[U-Boot] [PATCH] armv8: sec_firmware: Remove JR3 from device tree node in all cases
JR3 was getting removed from device tree only if random number generation was successful. However, if SEC firmware is present,JR3 should be removed from device tree node irrespective of the random seed generation as SEC firmware reserves it for it's use. Not removing it in case of random number generation failure causes the kernel to crash.
Random number generation was being called twice. This is not required. If SEC firmware is running, SIP call can be made to the SEC firmware to get the random number. This call itself would return failure if function is not supported. Duplicate calling of random number generation function has been removed
Signed-off-by: Ruchika Gupta ruchika.gupta@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 4 ++-- arch/arm/cpu/armv8/sec_firmware.c | 5 +++-- 2 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index 80af318..6a19f4d 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -415,8 +415,8 @@ void ft_cpu_setup(void *blob, bd_t *bd) ccsr_sec_t __iomem *sec;
#ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT - if (fdt_fixup_kaslr(blob)) - fdt_fixup_remove_jr(blob); + fdt_fixup_remove_jr(blob); + fdt_fixup_kaslr(blob); #endif
sec = (void __iomem *)CONFIG_SYS_FSL_SEC_ADDR; diff --git a/arch/arm/cpu/armv8/sec_firmware.c b/arch/arm/cpu/armv8/sec_firmware.c index b56ea78..ebf41b5 100644 --- a/arch/arm/cpu/armv8/sec_firmware.c +++ b/arch/arm/cpu/armv8/sec_firmware.c @@ -320,7 +320,6 @@ bool sec_firmware_support_hwrng(void) { uint8_t rand[8]; if (sec_firmware_addr & SEC_FIRMWARE_RUNNING) { - if (!sec_firmware_get_random(rand, 8)) return true; }
@@ -429,8 +428,10 @@ int fdt_fixup_kaslr(void *fdt)
#if defined(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT) /* Check if random seed generation is supported */ - if (sec_firmware_support_hwrng() == false) + if (sec_firmware_support_hwrng() == false) { + printf("WARNING: SEC firmware not running, no kaslr-seed\n"); return 0; + }
ret = sec_firmware_get_random(rand, 8); if (ret < 0) {
#endif
You didn't remove variable rand above, causing compiling warning on multiple targets.
York
Ruchika Gupta
York Sun
