[U-Boot] [PATCH] powerpc 86xx: Handle CCSR relocation earlier
Currently, the CCSR gets relocated while translation is enabled, meaning we need 2 BAT translations to get to both the old location and the new location. Also, the DEFAULT CCSR location has a dependency on the BAT that maps the FLASH region. Moving the relocation removes this unnecessary dependency. This makes it easier and more intutive to modify the board's memory map.
Signed-off-by: Becky Bruce becky.bruce@freescale.com --- cpu/mpc86xx/start.S | 29 ++++++++++++++++++++++++----- 1 files changed, 24 insertions(+), 5 deletions(-)
diff --git a/cpu/mpc86xx/start.S b/cpu/mpc86xx/start.S index 75e4317..b1a23b4 100644 --- a/cpu/mpc86xx/start.S +++ b/cpu/mpc86xx/start.S @@ -219,6 +219,11 @@ boot_warm: sync #endif
+#if (CONFIG_SYS_CCSRBAR_DEFAULT != CONFIG_SYS_CCSRBAR) + /* setup ccsrbar now while we're in real mode */ + bl setup_ccsrbar +#endif + /* * Calculate absolute address in FLASH and jump there *------------------------------------------------------*/ @@ -281,10 +286,6 @@ in_flash: bl setup_bats sync
-#if (CONFIG_SYS_CCSRBAR_DEFAULT != CONFIG_SYS_CCSRBAR) - /* setup ccsrbar */ - bl setup_ccsrbar -#endif
/* run low-level CPU init code (from Flash) */ bl cpu_init_f @@ -365,10 +366,28 @@ invalidate_bats: * early_bats: * * Set up bats needed early on - this is usually the BAT for the - * stack-in-cache and the Flash + * stack-in-cache, the Flash, and CCSR space */ .globl early_bats early_bats: + /* IBAT 3 */ + lis r4, CONFIG_SYS_IBAT3L@h + ori r4, r4, CONFIG_SYS_IBAT3L@l + lis r3, CONFIG_SYS_IBAT3U@h + ori r3, r3, CONFIG_SYS_IBAT3U@l + mtspr IBAT3L, r4 + mtspr IBAT3U, r3 + isync + + /* DBAT 3 */ + lis r4, CONFIG_SYS_DBAT3L@h + ori r4, r4, CONFIG_SYS_DBAT3L@l + lis r3, CONFIG_SYS_DBAT3U@h + ori r3, r3, CONFIG_SYS_DBAT3U@l + mtspr DBAT3L, r4 + mtspr DBAT3U, r3 + isync + /* IBAT 5 */ lis r4, CONFIG_SYS_IBAT5L@h ori r4, r4, CONFIG_SYS_IBAT5L@l
Swap BATs 3 and 4 on 8610 so that all 86xx boards use the same BAT for CCSR space.
Signed-off-by: Becky Bruce becky.bruce@freescale.com --- Somehow when I split up my patches, I had lost the config changes for 8610 that swap BATs 3 and 4 so that all 86xx boards use the same BAT for CCSR. I've added that back here. FWIW, I hope to be able to clean up the BAT initialization in the future - the hardcoded nature of this stuff is really bad since multiple boards often share cpu code that is dependent on certain BATS having the mappings for certain regions.
-Becky
cpu/mpc86xx/start.S | 29 ++++++++++++++++++++++++----- include/configs/MPC8610HPCD.h | 24 +++++++++++++----------- 2 files changed, 37 insertions(+), 16 deletions(-)
/* run low-level CPU init code (from Flash) */ bl cpu_init_f @@ -365,10 +366,28 @@ invalidate_bats: * early_bats: * * Set up bats needed early on - this is usually the BAT for the - * stack-in-cache and the Flash + * stack-in-cache, the Flash, and CCSR space */ .globl early_bats early_bats: + /* IBAT 3 */ + lis r4, CONFIG_SYS_IBAT3L@h + ori r4, r4, CONFIG_SYS_IBAT3L@l + lis r3, CONFIG_SYS_IBAT3U@h + ori r3, r3, CONFIG_SYS_IBAT3U@l + mtspr IBAT3L, r4 + mtspr IBAT3U, r3 + isync + + /* DBAT 3 */ + lis r4, CONFIG_SYS_DBAT3L@h + ori r4, r4, CONFIG_SYS_DBAT3L@l + lis r3, CONFIG_SYS_DBAT3U@h + ori r3, r3, CONFIG_SYS_DBAT3U@l + mtspr DBAT3L, r4 + mtspr DBAT3U, r3 + isync + /* IBAT 5 */ lis r4, CONFIG_SYS_IBAT5L@h ori r4, r4, CONFIG_SYS_IBAT5L@l diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 67b2764..6f04127 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -370,27 +370,29 @@ #define CONFIG_SYS_IBAT2U CONFIG_SYS_DBAT2U
/* - * BAT3 32M Cache-inhibited, guarded - * 0xe200_0000 1M PCI-Express 2 I/O - * 0xe300_0000 1M PCI-Express 1 I/O + * BAT3 4M Cache-inhibited, guarded + * 0xe000_0000 4M CCSR */
-#define CONFIG_SYS_DBAT3L (CONFIG_SYS_PCIE2_IO_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT \ +#define CONFIG_SYS_DBAT3L (CONFIG_SYS_CCSRBAR | BATL_PP_RW | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_DBAT3U (CONFIG_SYS_PCIE2_IO_PHYS | BATU_BL_32M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCIE2_IO_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT) +#define CONFIG_SYS_DBAT3U (CONFIG_SYS_CCSRBAR | BATU_BL_1M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_CCSRBAR | BATL_PP_RW | BATL_CACHEINHIBIT) #define CONFIG_SYS_IBAT3U CONFIG_SYS_DBAT3U
/* - * BAT4 4M Cache-inhibited, guarded - * 0xe000_0000 4M CCSR + * BAT4 32M Cache-inhibited, guarded + * 0xe200_0000 1M PCI-Express 2 I/O + * 0xe300_0000 1M PCI-Express 1 I/O */ -#define CONFIG_SYS_DBAT4L (CONFIG_SYS_CCSRBAR | BATL_PP_RW | BATL_CACHEINHIBIT \ + +#define CONFIG_SYS_DBAT4L (CONFIG_SYS_PCIE2_IO_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_DBAT4U (CONFIG_SYS_CCSRBAR | BATU_BL_1M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_CCSRBAR | BATL_PP_RW | BATL_CACHEINHIBIT) +#define CONFIG_SYS_DBAT4U (CONFIG_SYS_PCIE2_IO_PHYS | BATU_BL_32M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCIE2_IO_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT) #define CONFIG_SYS_IBAT4U CONFIG_SYS_DBAT4U
+ /* * BAT5 128K Cacheable, non-guarded * 0xe400_0000 128K Init RAM for stack in the CPU DCache (no backing memory)
Applied to u-boot-mpc86xx.
Thanks, jdl
Becky Bruce
Jon Loeliger
