[U-Boot] [PATCH] arm: dts: am33xx: add u-boot, dm-spl to ocp bus
commit fdce9d35dc36 ("arm: dts: am33xx: Sync dts with Linux 4.20.0") did remove the "u-boot,dm-spl" flag from the 'ocp' bus which was introduced with commit 19aa4ac09db9 ("dts: am33xx: add u-boot, dm-spl to ocp bus")
Due to this the brppt1_spi board is broken because it cannot bind/probe the spi-interface during SPL stage.
This commit adds this flag again.
This flag is needed for having access to the devices below this bus, most important is uart and boot-device (spi, mmc, ...) in SPL stage.
Signed-off-by: Hannes Schmelzer hannes.schmelzer@br-automation.com
arch/arm/dts/am33xx.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/am33xx.dtsi b/arch/arm/dts/am33xx.dtsi index d3dd6a1..0a6b177 100644 --- a/arch/arm/dts/am33xx.dtsi +++ b/arch/arm/dts/am33xx.dtsi @@ -160,6 +160,7 @@ * the whole bus hierarchy. */ ocp { + u-boot,dm-spl; compatible = "simple-bus"; #address-cells = <1>; #size-cells = <1>;
compatible = "simple-bus"; #address-cells = <1>; #size-cells = <1>;u-boot,dm-spl;
We need to put this into one of the -u-boot.dtsi files and then #include it from the others, so that we don't keep dropping this flag. Thanks!
Hi Tom, i'm not sure if we can do that this way because the "ocp" bus has no valid label like other elements. So we have at least to adjust the am33xx.dtsi file like this:
ocp : ocp { compatible = "simple-bus"; ..... }
what do you suggest ?
cheers, Hannes
Er, with the example of arch/arm/dts/am335x-pdu001-u-boot.dtsi should't we be able to just do that, globally? Or is that part _not_ working and relied on the now removed hunk?
Hi Tom, I'll verify this tomorrow. But the pdu001 looks good to me. This would be a solution for my boards too if it does the job. Keep you up to date.
cheers, Hannes
Thanks. Just keep in mind that if it works, we need am33xx-u-boot.dtsi with that, so it unbreaks all the SoC.
Hi Hannes,
Please CC me if you fix this by a patch adding a am33xx-u-boot.dtsi file.
regards Felix
On 2/1/19 12:15 PM, Felix Brack wrote:
Hi Hannes,
Hi Tom, Felix,
my boards are now up/running again. In fact the removed hunk really hurts all boards (which using dm in spl) with a few exceptions:
arch/arm/dts/am4372-generic-u-boot.dtsi: ocp { arch/arm/dts/am437x-idk-evm-u-boot.dtsi: ocp { arch/arm/dts/omap5-u-boot.dtsi: ocp { arch/arm/dts/am335x-pdu001-u-boot.dtsi: ocp { arch/arm/dts/am437x-gp-evm-u-boot.dtsi: ocp { arch/arm/dts/am437x-sk-evm-u-boot.dtsi: ocp {
Those do the trick within their own files, either with "u-boot,dm-spl;" or "u-boot,dm-pre-reloc;".
The ocp is in fact the root of all important peripheral, so they all have this within. Some files do also add the necessary "u-boot,dm-spl;" flag to some other devices which are needed for bring up SPL.
I would suggest to have a "am33xx-u-boot.dtsi" which provides the ""u-boot,dm-spl;" or "u-boot,dm-pre-reloc;" (not sure which one is the formal correct one), flag at least to the most important "ocp" and also to all devices from where the am335x can boot. Does anybody think that we may run into SPL size trouble, with this little bigger dtb blob in spl ?
So maybe we can finish the discussion during next week and then i will provide a patch adding/using some "am33xx-uboot.dtsi" file.
regards Felix
Hi Hannes,
>commit fdce9d35dc36 ("arm: dts: am33xx: Sync dts with Linux 4.20.0") >did remove the "u-boot,dm-spl" flag from the 'ocp' bus which was >introduced with >commit 19aa4ac09db9 ("dts: am33xx: add u-boot, dm-spl to ocp bus") > >Due to this the brppt1_spi board is broken because it cannot >bind/probe the spi-interface during SPL stage. > >This commit adds this flag again. > >This flag is needed for having access to the devices below this bus, >most important is uart and boot-device (spi, mmc, ...) in SPL stage. > >Signed-off-by: Hannes Schmelzer hannes.schmelzer@br-automation.com > >--- > > arch/arm/dts/am33xx.dtsi | 1 + > 1 file changed, 1 insertion(+) > >diff --git a/arch/arm/dts/am33xx.dtsi b/arch/arm/dts/am33xx.dtsi >index d3dd6a1..0a6b177 100644 >--- a/arch/arm/dts/am33xx.dtsi >+++ b/arch/arm/dts/am33xx.dtsi >@@ -160,6 +160,7 @@ > * the whole bus hierarchy. > */ > ocp { >+ u-boot,dm-spl; > compatible = "simple-bus"; > #address-cells = <1>; > #size-cells = <1>; We need to put this into one of the -u-boot.dtsi files and then #include it from the others, so that we don't keep dropping this flag. Thanks!
Hi Tom, Felix,
In this case, we want u-boot,dm-pre-reloc. To figure out which we would want in general, drivers/core/ofnode.c and drivers/core/util.c are easy to search for the few functions that check for "u-boot,dm-pre-reloc" as well as "u-boot,dm-spl" and "u-boot,dm-tpl". In all functions dm-pre-reloc is found in U-Boot, TPL and SPL while dm-spl/dm-tpl are found in their respective builds and full U-Boot but not their counterpart (ie u-boot,dm-tpl is true for TPL and U-Boot and false SPL). Thanks again!
Hi Hannes,
Hi Hannes,
> commit fdce9d35dc36 ("arm: dts: am33xx: Sync dts with Linux 4.20.0") > did remove the "u-boot,dm-spl" flag from the 'ocp' bus which was > introduced with > commit 19aa4ac09db9 ("dts: am33xx: add u-boot, dm-spl to ocp bus") > > Due to this the brppt1_spi board is broken because it cannot > bind/probe the spi-interface during SPL stage. > > This commit adds this flag again. > > This flag is needed for having access to the devices below this bus, > most important is uart and boot-device (spi, mmc, ...) in SPL stage. > > Signed-off-by: Hannes Schmelzer hannes.schmelzer@br-automation.com > > --- > > arch/arm/dts/am33xx.dtsi | 1 + > 1 file changed, 1 insertion(+) > > diff --git a/arch/arm/dts/am33xx.dtsi b/arch/arm/dts/am33xx.dtsi > index d3dd6a1..0a6b177 100644 > --- a/arch/arm/dts/am33xx.dtsi > +++ b/arch/arm/dts/am33xx.dtsi > @@ -160,6 +160,7 @@ > * the whole bus hierarchy. > */ > ocp { > + u-boot,dm-spl; > compatible = "simple-bus"; > #address-cells = <1>; > #size-cells = <1>; We need to put this into one of the -u-boot.dtsi files and then #include it from the others, so that we don't keep dropping this flag. Thanks!
Hi Tom, Felix,
As Tom already stated: dm-pre-reloc is correct here. More information and hints about when to use dm-pre-reloc, dm-spl and dm-tpl can be found in doc/driver-model/README.txt.
As dm-pre-reloc already existed in am33xx.dtsi before syncing this file with Linux 4.20.0 I don't think that size would be an issue.
Excellent, many thanks!
regards Felix
Felix Brack
Hannes Schmelzer
Hannes Schmelzer
