[U-Boot] [PATCH] ARM: tegra: Add support for TK1-SOM board from Colorado Engineering
The Colorado TK1 SOM is a small form factor board similar to the Jetson TK1. The main differences lie in the pinmux, and in that the PCIe controller is set to use in 4lanes+1lane, rather than 2+2.
The pinmux header here was generated from a spreadsheet provided by Colorado Engineering using the tegra-pinmux scripts. The spreadsheet was converted from v09 to v11 by me.
Signed-off-by: Peter Chubb peter.chubb@data61.csiro.au --- arch/arm/dts/Makefile | 1 + arch/arm/dts/tegra124-cei-tk1-som.dts | 477 ++++++++++++++++++++++ arch/arm/mach-tegra/tegra124/Kconfig | 11 + board/cei/cei-tk1-som/Kconfig | 12 + board/cei/cei-tk1-som/MAINTAINERS | 6 + board/cei/cei-tk1-som/Makefile | 9 + board/cei/cei-tk1-som/cei-tk1-som.c | 65 +++ board/cei/cei-tk1-som/pinmux-config-cei-tk1-som.h | 301 ++++++++++++++ board/nvidia/venice2/as3722_init.h | 8 +- configs/cei-tk1-som_defconfig | 47 +++ include/configs/cei-tk1-som.h | 71 ++++ 11 files changed, 1004 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/tegra124-cei-tk1-som.dts create mode 100644 board/cei/cei-tk1-som/Kconfig create mode 100644 board/cei/cei-tk1-som/MAINTAINERS create mode 100644 board/cei/cei-tk1-som/Makefile create mode 100644 board/cei/cei-tk1-som/cei-tk1-som.c create mode 100644 board/cei/cei-tk1-som/pinmux-config-cei-tk1-som.h create mode 100644 configs/cei-tk1-som_defconfig create mode 100644 include/configs/cei-tk1-som.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7d1944f..25fc22f 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -57,6 +57,7 @@ dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra114-dalmore.dtb \ tegra124-jetson-tk1.dtb \ tegra124-nyan-big.dtb \ + tegra124-cei-tk1-som.dtb \ tegra124-venice2.dtb \ tegra186-p2771-0000-a02.dtb \ tegra186-p2771-0000-b00.dtb \ diff --git a/arch/arm/dts/tegra124-cei-tk1-som.dts b/arch/arm/dts/tegra124-cei-tk1-som.dts new file mode 100644 index 0000000..d22c0ca --- /dev/null +++ b/arch/arm/dts/tegra124-cei-tk1-som.dts @@ -0,0 +1,477 @@ +/dts-v1/; + +#include "tegra124.dtsi" + +/ { + model = "Colorado Engineering TK1-SOM"; + compatible = "nvidia,cei-tk1-som", "nvidia,tegra124"; + + chosen { + stdout-path = &uartd; + }; + + aliases { + i2c0 = "/i2c@7000d000"; + i2c1 = "/i2c@7000c000"; + i2c2 = "/i2c@7000c400"; + i2c3 = "/i2c@7000c500"; + i2c4 = "/i2c@7000c700"; + sdhci0 = "/sdhci@700b0600"; + sdhci1 = "/sdhci@700b0400"; + spi0 = "/spi@7000d400"; + spi1 = "/spi@7000da00"; + usb0 = "/usb@7d000000"; + usb1 = "/usb@7d008000"; + }; + + memory { + device_type = "memory"; + reg = <0x80000000 0x80000000>; + }; + + pcie-controller@01003000 { + status = "okay"; + + avddio-pex-supply = <&vdd_1v05_run>; + dvddio-pex-supply = <&vdd_1v05_run>; + avdd-pex-pll-supply = <&vdd_1v05_run>; + hvdd-pex-supply = <&vdd_3v3_lp0>; + hvdd-pex-pll-e-supply = <&vdd_3v3_lp0>; + vddio-pex-ctl-supply = <&vdd_3v3_lp0>; + avdd-pll-erefe-supply = <&avdd_1v05_run>; + + pci@1,0 { + status = "okay"; + nvidia,num-lanes = <4>; + }; + + pci@2,0 { + status = "okay"; + }; + }; + + i2c@7000c000 { + status = "okay"; + clock-frequency = <100000>; + }; + + i2c@7000c400 { + status = "okay"; + clock-frequency = <100000>; + }; + + i2c@7000c500 { + status = "okay"; + clock-frequency = <100000>; + }; + + i2c@7000c700 { + status = "okay"; + clock-frequency = <100000>; + }; + + /* Expansion PWR_I2C_*, on-board components */ + i2c@7000d000 { + status = "okay"; + clock-frequency = <400000>; + + pmic: pmic@40 { + compatible = "ams,as3722"; + reg = <0x40>; + interrupts = <0 86 IRQ_TYPE_LEVEL_HIGH>; + + ams,system-power-controller; + + #interrupt-cells = <2>; + interrupt-controller; + + gpio-controller; + #gpio-cells = <2>; + + pinctrl-names = "default"; + pinctrl-0 = <&as3722_default>; + + as3722_default: pinmux { + gpio0 { + pins = "gpio0"; + function = "gpio"; + bias-pull-down; + }; + + gpio1_2_4_7 { + pins = "gpio1", "gpio2", "gpio4", "gpio7"; + function = "gpio"; + bias-pull-up; + }; + + gpio3_5_6 { + pins = "gpio3", "gpio5", "gpio6"; + bias-high-impedance; + }; + }; + + regulators { + vsup-sd2-supply = <&vdd_5v0_sys>; + vsup-sd3-supply = <&vdd_5v0_sys>; + vsup-sd4-supply = <&vdd_5v0_sys>; + vsup-sd5-supply = <&vdd_5v0_sys>; + vin-ldo0-supply = <&vdd_1v35_lp0>; + vin-ldo1-6-supply = <&vdd_3v3_run>; + vin-ldo2-5-7-supply = <&vddio_1v8>; + vin-ldo3-4-supply = <&vdd_3v3_sys>; + vin-ldo9-10-supply = <&vdd_5v0_sys>; + vin-ldo11-supply = <&vdd_3v3_run>; + + sd0 { + regulator-name = "+VDD_CPU_AP"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1400000>; + regulator-min-microamp = <3500000>; + regulator-max-microamp = <3500000>; + regulator-always-on; + regulator-boot-on; + ams,ext-control = <2>; + }; + + sd1 { + regulator-name = "+VDD_CORE"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + regulator-min-microamp = <2500000>; + regulator-max-microamp = <2500000>; + regulator-always-on; + regulator-boot-on; + ams,ext-control = <1>; + }; + + vdd_1v35_lp0: sd2 { + regulator-name = "+1.35V_LP0(sd2)"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + }; + + sd3 { + regulator-name = "+1.35V_LP0(sd3)"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_1v05_run: sd4 { + regulator-name = "+1.05V_RUN"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + }; + + vddio_1v8: sd5 { + regulator-name = "+1.8V_VDDIO"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + vdd_gpu: sd6 { + regulator-name = "+VDD_GPU_AP"; + regulator-min-microvolt = <650000>; + regulator-max-microvolt = <1200000>; + regulator-min-microamp = <3500000>; + regulator-max-microamp = <3500000>; + regulator-boot-on; + regulator-always-on; + }; + + avdd_1v05_run: ldo0 { + regulator-name = "+1.05V_RUN_AVDD"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + regulator-boot-on; + regulator-always-on; + ams,ext-control = <1>; + }; + + ldo1 { + regulator-name = "+1.8V_RUN_CAM"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + ldo2 { + regulator-name = "+1.2V_GEN_AVDD"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3 { + regulator-name = "+1.05V_LP0_VDD_RTC"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-boot-on; + regulator-always-on; + ams,enable-tracking; + }; + + ldo4 { + regulator-name = "+2.8V_RUN_CAM"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + }; + + ldo5 { + regulator-name = "+1.2V_RUN_CAM_FRONT"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + }; + + vddio_sdmmc3: ldo6 { + regulator-name = "+VDDIO_SDMMC3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + + ldo7 { + regulator-name = "+1.05V_RUN_CAM_REAR"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + }; + + ldo9 { + regulator-name = "+3.3V_RUN_TOUCH"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + }; + + ldo10 { + regulator-name = "+2.8V_RUN_CAM_AF"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + }; + + ldo11 { + regulator-name = "+1.8V_RUN_VPP_FUSE"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + }; + }; + }; + + i2c@7000d100 { + status = "okay"; + clock-frequency = <400000>; + }; + + spi@7000d400 { + status = "okay"; + spi-max-frequency = <25000000>; + }; + + spi@7000da00 { + status = "okay"; + spi-max-frequency = <25000000>; + }; + + padctl@7009f000 { + pinctrl-0 = <&padctl_default>; + pinctrl-names = "default"; + + padctl_default: pinmux { + usb3 { + nvidia,lanes = "sata-0"; + nvidia,function = "usb3"; + nvidia,iddq = <0>; + }; + + pcie { + nvidia,lanes = "pcie-0", "pcie-1", "pcie-2", "pcie-3", + "pcie-4"; + nvidia,function = "pcie"; + nvidia,iddq = <0>; + }; + + }; + }; + + sdhci@700b0400 { + status = "okay"; + cd-gpios = <&gpio TEGRA_GPIO(V, 2) GPIO_ACTIVE_LOW>; + power-gpios = <&gpio TEGRA_GPIO(R, 0) GPIO_ACTIVE_HIGH>; + wp-gpios = <&gpio TEGRA_GPIO(Q, 4) GPIO_ACTIVE_HIGH>; + bus-width = <4>; + }; + + sdhci@700b0600 { + status = "okay"; + bus-width = <8>; + }; + + usb@7d000000 { + status = "okay"; + dr_mode = "otg"; + nvidia,vbus-gpio = <&gpio TEGRA_GPIO(N, 4) GPIO_ACTIVE_HIGH>; + }; + + usb@7d008000 { + status = "okay"; + nvidia,vbus-gpio = <&gpio TEGRA_GPIO(N, 5) GPIO_ACTIVE_HIGH>; + }; + + clocks { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + clk32k_in: clock@0 { + compatible = "fixed-clock"; + reg = <0>; + #clock-cells = <0>; + clock-frequency = <32768>; + }; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + vdd_mux: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "+VDD_MUX"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_5v0_sys: regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "+5V_SYS"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vdd_mux>; + }; + + vdd_3v3_sys: regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "+3.3V_SYS"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vdd_mux>; + }; + + vdd_3v3_run: regulator@3 { + compatible = "regulator-fixed"; + reg = <3>; + regulator-name = "+3.3V_RUN"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + gpio = <&pmic 1 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_3v3_sys>; + }; + + vdd_3v3_hdmi: regulator@4 { + compatible = "regulator-fixed"; + reg = <4>; + regulator-name = "+3.3V_AVDD_HDMI_AP_GATED"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vdd_3v3_run>; + }; + + vdd_usb1_vbus: regulator@7 { + compatible = "regulator-fixed"; + reg = <7>; + regulator-name = "+USB0_VBUS_SW"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio TEGRA_GPIO(N, 4) GPIO_ACTIVE_HIGH>; + enable-active-high; + gpio-open-drain; + vin-supply = <&vdd_5v0_sys>; + }; + + vdd_usb3_vbus: regulator@8 { + compatible = "regulator-fixed"; + reg = <8>; + regulator-name = "+5V_USB_HS"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio TEGRA_GPIO(N, 5) GPIO_ACTIVE_HIGH>; + enable-active-high; + gpio-open-drain; + vin-supply = <&vdd_5v0_sys>; + }; + + vdd_3v3_lp0: regulator@10 { + compatible = "regulator-fixed"; + reg = <10>; + regulator-name = "+3.3V_LP0"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + gpio = <&pmic 2 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_3v3_sys>; + }; + + vdd_hdmi_pll: regulator@11 { + compatible = "regulator-fixed"; + reg = <11>; + regulator-name = "+1.05V_RUN_AVDD_HDMI_PLL"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + gpio = <&gpio TEGRA_GPIO(H, 7) GPIO_ACTIVE_LOW>; + vin-supply = <&vdd_1v05_run>; + }; + + vdd_5v0_hdmi: regulator@12 { + compatible = "regulator-fixed"; + reg = <12>; + regulator-name = "+5V_HDMI_CON"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio TEGRA_GPIO(K, 6) GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_5v0_sys>; + }; + + /* Molex power connector */ + vdd_5v0_sata: regulator@13 { + compatible = "regulator-fixed"; + reg = <13>; + regulator-name = "+5V_SATA"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio TEGRA_GPIO(EE, 2) GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_5v0_sys>; + }; + + vdd_12v0_sata: regulator@14 { + compatible = "regulator-fixed"; + reg = <14>; + regulator-name = "+12V_SATA"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + gpio = <&gpio TEGRA_GPIO(EE, 2) GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_mux>; + }; + }; +}; diff --git a/arch/arm/mach-tegra/tegra124/Kconfig b/arch/arm/mach-tegra/tegra124/Kconfig index f3324ff..de291f9 100644 --- a/arch/arm/mach-tegra/tegra124/Kconfig +++ b/arch/arm/mach-tegra/tegra124/Kconfig @@ -9,6 +9,16 @@ config TARGET_JETSON_TK1 select CPU_V7_HAS_NONSEC if !SPL_BUILD select CPU_V7_HAS_VIRT if !SPL_BUILD
+config TARGET_CEI_TK1_SOM + bool "Colorado/NVIDIA Tegra124 TK1-som board" + select CPU_V7_HAS_NONSEC if !SPL_BUILD + select CPU_V7_HAS_VIRT if !SPL_BUILD + help + The Colorado Engineering Tegra TK1-SOM is a very compact + (51mmx58mm) board that is functionally almost the same as the + Jetson TK1. The main differences are in which balls on the + SoC are assigned to which functions, and the PCIEe configuration. + config TARGET_NYAN_BIG bool "Google/NVIDIA Nyan-big Chromebook" help @@ -26,6 +36,7 @@ endchoice config SYS_SOC default "tegra124"
+source "board/cei/cei-tk1-som/Kconfig" source "board/nvidia/jetson-tk1/Kconfig" source "board/nvidia/nyan-big/Kconfig" source "board/nvidia/venice2/Kconfig" diff --git a/board/cei/cei-tk1-som/Kconfig b/board/cei/cei-tk1-som/Kconfig new file mode 100644 index 0000000..5fcb51f --- /dev/null +++ b/board/cei/cei-tk1-som/Kconfig @@ -0,0 +1,12 @@ +if TARGET_CEI_TK1_SOM + +config SYS_BOARD + default "cei-tk1-som" + +config SYS_VENDOR + default "cei" + +config SYS_CONFIG_NAME + default "cei-tk1-som" + +endif diff --git a/board/cei/cei-tk1-som/MAINTAINERS b/board/cei/cei-tk1-som/MAINTAINERS new file mode 100644 index 0000000..192e1a3 --- /dev/null +++ b/board/cei/cei-tk1-som/MAINTAINERS @@ -0,0 +1,6 @@ +TK1-SOM BOARD +M: Peter.Chubb@data61.csiro.au +S: Maintained +F: board/cei/tk1-som/ +F: include/configs/cei-tk1-som.h +F: configs/cei-tk1-som_defconfig diff --git a/board/cei/cei-tk1-som/Makefile b/board/cei/cei-tk1-som/Makefile new file mode 100644 index 0000000..127b104 --- /dev/null +++ b/board/cei/cei-tk1-som/Makefile @@ -0,0 +1,9 @@ +# +# (C) Copyright 2014 +# NVIDIA Corporation <www.nvidia.com> +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += ../../nvidia/venice2/as3722_init.o +obj-y += cei-tk1-som.o diff --git a/board/cei/cei-tk1-som/cei-tk1-som.c b/board/cei/cei-tk1-som/cei-tk1-som.c new file mode 100644 index 0000000..9ba7490 --- /dev/null +++ b/board/cei/cei-tk1-som/cei-tk1-som.c @@ -0,0 +1,65 @@ +/* + * (C) Copyright 2014 + * NVIDIA Corporation <www.nvidia.