[U-Boot] [PATCH u-boot] ARM: arch-meson: fix writel arguments order
Using writel causes a "Synchronous Abort". Invert the arguments.
Signed-off-by: Hans Verkuil hans.verkuil@cisco.com Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/mach-meson/eth.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
Thanks Hans for finding this stupid error !
Neil
diff --git a/arch/arm/mach-meson/eth.c b/arch/arm/mach-meson/eth.c index 2debe93..8c6577b 100644 --- a/arch/arm/mach-meson/eth.c +++ b/arch/arm/mach-meson/eth.c @@ -38,8 +38,8 @@ void meson_gx_eth_init(phy_interface_t mode, unsigned int flags) /* Use GXL RMII Internal PHY */ if (IS_ENABLED(CONFIG_MESON_GXL) && (flags & MESON_GXL_USE_INTERNAL_RMII_PHY)) { - writel(GXBB_ETH_REG_2, 0x10110181); - writel(GXBB_ETH_REG_3, 0xe40908ff); + writel(0x10110181, GXBB_ETH_REG_2); + writel(0xe40908ff, GXBB_ETH_REG_3); }
break;
Neil
break;
Hi Tom,
Can this be merged ? This error breaks boot on 3 boards.
Thanks, Neil
Neil Armstrong
