[U-Boot] [PATCH] ARM: da850-evm: Enable filesystem commands when booting from NOR
The configuration with NOR is mutually exclusive with MMC, and as such, the filesystem commands were disabled. With the USB host enabled, this patch enables the file system command which can be executed on storage devices attached to the USB.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 1c0e237571..b4e0d08d7f 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -29,10 +29,6 @@ CONFIG_CMD_MTD=y # CONFIG_CMD_SPI is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_TIME is not set -# CONFIG_CMD_EXT2 is not set -# CONFIG_CMD_EXT4 is not set -# CONFIG_CMD_FAT is not set -# CONFIG_CMD_FS_GENERIC is not set CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=physmap-flash.2" CONFIG_MTDPARTS_DEFAULT="mtdparts=physmap-flash.2:1m(u-boot),128k(u-boot-env),-(spare)"
Adam Ford
