[U-Boot-Users] [GIT PULL] MIPS updates
Dear Wolfgang,
please pull MIPS updates. 2 patches are there. One fixes a build failure caused by absence of dcache_enable(). The other is for a better handling of gas minor version (this isn't a kind of bug fix, but I'd like to push this for 1.3.3 release. Ok?).
Each patch has not been posted to u-boot-users yet, so they will follow this mail. Please review (and apply).
thanks,
Shinya
--- The following changes since commit 50f93d30dae3c5d888aa244d964ccd77be9b1c0c: Wolfgang Denk (1): Merge branch 'master' of git+ssh://10.10.0.7/home/wd/git/u-boot/master
git://git.denx.de/u-boot-mips.git master
Shinya Kuribayashi (2): [MIPS] cpu/mips/cache.S: Add dcache_enable [MIPS] cpu/mips/config.mk: Fix GNU assembler minor version picker
cpu/mips/cache.S | 16 ++++++++++++++++ cpu/mips/config.mk | 2 +- 2 files changed, 17 insertions(+), 1 deletions(-)
Recent bootelf command fixes (017e9b7925f74878d0e9475388cca9bda5ef9482, "allow ports to override bootelf behavior") requires ports to have this function.
Signed-off-by: Shinya Kuribayashi skuribay@ruby.dti.ne.jp ---
cpu/mips/cache.S | 16 ++++++++++++++++ 1 files changed, 16 insertions(+), 0 deletions(-)
diff --git a/cpu/mips/cache.S b/cpu/mips/cache.S index f593968..428d251 100644 --- a/cpu/mips/cache.S +++ b/cpu/mips/cache.S @@ -285,6 +285,22 @@ LEAF(dcache_disable) jr ra END(dcache_disable)
+/******************************************************************************* +* +* dcache_enable - enable cache +* +* RETURNS: N/A +* +*/ +LEAF(dcache_enable) + mfc0 t0, CP0_CONFIG + ori t0, CONF_CM_CMASK + xori t0, CONF_CM_CMASK + ori t0, CONF_CM_CACHABLE_NONCOHERENT + mtc0 t0, CP0_CONFIG + jr ra + END(dcache_enable) + #ifdef CFG_INIT_RAM_LOCK_MIPS /******************************************************************************* *
Acked-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
Current trick to pick up GNU assembler minor version uses a dot(.) as a delimiter, and take the second field to obtain minor version number. But as can be expected, this doesn't work with a version string which has dots more than needs.
Here's an example:
$ mips-linux-gnu-as --version | grep 'GNU assembler' GNU assembler (Sourcery G++ Lite 4.2-129) 2.18.50.20080215 $ mips-linux-gnu-as --version | grep 'GNU assembler' | cut -d. -f2 2-129) 2 $
This patch restricts the version format to 2.XX.XX... This will work in most cases.
$ mips-linux-gnu-as --version | grep 'GNU assembler' | egrep -o '2.[0-9.]+' 2.18.50.20080215 $ mips-linux-gnu-as --version | grep 'GNU assembler' | egrep -o '2.[0-9.]+' | cut -d. -f2 18 $
cpu/mips/config.mk | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/cpu/mips/config.mk b/cpu/mips/config.mk index b505a42..a173c54 100644 --- a/cpu/mips/config.mk +++ b/cpu/mips/config.mk @@ -20,7 +20,7 @@ # Foundation, Inc., 59 Temple Place, Suite 330, Boston, # MA 02111-1307 USA # -v=$(shell $(AS) --version |grep "GNU assembler" |cut -d. -f2) +v=$(shell $(AS) --version | grep 'GNU assembler' | egrep -o '2.[0-9.]+' | cut -d. -f2) MIPSFLAGS:=$(shell \ if [ "$v" -lt "14" ]; then \ echo "-mcpu=4kc"; \
In message 481A8B97.5030209@ruby.dti.ne.jp you wrote:
Dear Wolfgang,
thanks,
Shinya
Applied, thanks.
Shinya Kuribayashi