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <power/as3722.h> + +#include <asm/arch/gpio.h> +#include <asm/arch/pinmux.h> + +#include "pinmux-config-cei-tk1-som.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Routine: pinmux_init + * Description: Do individual peripheral pinmux configs + */ +void pinmux_init(void) +{ + pinmux_clear_tristate_input_clamping(); + + gpio_config_table(cei_tk1_som_gpio_inits, + ARRAY_SIZE(cei_tk1_som_gpio_inits)); + + pinmux_config_pingrp_table(cei_tk1_som_pingrps, + ARRAY_SIZE(cei_tk1_som_pingrps)); + + pinmux_config_drvgrp_table(cei_tk1_som_drvgrps, + ARRAY_SIZE(cei_tk1_som_drvgrps)); + + pinmux_config_mipipadctrlgrp_table(cei_tk1_som_mipipadctrlgrps, + ARRAY_SIZE(cei_tk1_som_mipipadctrlgrps)); +} + +#ifdef CONFIG_PCI_TEGRA +int tegra_pcie_board_init(void) +{ + struct udevice *pmic; + int err; + + err = as3722_init(&pmic); + if (err) { + error("failed to initialize AS3722 PMIC: %d\n", err); + return err; + } + + err = as3722_sd_enable(pmic, 4); + if (err < 0) { + error("failed to enable SD4: %d\n", err); + return err; + } + + err = as3722_sd_set_voltage(pmic, 4, 0x24); + if (err < 0) { + error("failed to set SD4 voltage: %d\n", err); + return err; + } + + return 0; +} +#endif /* PCI */ diff --git a/board/cei/cei-tk1-som/pinmux-config-cei-tk1-som.h b/board/cei/cei-tk1-som/pinmux-config-cei-tk1-som.h new file mode 100644 index 0000000..3431bfe --- /dev/null +++ b/board/cei/cei-tk1-som/pinmux-config-cei-tk1-som.h @@ -0,0 +1,301 @@ +/* + * Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* + * THIS FILE IS AUTO-GENERATED - DO NOT EDIT! + * + * To generate this file, use the tegra-pinmux-scripts tool available from + * https://github.com/NVIDIA/tegra-pinmux-scripts + * Run "board-to-uboot.py cei-tk1-som". + */ + +#ifndef _PINMUX_CONFIG_CEI_TK1_SOM_H_ +#define _PINMUX_CONFIG_CEI_TK1_SOM_H_ + +#define GPIO_INIT(_port, _gpio, _init) \ + { \ + .gpio = TEGRA_GPIO(_port, _gpio), \ + .init = TEGRA_GPIO_INIT_##_init, \ + } + +static const struct tegra_gpio_config cei_tk1_som_gpio_inits[] = { + /* port, pin, init_val */ + GPIO_INIT(G, 0, IN), + GPIO_INIT(G, 1, IN), + GPIO_INIT(G, 2, IN), + GPIO_INIT(G, 3, IN), + GPIO_INIT(G, 4, IN), + GPIO_INIT(H, 4, IN), + GPIO_INIT(H, 7, IN), + GPIO_INIT(I, 0, OUT0), + GPIO_INIT(I, 1, IN), + GPIO_INIT(I, 3, IN), + GPIO_INIT(I, 6, IN), + GPIO_INIT(J, 0, IN), + GPIO_INIT(J, 2, IN), + GPIO_INIT(K, 2, IN), + GPIO_INIT(K, 6, OUT0), + GPIO_INIT(N, 7, IN), + GPIO_INIT(O, 1, IN), + GPIO_INIT(O, 4, IN), + GPIO_INIT(Q, 0, IN), + GPIO_INIT(Q, 3, IN), + GPIO_INIT(R, 0, IN), + GPIO_INIT(R, 2, OUT0), + GPIO_INIT(R, 4, IN), + GPIO_INIT(R, 6, IN), + GPIO_INIT(S, 2, IN), + GPIO_INIT(S, 3, IN), + GPIO_INIT(S, 4, IN), + GPIO_INIT(S, 5, IN), + GPIO_INIT(S, 6, IN), + GPIO_INIT(S, 7, IN), + GPIO_INIT(T, 0, IN), + GPIO_INIT(T, 1, IN), + GPIO_INIT(V, 0, IN), + GPIO_INIT(V, 1, IN), + GPIO_INIT(X, 1, IN), + GPIO_INIT(X, 4, IN), + GPIO_INIT(BB, 3, OUT0), + GPIO_INIT(BB, 6, OUT0), + GPIO_INIT(BB, 7, OUT0), + GPIO_INIT(CC, 1, IN), + GPIO_INIT(CC, 2, IN), +}; + +#define PINCFG(_pingrp, _mux, _pull, _tri, _io, _od, _rcv_sel) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .od = PMUX_PIN_OD_##_od, \ + .rcv_sel = PMUX_PIN_RCV_SEL_##_rcv_sel, \ + .lock = PMUX_PIN_LOCK_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +static const struct pmux_pingrp_config cei_tk1_som_pingrps[] = { + /* pingrp, mux, pull, tri, e_input, od, rcv_sel */ + PINCFG(CLK_32K_OUT_PA0, SOC, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_CTS_N_PA1, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_FS_PA2, I2S1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_SCLK_PA3, I2S1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_DIN_PA4, I2S1, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_DOUT_PA5, I2S1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CLK_PA6, SDMMC3, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CMD_PA7, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PB0, UARTD, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PB1, UARTD, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT3_PB4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT2_PB5, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT1_PB6, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT0_PB7, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_RTS_N_PC0, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_TXD_PC2, IRDA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_RXD_PC3, IRDA, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PC7, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG0, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PG1, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PG2, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PG3, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PG4, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PG5, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG6, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG7, SPI4, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PH0, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH1, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH2, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH3, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH4, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PH5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH6, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH7, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PI0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI1, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PI2, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI3, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PI4, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI6, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PI7, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PJ0, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PJ2, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(UART2_CTS_N_PJ5, UARTB, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(UART2_RTS_N_PJ6, UARTB, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PJ7, UARTD, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK0, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK1, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK2, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK3, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK4, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_OUT_PK5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_IN_PK6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK7, UARTD, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_FS_PN0, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_DIN_PN1, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_DOUT_PN2, I2S0, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_SCLK_PN3, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(USB_VBUS_EN0_PN4, USB, NORMAL, NORMAL, INPUT, DISABLE, DEFAULT), + PINCFG(USB_VBUS_EN1_PN5, USB, NORMAL, NORMAL, INPUT, DISABLE, DEFAULT), + PINCFG(HDMI_INT_PN7, DEFAULT, DOWN, TRISTATE, INPUT, DEFAULT, NORMAL), + PINCFG(ULPI_DATA7_PO0, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA0_PO1, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA1_PO2, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA2_PO3, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA3_PO4, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA4_PO5, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA5_PO6, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA6_PO7, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_FS_PP0, I2S2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DIN_PP1, I2S2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DOUT_PP2, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_SCLK_PP3, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_FS_PP4, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_DIN_PP5, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_DOUT_PP6, