) && (depth >= 0); offset = fdt_next_node(fdt, offset, &depth)) if ((depth == 1) - && _fdt_nodename_eq(fdt, offset, name, namelen)) + && fdt_nodename_eq_(fdt, offset, name, namelen)) return offset;
if (depth < 0) @@ -170,36 +249,17 @@ int fdt_subnode_offset(const void *fdt, int parentoffset, return fdt_subnode_offset_namelen(fdt, parentoffset, name, strlen(name)); }
-/* - * Find the next of path separator, note we need to search for both '/' and ':' - * and then take the first one so that we do the right thing for e.g. - * "foo/bar:option" and "bar:option/otheroption", both of which happen, so - * first searching for either ':' or '/' does not work. - */ -static const char *fdt_path_next_separator(const char *path, int len) -{ - const void *sep1 = memchr(path, '/', len); - const void *sep2 = memchr(path, ':', len); - - if (sep1 && sep2) - return (sep1 < sep2) ? sep1 : sep2; - else if (sep1) - return sep1; - else - return sep2; -} - int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen) { const char *end = path + namelen; const char *p = path; int offset = 0;
/* see if we have an alias */ if (*path != '/') { - const char *q = fdt_path_next_separator(path, namelen); + const char *q = memchr(path, '/', end - p);
if (!q) q = end; @@ -212,17 +272,16 @@ int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen) p = q; }
- while (*p && (p < end)) { + while (p < end) { const char *q;
- while (*p == '/') + while (*p == '/') { p++; - - if (*p == '\0' || *p == ':') - return offset; - - q = fdt_path_next_separator(p, end - p); - if (!q) + if (p == end) + return offset; + } + q = memchr(p, '/', end - p); + if (! q) q = end;
offset = fdt_subnode_offset_namelen(fdt, offset, p, q-p); @@ -243,16 +302,35 @@ int fdt_path_offset(const void *fdt, const char *path) const char *fdt_get_name(const void *fdt, int nodeoffset, int *len) { const struct fdt_node_header *nh = fdt_offset_ptr_(fdt, nodeoffset); + const char *nameptr; int err;
- if (((err = fdt_check_header(fdt)) != 0) - || ((err = fdt_check_node_offset_(fdt, nodeoffset)) < 0)) + if (fdt_chk_extra() && + (((err = fdt_ro_probe_(fdt)) < 0) + || ((err = fdt_check_node_offset_(fdt, nodeoffset)) < 0))) + goto fail; + + nameptr = nh->name; + + if (fdt_chk_version() && fdt_version(fdt) < 0x10) { + /* + * For old FDT versions, match the naming conventions of V16: + * give only the leaf name (after all /). The actual tree + * contents are loosely checked. + */ + const char *leaf; + leaf = strrchr(nameptr, '/'); + if (leaf == NULL) { + err = -FDT_ERR_BADSTRUCTURE; goto fail; + } + nameptr = leaf+1; + }
if (len) - *len = strlen(nh->name); + *len = strlen(nameptr);
- return nh->name; + return nameptr;
fail: if (len) @@ -267,7 +345,7 @@ int fdt_first_property_offset(const void *fdt, int nodeoffset) if ((offset = fdt_check_node_offset_(fdt, nodeoffset)) < 0) return offset;
- return _nextprop(fdt, offset); + return nextprop_(fdt, offset); }
int fdt_next_property_offset(const void *fdt, int offset) @@ -275,17 +353,17 @@ int fdt_next_property_offset(const void *fdt, int offset) if ((offset = fdt_check_prop_offset_(fdt, offset)) < 0) return offset;
-const struct fdt_property *fdt_get_property_by_offset(const void *fdt, - int offset, - int *lenp) +static const struct fdt_property *fdt_get_property_by_offset_(const void *fdt, + int offset, + int *lenp) { int err; const struct fdt_property *prop;
- if ((err = fdt_check_prop_offset_(fdt, offset)) < 0) { + if (fdt_chk_basic() && (err = fdt_check_prop_offset_(fdt, offset)) < 0) { if (lenp) *lenp = err; return NULL; @@ -294,28 +372,50 @@ const struct fdt_property *fdt_get_property_by_offset(const void *fdt, prop = fdt_offset_ptr_(fdt, offset);
if (lenp) - *lenp = fdt32_to_cpu(prop->len); + *lenp = fdt32_ld(&prop->len);
return prop; }
-const struct fdt_property *fdt_get_property_namelen(const void *fdt, - int offset, - const char *name, - int namelen, int *lenp) +const struct fdt_property *fdt_get_property_by_offset(const void *fdt, + int offset, + int *lenp) +{ + /* Prior to version 16, properties may need realignment + * and this API does not work. fdt_getprop_*() will, however. */ + + if (fdt_chk_version() && fdt_version(fdt) < 0x10) { + if (lenp) + *lenp = -FDT_ERR_BADVERSION; + return NULL; + } + + return fdt_get_property_by_offset_(fdt, offset, lenp); +} + +static const struct fdt_property *fdt_get_property_namelen_(const void *fdt, + int offset, + const char *name, + int namelen, + int *lenp, + int *poffset) { for (offset = fdt_first_property_offset(fdt, offset); (offset >= 0); (offset = fdt_next_property_offset(fdt, offset))) { const struct fdt_property *prop;
- if (!(prop = fdt_get_property_by_offset(fdt, offset, lenp))) { + prop = fdt_get_property_by_offset_(fdt, offset, lenp); + if (fdt_chk_extra() && !prop) { offset = -FDT_ERR_INTERNAL; break; } - if (_fdt_string_eq(fdt, fdt32_to_cpu(prop->nameoff), - name, namelen)) + if (fdt_string_eq_(fdt, fdt32_ld(&prop->nameoff), + name, namelen)) { + if (poffset) + *poffset = offset; return prop; + } }
if (lenp) @@ -323,6 +423,25 @@ const struct fdt_property *fdt_get_property_namelen(const void *fdt, return NULL; }
+ +const struct fdt_property *fdt_get_property_namelen(const void *fdt, + int offset, + const char *name, + int namelen, int *lenp) +{ + /* Prior to version 16, properties may need realignment + * and this API does not work. fdt_getprop_*() will, however. */ + if (fdt_chk_version() && fdt_version(fdt) < 0x10) { + if (lenp) + *lenp = -FDT_ERR_BADVERSION; + return NULL; + } + + return fdt_get_property_namelen_(fdt, offset, name, namelen, lenp, + NULL); +} + + const struct fdt_property *fdt_get_property(const void *fdt, int nodeoffset, const char *name, int *lenp) @@ -334,12 +453,18 @@ const struct fdt_property *fdt_get_property(const void *fdt, const void *fdt_getprop_namelen(const void *fdt, int nodeoffset, const char *name, int namelen, int *lenp) { + int poffset; const struct fdt_property *prop;
- prop = fdt_get_property_namelen(fdt, nodeoffset, name, namelen, lenp); + prop = fdt_get_property_namelen_(fdt, nodeoffset, name, namelen, lenp, + &poffset); if (!prop) return NULL;
+ /* Handle realignment */ + if (fdt_chk_version() && fdt_version(fdt) < 0x10 && + (poffset + sizeof(*prop)) % 8 && fdt32_ld(&prop->len) >= 8) + return prop->data + 4; return prop->data; }
@@ -348,11 +473,31 @@ const void *fdt_getprop_by_offset(const void *fdt, int offset, { const struct fdt_property *prop;
- prop = fdt_get_property_by_offset(fdt, offset, lenp); + prop = fdt_get_property_by_offset_(fdt, offset, lenp); if (!prop) return NULL; - if (namep) - *namep = fdt_string(fdt, fdt32_to_cpu(prop->nameoff)); + if (namep) { + const char *name; + int namelen; + + if (fdt_chk_extra()) { + name = fdt_get_string(fdt, fdt32_ld(&prop->nameoff), + &namelen); + if (!name) { + if (lenp) + *lenp = namelen; + return NULL; + } + *namep = name; + } else { + *namep = fdt_string(fdt, fdt32_ld(&prop->nameoff)); + } + } + + /* Handle realignment */ + if (fdt_chk_version() && fdt_version(fdt) < 0x10 && + (offset + sizeof(*prop)) % 8 && fdt32_ld(&prop->len) >= 8) + return prop->data + 4; return prop->data; }
@@ -376,7 +521,7 @@ uint32_t fdt_get_phandle(const void *fdt, int nodeoffset) return 0; }
- return fdt32_to_cpu(*php); + return fdt32_ld(php); }
const char *fdt_get_alias_namelen(const void *fdt, @@ -402,7 +547,7 @@ int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen) int offset, depth, namelen; const char *name;
if (buflen < 2) return -FDT_ERR_NOSPACE; @@ -454,7 +599,7 @@ int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, int offset, depth; int supernodeoffset = -FDT_ERR_INTERNAL;
if (supernodedepth < 0) return -FDT_ERR_NOTFOUND; @@ -476,10 +621,12 @@ int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, } }
- if ((offset == -FDT_ERR_NOTFOUND) || (offset >= 0)) - return -FDT_ERR_BADOFFSET; - else if (offset == -FDT_ERR_BADOFFSET) - return -FDT_ERR_BADSTRUCTURE; + if (fdt_chk_extra()) { + if ((offset == -FDT_ERR_NOTFOUND) || (offset >= 0)) + return -FDT_ERR_BADOFFSET; + else if (offset == -FDT_ERR_BADOFFSET) + return -FDT_ERR_BADSTRUCTURE; + }
return offset; /* error from fdt_next_node() */ } @@ -491,7 +638,7 @@ int fdt_node_depth(const void *fdt, int nodeoffset)
err = fdt_supernode_atdepth_offset(fdt, nodeoffset, 0, &nodedepth); if (err) - return (err < 0) ? err : -FDT_ERR_INTERNAL; + return (!fdt_chk_extra() || err < 0) ? err : -FDT_ERR_INTERNAL; return nodedepth; }
@@ -513,7 +660,7 @@ int fdt_node_offset_by_prop_value(const void *fdt, int startoffset, const void *val; int len;
/* FIXME: The algorithm here is pretty horrible: we scan each * property of a node in fdt_getprop(), then if that didn't @@ -539,7 +686,7 @@ int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle) if ((phandle == 0) || (phandle == -1)) return -FDT_ERR_BADPHANDLE;
/* FIXME: The algorithm here is pretty horrible: we * potentially scan each property of a node in @@ -692,7 +839,7 @@ int fdt_node_offset_by_compatible(const void *fdt, int startoffset, { int offset, err;
/* FIXME: The algorithm here is pretty horrible: we scan each * property of a node in fdt_node_check_compatible(), then if @@ -711,3 +858,68 @@ int fdt_node_offset_by_compatible(const void *fdt, int startoffset,
return offset; /* error from fdt_next_node() */ } + +#if !defined(CHECK_LEVEL) || CHECK_LEVEL > 0 +int fdt_check_full(const void *fdt, size_t bufsize) +{ + int err; + int num_memrsv; + int offset, nextoffset = 0; + uint32_t tag; + unsigned depth = 0; + const void *prop; + const char *propname; + + if (bufsize < FDT_V1_SIZE) + return -FDT_ERR_TRUNCATED; + err = fdt_check_header(fdt); + if (err != 0) + return err; + if (bufsize < fdt_totalsize(fdt)) + return -FDT_ERR_TRUNCATED; + + num_memrsv = fdt_num_mem_rsv(fdt); + if (num_memrsv < 0) + return num_memrsv; + + while (1) { + offset = nextoffset; + tag = fdt_next_tag(fdt, offset, &nextoffset); + + if (nextoffset < 0) + return nextoffset; + + switch (tag) { + case FDT_NOP: + break; + + case FDT_END: + if (depth != 0) + return -FDT_ERR_BADSTRUCTURE; + return 0; + + case FDT_BEGIN_NODE: + depth++; + if (depth > INT_MAX) + return -FDT_ERR_BADSTRUCTURE; + break; + + case FDT_END_NODE: + if (depth == 0) + return -FDT_ERR_BADSTRUCTURE; + depth--; + break; + + case FDT_PROP: + prop = fdt_getprop_by_offset(fdt, offset, &propname, + &err); + if (!prop) + return err; + break; + + default: + return -FDT_ERR_INTERNAL; + } + } +} +#endif diff --git a/scripts/dtc/libfdt/Makefile.libfdt b/scripts/dtc/libfdt/Makefile.libfdt index 098b3f36e6..e54639738c 100644 --- a/scripts/dtc/libfdt/Makefile.libfdt +++ b/scripts/dtc/libfdt/Makefile.libfdt @@ -1,3 +1,4 @@ +# SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) # Makefile.libfdt # # This is not a complete Makefile of itself. Instead, it is designed to @@ -9,3 +10,9 @@ LIBFDT_VERSION = version.lds LIBFDT_SRCS = fdt.c fdt_ro.c fdt_wip.c fdt_sw.c fdt_rw.c fdt_strerror.c fdt_empty_tree.c \ fdt_addresses.c fdt_overlay.c LIBFDT_OBJS = $(LIBFDT_SRCS:%.c=%.o) +LIBFDT_LIB = libfdt-$(DTC_VERSION).$(SHAREDLIB_EXT) + +libfdt_clean: + @$(VECHO) CLEAN "(libfdt)" + rm -f $(STD_CLEANFILES:%=$(LIBFDT_dir)/%) + rm -f $(LIBFDT_dir)/$(LIBFDT_soname) diff --git a/scripts/dtc/libfdt/fdt.c b/scripts/dtc/libfdt/fdt.c index 7855a17877..8e4cce3b9b 100644 --- a/scripts/dtc/libfdt/fdt.c +++ b/scripts/dtc/libfdt/fdt.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /* * libfdt - Flat Device Tree manipulation * Copyright (C) 2006 David Gibson, IBM Corporation. - * - * libfdt is dual licensed: you can use it either under the terms of - * the GPL, or the BSD license, at your option. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this library; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Alternatively, - * - * b) Redistribution and use in source and binary forms, with or - * without modification, are permitted provided that the following - * conditions are met: - * - * 1. Redistributions of source code must retain the above - * copyright notice, this list of conditions and the following - * disclaimer. - * 2. Redistributions in binary form must reproduce the above - * copyright notice, this list of conditions and the following - * disclaimer in the documentation and/or other materials - * provided with the distribution. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND - * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, - * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF - * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR - * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT - * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR - * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, - * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include "libfdt_env.h"
@@ -55,14 +10,24 @@
-int fdt_check_header(const void *fdt) +/* + * Minimal sanity check for a read-only tree. fdt_ro_probe_() checks + * that the given buffer contains what appears to be a flattened + * device tree with sane information in its header. + */ +int32_t fdt_ro_probe_(const void *fdt) { + uint32_t totalsize = fdt_totalsize(fdt); + if (fdt_magic(fdt) == FDT_MAGIC) { /* Complete tree */ - if (fdt_version(fdt) < FDT_FIRST_SUPPORTED_VERSION) - return -FDT_ERR_BADVERSION; - if (fdt_last_comp_version(fdt) > FDT_LAST_SUPPORTED_VERSION) - return -FDT_ERR_BADVERSION; + if (fdt_chk_version()) { + if (fdt_version(fdt) < FDT_FIRST_SUPPORTED_VERSION) + return -FDT_ERR_BADVERSION; + if (fdt_last_comp_version(fdt) > + FDT_LAST_SUPPORTED_VERSION) + return -FDT_ERR_BADVERSION; + } } else if (fdt_magic(fdt) == FDT_SW_MAGIC) { /* Unfinished sequential-write blob */ if (fdt_size_dt_struct(fdt) == 0) @@ -71,6 +36,96 @@ int fdt_check_header(const void *fdt) return -FDT_ERR_BADMAGIC; }
+ if (totalsize < INT32_MAX) + return totalsize; + else + return -FDT_ERR_TRUNCATED; +} + +static int check_off_(uint32_t hdrsize, uint32_t totalsize, uint32_t off) +{ + return (off >= hdrsize) && (off <= totalsize); +} + +static int check_block_(uint32_t hdrsize, uint32_t totalsize, + uint32_t base, uint32_t size) +{ + if (!check_off_(hdrsize, totalsize, base)) + return 0; /* block start out of bounds */ + if ((base + size) < base) + return 0; /* overflow */ + if (!check_off_(hdrsize, totalsize, base + size)) + return 0; /* block end out of bounds */ + return 1; +} + +size_t fdt_header_size_(uint32_t version) +{ + if (version <= 1) + return FDT_V1_SIZE; + else if (version <= 2) + return FDT_V2_SIZE; + else if (version <= 3) + return FDT_V3_SIZE; + else if (version <= 16) + return FDT_V16_SIZE; + else + return FDT_V17_SIZE; +} + +size_t fdt_header_size(const void *fdt) +{ + return fdt_chk_version() ? fdt_header_size_(fdt_version(fdt)) : + FDT_V17_SIZE; +} + +int fdt_check_header(const void *fdt) +{ + size_t hdrsize; + + if (fdt_magic(fdt) != FDT_MAGIC) + return -FDT_ERR_BADMAGIC; + if (fdt_chk_version()) { + if ((fdt_version(fdt) < FDT_FIRST_SUPPORTED_VERSION) + || (fdt_last_comp_version(fdt) > + FDT_LAST_SUPPORTED_VERSION)) + return -FDT_ERR_BADVERSION; + if (fdt_version(fdt) < fdt_last_comp_version(fdt)) + return -FDT_ERR_BADVERSION; + } + hdrsize = fdt_header_size(fdt); + if (fdt_chk_basic()) { + + if ((fdt_totalsize(fdt) < hdrsize) + || (fdt_totalsize(fdt) > INT_MAX)) + return -FDT_ERR_TRUNCATED; + + /* Bounds check memrsv block */ + if (!check_off_(hdrsize, fdt_totalsize(fdt), + fdt_off_mem_rsvmap(fdt))) + return -FDT_ERR_TRUNCATED; + } + + if (fdt_chk_extra()) { + /* Bounds check structure block */ + if (fdt_chk_version() && fdt_version(fdt) < 17) { + if (!check_off_(hdrsize, fdt_totalsize(fdt), + fdt_off_dt_struct(fdt))) + return -FDT_ERR_TRUNCATED; + } else { + if (!check_block_(hdrsize, fdt_totalsize(fdt), + fdt_off_dt_struct(fdt), + fdt_size_dt_struct(fdt))) + return -FDT_ERR_TRUNCATED; + } + + /* Bounds check strings block */ + if (!check_block_(hdrsize, fdt_totalsize(fdt), + fdt_off_dt_strings(fdt), + fdt_size_dt_strings(fdt))) + return -FDT_ERR_TRUNCATED; + } + return 0; }
@@ -78,12 +133,13 @@ const void *fdt_offset_ptr(const void *fdt, int offset, unsigned int len) { unsigned absoffset = offset + fdt_off_dt_struct(fdt);
- if ((absoffset < offset) - || ((absoffset + len) < absoffset) - || (absoffset + len) > fdt_totalsize(fdt)) - return NULL; + if (fdt_chk_basic()) + if ((absoffset < offset) + || ((absoffset + len) < absoffset) + || (absoffset + len) > fdt_totalsize(fdt)) + return NULL;
- if (fdt_version(fdt) >= 0x11) + if (!fdt_chk_version() || fdt_version(fdt) >= 0x11) if (((offset + len) < offset) || ((offset + len) > fdt_size_dt_struct(fdt))) return NULL; @@ -100,7 +156,7 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset)
*nextoffset = -FDT_ERR_TRUNCATED; tagp = fdt_offset_ptr(fdt, offset, FDT_TAGSIZE); - if (!tagp) + if (fdt_chk_basic() && !tagp) return FDT_END; /* premature end */ tag = fdt32_to_cpu(*tagp); offset += FDT_TAGSIZE; @@ -112,18 +168,19 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset) do { p = fdt_offset_ptr(fdt, offset++, 1); } while (p && (*p != '\0')); - if (!p) + if (fdt_chk_basic() && !p) return FDT_END; /* premature end */ break;
case FDT_PROP: lenp = fdt_offset_ptr(fdt, offset, sizeof(*lenp)); - if (!lenp) + if (fdt_chk_basic() && !lenp) return FDT_END; /* premature end */ /* skip-name offset, length and value */ offset += sizeof(struct fdt_property) - FDT_TAGSIZE + fdt32_to_cpu(*lenp); - if (fdt_version(fdt) < 0x10 && fdt32_to_cpu(*lenp) >= 8 && + if (fdt_chk_version() && + fdt_version(fdt) < 0x10 && fdt32_to_cpu(*lenp) >= 8 && ((offset - fdt32_to_cpu(*lenp)) % 8) != 0) offset += 4; break; @@ -137,7 +194,8 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset) return FDT_END; }
- if (!fdt_offset_ptr(fdt, startoffset, offset - startoffset)) + if (fdt_chk_basic() && + !fdt_offset_ptr(fdt, startoffset, offset - startoffset)) return FDT_END; /* premature end */
*nextoffset = FDT_TAGALIGN(offset); @@ -244,7 +302,7 @@ const char *fdt_find_string_(const char *strtab, int tabsize, const char *s)
int fdt_move(const void *fdt, void *buf, int bufsize) { - FDT_CHECK_HEADER(fdt); + FDT_RO_PROBE(fdt);
if (fdt_totalsize(fdt) > bufsize) return -FDT_ERR_NOSPACE; diff --git a/scripts/dtc/libfdt/fdt.h b/scripts/dtc/libfdt/fdt.h index 74961f9026..f2e68807f2 100644 --- a/scripts/dtc/libfdt/fdt.h +++ b/scripts/dtc/libfdt/fdt.h @@ -1,55 +1,10 @@ +/* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */ #ifndef FDT_H #define FDT_H /* * libfdt - Flat Device Tree manipulation * Copyright (C) 2006 David Gibson, IBM Corporation. * Copyright 2012 Kim Phillips, Freescale Semiconductor. - * - * libfdt is dual licensed: you can use it either under the terms of - * the GPL, or the BSD license, at your option. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this library; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Alternatively, - * - * b) Redistribution and use in source and binary forms, with or - * without modification, are permitted provided that the following - * conditions are met: - * - * 1. Redistributions of source code must retain the above - * copyright notice, this list of conditions and the following - * disclaimer. - * 2. Redistributions in binary form must reproduce the above - * copyright notice, this list of conditions and the following - * disclaimer in the documentation and/or other materials - * provided with the distribution. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND - * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, - * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF - * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR - * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT - * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR - * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, - * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
#ifndef __ASSEMBLY__ diff --git a/scripts/dtc/libfdt/fdt_addresses.c b/scripts/dtc/libfdt/fdt_addresses.c index 788c143113..9a82cd0ba2 100644 --- a/scripts/dtc/libfdt/fdt_addresses.c +++ b/scripts/dtc/libfdt/fdt_addresses.c @@ -1,53 +1,8 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /* * libfdt - Flat Device Tree manipulation * Copyright (C) 2014 David Gibson david@gibson.dropbear.id.au * Copyright (C) 2018 embedded brains GmbH - * - * libfdt is dual licensed: you can use it either under the terms of - * the GPL, or the BSD license, at your option. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this library; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Alternatively, - * - * b) Redistribution and use in source and binary forms, with or - * without modification, are permitted provided that the following - * conditions are met: - * - * 1. Redistributions of source code must retain the above - * copyright notice, this list of conditions and the following - * disclaimer. - * 2. Redistributions in binary form must reproduce the above - * copyright notice, this list of conditions and the following - * disclaimer in the documentation and/or other materials - * provided with the distribution. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND - * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, - * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF - * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR - * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT - * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR - * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, - * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include "libfdt_env.h"
@@ -97,3 +52,50 @@ int fdt_size_cells(const void *fdt, int nodeoffset) return 1; return val; } + +/* This function assumes that [address|size]_cells is 1 or 2 */ +int fdt_appendprop_addrrange(void *fdt, int parent, int nodeoffset, + const char *name, uint64_t addr, uint64_t size) +{ + int addr_cells, size_cells, ret; + uint8_t data[sizeof(fdt64_t) * 2], *prop; + + ret = fdt_address_cells(fdt, parent); + if (ret < 0) + return ret; + addr_cells = ret; + + ret = fdt_size_cells(fdt, parent); + if (ret < 0) + return ret; + size_cells = ret; + + /* check validity of address */ + prop = data; + if (addr_cells == 1) { + if ((addr > UINT32_MAX) || ((UINT32_MAX + 1 - addr) < size)) + return -FDT_ERR_BADVALUE; + + fdt32_st(prop, (uint32_t)addr); + } else if (addr_cells == 2) { + fdt64_st(prop, addr); + } else { + return -FDT_ERR_BADNCELLS; + } + + /* check validity of size */ + prop += addr_cells * sizeof(fdt32_t); + if (size_cells == 1) { + if (size > UINT32_MAX) + return -FDT_ERR_BADVALUE; + + fdt32_st(prop, (uint32_t)size); + } else if (size_cells == 2) { + fdt64_st(prop, size); + } else { + return -FDT_ERR_BADNCELLS; + } + + return fdt_appendprop(fdt, nodeoffset, name, data, + (addr_cells + size_cells) * sizeof(fdt32_t)); +} diff --git a/scripts/dtc/libfdt/fdt_empty_tree.c b/scripts/dtc/libfdt/fdt_empty_tree.c index f2ae9b77c2..49d54d44b8 100644 --- a/scripts/dtc/libfdt/fdt_empty_tree.c +++ b/scripts/dtc/libfdt/fdt_empty_tree.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /* * libfdt - Flat Device Tree manipulation * Copyright (C) 2012 David Gibson, IBM Corporation. - * - * libfdt is dual licensed: you can use it either under the terms of - * the GPL, or the BSD license, at your option. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this library; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Alternatively, - * - * b) Redistribution and use in source and binary forms, with or - * without modification, are permitted provided that the following - * conditions are met: - * - * 1. Redistributions of source code must retain the above - * copyright notice, this list of conditions and the following - * disclaimer. - * 2. Redistributions in binary form must reproduce the above - * copyright notice, this list of conditions and the following - * disclaimer in the documentation and/or other materials - * provided with the distribution. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND - * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, - * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF - * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR - * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT - * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR - * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, - * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include "libfdt_env.h"
diff --git a/scripts/dtc/libfdt/fdt_overlay.c b/scripts/dtc/libfdt/fdt_overlay.c index bf75388ec9..be71873366 100644 --- a/scripts/dtc/libfdt/fdt_overlay.c +++ b/scripts/dtc/libfdt/fdt_overlay.c @@ -1,53 +1,8 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /* * libfdt - Flat Device Tree manipulation * Copyright (C) 2016 Free Electrons * Copyright (C) 2016 NextThing Co. - * - * libfdt is dual licensed: you can use it either under the terms of - * the GPL, or the BSD license, at your option. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this library; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Alternatively, - * - * b) Redistribution and use in source and binary forms, with or - * without modification, are permitted provided that the following - * conditions are met: - * - * 1. Redistributions of source code must retain the above - * copyright notice, this list of conditions and the following - * disclaimer. - * 2. Redistributions in binary form must reproduce the above - * copyright notice, this list of conditions and the following - * disclaimer in the documentation and/or other materials - * provided with the distribution. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND - * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, - * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF - * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR - * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT - * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR - * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, - * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include "libfdt_env.h"
@@ -93,11 +48,11 @@ static uint32_t overlay_get_target_phandle(const void *fdto, int fragment) * @pathp: pointer which receives the path of the target (or NULL) * * overlay_get_target() retrieves the target offset in the base - * device tree of a fragment, no matter how the actual targetting is + * device tree of a fragment, no matter how the actual targeting is * done (through a phandle or a path) * * returns: - * the targetted node offset in the base device tree + * the targeted node offset in the base device tree * Negative error code on error */ static int overlay_get_target(const void *fdt, const void *fdto, @@ -697,7 +652,7 @@ static int get_path_len(const void *fdt, int nodeoffset) int len = 0, namelen; const char *name;
