[PATCH] gpio: add GPIOD_ACTIVE_LOW into GPIOD_MASK_DIR
dm_gpio_set_dir_flags() will clear GPIOD_MASK_DIR and set new flags. But there are cases like i2c_deblock_gpio_loop() will do like this:
-first conifg GPIO(SDA) output with GPIOD_ACTIVE_LOW dm_gpio_set_dir_flags(pin, GPIOD_IS_OUT | GPIOD_ACTIVE_LOW | GPIOD_IS_OUT_ACTIVE);
-then config GPIO input dm_gpio_set_dir_flags(pin, GPIOD_IS_IN);
-then get the GPIO input value: dm_gpio_get_value(pin);
When config the GPIO input, only set GPIOD_IS_IN, but unfortunately since the previous GPIOD_ACTIVE_LOW is not cleared, still keep in flags, make the value from dm_gpio_get_value() not logic correct.
So add GPIOD_ACTIVE_LOW into GPIOD_MASK_DIR to avoid this issue.
Signed-off-by: Haibo Chen haibo.chen@nxp.com --- include/asm-generic/gpio.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/asm-generic/gpio.h b/include/asm-generic/gpio.h index dd0bdf2315..903b237aac 100644 --- a/include/asm-generic/gpio.h +++ b/include/asm-generic/gpio.h @@ -131,7 +131,7 @@ struct gpio_desc {
/* Flags for updating the above */ #define GPIOD_MASK_DIR (GPIOD_IS_OUT | GPIOD_IS_IN | \ - GPIOD_IS_OUT_ACTIVE) + GPIOD_IS_OUT_ACTIVE | GPIOD_ACTIVE_LOW) #define GPIOD_MASK_DSTYPE (GPIOD_OPEN_DRAIN | GPIOD_OPEN_SOURCE) #define GPIOD_MASK_PULL (GPIOD_PULL_UP | GPIOD_PULL_DOWN)
Reviewed-by: Alexander Kochetkov al.kochet@gmail.com
- GPIOD_IS_OUT_ACTIVE | GPIOD_ACTIVE_LOW)
-- 2.34.1
Hi
#define GPIOD_MASK_DSTYPE (GPIOD_OPEN_DRAIN | GPIOD_OPEN_SOURCE) #define GPIOD_MASK_PULL (GPIOD_PULL_UP | GPIOD_PULL_DOWN)GPIOD_IS_OUT_ACTIVE | GPIOD_ACTIVE_LOW)
I think you are breaking the management of GPIOD_ACTIVE_LOW, provided by device tree in the GPIO uclass:
because the modified GPIOD_MASK_DIR is used in other location....
normally GPIOD_ACTIVE_LOW is saved in desc->flags
it is the "desciptor flags" and must be not cleary by normal API
see gpio_xlate_offs_flags() => gpio_flags_xlate()
For example in gpio_request_tail(), in the line:
/* Keep any direction flags provided by the devicetree */ ret = dm_gpio_set_dir_flags(desc, flags | (desc->flags& GPIOD_MASK_DIR)); With your patch the descriptor flags is cleared / so DT information is lost. For me GPIOD_ACTIVE_LOW must be managed carefully to avoid side effect. and if you inverse the PIN logical in device tree (GPIOD_ACTIVE_LOW) it is normal to inverse it for INPUT and OUTPUT it is managed in GPIO U-Class => dm_gpio_set_dir_flagsshould not cleared this flag GPIOD_ACTIVE_LOW you can change the caller ? static void i2c_gpio_set_pin(struct gpio_desc *pin, int bit) { if (bit) dm_gpio_set_dir_flags(pin, GPIOD_IS_IN); else dm_gpio_set_dir_flags(pin, GPIOD_IS_OUT | GPIOD_ACTIVE_LOW | GPIOD_IS_OUT_ACTIVE); } =>
static void i2c_gpio_set_pin(struct gpio_desc *pin, int bit) { if (bit) dm_gpio_set_dir_flags(pin, GPIOD_IS_IN); else dm_gpio_set_dir_flags(pin, GPIOD_IS_OUT); }
The output value is the same => GPIOD_ACTIVE_LOW and GPIOD_IS_OUT_ACTIVE not active but you don't need to modify GPIOD_ACTIVE_LOW outside the GPIO uclass. Patrick
-----Original Message----- From: Patrick DELAUNAY patrick.delaunay@foss.st.com Sent: 2023年3月23日 3:11 To: Bough Chen haibo.chen@nxp.com; al.kochet@gmail.com; hs@denx.de; sjg@chromium.org; andrew@aj.id.au; patrice.chotard@foss.st.com; samuel@sholland.org; marex@denx.de Cc: dl-uboot-imx uboot-imx@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH] gpio: add GPIOD_ACTIVE_LOW into GPIOD_MASK_DIR
Hi
#define GPIOD_MASK_DSTYPE (GPIOD_OPEN_DRAIN |GPIOD_IS_OUT_ACTIVE | GPIOD_ACTIVE_LOW)
GPIOD_OPEN_SOURCE)
GPIOD_PULL_DOWN)
Here, for i2c-deblock, when call dm_gpio_set_dir_flags(pin, GPIOD_IS_OUT), the software actually want to config the gpio at output, and config the output to low level. This means in dts, need to config the i2c gpio as GPIO_ACTIVE_HIGH, then when call dm_gpio_set_dir_flags(pin, GPIOD_IS_OUT), it finally config the value to 0, which means low level.
But from user point, we usually take the i2c gpio as GPIO_ACTIVE_LOW, seems a bit conflict.
Any thoughts? Or just use my first patch?
Best Regards Haibo Chen
Hi
GPIOD_OPEN_SOURCE)
GPIOD_PULL_DOWN)
I am lost (I am not dig in I2C GPIO part)
but if I assume that GPIO_ACTIVE_HIGH is NOT activated in DT
(because the GPIO line is directly connected to the I2C device)
Then GPIO line = HIGH => GPIO value is 1 for uclass (input or output)
=> dm_gpio_set_dir_flags(pin, GPIOD_IS_OUT);
if you want to have output LOW
=> dm_gpio_set_dir_flags(pin, GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE);
if you want to have output HIGH
You can select what it is expected.... in I2C
input => GPIO input selection
output => ouput value selected by bit
for example
i2c_gpio_set_pin(struct gpio_desc *pin, int input, int bit) {
if (input) dm_gpio_set_dir_flags(pin, GPIOD_IS_IN); else if (bit) dm_gpio_set_dir_flags(pin, GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); else dm_gpio_set_dir_flags(pin, GPIOD_IS_OUT); }
if the GPIO is inverted in DT (that means some inverse logic exist on hardware), with GPIO_ACTIVE_LOW
=> the result is inverted as expected for INPUT and OUTPUT
if the logic is always inverted => you need to change the caller (request 1 instead 0)
For me the SW side in U-boot should be not take care of GPIO_ACTIVE_LOW, except the GPIO uclass.
for me your patch is not acceptable
it solves the I2C GPIO issue but break ALL the other users of GPIO uclass.
Regards
Patrick
Alexander Kochetkov
Bough Chen
haibo.chen@nxp.com
Patrick DELAUNAY
