[U-Boot] [PATCH] arm: sunxi: Enable DM_MMC on required SoCs
Enabling DM_MMC is forcing CONFIG_BLK=y so if any board which uses SCSI must need to enable DM_SCSI otherwise SCSI reads on that particular target making invalid reading to the disk drive.
Allwinner platform do support SCSI on A10, A20 and R40 SoC's out of these only A10 have DM_SCSI enabled. So enabling DM_MMC on A20, R40 would eventually end-up with scsi disk read failures like [1]
So, enable DM_MMC in all places of respective SoC's instead of enabling them globally to Allwinner platform.
Now, DM_MMC is enabled in Allwinner SoC's except A20 and R40.
[1] https://lists.denx.de/pipermail/u-boot/2019-April/364057.html
Reported-by: Pablo Sebastián Greco pgreco@centosproject.org Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/Kconfig | 1 - arch/arm/mach-sunxi/Kconfig | 12 ++++++++++++ 2 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f42eccef80..4a23e327df 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -857,7 +857,6 @@ config ARCH_SUNXI select DM_ETH select DM_GPIO select DM_KEYBOARD - select DM_MMC if MMC select DM_SERIAL select DM_USB if DISTRO_DEFAULTS select OF_BOARD_SETUP diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 74e234cded..152deb04e9 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -154,6 +154,7 @@ config MACH_SUN4I bool "sun4i (Allwinner A10)" select CPU_V7A select ARM_CORTEX_CPU_IS_UP + select DM_MMC if MMC select DM_SCSI if SCSI select PHY_SUN4I_USB select DRAM_SUN4I @@ -164,6 +165,7 @@ config MACH_SUN5I bool "sun5i (Allwinner A13)" select CPU_V7A select ARM_CORTEX_CPU_IS_UP + select DM_MMC if MMC select DRAM_SUN4I select PHY_SUN4I_USB select SUNXI_GEN_SUN4I @@ -176,6 +178,7 @@ config MACH_SUN6I select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select DM_MMC if MMC select DRAM_SUN6I select PHY_SUN4I_USB select SUN6I_P2WI @@ -202,6 +205,7 @@ config MACH_SUN8I_A23 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select DM_MMC if MMC select DRAM_SUN8I_A23 select PHY_SUN4I_USB select SUNXI_GEN_SUN6I @@ -215,6 +219,7 @@ config MACH_SUN8I_A33 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select DM_MMC if MMC select DRAM_SUN8I_A33 select PHY_SUN4I_USB select SUNXI_GEN_SUN6I @@ -225,6 +230,7 @@ config MACH_SUN8I_A33 config MACH_SUN8I_A83T bool "sun8i (Allwinner A83T)" select CPU_V7A + select DM_MMC if MMC select DRAM_SUN8I_A83T select PHY_SUN4I_USB select SUNXI_GEN_SUN6I @@ -240,6 +246,7 @@ config MACH_SUN8I_H3 select ARCH_SUPPORT_PSCI select MACH_SUNXI_H3_H5 select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT + select DM_MMC if MMC
config MACH_SUN8I_R40 bool "sun8i (Allwinner R40)" @@ -258,6 +265,7 @@ config MACH_SUN8I_V3S select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select DM_MMC if MMC select SUNXI_GEN_SUN6I select SUNXI_DRAM_DW select SUNXI_DRAM_DW_16BIT @@ -272,11 +280,13 @@ config MACH_SUN9I select SUNXI_GEN_SUN6I select SUN8I_RSB select SUPPORT_SPL + select DM_MMC if MMC
config MACH_SUN50I bool "sun50i (Allwinner A64)" select ARM64 select DM_I2C + select DM_MMC if MMC select PHY_SUN4I_USB select SUN6I_PRCM select SUNXI_DE2 @@ -293,6 +303,7 @@ config MACH_SUN50I_H5 bool "sun50i (Allwinner H5)" select ARM64 select MACH_SUNXI_H3_H5 + select DM_MMC if MMC select FIT select SPL_LOAD_FIT
@@ -300,6 +311,7 @@ config MACH_SUN50I_H6 bool "sun50i (Allwinner H6)" select ARM64 select SUPPORT_SPL + select DM_MMC if MMC select FIT select SPL_LOAD_FIT select DRAM_SUN50I_H6
Thanks for coming up with the root cause and a work around quickly!
Jagan Teki