for (;;) { name = fdt_get_name(fdt, nodeoffset, &namelen); @@ -778,26 +733,36 @@ static int overlay_symbol_update(void *fdt, void *fdto) /* keep end marker to avoid strlen() */ e = path + path_len;
- /* format: /<fragment-name>/__overlay__/<relative-subnode-path> */ - if (*path != '/') return -FDT_ERR_BADVALUE;
/* get fragment name first */ s = strchr(path + 1, '/'); - if (!s) - return -FDT_ERR_BADOVERLAY; + if (!s) { + /* Symbol refers to something that won't end + * up in the target tree */ + continue; + }
frag_name = path + 1; frag_name_len = s - path - 1;
/* verify format; safe since "s" lies in \0 terminated prop */ len = sizeof("/__overlay__/") - 1; - if ((e - s) < len || memcmp(s, "/__overlay__/", len)) - return -FDT_ERR_BADOVERLAY; - - rel_path = s + len; - rel_path_len = e - rel_path; + if ((e - s) > len && (memcmp(s, "/__overlay__/", len) == 0)) { + /* /<fragment-name>/__overlay__/<relative-subnode-path> */ + rel_path = s + len; + rel_path_len = e - rel_path; + } else if ((e - s) == len + && (memcmp(s, "/__overlay__", len - 1) == 0)) { + /* /<fragment-name>/__overlay__ */ + rel_path = ""; + rel_path_len = 0; + } else { + /* Symbol refers to something that won't end + * up in the target tree */ + continue; + }
/* find the fragment index in which the symbol lies */ ret = fdt_subnode_offset_namelen(fdto, 0, frag_name, @@ -863,11 +828,15 @@ static int overlay_symbol_update(void *fdt, void *fdto)
int fdt_overlay_apply(void *fdt, void *fdto) { - uint32_t delta = fdt_get_max_phandle(fdt); + uint32_t delta; int ret;
- FDT_CHECK_HEADER(fdt); - FDT_CHECK_HEADER(fdto); + FDT_RO_PROBE(fdt); + FDT_RO_PROBE(fdto); + + ret = fdt_find_max_phandle(fdt, &delta); + if (ret) + goto err;
ret = overlay_adjust_local_phandles(fdto, delta); if (ret) diff --git a/scripts/dtc/libfdt/fdt_ro.c b/scripts/dtc/libfdt/fdt_ro.c index dc499884e4..e398815485 100644 --- a/scripts/dtc/libfdt/fdt_ro.c +++ b/scripts/dtc/libfdt/fdt_ro.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /* * libfdt - Flat Device Tree manipulation * Copyright (C) 2006 David Gibson, IBM Corporation. - * - * libfdt is dual licensed: you can use it either under the terms of - * the GPL, or the BSD license, at your option. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this library; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Alternatively, - * - * b) Redistribution and use in source and binary forms, with or - * without modification, are permitted provided that the following - * conditions are met: - * - * 1. Redistributions of source code must retain the above - * copyright notice, this list of conditions and the following - * disclaimer. - * 2. Redistributions in binary form must reproduce the above - * copyright notice, this list of conditions and the following - * disclaimer in the documentation and/or other materials - * provided with the distribution. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND - * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, - * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF - * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR - * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT - * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR - * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, - * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include "libfdt_env.h"
@@ -61,7 +16,7 @@ static int fdt_nodename_eq_(const void *fdt, int offset, int olen; const char *p = fdt_get_name(fdt, offset, &olen);
- if (!p || olen < len) + if (!p || (fdt_chk_extra() && olen < len)) /* short match */ return 0;
@@ -76,46 +31,85 @@ static int fdt_nodename_eq_(const void *fdt, int offset, return 0; }
-const char *fdt_string(const void *fdt, int stroffset) -{ - return (const char *)fdt + fdt_off_dt_strings(fdt) + stroffset; -} - -static int fdt_string_eq_(const void *fdt, int stroffset, - const char *s, int len) +const char *fdt_get_string(const void *fdt, int stroffset, int *lenp) { - const char *p = fdt_string(fdt, stroffset); + int32_t totalsize; + uint32_t absoffset; + size_t len; + int err; + const char *s, *n;
- return (strlen(p) == len) && (memcmp(p, s, len) == 0); -} + if (!fdt_chk_extra()) { + s = (const char *)fdt + fdt_off_dt_strings(fdt) + stroffset;
-int fdt_generate_phandle(const void *fdt, uint32_t *phandle) +int fdt_find_max_phandle(const void *fdt, uint32_t *phandle) { uint32_t max = 0; int offset = -1; @@ -137,6 +131,21 @@ int fdt_generate_phandle(const void *fdt, uint32_t *phandle) max = value; }
@@ -146,21 +155,45 @@ int fdt_generate_phandle(const void *fdt, uint32_t *phandle) return 0; }
static int nextprop_(const void *fdt, int offset) @@ -192,7 +225,7 @@ int fdt_subnode_offset_namelen(const void *fdt, int offset, { int depth;
for (depth = 0; (offset >= 0) && (depth >= 0); @@ -218,7 +251,7 @@ int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen) const char *p = path; int offset = 0;
/* see if we have an alias */ if (*path != '/') { @@ -268,13 +301,14 @@ const char *fdt_get_name(const void *fdt, int nodeoffset, int *len) const char *nameptr; int err;
- if (((err = fdt_check_header(fdt)) != 0) - || ((err = fdt_check_node_offset_(fdt, nodeoffset)) < 0)) - goto fail; + if (fdt_chk_extra() && + (((err = fdt_ro_probe_(fdt)) < 0) + || ((err = fdt_check_node_offset_(fdt, nodeoffset)) < 0))) + goto fail;
nameptr = nh->name;
- if (fdt_version(fdt) < 0x10) { + if (fdt_chk_version() && fdt_version(fdt) < 0x10) { /* * For old FDT versions, match the naming conventions of V16: * give only the leaf name (after all /). The actual tree @@ -325,7 +359,7 @@ static const struct fdt_property *fdt_get_property_by_offset_(const void *fdt, int err; const struct fdt_property *prop;
- if ((err = fdt_check_prop_offset_(fdt, offset)) < 0) { + if (fdt_chk_basic() && (err = fdt_check_prop_offset_(fdt, offset)) < 0) { if (lenp) *lenp = err; return NULL; @@ -334,7 +368,7 @@ static const struct fdt_property *fdt_get_property_by_offset_(const void *fdt, prop = fdt_offset_ptr_(fdt, offset);
return prop; } @@ -346,7 +380,7 @@ const struct fdt_property *fdt_get_property_by_offset(const void *fdt, /* Prior to version 16, properties may need realignment * and this API does not work. fdt_getprop_*() will, however. */
- if (fdt_version(fdt) < 0x10) { + if (fdt_chk_version() && fdt_version(fdt) < 0x10) { if (lenp) *lenp = -FDT_ERR_BADVERSION; return NULL; @@ -367,11 +401,12 @@ static const struct fdt_property *fdt_get_property_namelen_(const void *fdt, (offset = fdt_next_property_offset(fdt, offset))) { const struct fdt_property *prop;
- if (!(prop = fdt_get_property_by_offset_(fdt, offset, lenp))) { + prop = fdt_get_property_by_offset_(fdt, offset, lenp); + if (fdt_chk_extra() && !prop) { offset = -FDT_ERR_INTERNAL; break; } - if (fdt_string_eq_(fdt, fdt32_to_cpu(prop->nameoff), + if (fdt_string_eq_(fdt, fdt32_ld(&prop->nameoff), name, namelen)) { if (poffset) *poffset = offset; @@ -392,7 +427,7 @@ const struct fdt_property *fdt_get_property_namelen(const void *fdt, { /* Prior to version 16, properties may need realignment * and this API does not work. fdt_getprop_*() will, however. */ - if (fdt_version(fdt) < 0x10) { + if (fdt_chk_version() && fdt_version(fdt) < 0x10) { if (lenp) *lenp = -FDT_ERR_BADVERSION; return NULL; @@ -423,8 +458,8 @@ const void *fdt_getprop_namelen(const void *fdt, int nodeoffset, return NULL;
/* Handle realignment */ - if (fdt_version(fdt) < 0x10 && (poffset + sizeof(*prop)) % 8 && - fdt32_to_cpu(prop->len) >= 8) + if (fdt_chk_version() && fdt_version(fdt) < 0x10 && + (poffset + sizeof(*prop)) % 8 && fdt32_ld(&prop->len) >= 8) return prop->data + 4; return prop->data; } @@ -437,12 +472,27 @@ const void *fdt_getprop_by_offset(const void *fdt, int offset, prop = fdt_get_property_by_offset_(fdt, offset, lenp); if (!prop) return NULL; - if (namep) - *namep = fdt_string(fdt, fdt32_to_cpu(prop->nameoff)); + if (namep) { + const char *name; + int namelen; + + if (fdt_chk_extra()) { + name = fdt_get_string(fdt, fdt32_ld(&prop->nameoff), + &namelen); + if (!name) { + if (lenp) + *lenp = namelen; + return NULL; + } + *namep = name; + } else { + *namep = fdt_string(fdt, fdt32_ld(&prop->nameoff)); + } + }
/* Handle realignment */ - if (fdt_version(fdt) < 0x10 && (offset + sizeof(*prop)) % 8 && - fdt32_to_cpu(prop->len) >= 8) + if (fdt_chk_version() && fdt_version(fdt) < 0x10 && + (offset + sizeof(*prop)) % 8 && fdt32_ld(&prop->len) >= 8) return prop->data + 4; return prop->data; } @@ -467,7 +517,7 @@ uint32_t fdt_get_phandle(const void *fdt, int nodeoffset) return 0; }
const char *fdt_get_alias_namelen(const void *fdt, @@ -493,7 +543,7 @@ int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen) int offset, depth, namelen; const char *name;
if (buflen < 2) return -FDT_ERR_NOSPACE; @@ -545,7 +595,7 @@ int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, int offset, depth; int supernodeoffset = -FDT_ERR_INTERNAL;
if (supernodedepth < 0) return -FDT_ERR_NOTFOUND; @@ -567,10 +617,12 @@ int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, } }
return offset; /* error from fdt_next_node() */ } @@ -582,7 +634,7 @@ int fdt_node_depth(const void *fdt, int nodeoffset)
@@ -604,7 +656,7 @@ int fdt_node_offset_by_prop_value(const void *fdt, int startoffset, const void *val; int len;
/* FIXME: The algorithm here is pretty horrible: we scan each * property of a node in fdt_getprop(), then if that didn't @@ -630,7 +682,7 @@ int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle) if ((phandle == 0) || (phandle == -1)) return -FDT_ERR_BADPHANDLE;
/* FIXME: The algorithm here is pretty horrible: we * potentially scan each property of a node in @@ -783,7 +835,7 @@ int fdt_node_offset_by_compatible(const void *fdt, int startoffset, { int offset, err;
/* FIXME: The algorithm here is pretty horrible: we scan each * property of a node in fdt_node_check_compatible(), then if @@ -802,3 +854,68 @@ int fdt_node_offset_by_compatible(const void *fdt, int startoffset,
return offset; /* error from fdt_next_node() */ } + +#if !defined(FDT_ASSUME_MASK) || FDT_ASSUME_MASK != 0xff +int fdt_check_full(const void *fdt, size_t bufsize) +{ + int err; + int num_memrsv; + int offset, nextoffset = 0; + uint32_t tag; + unsigned depth = 0; + const void *prop; + const char *propname; + + if (bufsize < FDT_V1_SIZE) + return -FDT_ERR_TRUNCATED; + err = fdt_check_header(fdt); + if (err != 0) + return err; + if (bufsize < fdt_totalsize(fdt)) + return -FDT_ERR_TRUNCATED; + + num_memrsv = fdt_num_mem_rsv(fdt); + if (num_memrsv < 0) + return num_memrsv; + + while (1) { + offset = nextoffset; + tag = fdt_next_tag(fdt, offset, &nextoffset); + + if (nextoffset < 0) + return nextoffset; + + switch (tag) { + case FDT_NOP: + break; + + case FDT_END: + if (depth != 0) + return -FDT_ERR_BADSTRUCTURE; + return 0; + + case FDT_BEGIN_NODE: + depth++; + if (depth > INT_MAX) + return -FDT_ERR_BADSTRUCTURE; + break; + + case FDT_END_NODE: + if (depth == 0) + return -FDT_ERR_BADSTRUCTURE; + depth--; + break; + + case FDT_PROP: + prop = fdt_getprop_by_offset(fdt, offset, &propname, + &err); + if (!prop) + return err; + break; + + default: + return -FDT_ERR_INTERNAL; + } + } +} +#endif diff --git a/scripts/dtc/libfdt/fdt_rw.c b/scripts/dtc/libfdt/fdt_rw.c index 9b829051e4..08e2981a44 100644 --- a/scripts/dtc/libfdt/fdt_rw.c +++ b/scripts/dtc/libfdt/fdt_rw.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /* * libfdt - Flat Device Tree manipulation * Copyright (C) 2006 David Gibson, IBM Corporation. - * - * libfdt is dual licensed: you can use it either under the terms of - * the GPL, or the BSD license, at your option. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this library; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Alternatively, - * - * b) Redistribution and use in source and binary forms, with or - * without modification, are permitted provided that the following - * conditions are met: - * - * 1. Redistributions of source code must retain the above - * copyright notice, this list of conditions and the following - * disclaimer. - * 2. Redistributions in binary form must reproduce the above - * copyright notice, this list of conditions and the following - * disclaimer in the documentation and/or other materials - * provided with the distribution. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND - * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, - * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF - * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR - * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT - * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR - * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, - * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include "libfdt_env.h"
@@ -58,6 +13,8 @@ static int fdt_blocks_misordered_(const void *fdt, int mem_rsv_size, int struct_size) { + if (!fdt_chk_basic()) + return false; return (fdt_off_mem_rsvmap(fdt) < FDT_ALIGN(sizeof(struct fdt_header), 8)) || (fdt_off_dt_struct(fdt) < (fdt_off_mem_rsvmap(fdt) + mem_rsv_size)) @@ -67,25 +24,27 @@ static int fdt_blocks_misordered_(const void *fdt, (fdt_off_dt_strings(fdt) + fdt_size_dt_strings(fdt))); }
-static int fdt_rw_check_header_(void *fdt) +static int fdt_rw_probe_(void *fdt) { - FDT_CHECK_HEADER(fdt); + if (!fdt_chk_basic()) + return 0; + FDT_RO_PROBE(fdt);
- if (fdt_version(fdt) < 17) + if (fdt_chk_version() && fdt_version(fdt) < 17) return -FDT_ERR_BADVERSION; if (fdt_blocks_misordered_(fdt, sizeof(struct fdt_reserve_entry), fdt_size_dt_struct(fdt))) return -FDT_ERR_BADLAYOUT; - if (fdt_version(fdt) > 17) + if (fdt_chk_version() && fdt_version(fdt) > 17) fdt_set_version(fdt, 17);
return 0; }
-#define FDT_RW_CHECK_HEADER(fdt) \ +#define FDT_RW_PROBE(fdt) \ { \ int err_; \ - if ((err_ = fdt_rw_check_header_(fdt)) != 0) \ + if (fdt_chk_extra() && (err_ = fdt_rw_probe_(fdt)) != 0) \ return err_; \ }
@@ -136,6 +95,14 @@ static int fdt_splice_struct_(void *fdt, void *p, return 0; }
+/* Must only be used to roll back in case of error */ +static void fdt_del_last_string_(void *fdt, const char *s) +{ + int newlen = strlen(s) + 1; + + fdt_set_size_dt_strings(fdt, fdt_size_dt_strings(fdt) - newlen); +} + static int fdt_splice_string_(void *fdt, int newlen) { void *p = (char *)fdt @@ -149,7 +116,16 @@ static int fdt_splice_string_(void *fdt, int newlen) return 0; }
-static int fdt_find_add_string_(void *fdt, const char *s) +/** + * fdt_find_add_string_() - Find or allocate a string + * + * @fdt: pointer to the device tree to check/adjust + * @s: string to find/add + * @allocated: Set to 0 if the string was found, 1 if not found and so + * allocated. Ignored if !fdt_chk_basic() + * @return offset of string in the string table (whether found or added) + */ +static int fdt_find_add_string_(void *fdt, const char *s, int *allocated) { char *strtab = (char *)fdt + fdt_off_dt_strings(fdt); const char *p; @@ -157,6 +133,9 @@ static int fdt_find_add_string_(void *fdt, const char *s) int len = strlen(s) + 1; int err;
+ if (fdt_chk_basic()) + *allocated = 0; + p = fdt_find_string_(strtab, fdt_size_dt_strings(fdt), s); if (p) /* found it */ @@ -167,6 +146,9 @@ static int fdt_find_add_string_(void *fdt, const char *s) if (err) return err;
+ if (fdt_chk_basic()) + *allocated = 1; + memcpy(new, s, len); return (new - strtab); } @@ -176,7 +158,7 @@ int fdt_add_mem_rsv(void *fdt, uint64_t address, uint64_t size) struct fdt_reserve_entry *re; int err;
- FDT_RW_CHECK_HEADER(fdt); + FDT_RW_PROBE(fdt);
re = fdt_mem_rsv_w_(fdt, fdt_num_mem_rsv(fdt)); err = fdt_splice_mem_rsv_(fdt, re, 0, 1); @@ -192,7 +174,7 @@ int fdt_del_mem_rsv(void *fdt, int n) { struct fdt_reserve_entry *re = fdt_mem_rsv_w_(fdt, n);
if (n >= fdt_num_mem_rsv(fdt)) return -FDT_ERR_NOTFOUND; @@ -225,11 +207,12 @@ static int fdt_add_property_(void *fdt, int nodeoffset, const char *name, int nextoffset; int namestroff; int err; + int allocated;
if ((nextoffset = fdt_check_node_offset_(fdt, nodeoffset)) < 0) return nextoffset;
- namestroff = fdt_find_add_string_(fdt, name); + namestroff = fdt_find_add_string_(fdt, name, &allocated); if (namestroff < 0) return namestroff;
@@ -237,8 +220,12 @@ static int fdt_add_property_(void *fdt, int nodeoffset, const char *name, proplen = sizeof(**prop) + FDT_TAGALIGN(len);
err = fdt_splice_struct_(fdt, *prop, 0, proplen); - if (err) + if (err) { + /* Delete the string if we failed to add it */ + if (fdt_chk_basic() && allocated) + fdt_del_last_string_(fdt, name); return err; + }
(*prop)->tag = cpu_to_fdt32(FDT_PROP); (*prop)->nameoff = cpu_to_fdt32(namestroff); @@ -252,7 +239,7 @@ int fdt_set_name(void *fdt, int nodeoffset, const char *name) int oldlen, newlen; int err;
namep = (char *)(uintptr_t)fdt_get_name(fdt, nodeoffset, &oldlen); if (!namep) @@ -275,7 +262,7 @@ int fdt_setprop_placeholder(void *fdt, int nodeoffset, const char *name, struct fdt_property *prop; int err;
err = fdt_resize_property_(fdt, nodeoffset, name, len, &prop); if (err == -FDT_ERR_NOTFOUND) @@ -308,7 +295,7 @@ int fdt_appendprop(void *fdt, int nodeoffset, const char *name, struct fdt_property *prop; int err, oldlen, newlen;
prop = fdt_get_property_w(fdt, nodeoffset, name, &oldlen); if (prop) { @@ -334,7 +321,7 @@ int fdt_delprop(void *fdt, int nodeoffset, const char *name) struct fdt_property *prop; int len, proplen;
prop = fdt_get_property_w(fdt, nodeoffset, name, &len); if (!prop) @@ -354,7 +341,7 @@ int fdt_add_subnode_namelen(void *fdt, int parentoffset, uint32_t tag; fdt32_t *endtag;
offset = fdt_subnode_offset_namelen(fdt, parentoffset, name, namelen); if (offset >= 0) @@ -394,7 +381,7 @@ int fdt_del_node(void *fdt, int nodeoffset) { int endoffset;
endoffset = fdt_node_end_offset_(fdt, nodeoffset); if (endoffset < 0) @@ -435,12 +422,12 @@ int fdt_open_into(const void *fdt, void *buf, int bufsize) const char *fdtend = fdtstart + fdt_totalsize(fdt); char *tmp;
mem_rsv_size = (fdt_num_mem_rsv(fdt)+1) * sizeof(struct fdt_reserve_entry);
- if (fdt_version(fdt) >= 17) { + if (!fdt_chk_version() || fdt_version(fdt) >= 17) { struct_size = fdt_size_dt_struct(fdt); } else { struct_size = 0; @@ -494,7 +481,7 @@ int fdt_pack(void *fdt) { int mem_rsv_size;
mem_rsv_size = (fdt_num_mem_rsv(fdt)+1) * sizeof(struct fdt_reserve_entry); diff --git a/scripts/dtc/libfdt/fdt_strerror.c b/scripts/dtc/libfdt/fdt_strerror.c index 9677a1887e..768db66ead 100644 --- a/scripts/dtc/libfdt/fdt_strerror.c +++ b/scripts/dtc/libfdt/fdt_strerror.c @@ -1,51 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /* * libfdt - Flat Device Tree manipulation * Copyright (C) 2006 David Gibson, IBM Corporation. - * - * libfdt is dual licensed: you can use it either under the terms of - * the GPL, or the BSD license, at your option. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this library; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Alternatively, - * - * b) Redistribution and use in source and binary forms, with or - * without modification, are permitted provided that the following - * conditions are met: - * - * 1. Redistributions of source code must retain the above - * copyright notice, this list of conditions and the following - * disclaimer. - * 2. Redistributions in binary form must reproduce the above - * copyright notice, this list of conditions and the following - * disclaimer in the documentation and/or other materials - * provided with the distribution. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND - * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, - * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF - * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR - * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT - * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR - * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include "libfdt_env.h" @@ -82,6 +38,7 @@ static struct fdt_errtabent fdt_errtable[] = { FDT_ERRTABENT(FDT_ERR_BADVALUE), FDT_ERRTABENT(FDT_ERR_BADOVERLAY), FDT_ERRTABENT(FDT_ERR_NOPHANDLES), + FDT_ERRTABENT(FDT_ERR_BADFLAGS), }; #define FDT_ERRTABSIZE (sizeof(fdt_errtable) / sizeof(fdt_errtable[0]))
diff --git a/scripts/dtc/libfdt/fdt_sw.c b/scripts/dtc/libfdt/fdt_sw.c index d8ef748a72..a8c924675a 100644 --- a/scripts/dtc/libfdt/fdt_sw.c +++ b/scripts/dtc/libfdt/fdt_sw.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /* * libfdt - Flat Device Tree manipulation * Copyright (C) 2006 David Gibson, IBM Corporation. - * - * libfdt is dual licensed: you can use it either under the terms of - * the GPL, or the BSD license, at your option. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this library; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Alternatively, - * - * b) Redistribution and use in source and binary forms, with or - * without modification, are permitted provided that the following - * conditions are met: - * - * 1. Redistributions of source code must retain the above - * copyright notice, this list of conditions and the following - * disclaimer. - * 2. Redistributions in binary form must reproduce the above - * copyright notice, this list of conditions and the following - * disclaimer in the documentation and/or other materials - * provided with the distribution. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND - * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, - * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF - * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR - * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT - * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR - * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, - * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include "libfdt_env.h"
@@ -55,21 +10,90 @@
#include "libfdt_internal.h"
-static int fdt_sw_check_header_(void *fdt) +static int fdt_sw_probe_(void *fdt) +{ + if (fdt_chk_basic()) { + if (fdt_magic(fdt) == FDT_MAGIC) + return -FDT_ERR_BADSTATE; + else if (fdt_magic(fdt) != FDT_SW_MAGIC) + return -FDT_ERR_BADMAGIC; + } + + return 0; +} + +#define FDT_SW_PROBE(fdt) \ + { \ + int err; \ + if (fdt_chk_basic() && (err = fdt_sw_probe_(fdt)) != 0) \ + return err; \ + } + +/* 'memrsv' state: Initial state after fdt_create() + * + * Allowed functions: + * fdt_add_reservmap_entry() + * fdt_finish_reservemap() [moves to 'struct' state] + */ +static int fdt_sw_probe_memrsv_(void *fdt) +{ + int err = fdt_sw_probe_(fdt); + if (err) + return err; + + if (fdt_chk_extra() && fdt_off_dt_strings(fdt) != 0) + return -FDT_ERR_BADSTATE; + return 0; +} + +#define FDT_SW_PROBE_MEMRSV(fdt) \ + { \ + int err; \ + if (fdt_chk_extra() && (err = fdt_sw_probe_memrsv_(fdt)) != 0) \ + return err; \ + } + +/* 'struct' state: Enter this state after fdt_finish_reservemap() + * + * Allowed functions: + * fdt_begin_node() + * fdt_end_node() + * fdt_property*() + * fdt_finish() [moves to 'complete' state] + */ +static int fdt_sw_probe_struct_(void *fdt) { - if (fdt_magic(fdt) != FDT_SW_MAGIC) - return -FDT_ERR_BADMAGIC; - /* FIXME: should check more details about the header state */ + int err; + + if (!fdt_chk_extra()) + return 0; + err = fdt_sw_probe_(fdt); + if (err) + return err; + + if (fdt_off_dt_strings(fdt) != fdt_totalsize(fdt)) + return -FDT_ERR_BADSTATE; return 0; }
-#define FDT_SW_CHECK_HEADER(fdt) \ +#define FDT_SW_PROBE_STRUCT(fdt) \ { \ int err; \ - if ((err = fdt_sw_check_header_(fdt)) != 0) \ + if (fdt_chk_extra() && (err = fdt_sw_probe_struct_(fdt)) != 0) \ return err; \ }
+static inline uint32_t sw_flags(void *fdt) +{ + /* assert: (fdt_magic(fdt) == FDT_SW_MAGIC) */ + return fdt_last_comp_version(fdt); +} + +/* 'complete' state: Enter this state after fdt_finish() + * + * Allowed functions: none + */ + static void *fdt_grab_space_(void *fdt, size_t len) { int offset = fdt_size_dt_struct(fdt); @@ -85,38 +109,58 @@ static void *fdt_grab_space_(void *fdt, size_t len) return fdt_offset_ptr_w_(fdt, offset); }
-int fdt_create(void *buf, int bufsize) +int fdt_create_with_flags(void *buf, int bufsize, uint32_t flags) { + const size_t hdrsize = FDT_ALIGN(sizeof(struct fdt_header), + sizeof(struct fdt_reserve_entry)); void *fdt = buf;
- if (bufsize < sizeof(struct fdt_header)) + if (bufsize < hdrsize) return -FDT_ERR_NOSPACE;
+ if (flags & ~FDT_CREATE_FLAGS_ALL) + return -FDT_ERR_BADFLAGS; + memset(buf, 0, bufsize);
+ /* + * magic and last_comp_version keep intermediate state during the fdt + * creation process, which is replaced with the proper FDT format by + * fdt_finish(). + * + * flags should be accessed with sw_flags(). + */ fdt_set_magic(fdt, FDT_SW_MAGIC); fdt_set_version(fdt, FDT_LAST_SUPPORTED_VERSION); - fdt_set_last_comp_version(fdt, FDT_FIRST_SUPPORTED_VERSION); + fdt_set_last_comp_version(fdt, flags); + fdt_set_totalsize(fdt, bufsize);
- fdt_set_off_mem_rsvmap(fdt, FDT_ALIGN(sizeof(struct fdt_header), - sizeof(struct fdt_reserve_entry))); + fdt_set_off_mem_rsvmap(fdt, hdrsize); fdt_set_off_dt_struct(fdt, fdt_off_mem_rsvmap(fdt)); - fdt_set_off_dt_strings(fdt, bufsize); + fdt_set_off_dt_strings(fdt, 0);
return 0; }
+int fdt_create(void *buf, int bufsize) +{ + return fdt_create_with_flags(buf, bufsize, 0); +} + int fdt_resize(void *fdt, void *buf, int bufsize) { size_t headsize, tailsize; char *oldtail, *newtail;
- FDT_SW_CHECK_HEADER(fdt); + FDT_SW_PROBE(fdt);
headsize = fdt_off_dt_struct(fdt) + fdt_size_dt_struct(fdt); tailsize = fdt_size_dt_strings(fdt);
+ if (fdt_chk_extra() && (headsize + tailsize) > fdt_totalsize(fdt)) + return -FDT_ERR_INTERNAL; + if ((headsize + tailsize) > bufsize) return -FDT_ERR_NOSPACE;
@@ -133,8 +177,9 @@ int fdt_resize(void *fdt, void *buf, int bufsize) memmove(buf, fdt, headsize); }
- fdt_set_off_dt_strings(buf, bufsize); fdt_set_totalsize(buf, bufsize); + if (fdt_off_dt_strings(buf)) + fdt_set_off_dt_strings(buf, bufsize);
return 0; } @@ -144,10 +189,7 @@ int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size) struct fdt_reserve_entry *re; int offset;
- FDT_SW_CHECK_HEADER(fdt); - - if (fdt_size_dt_struct(fdt)) - return -FDT_ERR_BADSTATE; + FDT_SW_PROBE_MEMRSV(fdt);
offset = fdt_off_dt_struct(fdt); if ((offset + sizeof(*re)) > fdt_totalsize(fdt)) @@ -164,16 +206,23 @@ int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size)