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_SCLK_PP7, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL0_PQ0, DEFAULT, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL1_PQ1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL2_PQ2, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL3_PQ3, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL4_PQ4, KBC, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL5_PQ5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL6_PQ6, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL7_PQ7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW0_PR0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW1_PR1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW2_PR2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW3_PR3, KBC, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW4_PR4, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW5_PR5, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW6_PR6, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW7_PR7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW8_PS0, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW9_PS1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW10_PS2, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW11_PS3, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW12_PS4, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW13_PS5, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW14_PS6, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW15_PS7, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW16_PT0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW17_PT1, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(GEN2_I2C_SCL_PT5, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(GEN2_I2C_SDA_PT6, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC4_CMD_PT7, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU0, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU1, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU2, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU3, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU4, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU5, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU6, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PV0, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PV1, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CD_N_PV2, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_WP_N_PV3, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DDC_SCL_PV4, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(DDC_SDA_PV5, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(GPIO_W2_AUD_PW2, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_W3_AUD_PW3, SPI6, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP_MCLK1_PW4, EXTPERIPH1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_OUT_PW5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART3_TXD_PW6, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART3_RXD_PW7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DVFS_PWM_PX0, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X1_AUD_PX1, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(DVFS_CLK_PX2, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X3_AUD_PX3, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X4_AUD_PX4, DEFAULT, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X5_AUD_PX5, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X6_AUD_PX6, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X7_AUD_PX7, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_CLK_PY0, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DIR_PY1, SPI1, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_NXT_PY2, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_STP_PY3, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT3_PY4, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT2_PY5, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT1_PY6, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT0_PY7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_CLK_PZ0, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_CMD_PZ1, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PWR_I2C_SCL_PZ6, I2CPWR, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PWR_I2C_SDA_PZ7, I2CPWR, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC4_DAT0_PAA0, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT1_PAA1, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT2_PAA2, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT3_PAA3, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT4_PAA4, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT5_PAA5, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PBB0, VIMCLK2_ALT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CAM_I2C_SCL_PBB1, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(CAM_I2C_SDA_PBB2, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PBB3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB4, VGP4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB5, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB7, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CAM_MCLK_PCC0, VI_ALT3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PCC1, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PCC2, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_REQ_PCC5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L0_RST_N_PDD1, PE0, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L0_CLKREQ_N_PDD2, PE0, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PEX_WAKE_N_PDD3, PE, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L1_RST_N_PDD5, PE1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L1_CLKREQ_N_PDD6, PE1, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_OUT_PEE0, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_REQ_PEE1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP_MCLK1_REQ_PEE2, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(HDMI_CEC_PEE3, CEC, NORMAL, NORMAL, INPUT, DISABLE, DEFAULT), + PINCFG(SDMMC3_CLK_LB_OUT_PEE4, SDMMC3, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CLK_LB_IN_PEE5, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DP_HPD_PFF0, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(USB_VBUS_EN2_PFF1, RSVD2, DOWN, TRISTATE, OUTPUT, DISABLE, DEFAULT), + PINCFG(PFF2, RSVD2, DOWN, TRISTATE, OUTPUT, DISABLE, DEFAULT), + PINCFG(CORE_PWR_REQ, PWRON, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CPU_PWR_REQ, CPU, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PWR_INT_N, PMI, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(RESET_OUT_N, RESET_OUT_N, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(CLK_32K_IN, CLK, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(JTAG_RTCK, RTCK, UP, NORMAL, OUTPUT, DEFAULT, DEFAULT), +}; + +#define DRVCFG(_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) \ + { \ + .drvgrp = PMUX_DRVGRP_##_drvgrp, \ + .slwf = _slwf, \ + .slwr = _slwr, \ + .drvup = _drvup, \ + .drvdn = _drvdn, \ + .lpmd = PMUX_LPMD_##_lpmd, \ + .schmt = PMUX_SCHMT_##_schmt, \ + .hsm = PMUX_HSM_##_hsm, \ + } + +static const struct pmux_drvgrp_config cei_tk1_som_drvgrps[] = { +}; + +#define MIPIPADCTRLCFG(_grp, _mux) \ + { \ + .grp = PMUX_MIPIPADCTRLGRP_##_grp, \ + .func = PMUX_FUNC_##_mux, \ + } + +static const struct pmux_mipipadctrlgrp_config cei_tk1_som_mipipadctrlgrps[] = { + /* grp, mux */ + MIPIPADCTRLCFG(DSI_B, DSI_B), +}; + +#endif /* PINMUX_CONFIG_CEI_TK1_SOM_H */ diff --git a/board/nvidia/venice2/as3722_init.h b/board/nvidia/venice2/as3722_init.h index c6b1247..30fb132 100644 --- a/board/nvidia/venice2/as3722_init.h +++ b/board/nvidia/venice2/as3722_init.h @@ -18,14 +18,14 @@ #define AS3722_LDO6VOLTAGE_REG 0x16 /* VDD_SDMMC */ #define AS3722_LDCONTROL_REG 0x4E
-#if defined(CONFIG_TARGET_JETSON_TK1) || defined(CONFIG_TARGET_NYAN_BIG) -#define AS3722_SD0VOLTAGE_DATA (0x3C00 | AS3722_SD0VOLTAGE_REG) -#else +#if defined(CONFIG_TARGET_VENICE2) #define AS3722_SD0VOLTAGE_DATA (0x2800 | AS3722_SD0VOLTAGE_REG) +#else /* TK1 or Nyan-Big */ +#define AS3722_SD0VOLTAGE_DATA (0x3C00 | AS3722_SD0VOLTAGE_REG) #endif #define AS3722_SD0CONTROL_DATA (0x0100 | AS3722_SDCONTROL_REG)
