[PATCH] mtd: spi-nor: Keep CFR5V[6] as 1 in Octal DTR enable
CFR5V[6] is reserved bit and must always be 1.
Fixes: ea9a22f7e79c ("mtd: spi-nor-core: Add support for Cypress Semper flash") Signed-off-by: Takahiro Kuwano Takahiro.Kuwano@infineon.com --- include/linux/mtd/spi-nor.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/linux/mtd/spi-nor.h b/include/linux/mtd/spi-nor.h index 30f15452aa68..181eb6710d7e 100644 --- a/include/linux/mtd/spi-nor.h +++ b/include/linux/mtd/spi-nor.h @@ -194,7 +194,7 @@ #define SPINOR_REG_CYPRESS_CFR3V_PGSZ BIT(4) /* Page size. */ #define SPINOR_REG_CYPRESS_CFR3V_UNISECT BIT(3) /* Uniform sector mode */ #define SPINOR_REG_CYPRESS_CFR5V 0x00800006 -#define SPINOR_REG_CYPRESS_CFR5V_OCT_DTR_EN 0x3 +#define SPINOR_REG_CYPRESS_CFR5V_OCT_DTR_EN 0x43 #define SPINOR_OP_CYPRESS_RD_FAST 0xee
/* Supported SPI protocols */
Hi Takahiro,
I second Tudor's review on the linux-mtd mailing list here as well,
(493d9a10-aaf3-70f6-36c3-9a2cf39f0759@linaro.org)
This looks bad. Instead of overwriting CFR5V with whatever value, we should instead first read it and then update only the bit that we're interested in. If it happens to write CFR5V before octal enable/disable, you'll overwrite the previous set values.
Dhruva Gole