int fdt_finish_reservemap(void *fdt) { - return fdt_add_reservemap_entry(fdt, 0, 0); + int err = fdt_add_reservemap_entry(fdt, 0, 0); + + if (err) + return err; + + fdt_set_off_dt_strings(fdt, fdt_totalsize(fdt)); + return 0; }
int fdt_begin_node(void *fdt, const char *name) { struct fdt_node_header *nh; - int namelen = strlen(name) + 1; + int namelen;
- FDT_SW_CHECK_HEADER(fdt); + FDT_SW_PROBE_STRUCT(fdt);
+ namelen = strlen(name) + 1; nh = fdt_grab_space_(fdt, sizeof(*nh) + FDT_TAGALIGN(namelen)); if (! nh) return -FDT_ERR_NOSPACE; @@ -187,7 +236,7 @@ int fdt_end_node(void *fdt) { fdt32_t *en;
en = fdt_grab_space_(fdt, FDT_TAGSIZE); if (! en) @@ -197,19 +246,13 @@ int fdt_end_node(void *fdt) return 0; }
-static int fdt_find_add_string_(void *fdt, const char *s) +static int fdt_add_string_(void *fdt, const char *s) { char *strtab = (char *)fdt + fdt_totalsize(fdt); - const char *p; int strtabsize = fdt_size_dt_strings(fdt); int len = strlen(s) + 1; int struct_top, offset;
- p = fdt_find_string_(strtab - strtabsize, strtabsize, s); - if (p) - return p - strtab; - - /* Add it */ offset = -strtabsize - len; struct_top = fdt_off_dt_struct(fdt) + fdt_size_dt_struct(fdt); if (fdt_totalsize(fdt) + offset < struct_top) @@ -220,20 +263,56 @@ static int fdt_find_add_string_(void *fdt, const char *s) return offset; }
+/* Must only be used to roll back in case of error */ +static void fdt_del_last_string_(void *fdt, const char *s) +{ + int strtabsize = fdt_size_dt_strings(fdt); + int len = strlen(s) + 1; + + fdt_set_size_dt_strings(fdt, strtabsize - len); +} + +static int fdt_find_add_string_(void *fdt, const char *s, int *allocated) +{ + char *strtab = (char *)fdt + fdt_totalsize(fdt); + int strtabsize = fdt_size_dt_strings(fdt); + const char *p; + + *allocated = 0; + + p = fdt_find_string_(strtab - strtabsize, strtabsize, s); + if (p) + return p - strtab; + + *allocated = 1; + + return fdt_add_string_(fdt, s); +} + int fdt_property_placeholder(void *fdt, const char *name, int len, void **valp) { struct fdt_property *prop; int nameoff; + int allocated;
- nameoff = fdt_find_add_string_(fdt, name); + /* String de-duplication can be slow, _NO_NAME_DEDUP skips it */ + if (sw_flags(fdt) & FDT_CREATE_FLAG_NO_NAME_DEDUP) { + allocated = 1; + nameoff = fdt_add_string_(fdt, name); + } else { + nameoff = fdt_find_add_string_(fdt, name, &allocated); + } if (nameoff == 0) return -FDT_ERR_NOSPACE;
prop = fdt_grab_space_(fdt, sizeof(*prop) + FDT_TAGALIGN(len)); - if (! prop) + if (! prop) { + if (allocated) + fdt_del_last_string_(fdt, name); return -FDT_ERR_NOSPACE; + }
prop->tag = cpu_to_fdt32(FDT_PROP); prop->nameoff = cpu_to_fdt32(nameoff); @@ -262,7 +341,7 @@ int fdt_finish(void *fdt) uint32_t tag; int offset, nextoffset;
/* Add terminator */ end = fdt_grab_space_(fdt, sizeof(*end)); @@ -295,6 +374,10 @@ int fdt_finish(void *fdt)
/* Finally, adjust the header */ fdt_set_totalsize(fdt, newstroffset + fdt_size_dt_strings(fdt)); + + /* And fix up fields that were keeping intermediate state. */ + fdt_set_last_comp_version(fdt, FDT_FIRST_SUPPORTED_VERSION); fdt_set_magic(fdt, FDT_MAGIC); + return 0; } diff --git a/scripts/dtc/libfdt/fdt_wip.c b/scripts/dtc/libfdt/fdt_wip.c index 534c1cbbb2..f64139e0b3 100644 --- a/scripts/dtc/libfdt/fdt_wip.c +++ b/scripts/dtc/libfdt/fdt_wip.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /* * libfdt - Flat Device Tree manipulation * Copyright (C) 2006 David Gibson, IBM Corporation. - * - * libfdt is dual licensed: you can use it either under the terms of - * the GPL, or the BSD license, at your option. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this library; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Alternatively, - * - * b) Redistribution and use in source and binary forms, with or - * without modification, are permitted provided that the following - * conditions are met: - * - * 1. Redistributions of source code must retain the above - * copyright notice, this list of conditions and the following - * disclaimer. - * 2. Redistributions in binary form must reproduce the above - * copyright notice, this list of conditions and the following - * disclaimer in the documentation and/or other materials - * provided with the distribution. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND - * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, - * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF - * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR - * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT - * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR - * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, - * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include "libfdt_env.h"
diff --git a/scripts/dtc/libfdt/libfdt.h b/scripts/dtc/libfdt/libfdt.h index c400f2f5d5..36fadcdea5 100644 --- a/scripts/dtc/libfdt/libfdt.h +++ b/scripts/dtc/libfdt/libfdt.h @@ -1,54 +1,9 @@ +/* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */ #ifndef LIBFDT_H #define LIBFDT_H /* * libfdt - Flat Device Tree manipulation * Copyright (C) 2006 David Gibson, IBM Corporation. - * - * libfdt is dual licensed: you can use it either under the terms of - * the GPL, or the BSD license, at your option. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this library; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Alternatively, - * - * b) Redistribution and use in source and binary forms, with or - * without modification, are permitted provided that the following - * conditions are met: - * - * 1. Redistributions of source code must retain the above - * copyright notice, this list of conditions and the following - * disclaimer. - * 2. Redistributions in binary form must reproduce the above - * copyright notice, this list of conditions and the following - * disclaimer in the documentation and/or other materials - * provided with the distribution. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND - * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, - * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF - * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR - * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT - * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR - * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, - * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
#include "libfdt_env.h" @@ -90,8 +45,9 @@
/* Error codes: codes for bad device tree blobs */ #define FDT_ERR_TRUNCATED 8 - /* FDT_ERR_TRUNCATED: Structure block of the given device tree - * ends without an FDT_END tag. */ + /* FDT_ERR_TRUNCATED: FDT or a sub-block is improperly + * terminated (overflows, goes outside allowed bounds, or + * isn't properly terminated). */ #define FDT_ERR_BADMAGIC 9 /* FDT_ERR_BADMAGIC: Given "device tree" appears not to be a * device tree at all - it is missing the flattened device @@ -137,7 +93,11 @@ /* FDT_ERR_NOPHANDLES: The device tree doesn't have any * phandle available anymore without causing an overflow */
-#define FDT_ERR_MAX 17 +#define FDT_ERR_BADFLAGS 18 + /* FDT_ERR_BADFLAGS: The function was passed a flags field that + * contains invalid flags or an invalid combination of flags. */ + +#define FDT_ERR_MAX 18
/* constants */ #define FDT_MAX_PHANDLE 0xfffffffe @@ -157,6 +117,61 @@ static inline void *fdt_offset_ptr_w(void *fdt, int offset, int checklen)
uint32_t fdt_next_tag(const void *fdt, int offset, int *nextoffset);
+/* + * Alignment helpers: + * These helpers access words from a device tree blob. They're + * built to work even with unaligned pointers on platforms (ike + * ARM) that don't like unaligned loads and stores + */ + +static inline uint32_t fdt32_ld(const fdt32_t *p) +{ + const uint8_t *bp = (const uint8_t *)p; + + return ((uint32_t)bp[0] << 24) + | ((uint32_t)bp[1] << 16) + | ((uint32_t)bp[2] << 8) + | bp[3]; +} + +static inline void fdt32_st(void *property, uint32_t value) +{ + uint8_t *bp = (uint8_t *)property; + + bp[0] = value >> 24; + bp[1] = (value >> 16) & 0xff; + bp[2] = (value >> 8) & 0xff; + bp[3] = value & 0xff; +} + +static inline uint64_t fdt64_ld(const fdt64_t *p) +{ + const uint8_t *bp = (const uint8_t *)p; + + return ((uint64_t)bp[0] << 56) + | ((uint64_t)bp[1] << 48) + | ((uint64_t)bp[2] << 40) + | ((uint64_t)bp[3] << 32) + | ((uint64_t)bp[4] << 24) + | ((uint64_t)bp[5] << 16) + | ((uint64_t)bp[6] << 8) + | bp[7]; +} + +static inline void fdt64_st(void *property, uint64_t value) +{ + uint8_t *bp = (uint8_t *)property; + + bp[0] = value >> 56; + bp[1] = (value >> 48) & 0xff; + bp[2] = (value >> 40) & 0xff; + bp[3] = (value >> 32) & 0xff; + bp[4] = (value >> 24) & 0xff; + bp[5] = (value >> 16) & 0xff; + bp[6] = (value >> 8) & 0xff; + bp[7] = value & 0xff; +} + /**********************************************************************/ /* Traversal functions */ /**********************************************************************/ @@ -199,7 +214,7 @@ int fdt_next_subnode(const void *fdt, int offset); * ... * } * - * if ((node < 0) && (node != -FDT_ERR_NOT_FOUND)) { + * if ((node < 0) && (node != -FDT_ERR_NOTFOUND)) { * Error handling * } * @@ -217,7 +232,7 @@ int fdt_next_subnode(const void *fdt, int offset); /* General functions */ /**********************************************************************/ #define fdt_get_header(fdt, field) \ - (fdt32_to_cpu(((const struct fdt_header *)(fdt))->field)) + (fdt32_ld(&((const struct fdt_header *)(fdt))->field)) #define fdt_magic(fdt) (fdt_get_header(fdt, magic)) #define fdt_totalsize(fdt) (fdt_get_header(fdt, totalsize)) #define fdt_off_dt_struct(fdt) (fdt_get_header(fdt, off_dt_struct)) @@ -248,18 +263,32 @@ fdt_set_hdr_(size_dt_struct); #undef fdt_set_hdr_
/** - * fdt_check_header - sanity check a device tree or possible device tree + * fdt_header_size - return the size of the tree's header + * @fdt: pointer to a flattened device tree + */ +size_t fdt_header_size(const void *fdt); + +/** + * fdt_header_size_ - internal function which takes a version number + */ +size_t fdt_header_size_(uint32_t version); + +/** + * fdt_check_header - sanity check a device tree header + * @fdt: pointer to data which might be a flattened device tree * * fdt_check_header() checks that the given buffer contains what - * appears to be a flattened device tree with sane information in its - * header. + * appears to be a flattened device tree, and that the header contains + * valid information (to the extent that can be determined from the + * header alone). * * returns: * 0, if the buffer appears to contain a valid device tree * -FDT_ERR_BADMAGIC, * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, standard meanings, as above + * -FDT_ERR_BADSTATE, + * -FDT_ERR_TRUNCATED, standard meanings, as above */ int fdt_check_header(const void *fdt);
@@ -288,6 +317,24 @@ int fdt_move(const void *fdt, void *buf, int bufsize); /* Read-only functions */ /**********************************************************************/
+int fdt_check_full(const void *fdt, size_t bufsize); + +/** + * fdt_get_string - retrieve a string from the strings block of a device tree + * @fdt: pointer to the device tree blob + * @stroffset: offset of the string within the strings block (native endian) + * @lenp: optional pointer to return the string's length + * + * fdt_get_string() retrieves a pointer to a single string from the + * strings block of the device tree blob at fdt, and optionally also + * returns the string's length in *lenp. + * + * returns: + * a pointer to the string, on success + * NULL, if stroffset is out of bounds, or doesn't point to a valid string + */ +const char *fdt_get_string(const void *fdt, int stroffset, int *lenp); + /** * fdt_string - retrieve a string from the strings block of a device tree * @fdt: pointer to the device tree blob @@ -298,10 +345,24 @@ int fdt_move(const void *fdt, void *buf, int bufsize); * * returns: * a pointer to the string, on success - * NULL, if stroffset is out of bounds + * NULL, if stroffset is out of bounds, or doesn't point to a valid string */ const char *fdt_string(const void *fdt, int stroffset);
+/** + * fdt_find_max_phandle - find and return the highest phandle in a tree + * @fdt: pointer to the device tree blob + * @phandle: return location for the highest phandle value found in the tree + * + * fdt_find_max_phandle() finds the highest phandle value in the given device + * tree. The value returned in @phandle is only valid if the function returns + * success. + * + * returns: + * 0 on success or a negative error code on failure + */ +int fdt_find_max_phandle(const void *fdt, uint32_t *phandle); + /** * fdt_get_max_phandle - retrieves the highest phandle in a tree * @fdt: pointer to the device tree blob @@ -310,12 +371,24 @@ const char *fdt_string(const void *fdt, int stroffset); * device tree. This will ignore badly formatted phandles, or phandles * with a value of 0 or -1. * + * This function is deprecated in favour of fdt_find_max_phandle(). + * * returns: * the highest phandle on success * 0, if no phandle was found in the device tree * -1, if an error occurred */ -uint32_t fdt_get_max_phandle(const void *fdt); +static inline uint32_t fdt_get_max_phandle(const void *fdt) +{ + uint32_t phandle; + int err; + + err = fdt_find_max_phandle(fdt, &phandle); + if (err < 0) + return (uint32_t)-1; + + return phandle; +}
/** * fdt_generate_phandle - return a new, unused phandle for a device tree blob @@ -522,7 +595,7 @@ int fdt_next_property_offset(const void *fdt, int offset); * ... * } * - * if ((property < 0) && (property != -FDT_ERR_NOT_FOUND)) { + * if ((property < 0) && (property != -FDT_ERR_NOTFOUND)) { * Error handling * } * @@ -625,7 +698,7 @@ static inline struct fdt_property *fdt_get_property_w(void *fdt, int nodeoffset, /** * fdt_getprop_by_offset - retrieve the value of a property at a given offset * @fdt: pointer to the device tree blob - * @ffset: offset of the property to read + * @offset: offset of the property to read * @namep: pointer to a string variable (will be overwritten) or NULL * @lenp: pointer to an integer variable (will be overwritten) or NULL * @@ -734,7 +807,7 @@ uint32_t fdt_get_phandle(const void *fdt, int nodeoffset); /** * fdt_get_alias_namelen - get alias based on substring * @fdt: pointer to the device tree blob - * @name: name of the alias to look up + * @name: name of the alias th look up * @namelen: number of characters of name to consider * * Identical to fdt_get_alias(), but only examine the first namelen @@ -1316,7 +1389,45 @@ int fdt_nop_node(void *fdt, int nodeoffset); /* Sequential write functions */ /**********************************************************************/
+/* fdt_create_with_flags flags */ +#define FDT_CREATE_FLAG_NO_NAME_DEDUP 0x1 + /* FDT_CREATE_FLAG_NO_NAME_DEDUP: Do not try to de-duplicate property + * names in the fdt. This can result in faster creation times, but + * a larger fdt. */ + +#define FDT_CREATE_FLAGS_ALL (FDT_CREATE_FLAG_NO_NAME_DEDUP) + +/** + * fdt_create_with_flags - begin creation of a new fdt + * @fdt: pointer to memory allocated where fdt will be created + * @bufsize: size of the memory space at fdt + * @flags: a valid combination of FDT_CREATE_FLAG_ flags, or 0. + * + * fdt_create_with_flags() begins the process of creating a new fdt with + * the sequential write interface. + * + * fdt creation process must end with fdt_finished() to produce a valid fdt. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, bufsize is insufficient for a minimal fdt + * -FDT_ERR_BADFLAGS, flags is not valid + */ +int fdt_create_with_flags(void *buf, int bufsize, uint32_t flags); + +/** + * fdt_create - begin creation of a new fdt + * @fdt: pointer to memory allocated where fdt will be created + * @bufsize: size of the memory space at fdt + * + * fdt_create() is equivalent to fdt_create_with_flags() with flags=0. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, bufsize is insufficient for a minimal fdt + */ int fdt_create(void *buf, int bufsize); + int fdt_resize(void *fdt, void *buf, int bufsize); int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size); int fdt_finish_reservemap(void *fdt); @@ -1787,6 +1898,43 @@ static inline int fdt_appendprop_cell(void *fdt, int nodeoffset, #define fdt_appendprop_string(fdt, nodeoffset, name, str) \ fdt_appendprop((fdt), (nodeoffset), (name), (str), strlen(str)+1)
+/** + * fdt_appendprop_addrrange - append a address range property + * @fdt: pointer to the device tree blob + * @parent: offset of the parent node + * @nodeoffset: offset of the node to add a property at + * @name: name of property + * @addr: start address of a given range + * @size: size of a given range + * + * fdt_appendprop_addrrange() appends an address range value (start + * address and size) to the value of the named property in the given + * node, or creates a new property with that value if it does not + * already exist. + * If "name" is not specified, a default "reg" is used. + * Cell sizes are determined by parent's #address-cells and #size-cells. + * + * This function may insert data into the blob, and will therefore + * change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid + * #address-cells property + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADVALUE, addr or size doesn't fit to respective cells size + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain a new property + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_appendprop_addrrange(void *fdt, int parent, int nodeoffset, + const char *name, uint64_t addr, uint64_t size); + /** * fdt_delprop - delete a property * @fdt: pointer to the device tree blob diff --git a/scripts/dtc/libfdt/libfdt_env.h b/scripts/dtc/libfdt/libfdt_env.h index 3ff9e28630..73b6d40450 100644 --- a/scripts/dtc/libfdt/libfdt_env.h +++ b/scripts/dtc/libfdt/libfdt_env.h @@ -1,55 +1,10 @@ +/* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */ #ifndef LIBFDT_ENV_H #define LIBFDT_ENV_H /* * libfdt - Flat Device Tree manipulation * Copyright (C) 2006 David Gibson, IBM Corporation. * Copyright 2012 Kim Phillips, Freescale Semiconductor. - * - * libfdt is dual licensed: you can use it either under the terms of - * the GPL, or the BSD license, at your option. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this library; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Alternatively, - * - * b) Redistribution and use in source and binary forms, with or - * without modification, are permitted provided that the following - * conditions are met: - * - * 1. Redistributions of source code must retain the above - * copyright notice, this list of conditions and the following - * disclaimer. - * 2. Redistributions in binary form must reproduce the above - * copyright notice, this list of conditions and the following - * disclaimer in the documentation and/or other materials - * provided with the distribution. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND - * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, - * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF - * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR - * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT - * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR - * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, - * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
#include <stdbool.h> @@ -57,6 +12,7 @@ #include <stdint.h> #include <stdlib.h> #include <string.h> +#include <limits.h>
#ifdef __CHECKER__ #define FDT_FORCE __attribute__((force)) diff --git a/scripts/dtc/libfdt/libfdt_internal.h b/scripts/dtc/libfdt/libfdt_internal.h index 7681e19229..5436e2ceea 100644 --- a/scripts/dtc/libfdt/libfdt_internal.h +++ b/scripts/dtc/libfdt/libfdt_internal.h @@ -1,65 +1,24 @@ +/* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */ #ifndef LIBFDT_INTERNAL_H #define LIBFDT_INTERNAL_H /* * libfdt - Flat Device Tree manipulation * Copyright (C) 2006 David Gibson, IBM Corporation. - * - * libfdt is dual licensed: you can use it either under the terms of - * the GPL, or the BSD license, at your option. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this library; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Alternatively, - * - * b) Redistribution and use in source and binary forms, with or - * without modification, are permitted provided that the following - * conditions are met: - * - * 1. Redistributions of source code must retain the above - * copyright notice, this list of conditions and the following - * disclaimer. - * 2. Redistributions in binary form must reproduce the above - * copyright notice, this list of conditions and the following - * disclaimer in the documentation and/or other materials - * provided with the distribution. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND - * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, - * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF - * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR - * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT - * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR - * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, - * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include <fdt.h>
#define FDT_ALIGN(x, a) (((x) + (a) - 1) & ~((a) - 1)) #define FDT_TAGALIGN(x) (FDT_ALIGN((x), FDT_TAGSIZE))
-#define FDT_CHECK_HEADER(fdt) \ - { \ - int err_; \ - if ((err_ = fdt_check_header(fdt)) != 0) \ - return err_; \ +int fdt_ro_probe_(const void *fdt); +#define FDT_RO_PROBE(fdt) \ + { \ + int totalsize_; \ + if (fdt_chk_basic()) { \ + totalsize_ = fdt_ro_probe_(fdt); \ + if (totalsize_ < 0) \ + return totalsize_; \ + } \ }
int fdt_check_node_offset_(const void *fdt, int offset); @@ -92,4 +51,87 @@ static inline struct fdt_reserve_entry *fdt_mem_rsv_w_(void *fdt, int n)
#define FDT_SW_MAGIC (~FDT_MAGIC)
+/**********************************************************************/ +/* Checking controls */ +/**********************************************************************/ + +#ifndef FDT_ASSUME_MASK +#define FDT_ASSUME_MASK 0 +#endif + +/* + * Defines assumptions which can be enabled. Each of these can be enabled + * individually. For maximum saftey, don't enable any assumptions! + * + * For minimal code size and no safety, use FDT_ASSUME_PERFECT at your own risk. + * You should have another method of validating the device tree, such as a + * signature or hash check before using libfdt. + * + * For situations where security is not a concern it may be safe to enable + * FDT_ASSUME_FRIENDLY. + */ +enum { + /* + * This does essentially no checks. Only the latest device-tree + * version is correctly handled. Incosistencies or errors in the device + * tree may cause undefined behaviour or crashes. + * + * If an error occurs when modifying the tree it may leave the tree in + * an intermediate (but valid) state. As an example, adding a property + * where there is insufficient space may result in the property name + * being added to the string table even though the property itself is + * not added to the struct section. + * + * Only use this if you have a fully validated device tree with + * the latest supported version and wish to minimise code size. + */ + FDT_ASSUME_PERFECT = 0xff, + + /* + * This assumes that the device tree is sane. i.e. header metadata + * and basic hierarchy are correct. + * + * These checks will be sufficient if you have a valid device tree with + * no internal inconsistencies. With this assumption, libfdt will + * generally not return -FDT_ERR_INTERNAL, -FDT_ERR_BADLAYOUT, etc. + */ + FDT_ASSUME_SANE = 1 << 0, + + /* + * This disables checks for device-tree version and removes all code + * which handles older versions. + * + * Only enable this if you know you have a device tree with the latest + * version. + */ + FDT_ASSUME_LATEST = 1 << 1, + + /* + * This disables any extensive checking of parameters and the device + * tree, making various assumptions about correctness. Normal device + * trees produced by libfdt and the compiler should be handled safely. + * Malicious device trees and complete garbage may cause libfdt to + * behave badly or crash. + */ + FDT_ASSUME_FRIENDLY = 1 << 2, +}; + +/** fdt_chk_basic() - see if basic checking of params and DT data is enabled */ +static inline bool fdt_chk_basic(void) +{ + return !(FDT_ASSUME_MASK & FDT_ASSUME_SANE); +} + +/** fdt_chk_version() - see if we need to handle old versions of the DT */ +static inline bool fdt_chk_version(void) +{ + return !(FDT_ASSUME_MASK & FDT_ASSUME_LATEST); +} + +/** fdt_chk_extra() - see if extra checking is enabled */ +static inline bool fdt_chk_extra(void) +{ + return !(FDT_ASSUME_MASK & FDT_ASSUME_FRIENDLY); +} + #endif /* LIBFDT_INTERNAL_H */ diff --git a/tools/libfdt/fdt_rw.c b/tools/libfdt/fdt_rw.c index 68fc7c8c88..7189f01429 100644 --- a/tools/libfdt/fdt_rw.c +++ b/tools/libfdt/fdt_rw.c @@ -11,6 +11,7 @@ int fdt_remove_unused_strings(const void *old, void *new) const char *str; int ret; int tag = FDT_PROP; + int allocated;
/* Make a copy and remove the strings */ memcpy(new, old, size); @@ -25,7 +26,7 @@ int fdt_remove_unused_strings(const void *old, void *new) new_prop = (struct fdt_property *)(unsigned long) fdt_get_property_by_offset(new, offset, NULL); str = fdt_string(old, fdt32_to_cpu(old_prop->nameoff)); - ret = fdt_find_add_string_(new, str); + ret = fdt_find_add_string_(new, str, &allocated); if (ret < 0) return ret; new_prop->nameoff = cpu_to_fdt32(ret);
Bring over the fdt from this commit:
430419c (origin/master) tests: fix some python warnings
adding in the 'assumptions' series designed to reduce code size.
lib/libfdt/fdt_ro.c | 420 ++++++++++++++++++++------- scripts/dtc/libfdt/Makefile.libfdt | 7 + scripts/dtc/libfdt/fdt.c | 182 ++++++++---- scripts/dtc/libfdt/fdt.h | 47 +-- scripts/dtc/libfdt/fdt_addresses.c | 94 +++--- scripts/dtc/libfdt/fdt_empty_tree.c | 47 +-- scripts/dtc/libfdt/fdt_overlay.c | 91 ++---- scripts/dtc/libfdt/fdt_ro.c | 341 +++++++++++++++------- scripts/dtc/libfdt/fdt_rw.c | 119 ++++---- scripts/dtc/libfdt/fdt_strerror.c | 47 +-- scripts/dtc/libfdt/fdt_sw.c | 241 ++++++++++----- scripts/dtc/libfdt/fdt_wip.c | 47 +-- scripts/dtc/libfdt/libfdt.h | 268 +++++++++++++---- scripts/dtc/libfdt/libfdt_env.h | 48 +-- scripts/dtc/libfdt/libfdt_internal.h | 144 +++++---- tools/libfdt/fdt_rw.c | 3 +- 16 files changed, 1275 insertions(+), 871 deletions(-)
Applied to u-boot-fdt
I don't know how, but this patch broke the am3517_evm board. I haven't had a chance to review other omap3 boards I have yet.