-#ifdef CONFIG_TARGET_JETSON_TK1 +#if defined(CONFIG_TARGET_JETSON_TK1) || defined(CONFIG_TARGET_CEI_TK1_SOM) #define AS3722_SD1VOLTAGE_DATA (0x2800 | AS3722_SD1VOLTAGE_REG) #define AS3722_SD1CONTROL_DATA (0x0200 | AS3722_SDCONTROL_REG) #endif diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig new file mode 100644 index 0000000..0704497 --- /dev/null +++ b/configs/cei-tk1-som_defconfig @@ -0,0 +1,47 @@ +CONFIG_ARM=y +CONFIG_TEGRA=y +CONFIG_SPL_DM=y +CONFIG_TEGRA124=y +CONFIG_TARGET_CEI_TK1_SOM=y +CONFIG_DEFAULT_DEVICE_TREE="tegra124-cei-tk1-som" +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="Tegra124 (TK1-SOM) # " +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_RTL8169=y +CONFIG_PCI_TEGRA=y +CONFIG_SYS_NS16550=y +CONFIG_TEGRA114_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_GADGET=y +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="NVIDIA" +CONFIG_G_DNL_VENDOR_NUM=0x0955 +CONFIG_G_DNL_PRODUCT_NUM=0x701a +CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/include/configs/cei-tk1-som.h b/include/configs/cei-tk1-som.h new file mode 100644 index 0000000..5c5be5e --- /dev/null +++ b/include/configs/cei-tk1-som.h @@ -0,0 +1,71 @@ +/* + * (C) Copyright 2016 Peter Chubb + * Based on the jetson-tk1.h which is + * (C) Copyright 2013-2014 + * NVIDIA Corporation <www.nvidia.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <linux/sizes.h> + +/* enable PMIC */ +#define CONFIG_AS3722_POWER + +#include "tegra124-common.h" + +/* High-level configuration options */ +#define CONFIG_TEGRA_BOARD_STRING "CEI tk1-som" + +/* Board-specific serial config */ +#define CONFIG_TEGRA_ENABLE_UARTD +#define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTD_BASE + +/* I2C */ +#define CONFIG_SYS_I2C_TEGRA + +/* SD/MMC */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_TEGRA_MMC + +/* Environment in eMMC, at the end of 2nd "boot sector" */ +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_PART 2 + +/* SPI */ +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#define CONFIG_SF_DEFAULT_SPEED 24000000 +#define CONFIG_SPI_FLASH_SIZE (4 << 20) + +/* USB Host support */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_TEGRA +#define CONFIG_USB_STORAGE + +/* USB networking support */ +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX + +/* PCI host support */ +#define CONFIG_PCI +#define CONFIG_PCI_PNP +#define CONFIG_CMD_PCI + +/* General networking support */ + +#include "tegra-common-usb-gadget.h" +#include "tegra-common-post.h" + +#define CONFIG_ARMV7_PSCI 1 +#define CONFIG_ARMV7_PSCI_NR_CPUS 4 +/* Reserve top 1M for secure RAM */ +#define CONFIG_ARMV7_SECURE_BASE 0xfff00000 +#define CONFIG_ARMV7_SECURE_RESERVE_SIZE 0x00100000 + +#endif /* __CONFIG_H */
- bool "Colorado/NVIDIA Tegra124 TK1-som board"
I think that should say:
bool "Colorado Engineering Inc TK1-som board"
I assume that NVIDIA had no part in creating this derivative; they simply created the board it was based on.
- (C) Copyright 2016 Peter Chubb
- Based on the jetson-tk1.h which is
There's trailing whitespace on that line.
I might suggest adding a : to the end of the line, so it's more obvious (when looking at just the added lines) that it's referring to the next line rather than a statement that wasn't finished.
- THIS FILE IS AUTO-GENERATED - DO NOT EDIT!
- To generate this file, use the tegra-pinmux-scripts tool available from
- Run "board-to-uboot.py cei-tk1-som".
Is that true? I'd like to see a patch for tegra-pinmux-scripts that adds the config file for this board too.
Aside from those minor issues, Acked-by: Stephen Warren swarren@nvidia.com
"Stephen" == Stephen Warren swarren@wwwdotorg.org writes:
Stephen> I think that should say:
Stephen> bool "Colorado Engineering Inc TK1-som board"
Stephen> I assume that NVIDIA had no part in creating this derivative; Stephen> they simply created the board it was based on.
As far a I know that's the case. It's an NVIDIA SoC though.
Stephen> There's trailing whitespace on that line.
Stephen> I might suggest adding a : to the end of the line, so it's Stephen> more obvious (when looking at just the added lines) that it's Stephen> referring to the next line rather than a statement that Stephen> wasn't finished.
OK. I need to fix the copyright header too (my employer wants a mention, which is fair enough as they're paying for me to do this work))
Stephen> Is that true? I'd like to see a patch for Stephen> tegra-pinmux-scripts that adds the config file for this board Stephen> too.
It's on its way. I'm currently trying to get the Linux DTS part working.
Stephen> Aside from those minor issues, Acked-by: Stephen Warren Stephen> swarren@nvidia.com
Thanks.
Stephen Warren