With this patch:
U-Boot SPL 2020.01-rc1-00163-gf0921f5098 (Jan 07 2020 - 05:31:57 -0600) Trying to boot from MMC1 spl_register_fat_device: fat register err - -1 spl_register_fat_device: fat register err - -1 spl_load_image_fat: error reading image u-boot.img, err - -1 SPL: failed to boot from all boot devices
If I revert this patch on master, the am3517_evm boots just fine. I'm open to trying stuff if you have ideas.
adam
diff --git a/lib/libfdt/fdt_ro.c b/lib/libfdt/fdt_ro.c index 693de9aa5a..560041b603 100644 --- a/lib/libfdt/fdt_ro.c +++ b/lib/libfdt/fdt_ro.c @@ -14,12 +14,13 @@
-static int _fdt_nodename_eq(const void *fdt, int offset, +static int fdt_nodename_eq_(const void *fdt, int offset, const char *s, int len) {
const char *p = fdt_offset_ptr(fdt, offset + FDT_TAGSIZE, len+1);
int olen;
if (!p)
@@ -34,46 +35,85 @@ static int _fdt_nodename_eq(const void *fdt, int offset, return 0; }
-static int _fdt_string_eq(const void *fdt, int stroffset,
int32_t totalsize;
uint32_t absoffset;
size_t len;
int err;
const char *s, *n;
return (strnlen(p, len + 1) == len) && (memcmp(p, s, len) == 0);
-uint32_t fdt_get_max_phandle(const void *fdt) -{
uint32_t max_phandle = 0;
int offset;
if (lenp)
*lenp = strlen(s);
return s;
totalsize = fdt_ro_probe_(fdt);
err = totalsize;
if (totalsize < 0)
goto fail;
err = -FDT_ERR_BADOFFSET;
absoffset = stroffset + fdt_off_dt_strings(fdt);
if (absoffset >= totalsize)
goto fail;
len = totalsize - absoffset;
if (fdt_magic(fdt) == FDT_MAGIC) {
if (stroffset < 0)
goto fail;
if (stroffset >= fdt_size_dt_strings(fdt))
goto fail;
if ((fdt_size_dt_strings(fdt) - stroffset) < len)
len = fdt_size_dt_strings(fdt) - stroffset;
} else if (fdt_magic(fdt) == FDT_SW_MAGIC) {
if ((stroffset >= 0)
|| (stroffset < -fdt_size_dt_strings(fdt)))
goto fail;
if ((-stroffset) < len)
len = -stroffset;
} else {
err = -FDT_ERR_INTERNAL;
goto fail;
for (offset = fdt_next_node(fdt, -1, NULL);;
offset = fdt_next_node(fdt, offset, NULL)) {
uint32_t phandle;
s = (const char *)fdt + absoffset;
n = memchr(s, '\0', len);
if (!n) {
/* missing terminating NULL */
err = -FDT_ERR_TRUNCATED;
goto fail;
if (offset == -FDT_ERR_NOTFOUND)
return max_phandle;
if (lenp)
*lenp = n - s;
return s;
if (offset < 0)
+fail:
if (lenp)
*lenp = err;
return NULL;
phandle = fdt_get_phandle(fdt, offset);
if (phandle == (uint32_t)-1)
continue;
+const char *fdt_string(const void *fdt, int stroffset) +{
return fdt_get_string(fdt, stroffset, NULL);
if (phandle > max_phandle)
max_phandle = phandle;
+static int fdt_string_eq_(const void *fdt, int stroffset,
int slen;
const char *p = fdt_get_string(fdt, stroffset, &slen);
return p && (slen == len) && (memcmp(p, s, len) == 0);
-int fdt_generate_phandle(const void *fdt, uint32_t *phandle) +int fdt_find_max_phandle(const void *fdt, uint32_t *phandle) { uint32_t max = 0; int offset = -1; @@ -95,6 +135,21 @@ int fdt_generate_phandle(const void *fdt, uint32_t *phandle) max = value; }
if (phandle)
*phandle = max;
+int fdt_generate_phandle(const void *fdt, uint32_t *phandle) +{
uint32_t max;
int err;
err = fdt_find_max_phandle(fdt, &max);
if (err < 0)
return err;
if (max == FDT_MAX_PHANDLE) return -FDT_ERR_NOPHANDLES;
@@ -104,24 +159,48 @@ int fdt_generate_phandle(const void *fdt, uint32_t *phandle) return 0; }
+static const struct fdt_reserve_entry *fdt_mem_rsv(const void *fdt, int n) +{
int offset = n * sizeof(struct fdt_reserve_entry);
int absoffset = fdt_off_mem_rsvmap(fdt) + offset;
if (absoffset < fdt_off_mem_rsvmap(fdt))
return NULL;
if (absoffset > fdt_totalsize(fdt) -
return NULL;
return fdt_mem_rsv_(fdt, n);
int fdt_get_mem_rsv(const void *fdt, int n, uint64_t *address, uint64_t *size) {
*address = fdt64_to_cpu(fdt_mem_rsv_(fdt, n)->address);
*size = fdt64_to_cpu(fdt_mem_rsv_(fdt, n)->size);
const struct fdt_reserve_entry *re;
FDT_RO_PROBE(fdt);
re = fdt_mem_rsv(fdt, n);
if (fdt_chk_extra() && !re)
return -FDT_ERR_BADOFFSET;
*address = fdt64_ld(&re->address);
*size = fdt64_ld(&re->size); return 0;
int fdt_num_mem_rsv(const void *fdt) {
int i = 0;
int i;
while (fdt64_to_cpu(fdt_mem_rsv_(fdt, i)->size) != 0)
i++;
return i;
for (i = 0; (re = fdt_mem_rsv(fdt, i)) != NULL; i++) {
if (fdt64_ld(&re->size) == 0)
return i;
-static int _nextprop(const void *fdt, int offset) +static int nextprop_(const void *fdt, int offset) { uint32_t tag; int nextoffset; @@ -150,13 +229,13 @@ int fdt_subnode_offset_namelen(const void *fdt, int offset, { int depth;
FDT_RO_PROBE(fdt); for (depth = 0; (offset >= 0) && (depth >= 0); offset = fdt_next_node(fdt, offset, &depth)) if ((depth == 1)
&& _fdt_nodename_eq(fdt, offset, name, namelen))
&& fdt_nodename_eq_(fdt, offset, name, namelen)) return offset; if (depth < 0)
@@ -170,36 +249,17 @@ int fdt_subnode_offset(const void *fdt, int parentoffset, return fdt_subnode_offset_namelen(fdt, parentoffset, name, strlen(name)); }
- Find the next of path separator, note we need to search for both '/' and ':'
- and then take the first one so that we do the right thing for e.g.
- "foo/bar:option" and "bar:option/otheroption", both of which happen, so
- first searching for either ':' or '/' does not work.
-static const char *fdt_path_next_separator(const char *path, int len) -{
const void *sep1 = memchr(path, '/', len);
const void *sep2 = memchr(path, ':', len);
if (sep1 && sep2)
return (sep1 < sep2) ? sep1 : sep2;
else if (sep1)
return sep1;
else
return sep2;
int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen) { const char *end = path + namelen; const char *p = path; int offset = 0;
FDT_RO_PROBE(fdt); /* see if we have an alias */ if (*path != '/') {
const char *q = fdt_path_next_separator(path, namelen);
const char *q = memchr(path, '/', end - p); if (!q) q = end;
@@ -212,17 +272,16 @@ int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen) p = q; }
while (*p && (p < end)) {
while (p < end) { const char *q;
while (*p == '/')
while (*p == '/') { p++;
if (*p == '\0' || *p == ':')
return offset;
q = fdt_path_next_separator(p, end - p);
if (!q)
if (p == end)
return offset;
q = memchr(p, '/', end - p);
if (! q) q = end; offset = fdt_subnode_offset_namelen(fdt, offset, p, q-p);
@@ -243,16 +302,35 @@ int fdt_path_offset(const void *fdt, const char *path) const char *fdt_get_name(const void *fdt, int nodeoffset, int *len) { const struct fdt_node_header *nh = fdt_offset_ptr_(fdt, nodeoffset);
const char *nameptr; int err;
if (((err = fdt_check_header(fdt)) != 0)
|| ((err = fdt_check_node_offset_(fdt, nodeoffset)) < 0))
(((err = fdt_ro_probe_(fdt)) < 0)
|| ((err = fdt_check_node_offset_(fdt, nodeoffset)) < 0)))
goto fail;
nameptr = nh->name;
* For old FDT versions, match the naming conventions of V16:
* give only the leaf name (after all /). The actual tree
* contents are loosely checked.
const char *leaf;
leaf = strrchr(nameptr, '/');
if (leaf == NULL) {
err = -FDT_ERR_BADSTRUCTURE; goto fail;
nameptr = leaf+1;
} if (len)
*len = strlen(nh->name);
*len = strlen(nameptr);
return nh->name;
return nameptr;
fail: if (len)
@@ -267,7 +345,7 @@ int fdt_first_property_offset(const void *fdt, int nodeoffset) if ((offset = fdt_check_node_offset_(fdt, nodeoffset)) < 0) return offset;
return _nextprop(fdt, offset);
return nextprop_(fdt, offset);
int fdt_next_property_offset(const void *fdt, int offset) @@ -275,17 +353,17 @@ int fdt_next_property_offset(const void *fdt, int offset) if ((offset = fdt_check_prop_offset_(fdt, offset)) < 0) return offset;
-const struct fdt_property *fdt_get_property_by_offset(const void *fdt,
int offset,
int *lenp)
+static const struct fdt_property *fdt_get_property_by_offset_(const void *fdt,
int offset,
int *lenp)
{ int err; const struct fdt_property *prop;
if ((err = fdt_check_prop_offset_(fdt, offset)) < 0) {
if (fdt_chk_basic() && (err = fdt_check_prop_offset_(fdt, offset)) < 0) { if (lenp) *lenp = err; return NULL;
@@ -294,28 +372,50 @@ const struct fdt_property *fdt_get_property_by_offset(const void *fdt, prop = fdt_offset_ptr_(fdt, offset);
if (lenp)
*lenp = fdt32_to_cpu(prop->len);
*lenp = fdt32_ld(&prop->len); return prop;
-const struct fdt_property *fdt_get_property_namelen(const void *fdt,
int offset,
const char *name,
int namelen, int *lenp)
+const struct fdt_property *fdt_get_property_by_offset(const void *fdt,
int offset,
int *lenp)
/* Prior to version 16, properties may need realignment
* and this API does not work. fdt_getprop_*() will, however. */
if (fdt_chk_version() && fdt_version(fdt) < 0x10) {
if (lenp)
*lenp = -FDT_ERR_BADVERSION;
return NULL;
return fdt_get_property_by_offset_(fdt, offset, lenp);
+static const struct fdt_property *fdt_get_property_namelen_(const void *fdt,
int offset,
const char *name,
int namelen,
int *lenp,
int *poffset)
{ for (offset = fdt_first_property_offset(fdt, offset); (offset >= 0); (offset = fdt_next_property_offset(fdt, offset))) { const struct fdt_property *prop;
if (!(prop = fdt_get_property_by_offset(fdt, offset, lenp))) {
prop = fdt_get_property_by_offset_(fdt, offset, lenp);
if (fdt_chk_extra() && !prop) { offset = -FDT_ERR_INTERNAL; break; }
if (_fdt_string_eq(fdt, fdt32_to_cpu(prop->nameoff),
name, namelen))
if (fdt_string_eq_(fdt, fdt32_ld(&prop->nameoff),
name, namelen)) {
if (poffset)
*poffset = offset; return prop;
} } if (lenp)
@@ -323,6 +423,25 @@ const struct fdt_property *fdt_get_property_namelen(const void *fdt, return NULL; }
+const struct fdt_property *fdt_get_property_namelen(const void *fdt,
int offset,
const char *name,
if (lenp)
return NULL;
return fdt_get_property_namelen_(fdt, offset, name, namelen, lenp,
NULL);
const struct fdt_property *fdt_get_property(const void *fdt, int nodeoffset, const char *name, int *lenp) @@ -334,12 +453,18 @@ const struct fdt_property *fdt_get_property(const void *fdt, const void *fdt_getprop_namelen(const void *fdt, int nodeoffset, const char *name, int namelen, int *lenp) {
int poffset; const struct fdt_property *prop;
prop = fdt_get_property_namelen(fdt, nodeoffset, name, namelen, lenp);
prop = fdt_get_property_namelen_(fdt, nodeoffset, name, namelen, lenp,
&poffset); if (!prop) return NULL;
/* Handle realignment */
if (fdt_chk_version() && fdt_version(fdt) < 0x10 &&
(poffset + sizeof(*prop)) % 8 && fdt32_ld(&prop->len) >= 8)
return prop->data + 4; return prop->data;
@@ -348,11 +473,31 @@ const void *fdt_getprop_by_offset(const void *fdt, int offset, { const struct fdt_property *prop;
prop = fdt_get_property_by_offset(fdt, offset, lenp);
prop = fdt_get_property_by_offset_(fdt, offset, lenp); if (!prop) return NULL;
if (namep)
*namep = fdt_string(fdt, fdt32_to_cpu(prop->nameoff));
if (namep) {
const char *name;
int namelen;
if (fdt_chk_extra()) {
name = fdt_get_string(fdt, fdt32_ld(&prop->nameoff),
&namelen);
if (!name) {
if (lenp)
*lenp = namelen;
return NULL;
*namep = name;
} else {
*namep = fdt_string(fdt, fdt32_ld(&prop->nameoff));
(offset + sizeof(*prop)) % 8 && fdt32_ld(&prop->len) >= 8)
@@ -376,7 +521,7 @@ uint32_t fdt_get_phandle(const void *fdt, int nodeoffset) return 0; }
return fdt32_to_cpu(*php);
return fdt32_ld(php);
const char *fdt_get_alias_namelen(const void *fdt, @@ -402,7 +547,7 @@ int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen) int offset, depth, namelen; const char *name;
FDT_RO_PROBE(fdt); if (buflen < 2) return -FDT_ERR_NOSPACE;
@@ -454,7 +599,7 @@ int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, int offset, depth; int supernodeoffset = -FDT_ERR_INTERNAL;
FDT_RO_PROBE(fdt); if (supernodedepth < 0) return -FDT_ERR_NOTFOUND;
@@ -476,10 +621,12 @@ int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, } }
if ((offset == -FDT_ERR_NOTFOUND) || (offset >= 0))
else if (offset == -FDT_ERR_BADOFFSET)
return -FDT_ERR_BADSTRUCTURE;
} return offset; /* error from fdt_next_node() */
} @@ -491,7 +638,7 @@ int fdt_node_depth(const void *fdt, int nodeoffset)
err = fdt_supernode_atdepth_offset(fdt, nodeoffset, 0, &nodedepth); if (err)
return (err < 0) ? err : -FDT_ERR_INTERNAL;
return (!fdt_chk_extra() || err < 0) ? err : -FDT_ERR_INTERNAL; return nodedepth;
@@ -513,7 +660,7 @@ int fdt_node_offset_by_prop_value(const void *fdt, int startoffset, const void *val; int len;
FDT_RO_PROBE(fdt); /* FIXME: The algorithm here is pretty horrible: we scan each * property of a node in fdt_getprop(), then if that didn't
@@ -539,7 +686,7 @@ int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle) if ((phandle == 0) || (phandle == -1)) return -FDT_ERR_BADPHANDLE;
FDT_RO_PROBE(fdt); /* FIXME: The algorithm here is pretty horrible: we * potentially scan each property of a node in
@@ -692,7 +839,7 @@ int fdt_node_offset_by_compatible(const void *fdt, int startoffset, { int offset, err;
FDT_RO_PROBE(fdt); /* FIXME: The algorithm here is pretty horrible: we scan each * property of a node in fdt_node_check_compatible(), then if
@@ -711,3 +858,68 @@ int fdt_node_offset_by_compatible(const void *fdt, int startoffset,
+#if !defined(CHECK_LEVEL) || CHECK_LEVEL > 0 +int fdt_check_full(const void *fdt, size_t bufsize) +{
int err;
int num_memrsv;
int offset, nextoffset = 0;
uint32_t tag;
unsigned depth = 0;
const void *prop;
const char *propname;
if (bufsize < FDT_V1_SIZE)
return -FDT_ERR_TRUNCATED;
err = fdt_check_header(fdt);
if (err != 0)
return err;
if (bufsize < fdt_totalsize(fdt))
num_memrsv = fdt_num_mem_rsv(fdt);
if (num_memrsv < 0)
return num_memrsv;
while (1) {
offset = nextoffset;
tag = fdt_next_tag(fdt, offset, &nextoffset);
if (nextoffset < 0)
return nextoffset;
switch (tag) {
case FDT_NOP:
break;
case FDT_END:
if (depth != 0)
case FDT_BEGIN_NODE:
depth++;
if (depth > INT_MAX)
break;
case FDT_END_NODE:
if (depth == 0)
depth--;
break;
case FDT_PROP:
prop = fdt_getprop_by_offset(fdt, offset, &propname,
&err);
if (!prop)
return err;
break;
default:
+} +#endif diff --git a/scripts/dtc/libfdt/Makefile.libfdt b/scripts/dtc/libfdt/Makefile.libfdt index 098b3f36e6..e54639738c 100644 --- a/scripts/dtc/libfdt/Makefile.libfdt +++ b/scripts/dtc/libfdt/Makefile.libfdt @@ -1,3 +1,4 @@ +# SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) # Makefile.libfdt # # This is not a complete Makefile of itself. Instead, it is designed to @@ -9,3 +10,9 @@ LIBFDT_VERSION = version.lds LIBFDT_SRCS = fdt.c fdt_ro.c fdt_wip.c fdt_sw.c fdt_rw.c fdt_strerror.c fdt_empty_tree.c \ fdt_addresses.c fdt_overlay.c LIBFDT_OBJS = $(LIBFDT_SRCS:%.c=%.o) +LIBFDT_LIB = libfdt-$(DTC_VERSION).$(SHAREDLIB_EXT)
+libfdt_clean:
@$(VECHO) CLEAN "(libfdt)"
rm -f $(STD_CLEANFILES:%=$(LIBFDT_dir)/%)
rm -f $(LIBFDT_dir)/$(LIBFDT_soname)
diff --git a/scripts/dtc/libfdt/fdt.c b/scripts/dtc/libfdt/fdt.c index 7855a17877..8e4cce3b9b 100644 --- a/scripts/dtc/libfdt/fdt.c +++ b/scripts/dtc/libfdt/fdt.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
- libfdt - Flat Device Tree manipulation
- Copyright (C) 2006 David Gibson, IBM Corporation.
- libfdt is dual licensed: you can use it either under the terms of
- the GPL, or the BSD license, at your option.
- a) This library is free software; you can redistribute it and/or
MA 02110-1301 USA
- Alternatively,
- b) Redistribution and use in source and binary forms, with or
conditions are met:
disclaimer.
@@ -55,14 +10,24 @@
-int fdt_check_header(const void *fdt) +/*
- Minimal sanity check for a read-only tree. fdt_ro_probe_() checks
- that the given buffer contains what appears to be a flattened
- device tree with sane information in its header.
+int32_t fdt_ro_probe_(const void *fdt) {
uint32_t totalsize = fdt_totalsize(fdt);
if (fdt_magic(fdt) == FDT_MAGIC) { /* Complete tree */
if (fdt_version(fdt) < FDT_FIRST_SUPPORTED_VERSION)
return -FDT_ERR_BADVERSION;
if (fdt_last_comp_version(fdt) > FDT_LAST_SUPPORTED_VERSION)
if (fdt_chk_version()) {
} } else if (fdt_magic(fdt) == FDT_SW_MAGIC) { /* Unfinished sequential-write blob */ if (fdt_size_dt_struct(fdt) == 0)
@@ -71,6 +36,96 @@ int fdt_check_header(const void *fdt) return -FDT_ERR_BADMAGIC; }
if (totalsize < INT32_MAX)
return totalsize;
else
+static int check_off_(uint32_t hdrsize, uint32_t totalsize, uint32_t off) +{
return (off >= hdrsize) && (off <= totalsize);
+static int check_block_(uint32_t hdrsize, uint32_t totalsize,
uint32_t base, uint32_t size)
if (!check_off_(hdrsize, totalsize, base))
return 0; /* block start out of bounds */
if ((base + size) < base)
return 0; /* overflow */
if (!check_off_(hdrsize, totalsize, base + size))
return 0; /* block end out of bounds */
return 1;
+size_t fdt_header_size_(uint32_t version) +{
if (version <= 1)
return FDT_V1_SIZE;
else if (version <= 2)
return FDT_V2_SIZE;
else if (version <= 3)
return FDT_V3_SIZE;
else if (version <= 16)
return FDT_V16_SIZE;
else
return FDT_V17_SIZE;
+size_t fdt_header_size(const void *fdt) +{
return fdt_chk_version() ? fdt_header_size_(fdt_version(fdt)) :
FDT_V17_SIZE;
+int fdt_check_header(const void *fdt) +{
size_t hdrsize;
if (fdt_magic(fdt) != FDT_MAGIC)
if ((fdt_version(fdt) < FDT_FIRST_SUPPORTED_VERSION)
FDT_LAST_SUPPORTED_VERSION))
if (fdt_version(fdt) < fdt_last_comp_version(fdt))
hdrsize = fdt_header_size(fdt);
if ((fdt_totalsize(fdt) < hdrsize)
|| (fdt_totalsize(fdt) > INT_MAX))
/* Bounds check memrsv block */
if (!check_off_(hdrsize, fdt_totalsize(fdt),
fdt_off_mem_rsvmap(fdt)))
/* Bounds check structure block */
if (fdt_chk_version() && fdt_version(fdt) < 17) {
fdt_off_dt_struct(fdt)))
} else {
if (!check_block_(hdrsize, fdt_totalsize(fdt),
fdt_off_dt_struct(fdt),
fdt_size_dt_struct(fdt)))
/* Bounds check strings block */
fdt_off_dt_strings(fdt),
@@ -78,12 +133,13 @@ const void *fdt_offset_ptr(const void *fdt, int offset, unsigned int len) { unsigned absoffset = offset + fdt_off_dt_struct(fdt);
if ((absoffset < offset)
|| ((absoffset + len) < absoffset)
|| (absoffset + len) > fdt_totalsize(fdt))
return NULL;
return NULL;
if (fdt_version(fdt) >= 0x11)
if (!fdt_chk_version() || fdt_version(fdt) >= 0x11) if (((offset + len) < offset) || ((offset + len) > fdt_size_dt_struct(fdt))) return NULL;
@@ -100,7 +156,7 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset)
*nextoffset = -FDT_ERR_TRUNCATED; tagp = fdt_offset_ptr(fdt, offset, FDT_TAGSIZE);
if (!tagp)
if (fdt_chk_basic() && !tagp) return FDT_END; /* premature end */ tag = fdt32_to_cpu(*tagp); offset += FDT_TAGSIZE;
@@ -112,18 +168,19 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset) do { p = fdt_offset_ptr(fdt, offset++, 1); } while (p && (*p != '\0'));
if (!p)
if (fdt_chk_basic() && !p) return FDT_END; /* premature end */ break; case FDT_PROP: lenp = fdt_offset_ptr(fdt, offset, sizeof(*lenp));
if (!lenp)
if (fdt_chk_basic() && !lenp) return FDT_END; /* premature end */ /* skip-name offset, length and value */ offset += sizeof(struct fdt_property) - FDT_TAGSIZE + fdt32_to_cpu(*lenp);
if (fdt_version(fdt) < 0x10 && fdt32_to_cpu(*lenp) >= 8 &&
fdt_version(fdt) < 0x10 && fdt32_to_cpu(*lenp) >= 8 && ((offset - fdt32_to_cpu(*lenp)) % 8) != 0) offset += 4; break;
@@ -137,7 +194,8 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset) return FDT_END; }
if (!fdt_offset_ptr(fdt, startoffset, offset - startoffset))
!fdt_offset_ptr(fdt, startoffset, offset - startoffset)) return FDT_END; /* premature end */ *nextoffset = FDT_TAGALIGN(offset);
@@ -244,7 +302,7 @@ const char *fdt_find_string_(const char *strtab, int tabsize, const char *s)
int fdt_move(const void *fdt, void *buf, int bufsize) {
FDT_CHECK_HEADER(fdt);
FDT_RO_PROBE(fdt); if (fdt_totalsize(fdt) > bufsize) return -FDT_ERR_NOSPACE;
diff --git a/scripts/dtc/libfdt/fdt.h b/scripts/dtc/libfdt/fdt.h index 74961f9026..f2e68807f2 100644 --- a/scripts/dtc/libfdt/fdt.h +++ b/scripts/dtc/libfdt/fdt.h @@ -1,55 +1,10 @@ +/* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */ #ifndef FDT_H #define FDT_H /*
- Copyright 2012 Kim Phillips, Freescale Semiconductor.
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
#ifndef __ASSEMBLY__ diff --git a/scripts/dtc/libfdt/fdt_addresses.c b/scripts/dtc/libfdt/fdt_addresses.c index 788c143113..9a82cd0ba2 100644 --- a/scripts/dtc/libfdt/fdt_addresses.c +++ b/scripts/dtc/libfdt/fdt_addresses.c @@ -1,53 +1,8 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
- Copyright (C) 2014 David Gibson david@gibson.dropbear.id.au
- Copyright (C) 2018 embedded brains GmbH
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
@@ -97,3 +52,50 @@ int fdt_size_cells(const void *fdt, int nodeoffset) return 1; return val; }
+/* This function assumes that [address|size]_cells is 1 or 2 */ +int fdt_appendprop_addrrange(void *fdt, int parent, int nodeoffset,
int addr_cells, size_cells, ret;
uint8_t data[sizeof(fdt64_t) * 2], *prop;
ret = fdt_address_cells(fdt, parent);
if (ret < 0)
return ret;
addr_cells = ret;
ret = fdt_size_cells(fdt, parent);
if (ret < 0)
return ret;
size_cells = ret;
/* check validity of address */
prop = data;
if (addr_cells == 1) {
if ((addr > UINT32_MAX) || ((UINT32_MAX + 1 - addr) < size))
return -FDT_ERR_BADVALUE;
fdt32_st(prop, (uint32_t)addr);
} else if (addr_cells == 2) {
fdt64_st(prop, addr);
} else {
return -FDT_ERR_BADNCELLS;
/* check validity of size */
prop += addr_cells * sizeof(fdt32_t);
if (size_cells == 1) {
if (size > UINT32_MAX)
fdt32_st(prop, (uint32_t)size);
} else if (size_cells == 2) {
fdt64_st(prop, size);
} else {
return fdt_appendprop(fdt, nodeoffset, name, data,
(addr_cells + size_cells) * sizeof(fdt32_t));
+} diff --git a/scripts/dtc/libfdt/fdt_empty_tree.c b/scripts/dtc/libfdt/fdt_empty_tree.c index f2ae9b77c2..49d54d44b8 100644 --- a/scripts/dtc/libfdt/fdt_empty_tree.c +++ b/scripts/dtc/libfdt/fdt_empty_tree.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
- Copyright (C) 2012 David Gibson, IBM Corporation.
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
diff --git a/scripts/dtc/libfdt/fdt_overlay.c b/scripts/dtc/libfdt/fdt_overlay.c index bf75388ec9..be71873366 100644 --- a/scripts/dtc/libfdt/fdt_overlay.c +++ b/scripts/dtc/libfdt/fdt_overlay.c @@ -1,53 +1,8 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
- Copyright (C) 2016 Free Electrons
- Copyright (C) 2016 NextThing Co.
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
@@ -93,11 +48,11 @@ static uint32_t overlay_get_target_phandle(const void *fdto, int fragment)
- @pathp: pointer which receives the path of the target (or NULL)
- overlay_get_target() retrieves the target offset in the base
- device tree of a fragment, no matter how the actual targetting is
- device tree of a fragment, no matter how the actual targeting is
- done (through a phandle or a path)
- returns:
the targetted node offset in the base device tree
the targeted node offset in the base device tree
Negative error code on error
static int overlay_get_target(const void *fdt, const void *fdto, @@ -697,7 +652,7 @@ static int get_path_len(const void *fdt, int nodeoffset) int len = 0, namelen; const char *name;
FDT_RO_PROBE(fdt); for (;;) { name = fdt_get_name(fdt, nodeoffset, &namelen);
@@ -778,26 +733,36 @@ static int overlay_symbol_update(void *fdt, void *fdto) /* keep end marker to avoid strlen() */ e = path + path_len;
/* format: /<fragment-name>/__overlay__/<relative-subnode-path> */
if (*path != '/') return -FDT_ERR_BADVALUE; /* get fragment name first */ s = strchr(path + 1, '/');
if (!s)
return -FDT_ERR_BADOVERLAY;
if (!s) {
/* Symbol refers to something that won't end
* up in the target tree */
continue;
} frag_name = path + 1; frag_name_len = s - path - 1; /* verify format; safe since "s" lies in \0 terminated prop */ len = sizeof("/__overlay__/") - 1;
if ((e - s) < len || memcmp(s, "/__overlay__/", len))
rel_path = s + len;
rel_path_len = e - rel_path;
if ((e - s) > len && (memcmp(s, "/__overlay__/", len) == 0)) {
/* /<fragment-name>/__overlay__/<relative-subnode-path> */
rel_path = s + len;
} else if ((e - s) == len
&& (memcmp(s, "/__overlay__", len - 1) == 0)) {
/* /<fragment-name>/__overlay__ */
rel_path = "";
rel_path_len = 0;
} else {
continue;
} /* find the fragment index in which the symbol lies */ ret = fdt_subnode_offset_namelen(fdto, 0, frag_name,
@@ -863,11 +828,15 @@ static int overlay_symbol_update(void *fdt, void *fdto)
int fdt_overlay_apply(void *fdt, void *fdto) {
uint32_t delta = fdt_get_max_phandle(fdt);
uint32_t delta; int ret;
FDT_CHECK_HEADER(fdto);
FDT_RO_PROBE(fdt);
FDT_RO_PROBE(fdto);
ret = fdt_find_max_phandle(fdt, &delta);
if (ret)
goto err; ret = overlay_adjust_local_phandles(fdto, delta); if (ret)
diff --git a/scripts/dtc/libfdt/fdt_ro.c b/scripts/dtc/libfdt/fdt_ro.c index dc499884e4..e398815485 100644 --- a/scripts/dtc/libfdt/fdt_ro.c +++ b/scripts/dtc/libfdt/fdt_ro.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
@@ -61,7 +16,7 @@ static int fdt_nodename_eq_(const void *fdt, int offset, int olen; const char *p = fdt_get_name(fdt, offset, &olen);
if (!p || olen < len)
if (!p || (fdt_chk_extra() && olen < len)) /* short match */ return 0;
@@ -76,46 +31,85 @@ static int fdt_nodename_eq_(const void *fdt, int offset, return 0; }
-const char *fdt_string(const void *fdt, int stroffset) -{
return (const char *)fdt + fdt_off_dt_strings(fdt) + stroffset;
-static int fdt_string_eq_(const void *fdt, int stroffset,
+const char *fdt_get_string(const void *fdt, int stroffset, int *lenp) {
const char *p = fdt_string(fdt, stroffset);
int32_t totalsize;
uint32_t absoffset;
size_t len;
int err;
const char *s, *n;
return (strlen(p) == len) && (memcmp(p, s, len) == 0);
if (!fdt_chk_extra()) {
s = (const char *)fdt + fdt_off_dt_strings(fdt) + stroffset;
int offset;
if (lenp)
*lenp = strlen(s);
return s;
err = totalsize;
if (totalsize < 0)
goto fail;
goto fail;
if (stroffset < 0)
goto fail;
if (!fdt_chk_version() || fdt_version(fdt) >= 17) {
goto fail;
goto fail;
len = -stroffset;
} else {
goto fail;
uint32_t phandle;
if (!n) {
goto fail;
return max_phandle;
if (lenp)
*lenp = n - s;
return s;
if (offset < 0)
+fail:
if (lenp)
*lenp = err;
return NULL;
continue;
int slen;
-int fdt_generate_phandle(const void *fdt, uint32_t *phandle) +int fdt_find_max_phandle(const void *fdt, uint32_t *phandle) { uint32_t max = 0; int offset = -1; @@ -137,6 +131,21 @@ int fdt_generate_phandle(const void *fdt, uint32_t *phandle) max = value; }
if (phandle)
*phandle = max;
uint32_t max;
int err;
if (err < 0)
return err;
@@ -146,21 +155,45 @@ int fdt_generate_phandle(const void *fdt, uint32_t *phandle) return 0; }
return NULL;
return NULL;
FDT_RO_PROBE(fdt);
int i = 0;
int i;
i++;
return i;
return i;
static int nextprop_(const void *fdt, int offset) @@ -192,7 +225,7 @@ int fdt_subnode_offset_namelen(const void *fdt, int offset, { int depth;
@@ -218,7 +251,7 @@ int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen) const char *p = path; int offset = 0;
@@ -268,13 +301,14 @@ const char *fdt_get_name(const void *fdt, int nodeoffset, int *len) const char *nameptr; int err;
goto fail;
goto fail; nameptr = nh->name;
if (fdt_version(fdt) < 0x10) {
if (fdt_chk_version() && fdt_version(fdt) < 0x10) { /* * For old FDT versions, match the naming conventions of V16: * give only the leaf name (after all /). The actual tree
@@ -325,7 +359,7 @@ static const struct fdt_property *fdt_get_property_by_offset_(const void *fdt, int err; const struct fdt_property *prop;
@@ -334,7 +368,7 @@ static const struct fdt_property *fdt_get_property_by_offset_(const void *fdt, prop = fdt_offset_ptr_(fdt, offset);
if (lenp)
} @@ -346,7 +380,7 @@ const struct fdt_property *fdt_get_property_by_offset(const void *fdt, /* Prior to version 16, properties may need realignment * and this API does not work. fdt_getprop_*() will, however. */
if (fdt_chk_version() && fdt_version(fdt) < 0x10) { if (lenp) *lenp = -FDT_ERR_BADVERSION; return NULL;
@@ -367,11 +401,12 @@ static const struct fdt_property *fdt_get_property_namelen_(const void *fdt, (offset = fdt_next_property_offset(fdt, offset))) { const struct fdt_property *prop;
if (!(prop = fdt_get_property_by_offset_(fdt, offset, lenp))) {
if (fdt_string_eq_(fdt, fdt32_to_cpu(prop->nameoff),
if (fdt_string_eq_(fdt, fdt32_ld(&prop->nameoff), name, namelen)) { if (poffset) *poffset = offset;
@@ -392,7 +427,7 @@ const struct fdt_property *fdt_get_property_namelen(const void *fdt, { /* Prior to version 16, properties may need realignment * and this API does not work. fdt_getprop_*() will, however. */
@@ -423,8 +458,8 @@ const void *fdt_getprop_namelen(const void *fdt, int nodeoffset, return NULL;
if (fdt_version(fdt) < 0x10 && (poffset + sizeof(*prop)) % 8 &&
fdt32_to_cpu(prop->len) >= 8)
(poffset + sizeof(*prop)) % 8 && fdt32_ld(&prop->len) >= 8) return prop->data + 4; return prop->data;
} @@ -437,12 +472,27 @@ const void *fdt_getprop_by_offset(const void *fdt, int offset, prop = fdt_get_property_by_offset_(fdt, offset, lenp); if (!prop) return NULL;
if (namep)
if (namep) {
const char *name;
int namelen;
&namelen);
if (!name) {
if (lenp)
*lenp = namelen;
return NULL;
*namep = name;
} else {
} /* Handle realignment */
if (fdt_version(fdt) < 0x10 && (offset + sizeof(*prop)) % 8 &&
(offset + sizeof(*prop)) % 8 && fdt32_ld(&prop->len) >= 8) return prop->data + 4; return prop->data;
} @@ -467,7 +517,7 @@ uint32_t fdt_get_phandle(const void *fdt, int nodeoffset) return 0; }
const char *fdt_get_alias_namelen(const void *fdt, @@ -493,7 +543,7 @@ int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen) int offset, depth, namelen; const char *name;
@@ -545,7 +595,7 @@ int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, int offset, depth; int supernodeoffset = -FDT_ERR_INTERNAL;
@@ -567,10 +617,12 @@ int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, } }
} @@ -582,7 +634,7 @@ int fdt_node_depth(const void *fdt, int nodeoffset)
@@ -604,7 +656,7 @@ int fdt_node_offset_by_prop_value(const void *fdt, int startoffset, const void *val; int len;
@@ -630,7 +682,7 @@ int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle) if ((phandle == 0) || (phandle == -1)) return -FDT_ERR_BADPHANDLE;
@@ -783,7 +835,7 @@ int fdt_node_offset_by_compatible(const void *fdt, int startoffset, { int offset, err;
@@ -802,3 +854,68 @@ int fdt_node_offset_by_compatible(const void *fdt, int startoffset,
+#if !defined(FDT_ASSUME_MASK) || FDT_ASSUME_MASK != 0xff +int fdt_check_full(const void *fdt, size_t bufsize) +{
int err;
int num_memrsv;
uint32_t tag;
unsigned depth = 0;
const void *prop;
if (err != 0)
return err;
if (num_memrsv < 0)
return num_memrsv;
while (1) {
if (nextoffset < 0)
return nextoffset;
switch (tag) {
case FDT_NOP:
break;
case FDT_END:
if (depth != 0)
depth++;
break;
case FDT_END_NODE:
if (depth == 0)
depth--;
break;
case FDT_PROP:
&err);
if (!prop)
return err;
break;
default:
return -FDT_ERR_INTERNAL;
+} +#endif diff --git a/scripts/dtc/libfdt/fdt_rw.c b/scripts/dtc/libfdt/fdt_rw.c index 9b829051e4..08e2981a44 100644 --- a/scripts/dtc/libfdt/fdt_rw.c +++ b/scripts/dtc/libfdt/fdt_rw.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
@@ -58,6 +13,8 @@ static int fdt_blocks_misordered_(const void *fdt, int mem_rsv_size, int struct_size) {
if (!fdt_chk_basic())
return false; return (fdt_off_mem_rsvmap(fdt) < FDT_ALIGN(sizeof(struct fdt_header), 8)) || (fdt_off_dt_struct(fdt) < (fdt_off_mem_rsvmap(fdt) + mem_rsv_size))
@@ -67,25 +24,27 @@ static int fdt_blocks_misordered_(const void *fdt, (fdt_off_dt_strings(fdt) + fdt_size_dt_strings(fdt))); }
-static int fdt_rw_check_header_(void *fdt) +static int fdt_rw_probe_(void *fdt) {
FDT_RO_PROBE(fdt);
if (fdt_version(fdt) < 17)
if (fdt_chk_version() && fdt_version(fdt) < 17) return -FDT_ERR_BADVERSION; if (fdt_blocks_misordered_(fdt, sizeof(struct fdt_reserve_entry), fdt_size_dt_struct(fdt))) return -FDT_ERR_BADLAYOUT;
if (fdt_version(fdt) > 17)
if (fdt_chk_version() && fdt_version(fdt) > 17) fdt_set_version(fdt, 17); return 0;
-#define FDT_RW_CHECK_HEADER(fdt) \ +#define FDT_RW_PROBE(fdt) \ { \ int err_; \
if ((err_ = fdt_rw_check_header_(fdt)) != 0) \
if (fdt_chk_extra() && (err_ = fdt_rw_probe_(fdt)) != 0) \ return err_; \ }
@@ -136,6 +95,14 @@ static int fdt_splice_struct_(void *fdt, void *p, return 0; }
+/* Must only be used to roll back in case of error */ +static void fdt_del_last_string_(void *fdt, const char *s) +{
int newlen = strlen(s) + 1;
fdt_set_size_dt_strings(fdt, fdt_size_dt_strings(fdt) - newlen);
static int fdt_splice_string_(void *fdt, int newlen) { void *p = (char *)fdt @@ -149,7 +116,16 @@ static int fdt_splice_string_(void *fdt, int newlen) return 0; }
-static int fdt_find_add_string_(void *fdt, const char *s) +/**
- fdt_find_add_string_() - Find or allocate a string
- @fdt: pointer to the device tree to check/adjust
- @s: string to find/add
- @allocated: Set to 0 if the string was found, 1 if not found and so
allocated. Ignored if !fdt_chk_basic()
- @return offset of string in the string table (whether found or added)
+static int fdt_find_add_string_(void *fdt, const char *s, int *allocated) { char *strtab = (char *)fdt + fdt_off_dt_strings(fdt); const char *p; @@ -157,6 +133,9 @@ static int fdt_find_add_string_(void *fdt, const char *s) int len = strlen(s) + 1; int err;
*allocated = 0;
p = fdt_find_string_(strtab, fdt_size_dt_strings(fdt), s); if (p) /* found it */
@@ -167,6 +146,9 @@ static int fdt_find_add_string_(void *fdt, const char *s) if (err) return err;
*allocated = 1;
memcpy(new, s, len); return (new - strtab);
} @@ -176,7 +158,7 @@ int fdt_add_mem_rsv(void *fdt, uint64_t address, uint64_t size) struct fdt_reserve_entry *re; int err;
FDT_RW_CHECK_HEADER(fdt);
FDT_RW_PROBE(fdt); re = fdt_mem_rsv_w_(fdt, fdt_num_mem_rsv(fdt)); err = fdt_splice_mem_rsv_(fdt, re, 0, 1);
@@ -192,7 +174,7 @@ int fdt_del_mem_rsv(void *fdt, int n) { struct fdt_reserve_entry *re = fdt_mem_rsv_w_(fdt, n);
FDT_RW_PROBE(fdt); if (n >= fdt_num_mem_rsv(fdt)) return -FDT_ERR_NOTFOUND;
@@ -225,11 +207,12 @@ static int fdt_add_property_(void *fdt, int nodeoffset, const char *name, int nextoffset; int namestroff; int err;
int allocated; if ((nextoffset = fdt_check_node_offset_(fdt, nodeoffset)) < 0) return nextoffset;
namestroff = fdt_find_add_string_(fdt, name);
namestroff = fdt_find_add_string_(fdt, name, &allocated); if (namestroff < 0) return namestroff;
@@ -237,8 +220,12 @@ static int fdt_add_property_(void *fdt, int nodeoffset, const char *name, proplen = sizeof(**prop) + FDT_TAGALIGN(len);
err = fdt_splice_struct_(fdt, *prop, 0, proplen);
if (err)
if (err) {
/* Delete the string if we failed to add it */
if (fdt_chk_basic() && allocated)
fdt_del_last_string_(fdt, name); return err;
} (*prop)->tag = cpu_to_fdt32(FDT_PROP); (*prop)->nameoff = cpu_to_fdt32(namestroff);
@@ -252,7 +239,7 @@ int fdt_set_name(void *fdt, int nodeoffset, const char *name) int oldlen, newlen; int err;
FDT_RW_PROBE(fdt); namep = (char *)(uintptr_t)fdt_get_name(fdt, nodeoffset, &oldlen); if (!namep)
@@ -275,7 +262,7 @@ int fdt_setprop_placeholder(void *fdt, int nodeoffset, const char *name, struct fdt_property *prop; int err;
FDT_RW_PROBE(fdt); err = fdt_resize_property_(fdt, nodeoffset, name, len, &prop); if (err == -FDT_ERR_NOTFOUND)
@@ -308,7 +295,7 @@ int fdt_appendprop(void *fdt, int nodeoffset, const char *name, struct fdt_property *prop; int err, oldlen, newlen;
FDT_RW_PROBE(fdt); prop = fdt_get_property_w(fdt, nodeoffset, name, &oldlen); if (prop) {
@@ -334,7 +321,7 @@ int fdt_delprop(void *fdt, int nodeoffset, const char *name) struct fdt_property *prop; int len, proplen;
FDT_RW_PROBE(fdt); prop = fdt_get_property_w(fdt, nodeoffset, name, &len); if (!prop)
@@ -354,7 +341,7 @@ int fdt_add_subnode_namelen(void *fdt, int parentoffset, uint32_t tag; fdt32_t *endtag;
FDT_RW_PROBE(fdt); offset = fdt_subnode_offset_namelen(fdt, parentoffset, name, namelen); if (offset >= 0)
@@ -394,7 +381,7 @@ int fdt_del_node(void *fdt, int nodeoffset) { int endoffset;
FDT_RW_PROBE(fdt); endoffset = fdt_node_end_offset_(fdt, nodeoffset); if (endoffset < 0)
@@ -435,12 +422,12 @@ int fdt_open_into(const void *fdt, void *buf, int bufsize) const char *fdtend = fdtstart + fdt_totalsize(fdt); char *tmp;
FDT_RO_PROBE(fdt); mem_rsv_size = (fdt_num_mem_rsv(fdt)+1) * sizeof(struct fdt_reserve_entry);
if (fdt_version(fdt) >= 17) {
if (!fdt_chk_version() || fdt_version(fdt) >= 17) { struct_size = fdt_size_dt_struct(fdt); } else { struct_size = 0;
@@ -494,7 +481,7 @@ int fdt_pack(void *fdt) { int mem_rsv_size;
FDT_RW_PROBE(fdt); mem_rsv_size = (fdt_num_mem_rsv(fdt)+1) * sizeof(struct fdt_reserve_entry);
diff --git a/scripts/dtc/libfdt/fdt_strerror.c b/scripts/dtc/libfdt/fdt_strerror.c index 9677a1887e..768db66ead 100644 --- a/scripts/dtc/libfdt/fdt_strerror.c +++ b/scripts/dtc/libfdt/fdt_strerror.c @@ -1,51 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
#include "libfdt_env.h" @@ -82,6 +38,7 @@ static struct fdt_errtabent fdt_errtable[] = { FDT_ERRTABENT(FDT_ERR_BADVALUE), FDT_ERRTABENT(FDT_ERR_BADOVERLAY), FDT_ERRTABENT(FDT_ERR_NOPHANDLES),
FDT_ERRTABENT(FDT_ERR_BADFLAGS),
}; #define FDT_ERRTABSIZE (sizeof(fdt_errtable) / sizeof(fdt_errtable[0]))
diff --git a/scripts/dtc/libfdt/fdt_sw.c b/scripts/dtc/libfdt/fdt_sw.c index d8ef748a72..a8c924675a 100644 --- a/scripts/dtc/libfdt/fdt_sw.c +++ b/scripts/dtc/libfdt/fdt_sw.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
@@ -55,21 +10,90 @@
#include "libfdt_internal.h"
-static int fdt_sw_check_header_(void *fdt) +static int fdt_sw_probe_(void *fdt) +{
return -FDT_ERR_BADSTATE;
else if (fdt_magic(fdt) != FDT_SW_MAGIC)
+#define FDT_SW_PROBE(fdt) \
int err; \
if (fdt_chk_basic() && (err = fdt_sw_probe_(fdt)) != 0) \
return err; \
+/* 'memrsv' state: Initial state after fdt_create()
- Allowed functions:
fdt_add_reservmap_entry()
fdt_finish_reservemap() [moves to 'struct' state]
+static int fdt_sw_probe_memrsv_(void *fdt) +{
int err = fdt_sw_probe_(fdt);
if (err)
return err;
if (fdt_chk_extra() && fdt_off_dt_strings(fdt) != 0)
+#define FDT_SW_PROBE_MEMRSV(fdt) \
int err; \
if (fdt_chk_extra() && (err = fdt_sw_probe_memrsv_(fdt)) != 0) \
return err; \
+/* 'struct' state: Enter this state after fdt_finish_reservemap()
fdt_begin_node()
fdt_end_node()
fdt_property*()
fdt_finish() [moves to 'complete' state]
+static int fdt_sw_probe_struct_(void *fdt) {
/* FIXME: should check more details about the header state */
int err;
if (err)
return err;
if (fdt_off_dt_strings(fdt) != fdt_totalsize(fdt))
return -FDT_ERR_BADSTATE; return 0;
-#define FDT_SW_CHECK_HEADER(fdt) \ +#define FDT_SW_PROBE_STRUCT(fdt) \ { \ int err; \
if ((err = fdt_sw_check_header_(fdt)) != 0) \
if (fdt_chk_extra() && (err = fdt_sw_probe_struct_(fdt)) != 0) \ return err; \ }
+static inline uint32_t sw_flags(void *fdt) +{
/* assert: (fdt_magic(fdt) == FDT_SW_MAGIC) */
return fdt_last_comp_version(fdt);
+/* 'complete' state: Enter this state after fdt_finish()
- Allowed functions: none
static void *fdt_grab_space_(void *fdt, size_t len) { int offset = fdt_size_dt_struct(fdt); @@ -85,38 +109,58 @@ static void *fdt_grab_space_(void *fdt, size_t len) return fdt_offset_ptr_w_(fdt, offset); }
-int fdt_create(void *buf, int bufsize) +int fdt_create_with_flags(void *buf, int bufsize, uint32_t flags) {
const size_t hdrsize = FDT_ALIGN(sizeof(struct fdt_header),
sizeof(struct fdt_reserve_entry)); void *fdt = buf;
if (bufsize < sizeof(struct fdt_header))
if (bufsize < hdrsize) return -FDT_ERR_NOSPACE;
if (flags & ~FDT_CREATE_FLAGS_ALL)
return -FDT_ERR_BADFLAGS;
memset(buf, 0, bufsize);
* magic and last_comp_version keep intermediate state during the fdt
* creation process, which is replaced with the proper FDT format by
* fdt_finish().
* flags should be accessed with sw_flags().
*/ fdt_set_magic(fdt, FDT_SW_MAGIC); fdt_set_version(fdt, FDT_LAST_SUPPORTED_VERSION);
fdt_set_last_comp_version(fdt, FDT_FIRST_SUPPORTED_VERSION);
fdt_set_last_comp_version(fdt, flags);
fdt_set_totalsize(fdt, bufsize);
fdt_set_off_mem_rsvmap(fdt, FDT_ALIGN(sizeof(struct fdt_header),
sizeof(struct fdt_reserve_entry)));
fdt_set_off_mem_rsvmap(fdt, hdrsize); fdt_set_off_dt_struct(fdt, fdt_off_mem_rsvmap(fdt));
fdt_set_off_dt_strings(fdt, bufsize);
fdt_set_off_dt_strings(fdt, 0); return 0;
+int fdt_create(void *buf, int bufsize) +{
return fdt_create_with_flags(buf, bufsize, 0);
int fdt_resize(void *fdt, void *buf, int bufsize) { size_t headsize, tailsize; char *oldtail, *newtail;
FDT_SW_CHECK_HEADER(fdt);
FDT_SW_PROBE(fdt); headsize = fdt_off_dt_struct(fdt) + fdt_size_dt_struct(fdt); tailsize = fdt_size_dt_strings(fdt);
if (fdt_chk_extra() && (headsize + tailsize) > fdt_totalsize(fdt))
if ((headsize + tailsize) > bufsize) return -FDT_ERR_NOSPACE;
@@ -133,8 +177,9 @@ int fdt_resize(void *fdt, void *buf, int bufsize) memmove(buf, fdt, headsize); }
fdt_set_off_dt_strings(buf, bufsize); fdt_set_totalsize(buf, bufsize);
if (fdt_off_dt_strings(buf))
fdt_set_off_dt_strings(buf, bufsize); return 0;
} @@ -144,10 +189,7 @@ int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size) struct fdt_reserve_entry *re; int offset;
if (fdt_size_dt_struct(fdt))
FDT_SW_PROBE_MEMRSV(fdt); offset = fdt_off_dt_struct(fdt); if ((offset + sizeof(*re)) > fdt_totalsize(fdt))
@@ -164,16 +206,23 @@ int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size)
int fdt_finish_reservemap(void *fdt) {
return fdt_add_reservemap_entry(fdt, 0, 0);
int err = fdt_add_reservemap_entry(fdt, 0, 0);
if (err)
return err;
fdt_set_off_dt_strings(fdt, fdt_totalsize(fdt));
int fdt_begin_node(void *fdt, const char *name) { struct fdt_node_header *nh;
int namelen = strlen(name) + 1;
int namelen;
FDT_SW_PROBE_STRUCT(fdt);
namelen = strlen(name) + 1; nh = fdt_grab_space_(fdt, sizeof(*nh) + FDT_TAGALIGN(namelen)); if (! nh) return -FDT_ERR_NOSPACE;
@@ -187,7 +236,7 @@ int fdt_end_node(void *fdt) { fdt32_t *en;
FDT_SW_PROBE_STRUCT(fdt); en = fdt_grab_space_(fdt, FDT_TAGSIZE); if (! en)
@@ -197,19 +246,13 @@ int fdt_end_node(void *fdt) return 0; }
-static int fdt_find_add_string_(void *fdt, const char *s) +static int fdt_add_string_(void *fdt, const char *s) { char *strtab = (char *)fdt + fdt_totalsize(fdt);
const char *p; int strtabsize = fdt_size_dt_strings(fdt); int len = strlen(s) + 1; int struct_top, offset;
p = fdt_find_string_(strtab - strtabsize, strtabsize, s);
if (p)
return p - strtab;
/* Add it */ offset = -strtabsize - len; struct_top = fdt_off_dt_struct(fdt) + fdt_size_dt_struct(fdt); if (fdt_totalsize(fdt) + offset < struct_top)
@@ -220,20 +263,56 @@ static int fdt_find_add_string_(void *fdt, const char *s) return offset; }
fdt_set_size_dt_strings(fdt, strtabsize - len);
+static int fdt_find_add_string_(void *fdt, const char *s, int *allocated) +{
const char *p;
*allocated = 0;
if (p)
return p - strtab;
*allocated = 1;
return fdt_add_string_(fdt, s);
int fdt_property_placeholder(void *fdt, const char *name, int len, void **valp) { struct fdt_property *prop; int nameoff;
int allocated;
nameoff = fdt_find_add_string_(fdt, name);
/* String de-duplication can be slow, _NO_NAME_DEDUP skips it */
if (sw_flags(fdt) & FDT_CREATE_FLAG_NO_NAME_DEDUP) {
allocated = 1;
nameoff = fdt_add_string_(fdt, name);
} else {
nameoff = fdt_find_add_string_(fdt, name, &allocated);
} if (nameoff == 0) return -FDT_ERR_NOSPACE; prop = fdt_grab_space_(fdt, sizeof(*prop) + FDT_TAGALIGN(len));
if (! prop)
if (! prop) {
if (allocated)
fdt_del_last_string_(fdt, name); return -FDT_ERR_NOSPACE;
} prop->tag = cpu_to_fdt32(FDT_PROP); prop->nameoff = cpu_to_fdt32(nameoff);
@@ -262,7 +341,7 @@ int fdt_finish(void *fdt) uint32_t tag; int offset, nextoffset;
FDT_SW_PROBE_STRUCT(fdt); /* Add terminator */ end = fdt_grab_space_(fdt, sizeof(*end));
@@ -295,6 +374,10 @@ int fdt_finish(void *fdt)
/* Finally, adjust the header */ fdt_set_totalsize(fdt, newstroffset + fdt_size_dt_strings(fdt));
/* And fix up fields that were keeping intermediate state. */
fdt_set_last_comp_version(fdt, FDT_FIRST_SUPPORTED_VERSION); fdt_set_magic(fdt, FDT_MAGIC);
} diff --git a/scripts/dtc/libfdt/fdt_wip.c b/scripts/dtc/libfdt/fdt_wip.c index 534c1cbbb2..f64139e0b3 100644 --- a/scripts/dtc/libfdt/fdt_wip.c +++ b/scripts/dtc/libfdt/fdt_wip.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
diff --git a/scripts/dtc/libfdt/libfdt.h b/scripts/dtc/libfdt/libfdt.h index c400f2f5d5..36fadcdea5 100644 --- a/scripts/dtc/libfdt/libfdt.h +++ b/scripts/dtc/libfdt/libfdt.h @@ -1,54 +1,9 @@ +/* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */ #ifndef LIBFDT_H #define LIBFDT_H /*
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
#include "libfdt_env.h" @@ -90,8 +45,9 @@
/* Error codes: codes for bad device tree blobs */ #define FDT_ERR_TRUNCATED 8
/* FDT_ERR_TRUNCATED: Structure block of the given device tree
* ends without an FDT_END tag. */
/* FDT_ERR_TRUNCATED: FDT or a sub-block is improperly
* terminated (overflows, goes outside allowed bounds, or
* isn't properly terminated). */
#define FDT_ERR_BADMAGIC 9 /* FDT_ERR_BADMAGIC: Given "device tree" appears not to be a * device tree at all - it is missing the flattened device @@ -137,7 +93,11 @@ /* FDT_ERR_NOPHANDLES: The device tree doesn't have any * phandle available anymore without causing an overflow */
-#define FDT_ERR_MAX 17 +#define FDT_ERR_BADFLAGS 18
/* FDT_ERR_BADFLAGS: The function was passed a flags field that
* contains invalid flags or an invalid combination of flags. */
+#define FDT_ERR_MAX 18
/* constants */ #define FDT_MAX_PHANDLE 0xfffffffe @@ -157,6 +117,61 @@ static inline void *fdt_offset_ptr_w(void *fdt, int offset, int checklen)
uint32_t fdt_next_tag(const void *fdt, int offset, int *nextoffset);
- Alignment helpers:
These helpers access words from a device tree blob. They're
built to work even with unaligned pointers on platforms (ike
ARM) that don't like unaligned loads and stores
+static inline uint32_t fdt32_ld(const fdt32_t *p) +{
const uint8_t *bp = (const uint8_t *)p;
return ((uint32_t)bp[0] << 24)
| ((uint32_t)bp[1] << 16)
| ((uint32_t)bp[2] << 8)
| bp[3];
+static inline void fdt32_st(void *property, uint32_t value) +{
uint8_t *bp = (uint8_t *)property;
bp[0] = value >> 24;
bp[1] = (value >> 16) & 0xff;
bp[2] = (value >> 8) & 0xff;
bp[3] = value & 0xff;
+static inline uint64_t fdt64_ld(const fdt64_t *p) +{
return ((uint64_t)bp[0] << 56)
| ((uint64_t)bp[1] << 48)
| ((uint64_t)bp[2] << 40)
| ((uint64_t)bp[3] << 32)
| ((uint64_t)bp[4] << 24)
| ((uint64_t)bp[5] << 16)
| ((uint64_t)bp[6] << 8)
| bp[7];
+static inline void fdt64_st(void *property, uint64_t value) +{
bp[0] = value >> 56;
bp[1] = (value >> 48) & 0xff;
bp[2] = (value >> 40) & 0xff;
bp[3] = (value >> 32) & 0xff;
bp[4] = (value >> 24) & 0xff;
bp[5] = (value >> 16) & 0xff;
bp[6] = (value >> 8) & 0xff;
bp[7] = value & 0xff;
/**********************************************************************/ /* Traversal functions */ /**********************************************************************/ @@ -199,7 +214,7 @@ int fdt_next_subnode(const void *fdt, int offset);
if ((node < 0) && (node != -FDT_ERR_NOT_FOUND)) {
if ((node < 0) && (node != -FDT_ERR_NOTFOUND)) {
Error handling
@@ -217,7 +232,7 @@ int fdt_next_subnode(const void *fdt, int offset); /* General functions */ /**********************************************************************/ #define fdt_get_header(fdt, field) \
(fdt32_to_cpu(((const struct fdt_header *)(fdt))->field))
(fdt32_ld(&((const struct fdt_header *)(fdt))->field))
#define fdt_magic(fdt) (fdt_get_header(fdt, magic)) #define fdt_totalsize(fdt) (fdt_get_header(fdt, totalsize)) #define fdt_off_dt_struct(fdt) (fdt_get_header(fdt, off_dt_struct)) @@ -248,18 +263,32 @@ fdt_set_hdr_(size_dt_struct); #undef fdt_set_hdr_
- fdt_check_header - sanity check a device tree or possible device tree
- fdt_header_size - return the size of the tree's header
- @fdt: pointer to a flattened device tree
+size_t fdt_header_size(const void *fdt);
- fdt_header_size_ - internal function which takes a version number
+size_t fdt_header_size_(uint32_t version);
- fdt_check_header - sanity check a device tree header
- @fdt: pointer to data which might be a flattened device tree
- fdt_check_header() checks that the given buffer contains what
- appears to be a flattened device tree with sane information in its
- header.
- appears to be a flattened device tree, and that the header contains
- valid information (to the extent that can be determined from the
- header alone).
- returns:
0, if the buffer appears to contain a valid device tree
-FDT_ERR_BADMAGIC,
-FDT_ERR_BADVERSION,
-FDT_ERR_BADSTATE, standard meanings, as above
-FDT_ERR_BADSTATE,
-FDT_ERR_TRUNCATED, standard meanings, as above
int fdt_check_header(const void *fdt);
@@ -288,6 +317,24 @@ int fdt_move(const void *fdt, void *buf, int bufsize); /* Read-only functions */ /**********************************************************************/
+int fdt_check_full(const void *fdt, size_t bufsize);
- fdt_get_string - retrieve a string from the strings block of a device tree
- @fdt: pointer to the device tree blob
- @stroffset: offset of the string within the strings block (native endian)
- @lenp: optional pointer to return the string's length
- fdt_get_string() retrieves a pointer to a single string from the
- strings block of the device tree blob at fdt, and optionally also
- returns the string's length in *lenp.
- returns:
a pointer to the string, on success
NULL, if stroffset is out of bounds, or doesn't point to a valid string
+const char *fdt_get_string(const void *fdt, int stroffset, int *lenp);
- fdt_string - retrieve a string from the strings block of a device tree
@@ -298,10 +345,24 @@ int fdt_move(const void *fdt, void *buf, int bufsize);
- returns:
const char *fdt_string(const void *fdt, int stroffset);
- fdt_find_max_phandle - find and return the highest phandle in a tree
- @phandle: return location for the highest phandle value found in the tree
- fdt_find_max_phandle() finds the highest phandle value in the given device
- tree. The value returned in @phandle is only valid if the function returns
- success.
- returns:
0 on success or a negative error code on failure
+int fdt_find_max_phandle(const void *fdt, uint32_t *phandle);
- fdt_get_max_phandle - retrieves the highest phandle in a tree
@@ -310,12 +371,24 @@ const char *fdt_string(const void *fdt, int stroffset);
- device tree. This will ignore badly formatted phandles, or phandles
- with a value of 0 or -1.
- This function is deprecated in favour of fdt_find_max_phandle().
- returns:
the highest phandle on success
0, if no phandle was found in the device tree
-1, if an error occurred
-uint32_t fdt_get_max_phandle(const void *fdt); +static inline uint32_t fdt_get_max_phandle(const void *fdt) +{
uint32_t phandle;
int err;
err = fdt_find_max_phandle(fdt, &phandle);
if (err < 0)
return (uint32_t)-1;
return phandle;
- fdt_generate_phandle - return a new, unused phandle for a device tree blob
@@ -522,7 +595,7 @@ int fdt_next_property_offset(const void *fdt, int offset);
if ((property < 0) && (property != -FDT_ERR_NOT_FOUND)) {
if ((property < 0) && (property != -FDT_ERR_NOTFOUND)) {
Error handling
@@ -625,7 +698,7 @@ static inline struct fdt_property *fdt_get_property_w(void *fdt, int nodeoffset, /**
- fdt_getprop_by_offset - retrieve the value of a property at a given offset
- @ffset: offset of the property to read
- @offset: offset of the property to read
- @namep: pointer to a string variable (will be overwritten) or NULL
- @lenp: pointer to an integer variable (will be overwritten) or NULL
@@ -734,7 +807,7 @@ uint32_t fdt_get_phandle(const void *fdt, int nodeoffset); /**
- fdt_get_alias_namelen - get alias based on substring
- @name: name of the alias to look up
- @name: name of the alias th look up
- @namelen: number of characters of name to consider
- Identical to fdt_get_alias(), but only examine the first namelen
@@ -1316,7 +1389,45 @@ int fdt_nop_node(void *fdt, int nodeoffset); /* Sequential write functions */ /**********************************************************************/
+/* fdt_create_with_flags flags */ +#define FDT_CREATE_FLAG_NO_NAME_DEDUP 0x1
/* FDT_CREATE_FLAG_NO_NAME_DEDUP: Do not try to de-duplicate property
* names in the fdt. This can result in faster creation times, but
* a larger fdt. */
+#define FDT_CREATE_FLAGS_ALL (FDT_CREATE_FLAG_NO_NAME_DEDUP)
- fdt_create_with_flags - begin creation of a new fdt
- @fdt: pointer to memory allocated where fdt will be created
- @bufsize: size of the memory space at fdt
- @flags: a valid combination of FDT_CREATE_FLAG_ flags, or 0.
- fdt_create_with_flags() begins the process of creating a new fdt with
- the sequential write interface.
- fdt creation process must end with fdt_finished() to produce a valid fdt.
- returns:
0, on success
-FDT_ERR_NOSPACE, bufsize is insufficient for a minimal fdt
-FDT_ERR_BADFLAGS, flags is not valid
+int fdt_create_with_flags(void *buf, int bufsize, uint32_t flags);
- fdt_create - begin creation of a new fdt
- fdt_create() is equivalent to fdt_create_with_flags() with flags=0.
- returns:
0, on success
int fdt_create(void *buf, int bufsize);
int fdt_resize(void *fdt, void *buf, int bufsize); int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size); int fdt_finish_reservemap(void *fdt); @@ -1787,6 +1898,43 @@ static inline int fdt_appendprop_cell(void *fdt, int nodeoffset, #define fdt_appendprop_string(fdt, nodeoffset, name, str) \ fdt_appendprop((fdt), (nodeoffset), (name), (str), strlen(str)+1)
- fdt_appendprop_addrrange - append a address range property
- @parent: offset of the parent node
- @nodeoffset: offset of the node to add a property at
- @name: name of property
- @addr: start address of a given range
- @size: size of a given range
- fdt_appendprop_addrrange() appends an address range value (start
- address and size) to the value of the named property in the given
- node, or creates a new property with that value if it does not
- already exist.
- If "name" is not specified, a default "reg" is used.
- Cell sizes are determined by parent's #address-cells and #size-cells.
- This function may insert data into the blob, and will therefore
- change the offsets of some existing nodes.
- returns:
0, on success
-FDT_ERR_BADLAYOUT,
-FDT_ERR_BADMAGIC,
-FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid
#address-cells property
-FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag
-FDT_ERR_BADSTATE,
-FDT_ERR_BADSTRUCTURE,
-FDT_ERR_BADVALUE, addr or size doesn't fit to respective cells size
-FDT_ERR_NOSPACE, there is insufficient free space in the blob to
contain a new property
const char *name, uint64_t addr, uint64_t size);
- fdt_delprop - delete a property
diff --git a/scripts/dtc/libfdt/libfdt_env.h b/scripts/dtc/libfdt/libfdt_env.h index 3ff9e28630..73b6d40450 100644 --- a/scripts/dtc/libfdt/libfdt_env.h +++ b/scripts/dtc/libfdt/libfdt_env.h @@ -1,55 +1,10 @@ +/* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */ #ifndef LIBFDT_ENV_H #define LIBFDT_ENV_H /*
modify it under the terms of the GNU General Public License as
published by the Free Software Foundation; either version 2 of the
License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public
License along with this library; if not, write to the Free
Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston,
MA 02110-1301 USA
- Alternatively,
without modification, are permitted provided that the following
conditions are met:
1. Redistributions of source code must retain the above
copyright notice, this list of conditions and the following
disclaimer.
2. Redistributions in binary form must reproduce the above
disclaimer in the documentation and/or other materials
provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdbool.h> @@ -57,6 +12,7 @@ #include <stdint.h> #include <stdlib.h> #include <string.h> +#include <limits.h>
#ifdef __CHECKER__ #define FDT_FORCE __attribute__((force)) diff --git a/scripts/dtc/libfdt/libfdt_internal.h b/scripts/dtc/libfdt/libfdt_internal.h index 7681e19229..5436e2ceea 100644 --- a/scripts/dtc/libfdt/libfdt_internal.h +++ b/scripts/dtc/libfdt/libfdt_internal.h @@ -1,65 +1,24 @@ +/* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */ #ifndef LIBFDT_INTERNAL_H #define LIBFDT_INTERNAL_H /*
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
#include <fdt.h>
#define FDT_ALIGN(x, a) (((x) + (a) - 1) & ~((a) - 1)) #define FDT_TAGALIGN(x) (FDT_ALIGN((x), FDT_TAGSIZE))
-#define FDT_CHECK_HEADER(fdt) \
int err_; \
if ((err_ = fdt_check_header(fdt)) != 0) \
return err_; \
+int fdt_ro_probe_(const void *fdt); +#define FDT_RO_PROBE(fdt) \
int totalsize_; \
if (fdt_chk_basic()) { \
totalsize_ = fdt_ro_probe_(fdt); \
if (totalsize_ < 0) \
return totalsize_; \
int fdt_check_node_offset_(const void *fdt, int offset); @@ -92,4 +51,87 @@ static inline struct fdt_reserve_entry *fdt_mem_rsv_w_(void *fdt, int n)
#define FDT_SW_MAGIC (~FDT_MAGIC)
+/**********************************************************************/ +/* Checking controls */ +/**********************************************************************/
+#ifndef FDT_ASSUME_MASK +#define FDT_ASSUME_MASK 0 +#endif
- Defines assumptions which can be enabled. Each of these can be enabled
- individually. For maximum saftey, don't enable any assumptions!
- For minimal code size and no safety, use FDT_ASSUME_PERFECT at your own risk.
- You should have another method of validating the device tree, such as a
- signature or hash check before using libfdt.
- For situations where security is not a concern it may be safe to enable
- FDT_ASSUME_FRIENDLY.
+enum {
* This does essentially no checks. Only the latest device-tree
* version is correctly handled. Incosistencies or errors in the device
* tree may cause undefined behaviour or crashes.
* If an error occurs when modifying the tree it may leave the tree in
* an intermediate (but valid) state. As an example, adding a property
* where there is insufficient space may result in the property name
* being added to the string table even though the property itself is
* not added to the struct section.
* Only use this if you have a fully validated device tree with
* the latest supported version and wish to minimise code size.
FDT_ASSUME_PERFECT = 0xff,
* This assumes that the device tree is sane. i.e. header metadata
* and basic hierarchy are correct.
* These checks will be sufficient if you have a valid device tree with
* no internal inconsistencies. With this assumption, libfdt will
* generally not return -FDT_ERR_INTERNAL, -FDT_ERR_BADLAYOUT, etc.
FDT_ASSUME_SANE = 1 << 0,
* This disables checks for device-tree version and removes all code
* which handles older versions.
* Only enable this if you know you have a device tree with the latest
* version.
FDT_ASSUME_LATEST = 1 << 1,
* This disables any extensive checking of parameters and the device
* tree, making various assumptions about correctness. Normal device
* trees produced by libfdt and the compiler should be handled safely.
* Malicious device trees and complete garbage may cause libfdt to
* behave badly or crash.
FDT_ASSUME_FRIENDLY = 1 << 2,
+/** fdt_chk_basic() - see if basic checking of params and DT data is enabled */ +static inline bool fdt_chk_basic(void) +{
return !(FDT_ASSUME_MASK & FDT_ASSUME_SANE);
+/** fdt_chk_version() - see if we need to handle old versions of the DT */ +static inline bool fdt_chk_version(void) +{
return !(FDT_ASSUME_MASK & FDT_ASSUME_LATEST);
+/** fdt_chk_extra() - see if extra checking is enabled */ +static inline bool fdt_chk_extra(void) +{
return !(FDT_ASSUME_MASK & FDT_ASSUME_FRIENDLY);
#endif /* LIBFDT_INTERNAL_H */ diff --git a/tools/libfdt/fdt_rw.c b/tools/libfdt/fdt_rw.c index 68fc7c8c88..7189f01429 100644 --- a/tools/libfdt/fdt_rw.c +++ b/tools/libfdt/fdt_rw.c @@ -11,6 +11,7 @@ int fdt_remove_unused_strings(const void *old, void *new) const char *str; int ret; int tag = FDT_PROP;
int allocated; /* Make a copy and remove the strings */ memcpy(new, old, size);
@@ -25,7 +26,7 @@ int fdt_remove_unused_strings(const void *old, void *new) new_prop = (struct fdt_property *)(unsigned long) fdt_get_property_by_offset(new, offset, NULL); str = fdt_string(old, fdt32_to_cpu(old_prop->nameoff));
ret = fdt_find_add_string_(new, str);
ret = fdt_find_add_string_(new, str, &allocated); if (ret < 0) return ret; new_prop->nameoff = cpu_to_fdt32(ret);
-- 2.24.0.rc0.303.g954a862665-goog
On Tue, Jan 7, 2020 at 5:43 AM Adam Ford aford173@gmail.com wrote:
On Sun, Oct 27, 2019 at 10:55 AM Simon Glass sjg@chromium.org wrote:
Bring over the fdt from this commit:
430419c (origin/master) tests: fix some python warnings
adding in the 'assumptions' series designed to reduce code size.
Signed-off-by: Simon Glass sjg@chromium.org
I don't know how, but this patch broke the am3517_evm board. I haven't had a chance to review other omap3 boards I have yet.
With this patch:
U-Boot SPL 2020.01-rc1-00163-gf0921f5098 (Jan 07 2020 - 05:31:57 -0600) Trying to boot from MMC1 spl_register_fat_device: fat register err - -1 spl_register_fat_device: fat register err - -1 spl_load_image_fat: error reading image u-boot.img, err - -1 SPL: failed to boot from all boot devices
If I revert this patch on master, the am3517_evm boots just fine. I'm open to trying stuff if you have ideas.
Go ahead and disregard that message. I pulled in the latest master after 2020.01 and the issue appears to have resolved itself. I didn't bisect, but I'm happy it works again. :-)
adam
adam
lib/libfdt/fdt_ro.c | 420 ++++++++++++++++++++------- scripts/dtc/libfdt/Makefile.libfdt | 7 + scripts/dtc/libfdt/fdt.c | 182 ++++++++---- scripts/dtc/libfdt/fdt.h | 47 +-- scripts/dtc/libfdt/fdt_addresses.c | 94 +++--- scripts/dtc/libfdt/fdt_empty_tree.c | 47 +-- scripts/dtc/libfdt/fdt_overlay.c | 91 ++---- scripts/dtc/libfdt/fdt_ro.c | 341 +++++++++++++++------- scripts/dtc/libfdt/fdt_rw.c | 119 ++++---- scripts/dtc/libfdt/fdt_strerror.c | 47 +-- scripts/dtc/libfdt/fdt_sw.c | 241 ++++++++++----- scripts/dtc/libfdt/fdt_wip.c | 47 +-- scripts/dtc/libfdt/libfdt.h | 268 +++++++++++++---- scripts/dtc/libfdt/libfdt_env.h | 48 +-- scripts/dtc/libfdt/libfdt_internal.h | 144 +++++---- tools/libfdt/fdt_rw.c | 3 +- 16 files changed, 1275 insertions(+), 871 deletions(-)
diff --git a/lib/libfdt/fdt_ro.c b/lib/libfdt/fdt_ro.c index 693de9aa5a..560041b603 100644 --- a/lib/libfdt/fdt_ro.c +++ b/lib/libfdt/fdt_ro.c @@ -14,12 +14,13 @@
-static int _fdt_nodename_eq(const void *fdt, int offset, +static int fdt_nodename_eq_(const void *fdt, int offset, const char *s, int len) {
const char *p = fdt_offset_ptr(fdt, offset + FDT_TAGSIZE, len+1);
int olen;
if (!p)
@@ -34,46 +35,85 @@ static int _fdt_nodename_eq(const void *fdt, int offset, return 0; }
-static int _fdt_string_eq(const void *fdt, int stroffset,
int32_t totalsize;
uint32_t absoffset;
size_t len;
int err;
const char *s, *n;
return (strnlen(p, len + 1) == len) && (memcmp(p, s, len) == 0);
-uint32_t fdt_get_max_phandle(const void *fdt) -{
uint32_t max_phandle = 0;
int offset;
if (lenp)
*lenp = strlen(s);
return s;
totalsize = fdt_ro_probe_(fdt);
err = totalsize;
if (totalsize < 0)
goto fail;
err = -FDT_ERR_BADOFFSET;
absoffset = stroffset + fdt_off_dt_strings(fdt);
if (absoffset >= totalsize)
goto fail;
len = totalsize - absoffset;
if (stroffset < 0)
goto fail;
if (stroffset >= fdt_size_dt_strings(fdt))
goto fail;
if ((fdt_size_dt_strings(fdt) - stroffset) < len)
len = fdt_size_dt_strings(fdt) - stroffset;
if ((stroffset >= 0)
|| (stroffset < -fdt_size_dt_strings(fdt)))
goto fail;
if ((-stroffset) < len)
len = -stroffset;
} else {
err = -FDT_ERR_INTERNAL;
goto fail;
for (offset = fdt_next_node(fdt, -1, NULL);;
offset = fdt_next_node(fdt, offset, NULL)) {
uint32_t phandle;
s = (const char *)fdt + absoffset;
n = memchr(s, '\0', len);
if (!n) {
/* missing terminating NULL */
err = -FDT_ERR_TRUNCATED;
goto fail;
if (offset == -FDT_ERR_NOTFOUND)
return max_phandle;
if (lenp)
*lenp = n - s;
return s;
if (offset < 0)
+fail:
if (lenp)
*lenp = err;
return NULL;
phandle = fdt_get_phandle(fdt, offset);
if (phandle == (uint32_t)-1)
continue;
+const char *fdt_string(const void *fdt, int stroffset) +{
return fdt_get_string(fdt, stroffset, NULL);
if (phandle > max_phandle)
max_phandle = phandle;
+static int fdt_string_eq_(const void *fdt, int stroffset,
int slen;
const char *p = fdt_get_string(fdt, stroffset, &slen);
return p && (slen == len) && (memcmp(p, s, len) == 0);
-int fdt_generate_phandle(const void *fdt, uint32_t *phandle) +int fdt_find_max_phandle(const void *fdt, uint32_t *phandle) { uint32_t max = 0; int offset = -1; @@ -95,6 +135,21 @@ int fdt_generate_phandle(const void *fdt, uint32_t *phandle) max = value; }
if (phandle)
*phandle = max;
+int fdt_generate_phandle(const void *fdt, uint32_t *phandle) +{
uint32_t max;
int err;
err = fdt_find_max_phandle(fdt, &max);
if (err < 0)
return err;
if (max == FDT_MAX_PHANDLE) return -FDT_ERR_NOPHANDLES;
@@ -104,24 +159,48 @@ int fdt_generate_phandle(const void *fdt, uint32_t *phandle) return 0; }
+static const struct fdt_reserve_entry *fdt_mem_rsv(const void *fdt, int n) +{
int offset = n * sizeof(struct fdt_reserve_entry);
int absoffset = fdt_off_mem_rsvmap(fdt) + offset;
if (absoffset < fdt_off_mem_rsvmap(fdt))
return NULL;
if (absoffset > fdt_totalsize(fdt) -
return NULL;
return fdt_mem_rsv_(fdt, n);
int fdt_get_mem_rsv(const void *fdt, int n, uint64_t *address, uint64_t *size) {
*address = fdt64_to_cpu(fdt_mem_rsv_(fdt, n)->address);
*size = fdt64_to_cpu(fdt_mem_rsv_(fdt, n)->size);
const struct fdt_reserve_entry *re;
FDT_RO_PROBE(fdt);
re = fdt_mem_rsv(fdt, n);
if (fdt_chk_extra() && !re)
return -FDT_ERR_BADOFFSET;
*address = fdt64_ld(&re->address);
*size = fdt64_ld(&re->size); return 0;
int fdt_num_mem_rsv(const void *fdt) {
int i = 0;
int i;
while (fdt64_to_cpu(fdt_mem_rsv_(fdt, i)->size) != 0)
i++;
return i;
for (i = 0; (re = fdt_mem_rsv(fdt, i)) != NULL; i++) {
if (fdt64_ld(&re->size) == 0)
return i;
-static int _nextprop(const void *fdt, int offset) +static int nextprop_(const void *fdt, int offset) { uint32_t tag; int nextoffset; @@ -150,13 +229,13 @@ int fdt_subnode_offset_namelen(const void *fdt, int offset, { int depth;
FDT_RO_PROBE(fdt); for (depth = 0; (offset >= 0) && (depth >= 0); offset = fdt_next_node(fdt, offset, &depth)) if ((depth == 1)
&& _fdt_nodename_eq(fdt, offset, name, namelen))
&& fdt_nodename_eq_(fdt, offset, name, namelen)) return offset; if (depth < 0)
@@ -170,36 +249,17 @@ int fdt_subnode_offset(const void *fdt, int parentoffset, return fdt_subnode_offset_namelen(fdt, parentoffset, name, strlen(name)); }
- Find the next of path separator, note we need to search for both '/' and ':'
- and then take the first one so that we do the right thing for e.g.
- "foo/bar:option" and "bar:option/otheroption", both of which happen, so
- first searching for either ':' or '/' does not work.
-static const char *fdt_path_next_separator(const char *path, int len) -{
const void *sep1 = memchr(path, '/', len);
const void *sep2 = memchr(path, ':', len);
if (sep1 && sep2)
return (sep1 < sep2) ? sep1 : sep2;
else if (sep1)
return sep1;
else
return sep2;
int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen) { const char *end = path + namelen; const char *p = path; int offset = 0;
FDT_RO_PROBE(fdt); /* see if we have an alias */ if (*path != '/') {
const char *q = fdt_path_next_separator(path, namelen);
const char *q = memchr(path, '/', end - p); if (!q) q = end;
@@ -212,17 +272,16 @@ int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen) p = q; }
while (*p && (p < end)) {
while (p < end) { const char *q;
while (*p == '/')
while (*p == '/') { p++;
if (*p == '\0' || *p == ':')
return offset;
q = fdt_path_next_separator(p, end - p);
if (!q)
if (p == end)
return offset;
q = memchr(p, '/', end - p);
if (! q) q = end; offset = fdt_subnode_offset_namelen(fdt, offset, p, q-p);
@@ -243,16 +302,35 @@ int fdt_path_offset(const void *fdt, const char *path) const char *fdt_get_name(const void *fdt, int nodeoffset, int *len) { const struct fdt_node_header *nh = fdt_offset_ptr_(fdt, nodeoffset);
if (((err = fdt_check_header(fdt)) != 0)
|| ((err = fdt_check_node_offset_(fdt, nodeoffset)) < 0))
(((err = fdt_ro_probe_(fdt)) < 0)
|| ((err = fdt_check_node_offset_(fdt, nodeoffset)) < 0)))
goto fail;
nameptr = nh->name;
* contents are loosely checked.
const char *leaf;
leaf = strrchr(nameptr, '/');
if (leaf == NULL) {
err = -FDT_ERR_BADSTRUCTURE; goto fail;
nameptr = leaf+1;
} if (len)
*len = strlen(nh->name);
*len = strlen(nameptr);
return nh->name;
return nameptr;
fail: if (len)
@@ -267,7 +345,7 @@ int fdt_first_property_offset(const void *fdt, int nodeoffset) if ((offset = fdt_check_node_offset_(fdt, nodeoffset)) < 0) return offset;
return _nextprop(fdt, offset);
return nextprop_(fdt, offset);
int fdt_next_property_offset(const void *fdt, int offset) @@ -275,17 +353,17 @@ int fdt_next_property_offset(const void *fdt, int offset) if ((offset = fdt_check_prop_offset_(fdt, offset)) < 0) return offset;
-const struct fdt_property *fdt_get_property_by_offset(const void *fdt,
int offset,
int *lenp)
+static const struct fdt_property *fdt_get_property_by_offset_(const void *fdt,
int offset,
int *lenp)
{ int err; const struct fdt_property *prop;
if ((err = fdt_check_prop_offset_(fdt, offset)) < 0) {
if (fdt_chk_basic() && (err = fdt_check_prop_offset_(fdt, offset)) < 0) { if (lenp) *lenp = err; return NULL;
@@ -294,28 +372,50 @@ const struct fdt_property *fdt_get_property_by_offset(const void *fdt, prop = fdt_offset_ptr_(fdt, offset);
if (lenp)
*lenp = fdt32_to_cpu(prop->len);
*lenp = fdt32_ld(&prop->len); return prop;
-const struct fdt_property *fdt_get_property_namelen(const void *fdt,
int offset,
const char *name,
int namelen, int *lenp)
+const struct fdt_property *fdt_get_property_by_offset(const void *fdt,
int offset,
int *lenp)
if (lenp)
return NULL;
return fdt_get_property_by_offset_(fdt, offset, lenp);
+static const struct fdt_property *fdt_get_property_namelen_(const void *fdt,
int offset,
const char *name,
int namelen,
int *lenp,
int *poffset)
{ for (offset = fdt_first_property_offset(fdt, offset); (offset >= 0); (offset = fdt_next_property_offset(fdt, offset))) { const struct fdt_property *prop;
if (!(prop = fdt_get_property_by_offset(fdt, offset, lenp))) {
if (fdt_chk_extra() && !prop) { offset = -FDT_ERR_INTERNAL; break; }
if (_fdt_string_eq(fdt, fdt32_to_cpu(prop->nameoff),
name, namelen))
name, namelen)) {
if (poffset)
*poffset = offset; return prop;
} } if (lenp)
@@ -323,6 +423,25 @@ const struct fdt_property *fdt_get_property_namelen(const void *fdt, return NULL; }
+const struct fdt_property *fdt_get_property_namelen(const void *fdt,
int offset,
const char *name,
if (lenp)
return NULL;
return fdt_get_property_namelen_(fdt, offset, name, namelen, lenp,
NULL);
const struct fdt_property *fdt_get_property(const void *fdt, int nodeoffset, const char *name, int *lenp) @@ -334,12 +453,18 @@ const struct fdt_property *fdt_get_property(const void *fdt, const void *fdt_getprop_namelen(const void *fdt, int nodeoffset, const char *name, int namelen, int *lenp) {
int poffset; const struct fdt_property *prop;
prop = fdt_get_property_namelen(fdt, nodeoffset, name, namelen, lenp);
prop = fdt_get_property_namelen_(fdt, nodeoffset, name, namelen, lenp,
&poffset); if (!prop) return NULL;
if (fdt_chk_version() && fdt_version(fdt) < 0x10 &&
@@ -348,11 +473,31 @@ const void *fdt_getprop_by_offset(const void *fdt, int offset, { const struct fdt_property *prop;
prop = fdt_get_property_by_offset(fdt, offset, lenp);
if (namep)
*namep = fdt_string(fdt, fdt32_to_cpu(prop->nameoff));
if (namep) {
const char *name;
int namelen;
if (fdt_chk_extra()) {
name = fdt_get_string(fdt, fdt32_ld(&prop->nameoff),
&namelen);
if (!name) {
if (lenp)
*lenp = namelen;
return NULL;
*namep = name;
} else {
*namep = fdt_string(fdt, fdt32_ld(&prop->nameoff));
@@ -376,7 +521,7 @@ uint32_t fdt_get_phandle(const void *fdt, int nodeoffset) return 0; }
return fdt32_to_cpu(*php);
return fdt32_ld(php);
const char *fdt_get_alias_namelen(const void *fdt, @@ -402,7 +547,7 @@ int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen) int offset, depth, namelen; const char *name;
FDT_RO_PROBE(fdt); if (buflen < 2) return -FDT_ERR_NOSPACE;
@@ -454,7 +599,7 @@ int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, int offset, depth; int supernodeoffset = -FDT_ERR_INTERNAL;
FDT_RO_PROBE(fdt); if (supernodedepth < 0) return -FDT_ERR_NOTFOUND;
@@ -476,10 +621,12 @@ int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, } }
if ((offset == -FDT_ERR_NOTFOUND) || (offset >= 0))
else if (offset == -FDT_ERR_BADOFFSET)
return -FDT_ERR_BADSTRUCTURE;
} return offset; /* error from fdt_next_node() */
} @@ -491,7 +638,7 @@ int fdt_node_depth(const void *fdt, int nodeoffset)
err = fdt_supernode_atdepth_offset(fdt, nodeoffset, 0, &nodedepth); if (err)
return (err < 0) ? err : -FDT_ERR_INTERNAL;
return (!fdt_chk_extra() || err < 0) ? err : -FDT_ERR_INTERNAL; return nodedepth;
@@ -513,7 +660,7 @@ int fdt_node_offset_by_prop_value(const void *fdt, int startoffset, const void *val; int len;
FDT_RO_PROBE(fdt); /* FIXME: The algorithm here is pretty horrible: we scan each * property of a node in fdt_getprop(), then if that didn't
@@ -539,7 +686,7 @@ int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle) if ((phandle == 0) || (phandle == -1)) return -FDT_ERR_BADPHANDLE;
FDT_RO_PROBE(fdt); /* FIXME: The algorithm here is pretty horrible: we * potentially scan each property of a node in
@@ -692,7 +839,7 @@ int fdt_node_offset_by_compatible(const void *fdt, int startoffset, { int offset, err;
FDT_RO_PROBE(fdt); /* FIXME: The algorithm here is pretty horrible: we scan each * property of a node in fdt_node_check_compatible(), then if
@@ -711,3 +858,68 @@ int fdt_node_offset_by_compatible(const void *fdt, int startoffset,
+#if !defined(CHECK_LEVEL) || CHECK_LEVEL > 0 +int fdt_check_full(const void *fdt, size_t bufsize) +{
int err;
int num_memrsv;
int offset, nextoffset = 0;
uint32_t tag;
unsigned depth = 0;
const void *prop;
const char *propname;
if (bufsize < FDT_V1_SIZE)
return -FDT_ERR_TRUNCATED;
err = fdt_check_header(fdt);
if (err != 0)
return err;
if (bufsize < fdt_totalsize(fdt))
num_memrsv = fdt_num_mem_rsv(fdt);
if (num_memrsv < 0)
return num_memrsv;
while (1) {
offset = nextoffset;
tag = fdt_next_tag(fdt, offset, &nextoffset);
if (nextoffset < 0)
return nextoffset;
switch (tag) {
case FDT_NOP:
break;
case FDT_END:
if (depth != 0)
case FDT_BEGIN_NODE:
depth++;
if (depth > INT_MAX)
break;
case FDT_END_NODE:
if (depth == 0)
depth--;
break;
case FDT_PROP:
prop = fdt_getprop_by_offset(fdt, offset, &propname,
&err);
if (!prop)
return err;
break;
default:
+} +#endif diff --git a/scripts/dtc/libfdt/Makefile.libfdt b/scripts/dtc/libfdt/Makefile.libfdt index 098b3f36e6..e54639738c 100644 --- a/scripts/dtc/libfdt/Makefile.libfdt +++ b/scripts/dtc/libfdt/Makefile.libfdt @@ -1,3 +1,4 @@ +# SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) # Makefile.libfdt # # This is not a complete Makefile of itself. Instead, it is designed to @@ -9,3 +10,9 @@ LIBFDT_VERSION = version.lds LIBFDT_SRCS = fdt.c fdt_ro.c fdt_wip.c fdt_sw.c fdt_rw.c fdt_strerror.c fdt_empty_tree.c \ fdt_addresses.c fdt_overlay.c LIBFDT_OBJS = $(LIBFDT_SRCS:%.c=%.o) +LIBFDT_LIB = libfdt-$(DTC_VERSION).$(SHAREDLIB_EXT)
+libfdt_clean:
@$(VECHO) CLEAN "(libfdt)"
rm -f $(STD_CLEANFILES:%=$(LIBFDT_dir)/%)
rm -f $(LIBFDT_dir)/$(LIBFDT_soname)
diff --git a/scripts/dtc/libfdt/fdt.c b/scripts/dtc/libfdt/fdt.c index 7855a17877..8e4cce3b9b 100644 --- a/scripts/dtc/libfdt/fdt.c +++ b/scripts/dtc/libfdt/fdt.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
- libfdt - Flat Device Tree manipulation
- Copyright (C) 2006 David Gibson, IBM Corporation.
- libfdt is dual licensed: you can use it either under the terms of
- the GPL, or the BSD license, at your option.
- a) This library is free software; you can redistribute it and/or
MA 02110-1301 USA
- Alternatively,
- b) Redistribution and use in source and binary forms, with or
conditions are met:
disclaimer.
@@ -55,14 +10,24 @@
-int fdt_check_header(const void *fdt) +/*
- Minimal sanity check for a read-only tree. fdt_ro_probe_() checks
- that the given buffer contains what appears to be a flattened
- device tree with sane information in its header.
+int32_t fdt_ro_probe_(const void *fdt) {
uint32_t totalsize = fdt_totalsize(fdt);
if (fdt_magic(fdt) == FDT_MAGIC) { /* Complete tree */
if (fdt_version(fdt) < FDT_FIRST_SUPPORTED_VERSION)
if (fdt_last_comp_version(fdt) > FDT_LAST_SUPPORTED_VERSION)
if (fdt_chk_version()) {
} } else if (fdt_magic(fdt) == FDT_SW_MAGIC) { /* Unfinished sequential-write blob */ if (fdt_size_dt_struct(fdt) == 0)
@@ -71,6 +36,96 @@ int fdt_check_header(const void *fdt) return -FDT_ERR_BADMAGIC; }
if (totalsize < INT32_MAX)
return totalsize;
else
+static int check_off_(uint32_t hdrsize, uint32_t totalsize, uint32_t off) +{
return (off >= hdrsize) && (off <= totalsize);
+static int check_block_(uint32_t hdrsize, uint32_t totalsize,
uint32_t base, uint32_t size)
if (!check_off_(hdrsize, totalsize, base))
return 0; /* block start out of bounds */
if ((base + size) < base)
return 0; /* overflow */
if (!check_off_(hdrsize, totalsize, base + size))
return 0; /* block end out of bounds */
return 1;
+size_t fdt_header_size_(uint32_t version) +{
if (version <= 1)
return FDT_V1_SIZE;
else if (version <= 2)
return FDT_V2_SIZE;
else if (version <= 3)
return FDT_V3_SIZE;
else if (version <= 16)
return FDT_V16_SIZE;
else
return FDT_V17_SIZE;
+size_t fdt_header_size(const void *fdt) +{
return fdt_chk_version() ? fdt_header_size_(fdt_version(fdt)) :
FDT_V17_SIZE;
+int fdt_check_header(const void *fdt) +{
size_t hdrsize;
if (fdt_magic(fdt) != FDT_MAGIC)
if ((fdt_version(fdt) < FDT_FIRST_SUPPORTED_VERSION)
FDT_LAST_SUPPORTED_VERSION))
if (fdt_version(fdt) < fdt_last_comp_version(fdt))
hdrsize = fdt_header_size(fdt);
if ((fdt_totalsize(fdt) < hdrsize)
|| (fdt_totalsize(fdt) > INT_MAX))
/* Bounds check memrsv block */
if (!check_off_(hdrsize, fdt_totalsize(fdt),
fdt_off_mem_rsvmap(fdt)))
/* Bounds check structure block */
if (fdt_chk_version() && fdt_version(fdt) < 17) {
fdt_off_dt_struct(fdt)))
} else {
if (!check_block_(hdrsize, fdt_totalsize(fdt),
fdt_off_dt_struct(fdt),
/* Bounds check strings block */
fdt_off_dt_strings(fdt),
@@ -78,12 +133,13 @@ const void *fdt_offset_ptr(const void *fdt, int offset, unsigned int len) { unsigned absoffset = offset + fdt_off_dt_struct(fdt);
if ((absoffset < offset)
|| ((absoffset + len) < absoffset)
|| (absoffset + len) > fdt_totalsize(fdt))
return NULL;
return NULL;
if (fdt_version(fdt) >= 0x11)
if (!fdt_chk_version() || fdt_version(fdt) >= 0x11) if (((offset + len) < offset) || ((offset + len) > fdt_size_dt_struct(fdt))) return NULL;
@@ -100,7 +156,7 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset)
*nextoffset = -FDT_ERR_TRUNCATED; tagp = fdt_offset_ptr(fdt, offset, FDT_TAGSIZE);
if (!tagp)
if (fdt_chk_basic() && !tagp) return FDT_END; /* premature end */ tag = fdt32_to_cpu(*tagp); offset += FDT_TAGSIZE;
@@ -112,18 +168,19 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset) do { p = fdt_offset_ptr(fdt, offset++, 1); } while (p && (*p != '\0'));
if (!p)
if (fdt_chk_basic() && !p) return FDT_END; /* premature end */ break; case FDT_PROP: lenp = fdt_offset_ptr(fdt, offset, sizeof(*lenp));
if (!lenp)
if (fdt_chk_basic() && !lenp) return FDT_END; /* premature end */ /* skip-name offset, length and value */ offset += sizeof(struct fdt_property) - FDT_TAGSIZE + fdt32_to_cpu(*lenp);
if (fdt_version(fdt) < 0x10 && fdt32_to_cpu(*lenp) >= 8 &&
fdt_version(fdt) < 0x10 && fdt32_to_cpu(*lenp) >= 8 && ((offset - fdt32_to_cpu(*lenp)) % 8) != 0) offset += 4; break;
@@ -137,7 +194,8 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset) return FDT_END; }
if (!fdt_offset_ptr(fdt, startoffset, offset - startoffset))
!fdt_offset_ptr(fdt, startoffset, offset - startoffset)) return FDT_END; /* premature end */ *nextoffset = FDT_TAGALIGN(offset);
@@ -244,7 +302,7 @@ const char *fdt_find_string_(const char *strtab, int tabsize, const char *s)
int fdt_move(const void *fdt, void *buf, int bufsize) {
FDT_CHECK_HEADER(fdt);
FDT_RO_PROBE(fdt); if (fdt_totalsize(fdt) > bufsize) return -FDT_ERR_NOSPACE;
diff --git a/scripts/dtc/libfdt/fdt.h b/scripts/dtc/libfdt/fdt.h index 74961f9026..f2e68807f2 100644 --- a/scripts/dtc/libfdt/fdt.h +++ b/scripts/dtc/libfdt/fdt.h @@ -1,55 +1,10 @@ +/* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */ #ifndef FDT_H #define FDT_H /*
- Copyright 2012 Kim Phillips, Freescale Semiconductor.
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
#ifndef __ASSEMBLY__ diff --git a/scripts/dtc/libfdt/fdt_addresses.c b/scripts/dtc/libfdt/fdt_addresses.c index 788c143113..9a82cd0ba2 100644 --- a/scripts/dtc/libfdt/fdt_addresses.c +++ b/scripts/dtc/libfdt/fdt_addresses.c @@ -1,53 +1,8 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
- Copyright (C) 2014 David Gibson david@gibson.dropbear.id.au
- Copyright (C) 2018 embedded brains GmbH
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
@@ -97,3 +52,50 @@ int fdt_size_cells(const void *fdt, int nodeoffset) return 1; return val; }
+/* This function assumes that [address|size]_cells is 1 or 2 */ +int fdt_appendprop_addrrange(void *fdt, int parent, int nodeoffset,
int addr_cells, size_cells, ret;
uint8_t data[sizeof(fdt64_t) * 2], *prop;
ret = fdt_address_cells(fdt, parent);
if (ret < 0)
return ret;
addr_cells = ret;
ret = fdt_size_cells(fdt, parent);
if (ret < 0)
return ret;
size_cells = ret;
/* check validity of address */
prop = data;
if (addr_cells == 1) {
if ((addr > UINT32_MAX) || ((UINT32_MAX + 1 - addr) < size))
return -FDT_ERR_BADVALUE;
fdt32_st(prop, (uint32_t)addr);
} else if (addr_cells == 2) {
fdt64_st(prop, addr);
} else {
return -FDT_ERR_BADNCELLS;
/* check validity of size */
prop += addr_cells * sizeof(fdt32_t);
if (size_cells == 1) {
if (size > UINT32_MAX)
fdt32_st(prop, (uint32_t)size);
} else if (size_cells == 2) {
fdt64_st(prop, size);
} else {
return fdt_appendprop(fdt, nodeoffset, name, data,
(addr_cells + size_cells) * sizeof(fdt32_t));
+} diff --git a/scripts/dtc/libfdt/fdt_empty_tree.c b/scripts/dtc/libfdt/fdt_empty_tree.c index f2ae9b77c2..49d54d44b8 100644 --- a/scripts/dtc/libfdt/fdt_empty_tree.c +++ b/scripts/dtc/libfdt/fdt_empty_tree.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
- Copyright (C) 2012 David Gibson, IBM Corporation.
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
diff --git a/scripts/dtc/libfdt/fdt_overlay.c b/scripts/dtc/libfdt/fdt_overlay.c index bf75388ec9..be71873366 100644 --- a/scripts/dtc/libfdt/fdt_overlay.c +++ b/scripts/dtc/libfdt/fdt_overlay.c @@ -1,53 +1,8 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
- Copyright (C) 2016 Free Electrons
- Copyright (C) 2016 NextThing Co.
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
@@ -93,11 +48,11 @@ static uint32_t overlay_get_target_phandle(const void *fdto, int fragment)
- @pathp: pointer which receives the path of the target (or NULL)
- overlay_get_target() retrieves the target offset in the base
- device tree of a fragment, no matter how the actual targetting is
- device tree of a fragment, no matter how the actual targeting is
- done (through a phandle or a path)
- returns:
the targetted node offset in the base device tree
the targeted node offset in the base device tree
Negative error code on error
static int overlay_get_target(const void *fdt, const void *fdto, @@ -697,7 +652,7 @@ static int get_path_len(const void *fdt, int nodeoffset) int len = 0, namelen; const char *name;
FDT_RO_PROBE(fdt); for (;;) { name = fdt_get_name(fdt, nodeoffset, &namelen);
@@ -778,26 +733,36 @@ static int overlay_symbol_update(void *fdt, void *fdto) /* keep end marker to avoid strlen() */ e = path + path_len;
/* format: /<fragment-name>/__overlay__/<relative-subnode-path> */
if (*path != '/') return -FDT_ERR_BADVALUE; /* get fragment name first */ s = strchr(path + 1, '/');
if (!s)
return -FDT_ERR_BADOVERLAY;
if (!s) {
/* Symbol refers to something that won't end
* up in the target tree */
continue;
} frag_name = path + 1; frag_name_len = s - path - 1; /* verify format; safe since "s" lies in \0 terminated prop */ len = sizeof("/__overlay__/") - 1;
if ((e - s) < len || memcmp(s, "/__overlay__/", len))
rel_path = s + len;
rel_path_len = e - rel_path;
if ((e - s) > len && (memcmp(s, "/__overlay__/", len) == 0)) {
/* /<fragment-name>/__overlay__/<relative-subnode-path> */
rel_path = s + len;
} else if ((e - s) == len
&& (memcmp(s, "/__overlay__", len - 1) == 0)) {
/* /<fragment-name>/__overlay__ */
rel_path = "";
rel_path_len = 0;
} else {
continue;
} /* find the fragment index in which the symbol lies */ ret = fdt_subnode_offset_namelen(fdto, 0, frag_name,
@@ -863,11 +828,15 @@ static int overlay_symbol_update(void *fdt, void *fdto)
int fdt_overlay_apply(void *fdt, void *fdto) {
uint32_t delta = fdt_get_max_phandle(fdt);
uint32_t delta; int ret;
FDT_CHECK_HEADER(fdto);
FDT_RO_PROBE(fdt);
FDT_RO_PROBE(fdto);
ret = fdt_find_max_phandle(fdt, &delta);
if (ret)
goto err; ret = overlay_adjust_local_phandles(fdto, delta); if (ret)
diff --git a/scripts/dtc/libfdt/fdt_ro.c b/scripts/dtc/libfdt/fdt_ro.c index dc499884e4..e398815485 100644 --- a/scripts/dtc/libfdt/fdt_ro.c +++ b/scripts/dtc/libfdt/fdt_ro.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
@@ -61,7 +16,7 @@ static int fdt_nodename_eq_(const void *fdt, int offset, int olen; const char *p = fdt_get_name(fdt, offset, &olen);
if (!p || olen < len)
if (!p || (fdt_chk_extra() && olen < len)) /* short match */ return 0;
@@ -76,46 +31,85 @@ static int fdt_nodename_eq_(const void *fdt, int offset, return 0; }
-const char *fdt_string(const void *fdt, int stroffset) -{
return (const char *)fdt + fdt_off_dt_strings(fdt) + stroffset;
-static int fdt_string_eq_(const void *fdt, int stroffset,
+const char *fdt_get_string(const void *fdt, int stroffset, int *lenp) {
const char *p = fdt_string(fdt, stroffset);
int32_t totalsize;
uint32_t absoffset;
size_t len;
int err;
const char *s, *n;
return (strlen(p) == len) && (memcmp(p, s, len) == 0);
if (!fdt_chk_extra()) {
s = (const char *)fdt + fdt_off_dt_strings(fdt) + stroffset;
int offset;
if (lenp)
*lenp = strlen(s);
return s;
err = totalsize;
if (totalsize < 0)
goto fail;
goto fail;
if (stroffset < 0)
goto fail;
goto fail;
goto fail;
len = -stroffset;
} else {
goto fail;
uint32_t phandle;
if (!n) {
goto fail;
return max_phandle;
if (lenp)
*lenp = n - s;
return s;
if (offset < 0)
+fail:
if (lenp)
*lenp = err;
return NULL;
continue;
int slen;
-int fdt_generate_phandle(const void *fdt, uint32_t *phandle) +int fdt_find_max_phandle(const void *fdt, uint32_t *phandle) { uint32_t max = 0; int offset = -1; @@ -137,6 +131,21 @@ int fdt_generate_phandle(const void *fdt, uint32_t *phandle) max = value; }
if (phandle)
*phandle = max;
uint32_t max;
int err;
if (err < 0)
return err;
@@ -146,21 +155,45 @@ int fdt_generate_phandle(const void *fdt, uint32_t *phandle) return 0; }
return NULL;
return NULL;
FDT_RO_PROBE(fdt);
int i = 0;
int i;
i++;
return i;
return i;
static int nextprop_(const void *fdt, int offset) @@ -192,7 +225,7 @@ int fdt_subnode_offset_namelen(const void *fdt, int offset, { int depth;
@@ -218,7 +251,7 @@ int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen) const char *p = path; int offset = 0;
@@ -268,13 +301,14 @@ const char *fdt_get_name(const void *fdt, int nodeoffset, int *len) const char *nameptr; int err;
goto fail;
goto fail; nameptr = nh->name;
if (fdt_version(fdt) < 0x10) {
if (fdt_chk_version() && fdt_version(fdt) < 0x10) { /* * For old FDT versions, match the naming conventions of V16: * give only the leaf name (after all /). The actual tree
@@ -325,7 +359,7 @@ static const struct fdt_property *fdt_get_property_by_offset_(const void *fdt, int err; const struct fdt_property *prop;
@@ -334,7 +368,7 @@ static const struct fdt_property *fdt_get_property_by_offset_(const void *fdt, prop = fdt_offset_ptr_(fdt, offset);
if (lenp)
} @@ -346,7 +380,7 @@ const struct fdt_property *fdt_get_property_by_offset(const void *fdt, /* Prior to version 16, properties may need realignment * and this API does not work. fdt_getprop_*() will, however. */
if (fdt_chk_version() && fdt_version(fdt) < 0x10) { if (lenp) *lenp = -FDT_ERR_BADVERSION; return NULL;
@@ -367,11 +401,12 @@ static const struct fdt_property *fdt_get_property_namelen_(const void *fdt, (offset = fdt_next_property_offset(fdt, offset))) { const struct fdt_property *prop;
if (!(prop = fdt_get_property_by_offset_(fdt, offset, lenp))) {
prop = fdt_get_property_by_offset_(fdt, offset, lenp);
if (fdt_string_eq_(fdt, fdt32_to_cpu(prop->nameoff),
if (fdt_string_eq_(fdt, fdt32_ld(&prop->nameoff), name, namelen)) { if (poffset) *poffset = offset;
@@ -392,7 +427,7 @@ const struct fdt_property *fdt_get_property_namelen(const void *fdt, { /* Prior to version 16, properties may need realignment * and this API does not work. fdt_getprop_*() will, however. */
@@ -423,8 +458,8 @@ const void *fdt_getprop_namelen(const void *fdt, int nodeoffset, return NULL;
/* Handle realignment */
if (fdt_version(fdt) < 0x10 && (poffset + sizeof(*prop)) % 8 &&
fdt32_to_cpu(prop->len) >= 8)
(poffset + sizeof(*prop)) % 8 && fdt32_ld(&prop->len) >= 8) return prop->data + 4; return prop->data;
} @@ -437,12 +472,27 @@ const void *fdt_getprop_by_offset(const void *fdt, int offset, prop = fdt_get_property_by_offset_(fdt, offset, lenp); if (!prop) return NULL;
if (namep)
if (namep) {
const char *name;
int namelen;
&namelen);
if (!name) {
if (lenp)
*lenp = namelen;
return NULL;
*namep = name;
} else {
} /* Handle realignment */
if (fdt_version(fdt) < 0x10 && (offset + sizeof(*prop)) % 8 &&
(offset + sizeof(*prop)) % 8 && fdt32_ld(&prop->len) >= 8) return prop->data + 4; return prop->data;
} @@ -467,7 +517,7 @@ uint32_t fdt_get_phandle(const void *fdt, int nodeoffset) return 0; }
const char *fdt_get_alias_namelen(const void *fdt, @@ -493,7 +543,7 @@ int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen) int offset, depth, namelen; const char *name;
@@ -545,7 +595,7 @@ int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, int offset, depth; int supernodeoffset = -FDT_ERR_INTERNAL;
@@ -567,10 +617,12 @@ int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, } }
} @@ -582,7 +634,7 @@ int fdt_node_depth(const void *fdt, int nodeoffset)
@@ -604,7 +656,7 @@ int fdt_node_offset_by_prop_value(const void *fdt, int startoffset, const void *val; int len;
@@ -630,7 +682,7 @@ int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle) if ((phandle == 0) || (phandle == -1)) return -FDT_ERR_BADPHANDLE;
@@ -783,7 +835,7 @@ int fdt_node_offset_by_compatible(const void *fdt, int startoffset, { int offset, err;
@@ -802,3 +854,68 @@ int fdt_node_offset_by_compatible(const void *fdt, int startoffset,
+#if !defined(FDT_ASSUME_MASK) || FDT_ASSUME_MASK != 0xff +int fdt_check_full(const void *fdt, size_t bufsize) +{
int err;
int num_memrsv;
uint32_t tag;
unsigned depth = 0;
const void *prop;
if (err != 0)
return err;
if (num_memrsv < 0)
return num_memrsv;
while (1) {
if (nextoffset < 0)
return nextoffset;
switch (tag) {
case FDT_NOP:
break;
case FDT_END:
if (depth != 0)
depth++;
break;
case FDT_END_NODE:
if (depth == 0)
depth--;
break;
case FDT_PROP:
&err);
if (!prop)
return err;
break;
default:
return -FDT_ERR_INTERNAL;
+} +#endif diff --git a/scripts/dtc/libfdt/fdt_rw.c b/scripts/dtc/libfdt/fdt_rw.c index 9b829051e4..08e2981a44 100644 --- a/scripts/dtc/libfdt/fdt_rw.c +++ b/scripts/dtc/libfdt/fdt_rw.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
@@ -58,6 +13,8 @@ static int fdt_blocks_misordered_(const void *fdt, int mem_rsv_size, int struct_size) {
if (!fdt_chk_basic())
return false; return (fdt_off_mem_rsvmap(fdt) < FDT_ALIGN(sizeof(struct fdt_header), 8)) || (fdt_off_dt_struct(fdt) < (fdt_off_mem_rsvmap(fdt) + mem_rsv_size))
@@ -67,25 +24,27 @@ static int fdt_blocks_misordered_(const void *fdt, (fdt_off_dt_strings(fdt) + fdt_size_dt_strings(fdt))); }
-static int fdt_rw_check_header_(void *fdt) +static int fdt_rw_probe_(void *fdt) {
FDT_RO_PROBE(fdt);
if (fdt_version(fdt) < 17)
if (fdt_chk_version() && fdt_version(fdt) < 17) return -FDT_ERR_BADVERSION; if (fdt_blocks_misordered_(fdt, sizeof(struct fdt_reserve_entry), fdt_size_dt_struct(fdt))) return -FDT_ERR_BADLAYOUT;
if (fdt_version(fdt) > 17)
if (fdt_chk_version() && fdt_version(fdt) > 17) fdt_set_version(fdt, 17); return 0;
-#define FDT_RW_CHECK_HEADER(fdt) \ +#define FDT_RW_PROBE(fdt) \ { \ int err_; \
if ((err_ = fdt_rw_check_header_(fdt)) != 0) \
if (fdt_chk_extra() && (err_ = fdt_rw_probe_(fdt)) != 0) \ return err_; \ }
@@ -136,6 +95,14 @@ static int fdt_splice_struct_(void *fdt, void *p, return 0; }
+/* Must only be used to roll back in case of error */ +static void fdt_del_last_string_(void *fdt, const char *s) +{
int newlen = strlen(s) + 1;
fdt_set_size_dt_strings(fdt, fdt_size_dt_strings(fdt) - newlen);
static int fdt_splice_string_(void *fdt, int newlen) { void *p = (char *)fdt @@ -149,7 +116,16 @@ static int fdt_splice_string_(void *fdt, int newlen) return 0; }
-static int fdt_find_add_string_(void *fdt, const char *s) +/**
- fdt_find_add_string_() - Find or allocate a string
- @fdt: pointer to the device tree to check/adjust
- @s: string to find/add
- @allocated: Set to 0 if the string was found, 1 if not found and so
allocated. Ignored if !fdt_chk_basic()
- @return offset of string in the string table (whether found or added)
+static int fdt_find_add_string_(void *fdt, const char *s, int *allocated) { char *strtab = (char *)fdt + fdt_off_dt_strings(fdt); const char *p; @@ -157,6 +133,9 @@ static int fdt_find_add_string_(void *fdt, const char *s) int len = strlen(s) + 1; int err;
*allocated = 0;
p = fdt_find_string_(strtab, fdt_size_dt_strings(fdt), s); if (p) /* found it */
@@ -167,6 +146,9 @@ static int fdt_find_add_string_(void *fdt, const char *s) if (err) return err;
*allocated = 1;
memcpy(new, s, len); return (new - strtab);
} @@ -176,7 +158,7 @@ int fdt_add_mem_rsv(void *fdt, uint64_t address, uint64_t size) struct fdt_reserve_entry *re; int err;
FDT_RW_CHECK_HEADER(fdt);
FDT_RW_PROBE(fdt); re = fdt_mem_rsv_w_(fdt, fdt_num_mem_rsv(fdt)); err = fdt_splice_mem_rsv_(fdt, re, 0, 1);
@@ -192,7 +174,7 @@ int fdt_del_mem_rsv(void *fdt, int n) { struct fdt_reserve_entry *re = fdt_mem_rsv_w_(fdt, n);
FDT_RW_PROBE(fdt); if (n >= fdt_num_mem_rsv(fdt)) return -FDT_ERR_NOTFOUND;
@@ -225,11 +207,12 @@ static int fdt_add_property_(void *fdt, int nodeoffset, const char *name, int nextoffset; int namestroff; int err;
int allocated; if ((nextoffset = fdt_check_node_offset_(fdt, nodeoffset)) < 0) return nextoffset;
namestroff = fdt_find_add_string_(fdt, name);
namestroff = fdt_find_add_string_(fdt, name, &allocated); if (namestroff < 0) return namestroff;
@@ -237,8 +220,12 @@ static int fdt_add_property_(void *fdt, int nodeoffset, const char *name, proplen = sizeof(**prop) + FDT_TAGALIGN(len);
err = fdt_splice_struct_(fdt, *prop, 0, proplen);
if (err)
if (err) {
/* Delete the string if we failed to add it */
if (fdt_chk_basic() && allocated)
fdt_del_last_string_(fdt, name); return err;
} (*prop)->tag = cpu_to_fdt32(FDT_PROP); (*prop)->nameoff = cpu_to_fdt32(namestroff);
@@ -252,7 +239,7 @@ int fdt_set_name(void *fdt, int nodeoffset, const char *name) int oldlen, newlen; int err;
FDT_RW_PROBE(fdt); namep = (char *)(uintptr_t)fdt_get_name(fdt, nodeoffset, &oldlen); if (!namep)
@@ -275,7 +262,7 @@ int fdt_setprop_placeholder(void *fdt, int nodeoffset, const char *name, struct fdt_property *prop; int err;
FDT_RW_PROBE(fdt); err = fdt_resize_property_(fdt, nodeoffset, name, len, &prop); if (err == -FDT_ERR_NOTFOUND)
@@ -308,7 +295,7 @@ int fdt_appendprop(void *fdt, int nodeoffset, const char *name, struct fdt_property *prop; int err, oldlen, newlen;
FDT_RW_PROBE(fdt); prop = fdt_get_property_w(fdt, nodeoffset, name, &oldlen); if (prop) {
@@ -334,7 +321,7 @@ int fdt_delprop(void *fdt, int nodeoffset, const char *name) struct fdt_property *prop; int len, proplen;
FDT_RW_PROBE(fdt); prop = fdt_get_property_w(fdt, nodeoffset, name, &len); if (!prop)
@@ -354,7 +341,7 @@ int fdt_add_subnode_namelen(void *fdt, int parentoffset, uint32_t tag; fdt32_t *endtag;
FDT_RW_PROBE(fdt); offset = fdt_subnode_offset_namelen(fdt, parentoffset, name, namelen); if (offset >= 0)
@@ -394,7 +381,7 @@ int fdt_del_node(void *fdt, int nodeoffset) { int endoffset;
FDT_RW_PROBE(fdt); endoffset = fdt_node_end_offset_(fdt, nodeoffset); if (endoffset < 0)
@@ -435,12 +422,12 @@ int fdt_open_into(const void *fdt, void *buf, int bufsize) const char *fdtend = fdtstart + fdt_totalsize(fdt); char *tmp;
FDT_RO_PROBE(fdt); mem_rsv_size = (fdt_num_mem_rsv(fdt)+1) * sizeof(struct fdt_reserve_entry);
if (fdt_version(fdt) >= 17) {
if (!fdt_chk_version() || fdt_version(fdt) >= 17) { struct_size = fdt_size_dt_struct(fdt); } else { struct_size = 0;
@@ -494,7 +481,7 @@ int fdt_pack(void *fdt) { int mem_rsv_size;
FDT_RW_PROBE(fdt); mem_rsv_size = (fdt_num_mem_rsv(fdt)+1) * sizeof(struct fdt_reserve_entry);
diff --git a/scripts/dtc/libfdt/fdt_strerror.c b/scripts/dtc/libfdt/fdt_strerror.c index 9677a1887e..768db66ead 100644 --- a/scripts/dtc/libfdt/fdt_strerror.c +++ b/scripts/dtc/libfdt/fdt_strerror.c @@ -1,51 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
#include "libfdt_env.h" @@ -82,6 +38,7 @@ static struct fdt_errtabent fdt_errtable[] = { FDT_ERRTABENT(FDT_ERR_BADVALUE), FDT_ERRTABENT(FDT_ERR_BADOVERLAY), FDT_ERRTABENT(FDT_ERR_NOPHANDLES),
FDT_ERRTABENT(FDT_ERR_BADFLAGS),
}; #define FDT_ERRTABSIZE (sizeof(fdt_errtable) / sizeof(fdt_errtable[0]))
diff --git a/scripts/dtc/libfdt/fdt_sw.c b/scripts/dtc/libfdt/fdt_sw.c index d8ef748a72..a8c924675a 100644 --- a/scripts/dtc/libfdt/fdt_sw.c +++ b/scripts/dtc/libfdt/fdt_sw.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
@@ -55,21 +10,90 @@
#include "libfdt_internal.h"
-static int fdt_sw_check_header_(void *fdt) +static int fdt_sw_probe_(void *fdt) +{
return -FDT_ERR_BADSTATE;
else if (fdt_magic(fdt) != FDT_SW_MAGIC)
+#define FDT_SW_PROBE(fdt) \
int err; \
if (fdt_chk_basic() && (err = fdt_sw_probe_(fdt)) != 0) \
return err; \
+/* 'memrsv' state: Initial state after fdt_create()
- Allowed functions:
fdt_add_reservmap_entry()
fdt_finish_reservemap() [moves to 'struct' state]
+static int fdt_sw_probe_memrsv_(void *fdt) +{
int err = fdt_sw_probe_(fdt);
if (err)
return err;
if (fdt_chk_extra() && fdt_off_dt_strings(fdt) != 0)
+#define FDT_SW_PROBE_MEMRSV(fdt) \
int err; \
if (fdt_chk_extra() && (err = fdt_sw_probe_memrsv_(fdt)) != 0) \
return err; \
+/* 'struct' state: Enter this state after fdt_finish_reservemap()
fdt_begin_node()
fdt_end_node()
fdt_property*()
fdt_finish() [moves to 'complete' state]
+static int fdt_sw_probe_struct_(void *fdt) {
/* FIXME: should check more details about the header state */
int err;
if (err)
return err;
if (fdt_off_dt_strings(fdt) != fdt_totalsize(fdt))
return -FDT_ERR_BADSTATE; return 0;
-#define FDT_SW_CHECK_HEADER(fdt) \ +#define FDT_SW_PROBE_STRUCT(fdt) \ { \ int err; \
if ((err = fdt_sw_check_header_(fdt)) != 0) \
if (fdt_chk_extra() && (err = fdt_sw_probe_struct_(fdt)) != 0) \ return err; \ }
+static inline uint32_t sw_flags(void *fdt) +{
/* assert: (fdt_magic(fdt) == FDT_SW_MAGIC) */
return fdt_last_comp_version(fdt);
+/* 'complete' state: Enter this state after fdt_finish()
- Allowed functions: none
static void *fdt_grab_space_(void *fdt, size_t len) { int offset = fdt_size_dt_struct(fdt); @@ -85,38 +109,58 @@ static void *fdt_grab_space_(void *fdt, size_t len) return fdt_offset_ptr_w_(fdt, offset); }
-int fdt_create(void *buf, int bufsize) +int fdt_create_with_flags(void *buf, int bufsize, uint32_t flags) {
const size_t hdrsize = FDT_ALIGN(sizeof(struct fdt_header),
sizeof(struct fdt_reserve_entry)); void *fdt = buf;
if (bufsize < sizeof(struct fdt_header))
if (bufsize < hdrsize) return -FDT_ERR_NOSPACE;
if (flags & ~FDT_CREATE_FLAGS_ALL)
return -FDT_ERR_BADFLAGS;
memset(buf, 0, bufsize);
* magic and last_comp_version keep intermediate state during the fdt
* creation process, which is replaced with the proper FDT format by
* fdt_finish().
* flags should be accessed with sw_flags().
*/ fdt_set_magic(fdt, FDT_SW_MAGIC); fdt_set_version(fdt, FDT_LAST_SUPPORTED_VERSION);
fdt_set_last_comp_version(fdt, flags);
fdt_set_totalsize(fdt, bufsize);
fdt_set_off_mem_rsvmap(fdt, FDT_ALIGN(sizeof(struct fdt_header),
sizeof(struct fdt_reserve_entry)));
fdt_set_off_mem_rsvmap(fdt, hdrsize); fdt_set_off_dt_struct(fdt, fdt_off_mem_rsvmap(fdt));
fdt_set_off_dt_strings(fdt, bufsize);
fdt_set_off_dt_strings(fdt, 0); return 0;
+int fdt_create(void *buf, int bufsize) +{
return fdt_create_with_flags(buf, bufsize, 0);
int fdt_resize(void *fdt, void *buf, int bufsize) { size_t headsize, tailsize; char *oldtail, *newtail;
FDT_SW_CHECK_HEADER(fdt);
FDT_SW_PROBE(fdt); headsize = fdt_off_dt_struct(fdt) + fdt_size_dt_struct(fdt); tailsize = fdt_size_dt_strings(fdt);
if (fdt_chk_extra() && (headsize + tailsize) > fdt_totalsize(fdt))
if ((headsize + tailsize) > bufsize) return -FDT_ERR_NOSPACE;
@@ -133,8 +177,9 @@ int fdt_resize(void *fdt, void *buf, int bufsize) memmove(buf, fdt, headsize); }
fdt_set_off_dt_strings(buf, bufsize); fdt_set_totalsize(buf, bufsize);
if (fdt_off_dt_strings(buf))
fdt_set_off_dt_strings(buf, bufsize); return 0;
} @@ -144,10 +189,7 @@ int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size) struct fdt_reserve_entry *re; int offset;
if (fdt_size_dt_struct(fdt))
FDT_SW_PROBE_MEMRSV(fdt); offset = fdt_off_dt_struct(fdt); if ((offset + sizeof(*re)) > fdt_totalsize(fdt))
@@ -164,16 +206,23 @@ int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size)
int fdt_finish_reservemap(void *fdt) {
return fdt_add_reservemap_entry(fdt, 0, 0);
int err = fdt_add_reservemap_entry(fdt, 0, 0);
if (err)
return err;
fdt_set_off_dt_strings(fdt, fdt_totalsize(fdt));
int fdt_begin_node(void *fdt, const char *name) { struct fdt_node_header *nh;
int namelen = strlen(name) + 1;
int namelen;
FDT_SW_PROBE_STRUCT(fdt);
namelen = strlen(name) + 1; nh = fdt_grab_space_(fdt, sizeof(*nh) + FDT_TAGALIGN(namelen)); if (! nh) return -FDT_ERR_NOSPACE;
@@ -187,7 +236,7 @@ int fdt_end_node(void *fdt) { fdt32_t *en;
FDT_SW_PROBE_STRUCT(fdt); en = fdt_grab_space_(fdt, FDT_TAGSIZE); if (! en)
@@ -197,19 +246,13 @@ int fdt_end_node(void *fdt) return 0; }
-static int fdt_find_add_string_(void *fdt, const char *s) +static int fdt_add_string_(void *fdt, const char *s) { char *strtab = (char *)fdt + fdt_totalsize(fdt);
const char *p; int strtabsize = fdt_size_dt_strings(fdt); int len = strlen(s) + 1; int struct_top, offset;
p = fdt_find_string_(strtab - strtabsize, strtabsize, s);
if (p)
return p - strtab;
/* Add it */ offset = -strtabsize - len; struct_top = fdt_off_dt_struct(fdt) + fdt_size_dt_struct(fdt); if (fdt_totalsize(fdt) + offset < struct_top)
@@ -220,20 +263,56 @@ static int fdt_find_add_string_(void *fdt, const char *s) return offset; }
fdt_set_size_dt_strings(fdt, strtabsize - len);
+static int fdt_find_add_string_(void *fdt, const char *s, int *allocated) +{
const char *p;
*allocated = 0;
if (p)
return p - strtab;
*allocated = 1;
return fdt_add_string_(fdt, s);
int fdt_property_placeholder(void *fdt, const char *name, int len, void **valp) { struct fdt_property *prop; int nameoff;
int allocated;
nameoff = fdt_find_add_string_(fdt, name);
/* String de-duplication can be slow, _NO_NAME_DEDUP skips it */
if (sw_flags(fdt) & FDT_CREATE_FLAG_NO_NAME_DEDUP) {
allocated = 1;
nameoff = fdt_add_string_(fdt, name);
} else {
nameoff = fdt_find_add_string_(fdt, name, &allocated);
} if (nameoff == 0) return -FDT_ERR_NOSPACE; prop = fdt_grab_space_(fdt, sizeof(*prop) + FDT_TAGALIGN(len));
if (! prop)
if (! prop) {
if (allocated)
fdt_del_last_string_(fdt, name); return -FDT_ERR_NOSPACE;
} prop->tag = cpu_to_fdt32(FDT_PROP); prop->nameoff = cpu_to_fdt32(nameoff);
@@ -262,7 +341,7 @@ int fdt_finish(void *fdt) uint32_t tag; int offset, nextoffset;
FDT_SW_PROBE_STRUCT(fdt); /* Add terminator */ end = fdt_grab_space_(fdt, sizeof(*end));
@@ -295,6 +374,10 @@ int fdt_finish(void *fdt)
/* Finally, adjust the header */ fdt_set_totalsize(fdt, newstroffset + fdt_size_dt_strings(fdt));
/* And fix up fields that were keeping intermediate state. */
fdt_set_last_comp_version(fdt, FDT_FIRST_SUPPORTED_VERSION); fdt_set_magic(fdt, FDT_MAGIC);
} diff --git a/scripts/dtc/libfdt/fdt_wip.c b/scripts/dtc/libfdt/fdt_wip.c index 534c1cbbb2..f64139e0b3 100644 --- a/scripts/dtc/libfdt/fdt_wip.c +++ b/scripts/dtc/libfdt/fdt_wip.c @@ -1,52 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) /*
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
diff --git a/scripts/dtc/libfdt/libfdt.h b/scripts/dtc/libfdt/libfdt.h index c400f2f5d5..36fadcdea5 100644 --- a/scripts/dtc/libfdt/libfdt.h +++ b/scripts/dtc/libfdt/libfdt.h @@ -1,54 +1,9 @@ +/* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */ #ifndef LIBFDT_H #define LIBFDT_H /*
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
#include "libfdt_env.h" @@ -90,8 +45,9 @@
/* Error codes: codes for bad device tree blobs */ #define FDT_ERR_TRUNCATED 8
/* FDT_ERR_TRUNCATED: Structure block of the given device tree
* ends without an FDT_END tag. */
/* FDT_ERR_TRUNCATED: FDT or a sub-block is improperly
* terminated (overflows, goes outside allowed bounds, or
* isn't properly terminated). */
#define FDT_ERR_BADMAGIC 9 /* FDT_ERR_BADMAGIC: Given "device tree" appears not to be a * device tree at all - it is missing the flattened device @@ -137,7 +93,11 @@ /* FDT_ERR_NOPHANDLES: The device tree doesn't have any * phandle available anymore without causing an overflow */
-#define FDT_ERR_MAX 17 +#define FDT_ERR_BADFLAGS 18
/* FDT_ERR_BADFLAGS: The function was passed a flags field that
* contains invalid flags or an invalid combination of flags. */
+#define FDT_ERR_MAX 18
/* constants */ #define FDT_MAX_PHANDLE 0xfffffffe @@ -157,6 +117,61 @@ static inline void *fdt_offset_ptr_w(void *fdt, int offset, int checklen)
uint32_t fdt_next_tag(const void *fdt, int offset, int *nextoffset);
- Alignment helpers:
These helpers access words from a device tree blob. They're
built to work even with unaligned pointers on platforms (ike
ARM) that don't like unaligned loads and stores
+static inline uint32_t fdt32_ld(const fdt32_t *p) +{
const uint8_t *bp = (const uint8_t *)p;
return ((uint32_t)bp[0] << 24)
| ((uint32_t)bp[1] << 16)
| ((uint32_t)bp[2] << 8)
| bp[3];
+static inline void fdt32_st(void *property, uint32_t value) +{
uint8_t *bp = (uint8_t *)property;
bp[0] = value >> 24;
bp[1] = (value >> 16) & 0xff;
bp[2] = (value >> 8) & 0xff;
bp[3] = value & 0xff;
+static inline uint64_t fdt64_ld(const fdt64_t *p) +{
return ((uint64_t)bp[0] << 56)
| ((uint64_t)bp[1] << 48)
| ((uint64_t)bp[2] << 40)
| ((uint64_t)bp[3] << 32)
| ((uint64_t)bp[4] << 24)
| ((uint64_t)bp[5] << 16)
| ((uint64_t)bp[6] << 8)
| bp[7];
+static inline void fdt64_st(void *property, uint64_t value) +{
bp[0] = value >> 56;
bp[1] = (value >> 48) & 0xff;
bp[2] = (value >> 40) & 0xff;
bp[3] = (value >> 32) & 0xff;
bp[4] = (value >> 24) & 0xff;
bp[5] = (value >> 16) & 0xff;
bp[6] = (value >> 8) & 0xff;
bp[7] = value & 0xff;
/**********************************************************************/ /* Traversal functions */ /**********************************************************************/ @@ -199,7 +214,7 @@ int fdt_next_subnode(const void *fdt, int offset);
if ((node < 0) && (node != -FDT_ERR_NOT_FOUND)) {
if ((node < 0) && (node != -FDT_ERR_NOTFOUND)) {
Error handling
@@ -217,7 +232,7 @@ int fdt_next_subnode(const void *fdt, int offset); /* General functions */ /**********************************************************************/ #define fdt_get_header(fdt, field) \
(fdt32_to_cpu(((const struct fdt_header *)(fdt))->field))
(fdt32_ld(&((const struct fdt_header *)(fdt))->field))
#define fdt_magic(fdt) (fdt_get_header(fdt, magic)) #define fdt_totalsize(fdt) (fdt_get_header(fdt, totalsize)) #define fdt_off_dt_struct(fdt) (fdt_get_header(fdt, off_dt_struct)) @@ -248,18 +263,32 @@ fdt_set_hdr_(size_dt_struct); #undef fdt_set_hdr_
- fdt_check_header - sanity check a device tree or possible device tree
- fdt_header_size - return the size of the tree's header
- @fdt: pointer to a flattened device tree
+size_t fdt_header_size(const void *fdt);
- fdt_header_size_ - internal function which takes a version number
+size_t fdt_header_size_(uint32_t version);
- fdt_check_header - sanity check a device tree header
- @fdt: pointer to data which might be a flattened device tree
- fdt_check_header() checks that the given buffer contains what
- appears to be a flattened device tree with sane information in its
- header.
- appears to be a flattened device tree, and that the header contains
- valid information (to the extent that can be determined from the
- header alone).
- returns:
0, if the buffer appears to contain a valid device tree
-FDT_ERR_BADMAGIC,
-FDT_ERR_BADVERSION,
-FDT_ERR_BADSTATE, standard meanings, as above
-FDT_ERR_BADSTATE,
-FDT_ERR_TRUNCATED, standard meanings, as above
int fdt_check_header(const void *fdt);
@@ -288,6 +317,24 @@ int fdt_move(const void *fdt, void *buf, int bufsize); /* Read-only functions */ /**********************************************************************/
+int fdt_check_full(const void *fdt, size_t bufsize);
- fdt_get_string - retrieve a string from the strings block of a device tree
- @fdt: pointer to the device tree blob
- @stroffset: offset of the string within the strings block (native endian)
- @lenp: optional pointer to return the string's length
- fdt_get_string() retrieves a pointer to a single string from the
- strings block of the device tree blob at fdt, and optionally also
- returns the string's length in *lenp.
- returns:
a pointer to the string, on success
NULL, if stroffset is out of bounds, or doesn't point to a valid string
+const char *fdt_get_string(const void *fdt, int stroffset, int *lenp);
- fdt_string - retrieve a string from the strings block of a device tree
@@ -298,10 +345,24 @@ int fdt_move(const void *fdt, void *buf, int bufsize);
- returns:
const char *fdt_string(const void *fdt, int stroffset);
- fdt_find_max_phandle - find and return the highest phandle in a tree
- @phandle: return location for the highest phandle value found in the tree
- fdt_find_max_phandle() finds the highest phandle value in the given device
- tree. The value returned in @phandle is only valid if the function returns
- success.
- returns:
0 on success or a negative error code on failure
+int fdt_find_max_phandle(const void *fdt, uint32_t *phandle);
- fdt_get_max_phandle - retrieves the highest phandle in a tree
@@ -310,12 +371,24 @@ const char *fdt_string(const void *fdt, int stroffset);
- device tree. This will ignore badly formatted phandles, or phandles
- with a value of 0 or -1.
- This function is deprecated in favour of fdt_find_max_phandle().
- returns:
the highest phandle on success
0, if no phandle was found in the device tree
-1, if an error occurred
-uint32_t fdt_get_max_phandle(const void *fdt); +static inline uint32_t fdt_get_max_phandle(const void *fdt) +{
uint32_t phandle;
int err;
err = fdt_find_max_phandle(fdt, &phandle);
if (err < 0)
return (uint32_t)-1;
return phandle;
- fdt_generate_phandle - return a new, unused phandle for a device tree blob
@@ -522,7 +595,7 @@ int fdt_next_property_offset(const void *fdt, int offset);
if ((property < 0) && (property != -FDT_ERR_NOT_FOUND)) {
if ((property < 0) && (property != -FDT_ERR_NOTFOUND)) {
Error handling
@@ -625,7 +698,7 @@ static inline struct fdt_property *fdt_get_property_w(void *fdt, int nodeoffset, /**
- fdt_getprop_by_offset - retrieve the value of a property at a given offset
- @ffset: offset of the property to read
- @offset: offset of the property to read
- @namep: pointer to a string variable (will be overwritten) or NULL
- @lenp: pointer to an integer variable (will be overwritten) or NULL
@@ -734,7 +807,7 @@ uint32_t fdt_get_phandle(const void *fdt, int nodeoffset); /**
- fdt_get_alias_namelen - get alias based on substring
- @name: name of the alias to look up
- @name: name of the alias th look up
- @namelen: number of characters of name to consider
- Identical to fdt_get_alias(), but only examine the first namelen
@@ -1316,7 +1389,45 @@ int fdt_nop_node(void *fdt, int nodeoffset); /* Sequential write functions */ /**********************************************************************/
+/* fdt_create_with_flags flags */ +#define FDT_CREATE_FLAG_NO_NAME_DEDUP 0x1
/* FDT_CREATE_FLAG_NO_NAME_DEDUP: Do not try to de-duplicate property
* names in the fdt. This can result in faster creation times, but
* a larger fdt. */
+#define FDT_CREATE_FLAGS_ALL (FDT_CREATE_FLAG_NO_NAME_DEDUP)
- fdt_create_with_flags - begin creation of a new fdt
- @fdt: pointer to memory allocated where fdt will be created
- @bufsize: size of the memory space at fdt
- @flags: a valid combination of FDT_CREATE_FLAG_ flags, or 0.
- fdt_create_with_flags() begins the process of creating a new fdt with
- the sequential write interface.
- fdt creation process must end with fdt_finished() to produce a valid fdt.
- returns:
0, on success
-FDT_ERR_NOSPACE, bufsize is insufficient for a minimal fdt
-FDT_ERR_BADFLAGS, flags is not valid
+int fdt_create_with_flags(void *buf, int bufsize, uint32_t flags);
- fdt_create - begin creation of a new fdt
- fdt_create() is equivalent to fdt_create_with_flags() with flags=0.
- returns:
0, on success
int fdt_create(void *buf, int bufsize);
int fdt_resize(void *fdt, void *buf, int bufsize); int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size); int fdt_finish_reservemap(void *fdt); @@ -1787,6 +1898,43 @@ static inline int fdt_appendprop_cell(void *fdt, int nodeoffset, #define fdt_appendprop_string(fdt, nodeoffset, name, str) \ fdt_appendprop((fdt), (nodeoffset), (name), (str), strlen(str)+1)
- fdt_appendprop_addrrange - append a address range property
- @parent: offset of the parent node
- @nodeoffset: offset of the node to add a property at
- @name: name of property
- @addr: start address of a given range
- @size: size of a given range
- fdt_appendprop_addrrange() appends an address range value (start
- address and size) to the value of the named property in the given
- node, or creates a new property with that value if it does not
- already exist.
- If "name" is not specified, a default "reg" is used.
- Cell sizes are determined by parent's #address-cells and #size-cells.
- This function may insert data into the blob, and will therefore
- change the offsets of some existing nodes.
- returns:
0, on success
-FDT_ERR_BADLAYOUT,
-FDT_ERR_BADMAGIC,
-FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid
#address-cells property
-FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag
-FDT_ERR_BADSTATE,
-FDT_ERR_BADSTRUCTURE,
-FDT_ERR_BADVALUE, addr or size doesn't fit to respective cells size
-FDT_ERR_NOSPACE, there is insufficient free space in the blob to
contain a new property
const char *name, uint64_t addr, uint64_t size);
- fdt_delprop - delete a property
diff --git a/scripts/dtc/libfdt/libfdt_env.h b/scripts/dtc/libfdt/libfdt_env.h index 3ff9e28630..73b6d40450 100644 --- a/scripts/dtc/libfdt/libfdt_env.h +++ b/scripts/dtc/libfdt/libfdt_env.h @@ -1,55 +1,10 @@ +/* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */ #ifndef LIBFDT_ENV_H #define LIBFDT_ENV_H /*
modify it under the terms of the GNU General Public License as
published by the Free Software Foundation; either version 2 of the
License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public
License along with this library; if not, write to the Free
Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston,
MA 02110-1301 USA
- Alternatively,
without modification, are permitted provided that the following
conditions are met:
1. Redistributions of source code must retain the above
copyright notice, this list of conditions and the following
disclaimer.
2. Redistributions in binary form must reproduce the above
disclaimer in the documentation and/or other materials
provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdbool.h> @@ -57,6 +12,7 @@ #include <stdint.h> #include <stdlib.h> #include <string.h> +#include <limits.h>
#ifdef __CHECKER__ #define FDT_FORCE __attribute__((force)) diff --git a/scripts/dtc/libfdt/libfdt_internal.h b/scripts/dtc/libfdt/libfdt_internal.h index 7681e19229..5436e2ceea 100644 --- a/scripts/dtc/libfdt/libfdt_internal.h +++ b/scripts/dtc/libfdt/libfdt_internal.h @@ -1,65 +1,24 @@ +/* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */ #ifndef LIBFDT_INTERNAL_H #define LIBFDT_INTERNAL_H /*
MA 02110-1301 USA
- Alternatively,
conditions are met:
disclaimer.
#include <fdt.h>
#define FDT_ALIGN(x, a) (((x) + (a) - 1) & ~((a) - 1)) #define FDT_TAGALIGN(x) (FDT_ALIGN((x), FDT_TAGSIZE))
-#define FDT_CHECK_HEADER(fdt) \
int err_; \
if ((err_ = fdt_check_header(fdt)) != 0) \
return err_; \
+int fdt_ro_probe_(const void *fdt); +#define FDT_RO_PROBE(fdt) \
int totalsize_; \
if (fdt_chk_basic()) { \
totalsize_ = fdt_ro_probe_(fdt); \
if (totalsize_ < 0) \
return totalsize_; \
int fdt_check_node_offset_(const void *fdt, int offset); @@ -92,4 +51,87 @@ static inline struct fdt_reserve_entry *fdt_mem_rsv_w_(void *fdt, int n)
#define FDT_SW_MAGIC (~FDT_MAGIC)
+/**********************************************************************/ +/* Checking controls */ +/**********************************************************************/
+#ifndef FDT_ASSUME_MASK +#define FDT_ASSUME_MASK 0 +#endif
- Defines assumptions which can be enabled. Each of these can be enabled
- individually. For maximum saftey, don't enable any assumptions!
- For minimal code size and no safety, use FDT_ASSUME_PERFECT at your own risk.
- You should have another method of validating the device tree, such as a
- signature or hash check before using libfdt.
- For situations where security is not a concern it may be safe to enable
- FDT_ASSUME_FRIENDLY.
+enum {
* This does essentially no checks. Only the latest device-tree
* version is correctly handled. Incosistencies or errors in the device
* tree may cause undefined behaviour or crashes.
* If an error occurs when modifying the tree it may leave the tree in
* an intermediate (but valid) state. As an example, adding a property
* where there is insufficient space may result in the property name
* being added to the string table even though the property itself is
* not added to the struct section.
* Only use this if you have a fully validated device tree with
* the latest supported version and wish to minimise code size.
FDT_ASSUME_PERFECT = 0xff,
* This assumes that the device tree is sane. i.e. header metadata
* and basic hierarchy are correct.
* These checks will be sufficient if you have a valid device tree with
* no internal inconsistencies. With this assumption, libfdt will
* generally not return -FDT_ERR_INTERNAL, -FDT_ERR_BADLAYOUT, etc.
FDT_ASSUME_SANE = 1 << 0,
* This disables checks for device-tree version and removes all code
* which handles older versions.
* Only enable this if you know you have a device tree with the latest
* version.
FDT_ASSUME_LATEST = 1 << 1,
* This disables any extensive checking of parameters and the device
* tree, making various assumptions about correctness. Normal device
* trees produced by libfdt and the compiler should be handled safely.
* Malicious device trees and complete garbage may cause libfdt to
* behave badly or crash.
FDT_ASSUME_FRIENDLY = 1 << 2,
+/** fdt_chk_basic() - see if basic checking of params and DT data is enabled */ +static inline bool fdt_chk_basic(void) +{
return !(FDT_ASSUME_MASK & FDT_ASSUME_SANE);
+/** fdt_chk_version() - see if we need to handle old versions of the DT */ +static inline bool fdt_chk_version(void) +{
return !(FDT_ASSUME_MASK & FDT_ASSUME_LATEST);
+/** fdt_chk_extra() - see if extra checking is enabled */ +static inline bool fdt_chk_extra(void) +{
return !(FDT_ASSUME_MASK & FDT_ASSUME_FRIENDLY);
#endif /* LIBFDT_INTERNAL_H */ diff --git a/tools/libfdt/fdt_rw.c b/tools/libfdt/fdt_rw.c index 68fc7c8c88..7189f01429 100644 --- a/tools/libfdt/fdt_rw.c +++ b/tools/libfdt/fdt_rw.c @@ -11,6 +11,7 @@ int fdt_remove_unused_strings(const void *old, void *new) const char *str; int ret; int tag = FDT_PROP;
int allocated; /* Make a copy and remove the strings */ memcpy(new, old, size);
@@ -25,7 +26,7 @@ int fdt_remove_unused_strings(const void *old, void *new) new_prop = (struct fdt_property *)(unsigned long) fdt_get_property_by_offset(new, offset, NULL); str = fdt_string(old, fdt32_to_cpu(old_prop->nameoff));
ret = fdt_find_add_string_(new, str);
ret = fdt_find_add_string_(new, str, &allocated); if (ret < 0) return ret; new_prop->nameoff = cpu_to_fdt32(ret);
-- 2.24.0.rc0.303.g954a862665-goog
On Sun, Oct 27, 2019 at 09:47:38AM -0600, Simon Glass wrote:
This series brings over the latest libfdt with some changes to deal with the recent code-size bloat.
With this change U-Boot size increases about 2.5KB on 'rock' and SPL reduces by about 128 bytes. This should be acceptable.
The 'assumptions' series is still under review, so we can sync that up later when complete.
Does this address the problem you have when moving binman to python3 as well? Thanks!
Hi Tom,
Yes it does, I figured that out.
participants (5)
Adam Ford
sjg@google.com
